[U-Boot] [PATCH 1/5][v7] arch: powerpc: Move CONFIG_FSL_IFC to Kconfig
Enable IFC from Kconfig.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- Changes for v5: Added first time Changes for v6: Sending as it is Changes for v7: Sending as it is
arch/powerpc/cpu/mpc85xx/Kconfig | 17 +++++++++++++++++ include/configs/B4860QDS.h | 1 - include/configs/BSC9131RDB.h | 1 - include/configs/BSC9132QDS.h | 1 - include/configs/C29XPCIE.h | 1 - include/configs/P1010RDB.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/t4qds.h | 1 - 14 files changed, 17 insertions(+), 13 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index 38ea4c1..a3db014 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -374,6 +374,7 @@ config ARCH_B4420 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 + select FSL_IFC
config ARCH_B4860 bool @@ -398,6 +399,7 @@ config ARCH_B4860 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 + select FSL_IFC
config ARCH_BSC9131 bool @@ -410,6 +412,7 @@ config ARCH_BSC9131 select SYS_FSL_HAS_SEC select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 + select FSL_IFC
config ARCH_BSC9132 bool @@ -426,6 +429,7 @@ config ARCH_BSC9132 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_IFC
config ARCH_C29X bool @@ -438,6 +442,7 @@ config ARCH_C29X select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_6 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_IFC
config ARCH_MPC8536 bool @@ -553,6 +558,7 @@ config ARCH_P1010 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_IFC
config ARCH_P1011 bool @@ -795,6 +801,7 @@ config ARCH_T1023 select SYS_FSL_QORIQ_CHASSIS2 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_5 + select FSL_IFC
config ARCH_T1024 bool @@ -811,6 +818,7 @@ config ARCH_T1024 select SYS_FSL_QORIQ_CHASSIS2 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_5 + select FSL_IFC
config ARCH_T1040 bool @@ -828,6 +836,7 @@ config ARCH_T1040 select SYS_FSL_QORIQ_CHASSIS2 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_5 + select FSL_IFC
config ARCH_T1042 bool @@ -845,6 +854,7 @@ config ARCH_T1042 select SYS_FSL_QORIQ_CHASSIS2 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_5 + select FSL_IFC
config ARCH_T2080 bool @@ -866,6 +876,7 @@ config ARCH_T2080 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 + select FSL_IFC
config ARCH_T2081 bool @@ -885,6 +896,7 @@ config ARCH_T2081 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 + select FSL_IFC
config ARCH_T4160 bool @@ -905,6 +917,7 @@ config ARCH_T4160 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 + select FSL_IFC
config ARCH_T4240 bool @@ -928,6 +941,7 @@ config ARCH_T4240 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 + select FSL_IFC
config BOOKE bool @@ -1260,6 +1274,9 @@ config SYS_PPC64 config SYS_PPC_E500_USE_DEBUG_TLB bool
+config FSL_IFC + bool + config SYS_PPC_E500_DEBUG_TLB int "Temporary TLB entry for external debugger" depends on SYS_PPC_E500_USE_DEBUG_TLB diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index fc99b96..2fdb869 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -63,7 +63,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index 77f0927..4116234 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -46,7 +46,6 @@ #endif
/* High Level Configuration Options */ -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */
#define CONFIG_TSEC_ENET diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index f336f28..b2c8b03 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -68,7 +68,6 @@ #endif
/* High Level Configuration Options */ -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ #define CONFIG_SYS_HAS_SERDES /* common SERDES init code */
diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index e1ce7ad..8f68748 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -68,7 +68,6 @@ #endif
diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 1d01e7f..3594e56 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -130,7 +130,6 @@ #endif
diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 2c3b660..0319f18 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -23,7 +23,6 @@
#define CONFIG_ENV_OVERWRITE
diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 79c34ef..459435f 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -23,7 +23,6 @@
diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 15a29cb..9de6185 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -51,7 +51,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ #define CONFIG_PCI_INDIRECT_BRIDGE #define CONFIG_PCIE1 /* PCIE controller 1 */ diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 45aaf90..b778ace 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -162,7 +162,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ #define CONFIG_PCI_INDIRECT_BRIDGE #define CONFIG_PCIE1 /* PCIE controller 1 */ diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 606c928..d6f647a 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -33,7 +33,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ #define CONFIG_ENV_OVERWRITE
diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 825bf25..53bd684 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -27,7 +27,6 @@
diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index be18f66..2b03801 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -73,7 +73,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */ diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index 15c0e89..7803a84 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -26,7 +26,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */ #define CONFIG_PCIE3 /* PCIE controller 3 */
Prabhakar,
Do you plan to make the same move for ARM-based platforms?
York
-----Original Message----- From: york sun Sent: Tuesday, January 31, 2017 11:02 PM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; u- boot@lists.denx.de Subject: Re: [PATCH 1/5][v7] arch: powerpc: Move CONFIG_FSL_IFC to Kconfig
Prabhakar,
Hi York,
I have plan for ARM -based platforms also. But It will not be part of this patch-set.
Prabhakar Kushwaha
york sun
