[U-Boot] Boot X86 PC from USB using U_boot
Hi all please help me
Am a beginner in Linux. I have a PC with UBUNTU 9.04 installed . I was trying to boot Linux PC from USB. I could able to boot PC with GRUB installed in USB .
Is it possible to boot the PC (X86 architecture) from USB with U-Boot in the USB?
What all configuration changes I need do to make this possible?
I have downloaded U-boot then configured and build for X86 architecture (sc520_cdp_config) And made a bootable partition in usb and copied u-boot image in to it and tried to boot from usb but It is not working.
Please help me in this.................
With best regards, Anoop Sasi
Theoretically, yes. Practically, it would be a *LOT* of work and require hardware details that you probably cannot get (chipset register definitions, how to initialize them, etc.).
With GRUB, the manufacturer's BIOS initialize the chipset and then boots GRUB -> linux based on the already configured hardware. U-Boot initializes the hardware, so you need the information that the PC BIOS / hardware manufacturer has (and won't tell you) to replace BIOS+GRUB with U-Boot.
There is some support for x86 in u-boot, but it is for one (?) specific x86 CPU, the AMD sc520, and your PC probably isn't running that. http://git.denx.de/?p=u-boot.git;a=tree;f=cpu/i386;h=cf975ccb545ea90c755b573...
That is a huge open-ended question. We don't have an answer.
You probably don't have a sc520.
Use the BIOS + GRUB. It works very well.
Best regards, gvb
Jerry Van Baren
