RE: [U-Boot-Users] Booting MPC8272ADS from flash base
Alex,
Again at work. I have some comment over those changes
For the record here is the change I needed to make to u-boot-1.1.3.
Index: board/mpc8260ads/config.mk
RCS file: /newcvs/pq2-linux/u-boot/board/mpc8260ads/config.mk,v retrieving revision 1.1.1.1 diff -u -r1.1.1.1 config.mk --- board/mpc8260ads/config.mk 24 Aug 2005 12:16:55 -0000 1.1.1.1 +++ board/mpc8260ads/config.mk 14 Oct 2005 08:36:46 -0000 @@ -29,4 +29,4 @@ # MPC8260ADS, MPC8266ADS, and PQ2FADS-ZU/VR boards #
-TEXT_BASE = 0xfff00000 +TEXT_BASE = 0xff800000
Are you sure you are using u-boot-1.1.3? Patch from Jerry Van Baren already made some changes to this file to allow the use of a different TEXT__BASE for lowboot in MPC8272ADS selecting it from Makefile config target. I have this changes already applied in 1.1.3.
Index: include/configs/MPC8260ADS.h
RCS file: /newcvs/pq2-linux/u-boot/include/configs/MPC8260ADS.h,v retrieving revision 1.1.1.1 diff -u -r1.1.1.1 MPC8260ADS.h --- include/configs/MPC8260ADS.h 24 Aug 2005 12:17:01 -0000 1.1.1.1 +++ include/configs/MPC8260ADS.h 14 Oct 2005 08:36:46 -0000 @@ -294,13 +294,8 @@ #define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) #define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET
+#define CFG_HRCW_MASTER 0x0e72b605 /* like BCSR version, but with CIP=1, BMS=1 */
In order lowboot patch from Jerry to work (which has been applied to u-boot source, so I recommned you to use) in MPC8272ADS, ISB must also be ISB=100, not ISB=010 as in BCSR.
Also, from MPC8272RM, bits 20-21 are reserved and should be cleared. So, LBPC=00, although 01 works.
And finally a question. You use MODCK_H = 0101 whereas I use in my patch MODCK_H=1010, while trying to set MODCK to 1010_100. Am I mis-understanding something?
Alex Bastos
alebas@televes.com
