[U-Boot] [PATCH] boot_fit: Fix warning: overflow in implicit constant conversion in fdt_offset()
FDT_ERROR is defined as unsigned long. However, since the return value of fdt_offset() is int, a warning will occur when compiling. This fixes this problem by cast to int when setting FDT_ERROR as return value.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org CC: Franklin S Cooper Jr fcooper@ti.com --- common/boot_fit.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/boot_fit.c b/common/boot_fit.c index 51440a6e6f..ca130f2308 100644 --- a/common/boot_fit.c +++ b/common/boot_fit.c @@ -25,7 +25,7 @@ int fdt_offset(void *fit) images = fdt_path_offset(fit, FIT_IMAGES_PATH); if (images < 0) { debug("%s: Cannot find /images node: %d\n", __func__, images); - return FDT_ERROR; + return (int)FDT_ERROR; }
fdt_name = fdt_getprop(fit, node, FIT_FDT_PROP, &fdt_len);
return FDT_ERROR;
Returning -EINVAL would be better. Doing essentially (int)((ulong)(-1)) doesn't look right and to function properly that function needs to return any kind of negative value. Thanks for catching this problem.
2017-08-03 8:56 GMT+09:00 Franklin S Cooper Jr fcooper@ti.com:
return FDT_ERROR;
I see. I will resend new patch. Thanks!
Nobuhiro
Nobuhiro Iwamatsu
