[U-Boot] igep0030_nand_defconfig compile is broken
Hello
on current HEAD of mainline code, compile for "igep0030_nand_defconfig" is broken:
arm-linux-gnueabi-ld.bfd: u-boot-spl section `.data' will not fit in region `.sram' arm-linux-gnueabi-ld.bfd: region `.sram' overflowed by 1176 bytes scripts/Makefile.spl:247: recipe for target 'spl/u-boot-spl' failed make[1]: *** [spl/u-boot-spl] Error 1 Makefile:1334: recipe for target 'spl/u-boot-spl' failed make: *** [spl/u-boot-spl] Error 2
a git bisect shows:
$ git bisect bad 578ec3b1fb3f4e85d8243d442f66f308c94b791d is the first bad commit commit 578ec3b1fb3f4e85d8243d442f66f308c94b791d Author: Alexander Graf agraf@suse.de Date: Mon Apr 11 16:16:21 2016 +0200
distro: Enable iso partition code
Now that we can properly boot EFI payloads from iso el torito images, let's enable support for isos by default in the distro header.
Signed-off-by: Alexander Graf agraf@suse.de
:040000 040000 ba4615980d26ef80e9b9e5ce9fc2440456c556cb 6d0ba56e5ed81ea54d37566763f3f225bd2d00ad M include pollux:u-boot hs [(kein Branch, binäre Suche begonnen bei master)] $
buildman show 3 boards:
arm: + igep0030_nand +arm-linux-gnueabi-ld.bfd: u-boot-spl section `.data' will not fit in region `.sram' +arm-linux-gnueabi-ld.bfd: region `.sram' overflowed by 1236 bytes +make[2]: *** [spl/u-boot-spl] Error 1 +make[1]: *** [spl/u-boot-spl] Error 2 +make: *** [sub-make] Error 2 arm: + duovero +arm-linux-gnueabi-ld.bfd: u-boot-spl section `.data' will not fit in region `.sram' +arm-linux-gnueabi-ld.bfd: region `.sram' overflowed by 816 bytes +make[2]: *** [spl/u-boot-spl] Error 1 +make[1]: *** [spl/u-boot-spl] Error 2 +make: *** [sub-make] Error 2 arm: + igep0020_nand +arm-linux-gnueabi-ld.bfd: u-boot-spl section `.data' will not fit in region `.sram' +arm-linux-gnueabi-ld.bfd: region `.sram' overflowed by 1220 bytes +make[2]: *** [spl/u-boot-spl] Error 1 +make[1]: *** [spl/u-boot-spl] Error 2 +make: *** [sub-make] Error 2 517 0 40 /557 q8_a13_tablet
Could somebody provide a fix for this boards?
Thanks!
bye, Heiko
On 04/25/2016 11:36 AM, Heiko Schocher wrote:
Hello
a git bisect shows:
distro: Enable iso partition code Now that we can properly boot EFI payloads from iso el torito images, let's enable support for isos by default in the distro header. Signed-off-by: Alexander Graf <agraf@suse.de>
Ouch, I didn't realize that distro defconfigs flow into SPL as well. Is there any streamlined way to only select default config options for SPL?
Alex
Hello
a git bisect shows:
As much as anything else it's also how gcc (prior to 6) combines strings prior to -fdata-sections/-ffunction-sections. Just need to find something or another that can come out of igep, most likely.
Alexander Graf
Heiko Schocher
