[U-Boot] [v2] include/configs: ls1012a: add pfe stop command
This adds pfe stop command before enter linux kernel to fix a problem that ethernet won't be workable after enter linux
Why need execute the command before enter linux kernel? - There is a h/w limitation in LS1012A PFE, to re-initialize PFE it has to be safe shutdown, these steps are done through PFE stop.
Signed-off-by: Biwen Li biwen.li@nxp.com --- Changes in v2: - trim subject - add why
include/configs/ls1012a2g5rdb.h | 2 +- include/configs/ls1012afrdm.h | 2 +- include/configs/ls1012afrwy.h | 4 ++-- include/configs/ls1012ardb.h | 2 +- 4 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/include/configs/ls1012a2g5rdb.h b/include/configs/ls1012a2g5rdb.h index cb329385d9..5943b69716 100644 --- a/include/configs/ls1012a2g5rdb.h +++ b/include/configs/ls1012a2g5rdb.h @@ -85,7 +85,7 @@ "installer=load mmc 0:2 $load_addr " \ "/flex_installer_arm64.itb; " \ "bootm $load_addr#$board\0" \ - "qspi_bootcmd=echo Trying load from qspi..;" \ + "qspi_bootcmd=pfe stop; echo Trying load from qspi..;" \ "sf probe && sf read $load_addr " \ "$kernel_addr $kernel_size; env exists secureboot " \ "&& sf read $kernelheader_addr_r $kernelheader_addr " \ diff --git a/include/configs/ls1012afrdm.h b/include/configs/ls1012afrdm.h index 8c7d4e558d..8a3ebf06f2 100644 --- a/include/configs/ls1012afrdm.h +++ b/include/configs/ls1012afrdm.h @@ -60,7 +60,7 @@ "installer=load usb 0:2 $load_addr " \ "/flex_installer_arm64.itb; " \ "bootm $load_addr#$board\0" \ - "qspi_bootcmd=echo Trying load from qspi..;" \ + "qspi_bootcmd=pfe stop; echo Trying load from qspi..;" \ "sf probe && sf read $load_addr " \ "$kernel_addr $kernel_size && bootm $load_addr#$board\0"
diff --git a/include/configs/ls1012afrwy.h b/include/configs/ls1012afrwy.h index 1b0f1566d3..a2ca326cfc 100644 --- a/include/configs/ls1012afrwy.h +++ b/include/configs/ls1012afrwy.h @@ -109,13 +109,13 @@ "installer=load mmc 0:2 $load_addr " \ "/flex_installer_arm64.itb; " \ "bootm $load_addr#$board\0" \ - "qspi_bootcmd=echo Trying load from qspi..;" \ + "qspi_bootcmd=pfe stop; echo Trying load from qspi..;" \ "sf probe && sf read $load_addr " \ "$kernel_addr $kernel_size; env exists secureboot " \ "&& sf read $kernelheader_addr_r $kernelheader_addr " \ "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; " \ "bootm $load_addr#$board\0" \ - "sd_bootcmd=echo Trying load from sd card..;" \ + "sd_bootcmd=pfe stop; echo Trying load from sd card..;" \ "mmcinfo; mmc read $load_addr " \ "$kernel_addr_sd $kernel_size_sd ;" \ "env exists secureboot && mmc read $kernelheader_addr_r "\ diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index a5e27404f8..39166fea7d 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -109,7 +109,7 @@ "installer=load mmc 0:2 $load_addr " \ "/flex_installer_arm64.itb; " \ "bootm $load_addr#$board\0" \ - "qspi_bootcmd=echo Trying load from qspi..;" \ + "qspi_bootcmd=pfe stop; echo Trying load from qspi..;" \ "sf probe && sf read $load_addr " \ "$kernel_addr $kernel_size; env exists secureboot " \ "&& sf read $kernelheader_addr_r $kernelheader_addr " \
-----Original Message----- From: Biwen Li biwen.li@nxp.com Sent: Thursday, November 14, 2019 10:15 AM To: Shengzhou Liu shengzhou.liu@nxp.com; Alison Wang alison.wang@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Priyanka Jain priyanka.jain@nxp.com Cc: Jiafei Pan jiafei.pan@nxp.com; Xiaobo Xie xiaobo.xie@nxp.com; u- boot@lists.denx.de; Biwen Li biwen.li@nxp.com Subject: [v2] include/configs: ls1012a: add pfe stop command
No need to add question. The description needs to be in passive voice. Add something like. 'pfe stop' command is required because
Changes in v2:
- trim subject
- add why
<snip> -priyankajain
-----Original Message----- From: Priyanka Jain priyanka.jain@nxp.com Sent: 2019年11月15日 12:57 To: Biwen Li biwen.li@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Alison Wang alison.wang@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com Cc: Jiafei Pan jiafei.pan@nxp.com; Xiaobo Xie xiaobo.xie@nxp.com; u-boot@lists.denx.de; Biwen Li biwen.li@nxp.com Subject: RE: [v2] include/configs: ls1012a: add pfe stop command
Okay, will be update in v3.
Changes in v2:
- trim subject
- add why
Biwen Li
Priyanka Jain
