[U-Boot] [PATCH] script: Make the get_default_envs.sh script working with newest u-boot
This commit fixes several issues:
- After moving env related code to ./env directory the env_common.o file is no longer present in the system (has been replaced with built-in.o).
- Use ${OBJCOPY} if available, fallback to system default's objcopy if not present.
- Extend the script to accept different build directory than current one. It is extremely handy with OE usage, where source code is separated from build.
Signed-off-by: Lukasz Majewski lukma@denx.de ---
scripts/get_default_envs.sh | 19 ++++++++++++++----- 1 file changed, 14 insertions(+), 5 deletions(-)
diff --git a/scripts/get_default_envs.sh b/scripts/get_default_envs.sh index 7955db60e5..bbb6d0a6ef 100755 --- a/scripts/get_default_envs.sh +++ b/scripts/get_default_envs.sh @@ -6,16 +6,24 @@ #
# This file extracts default envs from built u-boot -# usage: get_default_envs.sh > u-boot-env-default.txt +# usage: get_default_envs.sh [build dir] > u-boot-env-default.txt set -ue
-ENV_OBJ_FILE="env_common.o" +: "${OBJCOPY:=objcopy}" + +ENV_OBJ_FILE="built-in.o" ENV_OBJ_FILE_COPY="copy_${ENV_OBJ_FILE}"
echoerr() { echo "$@" 1>&2; }
-path=$(readlink -f $0) -env_obj_file_path=$(find ${path%/scripts*} -not -path "*/spl/*" \ +if [ "$#" -eq 1 ]; then + path=${1} +else + path=$(readlink -f $0) + path=${path%/scripts*} +fi + +env_obj_file_path=$(find ${path} -path "*/env/*" -not -path "*/spl/*" \ -name "${ENV_OBJ_FILE}") [ -z "${env_obj_file_path}" ] && \ { echoerr "File '${ENV_OBJ_FILE}' not found!"; exit 1; } @@ -24,7 +32,8 @@ cp ${env_obj_file_path} ${ENV_OBJ_FILE_COPY}
# NOTE: objcopy saves its output to file passed in # (copy_env_common.o in this case) -objcopy -O binary -j ".rodata.default_environment" ${ENV_OBJ_FILE_COPY} + +${OBJCOPY} -O binary -j ".rodata.default_environment" ${ENV_OBJ_FILE_COPY}
# Replace default '\0' with '\n' and sort entries tr '\0' '\n' < ${ENV_OBJ_FILE_COPY} | sort -u
present.
- path=${1}
+else
- path=$(readlink -f $0)
- path=${path%/scripts*}
+fi
Tested-by: Alex Kiernan alex.kiernan@gmail.com
present.
Maybe "${CROSS_COMPILE}objcopy" would be a better default as that's what the build system uses.
if not present.
Unfortunately not with OE builds. In OE, the OBJCOPY is set to arm specific objcopy.
With fallback (objcopy) from your local machine - it depends if it supports multi arch or not.
A side note:
I do use this script with /tools/mkenvimage to generate default main and redundant envs.
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
if not present.
No, I meant that instead of having a fallback of "objcopy", have a fallback of "${CROSS_COMPILE}objcopy". I.e. squashing this change:
diff --git a/scripts/get_default_envs.sh b/scripts/get_default_envs.sh index 3e532d12c4..184cc19ab7 100755 --- a/scripts/get_default_envs.sh +++ b/scripts/get_default_envs.sh @@ -9,7 +9,7 @@ # usage: get_default_envs.sh [build dir] > u-boot-env-default.txt set -ue
-: "${OBJCOPY:=objcopy}" +: "${OBJCOPY:=${CROSS_COMPILE:-}objcopy}"
That way the script works out-of-the-box for people who do the usual
export CROSS_COMPILE=aarch64-linux-gnu- (or whatever)
when building U-Boot.
Hi Tuomas,
Yes, you are obviously right. I've misunderstood you, sorry.
I will prepare v3 immediately.
Thanks.
Lukasz Majewski
Alex Kiernan
Lukasz Majewski
Tuomas Tynkkynen
