[PATCH 0/2] efi_loader: fix device-path for USB devices
EFI device paths for block devices must be unique. If a non-unique device path is discovered, probing of the block device fails.
Currently we use UsbClass() device path nodes. As multiple devices may have the same vendor and product id these are non-unique. Instead we should use Usb() device path nodes. They include the USB port on the parent hub and hence are unique.
A USB storage device may contain multiple logical units. These can be modeled as Ctrl() nodes.
Given a driver model tree
root 0 root_driver root_driver usb 0 ehci_generic |-- usb@1c1a000 usb_hub 0 usb_hub `-- usb_hub usb_hub 1 usb_hub `-- usb_hub usb_mass_s 2 usb_mass_storage `-- usb_mass_storage blk 4 usb_storage_blk |-- usb_mass_storage.lun0
where the USB mass storage device is connected to port 4 of the 2nd hub, the device path for LUN 0 will be:
/VenHw()/USB(0x0,0x0)/USB(0x1,0x0)/USB(0x4,0x0)/Ctrl(0x0)
Heinrich Schuchardt (2): efi_loader: support for Ctrl() device path node efi_loader: fix device-path for USB devices
include/efi_api.h | 6 ++++ lib/efi_loader/efi_device_path.c | 45 +++++++++++++++++------- lib/efi_loader/efi_device_path_to_text.c | 7 ++++ 3 files changed, 46 insertions(+), 12 deletions(-)
* Add the definitions for Ctrl() device path nodes. * Implement Ctrl() nodes in the device path to text protocol.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- include/efi_api.h | 6 ++++++ lib/efi_loader/efi_device_path_to_text.c | 7 +++++++ 2 files changed, 13 insertions(+)
diff --git a/include/efi_api.h b/include/efi_api.h index 2d18d25a71..c57868abbd 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -570,6 +570,7 @@ struct efi_mac_addr { #define DEVICE_PATH_TYPE_HARDWARE_DEVICE 0x01 # define DEVICE_PATH_SUB_TYPE_MEMORY 0x03 # define DEVICE_PATH_SUB_TYPE_VENDOR 0x04 +# define DEVICE_PATH_SUB_TYPE_CONTROLLER 0x05
struct efi_device_path_memory { struct efi_device_path dp; @@ -584,6 +585,11 @@ struct efi_device_path_vendor { u8 vendor_data[]; } __packed;
+struct efi_device_path_controller { + struct efi_device_path dp; + u32 controller_number; +} __packed; + #define DEVICE_PATH_TYPE_ACPI_DEVICE 0x02 # define DEVICE_PATH_SUB_TYPE_ACPI_DEVICE 0x01
diff --git a/lib/efi_loader/efi_device_path_to_text.c b/lib/efi_loader/efi_device_path_to_text.c index 9062058ac2..9c0b39311a 100644 --- a/lib/efi_loader/efi_device_path_to_text.c +++ b/lib/efi_loader/efi_device_path_to_text.c @@ -77,6 +77,13 @@ static char *dp_hardware(char *s, struct efi_device_path *dp) s += sprintf(s, ")"); break; } + case DEVICE_PATH_SUB_TYPE_CONTROLLER: { + struct efi_device_path_controller *cdp = + (struct efi_device_path_controller *)dp; + + s += sprintf(s, "Ctrl(0x%0x)", cdp->controller_number); + break; + } default: s = dp_unknown(s, dp); break;
On Mon, 20 Mar 2023 at 04:18, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
- Add the definitions for Ctrl() device path nodes.
- Implement Ctrl() nodes in the device path to text protocol.
- struct efi_device_path dp;
- u32 controller_number;
+} __packed;
- case DEVICE_PATH_SUB_TYPE_CONTROLLER: {
break;
- } default: s = dp_unknown(s, dp); break;
-- 2.39.2
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Currently we use UsbClass() device path nodes. As multiple devices may have the same vendor and product id these are non-unique. Instead we should use Usb() device path nodes. They include the USB port on the parent hub. Hence they are unique.
Reported-by: Patrick Delaunay patrick.delaunay@foss.st.com Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- lib/efi_loader/efi_device_path.c | 45 +++++++++++++++++++++++--------- 1 file changed, 33 insertions(+), 12 deletions(-)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index 3b267b713e..b6dd575b13 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -147,7 +147,7 @@ struct efi_device_path *efi_dp_shorten(struct efi_device_path *dp) * in practice fallback.efi just uses MEDIA:HARD_DRIVE * so not sure when we would see these other cases. */ - if (EFI_DP_TYPE(dp, MESSAGING_DEVICE, MSG_USB_CLASS) || + if (EFI_DP_TYPE(dp, MESSAGING_DEVICE, MSG_USB) || EFI_DP_TYPE(dp, MEDIA_DEVICE, HARD_DRIVE_PATH) || EFI_DP_TYPE(dp, MEDIA_DEVICE, FILE_PATH)) return dp; @@ -564,6 +564,11 @@ __maybe_unused static unsigned int dp_size(struct udevice *dev) return dp_size(dev->parent) + sizeof(struct efi_device_path_vendor) + 1; #endif +#ifdef CONFIG_USB + case UCLASS_MASS_STORAGE: + return dp_size(dev->parent) + + sizeof(struct efi_device_path_controller); +#endif #ifdef CONFIG_VIRTIO_BLK case UCLASS_VIRTIO: /* @@ -585,7 +590,7 @@ __maybe_unused static unsigned int dp_size(struct udevice *dev) case UCLASS_MASS_STORAGE: case UCLASS_USB_HUB: return dp_size(dev->parent) + - sizeof(struct efi_device_path_usb_class); + sizeof(struct efi_device_path_usb); default: /* just skip over unknown classes: */ return dp_size(dev->parent); @@ -741,6 +746,19 @@ __maybe_unused static void *dp_fill(void *buf, struct udevice *dev) memcpy(&dp->ns_id, &ns_id, sizeof(ns_id)); return &dp[1]; } +#endif +#if defined(CONFIG_USB) + case UCLASS_MASS_STORAGE: { + struct blk_desc *desc = desc = dev_get_uclass_plat(dev); + struct efi_device_path_controller *dp = + dp_fill(buf, dev->parent); + + dp->dp.type = DEVICE_PATH_TYPE_HARDWARE_DEVICE; + dp->dp.sub_type = DEVICE_PATH_SUB_TYPE_CONTROLLER; + dp->dp.length = sizeof(*dp); + dp->controller_number = desc->lun; + return &dp[1]; + } #endif default: debug("%s(%u) %s: unhandled parent class: %s (%u)\n", @@ -767,19 +785,22 @@ __maybe_unused static void *dp_fill(void *buf, struct udevice *dev) #endif case UCLASS_MASS_STORAGE: case UCLASS_USB_HUB: { - struct efi_device_path_usb_class *udp = - dp_fill(buf, dev->parent); - struct usb_device *udev = dev_get_parent_priv(dev); - struct usb_device_descriptor *desc = &udev->descriptor; + struct efi_device_path_usb *udp = dp_fill(buf, dev->parent); + + switch (device_get_uclass_id(dev->parent)) { + case UCLASS_USB_HUB: { + struct usb_device *udev = dev_get_parent_priv(dev);
+ udp->parent_port_number = udev->portnr; + break; + } + default: + udp->parent_port_number = 0; + } udp->dp.type = DEVICE_PATH_TYPE_MESSAGING_DEVICE; - udp->dp.sub_type = DEVICE_PATH_SUB_TYPE_MSG_USB_CLASS; + udp->dp.sub_type = DEVICE_PATH_SUB_TYPE_MSG_USB; udp->dp.length = sizeof(*udp); - udp->vendor_id = desc->idVendor; - udp->product_id = desc->idProduct; - udp->device_class = desc->bDeviceClass; - udp->device_subclass = desc->bDeviceSubClass; - udp->device_protocol = desc->bDeviceProtocol; + udp->usb_interface = 0;
return &udp[1]; }
Hi Heinrich,
On Mon, 20 Mar 2023 at 04:25, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Can we do:
case UCLASS_MASS_STORAGE: if (IS_ENABLED(CONFIG_USB)) { ... }
and below too
return &dp[1];
#endif
Regards, SImon
On 3/19/23 20:29, Simon Glass wrote:
Hi Heinrich,
Can we do:
That should be possible too. Didn't you want to get rid of IS_ENABLED()? CONFIG_IS_ENABLED() would work here too.
The whole way that we create device paths is not consistent. We should have a device path node for each DM device.
With v2023.07 I want to add
struct efi_device_path *(*get_dp_node)(struct udevice *dev);
to struct uclass_driver and move the generation of device path nodes to the individual uclass drivers.
Best regards
Heinrich
and below too
return &dp[1];
#endif}
Regards, SImon
Hi Heinrich,
On Mon, 20 Mar 2023 at 09:58, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
Can we do:
I was wanting to get rid of CONFIG_IS_ENABLED() for things that don't have an SPL Kconfig, then eventually get rid of CONFIG_IS_ENABLED(). I've got a bit lost in all the problems though.
We could also send an event (EVT_EFI_GET_DP_NODE) and connect it that way...ie would add less space to driver model. But yes it would be good to line up EFI and DM a bit better.
Regards, Simon [..]
On 3/20/23 19:39, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
Can we do:
The type of device-path node to be created is uclass specific:
For an NVMe device we will always create a NVMe() node. For a block device we will always create a Ctrl() node with the LUN number. ...
For drivers that don't implement the method yet we can create a VenHw() node per default with uclass-id and device number encoded in the node.
You suggested yourself that the DM and the EFI implementation should be tightly integrated.
I cannot see what the use of an event should be. Why should each udevice register to an event when all we need is a simple function like:
#if CONFIG_IS_ENABLED(EFI_LOADER) struct efi_device_path *uclass_get_dp_node(struct udevice *dev) { struct uclass *uc; struct efi_device_path_uboot *dp;
uc = dev->uclass; if (uc->uc_drv->get_dp_node) return uc->uc_drv->get_dp_node(dev);
dp = efi_alloc(sizeof(struct efi_device_path_uboot)); if (!dp) return NULL;
dp->dp.type = DEVICE_PATH_TYPE_HARDWARE_DEVICE; dp->dp.sub_type = DEVICE_PATH_SUB_TYPE_VENDOR; dp->dp.length = sizeof(struct efi_device_path_uboot); dp->guid = efi_u_boot_guid; dp->uclass_id = uc->uc_drv->id; dp->seq_ = dev->seq_;
return &dp->dp; } #endif
Best regards
Heinrich
Hi Heinrich,
On Wed, 22 Mar 2023 at 02:21, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
Hi Heinrich,
Can we do:
I mean that EFI should make full use of DM rather than maintaining parallel structures that need manual updating.
uc = dev->uclass; if (uc->uc_drv->get_dp_node) return uc->uc_drv->get_dp_node(dev); dp = efi_alloc(sizeof(struct efi_device_path_uboot)); if (!dp) return NULL; dp->dp.type = DEVICE_PATH_TYPE_HARDWARE_DEVICE; dp->dp.sub_type = DEVICE_PATH_SUB_TYPE_VENDOR; dp->dp.length = sizeof(struct efi_device_path_uboot); dp->guid = efi_u_boot_guid; dp->uclass_id = uc->uc_drv->id; dp->seq_ = dev->seq_; return &dp->dp;
} #endif
I'll take a look at your series. Basically the idea with an event is that it can tell EFI when action is needed, without requiring #ifdefs and the like to build it into DM itself.
On 3/27/23 06:00, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
Can we do:
} #endif
The trigger is not on the DM side but on the EFI side. EFI is asking DM for a device-path node for a device of a specific uclass.
So DM would have to register a listener per uclass if we use events.
Best regards
Heinrich
Hi Heinrich,
On Mon, 27 Mar 2023 at 18:30, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
On Mon, 20 Mar 2023 at 04:25, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote: > > EFI device paths for block devices must be unique. If a non-unique device > path is discovered, probing of the block device fails. > > Currently we use UsbClass() device path nodes. As multiple devices may > have the same vendor and product id these are non-unique. Instead we > should use Usb() device path nodes. They include the USB port on the > parent hub. Hence they are unique. > > A USB storage device may contain multiple logical units. These can be > modeled as Ctrl() nodes. > > Reported-by: Patrick Delaunay patrick.delaunay@foss.st.com > Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com > --- > lib/efi_loader/efi_device_path.c | 45 +++++++++++++++++++++++--------- > 1 file changed, 33 insertions(+), 12 deletions(-)
> > diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c > index 3b267b713e..b6dd575b13 100644 > --- a/lib/efi_loader/efi_device_path.c > +++ b/lib/efi_loader/efi_device_path.c > @@ -147,7 +147,7 @@ struct efi_device_path *efi_dp_shorten(struct efi_device_path *dp) > * in practice fallback.efi just uses MEDIA:HARD_DRIVE > * so not sure when we would see these other cases. > */ > - if (EFI_DP_TYPE(dp, MESSAGING_DEVICE, MSG_USB_CLASS) || > + if (EFI_DP_TYPE(dp, MESSAGING_DEVICE, MSG_USB) || > EFI_DP_TYPE(dp, MEDIA_DEVICE, HARD_DRIVE_PATH) || > EFI_DP_TYPE(dp, MEDIA_DEVICE, FILE_PATH)) > return dp; > @@ -564,6 +564,11 @@ __maybe_unused static unsigned int dp_size(struct udevice *dev) > return dp_size(dev->parent) > + sizeof(struct efi_device_path_vendor) + 1; > #endif > +#ifdef CONFIG_USB > + case UCLASS_MASS_STORAGE:
Can we do:
} #endif
Yes, I understand that.
We could have a spy in each uclass, right?
EFI_DP_TYPE(dp, MEDIA_DEVICE, HARD_DRIVE_PATH) || EFI_DP_TYPE(dp, MEDIA_DEVICE, FILE_PATH)) return dp;if (EFI_DP_TYPE(dp, MESSAGING_DEVICE, MSG_USB) ||
default: /* just skip over unknown classes: */ return dp_size(dev->parent);sizeof(struct efi_device_path_usb);
return &dp[1];
break;
default:
udp->dp.length = sizeof(*udp);udp->dp.sub_type = DEVICE_PATH_SUB_TYPE_MSG_USB;
Why is this 0? Can't we derive something reasonable from the uclass?
Thanks /Ilias
return &udp[1];
2.39.2
Ilias Apalodimas
