[U-Boot] [PATCH 0/5] Add support for Vybrid VF610-based PCM052
This patch series introduces the vf610-based PCM052 target after a few fixes to the vf610 code.
As indicated in the last patch in the series, there is a bug in the FEC whereby it wrongly reports having sent out a packet. This bug does not seem specific to PCM052, and it also seems to appear in the TimeSys U-Boot deliveries and also in Linux, with varying frequencies.
NOTE: this series is not checkpatch-clean. It has:
- 51 "line over 80 characters" warnings. These lines are in a block for which the line lenght limit was obviously waived. arch/arm/include/asm/arch-vf610/iomux-vf610.h has 5 of these; board/phytec/pcm052/pcm052.c has the remaining 50.
- 1 "please write a paragraph that describes the config symbol fully" warning for arch/arm/Kconfig. There are no such descriptions for any target in this file.
- 1 "need consistent spacing around '|' (ctx:WxV)" error in board/phytec/pcm052/pcm052.c at line 98. It seems spurious to me, as this construct has the exact same spacing as all others in the file.
Albert ARIBAUD (3ADEV) (5): net: fec_mxc: remove useless struct nbuf vf610: refactor DDRMC code i2c: fix vf610 support tools: mkimage: fix imximage header size vf610: add support for Phytec PCM052
arch/arm/Kconfig | 5 + arch/arm/imx-common/ddrmc-vf610.c | 239 +++--------- arch/arm/include/asm/arch-vf610/crm_regs.h | 3 + arch/arm/include/asm/arch-vf610/ddrmc-vf610.h | 60 +-- arch/arm/include/asm/arch-vf610/imx-regs.h | 3 + arch/arm/include/asm/arch-vf610/iomux-vf610.h | 11 +- arch/arm/include/asm/imx-common/iomux-v3.h | 2 + board/freescale/vf610twr/vf610twr.c | 181 ++++++--- board/phytec/pcm052/Kconfig | 15 + board/phytec/pcm052/MAINTAINERS | 6 + board/phytec/pcm052/Makefile | 7 + board/phytec/pcm052/imximage.cfg | 17 + board/phytec/pcm052/pcm052.c | 530 ++++++++++++++++++++++++++ board/toradex/colibri_vf/colibri_vf.c | 169 ++++++-- configs/pcm052_defconfig | 6 + drivers/i2c/mxc_i2c.c | 3 +- drivers/net/fec_mxc.c | 20 +- include/configs/pcm052.h | 234 ++++++++++++ tools/imximage.h | 1 + 19 files changed, 1155 insertions(+), 357 deletions(-) create mode 100644 board/phytec/pcm052/Kconfig create mode 100644 board/phytec/pcm052/MAINTAINERS create mode 100644 board/phytec/pcm052/Makefile create mode 100644 board/phytec/pcm052/imximage.cfg create mode 100644 board/phytec/pcm052/pcm052.c create mode 100644 configs/pcm052_defconfig create mode 100644 include/configs/pcm052.h
This locally defined struct is actually only used once and as an opaque type. Remove it for clarity.
Signed-off-by: Albert ARIBAUD (3ADEV) albert.aribaud@3adev.fr ---
drivers/net/fec_mxc.c | 20 +++++--------------- 1 file changed, 5 insertions(+), 15 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 9225d37..c5dcbbb 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -67,13 +67,6 @@ DECLARE_GLOBAL_DATA_PTR;
#undef DEBUG
-struct nbuf { - uint8_t data[1500]; /**< actual data */ - int length; /**< actual length */ - int used; /**< buffer in use or not */ - uint8_t head[16]; /**< MAC header(6 + 6 + 2) + 2(aligned) */ -}; - #ifdef CONFIG_FEC_MXC_SWAP_PACKET static void swap_packet(uint32_t *packet, int length) { @@ -775,7 +768,6 @@ static int fec_recv(struct eth_device *dev) struct fec_bd *rbd = &fec->rbd_base[fec->rbd_index]; unsigned long ievent; int frame_length, len = 0; - struct nbuf *frame; uint16_t bd_status; uint32_t addr, size, end; int i; @@ -835,12 +827,11 @@ static int fec_recv(struct eth_device *dev) /* * Get buffer address and size */ - frame = (struct nbuf *)readl(&rbd->data_pointer); + addr = readl(&rbd->data_pointer); frame_length = readw(&rbd->data_length) - 4; /* * Invalidate data cache over the buffer */ - addr = (uint32_t)frame; end = roundup(addr + frame_length, ARCH_DMA_MINALIGN); addr &= ~(ARCH_DMA_MINALIGN - 1); invalidate_dcache_range(addr, end); @@ -849,16 +840,15 @@ static int fec_recv(struct eth_device *dev) * Fill the buffer and pass it to upper layers */ #ifdef CONFIG_FEC_MXC_SWAP_PACKET - swap_packet((uint32_t *)frame->data, frame_length); + swap_packet((uint32_t *)addr, frame_length); #endif - memcpy(buff, frame->data, frame_length); + memcpy(buff, (char *)addr, frame_length); net_process_received_packet(buff, frame_length); len = frame_length; } else { if (bd_status & FEC_RBD_ERR) - printf("error frame: 0x%08lx 0x%08x\n", - (ulong)rbd->data_pointer, - bd_status); + printf("error frame: 0x%08x 0x%08x\n", + addr, bd_status); }
The VF610 DDRMC driver code contains settings which are board-specific. Move these out to boards so that new boards can define their own without having to modify the driver.
arch/arm/imx-common/ddrmc-vf610.c | 239 ++++++-------------------- arch/arm/include/asm/arch-vf610/ddrmc-vf610.h | 60 +------ board/freescale/vf610twr/vf610twr.c | 181 +++++++++++++------ board/toradex/colibri_vf/colibri_vf.c | 169 +++++++++++++----- 4 files changed, 312 insertions(+), 337 deletions(-)
diff --git a/arch/arm/imx-common/ddrmc-vf610.c b/arch/arm/imx-common/ddrmc-vf610.c index e462631..44b9a0f 100644 --- a/arch/arm/imx-common/ddrmc-vf610.c +++ b/arch/arm/imx-common/ddrmc-vf610.c @@ -12,9 +12,9 @@ #include <asm/arch/iomux-vf610.h> #include <asm/arch/ddrmc-vf610.h>
-void ddrmc_setup_iomux(void) +void ddrmc_setup_iomux(const iomux_v3_cfg_t *pads, int pads_count) { - static const iomux_v3_cfg_t ddr_pads[] = { + static const iomux_v3_cfg_t default_pads[] = { VF610_PAD_DDR_A15__DDR_A_15, VF610_PAD_DDR_A14__DDR_A_14, VF610_PAD_DDR_A13__DDR_A_13, @@ -65,212 +65,77 @@ void ddrmc_setup_iomux(void) VF610_PAD_DDR_RESETB, };
- imx_iomux_v3_setup_multiple_pads(ddr_pads, ARRAY_SIZE(ddr_pads)); -} + if ((pads == NULL) || (pads_count == 0)) { + pads = default_pads; + pads_count = ARRAY_SIZE(default_pads); + }
-void ddrmc_phy_init(void) -{ - struct ddrmr_regs *ddrmr = (struct ddrmr_regs *)DDR_BASE_ADDR; + imx_iomux_v3_setup_multiple_pads(pads, pads_count); +}
- writel(DDRMC_PHY_DQ_TIMING, &ddrmr->phy[0]); - writel(DDRMC_PHY_DQ_TIMING, &ddrmr->phy[16]); - writel(DDRMC_PHY_DQ_TIMING, &ddrmr->phy[32]); +static struct ddrmc_reg_setting default_phy_settings[] = { + { DDRMC_PHY_DQ_TIMING, 0 }, + { DDRMC_PHY_DQ_TIMING, 16 }, + { DDRMC_PHY_DQ_TIMING, 32 },
- writel(DDRMC_PHY_DQS_TIMING, &ddrmr->phy[1]); - writel(DDRMC_PHY_DQS_TIMING, &ddrmr->phy[17]); + { DDRMC_PHY_DQS_TIMING, 1 }, + { DDRMC_PHY_DQS_TIMING, 17 },
- writel(DDRMC_PHY_CTRL, &ddrmr->phy[2]); - writel(DDRMC_PHY_CTRL, &ddrmr->phy[18]); - writel(DDRMC_PHY_CTRL, &ddrmr->phy[34]); + { DDRMC_PHY_CTRL, 2 }, + { DDRMC_PHY_CTRL, 18 }, + { DDRMC_PHY_CTRL, 34 },
- writel(DDRMC_PHY_MASTER_CTRL, &ddrmr->phy[3]); - writel(DDRMC_PHY_MASTER_CTRL, &ddrmr->phy[19]); - writel(DDRMC_PHY_MASTER_CTRL, &ddrmr->phy[35]); + { DDRMC_PHY_MASTER_CTRL, 3 }, + { DDRMC_PHY_MASTER_CTRL, 19 }, + { DDRMC_PHY_MASTER_CTRL, 35 },
- writel(DDRMC_PHY_SLAVE_CTRL, &ddrmr->phy[4]); - writel(DDRMC_PHY_SLAVE_CTRL, &ddrmr->phy[20]); - writel(DDRMC_PHY_SLAVE_CTRL, &ddrmr->phy[36]); + { DDRMC_PHY_SLAVE_CTRL, 4 }, + { DDRMC_PHY_SLAVE_CTRL, 20 }, + { DDRMC_PHY_SLAVE_CTRL, 36 },
/* LPDDR2 only parameter */ - writel(DDRMC_PHY_OFF, &ddrmr->phy[49]); + { DDRMC_PHY_OFF, 49 },
- writel(DDRMC_PHY50_DDR3_MODE | - DDRMC_PHY50_EN_SW_HALF_CYCLE, &ddrmr->phy[50]); + { DDRMC_PHY50_DDR3_MODE | DDRMC_PHY50_EN_SW_HALF_CYCLE, 50 },
/* Processor Pad ODT settings */ - writel(DDRMC_PHY_PROC_PAD_ODT, &ddrmr->phy[52]); -} + { DDRMC_PHY_PROC_PAD_ODT, 52 },
-static void ddrmc_ctrl_lvl_init(struct ddrmc_lvl_info *lvl) -{ - struct ddrmr_regs *ddrmr = (struct ddrmr_regs *)DDR_BASE_ADDR; - u32 cr102 = 0, cr105 = 0, cr106 = 0, cr110 = 0; + /* end marker */ + { 0, -1 } +};
- if (lvl->wrlvl_reg_en) { - writel(DDRMC_CR97_WRLVL_EN, &ddrmr->cr[97]); - writel(DDRMC_CR98_WRLVL_DL_0(lvl->wrlvl_dl_0), &ddrmr->cr[98]); - writel(DDRMC_CR99_WRLVL_DL_1(lvl->wrlvl_dl_1), &ddrmr->cr[99]); - } - - if (lvl->rdlvl_reg_en) { - cr102 |= DDRMC_CR102_RDLVL_REG_EN; - cr105 |= DDRMC_CR105_RDLVL_DL_0(lvl->rdlvl_dl_0); - cr110 |= DDRMC_CR110_RDLVL_DL_1(lvl->rdlvl_dl_1); - } - - if (lvl->rdlvl_gt_reg_en) { - cr102 |= DDRMC_CR102_RDLVL_GT_REGEN; - cr106 |= DDRMC_CR106_RDLVL_GTDL_0(lvl->rdlvl_gt_dl_0); - cr110 |= DDRMC_CR110_RDLVL_GTDL_1(lvl->rdlvl_gt_dl_1); - } - - writel(cr102, &ddrmr->cr[102]); - writel(cr105, &ddrmr->cr[105]); - writel(cr106, &ddrmr->cr[106]); - writel(cr110, &ddrmr->cr[110]); -} - -void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings, - struct ddrmc_lvl_info *lvl, - int col_diff, int row_diff) +void ddrmc_ctrl_init_ddr3(struct ddrmc_reg_setting const *cr_settings, + struct ddrmc_reg_setting const *phy_settings) { struct ddrmr_regs *ddrmr = (struct ddrmr_regs *)DDR_BASE_ADDR; + struct ddrmc_reg_setting const *cr_setting = cr_settings; + struct ddrmc_reg_setting const *phy_setting = phy_settings;
+ /* configure controller for DDR3 and start init sequence */ writel(DDRMC_CR00_DRAM_CLASS_DDR3, &ddrmr->cr[0]); - writel(DDRMC_CR02_DRAM_TINIT(timings->tinit), &ddrmr->cr[2]); - writel(DDRMC_CR10_TRST_PWRON(timings->trst_pwron), &ddrmr->cr[10]); - - writel(DDRMC_CR11_CKE_INACTIVE(timings->cke_inactive), &ddrmr->cr[11]); - writel(DDRMC_CR12_WRLAT(timings->wrlat) | - DDRMC_CR12_CASLAT_LIN(timings->caslat_lin), &ddrmr->cr[12]); - writel(DDRMC_CR13_TRC(timings->trc) | DDRMC_CR13_TRRD(timings->trrd) | - DDRMC_CR13_TCCD(timings->tccd), &ddrmr->cr[13]); - writel(DDRMC_CR14_TFAW(timings->tfaw) | DDRMC_CR14_TRP(timings->trp) | - DDRMC_CR14_TWTR(timings->twtr) | - DDRMC_CR14_TRAS_MIN(timings->tras_min), &ddrmr->cr[14]); - writel(DDRMC_CR16_TMRD(timings->tmrd) | - DDRMC_CR16_TRTP(timings->trtp), &ddrmr->cr[16]); - writel(DDRMC_CR17_TRAS_MAX(timings->tras_max) | - DDRMC_CR17_TMOD(timings->tmod), &ddrmr->cr[17]); - writel(DDRMC_CR18_TCKESR(timings->tckesr) | - DDRMC_CR18_TCKE(timings->tcke), &ddrmr->cr[18]);
- writel(DDRMC_CR20_AP_EN, &ddrmr->cr[20]); - writel(DDRMC_CR21_TRCD_INT(timings->trcd_int) | - DDRMC_CR21_CCMAP_EN, &ddrmr->cr[21]); - - writel(DDRMC_CR22_TDAL(timings->tdal), &ddrmr->cr[22]); - writel(DDRMC_CR23_BSTLEN(3) | - DDRMC_CR23_TDLL(timings->tdll), &ddrmr->cr[23]); - writel(DDRMC_CR24_TRP_AB(timings->trp_ab), &ddrmr->cr[24]); - - writel(DDRMC_CR25_TREF_EN, &ddrmr->cr[25]); - writel(DDRMC_CR26_TREF(timings->tref) | - DDRMC_CR26_TRFC(timings->trfc), &ddrmr->cr[26]); - writel(DDRMC_CR28_TREF_INT(0), &ddrmr->cr[28]); - writel(DDRMC_CR29_TPDEX(timings->tpdex), &ddrmr->cr[29]); - - writel(DDRMC_CR30_TXPDLL(timings->txpdll), &ddrmr->cr[30]); - writel(DDRMC_CR31_TXSNR(timings->txsnr) | - DDRMC_CR31_TXSR(timings->txsr), &ddrmr->cr[31]); - writel(DDRMC_CR33_EN_QK_SREF, &ddrmr->cr[33]); - writel(DDRMC_CR34_CKSRX(timings->cksrx) | - DDRMC_CR34_CKSRE(timings->cksre), &ddrmr->cr[34]); - - writel(DDRMC_CR38_FREQ_CHG_EN(0), &ddrmr->cr[38]); - writel(DDRMC_CR39_PHY_INI_COM(1024) | DDRMC_CR39_PHY_INI_STA(16) | - DDRMC_CR39_FRQ_CH_DLLOFF(2), &ddrmr->cr[39]); - - writel(DDRMC_CR41_PHY_INI_STRT_INI_DIS, &ddrmr->cr[41]); - writel(DDRMC_CR48_MR1_DA_0(70) | - DDRMC_CR48_MR0_DA_0(1056), &ddrmr->cr[48]); - - writel(DDRMC_CR66_ZQCL(timings->zqcl) | - DDRMC_CR66_ZQINIT(timings->zqinit), &ddrmr->cr[66]); - writel(DDRMC_CR67_ZQCS(timings->zqcs), &ddrmr->cr[67]); - writel(DDRMC_CR69_ZQ_ON_SREF_EX(2), &ddrmr->cr[69]); - - writel(DDRMC_CR70_REF_PER_ZQ(timings->ref_per_zq), &ddrmr->cr[70]); - writel(DDRMC_CR72_ZQCS_ROTATE(0), &ddrmr->cr[72]); - - writel(DDRMC_CR73_APREBIT(timings->aprebit) | - DDRMC_CR73_COL_DIFF(col_diff) | - DDRMC_CR73_ROW_DIFF(row_diff), &ddrmr->cr[73]); - writel(DDRMC_CR74_BANKSPLT_EN | DDRMC_CR74_ADDR_CMP_EN | - DDRMC_CR74_CMD_AGE_CNT(64) | DDRMC_CR74_AGE_CNT(64), - &ddrmr->cr[74]); - writel(DDRMC_CR75_RW_PG_EN | DDRMC_CR75_RW_EN | DDRMC_CR75_PRI_EN | - DDRMC_CR75_PLEN, &ddrmr->cr[75]); - writel(DDRMC_CR76_NQENT_ACTDIS(3) | DDRMC_CR76_D_RW_G_BKCN(3) | - DDRMC_CR76_W2R_SPLT_EN, &ddrmr->cr[76]); - writel(DDRMC_CR77_CS_MAP | DDRMC_CR77_DI_RD_INTLEAVE | - DDRMC_CR77_SWAP_EN, &ddrmr->cr[77]); - writel(DDRMC_CR78_Q_FULLNESS(7) | - DDRMC_CR78_BUR_ON_FLY_BIT(12), &ddrmr->cr[78]); - writel(DDRMC_CR79_CTLUPD_AREF(0), &ddrmr->cr[79]); + /* execute CR sequence (MUST be supplied) */ + if (cr_setting) + while (cr_setting->reg_num >= 0) { + writel(cr_setting->setting, + &ddrmr->cr[cr_setting->reg_num]); + cr_setting++; + } + + /* execute PHY sequence (SHOULD be supplied but can be default) */ + if (phy_setting == NULL) + phy_setting = default_phy_settings; + + while (phy_setting->reg_num >= 0) { + writel(phy_setting->setting, + &ddrmr->phy[phy_setting->reg_num]); + phy_setting++; + }
+ /* final config: disable DDR interrupts and finish init squence */ writel(DDRMC_CR82_INT_MASK, &ddrmr->cr[82]);
- writel(DDRMC_CR87_ODT_WR_MAPCS0, &ddrmr->cr[87]); - writel(DDRMC_CR88_TODTL_CMD(4), &ddrmr->cr[88]); - writel(DDRMC_CR89_AODT_RWSMCS(2), &ddrmr->cr[89]); - - writel(DDRMC_CR91_R2W_SMCSDL(2), &ddrmr->cr[91]); - writel(DDRMC_CR96_WLMRD(timings->wlmrd) | - DDRMC_CR96_WLDQSEN(timings->wldqsen), &ddrmr->cr[96]); - - if (lvl != NULL) - ddrmc_ctrl_lvl_init(lvl); - - writel(DDRMC_CR117_AXI0_W_PRI(0) | - DDRMC_CR117_AXI0_R_PRI(0), &ddrmr->cr[117]); - writel(DDRMC_CR118_AXI1_W_PRI(1) | - DDRMC_CR118_AXI1_R_PRI(1), &ddrmr->cr[118]); - - writel(DDRMC_CR120_AXI0_PRI1_RPRI(2) | - DDRMC_CR120_AXI0_PRI0_RPRI(2), &ddrmr->cr[120]); - writel(DDRMC_CR121_AXI0_PRI3_RPRI(2) | - DDRMC_CR121_AXI0_PRI2_RPRI(2), &ddrmr->cr[121]); - writel(DDRMC_CR122_AXI1_PRI1_RPRI(1) | DDRMC_CR122_AXI1_PRI0_RPRI(1) | - DDRMC_CR122_AXI0_PRIRLX(100), &ddrmr->cr[122]); - writel(DDRMC_CR123_AXI1_P_ODR_EN | DDRMC_CR123_AXI1_PRI3_RPRI(1) | - DDRMC_CR123_AXI1_PRI2_RPRI(1), &ddrmr->cr[123]); - writel(DDRMC_CR124_AXI1_PRIRLX(100), &ddrmr->cr[124]); - - writel(DDRMC_CR126_PHY_RDLAT(8), &ddrmr->cr[126]); - writel(DDRMC_CR132_WRLAT_ADJ(5) | - DDRMC_CR132_RDLAT_ADJ(6), &ddrmr->cr[132]); - writel(DDRMC_CR137_PHYCTL_DL(2), &ddrmr->cr[137]); - writel(DDRMC_CR138_PHY_WRLV_MXDL(256) | - DDRMC_CR138_PHYDRAM_CK_EN(1), &ddrmr->cr[138]); - writel(DDRMC_CR139_PHY_WRLV_RESPLAT(4) | DDRMC_CR139_PHY_WRLV_LOAD(7) | - DDRMC_CR139_PHY_WRLV_DLL(3) | - DDRMC_CR139_PHY_WRLV_EN(3), &ddrmr->cr[139]); - writel(DDRMC_CR140_PHY_WRLV_WW(64), &ddrmr->cr[140]); - writel(DDRMC_CR143_RDLV_GAT_MXDL(1536) | - DDRMC_CR143_RDLV_MXDL(128), &ddrmr->cr[143]); - writel(DDRMC_CR144_PHY_RDLVL_RES(4) | DDRMC_CR144_PHY_RDLV_LOAD(7) | - DDRMC_CR144_PHY_RDLV_DLL(3) | - DDRMC_CR144_PHY_RDLV_EN(3), &ddrmr->cr[144]); - writel(DDRMC_CR145_PHY_RDLV_RR(64), &ddrmr->cr[145]); - writel(DDRMC_CR146_PHY_RDLVL_RESP(64), &ddrmr->cr[146]); - writel(DDRMC_CR147_RDLV_RESP_MASK(983040), &ddrmr->cr[147]); - writel(DDRMC_CR148_RDLV_GATE_RESP_MASK(983040), &ddrmr->cr[148]); - writel(DDRMC_CR151_RDLV_GAT_DQ_ZERO_CNT(1) | - DDRMC_CR151_RDLVL_DQ_ZERO_CNT(1), &ddrmr->cr[151]); - - writel(DDRMC_CR154_PAD_ZQ_EARLY_CMP_EN_TIMER(13) | - DDRMC_CR154_PAD_ZQ_MODE(1) | - DDRMC_CR154_DDR_SEL_PAD_CONTR(3) | - DDRMC_CR154_PAD_ZQ_HW_FOR(1), &ddrmr->cr[154]); - writel(DDRMC_CR155_PAD_ODT_BYTE1(2) | - DDRMC_CR155_PAD_ODT_BYTE0(2), &ddrmr->cr[155]); - writel(DDRMC_CR158_TWR(6), &ddrmr->cr[158]); - writel(DDRMC_CR161_ODT_EN(1) | DDRMC_CR161_TODTH_RD(2) | - DDRMC_CR161_TODTH_WR(2), &ddrmr->cr[161]); - - ddrmc_phy_init(); - writel(DDRMC_CR00_DRAM_CLASS_DDR3 | DDRMC_CR00_START, &ddrmr->cr[0]);
while (!(readl(&ddrmr->cr[80]) && 0x100)) diff --git a/arch/arm/include/asm/arch-vf610/ddrmc-vf610.h b/arch/arm/include/asm/arch-vf610/ddrmc-vf610.h index 6730cde..bc7f106 100644 --- a/arch/arm/include/asm/arch-vf610/ddrmc-vf610.h +++ b/arch/arm/include/asm/arch-vf610/ddrmc-vf610.h @@ -11,62 +11,14 @@ #ifndef __ASM_ARCH_VF610_DDRMC_H #define __ASM_ARCH_VF610_DDRMC_H
-struct ddrmc_lvl_info { - u16 wrlvl_reg_en; - u16 wrlvl_dl_0; - u16 wrlvl_dl_1; - u16 rdlvl_gt_reg_en; - u16 rdlvl_gt_dl_0; - u16 rdlvl_gt_dl_1; - u16 rdlvl_reg_en; - u16 rdlvl_dl_0; - u16 rdlvl_dl_1; +struct ddrmc_reg_setting { + u32 setting; + int reg_num; /* CR or PHY ; -1 for last entry */ };
-struct ddr3_jedec_timings { - u8 tinit; - u32 trst_pwron; - u32 cke_inactive; - u8 wrlat; - u8 caslat_lin; - u8 trc; - u8 trrd; - u8 tccd; - u8 tfaw; - u8 trp; - u8 twtr; - u8 tras_min; - u8 tmrd; - u8 trtp; - u32 tras_max; - u8 tmod; - u8 tckesr; - u8 tcke; - u8 trcd_int; - u8 tdal; - u16 tdll; - u8 trp_ab; - u16 tref; - u8 trfc; - u8 tpdex; - u8 txpdll; - u8 txsnr; - u16 txsr; - u8 cksrx; - u8 cksre; - u16 zqcl; - u16 zqinit; - u8 zqcs; - u8 ref_per_zq; - u8 aprebit; - u8 wlmrd; - u8 wldqsen; -}; - -void ddrmc_setup_iomux(void); +void ddrmc_setup_iomux(const iomux_v3_cfg_t *pads, int pads_count); void ddrmc_phy_init(void); -void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings, - struct ddrmc_lvl_info *lvl, - int col_diff, int row_diff); +void ddrmc_ctrl_init_ddr3(struct ddrmc_reg_setting const *cr_settings, + struct ddrmc_reg_setting const *phy_settings);
#endif diff --git a/board/freescale/vf610twr/vf610twr.c b/board/freescale/vf610twr/vf610twr.c index 4160acd..aab20ad 100644 --- a/board/freescale/vf610twr/vf610twr.c +++ b/board/freescale/vf610twr/vf610twr.c @@ -28,63 +28,136 @@ DECLARE_GLOBAL_DATA_PTR; #define ENET_PAD_CTRL (PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_HIGH | \ PAD_CTL_DSE_50ohm | PAD_CTL_OBE_IBE_ENABLE)
+static struct ddrmc_reg_setting vf610twr_cr_settings[] = { + { DDRMC_CR02_DRAM_TINIT(5), 2 }, + { DDRMC_CR10_TRST_PWRON(80000), 10 }, + { DDRMC_CR11_CKE_INACTIVE(200000), 11 }, + { DDRMC_CR12_WRLAT(5) | DDRMC_CR12_CASLAT_LIN(12), 12 }, + { DDRMC_CR13_TRC(21) | DDRMC_CR13_TRRD(4) | DDRMC_CR13_TCCD(4) | + DDRMC_CR13_TBST_INT_INTERVAL(0), 13 }, + { DDRMC_CR14_TFAW(20) | DDRMC_CR14_TRP(6) | DDRMC_CR14_TWTR(5) | + DDRMC_CR14_TRAS_MIN(15), 14 }, + { DDRMC_CR16_TMRD(4) | DDRMC_CR16_TRTP(4), 16 }, + { DDRMC_CR17_TRAS_MAX(28080) | DDRMC_CR17_TMOD(12), 17 }, + { DDRMC_CR18_TCKESR(4) | DDRMC_CR18_TCKE(3), 18 }, + + { DDRMC_CR20_AP_EN, 20 }, + { DDRMC_CR21_TRCD_INT(6) | DDRMC_CR21_CCMAP_EN, 21 }, + + { DDRMC_CR22_TDAL(12), 22 }, + { DDRMC_CR23_BSTLEN(3) | + DDRMC_CR23_TDLL(512), 23 }, + { DDRMC_CR24_TRP_AB(6), 24 }, + + { DDRMC_CR25_TREF_EN, 25 }, + { DDRMC_CR26_TREF(3120) | DDRMC_CR26_TRFC(44), 26 }, + { DDRMC_CR28_TREF_INT(0), 28 }, + { DDRMC_CR29_TPDEX(3), 29 }, + + { DDRMC_CR30_TXPDLL(10), 30 }, + { DDRMC_CR31_TXSNR(48) | DDRMC_CR31_TXSR(468), 31 }, + { DDRMC_CR33_EN_QK_SREF, 33 }, + { DDRMC_CR34_CKSRX(5) | DDRMC_CR34_CKSRE(5), 34 }, + + { DDRMC_CR38_FREQ_CHG_EN(0), 38 }, + { DDRMC_CR39_PHY_INI_COM(1024) | DDRMC_CR39_PHY_INI_STA(16) | + DDRMC_CR39_FRQ_CH_DLLOFF(2), 39 }, + + { DDRMC_CR41_PHY_INI_STRT_INI_DIS, 41 }, + { DDRMC_CR48_MR1_DA_0(70) | + DDRMC_CR48_MR0_DA_0(1056), 48 }, + + { DDRMC_CR66_ZQCL(256) | DDRMC_CR66_ZQINIT(512), 66 }, + { DDRMC_CR67_ZQCS(64), 67 }, + { DDRMC_CR69_ZQ_ON_SREF_EX(2), 69 }, + + { DDRMC_CR70_REF_PER_ZQ(64), 70 }, + { DDRMC_CR72_ZQCS_ROTATE(0), 72 }, + + { DDRMC_CR73_APREBIT(10) | DDRMC_CR73_COL_DIFF(1) | + DDRMC_CR73_ROW_DIFF(3), 73 }, + { DDRMC_CR74_BANKSPLT_EN | DDRMC_CR74_ADDR_CMP_EN | + DDRMC_CR74_CMD_AGE_CNT(64) | + DDRMC_CR74_AGE_CNT(64), 74 }, + { DDRMC_CR75_RW_PG_EN | DDRMC_CR75_RW_EN | DDRMC_CR75_PRI_EN | + DDRMC_CR75_PLEN, 75 }, + { DDRMC_CR76_NQENT_ACTDIS(3) | DDRMC_CR76_D_RW_G_BKCN(3) | + DDRMC_CR76_W2R_SPLT_EN, 76 }, + { DDRMC_CR77_CS_MAP | DDRMC_CR77_DI_RD_INTLEAVE | + DDRMC_CR77_SWAP_EN, 77 }, + { DDRMC_CR78_Q_FULLNESS(7) | DDRMC_CR78_BUR_ON_FLY_BIT(12), 78 }, + { DDRMC_CR79_CTLUPD_AREF(0), 79 }, + + { DDRMC_CR87_ODT_WR_MAPCS0, 87 }, + { DDRMC_CR88_TODTL_CMD(4), 88 }, + { DDRMC_CR89_AODT_RWSMCS(2), 89 }, + + { DDRMC_CR91_R2W_SMCSDL(2), 91 }, + { DDRMC_CR96_WLMRD(40) | DDRMC_CR96_WLDQSEN(25), 96 }, + + /* levelling */ + { DDRMC_CR97_WRLVL_EN, 97 }, + { DDRMC_CR98_WRLVL_DL_0(0), 98 }, + { DDRMC_CR99_WRLVL_DL_1(0), 99 }, + { DDRMC_CR102_RDLVL_REG_EN | DDRMC_CR102_RDLVL_GT_REGEN, 102 }, + { DDRMC_CR105_RDLVL_DL_0(0), 105 }, + { DDRMC_CR106_RDLVL_GTDL_0(4), 106 }, + { DDRMC_CR110_RDLVL_DL_1(0) | DDRMC_CR110_RDLVL_GTDL_1(4), 110 }, + + /* AXI */ + { DDRMC_CR117_AXI0_W_PRI(0) | DDRMC_CR117_AXI0_R_PRI(0), 117 }, + { DDRMC_CR118_AXI1_W_PRI(1) | DDRMC_CR118_AXI1_R_PRI(1), 118 }, + { DDRMC_CR120_AXI0_PRI1_RPRI(2) | + DDRMC_CR120_AXI0_PRI0_RPRI(2), 120 }, + { DDRMC_CR121_AXI0_PRI3_RPRI(2) | + DDRMC_CR121_AXI0_PRI2_RPRI(2), 121 }, + { DDRMC_CR122_AXI1_PRI1_RPRI(1) | DDRMC_CR122_AXI1_PRI0_RPRI(1) | + DDRMC_CR122_AXI0_PRIRLX(100), 122 }, + { DDRMC_CR123_AXI1_P_ODR_EN | DDRMC_CR123_AXI1_PRI3_RPRI(1) | + DDRMC_CR123_AXI1_PRI2_RPRI(1), 123 }, + { DDRMC_CR124_AXI1_PRIRLX(100), 124 }, + { DDRMC_CR126_PHY_RDLAT(8), 126 }, + { DDRMC_CR132_WRLAT_ADJ(5) | + DDRMC_CR132_RDLAT_ADJ(6), 132 }, + { DDRMC_CR137_PHYCTL_DL(2), 137 }, + { DDRMC_CR138_PHY_WRLV_MXDL(256) | + DDRMC_CR138_PHYDRAM_CK_EN(1), 138 }, + { DDRMC_CR139_PHY_WRLV_RESPLAT(4) | DDRMC_CR139_PHY_WRLV_LOAD(7) | + DDRMC_CR139_PHY_WRLV_DLL(3) | + DDRMC_CR139_PHY_WRLV_EN(3), 139 }, + { DDRMC_CR140_PHY_WRLV_WW(64), 140 }, + { DDRMC_CR143_RDLV_GAT_MXDL(1536) | + DDRMC_CR143_RDLV_MXDL(128), 143 }, + { DDRMC_CR144_PHY_RDLVL_RES(4) | DDRMC_CR144_PHY_RDLV_LOAD(7) | + DDRMC_CR144_PHY_RDLV_DLL(3) | + DDRMC_CR144_PHY_RDLV_EN(3), 144 }, + { DDRMC_CR145_PHY_RDLV_RR(64), 145 }, + { DDRMC_CR146_PHY_RDLVL_RESP(64), 146 }, + { DDRMC_CR147_RDLV_RESP_MASK(983040), 147 }, + { DDRMC_CR148_RDLV_GATE_RESP_MASK(983040), 148 }, + { DDRMC_CR151_RDLV_GAT_DQ_ZERO_CNT(1) | + DDRMC_CR151_RDLVL_DQ_ZERO_CNT(1), 151 }, + + { DDRMC_CR154_PAD_ZQ_EARLY_CMP_EN_TIMER(13) | + DDRMC_CR154_PAD_ZQ_MODE(1) | + DDRMC_CR154_DDR_SEL_PAD_CONTR(3) | + DDRMC_CR154_PAD_ZQ_HW_FOR(1), 154 }, + { DDRMC_CR155_PAD_ODT_BYTE1(1) | DDRMC_CR155_PAD_ODT_BYTE0(1), 155 }, + { DDRMC_CR158_TWR(6), 158 }, + { DDRMC_CR161_ODT_EN(1) | DDRMC_CR161_TODTH_RD(2) | + DDRMC_CR161_TODTH_WR(2), 161 }, + + /* end marker */ + { 0, -1 } +} + int dram_init(void) { - struct ddrmc_lvl_info lvl = { - .wrlvl_reg_en = 1, - .wrlvl_dl_0 = 0, - .wrlvl_dl_1 = 0, - .rdlvl_gt_reg_en = 1, - .rdlvl_gt_dl_0 = 4, - .rdlvl_gt_dl_1 = 4, - .rdlvl_reg_en = 1, - .rdlvl_dl_0 = 0, - .rdlvl_dl_1 = 0, - }; - - static const struct ddr3_jedec_timings timings = { - .tinit = 5, - .trst_pwron = 80000, - .cke_inactive = 200000, - .wrlat = 5, - .caslat_lin = 12, - .trc = 21, - .trrd = 4, - .tccd = 4, - .tfaw = 20, - .trp = 6, - .twtr = 4, - .tras_min = 15, - .tmrd = 4, - .trtp = 4, - .tras_max = 28080, - .tmod = 12, - .tckesr = 4, - .tcke = 3, - .trcd_int = 6, - .tdal = 12, - .tdll = 512, - .trp_ab = 6, - .tref = 3120, - .trfc = 44, - .tpdex = 3, - .txpdll = 10, - .txsnr = 48, - .txsr = 468, - .cksrx = 5, - .cksre = 5, - .zqcl = 256, - .zqinit = 512, - .zqcs = 64, - .ref_per_zq = 64, - .aprebit = 10, - .wlmrd = 40, - .wldqsen = 25, - }; - - ddrmc_setup_iomux(); + /* use driver default IOMUX settings */ + ddrmc_setup_iomux(NULL, 0);
- ddrmc_ctrl_init_ddr3(&timings, &lvl, 1, 3); + /* provide own CR setup but use default PHY setup */ + ddrmc_ctrl_init_ddr3(vf610twr_cr_settings, NULL); gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE);
return 0; diff --git a/board/toradex/colibri_vf/colibri_vf.c b/board/toradex/colibri_vf/colibri_vf.c index 8618fd0..01b3106 100644 --- a/board/toradex/colibri_vf/colibri_vf.c +++ b/board/toradex/colibri_vf/colibri_vf.c @@ -39,51 +39,136 @@ static const iomux_v3_cfg_t usb_pads[] = { VF610_PAD_PTD4__GPIO_83, };
+static struct ddrmc_reg_setting colibri_vf_cr_settings[] = { + { DDRMC_CR02_DRAM_TINIT(5), 2 }, + { DDRMC_CR10_TRST_PWRON(80000), 10 }, + { DDRMC_CR11_CKE_INACTIVE(200000), 11 }, + { DDRMC_CR12_WRLAT(5) | DDRMC_CR12_CASLAT_LIN(12), 12 }, + { DDRMC_CR13_TRC(21) | DDRMC_CR13_TRRD(4) | DDRMC_CR13_TCCD(4) | + DDRMC_CR13_TBST_INT_INTERVAL(0), 13 }, + { DDRMC_CR14_TFAW(20) | DDRMC_CR14_TRP(6) | DDRMC_CR14_TWTR(5) | + DDRMC_CR14_TRAS_MIN(15), 14 }, + { DDRMC_CR16_TMRD(4) | DDRMC_CR16_TRTP(4), 16 }, + { DDRMC_CR17_TRAS_MAX(28080) | DDRMC_CR17_TMOD(12), 17 }, + { DDRMC_CR18_TCKESR(4) | DDRMC_CR18_TCKE(3), 18 }, + + { DDRMC_CR20_AP_EN, 20 }, + { DDRMC_CR21_TRCD_INT(6) | DDRMC_CR21_CCMAP_EN, 21 }, + + { DDRMC_CR22_TDAL(12), 22 }, + { DDRMC_CR23_BSTLEN(3) | + DDRMC_CR23_TDLL(512), 23 }, + { DDRMC_CR24_TRP_AB(6), 24 }, + + { DDRMC_CR25_TREF_EN, 25 }, + { DDRMC_CR26_TREF(3120) | DDRMC_CR26_TRFC(44), 26 }, + { DDRMC_CR28_TREF_INT(0), 28 }, + { DDRMC_CR29_TPDEX(3), 29 }, + + { DDRMC_CR30_TXPDLL(10), 30 }, + { DDRMC_CR31_TXSNR(48) | DDRMC_CR31_TXSR(468), 31 }, + { DDRMC_CR33_EN_QK_SREF, 33 }, + { DDRMC_CR34_CKSRX(5) | DDRMC_CR34_CKSRE(5), 34 }, + + { DDRMC_CR38_FREQ_CHG_EN(0), 38 }, + { DDRMC_CR39_PHY_INI_COM(1024) | DDRMC_CR39_PHY_INI_STA(16) | + DDRMC_CR39_FRQ_CH_DLLOFF(2), 39 }, + + { DDRMC_CR41_PHY_INI_STRT_INI_DIS, 41 }, + { DDRMC_CR48_MR1_DA_0(70) | + DDRMC_CR48_MR0_DA_0(1056), 48 }, + + { DDRMC_CR66_ZQCL(256) | DDRMC_CR66_ZQINIT(512), 66 }, + { DDRMC_CR67_ZQCS(64), 67 }, + { DDRMC_CR69_ZQ_ON_SREF_EX(2), 69 }, + + { DDRMC_CR70_REF_PER_ZQ(64), 70 }, + { DDRMC_CR72_ZQCS_ROTATE(0), 72 }, + + { DDRMC_CR73_APREBIT(10) | DDRMC_CR73_COL_DIFF(1) | + DDRMC_CR73_ROW_DIFF(3), 73 }, + { DDRMC_CR74_BANKSPLT_EN | DDRMC_CR74_ADDR_CMP_EN | + DDRMC_CR74_CMD_AGE_CNT(64) | + DDRMC_CR74_AGE_CNT(64), 74 }, + { DDRMC_CR75_RW_PG_EN | DDRMC_CR75_RW_EN | DDRMC_CR75_PRI_EN | + DDRMC_CR75_PLEN, 75 }, + { DDRMC_CR76_NQENT_ACTDIS(3) | DDRMC_CR76_D_RW_G_BKCN(3) | + DDRMC_CR76_W2R_SPLT_EN, 76 }, + { DDRMC_CR77_CS_MAP | DDRMC_CR77_DI_RD_INTLEAVE | + DDRMC_CR77_SWAP_EN, 77 }, + { DDRMC_CR78_Q_FULLNESS(7) | DDRMC_CR78_BUR_ON_FLY_BIT(12), 78 }, + { DDRMC_CR79_CTLUPD_AREF(0), 79 }, + + { DDRMC_CR87_ODT_WR_MAPCS0, 87 }, + { DDRMC_CR88_TODTL_CMD(4), 88 }, + { DDRMC_CR89_AODT_RWSMCS(2), 89 }, + + { DDRMC_CR91_R2W_SMCSDL(2), 91 }, + { DDRMC_CR96_WLMRD(40) | DDRMC_CR96_WLDQSEN(25), 96 }, + + /* levelling */ + { DDRMC_CR97_WRLVL_EN, 97 }, + { DDRMC_CR98_WRLVL_DL_0(0), 98 }, + { DDRMC_CR99_WRLVL_DL_1(0), 99 }, + { DDRMC_CR102_RDLVL_REG_EN | DDRMC_CR102_RDLVL_GT_REGEN, 102 }, + { DDRMC_CR105_RDLVL_DL_0(0), 105 }, + { DDRMC_CR106_RDLVL_GTDL_0(4), 106 }, + { DDRMC_CR110_RDLVL_DL_1(0) | DDRMC_CR110_RDLVL_GTDL_1(4), 110 }, + + /* AXI */ + { DDRMC_CR117_AXI0_W_PRI(0) | DDRMC_CR117_AXI0_R_PRI(0), 117 }, + { DDRMC_CR118_AXI1_W_PRI(1) | DDRMC_CR118_AXI1_R_PRI(1), 118 }, + { DDRMC_CR120_AXI0_PRI1_RPRI(2) | + DDRMC_CR120_AXI0_PRI0_RPRI(2), 120 }, + { DDRMC_CR121_AXI0_PRI3_RPRI(2) | + DDRMC_CR121_AXI0_PRI2_RPRI(2), 121 }, + { DDRMC_CR122_AXI1_PRI1_RPRI(1) | DDRMC_CR122_AXI1_PRI0_RPRI(1) | + DDRMC_CR122_AXI0_PRIRLX(100), 122 }, + { DDRMC_CR123_AXI1_P_ODR_EN | DDRMC_CR123_AXI1_PRI3_RPRI(1) | + DDRMC_CR123_AXI1_PRI2_RPRI(1), 123 }, + { DDRMC_CR124_AXI1_PRIRLX(100), 124 }, + { DDRMC_CR126_PHY_RDLAT(8), 126 }, + { DDRMC_CR132_WRLAT_ADJ(5) | + DDRMC_CR132_RDLAT_ADJ(6), 132 }, + { DDRMC_CR137_PHYCTL_DL(2), 137 }, + { DDRMC_CR138_PHY_WRLV_MXDL(256) | + DDRMC_CR138_PHYDRAM_CK_EN(1), 138 }, + { DDRMC_CR139_PHY_WRLV_RESPLAT(4) | DDRMC_CR139_PHY_WRLV_LOAD(7) | + DDRMC_CR139_PHY_WRLV_DLL(3) | + DDRMC_CR139_PHY_WRLV_EN(3), 139 }, + { DDRMC_CR140_PHY_WRLV_WW(64), 140 }, + { DDRMC_CR143_RDLV_GAT_MXDL(1536) | + DDRMC_CR143_RDLV_MXDL(128), 143 }, + { DDRMC_CR144_PHY_RDLVL_RES(4) | DDRMC_CR144_PHY_RDLV_LOAD(7) | + DDRMC_CR144_PHY_RDLV_DLL(3) | + DDRMC_CR144_PHY_RDLV_EN(3), 144 }, + { DDRMC_CR145_PHY_RDLV_RR(64), 145 }, + { DDRMC_CR146_PHY_RDLVL_RESP(64), 146 }, + { DDRMC_CR147_RDLV_RESP_MASK(983040), 147 }, + { DDRMC_CR148_RDLV_GATE_RESP_MASK(983040), 148 }, + { DDRMC_CR151_RDLV_GAT_DQ_ZERO_CNT(1) | + DDRMC_CR151_RDLVL_DQ_ZERO_CNT(1), 151 }, + + { DDRMC_CR154_PAD_ZQ_EARLY_CMP_EN_TIMER(13) | + DDRMC_CR154_PAD_ZQ_MODE(1) | + DDRMC_CR154_DDR_SEL_PAD_CONTR(3) | + DDRMC_CR154_PAD_ZQ_HW_FOR(1), 154 }, + { DDRMC_CR155_PAD_ODT_BYTE1(1) | DDRMC_CR155_PAD_ODT_BYTE0(1), 155 }, + { DDRMC_CR158_TWR(6), 158 }, + { DDRMC_CR161_ODT_EN(1) | DDRMC_CR161_TODTH_RD(2) | + DDRMC_CR161_TODTH_WR(2), 161 }, + + /* end marker */ + { 0, -1 } +} + int dram_init(void) { - static const struct ddr3_jedec_timings timings = { - .tinit = 5, - .trst_pwron = 80000, - .cke_inactive = 200000, - .wrlat = 5, - .caslat_lin = 12, - .trc = 21, - .trrd = 4, - .tccd = 4, - .tfaw = 20, - .trp = 6, - .twtr = 4, - .tras_min = 15, - .tmrd = 4, - .trtp = 4, - .tras_max = 28080, - .tmod = 12, - .tckesr = 4, - .tcke = 3, - .trcd_int = 6, - .tdal = 12, - .tdll = 512, - .trp_ab = 6, - .tref = 3120, - .trfc = 64, - .tpdex = 3, - .txpdll = 10, - .txsnr = 48, - .txsr = 468, - .cksrx = 5, - .cksre = 5, - .zqcl = 256, - .zqinit = 512, - .zqcs = 64, - .ref_per_zq = 64, - .aprebit = 10, - .wlmrd = 40, - .wldqsen = 25, - }; - - ddrmc_setup_iomux(); + /* use driver default IOMUX settings */ + ddrmc_setup_iomux(NULL, 0);
- ddrmc_ctrl_init_ddr3(&timings, NULL, 1, 2); + /* provide own CR setup but use default PHY setup */ + ddrmc_ctrl_init_ddr3(&colibri_vf_cr_settings, NULL, 1, 2); gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE);
Add support in mxc_i2c driver, iomux_v3 and vf610 architecture for the four I2C instances available in VF610.
arch/arm/include/asm/arch-vf610/crm_regs.h | 3 +++ arch/arm/include/asm/arch-vf610/imx-regs.h | 3 +++ arch/arm/include/asm/arch-vf610/iomux-vf610.h | 11 +++++++---- arch/arm/include/asm/imx-common/iomux-v3.h | 2 ++ drivers/i2c/mxc_i2c.c | 3 ++- 5 files changed, 17 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/arch-vf610/crm_regs.h b/arch/arm/include/asm/arch-vf610/crm_regs.h index fdb45e9..a46e396 100644 --- a/arch/arm/include/asm/arch-vf610/crm_regs.h +++ b/arch/arm/include/asm/arch-vf610/crm_regs.h @@ -207,6 +207,7 @@ struct anadig_reg { #define CCM_CCGR4_CCM_CTRL_MASK (0x3 << 22) #define CCM_CCGR4_GPC_CTRL_MASK (0x3 << 24) #define CCM_CCGR4_I2C0_CTRL_MASK (0x3 << 12) +#define CCM_CCGR4_I2C1_CTRL_MASK (0x3 << 14) #define CCM_CCGR6_OCOTP_CTRL_MASK (0x3 << 10) #define CCM_CCGR6_DSPI2_CTRL_MASK (0x3 << 24) #define CCM_CCGR6_DSPI3_CTRL_MASK (0x3 << 26) @@ -216,6 +217,8 @@ struct anadig_reg { #define CCM_CCGR9_FEC0_CTRL_MASK 0x3 #define CCM_CCGR9_FEC1_CTRL_MASK (0x3 << 2) #define CCM_CCGR10_NFC_CTRL_MASK 0x3 +#define CCM_CCGR10_I2C2_CTRL_MASK (0x3 << 12) +#define CCM_CCGR10_I2C3_CTRL_MASK (0x3 << 14)
#define ANADIG_PLL7_CTRL_BYPASS (1 << 16) #define ANADIG_PLL7_CTRL_ENABLE (1 << 13) diff --git a/arch/arm/include/asm/arch-vf610/imx-regs.h b/arch/arm/include/asm/arch-vf610/imx-regs.h index 7df3b1e..4366985 100644 --- a/arch/arm/include/asm/arch-vf610/imx-regs.h +++ b/arch/arm/include/asm/arch-vf610/imx-regs.h @@ -75,6 +75,9 @@ #define ESAI_FIFO_BASE_ADDR (AIPS0_BASE_ADDR + 0x00063000) #define WDOG_BASE_ADDR (AIPS0_BASE_ADDR + 0x00065000) #define I2C1_BASE_ADDR (AIPS0_BASE_ADDR + 0x00066000) +#define I2C2_BASE_ADDR (AIPS0_BASE_ADDR + 0x00067000) +#define I2C3_BASE_ADDR (AIPS0_BASE_ADDR + 0x000E6000) +#define I2C4_BASE_ADDR (AIPS0_BASE_ADDR + 0x000E7000) #define WKUP_BASE_ADDR (AIPS0_BASE_ADDR + 0x0006A000) #define CCM_BASE_ADDR (AIPS0_BASE_ADDR + 0x0006B000) #define GPC_BASE_ADDR (AIPS0_BASE_ADDR + 0x0006C000) diff --git a/arch/arm/include/asm/arch-vf610/iomux-vf610.h b/arch/arm/include/asm/arch-vf610/iomux-vf610.h index 019307b..0e2bd53 100644 --- a/arch/arm/include/asm/arch-vf610/iomux-vf610.h +++ b/arch/arm/include/asm/arch-vf610/iomux-vf610.h @@ -20,7 +20,8 @@ #define VF610_DDR_PAD_CTRL_1 (PAD_CTL_DSE_25ohm | \ PAD_CTL_INPUT_DIFFERENTIAL) #define VF610_I2C_PAD_CTRL (PAD_CTL_PUS_47K_UP | PAD_CTL_DSE_50ohm | \ - PAD_CTL_SPEED_HIGH | PAD_CTL_OBE_IBE_ENABLE) + PAD_CTL_SPEED_HIGH | PAD_CTL_ODE | \ + PAD_CTL_OBE_IBE_ENABLE) #define VF610_NFC_IO_PAD_CTRL (PAD_CTL_SPEED_MED | PAD_CTL_SRE | \ PAD_CTL_DSE_50ohm | PAD_CTL_PUS_47K_UP | \ PAD_CTL_OBE_IBE_ENABLE) @@ -110,6 +111,8 @@ enum { VF610_PAD_PTA29__ESDHC1_DAT3 = IOMUX_PAD(0x004c, 0x004c, 5, __NA_, 0, VF610_SDHC_PAD_CTRL), VF610_PAD_PTB14__I2C0_SCL = IOMUX_PAD(0x0090, 0x0090, 2, 0x033c, 1, VF610_I2C_PAD_CTRL), VF610_PAD_PTB15__I2C0_SDA = IOMUX_PAD(0x0094, 0x0094, 2, 0x0340, 1, VF610_I2C_PAD_CTRL), + VF610_PAD_PTA22__I2C2_SCL = IOMUX_PAD(0x0030, 0x0030, 6, 0x034c, 0, VF610_I2C_PAD_CTRL), + VF610_PAD_PTA23__I2C2_SDA = IOMUX_PAD(0x0034, 0x0034, 6, 0x0350, 0, VF610_I2C_PAD_CTRL), VF610_PAD_PTD31__NF_IO15 = IOMUX_PAD(0x00fc, 0x00fc, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), VF610_PAD_PTD31__GPIO_63 = IOMUX_PAD(0x00fc, 0x00fc, 0, __NA_, 0, VF610_GPIO_PAD_CTRL), VF610_PAD_PTD30__NF_IO14 = IOMUX_PAD(0x0100, 0x0100, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), @@ -146,10 +149,10 @@ enum { VF610_PAD_PTD12__GPIO_91 = IOMUX_PAD(0x016c, 0x016c, 0, __NA_, 0, VF610_GPIO_PAD_CTRL), VF610_PAD_PTD13__GPIO_92 = IOMUX_PAD(0x0170, 0x0170, 0, __NA_, 0, VF610_GPIO_PAD_CTRL), VF610_PAD_PTD22__NF_IO6 = IOMUX_PAD(0x0120, 0x0120, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), - VF610_PAD_PTD21__NF_IO5 = IOMUX_PAD(0x0124, 0x0124, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), - VF610_PAD_PTD20__NF_IO4 = IOMUX_PAD(0x0128, 0x0128, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), + VF610_PAD_PTD21__NF_IO5 = IOMUX_PAD(0x0124, 0x0124, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), + VF610_PAD_PTD20__NF_IO4 = IOMUX_PAD(0x0128, 0x0128, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), VF610_PAD_PTD19__NF_IO3 = IOMUX_PAD(0x012c, 0x012c, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), - VF610_PAD_PTD18__NF_IO2 = IOMUX_PAD(0x0130, 0x0130, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), + VF610_PAD_PTD18__NF_IO2 = IOMUX_PAD(0x0130, 0x0130, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), VF610_PAD_PTD17__NF_IO1 = IOMUX_PAD(0x0134, 0x0134, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), VF610_PAD_PTD16__NF_IO0 = IOMUX_PAD(0x0138, 0x0138, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), VF610_PAD_PTB24__NF_WE_B = IOMUX_PAD(0x0178, 0x0178, 5, __NA_, 0, VF610_NFC_CN_PAD_CTRL), diff --git a/arch/arm/include/asm/imx-common/iomux-v3.h b/arch/arm/include/asm/imx-common/iomux-v3.h index 2581019..5cde90f 100644 --- a/arch/arm/include/asm/imx-common/iomux-v3.h +++ b/arch/arm/include/asm/imx-common/iomux-v3.h @@ -127,6 +127,8 @@ typedef u64 iomux_v3_cfg_t;
#define PAD_CTL_SRE (1 << 11)
+#define PAD_CTL_ODE (1 << 10) + #define PAD_CTL_DSE_150ohm (1 << 6) #define PAD_CTL_DSE_50ohm (3 << 6) #define PAD_CTL_DSE_25ohm (6 << 6) diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index b3c50aa..f1056e2 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -523,7 +523,8 @@ static int bus_i2c_write(struct mxc_i2c_bus *i2c_bus, u8 chip, u32 addr, #endif
static struct mxc_i2c_bus mxc_i2c_buses[] = { -#if defined(CONFIG_LS102XA) || defined(CONFIG_FSL_LSCH3) +#if defined(CONFIG_LS102XA) || defined(CONFIG_FSL_LSCH3) || \ + defined(CONFIG_VF610) { 0, I2C1_BASE_ADDR, I2C_QUIRK_FLAG }, { 1, I2C2_BASE_ADDR, I2C_QUIRK_FLAG }, { 2, I2C3_BASE_ADDR, I2C_QUIRK_FLAG },
imximage header size is 4-byte, not 8-byte aligned. This produces .imx images that a Vybrid cannot boot on.
Fix by adding a "padding" field in header.
tools/imximage.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/imximage.h b/tools/imximage.h index 36fe095..a913329 100644 --- a/tools/imximage.h +++ b/tools/imximage.h @@ -129,6 +129,7 @@ typedef struct { ivt_header_t header; write_dcd_command_t write_dcd_command; dcd_addr_data_t addr_data[MAX_HW_CFG_SIZE_V2]; + uint32_t padding[1]; /* end up on an 8-byte boundary */ } dcd_v2_t;
typedef struct {
Devices supported are: - NFC (NAND FLASH) - MMC - QSPI (SPI NOR FLASH) - I2C (only bus 2) - I2C RTC - I2C EEPROM - FEC
NOTES:
1. The NAND partitioning is different from the TimeSys U-Boot deliveries' for the following reasons:
- mainline U-Boot is bigger than TimeSys', even though it now builds for Thumb state, which forces the bootloader area size to increase by 128KB;
- The redundant environment definition in the TimeSys deliveries is erroneous, as both environments are in the same Flash sector. Here each environment gest its own sector, which increases the size needed for the environments by 128KB;
- The kernel area was consequently reduced by 256KB, and the rootfs area left unchanged (depending on the actual kernel size, the kernel and rootfs area sizes may need to change again in the future).
2. The FEC presents a bug whereby it will indicate a packet as sent but will not actually have sent it. Caches are not the cause. Erratum e6358 is not the cause, and implementing this erratum's workaround does not fix the bug. The FEC's observable state is strictly the same (and correct) whether the packet was actually sent or not, i.e., there is no way to detect a bug occurrence, apart from the higher layer failure (e.g. TFTP timeout). At this point I suspect this to be a silicon bug.
Patch-series: 1 Signed-off-by: Albert ARIBAUD (3ADEV) albert.aribaud@3adev.fr ---
arch/arm/Kconfig | 5 + board/phytec/pcm052/Kconfig | 15 ++ board/phytec/pcm052/MAINTAINERS | 6 + board/phytec/pcm052/Makefile | 7 + board/phytec/pcm052/imximage.cfg | 17 ++ board/phytec/pcm052/pcm052.c | 530 +++++++++++++++++++++++++++++++++++++++ configs/pcm052_defconfig | 6 + include/configs/pcm052.h | 234 +++++++++++++++++ 8 files changed, 820 insertions(+) create mode 100644 board/phytec/pcm052/Kconfig create mode 100644 board/phytec/pcm052/MAINTAINERS create mode 100644 board/phytec/pcm052/Makefile create mode 100644 board/phytec/pcm052/imximage.cfg create mode 100644 board/phytec/pcm052/pcm052.c create mode 100644 configs/pcm052_defconfig create mode 100644 include/configs/pcm052.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index ac86518..27a5a04 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -661,6 +661,10 @@ config TARGET_COLIBRI_VF bool "Support Colibri VF50/61" select CPU_V7
+config TARGET_PCM052 + bool "Support pcm-052" + select CPU_V7 + config ARCH_ZYNQ bool "Xilinx Zynq Platform" select CPU_V7 @@ -936,6 +940,7 @@ source "board/palmld/Kconfig" source "board/palmtc/Kconfig" source "board/palmtreo680/Kconfig" source "board/phytec/pcm051/Kconfig" +source "board/phytec/pcm052/Kconfig" source "board/ppcag/bg0900/Kconfig" source "board/pxa255_idp/Kconfig" source "board/samsung/smdk2410/Kconfig" diff --git a/board/phytec/pcm052/Kconfig b/board/phytec/pcm052/Kconfig new file mode 100644 index 0000000..d67a69a --- /dev/null +++ b/board/phytec/pcm052/Kconfig @@ -0,0 +1,15 @@ +if TARGET_PCM052 + +config SYS_BOARD + default "pcm052" + +config SYS_VENDOR + default "phytec" + +config SYS_SOC + default "vf610" + +config SYS_CONFIG_NAME + default "pcm052" + +endif diff --git a/board/phytec/pcm052/MAINTAINERS b/board/phytec/pcm052/MAINTAINERS new file mode 100644 index 0000000..a877436 --- /dev/null +++ b/board/phytec/pcm052/MAINTAINERS @@ -0,0 +1,6 @@ +PCM052 BOARD +M: Albert ARIBAUD (3ADEV) albert.aribaud@3adev.fr +S: Maintained +F: board/phytec/pcm052/ +F: include/configs/pcm052.h +F: configs/pcm052_defconfig diff --git a/board/phytec/pcm052/Makefile b/board/phytec/pcm052/Makefile new file mode 100644 index 0000000..144f4e7 --- /dev/null +++ b/board/phytec/pcm052/Makefile @@ -0,0 +1,7 @@ +# +# Copyright 2013 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := pcm052.o diff --git a/board/phytec/pcm052/imximage.cfg b/board/phytec/pcm052/imximage.cfg new file mode 100644 index 0000000..f5a9747 --- /dev/null +++ b/board/phytec/pcm052/imximage.cfg @@ -0,0 +1,17 @@ +/* + * Copyright 2015 3ADEV http://www.3adev.com + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ +#include <asm/imx-common/imximage.cfg> + +/* image version */ +IMAGE_VERSION 2 + +/* Boot Offset 0x400, valid for both SD and NAND boot */ +BOOT_OFFSET FLASH_OFFSET_STANDARD diff --git a/board/phytec/pcm052/pcm052.c b/board/phytec/pcm052/pcm052.c new file mode 100644 index 0000000..0607f1c --- /dev/null +++ b/board/phytec/pcm052/pcm052.c @@ -0,0 +1,530 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux-vf610.h> +#include <asm/arch/ddrmc-vf610.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/clock.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <miiphy.h> +#include <netdev.h> +#include <i2c.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Default DDR pad settings in arch/arm/include/asm/arch-vf610/iomux-vf610.h + * do not match our settings. Let us (re)define our own settings here. + */ + +#define PCM052_VF610_DDR_PAD_CTRL PAD_CTL_DSE_20ohm +#define PCM052_VF610_DDR_PAD_CTRL_1 (PAD_CTL_DSE_20ohm | \ + PAD_CTL_INPUT_DIFFERENTIAL) +#define PCM052_VF610_DDR_RESET_PAD_CTL (PAD_CTL_DSE_150ohm | \ + PAD_CTL_PUS_100K_UP | \ + PAD_CTL_INPUT_DIFFERENTIAL) + +enum { + PCM052_VF610_PAD_DDR_RESETB = IOMUX_PAD(0x021c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_RESET_PAD_CTL), + PCM052_VF610_PAD_DDR_A15__DDR_A_15 = IOMUX_PAD(0x0220, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A14__DDR_A_14 = IOMUX_PAD(0x0224, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A13__DDR_A_13 = IOMUX_PAD(0x0228, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A12__DDR_A_12 = IOMUX_PAD(0x022c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A11__DDR_A_11 = IOMUX_PAD(0x0230, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A10__DDR_A_10 = IOMUX_PAD(0x0234, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A9__DDR_A_9 = IOMUX_PAD(0x0238, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A8__DDR_A_8 = IOMUX_PAD(0x023c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A7__DDR_A_7 = IOMUX_PAD(0x0240, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A6__DDR_A_6 = IOMUX_PAD(0x0244, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A5__DDR_A_5 = IOMUX_PAD(0x0248, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A4__DDR_A_4 = IOMUX_PAD(0x024c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A3__DDR_A_3 = IOMUX_PAD(0x0250, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A2__DDR_A_2 = IOMUX_PAD(0x0254, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A1__DDR_A_1 = IOMUX_PAD(0x0258, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A0__DDR_A_0 = IOMUX_PAD(0x025c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_BA2__DDR_BA_2 = IOMUX_PAD(0x0260, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_BA1__DDR_BA_1 = IOMUX_PAD(0x0264, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_BA0__DDR_BA_0 = IOMUX_PAD(0x0268, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_CAS__DDR_CAS_B = IOMUX_PAD(0x026c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_CKE__DDR_CKE_0 = IOMUX_PAD(0x0270, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_CLK__DDR_CLK_0 = IOMUX_PAD(0x0274, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL_1), + PCM052_VF610_PAD_DDR_CS__DDR_CS_B_0 = IOMUX_PAD(0x0278, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D15__DDR_D_15 = IOMUX_PAD(0x027c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D14__DDR_D_14 = IOMUX_PAD(0x0280, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D13__DDR_D_13 = IOMUX_PAD(0x0284, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D12__DDR_D_12 = IOMUX_PAD(0x0288, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D11__DDR_D_11 = IOMUX_PAD(0x028c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D10__DDR_D_10 = IOMUX_PAD(0x0290, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D9__DDR_D_9 = IOMUX_PAD(0x0294, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D8__DDR_D_8 = IOMUX_PAD(0x0298, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D7__DDR_D_7 = IOMUX_PAD(0x029c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D6__DDR_D_6 = IOMUX_PAD(0x02a0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D5__DDR_D_5 = IOMUX_PAD(0x02a4, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D4__DDR_D_4 = IOMUX_PAD(0x02a8, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D3__DDR_D_3 = IOMUX_PAD(0x02ac, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D2__DDR_D_2 = IOMUX_PAD(0x02b0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D1__DDR_D_1 = IOMUX_PAD(0x02b4, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D0__DDR_D_0 = IOMUX_PAD(0x02b8, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_DQM1__DDR_DQM_1 = IOMUX_PAD(0x02bc, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_DQM0__DDR_DQM_0 = IOMUX_PAD(0x02c0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_DQS1__DDR_DQS_1 = IOMUX_PAD(0x02c4, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL_1), + PCM052_VF610_PAD_DDR_DQS0__DDR_DQS_0 = IOMUX_PAD(0x02c8, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL_1), + PCM052_VF610_PAD_DDR_RAS__DDR_RAS_B = IOMUX_PAD(0x02cc, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_WE__DDR_WE_B = IOMUX_PAD(0x02d0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_ODT1__DDR_ODT_0 = IOMUX_PAD(0x02d4, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_ODT0__DDR_ODT_1 = IOMUX_PAD(0x02d8, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_DDRBYTE1__DDR_DDRBYTE1 = IOMUX_PAD(0x02dc, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_DDRBYTE0__DDR_DDRBYTE0 = IOMUX_PAD(0x02e0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), +}; + +static struct ddrmc_reg_setting pcm052_cr_settings[] = { + { DDRMC_CR00_DRAM_CLASS_DDR3, 0 }, + { DDRMC_CR02_DRAM_TINIT(5), 2 }, + { DDRMC_CR10_TRST_PWRON(80000), 10 }, + + { DDRMC_CR11_CKE_INACTIVE(200000), 11 }, + { DDRMC_CR12_WRLAT(5) | DDRMC_CR12_CASLAT_LIN(12), 12 }, + { DDRMC_CR13_TRC(6) | DDRMC_CR13_TRRD(4) | DDRMC_CR13_TCCD(4) | + DDRMC_CR13_TBST_INT_INTERVAL(4), 13 }, + { DDRMC_CR14_TFAW(18) | DDRMC_CR14_TRP(6) | DDRMC_CR14_TWTR(4) | + DDRMC_CR14_TRAS_MIN(15), 14 }, + { DDRMC_CR16_TMRD(4) |DDRMC_CR16_TRTP(4), 16 }, + { DDRMC_CR17_TRAS_MAX(14040) | DDRMC_CR17_TMOD(12), 17 }, + { DDRMC_CR18_TCKESR(4) | DDRMC_CR18_TCKE(3), 18 }, + + { DDRMC_CR20_AP_EN, 20 }, + { DDRMC_CR21_TRCD_INT(6) | DDRMC_CR21_CCMAP_EN | + DDRMC_CR21_TRAS_LOCKOUT, 21 }, + + { DDRMC_CR22_TDAL(10), 22 }, + { DDRMC_CR23_BSTLEN(3) | DDRMC_CR23_TDLL(512), 23 }, + { DDRMC_CR24_TRP_AB(6), 24 }, + + { DDRMC_CR25_TREF_EN, 25 }, + { DDRMC_CR26_TREF(1542) | DDRMC_CR26_TRFC(64), 26 }, + { DDRMC_CR28_TREF_INT(5), 28 }, + { DDRMC_CR29_TPDEX(3), 29 }, + + { DDRMC_CR30_TXPDLL(10), 30 }, + { DDRMC_CR31_TXSNR(68) | DDRMC_CR31_TXSR(506), 31 }, + { DDRMC_CR33_EN_QK_SREF, 33 }, + { DDRMC_CR34_CKSRX(5) | DDRMC_CR34_CKSRE(5), 34 }, + + { DDRMC_CR38_FREQ_CHG_EN(1), 38 }, + { DDRMC_CR39_PHY_INI_COM(1024) | DDRMC_CR39_PHY_INI_STA(16) | + DDRMC_CR39_FRQ_CH_DLLOFF(2), 39 }, + + { DDRMC_CR41_PHY_INI_STRT_INI_DIS, 41 }, + { DDRMC_CR48_MR1_DA_0(70) | DDRMC_CR48_MR0_DA_0(1056), 48 }, + + { DDRMC_CR66_ZQCL(256) | DDRMC_CR66_ZQINIT(512), 66 }, + { DDRMC_CR67_ZQCS(64), 67 }, + { DDRMC_CR69_ZQ_ON_SREF_EX(2), 69 }, + + { DDRMC_CR70_REF_PER_ZQ(64), 70 }, + { DDRMC_CR72_ZQCS_ROTATE(1), 72 }, + + { DDRMC_CR73_APREBIT(10) | DDRMC_CR73_COL_DIFF(1) | + DDRMC_CR73_ROW_DIFF(2), 73 }, + { DDRMC_CR74_BANKSPLT_EN | DDRMC_CR74_ADDR_CMP_EN | + DDRMC_CR74_CMD_AGE_CNT(255) | DDRMC_CR74_AGE_CNT(255), + 74 }, + { DDRMC_CR75_RW_PG_EN | DDRMC_CR75_RW_EN | DDRMC_CR75_PRI_EN | + DDRMC_CR75_PLEN, 75 }, + { DDRMC_CR76_NQENT_ACTDIS(3) | DDRMC_CR76_D_RW_G_BKCN(3) | + DDRMC_CR76_W2R_SPLT_EN, 76 }, + { DDRMC_CR77_CS_MAP | DDRMC_CR77_DI_RD_INTLEAVE | + DDRMC_CR77_SWAP_EN, 77 }, + { DDRMC_CR78_Q_FULLNESS(0) | + DDRMC_CR78_BUR_ON_FLY_BIT(12), 78 }, + { DDRMC_CR79_CTLUPD_AREF(0), 79 }, + + { DDRMC_CR87_ODT_WR_MAPCS0 | DDRMC_CR87_ODT_RD_MAPCS0, 87 }, + { DDRMC_CR88_TODTL_CMD(4), 88 }, + { DDRMC_CR89_AODT_RWSMCS(2), 89 }, + + { DDRMC_CR91_R2W_SMCSDL(2), 91 }, + { DDRMC_CR96_WLMRD(40) | DDRMC_CR96_WLDQSEN(25), 96 }, + + { 0x00002000, 105 }, + { 0x00000020, 110 }, + + { DDRMC_CR117_AXI0_W_PRI(1) | DDRMC_CR117_AXI0_R_PRI(1), 117 }, + { DDRMC_CR118_AXI1_W_PRI(1) | DDRMC_CR118_AXI1_R_PRI(1), 118 }, + { DDRMC_CR120_AXI0_PRI1_RPRI(2) | + DDRMC_CR120_AXI0_PRI0_RPRI(2), 120 }, + { DDRMC_CR121_AXI0_PRI3_RPRI(2) | + DDRMC_CR121_AXI0_PRI2_RPRI(2), 121 }, + { DDRMC_CR122_AXI1_PRI1_RPRI(1) | DDRMC_CR122_AXI1_PRI0_RPRI(1) | + DDRMC_CR122_AXI0_PRIRLX(100), 122 }, + { DDRMC_CR123_AXI1_P_ODR_EN | DDRMC_CR123_AXI1_PRI3_RPRI(1) | + DDRMC_CR123_AXI1_PRI2_RPRI(1), 123 }, + { DDRMC_CR124_AXI1_PRIRLX(100), 124 }, + { DDRMC_CR126_PHY_RDLAT(11), 126 }, + { DDRMC_CR132_WRLAT_ADJ(5) | DDRMC_CR132_RDLAT_ADJ(6), 132 }, + { DDRMC_CR137_PHYCTL_DL(2), 137 }, + { DDRMC_CR139_PHY_WRLV_RESPLAT(4) | DDRMC_CR139_PHY_WRLV_LOAD(7) | + DDRMC_CR139_PHY_WRLV_DLL(3) | + DDRMC_CR139_PHY_WRLV_EN(3), 139 }, + { DDRMC_CR154_PAD_ZQ_EARLY_CMP_EN_TIMER(13) | + DDRMC_CR154_PAD_ZQ_MODE(1) | + DDRMC_CR154_DDR_SEL_PAD_CONTR(3) | + DDRMC_CR154_PAD_ZQ_HW_FOR(0), 154 }, + { DDRMC_CR155_PAD_ODT_BYTE1(5) | DDRMC_CR155_PAD_ODT_BYTE0(5), 155 }, + { DDRMC_CR158_TWR(6), 158 }, + { DDRMC_CR161_ODT_EN(0) | DDRMC_CR161_TODTH_RD(0) | + DDRMC_CR161_TODTH_WR(6), 161 }, + /* end marker */ + { 0, -1 } +}; + +/* PHY settings -- some of them differ from default in imx-regs.h */ + +#define PCM052_DDRMC_PHY_DQ_TIMING 0x00002213 +#define PCM052_DDRMC_PHY_CTRL 0x00290000 +#define PCM052_DDRMC_PHY_SLAVE_CTRL 0x00002c00 +#define PCM052_DDRMC_PHY_PROC_PAD_ODT 0x00010020 + +static struct ddrmc_reg_setting pcm052_phy_settings[] = { + { PCM052_DDRMC_PHY_DQ_TIMING, 0 }, + { PCM052_DDRMC_PHY_DQ_TIMING, 16 }, + { PCM052_DDRMC_PHY_DQ_TIMING, 32 }, + { PCM052_DDRMC_PHY_DQ_TIMING, 48 }, + { DDRMC_PHY_DQS_TIMING, 1 }, + { DDRMC_PHY_DQS_TIMING, 17 }, + { DDRMC_PHY_DQS_TIMING, 33 }, + { DDRMC_PHY_DQS_TIMING, 49 }, + { PCM052_DDRMC_PHY_CTRL, 2 }, + { PCM052_DDRMC_PHY_CTRL, 18 }, + { PCM052_DDRMC_PHY_CTRL, 34 }, + { DDRMC_PHY_MASTER_CTRL, 3 }, + { DDRMC_PHY_MASTER_CTRL, 19 }, + { DDRMC_PHY_MASTER_CTRL, 35 }, + { PCM052_DDRMC_PHY_SLAVE_CTRL, 4 }, + { PCM052_DDRMC_PHY_SLAVE_CTRL, 20 }, + { PCM052_DDRMC_PHY_SLAVE_CTRL, 36 }, + { DDRMC_PHY50_DDR3_MODE | DDRMC_PHY50_EN_SW_HALF_CYCLE, 50 }, + { PCM052_DDRMC_PHY_PROC_PAD_ODT, 52 }, + + /* end marker */ + { 0, -1 } +}; + +int dram_init(void) +{ + static const iomux_v3_cfg_t pcm052_pads[] = { + PCM052_VF610_PAD_DDR_A15__DDR_A_15, + PCM052_VF610_PAD_DDR_A14__DDR_A_14, + PCM052_VF610_PAD_DDR_A13__DDR_A_13, + PCM052_VF610_PAD_DDR_A12__DDR_A_12, + PCM052_VF610_PAD_DDR_A11__DDR_A_11, + PCM052_VF610_PAD_DDR_A10__DDR_A_10, + PCM052_VF610_PAD_DDR_A9__DDR_A_9, + PCM052_VF610_PAD_DDR_A8__DDR_A_8, + PCM052_VF610_PAD_DDR_A7__DDR_A_7, + PCM052_VF610_PAD_DDR_A6__DDR_A_6, + PCM052_VF610_PAD_DDR_A5__DDR_A_5, + PCM052_VF610_PAD_DDR_A4__DDR_A_4, + PCM052_VF610_PAD_DDR_A3__DDR_A_3, + PCM052_VF610_PAD_DDR_A2__DDR_A_2, + PCM052_VF610_PAD_DDR_A1__DDR_A_1, + PCM052_VF610_PAD_DDR_A0__DDR_A_0, + PCM052_VF610_PAD_DDR_BA2__DDR_BA_2, + PCM052_VF610_PAD_DDR_BA1__DDR_BA_1, + PCM052_VF610_PAD_DDR_BA0__DDR_BA_0, + PCM052_VF610_PAD_DDR_CAS__DDR_CAS_B, + PCM052_VF610_PAD_DDR_CKE__DDR_CKE_0, + PCM052_VF610_PAD_DDR_CLK__DDR_CLK_0, + PCM052_VF610_PAD_DDR_CS__DDR_CS_B_0, + PCM052_VF610_PAD_DDR_D15__DDR_D_15, + PCM052_VF610_PAD_DDR_D14__DDR_D_14, + PCM052_VF610_PAD_DDR_D13__DDR_D_13, + PCM052_VF610_PAD_DDR_D12__DDR_D_12, + PCM052_VF610_PAD_DDR_D11__DDR_D_11, + PCM052_VF610_PAD_DDR_D10__DDR_D_10, + PCM052_VF610_PAD_DDR_D9__DDR_D_9, + PCM052_VF610_PAD_DDR_D8__DDR_D_8, + PCM052_VF610_PAD_DDR_D7__DDR_D_7, + PCM052_VF610_PAD_DDR_D6__DDR_D_6, + PCM052_VF610_PAD_DDR_D5__DDR_D_5, + PCM052_VF610_PAD_DDR_D4__DDR_D_4, + PCM052_VF610_PAD_DDR_D3__DDR_D_3, + PCM052_VF610_PAD_DDR_D2__DDR_D_2, + PCM052_VF610_PAD_DDR_D1__DDR_D_1, + PCM052_VF610_PAD_DDR_D0__DDR_D_0, + PCM052_VF610_PAD_DDR_DQM1__DDR_DQM_1, + PCM052_VF610_PAD_DDR_DQM0__DDR_DQM_0, + PCM052_VF610_PAD_DDR_DQS1__DDR_DQS_1, + PCM052_VF610_PAD_DDR_DQS0__DDR_DQS_0, + PCM052_VF610_PAD_DDR_RAS__DDR_RAS_B, + PCM052_VF610_PAD_DDR_WE__DDR_WE_B, + PCM052_VF610_PAD_DDR_ODT1__DDR_ODT_0, + PCM052_VF610_PAD_DDR_ODT0__DDR_ODT_1, + PCM052_VF610_PAD_DDR_DDRBYTE1__DDR_DDRBYTE1, + PCM052_VF610_PAD_DDR_DDRBYTE0__DDR_DDRBYTE0, + PCM052_VF610_PAD_DDR_RESETB, + }; + + imx_iomux_v3_setup_multiple_pads(pcm052_pads, ARRAY_SIZE(pcm052_pads)); + + ddrmc_ctrl_init_ddr3(pcm052_cr_settings, pcm052_phy_settings); + + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + + return 0; +} + +static void setup_iomux_uart(void) +{ + static const iomux_v3_cfg_t uart1_pads[] = { + NEW_PAD_CTRL(VF610_PAD_PTB4__UART1_TX, VF610_UART_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTB5__UART1_RX, VF610_UART_PAD_CTRL), + }; + + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + +#define ENET_PAD_CTRL (PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_HIGH | \ + PAD_CTL_DSE_50ohm | PAD_CTL_OBE_IBE_ENABLE) + +static void setup_iomux_enet(void) +{ + static const iomux_v3_cfg_t enet0_pads[] = { + NEW_PAD_CTRL(VF610_PAD_PTA6__RMII0_CLKIN, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC1__RMII0_MDIO, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC0__RMII0_MDC, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC2__RMII0_CRS_DV, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC3__RMII0_RD1, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC4__RMII0_RD0, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC5__RMII0_RXER, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC6__RMII0_TD1, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC7__RMII0_TD0, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC8__RMII0_TXEN, ENET_PAD_CTRL), + }; + + imx_iomux_v3_setup_multiple_pads(enet0_pads, ARRAY_SIZE(enet0_pads)); +} + +/* + * I2C2 is the only I2C used, on pads PTA22/PTA23. + */ + +static void setup_iomux_i2c(void) +{ + static const iomux_v3_cfg_t i2c_pads[] = { + VF610_PAD_PTA22__I2C2_SCL, + VF610_PAD_PTA23__I2C2_SDA, + }; + + imx_iomux_v3_setup_multiple_pads(i2c_pads, ARRAY_SIZE(i2c_pads)); +} + +#ifdef CONFIG_NAND_VF610_NFC +static void setup_iomux_nfc(void) +{ + static const iomux_v3_cfg_t nfc_pads[] = { + VF610_PAD_PTD31__NF_IO15, + VF610_PAD_PTD30__NF_IO14, + VF610_PAD_PTD29__NF_IO13, + VF610_PAD_PTD28__NF_IO12, + VF610_PAD_PTD27__NF_IO11, + VF610_PAD_PTD26__NF_IO10, + VF610_PAD_PTD25__NF_IO9, + VF610_PAD_PTD24__NF_IO8, + VF610_PAD_PTD23__NF_IO7, + VF610_PAD_PTD22__NF_IO6, + VF610_PAD_PTD21__NF_IO5, + VF610_PAD_PTD20__NF_IO4, + VF610_PAD_PTD19__NF_IO3, + VF610_PAD_PTD18__NF_IO2, + VF610_PAD_PTD17__NF_IO1, + VF610_PAD_PTD16__NF_IO0, + VF610_PAD_PTB24__NF_WE_B, + VF610_PAD_PTB25__NF_CE0_B, + VF610_PAD_PTB27__NF_RE_B, + VF610_PAD_PTC26__NF_RB_B, + VF610_PAD_PTC27__NF_ALE, + VF610_PAD_PTC28__NF_CLE + }; + + imx_iomux_v3_setup_multiple_pads(nfc_pads, ARRAY_SIZE(nfc_pads)); +} +#endif + +static void setup_iomux_qspi(void) +{ + static const iomux_v3_cfg_t qspi0_pads[] = { + VF610_PAD_PTD0__QSPI0_A_QSCK, + VF610_PAD_PTD1__QSPI0_A_CS0, + VF610_PAD_PTD2__QSPI0_A_DATA3, + VF610_PAD_PTD3__QSPI0_A_DATA2, + VF610_PAD_PTD4__QSPI0_A_DATA1, + VF610_PAD_PTD5__QSPI0_A_DATA0, + VF610_PAD_PTD7__QSPI0_B_QSCK, + VF610_PAD_PTD8__QSPI0_B_CS0, + VF610_PAD_PTD9__QSPI0_B_DATA3, + VF610_PAD_PTD10__QSPI0_B_DATA2, + VF610_PAD_PTD11__QSPI0_B_DATA1, + VF610_PAD_PTD12__QSPI0_B_DATA0, + }; + + imx_iomux_v3_setup_multiple_pads(qspi0_pads, ARRAY_SIZE(qspi0_pads)); +} + +#define ESDHC_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_HIGH | \ + PAD_CTL_DSE_20ohm | PAD_CTL_OBE_IBE_ENABLE) + +struct fsl_esdhc_cfg esdhc_cfg[1] = { + {ESDHC1_BASE_ADDR}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + /* eSDHC1 is always present */ + return 1; +} + +int board_mmc_init(bd_t *bis) +{ + static const iomux_v3_cfg_t esdhc1_pads[] = { + NEW_PAD_CTRL(VF610_PAD_PTA24__ESDHC1_CLK, ESDHC_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTA25__ESDHC1_CMD, ESDHC_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTA26__ESDHC1_DAT0, ESDHC_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTA27__ESDHC1_DAT1, ESDHC_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTA28__ESDHC1_DAT2, ESDHC_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTA29__ESDHC1_DAT3, ESDHC_PAD_CTRL), + }; + + esdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + + imx_iomux_v3_setup_multiple_pads( + esdhc1_pads, ARRAY_SIZE(esdhc1_pads)); + + return fsl_esdhc_initialize(bis, &esdhc_cfg[0]); +} + +static void clock_init(void) +{ + struct ccm_reg *ccm = (struct ccm_reg *)CCM_BASE_ADDR; + struct anadig_reg *anadig = (struct anadig_reg *)ANADIG_BASE_ADDR; + + clrsetbits_le32(&ccm->ccgr0, CCM_REG_CTRL_MASK, + CCM_CCGR0_UART1_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr1, CCM_REG_CTRL_MASK, + CCM_CCGR1_PIT_CTRL_MASK | CCM_CCGR1_WDOGA5_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr2, CCM_REG_CTRL_MASK, + CCM_CCGR2_IOMUXC_CTRL_MASK | CCM_CCGR2_PORTA_CTRL_MASK | + CCM_CCGR2_PORTB_CTRL_MASK | CCM_CCGR2_PORTC_CTRL_MASK | + CCM_CCGR2_PORTD_CTRL_MASK | CCM_CCGR2_PORTE_CTRL_MASK | + CCM_CCGR2_QSPI0_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr3, CCM_REG_CTRL_MASK, + CCM_CCGR3_ANADIG_CTRL_MASK | CCM_CCGR3_SCSC_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr4, CCM_REG_CTRL_MASK, + CCM_CCGR4_WKUP_CTRL_MASK | CCM_CCGR4_CCM_CTRL_MASK | + CCM_CCGR4_GPC_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr6, CCM_REG_CTRL_MASK, + CCM_CCGR6_OCOTP_CTRL_MASK | CCM_CCGR6_DDRMC_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr7, CCM_REG_CTRL_MASK, + CCM_CCGR7_SDHC1_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr9, CCM_REG_CTRL_MASK, + CCM_CCGR9_FEC0_CTRL_MASK | CCM_CCGR9_FEC1_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr10, CCM_REG_CTRL_MASK, + CCM_CCGR10_NFC_CTRL_MASK | CCM_CCGR10_I2C2_CTRL_MASK); + + clrsetbits_le32(&anadig->pll2_ctrl, ANADIG_PLL2_CTRL_POWERDOWN, + ANADIG_PLL2_CTRL_ENABLE | ANADIG_PLL2_CTRL_DIV_SELECT); + clrsetbits_le32(&anadig->pll1_ctrl, ANADIG_PLL1_CTRL_POWERDOWN, + ANADIG_PLL1_CTRL_ENABLE | ANADIG_PLL1_CTRL_DIV_SELECT); + + clrsetbits_le32(&ccm->ccr, CCM_CCR_OSCNT_MASK, + CCM_CCR_FIRC_EN | CCM_CCR_OSCNT(5)); + clrsetbits_le32(&ccm->ccsr, CCM_REG_CTRL_MASK, + CCM_CCSR_PLL1_PFD_CLK_SEL(3) | CCM_CCSR_PLL2_PFD4_EN | + CCM_CCSR_PLL2_PFD3_EN | CCM_CCSR_PLL2_PFD2_EN | + CCM_CCSR_PLL2_PFD1_EN | CCM_CCSR_PLL1_PFD4_EN | + CCM_CCSR_PLL1_PFD3_EN | CCM_CCSR_PLL1_PFD2_EN | + CCM_CCSR_PLL1_PFD1_EN | CCM_CCSR_DDRC_CLK_SEL(1) | + CCM_CCSR_FAST_CLK_SEL(1) | CCM_CCSR_SYS_CLK_SEL(4)); + clrsetbits_le32(&ccm->cacrr, CCM_REG_CTRL_MASK, + CCM_CACRR_IPG_CLK_DIV(1) | CCM_CACRR_BUS_CLK_DIV(2) | + CCM_CACRR_ARM_CLK_DIV(0)); + clrsetbits_le32(&ccm->cscmr1, CCM_REG_CTRL_MASK, + CCM_CSCMR1_ESDHC1_CLK_SEL(3) | + CCM_CSCMR1_QSPI0_CLK_SEL(3) | + CCM_CSCMR1_NFC_CLK_SEL(0)); + clrsetbits_le32(&ccm->cscdr1, CCM_REG_CTRL_MASK, + CCM_CSCDR1_RMII_CLK_EN); + clrsetbits_le32(&ccm->cscdr2, CCM_REG_CTRL_MASK, + CCM_CSCDR2_ESDHC1_EN | CCM_CSCDR2_ESDHC1_CLK_DIV(0) | + CCM_CSCDR2_NFC_EN); + clrsetbits_le32(&ccm->cscdr3, CCM_REG_CTRL_MASK, + CCM_CSCDR3_QSPI0_EN | CCM_CSCDR3_QSPI0_DIV(1) | + CCM_CSCDR3_QSPI0_X2_DIV(1) | + CCM_CSCDR3_QSPI0_X4_DIV(3) | + CCM_CSCDR3_NFC_PRE_DIV(5)); + clrsetbits_le32(&ccm->cscmr2, CCM_REG_CTRL_MASK, + CCM_CSCMR2_RMII_CLK_SEL(0)); +} + +static void mscm_init(void) +{ + struct mscm_ir *mscmir = (struct mscm_ir *)MSCM_IR_BASE_ADDR; + int i; + + for (i = 0; i < MSCM_IRSPRC_NUM; i++) + writew(MSCM_IRSPRC_CP0_EN, &mscmir->irsprc[i]); +} + +int board_phy_config(struct phy_device *phydev) +{ + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +int board_early_init_f(void) +{ + clock_init(); + mscm_init(); + setup_iomux_uart(); + setup_iomux_enet(); + setup_iomux_i2c(); + setup_iomux_qspi(); + setup_iomux_nfc(); + + return 0; +} + +int board_init(void) +{ + struct scsc_reg *scsc = (struct scsc_reg *)SCSC_BASE_ADDR; + + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + /* + * Enable external 32K Oscillator + * + * The internal clock experiences significant drift + * so we must use the external oscillator in order + * to maintain correct time in the hwclock + */ + setbits_le32(&scsc->sosc_ctr, SCSC_SOSC_CTR_SOSC_EN); + + return 0; +} + +int checkboard(void) +{ + puts("Board: PCM-052\n"); + + return 0; +} diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig new file mode 100644 index 0000000..e8dc402 --- /dev/null +++ b/configs/pcm052_defconfig @@ -0,0 +1,6 @@ +CONFIG_ARM=y +CONFIG_TARGET_PCM052=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg,ENV_IS_IN_NAND" +CONFIG_NAND_VF610_NFC=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_SYS_NAND_VF610_NFC_45_ECC_BYTES=y diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h new file mode 100644 index 0000000..4cfce05 --- /dev/null +++ b/include/configs/pcm052.h @@ -0,0 +1,234 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * Configuration settings for the phytec PCM-052 SoM. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/imx-regs.h> +#include <config_cmd_default.h> + +#define CONFIG_VF610 + +#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_SYS_THUMB_BUILD + +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* Enable passing of ATAGs */ +#define CONFIG_CMDLINE_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) + +#define CONFIG_BOARD_EARLY_INIT_F + +#define CONFIG_FSL_LPUART +#define LPUART_BASE UART1_BASE + +/* Allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_UART_PORT (1) +#define CONFIG_BAUDRATE 115200 + +#undef CONFIG_CMD_IMLS + +/* NAND support */ +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NAND_TRIMFFS +#define CONFIG_SYS_NAND_ONFI_DETECTION + +#ifdef CONFIG_CMD_NAND +#define CONFIG_USE_ARCH_MEMCPY +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE NFC_BASE_ADDR + +#define CONFIG_JFFS2_NAND + +/* UBI */ +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#define CONFIG_RBTREE +#define CONFIG_LZO + +/* Dynamic MTD partition support */ +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#define MTDIDS_DEFAULT "nand0=NAND,nor0=qspi0-a,nor1=qspi0-b" +#define MTDPARTS_DEFAULT "mtdparts=NAND:256k(spare)"\ + ",384k(bootloader)"\ + ",128k(env1)"\ + ",128k(env2)"\ + ",3840k(kernel)"\ + ",-(rootfs)"\ + ",qspi0-a:-(jffs2),qspio0-b:-(jffs2)" +#endif + +#define CONFIG_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_ESDHC_NUM 1 + +/*#define CONFIG_ESDHC_DETECT_USE_EXTERN_IRQ1*/ +#define CONFIG_SYS_FSL_ERRATUM_ESDHC135 +#define CONFIG_SYS_FSL_ERRATUM_ESDHC111 +#define CONFIG_SYS_FSL_ERRATUM_ESDHC_A001 + +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_FEC_MXC_PHYADDR 0 +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL + +/* QSPI Configs*/ +#define CONFIG_FSL_QSPI + +#ifdef CONFIG_FSL_QSPI +#define CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO +#define FSL_QSPI_FLASH_SIZE (1 << 24) +#define FSL_QSPI_FLASH_NUM 2 +#define CONFIG_SYS_FSL_QSPI_LE +#endif + +/* I2C Configs */ +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC_I2C3 +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_SPD_BUS_NUM 0 + +/* RTC (actually an RV-4162 but M41T62-compatible) */ +#define CONFIG_CMD_DATE +#define CONFIG_RTC_M41T62 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 +#define CONFIG_SYS_RTC_BUS_NUM 2 + +/* EEPROM (24FC256) */ +#define CONFIG_CMD_EEPROM +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_I2C_EEPROM_BUS 2 + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_LOADADDR 0x82000000 + +/* We boot from the gfxRAM area of the OCRAM. */ +#define CONFIG_SYS_TEXT_BASE 0x3f408000 +#define CONFIG_BOARD_SIZE_LIMIT 524288 + +#define CONFIG_BOOTCOMMAND "run bootcmd_sd" +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootfile=uImage\0" \ + "bootargs_base=setenv bootargs rw mem=256M " \ + "console=ttymxc1,115200n8\0" \ + "bootargs_sd=setenv bootargs ${bootargs} " \ + "root=/dev/mmcblk0p2 rootwait\0" \ + "bootargs_net=setenv bootargs ${bootargs} root=/dev/nfs ip=dhcp " \ + "nfsroot=${serverip}:${nfs_root},v3,tcp\0" \ + "bootargs_nand=setenv bootargs ${bootargs} " \ + "root=/dev/mtdblock2 rootfstype=jffs2\0" \ + "bootargs_mtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ + "bootcmd_sd=run bootargs_base bootargs_sd bootargs_mtd; mmc rescan; " \ + "fatload mmc 0:1 ${loadaddr} ${bootfile}; bootm ${loadaddr}\0" \ + "bootcmd_net=run bootargs_base bootargs_net bootargs_mtd; " \ + "tftpboot ${loadaddr} ${tftploc}${bootfile}; bootm\0" \ + "bootcmd_nand='run bootargs_base bootargs_nand bootargs_mtd; " \ + "nand read ${loadaddr} 0x000E0000 0x3C0000; " \ + "bootm ${loadaddr}\0" \ + "tftploc=/path/to/tftp/directory/\0" \ + "nfs_root=/path/to/nfs/root\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "update_kernel_from_sd=mw.b $(loadaddr) 0xff 0x3C0000; " \ + "mmc rescan; fatload mmc 0:2 ${loadaddr} ${bootfile}; " \ + "nand erase 0xE0000 0x3C0000; " \ + "nand write.i ${loadaddr} 0xE0000 0x3C0000\0" \ + "update_rootfs_from_tftp=mw.b ${loadaddr} 0xff 0x8F20000; " \ + "tftp ${loadaddr} ${tftp}${filesys}; " \ + "nand erase 0x4A0000 0x8F20000; " \ + "nand write.i ${loadaddr} 0x4A0000 0x8F20000\0" \ + "filesys=rootfs.jffs2\0" + +/* miscellaneous commands */ +#define CONFIG_CMD_ELF + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80010000 +#define CONFIG_SYS_MEMTEST_END 0x87C00000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* + * Stack sizes + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 * 1024) /* regular stack */ + +/* Physical memory map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM (0x80000000) +#define PHYS_SDRAM_SIZE (256 * 1024 * 1024) + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#ifdef CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_SIZE (8 * 1024) + +#define CONFIG_ENV_OFFSET (12 * 64 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#endif + +#ifdef CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SECT_SIZE (128 * 1024) +#define CONFIG_ENV_SIZE (8 * 1024) +#define CONFIG_ENV_OFFSET 0x80000 +#define CONFIG_ENV_SIZE_REDUND (8 * 1024) +#define CONFIG_ENV_OFFSET_REDUND 0xA0000 +#endif + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ + +#endif
- uint32_t padding[1]; /* end up on an 8-byte boundary */
} dcd_v2_t;
typedef struct {
Best regards, Stefano Babic
Hi Stefano,
} dcd_v2_t;
typedef struct {
Sorry, just stumbled over this message now.
We discussed exactly this issue already more than a year ago, see: http://lists.denx.de/pipermail/u-boot/2014-April/177580.html
Back then you asked whether I asked Freescale about it. Earlier this year I tried to get hold of that issue and asked Freescale on Community, see: https://community.freescale.com/thread/355161
However, no official confirmation or explanation so far.
I think my patch back then solves the issue nicer. The struct dcd_v2_t is not the reason the whole header is not aligned by 8-byte, it is a problem of the boot_data_t header which is 12 bytes long. So inserting the padding just after struct boot_data_t (or inside of struct boot_data_t) seems to be more appropriate.
-- Stefan
Hi Stefan,
I admit that I have forgotten it....thanks to revive it !
I see. Albert, can you test on your board if Stefan's patch solves your issue, too ? I could then revert this one and apply Stefan's.
It remains doubious how the ROMs on Freescale are interpretating the header, but we can only test it.
Hello Stefano,
I can test it, but I'm sure that boot data does not need size alignment since in my case there is no such alignment and Vybrid boots. To me this means aligning boot_data_t size would introduce a constraint that is not really there.
If Stefan would test my patch as well, I reckon he would find it to work as well as his.
So we have two patches which fix Vybrid booting:
- one which aligns the boot_data_t /size/ but keeps its /offset/ unaligned;
- one which aligns the the boot_data_t /offset/ but keeps its /size/ unaligned.
Seems to me that the conclusion is that the actual alignment of boot_data_t does not matter and that only the alignment of the whole imx_header_v2_t size (and, consequently, offset) matters.
How about just adding an attribute((align(8))) to imx_header_v2_t?
See my other answer. We could prove it by disassembling the ROM code. Any volunteer? :)
Amicalement,
Hi Albert,
On 2015-07-15 09:54, Albert ARIBAUD wrote:
Hello Stefano,
I quote here from both emails, since its about the same topic.
After reading the U-Boot and Freescale discussions, IIUC you have come to the conclusion that the missing 4 bytes were in boot_data_t because it was the only structure in the header which was not 8-bytes-aligned.
However, the available documentation does not specify this constraint, and from a more experimental vewpoint, my patch adds 4 bytes at the end of the overall header, thus leaving boot data at 12 bytes (therefore leaving the dcd_table not 8-byte-aligned) and yet Vybrid can boot.
Yes, I agree on that. Also the boot data seems not to have the 8-byte alignment requirement (see the graphics I posted on the Freescale community article).
To me, this proves that the size alignment problem is not with boot_data_t but with the overall header.
I agree. Still, boot_data_t is the "offender", hence I would prefer that solution over your solution.
I don't get this classification. The complete header struct shows that dcd_v2_t is _after_ boot_data_t.
typedef struct { flash_header_v2_t fhdr; boot_data_t boot_data; dcd_v2_t dcd_table; } imx_header_v2_t;
Your patch changes the size of dcd_v2_t, hence compensating the "unaligned" size of boot_data_t.
As far as I see we have these two patches which fix Vybrid booting:
- one which changes the boot_data_t /size/ which keeps the offset of dcd_v2_t and the image aligned.
- one which changes the dcd_v2_t /size/ which compensates the unaligned size of boot_data_t and keeps the image aligned.
Hm this sounds tempting, but it does not seem to work here. I think because it only aligns the beginning of imx_header_v2_t in to 8-byte, however it does not align the size of the whole struct to 8 bytes, I guess? Hence the header size is still "unaligned".
Hehe, not me :-)
-- Stefan
Hello Stefan (and sorry for the duplicate),
On Wed, 15 Jul 2015 12:41:59 +0200, Stefan Agner stefan@agner.ch wrote:
Hi Albert,
Hello Stefano,
Compensating the unaligned size of the overall header for sure, since I'm adding a last field in the last structure. But precisely since I'm adding 4 bytes at the very end of the construct, we cannot tell whether I fixed the 'size' of the flash header, boot data or DCD.
What we can tell, though, is that Vybrid will boot as long as we increase the size of the overall header to an 8-byte boundary, and also that it will boot regardless to whether these 4 bytes are added between boot data and DCD or after DCD.
(note, btw, that in the Vybrid RM, the IVT itself, and the DCD, contain their own size explicitly in their tag-length-version headers, but the boot data does not contain its own size, nor is it contained elsewhere. What we call 'the size of the boot data' is 'the difference between the boot data and dcd addresses', but that's a definition for convenience.)
Correct -- my fault, this aligns the address, not size, and there is no attribute that will control size alignment.
So we really need to add manual padding.
And if we want to not introduce any artificial constaints, I suggest we define the padding as a separate field in the overall structure, i.e.:
typedef struct { flash_header_v2_t fhdr; boot_data_t boot_data; dcd_v2_t dcd_table; uint32_t padding; /* make size an 8-byte multiple */ } imx_header_v2_t;
I think this is the 'least inexact' solution: it does not enforce any address or size alignment constraint that is not defined in the RM, and it does show that the constraint is not on the boot data or DCD but on the header as a whole.
Functionally, it is identical to what I did, so I'm pretty sure it works. :)
Hehe, not me :-)
-- Stefan
Amicalement,
Hi Albert,
Hello Stefano,
Good point, agreed.
Actually I just discovered that "aligned" also changes the size (make sure using the correct syntax "__attribute__((aligned(8)))").
However, imximage.c seems to do some calculations using sizeof(struct imx_header) and sizeof(imx_header_v2_t) which lead to this error message: ./tools/mkimage: header error
Adding __attribute__((aligned(8))) to struct imx_header seems not to alleviate the problem... Any idea?
That change would also sound good to me.
Agreed.
-- Stefan
Hello Stefan,
Does it? Then I too was under the same misconception that it did not.
Agreed.
Ok, so let me look into the __attribute__((aligned(8))) issue. If that can be solved, I would give it my preference; if it cannot, then I will settle for manually padding the end of imx_header_v2_t.
-- Stefan
Amicalement,
Hello Stefan,
On Tue, 14 Jul 2015 12:29:52 +0200, Stefan Agner stefan@agner.ch wrote:
Hi Stefano,
} dcd_v2_t;
typedef struct {
Aside:
My own hypothesis on the reason for the non-written 8-byte-alignment requirement is that the ROM code initially loads the NAND sector containing the header at some fixed address then calls some function to copy the header just below the image destination address, and that function is 'optimized' to use 8-byte chunks (probably because it only had two free regs for ldm/stm) and thus assumes an 8 bytes header size, and nobody cared to document (or possibly even realized the existence of) that assumption.
-- Stefan
Amicalement,
Hi Albert,
- VF610_PAD_PTA22__I2C2_SCL = IOMUX_PAD(0x0030, 0x0030, 6, 0x034c, 0, VF610_I2C_PAD_CTRL),
- VF610_PAD_PTA23__I2C2_SDA = IOMUX_PAD(0x0034, 0x0034, 6, 0x0350, 0, VF610_I2C_PAD_CTRL), VF610_PAD_PTD31__NF_IO15 = IOMUX_PAD(0x00fc, 0x00fc, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), VF610_PAD_PTD31__GPIO_63 = IOMUX_PAD(0x00fc, 0x00fc, 0, __NA_, 0, VF610_GPIO_PAD_CTRL), VF610_PAD_PTD30__NF_IO14 = IOMUX_PAD(0x0100, 0x0100, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL),
- VF610_PAD_PTD20__NF_IO4 = IOMUX_PAD(0x0128, 0x0128, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), VF610_PAD_PTD19__NF_IO3 = IOMUX_PAD(0x012c, 0x012c, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL),
- VF610_PAD_PTD18__NF_IO2 = IOMUX_PAD(0x0130, 0x0130, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), VF610_PAD_PTD17__NF_IO1 = IOMUX_PAD(0x0134, 0x0134, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), VF610_PAD_PTD16__NF_IO0 = IOMUX_PAD(0x0138, 0x0138, 2, __NA_, 0, VF610_NFC_IO_PAD_CTRL), VF610_PAD_PTB24__NF_WE_B = IOMUX_PAD(0x0178, 0x0178, 5, __NA_, 0, VF610_NFC_CN_PAD_CTRL),
{ 0, I2C1_BASE_ADDR, I2C_QUIRK_FLAG }, { 1, I2C2_BASE_ADDR, I2C_QUIRK_FLAG }, { 2, I2C3_BASE_ADDR, I2C_QUIRK_FLAG },defined(CONFIG_VF610)
This is independent from the rest of patchset - I can merge it.
Hi Albert,
On 19.06.2015 14:18, Albert ARIBAUD (3ADEV) wrote:
The VF610 DDRMC driver code contains settings which are board-specific. Move these out to boards so that new boards can define their own without having to modify the driver.
arch/arm/imx-common/ddrmc-vf610.c | 239 ++++++-------------------- arch/arm/include/asm/arch-vf610/ddrmc-vf610.h | 60 +------ board/freescale/vf610twr/vf610twr.c | 181 +++++++++++++------ board/toradex/colibri_vf/colibri_vf.c | 169 +++++++++++++----- 4 files changed, 312 insertions(+), 337 deletions(-)
So this goes basically back to setting all DDR registers directly from boards? What we tried to do here is to factor out the memory chip specific data (JEDEC). The idea behind this is it would make it simpler to add new RAM timings if a new RAM vendor is used on a different board revision... With your changes it will be unnecessarily hard to add just a new RAM timing for a new board revision...
-- Stefan
diff --git a/arch/arm/imx-common/ddrmc-vf610.c b/arch/arm/imx-common/ddrmc-vf610.c index e462631..44b9a0f 100644 --- a/arch/arm/imx-common/ddrmc-vf610.c +++ b/arch/arm/imx-common/ddrmc-vf610.c @@ -12,9 +12,9 @@ #include <asm/arch/iomux-vf610.h> #include <asm/arch/ddrmc-vf610.h>
-void ddrmc_setup_iomux(void) +void ddrmc_setup_iomux(const iomux_v3_cfg_t *pads, int pads_count) {
- static const iomux_v3_cfg_t ddr_pads[] = {
- static const iomux_v3_cfg_t default_pads[] = { VF610_PAD_DDR_A15__DDR_A_15, VF610_PAD_DDR_A14__DDR_A_14, VF610_PAD_DDR_A13__DDR_A_13,
@@ -65,212 +65,77 @@ void ddrmc_setup_iomux(void) VF610_PAD_DDR_RESETB, };
- imx_iomux_v3_setup_multiple_pads(ddr_pads, ARRAY_SIZE(ddr_pads));
- if ((pads == NULL) || (pads_count == 0)) {
pads = default_pads;
pads_count = ARRAY_SIZE(default_pads);
-void ddrmc_phy_init(void) -{
- struct ddrmr_regs *ddrmr = (struct ddrmr_regs *)DDR_BASE_ADDR;
- imx_iomux_v3_setup_multiple_pads(pads, pads_count);
- writel(DDRMC_PHY_DQ_TIMING, &ddrmr->phy[0]);
- writel(DDRMC_PHY_DQ_TIMING, &ddrmr->phy[16]);
- writel(DDRMC_PHY_DQ_TIMING, &ddrmr->phy[32]);
+static struct ddrmc_reg_setting default_phy_settings[] = {
- { DDRMC_PHY_DQ_TIMING, 0 },
- { DDRMC_PHY_DQ_TIMING, 16 },
- { DDRMC_PHY_DQ_TIMING, 32 },
- writel(DDRMC_PHY_DQS_TIMING, &ddrmr->phy[1]);
- writel(DDRMC_PHY_DQS_TIMING, &ddrmr->phy[17]);
- { DDRMC_PHY_DQS_TIMING, 1 },
- { DDRMC_PHY_DQS_TIMING, 17 },
- writel(DDRMC_PHY_CTRL, &ddrmr->phy[2]);
- writel(DDRMC_PHY_CTRL, &ddrmr->phy[18]);
- writel(DDRMC_PHY_CTRL, &ddrmr->phy[34]);
- { DDRMC_PHY_CTRL, 2 },
- { DDRMC_PHY_CTRL, 18 },
- { DDRMC_PHY_CTRL, 34 },
- writel(DDRMC_PHY_MASTER_CTRL, &ddrmr->phy[3]);
- writel(DDRMC_PHY_MASTER_CTRL, &ddrmr->phy[19]);
- writel(DDRMC_PHY_MASTER_CTRL, &ddrmr->phy[35]);
- { DDRMC_PHY_MASTER_CTRL, 3 },
- { DDRMC_PHY_MASTER_CTRL, 19 },
- { DDRMC_PHY_MASTER_CTRL, 35 },
- writel(DDRMC_PHY_SLAVE_CTRL, &ddrmr->phy[4]);
- writel(DDRMC_PHY_SLAVE_CTRL, &ddrmr->phy[20]);
- writel(DDRMC_PHY_SLAVE_CTRL, &ddrmr->phy[36]);
{ DDRMC_PHY_SLAVE_CTRL, 4 },
{ DDRMC_PHY_SLAVE_CTRL, 20 },
{ DDRMC_PHY_SLAVE_CTRL, 36 },
/* LPDDR2 only parameter */
- writel(DDRMC_PHY_OFF, &ddrmr->phy[49]);
- { DDRMC_PHY_OFF, 49 },
- writel(DDRMC_PHY50_DDR3_MODE |
DDRMC_PHY50_EN_SW_HALF_CYCLE, &ddrmr->phy[50]);
/* Processor Pad ODT settings */
- writel(DDRMC_PHY_PROC_PAD_ODT, &ddrmr->phy[52]);
- { DDRMC_PHY_PROC_PAD_ODT, 52 },
-static void ddrmc_ctrl_lvl_init(struct ddrmc_lvl_info *lvl) -{
- u32 cr102 = 0, cr105 = 0, cr106 = 0, cr110 = 0;
- /* end marker */
- { 0, -1 }
- if (lvl->wrlvl_reg_en) {
writel(DDRMC_CR97_WRLVL_EN, &ddrmr->cr[97]);
writel(DDRMC_CR98_WRLVL_DL_0(lvl->wrlvl_dl_0), &ddrmr->cr[98]);
writel(DDRMC_CR99_WRLVL_DL_1(lvl->wrlvl_dl_1), &ddrmr->cr[99]);
- if (lvl->rdlvl_reg_en) {
cr102 |= DDRMC_CR102_RDLVL_REG_EN;
cr105 |= DDRMC_CR105_RDLVL_DL_0(lvl->rdlvl_dl_0);
cr110 |= DDRMC_CR110_RDLVL_DL_1(lvl->rdlvl_dl_1);
- if (lvl->rdlvl_gt_reg_en) {
cr102 |= DDRMC_CR102_RDLVL_GT_REGEN;
cr106 |= DDRMC_CR106_RDLVL_GTDL_0(lvl->rdlvl_gt_dl_0);
cr110 |= DDRMC_CR110_RDLVL_GTDL_1(lvl->rdlvl_gt_dl_1);
- writel(cr102, &ddrmr->cr[102]);
- writel(cr105, &ddrmr->cr[105]);
- writel(cr106, &ddrmr->cr[106]);
- writel(cr110, &ddrmr->cr[110]);
-void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings,
struct ddrmc_lvl_info *lvl,
int col_diff, int row_diff)
+void ddrmc_ctrl_init_ddr3(struct ddrmc_reg_setting const *cr_settings,
- struct ddrmc_reg_setting const *phy_settings)
{ struct ddrmr_regs *ddrmr = (struct ddrmr_regs *)DDR_BASE_ADDR;
struct ddrmc_reg_setting const *cr_setting = cr_settings;
struct ddrmc_reg_setting const *phy_setting = phy_settings;
/* configure controller for DDR3 and start init sequence */ writel(DDRMC_CR00_DRAM_CLASS_DDR3, &ddrmr->cr[0]);
writel(DDRMC_CR02_DRAM_TINIT(timings->tinit), &ddrmr->cr[2]);
writel(DDRMC_CR10_TRST_PWRON(timings->trst_pwron), &ddrmr->cr[10]);
writel(DDRMC_CR11_CKE_INACTIVE(timings->cke_inactive), &ddrmr->cr[11]);
writel(DDRMC_CR12_WRLAT(timings->wrlat) |
DDRMC_CR12_CASLAT_LIN(timings->caslat_lin), &ddrmr->cr[12]);
writel(DDRMC_CR13_TRC(timings->trc) | DDRMC_CR13_TRRD(timings->trrd) |
DDRMC_CR13_TCCD(timings->tccd), &ddrmr->cr[13]);
writel(DDRMC_CR14_TFAW(timings->tfaw) | DDRMC_CR14_TRP(timings->trp) |
DDRMC_CR14_TWTR(timings->twtr) |
DDRMC_CR14_TRAS_MIN(timings->tras_min), &ddrmr->cr[14]);
writel(DDRMC_CR16_TMRD(timings->tmrd) |
DDRMC_CR16_TRTP(timings->trtp), &ddrmr->cr[16]);
writel(DDRMC_CR17_TRAS_MAX(timings->tras_max) |
DDRMC_CR17_TMOD(timings->tmod), &ddrmr->cr[17]);
writel(DDRMC_CR18_TCKESR(timings->tckesr) |
DDRMC_CR18_TCKE(timings->tcke), &ddrmr->cr[18]);
writel(DDRMC_CR20_AP_EN, &ddrmr->cr[20]);
writel(DDRMC_CR21_TRCD_INT(timings->trcd_int) |
DDRMC_CR21_CCMAP_EN, &ddrmr->cr[21]);
writel(DDRMC_CR22_TDAL(timings->tdal), &ddrmr->cr[22]);
writel(DDRMC_CR23_BSTLEN(3) |
DDRMC_CR23_TDLL(timings->tdll), &ddrmr->cr[23]);
writel(DDRMC_CR24_TRP_AB(timings->trp_ab), &ddrmr->cr[24]);
writel(DDRMC_CR25_TREF_EN, &ddrmr->cr[25]);
writel(DDRMC_CR26_TREF(timings->tref) |
DDRMC_CR26_TRFC(timings->trfc), &ddrmr->cr[26]);
writel(DDRMC_CR28_TREF_INT(0), &ddrmr->cr[28]);
writel(DDRMC_CR29_TPDEX(timings->tpdex), &ddrmr->cr[29]);
writel(DDRMC_CR30_TXPDLL(timings->txpdll), &ddrmr->cr[30]);
writel(DDRMC_CR31_TXSNR(timings->txsnr) |
DDRMC_CR31_TXSR(timings->txsr), &ddrmr->cr[31]);
writel(DDRMC_CR33_EN_QK_SREF, &ddrmr->cr[33]);
writel(DDRMC_CR34_CKSRX(timings->cksrx) |
DDRMC_CR34_CKSRE(timings->cksre), &ddrmr->cr[34]);
writel(DDRMC_CR38_FREQ_CHG_EN(0), &ddrmr->cr[38]);
writel(DDRMC_CR39_PHY_INI_COM(1024) | DDRMC_CR39_PHY_INI_STA(16) |
DDRMC_CR39_FRQ_CH_DLLOFF(2), &ddrmr->cr[39]);
writel(DDRMC_CR41_PHY_INI_STRT_INI_DIS, &ddrmr->cr[41]);
writel(DDRMC_CR48_MR1_DA_0(70) |
DDRMC_CR48_MR0_DA_0(1056), &ddrmr->cr[48]);
writel(DDRMC_CR66_ZQCL(timings->zqcl) |
DDRMC_CR66_ZQINIT(timings->zqinit), &ddrmr->cr[66]);
writel(DDRMC_CR67_ZQCS(timings->zqcs), &ddrmr->cr[67]);
writel(DDRMC_CR69_ZQ_ON_SREF_EX(2), &ddrmr->cr[69]);
writel(DDRMC_CR70_REF_PER_ZQ(timings->ref_per_zq), &ddrmr->cr[70]);
writel(DDRMC_CR72_ZQCS_ROTATE(0), &ddrmr->cr[72]);
writel(DDRMC_CR73_APREBIT(timings->aprebit) |
DDRMC_CR73_COL_DIFF(col_diff) |
DDRMC_CR73_ROW_DIFF(row_diff), &ddrmr->cr[73]);
writel(DDRMC_CR74_BANKSPLT_EN | DDRMC_CR74_ADDR_CMP_EN |
DDRMC_CR74_CMD_AGE_CNT(64) | DDRMC_CR74_AGE_CNT(64),
&ddrmr->cr[74]);
writel(DDRMC_CR75_RW_PG_EN | DDRMC_CR75_RW_EN | DDRMC_CR75_PRI_EN |
DDRMC_CR75_PLEN, &ddrmr->cr[75]);
writel(DDRMC_CR76_NQENT_ACTDIS(3) | DDRMC_CR76_D_RW_G_BKCN(3) |
DDRMC_CR76_W2R_SPLT_EN, &ddrmr->cr[76]);
writel(DDRMC_CR77_CS_MAP | DDRMC_CR77_DI_RD_INTLEAVE |
DDRMC_CR77_SWAP_EN, &ddrmr->cr[77]);
writel(DDRMC_CR78_Q_FULLNESS(7) |
DDRMC_CR78_BUR_ON_FLY_BIT(12), &ddrmr->cr[78]);
writel(DDRMC_CR79_CTLUPD_AREF(0), &ddrmr->cr[79]);
/* execute CR sequence (MUST be supplied) */
if (cr_setting)
while (cr_setting->reg_num >= 0) {
writel(cr_setting->setting,
&ddrmr->cr[cr_setting->reg_num]);
cr_setting++;
/* execute PHY sequence (SHOULD be supplied but can be default) */
if (phy_setting == NULL)
phy_setting = default_phy_settings;
while (phy_setting->reg_num >= 0) {
writel(phy_setting->setting,
&ddrmr->phy[phy_setting->reg_num]);
phy_setting++;
/* final config: disable DDR interrupts and finish init squence */ writel(DDRMC_CR82_INT_MASK, &ddrmr->cr[82]);
writel(DDRMC_CR87_ODT_WR_MAPCS0, &ddrmr->cr[87]);
writel(DDRMC_CR88_TODTL_CMD(4), &ddrmr->cr[88]);
writel(DDRMC_CR89_AODT_RWSMCS(2), &ddrmr->cr[89]);
writel(DDRMC_CR91_R2W_SMCSDL(2), &ddrmr->cr[91]);
writel(DDRMC_CR96_WLMRD(timings->wlmrd) |
DDRMC_CR96_WLDQSEN(timings->wldqsen), &ddrmr->cr[96]);
if (lvl != NULL)
ddrmc_ctrl_lvl_init(lvl);
writel(DDRMC_CR117_AXI0_W_PRI(0) |
DDRMC_CR117_AXI0_R_PRI(0), &ddrmr->cr[117]);
writel(DDRMC_CR118_AXI1_W_PRI(1) |
DDRMC_CR118_AXI1_R_PRI(1), &ddrmr->cr[118]);
writel(DDRMC_CR120_AXI0_PRI1_RPRI(2) |
DDRMC_CR120_AXI0_PRI0_RPRI(2), &ddrmr->cr[120]);
writel(DDRMC_CR121_AXI0_PRI3_RPRI(2) |
DDRMC_CR121_AXI0_PRI2_RPRI(2), &ddrmr->cr[121]);
writel(DDRMC_CR122_AXI1_PRI1_RPRI(1) | DDRMC_CR122_AXI1_PRI0_RPRI(1) |
DDRMC_CR122_AXI0_PRIRLX(100), &ddrmr->cr[122]);
writel(DDRMC_CR123_AXI1_P_ODR_EN | DDRMC_CR123_AXI1_PRI3_RPRI(1) |
DDRMC_CR123_AXI1_PRI2_RPRI(1), &ddrmr->cr[123]);
writel(DDRMC_CR124_AXI1_PRIRLX(100), &ddrmr->cr[124]);
writel(DDRMC_CR126_PHY_RDLAT(8), &ddrmr->cr[126]);
writel(DDRMC_CR132_WRLAT_ADJ(5) |
DDRMC_CR132_RDLAT_ADJ(6), &ddrmr->cr[132]);
writel(DDRMC_CR137_PHYCTL_DL(2), &ddrmr->cr[137]);
writel(DDRMC_CR138_PHY_WRLV_MXDL(256) |
DDRMC_CR138_PHYDRAM_CK_EN(1), &ddrmr->cr[138]);
writel(DDRMC_CR139_PHY_WRLV_RESPLAT(4) | DDRMC_CR139_PHY_WRLV_LOAD(7) |
DDRMC_CR139_PHY_WRLV_EN(3), &ddrmr->cr[139]);
writel(DDRMC_CR140_PHY_WRLV_WW(64), &ddrmr->cr[140]);
writel(DDRMC_CR143_RDLV_GAT_MXDL(1536) |
DDRMC_CR143_RDLV_MXDL(128), &ddrmr->cr[143]);
writel(DDRMC_CR144_PHY_RDLVL_RES(4) | DDRMC_CR144_PHY_RDLV_LOAD(7) |
DDRMC_CR144_PHY_RDLV_EN(3), &ddrmr->cr[144]);
writel(DDRMC_CR145_PHY_RDLV_RR(64), &ddrmr->cr[145]);
writel(DDRMC_CR146_PHY_RDLVL_RESP(64), &ddrmr->cr[146]);
writel(DDRMC_CR147_RDLV_RESP_MASK(983040), &ddrmr->cr[147]);
writel(DDRMC_CR148_RDLV_GATE_RESP_MASK(983040), &ddrmr->cr[148]);
writel(DDRMC_CR151_RDLV_GAT_DQ_ZERO_CNT(1) |
DDRMC_CR151_RDLVL_DQ_ZERO_CNT(1), &ddrmr->cr[151]);
writel(DDRMC_CR154_PAD_ZQ_EARLY_CMP_EN_TIMER(13) |
DDRMC_CR154_PAD_ZQ_HW_FOR(1), &ddrmr->cr[154]);
writel(DDRMC_CR155_PAD_ODT_BYTE1(2) |
DDRMC_CR155_PAD_ODT_BYTE0(2), &ddrmr->cr[155]);
writel(DDRMC_CR158_TWR(6), &ddrmr->cr[158]);
writel(DDRMC_CR161_ODT_EN(1) | DDRMC_CR161_TODTH_RD(2) |
DDRMC_CR161_TODTH_WR(2), &ddrmr->cr[161]);
ddrmc_phy_init();
writel(DDRMC_CR00_DRAM_CLASS_DDR3 | DDRMC_CR00_START, &ddrmr->cr[0]);
while (!(readl(&ddrmr->cr[80]) && 0x100))
diff --git a/arch/arm/include/asm/arch-vf610/ddrmc-vf610.h b/arch/arm/include/asm/arch-vf610/ddrmc-vf610.h index 6730cde..bc7f106 100644 --- a/arch/arm/include/asm/arch-vf610/ddrmc-vf610.h +++ b/arch/arm/include/asm/arch-vf610/ddrmc-vf610.h @@ -11,62 +11,14 @@ #ifndef __ASM_ARCH_VF610_DDRMC_H #define __ASM_ARCH_VF610_DDRMC_H
-struct ddrmc_lvl_info {
- u16 wrlvl_reg_en;
- u16 wrlvl_dl_0;
- u16 wrlvl_dl_1;
- u16 rdlvl_gt_reg_en;
- u16 rdlvl_gt_dl_0;
- u16 rdlvl_gt_dl_1;
- u16 rdlvl_reg_en;
- u16 rdlvl_dl_0;
- u16 rdlvl_dl_1;
+struct ddrmc_reg_setting {
- u32 setting;
- int reg_num; /* CR or PHY ; -1 for last entry */
-struct ddr3_jedec_timings {
- u8 tinit;
- u32 trst_pwron;
- u32 cke_inactive;
- u8 wrlat;
- u8 caslat_lin;
- u8 trc;
- u8 trrd;
- u8 tccd;
- u8 tfaw;
- u8 trp;
- u8 twtr;
- u8 tras_min;
- u8 tmrd;
- u8 trtp;
- u32 tras_max;
- u8 tmod;
- u8 tckesr;
- u8 tcke;
- u8 trcd_int;
- u8 tdal;
- u16 tdll;
- u8 trp_ab;
- u16 tref;
- u8 trfc;
- u8 tpdex;
- u8 txpdll;
- u8 txsnr;
- u16 txsr;
- u8 cksrx;
- u8 cksre;
- u16 zqcl;
- u16 zqinit;
- u8 zqcs;
- u8 ref_per_zq;
- u8 aprebit;
- u8 wlmrd;
- u8 wldqsen;
-void ddrmc_setup_iomux(void); +void ddrmc_setup_iomux(const iomux_v3_cfg_t *pads, int pads_count); void ddrmc_phy_init(void); -void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings,
int col_diff, int row_diff);
- struct ddrmc_reg_setting const *phy_settings);
#endif diff --git a/board/freescale/vf610twr/vf610twr.c b/board/freescale/vf610twr/vf610twr.c index 4160acd..aab20ad 100644 --- a/board/freescale/vf610twr/vf610twr.c +++ b/board/freescale/vf610twr/vf610twr.c @@ -28,63 +28,136 @@ DECLARE_GLOBAL_DATA_PTR; #define ENET_PAD_CTRL (PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_HIGH | \ PAD_CTL_DSE_50ohm | PAD_CTL_OBE_IBE_ENABLE)
+static struct ddrmc_reg_setting vf610twr_cr_settings[] = {
- { DDRMC_CR02_DRAM_TINIT(5), 2 },
- { DDRMC_CR10_TRST_PWRON(80000), 10 },
- { DDRMC_CR11_CKE_INACTIVE(200000), 11 },
- { DDRMC_CR12_WRLAT(5) | DDRMC_CR12_CASLAT_LIN(12), 12 },
- { DDRMC_CR13_TRC(21) | DDRMC_CR13_TRRD(4) | DDRMC_CR13_TCCD(4) |
DDRMC_CR13_TBST_INT_INTERVAL(0), 13 },
- { DDRMC_CR14_TFAW(20) | DDRMC_CR14_TRP(6) | DDRMC_CR14_TWTR(5) |
- { DDRMC_CR16_TMRD(4) | DDRMC_CR16_TRTP(4), 16 },
- { DDRMC_CR17_TRAS_MAX(28080) | DDRMC_CR17_TMOD(12), 17 },
- { DDRMC_CR18_TCKESR(4) | DDRMC_CR18_TCKE(3), 18 },
- { DDRMC_CR20_AP_EN, 20 },
- { DDRMC_CR21_TRCD_INT(6) | DDRMC_CR21_CCMAP_EN, 21 },
- { DDRMC_CR22_TDAL(12), 22 },
- { DDRMC_CR23_BSTLEN(3) |
- { DDRMC_CR24_TRP_AB(6), 24 },
- { DDRMC_CR25_TREF_EN, 25 },
- { DDRMC_CR26_TREF(3120) | DDRMC_CR26_TRFC(44), 26 },
- { DDRMC_CR28_TREF_INT(0), 28 },
- { DDRMC_CR29_TPDEX(3), 29 },
- { DDRMC_CR30_TXPDLL(10), 30 },
- { DDRMC_CR31_TXSNR(48) | DDRMC_CR31_TXSR(468), 31 },
- { DDRMC_CR33_EN_QK_SREF, 33 },
- { DDRMC_CR34_CKSRX(5) | DDRMC_CR34_CKSRE(5), 34 },
- { DDRMC_CR38_FREQ_CHG_EN(0), 38 },
- { DDRMC_CR39_PHY_INI_COM(1024) | DDRMC_CR39_PHY_INI_STA(16) |
- { DDRMC_CR41_PHY_INI_STRT_INI_DIS, 41 },
- { DDRMC_CR48_MR1_DA_0(70) |
- { DDRMC_CR66_ZQCL(256) | DDRMC_CR66_ZQINIT(512), 66 },
- { DDRMC_CR67_ZQCS(64), 67 },
- { DDRMC_CR69_ZQ_ON_SREF_EX(2), 69 },
- { DDRMC_CR70_REF_PER_ZQ(64), 70 },
- { DDRMC_CR72_ZQCS_ROTATE(0), 72 },
- { DDRMC_CR73_APREBIT(10) | DDRMC_CR73_COL_DIFF(1) |
DDRMC_CR73_ROW_DIFF(3), 73 },
- { DDRMC_CR74_BANKSPLT_EN | DDRMC_CR74_ADDR_CMP_EN |
DDRMC_CR74_AGE_CNT(64), 74 },
- { DDRMC_CR75_RW_PG_EN | DDRMC_CR75_RW_EN | DDRMC_CR75_PRI_EN |
- { DDRMC_CR76_NQENT_ACTDIS(3) | DDRMC_CR76_D_RW_G_BKCN(3) |
- { DDRMC_CR77_CS_MAP | DDRMC_CR77_DI_RD_INTLEAVE |
- { DDRMC_CR78_Q_FULLNESS(7) | DDRMC_CR78_BUR_ON_FLY_BIT(12), 78 },
- { DDRMC_CR79_CTLUPD_AREF(0), 79 },
- { DDRMC_CR87_ODT_WR_MAPCS0, 87 },
- { DDRMC_CR88_TODTL_CMD(4), 88 },
- { DDRMC_CR89_AODT_RWSMCS(2), 89 },
- { DDRMC_CR91_R2W_SMCSDL(2), 91 },
- { DDRMC_CR96_WLMRD(40) | DDRMC_CR96_WLDQSEN(25), 96 },
- /* levelling */
- { DDRMC_CR97_WRLVL_EN, 97 },
- { DDRMC_CR98_WRLVL_DL_0(0), 98 },
- { DDRMC_CR99_WRLVL_DL_1(0), 99 },
- { DDRMC_CR102_RDLVL_REG_EN | DDRMC_CR102_RDLVL_GT_REGEN, 102 },
- { DDRMC_CR105_RDLVL_DL_0(0), 105 },
- { DDRMC_CR106_RDLVL_GTDL_0(4), 106 },
- { DDRMC_CR110_RDLVL_DL_1(0) | DDRMC_CR110_RDLVL_GTDL_1(4), 110 },
- /* AXI */
- { DDRMC_CR117_AXI0_W_PRI(0) | DDRMC_CR117_AXI0_R_PRI(0), 117 },
- { DDRMC_CR118_AXI1_W_PRI(1) | DDRMC_CR118_AXI1_R_PRI(1), 118 },
- { DDRMC_CR120_AXI0_PRI1_RPRI(2) |
- { DDRMC_CR121_AXI0_PRI3_RPRI(2) |
- { DDRMC_CR122_AXI1_PRI1_RPRI(1) | DDRMC_CR122_AXI1_PRI0_RPRI(1) |
- { DDRMC_CR123_AXI1_P_ODR_EN | DDRMC_CR123_AXI1_PRI3_RPRI(1) |
- { DDRMC_CR124_AXI1_PRIRLX(100), 124 },
- { DDRMC_CR126_PHY_RDLAT(8), 126 },
- { DDRMC_CR132_WRLAT_ADJ(5) |
- { DDRMC_CR137_PHYCTL_DL(2), 137 },
- { DDRMC_CR138_PHY_WRLV_MXDL(256) |
DDRMC_CR138_PHYDRAM_CK_EN(1), 138 },
- { DDRMC_CR139_PHY_WRLV_RESPLAT(4) | DDRMC_CR139_PHY_WRLV_LOAD(7) |
- { DDRMC_CR140_PHY_WRLV_WW(64), 140 },
- { DDRMC_CR143_RDLV_GAT_MXDL(1536) |
DDRMC_CR143_RDLV_MXDL(128), 143 },
- { DDRMC_CR144_PHY_RDLVL_RES(4) | DDRMC_CR144_PHY_RDLV_LOAD(7) |
DDRMC_CR144_PHY_RDLV_DLL(3) |
DDRMC_CR144_PHY_RDLV_EN(3), 144 },
- { DDRMC_CR145_PHY_RDLV_RR(64), 145 },
- { DDRMC_CR146_PHY_RDLVL_RESP(64), 146 },
- { DDRMC_CR147_RDLV_RESP_MASK(983040), 147 },
- { DDRMC_CR148_RDLV_GATE_RESP_MASK(983040), 148 },
- { DDRMC_CR151_RDLV_GAT_DQ_ZERO_CNT(1) |
DDRMC_CR151_RDLVL_DQ_ZERO_CNT(1), 151 },
- { DDRMC_CR154_PAD_ZQ_EARLY_CMP_EN_TIMER(13) |
DDRMC_CR154_PAD_ZQ_HW_FOR(1), 154 },
- { DDRMC_CR155_PAD_ODT_BYTE1(1) | DDRMC_CR155_PAD_ODT_BYTE0(1), 155 },
- { DDRMC_CR158_TWR(6), 158 },
- { DDRMC_CR161_ODT_EN(1) | DDRMC_CR161_TODTH_RD(2) |
DDRMC_CR161_TODTH_WR(2), 161 },
- /* end marker */
- { 0, -1 }
int dram_init(void) {
- struct ddrmc_lvl_info lvl = {
.wrlvl_reg_en = 1,
.wrlvl_dl_0 = 0,
.wrlvl_dl_1 = 0,
.rdlvl_gt_reg_en = 1,
.rdlvl_gt_dl_0 = 4,
.rdlvl_gt_dl_1 = 4,
.rdlvl_reg_en = 1,
.rdlvl_dl_0 = 0,
.rdlvl_dl_1 = 0,
- static const struct ddr3_jedec_timings timings = {
.tinit = 5,
.trst_pwron = 80000,
.cke_inactive = 200000,
.wrlat = 5,
.caslat_lin = 12,
.trc = 21,
.trrd = 4,
.tccd = 4,
.tfaw = 20,
.trp = 6,
.twtr = 4,
.tras_min = 15,
.tmrd = 4,
.trtp = 4,
.tras_max = 28080,
.tmod = 12,
.tckesr = 4,
.tcke = 3,
.trcd_int = 6,
.tdal = 12,
.tdll = 512,
.trp_ab = 6,
.tref = 3120,
.trfc = 44,
.tpdex = 3,
.txpdll = 10,
.txsnr = 48,
.txsr = 468,
.cksrx = 5,
.cksre = 5,
.zqcl = 256,
.zqinit = 512,
.zqcs = 64,
.ref_per_zq = 64,
.aprebit = 10,
.wlmrd = 40,
.wldqsen = 25,
- ddrmc_setup_iomux();
- /* use driver default IOMUX settings */
- ddrmc_setup_iomux(NULL, 0);
- ddrmc_ctrl_init_ddr3(&timings, &lvl, 1, 3);
/* provide own CR setup but use default PHY setup */
ddrmc_ctrl_init_ddr3(vf610twr_cr_settings, NULL); gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE);
diff --git a/board/toradex/colibri_vf/colibri_vf.c b/board/toradex/colibri_vf/colibri_vf.c index 8618fd0..01b3106 100644 --- a/board/toradex/colibri_vf/colibri_vf.c +++ b/board/toradex/colibri_vf/colibri_vf.c @@ -39,51 +39,136 @@ static const iomux_v3_cfg_t usb_pads[] = { VF610_PAD_PTD4__GPIO_83, };
+static struct ddrmc_reg_setting colibri_vf_cr_settings[] = {
- /* levelling */
- /* AXI */
- /* end marker */
- { 0, -1 }
.tinit = 5,
.wrlat = 5,
.caslat_lin = 12,
.trc = 21,
.trrd = 4,
.tccd = 4,
.tfaw = 20,
.trp = 6,
.twtr = 4,
.tras_min = 15,
.tmrd = 4,
.trtp = 4,
.tras_max = 28080,
.tmod = 12,
.tckesr = 4,
.tcke = 3,
.trcd_int = 6,
.tdal = 12,
.tdll = 512,
.trp_ab = 6,
.tref = 3120,
.trfc = 64,
.tpdex = 3,
.txpdll = 10,
.txsnr = 48,
.txsr = 468,
.cksrx = 5,
.cksre = 5,
.zqcl = 256,
.zqinit = 512,
.zqcs = 64,
.ref_per_zq = 64,
.aprebit = 10,
.wlmrd = 40,
.wldqsen = 25,
- ddrmc_ctrl_init_ddr3(&timings, NULL, 1, 2);
ddrmc_ctrl_init_ddr3(&colibri_vf_cr_settings, NULL, 1, 2); gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE);
Bonjour Stefan,
Le Fri, 19 Jun 2015 17:13:12 +0200, Stefan Agner stefan.agner@toradex.com a écrit :
Hi Albert,
I could probably factor back out the JEDEC settings, but there are still differences in the lists of registers to write between the existing vf610twr/colibri_vf and the new pcm052, especially the PHY regs but elsewhere too, and there are some writes in the driver that the PCM052 does not have.
As I wanted to leave the existing boards strictly unaffected, and as I did not want to start sprinkling '#if defined(some-board)' over the driver code, I went for a fully board-controlled design so that no board could possibly be affected by any future change to the driver.
How about a mix? I could keep the JEDEC and lvl pointers in the DDR controller init call arguments and append "per-boards" CR and PHY arrays. The driver would do the JEDEC writes (thus keeping JEDEC DDR3 additions simple), the LVL writes if not NULL, then the "per-board" CR writes if not NULL, then the current common PHY writes, then the "per-board" PHY writes if not null.
This would keep common parts (JEDEC and minimal settings) in the driver while allowing board their own specific settings -- even overriding the driver settings, since the per-board writes would come last before CR000 is rewritten.
Would that be ok ?
-- Stefan
Cordialement, Albert ARIBAUD 3ADEV
Bonjour Stefan,
Hi Albert,
Would that be ok ?
-- Stefan
Hi Albert, Stefan,
This matches IMHO what we have already tried to do with most of Frescale's i.MXes, putting general code and setting in the arch/cpu/ (or in the imx_common for MX5 and MX6), but letting the board code to write the board specific part.
Some mix seems to me a goog compromise between flexibility and common code.
Would that be ok ?
Hi Albert, Hi Stefano,
On 10.07.2015 10:09, Stefano Babic wrote:
Hi Albert, Stefan,
As far as I understood Alberts proposition it would mean that we write some registers directly from board code right? I'm not sure if this works out for all registers, since some might have JEDEC and Board specific fields in one register...?
Looking throug some CR registers lead me to belive that most settings are exact the same or already covered by the JEDEC struct... The few remaning ones could be part of a renamed ddrmc_lvl_info struct (e.g. ddrmc_cr_info).
The same for the PHY settings (ddrmc_phy_info). This would lead to a common place where all registers gets written, while having the flexibility to use board specific data... No back and forth between the board file and the common code.
I did not an exact survey how much of the registers are actually different, but I feel that the difference is not that big that moving the whole initialization to the board files is worth the effort...
-- Stefan
Would that be ok ?
Hi Stefan,
Le Mon, 13 Jul 2015 21:01:56 +0200, Stefan Agner stefan.agner@toradex.com a écrit :
Hi Albert, Stefan,
Well, it would not be /from/ board code as boards would actually pass descriptions and the writing would occur in the driver within the general write sequence, but I see your point about some register values possibly needing to be constructed from both the jedec struct) /and/ some other source -- see below.
Also, we can hardly avoid that each board will require regiser writes which will be somewhat unique to it. The question is not whether we can avoid that, it is how we should specify that and where we should put that.
I do understand the benefit of passing JEDEC parameters rather that register values, because this allows "working in the problem domain", i.e. using JEDEC values straight from datasheets, and having thdriver to the "heavy lifting", i.e. converting this set of JEDEC values into a consistent set of interrelated register values.
I might understand it for PHY settings when you might know that several PHY registers need values consistent with one another (more below).
Generally, though, I don't think there is added values in turning register values into a struct rather than an (offset, value) pair list which is IMO more versatile.
Take the lvl struct for example: it embodies a 'leveling' abstraction which does not exist in the IP per se, and does not exist outside the IP as JEDEC parameters do; it' artificial. And while it does provide some consistency, it does not even hide all hardware implementation details, so you still need to go see the IP's register definition if you want to fill that struct (as opposed to only having to read the DDR3 datasheet to fill the JEDEC structure). And if you need to go read the register structure, working with (offset, value) pairs makes a simpler driver.
Last point: the driver is supposed to work with various incarnations of the IP, not all of which may have the same set of known, and unknown, registers. I stumbled uplon this problem with the current driver code: it writes some (non-JEDEC) CR registers which my board does not write as far as I can tell, and it does not do some writes my board does.
I could have gone through the driver's 'extra' writes and tested whether they could be done on my board without any ill effect. I could also hve gone through my board's extra writes and seen whether they could be removed without any any ill effect. In fact, I *had* to do some of each, because some of the driver's writes (in the lvl struct notably, but elsewhere too) caused issues.
The problem was, I could not test what effect my changes would have on the other boards that use the driver -- it's not even a question of time: I just don't have these other boards which happen to use the driver that I'm modifying (and I expect that's a pretty common case).
Or I could make my changes so that existing boards using the driver kept writing the registers as they do in the current code and that my board write the registers as it needs to, and keep only the common part in the driver.
This way, I could ensure that existing code would retain the exact behavior it currently expects from the IP it runs on while in the same time getting the exact behavior I expected on my board.
Here too, there is a problem: current code does not write all the registers my code wants written. If I added writes to the driver unconditionally, I would risk breaking existing boards by adding writes to them that they never intended to do. If I added it conditionally, I would add artificial complexity to the driver, basically injecting board-specifics in it. That's why I initially went the "driver provides the tools, board provides the values" route.
Now I do understand that one might want to avoid duplication, which is why I would agree with keeping the existing sequence in the driver and only defining board-specific sequences in the board code.
OTOH, if the difference is not that big, then keeping it in the board is not that painful either. :)
Seriously, though: There's zero reason we should have board dependency compiled into drivers, since we can always write the driver API so that board-specifics are passed by argument to driver functions, and having a board-agnostic driver is a Good Thing (tm).
Now, what part is board-specific and how it is passed, that's quite an open point.
I personally think that the way we should abstract things, and whether we should abstract them at all, depends on the benefit from an overall SW architecture standpoint.
For instance, I have come to think the JEDEC abstraction is good, because it can be be reused by other (future /or/ existing) drivers, and ecause the JEDEC definition for a given DDR3 chip can be hared across all boards that use it (and then, all can benefit from 'bugfixes', if any, in the chip's JEDEC definition).
The only thing I'm not 100% sure is, as you mention it, whether the IP's JEDEC-related are *purely* JEDEC or whether they also depend in part on the board's HW design (track lengths, buffers, whatever). But even if they do, then we can always pass the existing, pure, JEDEC info in the JEDEC struct, /plus/ HW related info in another argument, and have the driver do the mix. The separation would allow us to keep sharing the pure JEDEC info in all boards that use the same DDR3 chip.
OTOH, structs like the lvl struct, with the driver interpreting them into register writes, seems not to benefit the SW architecture: you can't generalize that to other drivers. You can't share lvl struct values across boards. The lvl struct's only benefit is to ensure that a small group of writes will be consistent, something that the developer will quite probably have checked from the spec anyway; it is prone to introducing restrictions that will inevitably be hit one day, and then we will have to maintain the struct *and* the writing code, and run a risk of affecting existing boards each time we do it.
The (offset, value) sequence is indeed very low-level and does indeed make the board hardware-dependent, but the board already *is*, anyway -- anyone looking at the board's DDR3 init certainly should have read the DDR3 controller (and chip) HW specs -- and the maintenance cost in the is low: the driver won't need any once it knows how to run the sequence properly, existing boards which use it will only need maintenance in case of bugs, and new boards will only need to get their new sequence right without fear of affecting existing code.
-- Stefan
Would that be ok ?
Hi Albert,
On Fri, Jun 19, 2015 at 7:18 AM, Albert ARIBAUD (3ADEV) albert.aribaud@3adev.fr wrote:
This locally defined struct is actually only used once and as an opaque type. Remove it for clarity.
Signed-off-by: Albert ARIBAUD (3ADEV) albert.aribaud@3adev.fr
drivers/net/fec_mxc.c | 20 +++++--------------- 1 file changed, 5 insertions(+), 15 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 9225d37..c5dcbbb 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -67,13 +67,6 @@ DECLARE_GLOBAL_DATA_PTR;
#undef DEBUG
-struct nbuf {
- uint8_t data[1500]; /**< actual data */
- int length; /**< actual length */
- int used; /**< buffer in use or not */
- uint8_t head[16]; /**< MAC header(6 + 6 + 2) + 2(aligned) */
#ifdef CONFIG_FEC_MXC_SWAP_PACKET static void swap_packet(uint32_t *packet, int length) { @@ -775,7 +768,6 @@ static int fec_recv(struct eth_device *dev) struct fec_bd *rbd = &fec->rbd_base[fec->rbd_index]; unsigned long ievent; int frame_length, len = 0;
- struct nbuf *frame; uint16_t bd_status; uint32_t addr, size, end; int i;
@@ -835,12 +827,11 @@ static int fec_recv(struct eth_device *dev) /* * Get buffer address and size */
frame = (struct nbuf *)readl(&rbd->data_pointer);
addr = readl(&rbd->data_pointer); frame_length = readw(&rbd->data_length) - 4; /* * Invalidate data cache over the buffer */
addr = (uint32_t)frame; end = roundup(addr + frame_length, ARCH_DMA_MINALIGN); addr &= ~(ARCH_DMA_MINALIGN - 1); invalidate_dcache_range(addr, end);
@@ -849,16 +840,15 @@ static int fec_recv(struct eth_device *dev) * Fill the buffer and pass it to upper layers */ #ifdef CONFIG_FEC_MXC_SWAP_PACKET
swap_packet((uint32_t *)frame->data, frame_length);
swap_packet((uint32_t *)addr, frame_length);
#endif
memcpy(buff, frame->data, frame_length);
} else { if (bd_status & FEC_RBD_ERR)memcpy(buff, (char *)addr, frame_length); net_process_received_packet(buff, frame_length); len = frame_length;
printf("error frame: 0x%08lx 0x%08x\n",
(ulong)rbd->data_pointer,
bd_status);
printf("error frame: 0x%08x 0x%08x\n",
addr, bd_status);
participants (7)
Albert ARIBAUD
Albert ARIBAUD
Joe Hershberger
Stefan Agner
Stefan Agner
Stefano Babic
