The following changes since commit fdaccfeb5e03e18c05be386b8a7c6be02be2cf15:
Merge branch 'master' of git://git.denx.de/u-boot-socfpga (2018-10-31 17:15:55 -0400)
git://git.denx.de/u-boot-sh.git master
for you to fetch changes up to a376dde1deb9cc42e3804b9c654f873c936cc8d4:
mmc: tmio: sdhi: Merge DTCNTL access into single register write (2018-11-02 16:07:04 +0100)
---------------------------------------------------------------- Marek Vasut (12): pinctrl: renesas: Fix DRV register offset pinctrl: renesas: Add POCCTRL handling to r8a77990 ARM: rmobile: Generate fitting mem_map on Gen3 mmc: tmio: Simplify pinmux handling mmc: tmio: Improve error handling mmc: tmio: Silence transfer errors when tuning mmc: tmio: Configure clock before any other IOS mmc: tmio: Preinitialize regulator to 3.3V mmc: tmio: sdhi: Touch SCC only when UHS capable mmc: tmio: sdhi: Clear HS400 settings when resetting SCC mmc: tmio: sdhi: Implement waiting for DAT0 line state mmc: tmio: sdhi: Merge DTCNTL access into single register write
arch/arm/mach-rmobile/cpu_info.c | 3 +++ arch/arm/mach-rmobile/memmap-gen3.c | 89 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++- drivers/mmc/renesas-sdhi.c | 48 +++++++++++++++++++++++++++++++++++++++--------- drivers/mmc/tmio-common.c | 76 +++++++++++++++++++++++++++++++++------------------------------------------- drivers/pinctrl/renesas/pfc-r8a77990.c | 34 ++++++++++++++++++++++++++++++++-- drivers/pinctrl/renesas/pfc.c | 2 +- 6 files changed, 196 insertions(+), 56 deletions(-)
