[PATCH 0/3] mmc support for QEMU
This patch series allows you to use a mmc drive from within QEMU:
1. make qemu_arm_defconfig 2. Enable the CONFIG_DM_MMC, CONFIG_MMC_PCI, CONFIG_MMC_SDHCI options 3. Run quemu as follows:
qemu-system-arm -machine virt,highmem=off \ -device sdhci-pci \ -device sd-card,drive=mydrive \ -drive id=mydrive,if=none,format=raw,file=mmcblk0.bin \ -bios u-boot.bin
The MMC image can now be used to boot :)
Regards, Harm
Harm Berntsen (3): gpio: do not include <asm/arch/gpio.h> on ARCH_QEMU acpi: Only include asm table when available mmc: Only retrieve cd pin when GPIO is enabled
arch/arm/include/asm/gpio.h | 3 ++- drivers/mmc/pci_mmc.c | 2 ++ include/acpi/acpi_table.h | 2 ++ 3 files changed, 6 insertions(+), 1 deletion(-)
I don't see changes made to qemu_arm_defconfig. Is that a future patch?
Regards, Bin
I didn't include changes in the defconfig because you need to manually add the device to the QEMU virt machine via the command line. On the other hand the u-boot binary size does not really matter for QEMU environments. For CI it will also be nice to ensure this set-up will build.
I'll send in a patch for the config when this series has been merged!
Kind regards, Harm
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com To: Harm Berntsen harm.berntsen@nedap.com Cc: u-boot@lists.denx.de u-boot@lists.denx.de Subject: Re: [PATCH 0/3] mmc support for QEMU Date: Fri, 30 Oct 2020 22:34:10 +0800
- make qemu_arm_defconfig
- Enable the CONFIG_DM_MMC, CONFIG_MMC_PCI, CONFIG_MMC_SDHCI options
- Run quemu as follows:
Regards, Bin
Bin Meng
Harm Berntsen
