[U-Boot] [PATCH] Add support for KMC KZM-ARM11-01 board
This patch adds support for KMC KZM-ARM11-01 board.
Signed-off-by Atsuo Igarashi atsuo_igarashi@tripeaks.co.jp
MAKEALL | 1 + Makefile | 3 + board/kzm_arm11/Makefile | 49 +++++++ board/kzm_arm11/config.mk | 1 + board/kzm_arm11/kzm_arm11.c | 108 ++++++++++++++ board/kzm_arm11/lowlevel_init.S | 297 +++++++++++++++++++++++++++++++++++++++ board/kzm_arm11/u-boot.lds | 72 ++++++++++ include/asm-arm/mach-types.h | 13 ++ include/configs/kzm_arm11.h | 202 ++++++++++++++++++++++++++ 9 files changed, 746 insertions(+), 0 deletions(-) create mode 100644 board/kzm_arm11/Makefile create mode 100644 board/kzm_arm11/config.mk create mode 100644 board/kzm_arm11/kzm_arm11.c create mode 100644 board/kzm_arm11/lowlevel_init.S create mode 100644 board/kzm_arm11/u-boot.lds create mode 100644 include/configs/kzm_arm11.h
diff --git a/MAKEALL b/MAKEALL index e807063..8dab1b6 100755 --- a/MAKEALL +++ b/MAKEALL @@ -517,6 +517,7 @@ LIST_ARM11=" \ imx31_litekit \ imx31_phycore \ mx31ads \
- kzm_arm11 \
please keep sorted
######################################################################### diff --git a/Makefile b/Makefile index 89fea72..26af973 100644 --- a/Makefile +++ b/Makefile @@ -2746,6 +2746,9 @@ imx31_phycore_config : unconfig mx31ads_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 mx31ads freescale mx31
+kzm_arm11_config : unconfig
- @$(MKCONFIG) $(@:_config=) arm arm1136 kzm_arm11 NULL mx31
ditto
omap2420h4_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 omap2420h4 NULL omap24xx
- __REG(CSCR_A(0)) = 0x00450000;
- __REG(CSCR_U(1)) = 0x00001801;
- __REG(CSCR_L(1)) = 0x45450D01;
- __REG(CSCR_A(1)) = 0x00450000;
- /* setup pins for UART1 */
- mx31_gpio_mux(MUX_RXD1__UART1_RXD_MUX);
- mx31_gpio_mux(MUX_TXD1__UART1_TXD_MUX);
- mx31_gpio_mux(MUX_RTS1__UART1_RTS_B);
- mx31_gpio_mux(MUX_CTS1__UART1_CTS_B);
- /* SPI2 */
- mx31_gpio_mux(MUX_CSPI2_SS2__CSPI2_SS2_B);
- mx31_gpio_mux(MUX_CSPI2_SCLK__CSPI2_CLK);
- mx31_gpio_mux(MUX_CSPI2_SPI_RDY__CSPI2_DATAREADY_B);
- mx31_gpio_mux(MUX_CSPI2_MOSI__CSPI2_MOSI);
- mx31_gpio_mux(MUX_CSPI2_MISO__CSPI2_MISO);
- mx31_gpio_mux(MUX_CSPI2_SS0__CSPI2_SS0_B);
- mx31_gpio_mux(MUX_CSPI2_SS1__CSPI2_SS1_B);
- /* start SPI2 clock */
- __REG(CCM_CGR2) = __REG(CCM_CGR2) | (3 << 4);
- /* PBC setup */
- /* Enable UART transceivers also reset the Ethernet/external UART */
- readw(CS4_BASE + 4);
- writew(0x8023, CS4_BASE + 4);
- /* RedBoot also has an empty loop with 100000 iterations here -
* clock doesn't run yet */
- for (i = 0; i < 100000; i++)
- /* Clear the reset, toggle the LEDs */
- writew(0xDF, CS4_BASE + 6);
- /* clock still doesn't run */
- /* See 1.5.4 in IMX31ADSE_PERI_BUS_CNTRL_CPLD_RM.pdf */
- readb(CS4_BASE + 8);
- readb(CS4_BASE + 7);
- gd->bd->bi_arch_number = MACH_TYPE_KZM_ARM11_01;/* board id for linux */
- gd->bd->bi_boot_params = 0x80000100; /* adress of boot parameters */
+int checkboard (void) +{
- printf("Board: KZM-ARM11-01\n");
+} diff --git a/board/kzm_arm11/lowlevel_init.S b/board/kzm_arm11/lowlevel_init.S new file mode 100644 index 0000000..91d5c9b --- /dev/null +++ b/board/kzm_arm11/lowlevel_init.S
- ldr r1, [r0, #0x50]
- and r1, r1, #0x00FFFFFF
- str r1, [r0, #0x50]
+.endm /* init_aips */
in this file there is some whitespace please fix it
+/* RedBoot: MAX (Multi-Layer AHB Crossbar Switch) setup */ +.macro init_max
- ldr r0, =0x43F04000
- /* MPR - priority is M4 > M2 > M3 > M5 > M0 > M1 */
- ldr r1, =0x00302154
- str r1, [r0, #0x000] /* for S0 */
- str r1, [r0, #0x100] /* for S1 */
- str r1, [r0, #0x200] /* for S2 */
- str r1, [r0, #0x300] /* for S3 */
- str r1, [r0, #0x400] /* for S4 */
- /* SGPCR - always park on last master */
- ldr r1, =0x10
- str r1, [r0, #0x010] /* for S0 */
- str r1, [r0, #0x110] /* for S1 */
- str r1, [r0, #0x210] /* for S2 */
- str r1, [r0, #0x310] /* for S3 */
- str r1, [r0, #0x410] /* for S4 */
- /* MGPCR - restore default values */
- ldr r1, =0x0
- str r1, [r0, #0x800] /* for M0 */
- str r1, [r0, #0x900] /* for M1 */
- str r1, [r0, #0xA00] /* for M2 */
- str r1, [r0, #0xB00] /* for M3 */
- str r1, [r0, #0xC00] /* for M4 */
- str r1, [r0, #0xD00] /* for M5 */
+.endm /* init_max */
+/* RedBoot: M3IF setup */ +.macro init_m3if
- /* Configure M3IF registers */
- ldr r1, =0xB8003000
- str r1, [r0, #0x54]
- ldr r1, =0x00340000
- str r1, [r0, #0x58]
+.endm /* init_cs5 */
+.globl lowlevel_init +lowlevel_init:
- /* Redboot initializes very early AIPS, what for?
* Then it also initializes Multi-Layer AHB Crossbar Switch,
* M3IF */
- /* Also setup the Peripheral Port Remap register inside the core */
- ldr r0, =0x40000015 /* start from AIPS 2GB region */
- mcr p15, 0, r0, c15, c2, 4
- init_aips
- init_max
- init_m3if
- init_drive_strength
- init_cs4
- /* Image Processing Unit: */
- /* Too early to switch display on? */
- REG IPU_CONF, IPU_CONF_DI_EN /* Switch on Display Interface */
- /* Clock Control Module: */
- REG CCM_CCMR, 0x074B0BF5 /* Use CKIH, MCU PLL off */
- DELAY 0x40000
- REG CCM_CCMR, 0x074B0BF5 | CCMR_MPE /* MCU PLL on */
- REG CCM_CCMR, (0x074B0BF5 | CCMR_MPE) & ~CCMR_MDS /* Switch to MCU PLL */
- /* PBC CPLD on CS4 */
- mov r1, #CS4_BASE
- ldrh r1, [r1, #0x2]
- /* Is 27MHz switch set? */
- ands r1, r1, #0x10
- /* 532-133-66.5 */
- ldr r0, =CCM_BASE
- ldr r1, =0xFF872660
- /* PDR0 */
- str r1, [r0, #0x4]
- ldreq r1, MPCTL_PARAM_532
- ldrne r1, MPCTL_PARAM_532_27
- /* MPCTL */
- str r1, [r0, #0x10]
- /* Set UPLL=240MHz, USB=60MHz */
+/* ldr r1, =0x49FCFE7F*/
if no need please remove
- /* PDR1 */
+/* str r1, [r0, #0x8]*/
- ldreq r1, UPCTL_PARAM_240
- ldrne r1, UPCTL_PARAM_240_27
- /* UPCTL */
- str r1, [r0, #0x14]
- /* default CLKO to 1/8 of the ARM core */
- mov r1, #0x000002C0
- add r1, r1, #0x00000006
- /* COSR */
- str r1, [r0, #0x1c]
- /* RedBoot sets 0x1ff, 7, 3, 5, 1, 3, 0 */
+/* REG CCM_PDR0, PDR0_CSI_PODF(0x1ff) | PDR0_PER_PODF(7) | PDR0_HSP_PODF(2) | PDR0_NFC_PODF(6) | PDR0_IPG_PODF(1) | PDR0_MAX_PODF(2) | PDR0_MCU_PODF(0)*/
- /* Redboot: 0, 51, 10, 12 / 0, 14, 9, 13 */
+/* REG CCM_MPCTL, PLL_PD(0) | PLL_MFD(0x33) | PLL_MFI(7) | PLL_MFN(0x23)*/
- /* Default: 1, 4, 12, 1 */
- REG CCM_SPCTL, PLL_PD(1) | PLL_MFD(4) | PLL_MFI(12) | PLL_MFN(1)
- /* B8xxxxxx - NAND, 8xxxxxxx - CSD0 RAM */
- REG 0xB8001010, 0x00000004
- REG 0xB8001004, 0x0079d72a
- REG 0xB8001000, 0x92100000
- REG 0x80000f00, 0x12344321
- REG 0xB8001000, 0xa2100000
- REG 0x80000000, 0x12344321
- REG 0xB8001000, 0xb2100000
- REG8 0x81000020, 0x00
- REG8 0x80000033, 0xda
+/* REG8 0x81000000, 0xff*/
- REG 0xB8001000, 0x82226080
- REG 0x80000000, 0xDEADBEEF
- REG 0xB8001010, 0x0000000c
- init_cs5
- mov pc, lr
+MPCTL_PARAM_532:
- .word (((1-1) << 26) + ((52-1) << 16) + (10 << 10) + (12 << 0))
+MPCTL_PARAM_532_27:
- .word (((1-1) << 26) + ((15-1) << 16) + (9 << 10) + (13 << 0))
+UPCTL_PARAM_240:
- .word (((2-1) << 26) + ((13-1) << 16) + (9 << 10) + (3 << 0))
+UPCTL_PARAM_240_27:
- .word (((2-1) << 26) + ((9 -1) << 16) + (8 << 10) + (8 << 0))
diff --git a/board/kzm_arm11/u-boot.lds b/board/kzm_arm11/u-boot.lds new file mode 100644 index 0000000..bb5390e --- /dev/null +++ b/board/kzm_arm11/u-boot.lds @@ -0,0 +1,72 @@ +/*
- Derived from mx31ads
- January 2004 - Changed to support H4 device
- Copyright (c) 2004 Texas Instruments
- (C) Copyright 2002
- Gary Jennejohn, DENX Software Engineering, gj@denx.de
- project.
- MA 02111-1307 USA
+OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{
please use tab for indentation and fix whitespace
- . = 0x00000000;
- . = ALIGN(4);
- .text :
/* WARNING - the following is hand-optimized to fit within */
/* the sector layout of our flash chips! XXX FIXME XXX */
cpu/arm1136/start.o (.text)
board/kzm_arm11/libkzm_arm11.a (.text)
lib_arm/libarm.a (.text)
net/libnet.a (.text)
drivers/mtd/libmtd.a (.text)
. = DEFINED(env_offset) ? env_offset : .;
common/environment.o(.text)
*(.text)
diff --git a/include/configs/kzm_arm11.h b/include/configs/kzm_arm11.h new file mode 100644 index 0000000..8a467bc --- /dev/null +++ b/include/configs/kzm_arm11.h @@ -0,0 +1,202 @@ +/*
- Copyright (C) 2008, Guennadi Liakhovetski lg@denx.de
- Configuration settings for the KMC KZM-ARM11-01 board.
- MA 02111-1307 USA
+#ifndef __CONFIG_H +#define __CONFIG_H
+#include <asm/arch/mx31-regs.h>
- /* High Level Configuration Options */
+#define CONFIG_ARM1136 1 /* This is an arm1136 CPU core */ +#define CONFIG_MX31 1 /* in a mx31 */ +#define CONFIG_MX31_HCLK_FREQ 26000000 /* RedBoot says 26MHz */ +#define CONFIG_MX31_CLK32 32768
+#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO
- Disabled for now due to build problems under Debian and a significant increase
- in the final file size: 144260 vs. 109536 Bytes.
+#if 0 +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_FIT 1 +#define CONFIG_FIT_VERBOSE 1 +#endif
please remove if no need
+#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1
Best Regards, J.please remove if no need
Atsuo Igarashi
Jean-Christophe PLAGNIOL-VILLARD
