[U-Boot] [PATCH] NetStar: make crcit utility more readable.
Signed-off-by: Ladislav Michl ladis@linux-mips.org
--- board/netstar/crcit.c | 9 +++++---- 1 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/board/netstar/crcit.c b/board/netstar/crcit.c index e0cea9b..0eef41a 100644 --- a/board/netstar/crcit.c +++ b/board/netstar/crcit.c @@ -56,13 +56,14 @@ static int do_crc(char *path, unsigned version) fprintf(stderr, "File too large\n"); return EXIT_FAILURE; } - size = (size + 3) & ~3; /* round up to 4 bytes */ - data[0] = size + 4; /* add size of version field */ + size = (size + 3) & ~3; /* round up to 4 bytes */ + size += 4; /* add size of version field */ + data[0] = size; data[1] = version; - data[2 + (size >> 2)] = crc32(0, (unsigned char *)(data + 1), data[0]); + data[size/4 + 1] = crc32(0, (unsigned char *)(data + 1), size); close(fd);
- if (write(STDOUT_FILENO, data, size + 3*4) == -1) { + if (write(STDOUT_FILENO, data, size + 4 /*size*/ + 4 /*crc*/) == -1) { perror("Error writing file"); return EXIT_FAILURE; }
Subject: [PATCH] NetStar: make crcit utility more readable.
Pushed to u-boot-ti.
Again , since there is no patch description, I copied the patch header.
Ladislav Michl
Paulraj, Sandeep
