[U-Boot] [PATCH v3] fdt: allow address translation in case of SPL_OF_TRANSLATE
Address translation is not working at present even if SPL_OF_TRANSLATE is enabled which makes this configuration useless. This patch enables address translation for SPL U-Boot when SPL_OF_TRANSLATE is selected.
Signed-off-by: Vikas Manocha vikas.manocha@st.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v3: changed "u-boot" to "U-Boot" in commit message. Changes in v2: Added commit message
lib/fdtdec.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 81f47ef..a1c4d16 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -112,7 +112,7 @@ fdt_addr_t fdtdec_get_addr_size_fixed(const void *blob, int node, return FDT_ADDR_T_NONE; }
-#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_OF_LIBFDT) +#if defined(CONFIG_SPL_OF_TRANSLATE) || defined(CONFIG_OF_LIBFDT) if (translate) addr = fdt_translate_address(blob, node, prop_addr); else
Hi Vikas,
-#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_OF_LIBFDT) +#if defined(CONFIG_SPL_OF_TRANSLATE) || defined(CONFIG_OF_LIBFDT) if (translate) addr = fdt_translate_address(blob, node, prop_addr); else -- 1.9.1
Actually I'm a bit unsure about this patch. You already have a patch applied:
5efa1bf libfdt: use CONFIG_IS_ENABLED for OF_LIBFDT
Do you actually want this one else well? If so, please resend it as it conflicts.
Hi Simon,
On 04/04/2017 08:27 PM, Simon Glass wrote:
Hi Vikas,
This patch(5efa1bf) was recently applied & serves the same purpose. We can ignore my patch.
Cheers, Vikas
Regards, Simon .
Vikas Manocha
