[PATCH v4, 1/2] driver: watchdog: reset watchdog in designware_wdt_stop() function
In uboot command line environment, watchdog is not able to be stopped with below commands: SOCFPGA_STRATIX10 # wdt dev watchdog@ffd00200 SOCFPGA_STRATIX10 # wdt stop Refer to watchdog driver in linux kernel, it is also need to reset watchdog after disable it so that the disable action takes effect.
Signed-off-by: Meng Li Meng.Li@windriver.com Reviewed-by: Stefan Roese sr@denx.de
--- v4: Remove the unauthorized signature. v3: Add the resets to designware_wdt_priv and initialize it in probe(). v2: Change "#if CONFIG_IS_ENABLED(DM_RESET)" into "if (CONFIG_IS_ENABLED(DM_RESET)) {", and define the variable into if condition sentence. --- drivers/watchdog/designware_wdt.c | 31 +++++++++++++++++++++---------- 1 file changed, 21 insertions(+), 10 deletions(-)
diff --git a/drivers/watchdog/designware_wdt.c b/drivers/watchdog/designware_wdt.c index 12f09a7a39..cdf6b5709b 100644 --- a/drivers/watchdog/designware_wdt.c +++ b/drivers/watchdog/designware_wdt.c @@ -23,6 +23,7 @@ struct designware_wdt_priv { void __iomem *base; unsigned int clk_khz; + struct reset_ctl_bulk *resets; };
/* @@ -96,6 +97,18 @@ static int designware_wdt_stop(struct udevice *dev) designware_wdt_reset(dev); writel(0, priv->base + DW_WDT_CR);
+ if (CONFIG_IS_ENABLED(DM_RESET)) { + int ret; + + ret = reset_assert_bulk(priv->resets); + if (ret) + return ret; + + ret = reset_deassert_bulk(priv->resets); + if (ret) + return ret; + } + return 0; }
@@ -143,13 +143,11 @@ static int designware_wdt_probe(struct udevice *dev) #endif
if (CONFIG_IS_ENABLED(DM_RESET)) { - struct reset_ctl_bulk resets; - - ret = reset_get_bulk(dev, &resets); + ret = reset_get_bulk(dev, priv->resets); if (ret) goto err;
- ret = reset_deassert_bulk(&resets); + ret = reset_deassert_bulk((priv->resets); if (ret) goto err; }
In latest u-boot code, watchdog feature is implemented, so enable wdt command by default.
Signed-off-by: Meng Li Meng.Li@windriver.com --- configs/socfpga_stratix10_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index 02d4ac0dae..0256afe511 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_WDT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y
This patch is not really a "watchdog" patch. Please change the commit subject line to something like this:
arm: socfpga: socfpga_stratix10: Enable watchdog command
Thanks, Stefan
int ret;
if (ret)
return ret;
if (ret)
return ret;
- return 0; }
if (ret) goto err;ret = reset_get_bulk(dev, priv->resets);
Please see the double open "(" and the single closing ")" above!
Did you ever at least build-test this? Please send a fixed and also *tested* v5.
Thanks, Stefan
Stefan Roese
