[U-Boot-Users] [PATCH] DM9000 driver
The logic to check if there is a correct MAC address in the DM9000 EEPROM, added in the last patch, is wrong. Now the MAC address is always taken from the environment, even if a suitable MAC is present in the EEPROM.
Signed-off-by: Stefano Babic sbabic@denx.de
Your patch is backwards (stuff to remove should be - and to add should be +), and so won't apply. The same goes for the TFTP one.
From 432445542c9ebc11cc9d4ed4200de3671a2cf029 Mon Sep 17 00:00:00 2001
From: Stefano Babic sbabic@denx.de Date: Tue, 21 Aug 2007 12:46:34 +0200 Subject: [PATCH] The logic to check if there is a correct MAC address in the DM9000 EEPROM, added in the last patch, is wrong. Now the MAC address is always taken from the environment, even if a suitable MAC is present in the EEPROM. Time to wait reading the EEPROM is set to 8ms according to the linux driver
drivers/dm9000x.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/dm9000x.c b/drivers/dm9000x.c index e0d531b..78acb09 100644 --- a/drivers/dm9000x.c +++ b/drivers/dm9000x.c @@ -303,8 +303,8 @@ eth_init(bd_t * bd) for (i = 0; i < 6; i++) ((u16 *) bd->bi_enetaddr)[i] = read_srom_word(i);
- if (is_zero_ether_addr(bd->bi_enetaddr) ||
is_multicast_ether_addr(bd->bi_enetaddr)) {
- if (!is_zero_ether_addr(bd->bi_enetaddr) &&
/* try reading from environment */ u8 i; char *s, *e;!is_mutlicast_ether_addr(bd->bi_enetaddr)) {
@@ -542,7 +542,7 @@ read_srom_word(int offset) { DM9000_iow(DM9000_EPAR, offset); DM9000_iow(DM9000_EPCR, 0x4);
- udelay(8000);
- udelay(200);
Does the 200us delay not work, or are you just doing this to match the Linux driver?
Sorry, I submit the correct ones:
In message 46CAEDA9.7010100@denx.de you wrote:
This is a multi-part message in MIME format. --------------080308050605080402030006 Content-Type: text/plain; charset=ISO-8859-1; format=flowed Content-Transfer-Encoding: 7bit
Applied, thanks.
Ben Warren
stefano babic
