[U-Boot] [PATCH] atngw100: convert to generic board
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com --- Tested on an atngw100 thankfully provided by Waldemar. Thus http://patchwork.ozlabs.org/patch/470705/ is not required.
include/configs/atngw100.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index 540e86a..ef4e2fc 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -14,6 +14,10 @@ #define CONFIG_AT32AP7000 #define CONFIG_ATNGW100
+#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_EARLY_INIT_R + /* * Set up the PLL to run at 140 MHz, the CPU to run at the PLL * frequency, the HSB and PBB busses to run at 1/2 the PLL frequency
Dear =?utf-8?q?Andreas_Bie=C3=9Fmann?=,
Andreas Devel andreas.devel@googlemail.com writes:
applied to u-boot-avr32/master, thanks!
Best regards, Andreas Bießmann
Andreas Bießmann
