Please pull u-boot-i2c
Hello Tom,
please pull from:
The following changes since commit 5f68470d69f853b1652ebe93525b60064717fe2e:
Merge tag 'efi-2022-04-rc5' of https://source.denx.de/u-boot/custodians/u-boot-efi (2022-03-20 15:14:59 -0400)
https://source.denx.de/u-boot/custodians/u-boot-i2c.git tags/i2c-2022-04-rc5
for you to fetch changes up to fc1383ae2b5ca69e51bee68e4047589a5ee7b386:
bootcount: clarify documentation (2022-03-23 07:27:38 +0100)
---------------------------------------------------------------- i2c changes for fixes-for-2022.04
- atsha204a-i2c.c DTS and I2C fixes for Atmel ATSHA204 from Adrian
- i2c: fix always-true condition in i2c_probe_chip() from Nikita
- eeprom: Do not rewrite EEPROM I2C bus with DM I2C enabled from Marek
- clarify bootcount documentation fix from Michael
---------------------------------------------------------------- Adrian Fiergolski (3): misc: atsha204a: return timeout from wakeup function misc: atsha204a: add delay after sending the message misc: atsha204a: fix i2c address readout from DTS
Marek Vasut (1): cmd: eeprom: Do not rewrite EEPROM I2C bus with DM I2C enabled
Michael Opdenacker (1): bootcount: clarify documentation
Nikita Yushchenko (1): i2c: fix always-true condition in i2c_probe_chip()
cmd/eeprom.c | 2 +- doc/README.bootcount | 34 ++++++++++++++++++---------------- drivers/bootcount/Kconfig | 10 +++++----- drivers/i2c/i2c-uclass.c | 2 +- drivers/misc/atsha204a-i2c.c | 8 ++++---- 5 files changed, 29 insertions(+), 27 deletions(-)
Azure build is fine:
https://dev.azure.com/hs0298/hs/_build/results?buildId=79&view=results
Thanks!
bye, Heiko
On Wed, Mar 23, 2022 at 10:16:13AM +0100, Heiko Schocher wrote:
Hello Tom,
please pull from:
Heiko Schocher
