[U-Boot] Support required for PPC440gx
Hi Sir,
I am Sadashiva Reddy working in Mistral Solutions Pvt Ltd.
I am using AMCC PPC440Gx processor for our project presently the board is working with vxWorks. But our customer new requirement is same board should be ported with linux but porting time is very less.
So, I am asking the help from you.
Where do I get proper U-boot and kernel source code for the below mentioned specification or nearly related board specfication from your website.
Can I get any link where I can get the working u-boot and kernel code for the below specification or near to the specfication.
Board sprecification details are.
1. Proccessor = PPC440gx 2. NOR flash = Size 128MB 3. SDRAM = 256 MB 4. PHY = RGMII 5. UART = RS 232 6. FRAM or EEPROM = 2KB 7. VC0 = 1333 MHz 8. SysClock = 33.33 MHz Feedback is CPU core clock. 9. Memclock = 133.33 MHz 10. OPBClcok = 66.66 MHz 11. PerClock = 66.66 MHz
Best Regards, Sadashiv
Hi Sadashiv,
No, I'm afraid its not that easy. You seem to have a custom PPC440GX board which is not supported in mainline U-Boot and Linux. So there is no link to a "working u-boot and kernel code" for such a configuration. The 440GX is supported in U-Boot and Linux though (even if its not tested for quite some time). Best you could do is base your work on a supported 440GX board, for example the IBM/AMCC/AMP Ocotea board. But you need to port this code to your custom board.
So either go ahead and do the porting yourself (feel free to ask some questions while doing this on the lists), or if time is critical and you have no experience here you might consider to hire an expert to do this.
Hope this helps a bit.
Best regards, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: office@denx.de
Sadashiva Reddy N
Stefan Roese
