[U-Boot] [PATCH 1/2] travis: Setup QEMU_VERSION as variable
This change enables setting up specific Qemu version or sha1 for new targets which are added after (current) v3.0.0 version. This changes is preparation step for adding new Xilinx Versal Virt platform which was merge after v3.0.0.
.travis.yml | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/.travis.yml b/.travis.yml index 321fd793a756..6e4b4ba0a34a 100644 --- a/.travis.yml +++ b/.travis.yml @@ -63,6 +63,7 @@ env: - BUILD_DIR=build - HOSTCC="cc" - HOSTCXX="c++" + - QEMU_VERSION="v3.0.0"
before_script: # install toolchains based on TOOLCHAIN} variable @@ -97,7 +98,7 @@ before_script: git clone git://git.qemu.org/qemu.git /tmp/qemu; pushd /tmp/qemu; git submodule update --init dtc && - git checkout v3.0.0 && + git checkout ${QEMU_VERSION} && ./configure --prefix=/tmp/qemu-install --target-list=${QEMU_TARGET} && make -j4 all install; popd;
Test Xilinx Versal Virt platform running on the v3.1.0 Qemu.
Patch needs to be applied when this PR is merged. https://github.com/swarren/uboot-test-hooks/pull/21
--- .travis.yml | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/.travis.yml b/.travis.yml index 6e4b4ba0a34a..e14e6987e4cf 100644 --- a/.travis.yml +++ b/.travis.yml @@ -454,6 +454,14 @@ matrix: QEMU_TARGET="arm-softmmu" TEST_PY_ID="--id qemu" BUILDMAN="^zynq_zc702$" + - name: "test/py xilinx_versal_virt" + env: + - TEST_PY_BD="xilinx_versal_virt" + TEST_PY_TEST_SPEC="not sleep" + QEMU_TARGET="aarch64-softmmu" + QEMU_VERSION="v3.1.0" + TEST_PY_ID="--id qemu" + BUILDMAN="^xilinx_versal_virt$" - name: "test/py xtfpga" env: - TEST_PY_BD="xtfpga"
env:
Can we turn on 3.1.0 for all QEMU targets?
Regards, Bin
env:
I expected this question. First of all I wanted to enable an option to be able to wire whatever version. Even sha1 for not released version.
I think we can try to test v3.1.0 qemu version for all boards but I will let Tom to decide is we can move or not.
Thanks, Michal
Hi Michal,
env:
Yes, please try to test that. If everything is good, I see no reason not using it.
Regards, Bin
On Thu, Dec 20, 2018 at 04:30:19PM +0800, Bin Meng wrote:
Hi Michal,
env:
Yes, I would also like to move everyone up to v3.1.0 and also having the version we use be spelled out will help with future reproducibility.
Hi Michal,
env:
v3.1 is not working on vexpress_ca9x4 and vexpress_ca15_tc2. take a look at https://travis-ci.org/michalsimek/u-boot/builds/470873127 I am happy to keep them on v3.0 and move the rest to v3.1 and let vexpress guys to figured out what's wrong with v3.1 and configs around.
What do you think?
Thanks, Michal
Hi Michal,
env:
What do you think?
The error is: ---------------------------- Captured stdout setup ----------------------------- +u-boot-test-reset vexpress_ca15_tc2 qemu qemu-system-arm: -tftp: invalid option
And I guess the problem is that by v3.1.0 -tftp has been removed and we need to use -netdev user,id=net0,tftp=${UBOOT_TRAVIS_BUILD_DIR} like on the other QEMU-based targets. Can you update uboot-test-hooks (change .travis.yml to clone your fork of uboot-test-hooks rather than swarren's) to have the modern syntax? Thanks!
Hi Michal,
On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: > > Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. > > Signed-off-by: Michal Simek michal.simek@xilinx.com > --- > > Patch needs to be applied when this PR is merged. > https://github.com/swarren/uboot-test-hooks/pull/21 > > --- > .travis.yml | 8 ++++++++ > 1 file changed, 8 insertions(+) > > diff --git a/.travis.yml b/.travis.yml > index 6e4b4ba0a34a..e14e6987e4cf 100644 > --- a/.travis.yml > +++ b/.travis.yml > @@ -454,6 +454,14 @@ matrix: > QEMU_TARGET="arm-softmmu" > TEST_PY_ID="--id qemu" > BUILDMAN="^zynq_zc702$" > + - name: "test/py xilinx_versal_virt" > + env: > + - TEST_PY_BD="xilinx_versal_virt" > + TEST_PY_TEST_SPEC="not sleep" > + QEMU_TARGET="aarch64-softmmu" > + QEMU_VERSION="v3.1.0" > + TEST_PY_ID="--id qemu" > + BUILDMAN="^xilinx_versal_virt$"
What do you think?
I think the correct approach is to update uboot-test-hooks and send PR to Stephen, then apply this 3.1.0 patch on the U-Boot side. We should still have U-Boot's .travis.yml point to swarren's git repo, no?
Regards, Bin
Hi Michal,
On 20. 12. 18 9:09, Bin Meng wrote: > On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: >> >> Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. >> >> Signed-off-by: Michal Simek michal.simek@xilinx.com >> --- >> >> Patch needs to be applied when this PR is merged. >> https://github.com/swarren/uboot-test-hooks/pull/21 >> >> --- >> .travis.yml | 8 ++++++++ >> 1 file changed, 8 insertions(+) >> >> diff --git a/.travis.yml b/.travis.yml >> index 6e4b4ba0a34a..e14e6987e4cf 100644 >> --- a/.travis.yml >> +++ b/.travis.yml >> @@ -454,6 +454,14 @@ matrix: >> QEMU_TARGET="arm-softmmu" >> TEST_PY_ID="--id qemu" >> BUILDMAN="^zynq_zc702$" >> + - name: "test/py xilinx_versal_virt" >> + env: >> + - TEST_PY_BD="xilinx_versal_virt" >> + TEST_PY_TEST_SPEC="not sleep" >> + QEMU_TARGET="aarch64-softmmu" >> + QEMU_VERSION="v3.1.0" >> + TEST_PY_ID="--id qemu" >> + BUILDMAN="^xilinx_versal_virt$" > > Can we turn on 3.1.0 for all QEMU targets?
What do you think?
Yes, sorry, to be clear, I was just saying how to debug / confirm the changes to uboot-test-hooks.
Hi Michal,
On Thu, Dec 20, 2018 at 4:17 PM Michal Simek michal.simek@xilinx.com wrote: > > On 20. 12. 18 9:09, Bin Meng wrote: >> On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: >>> >>> Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. >>> >>> Signed-off-by: Michal Simek michal.simek@xilinx.com >>> --- >>> >>> Patch needs to be applied when this PR is merged. >>> https://github.com/swarren/uboot-test-hooks/pull/21 >>> >>> --- >>> .travis.yml | 8 ++++++++ >>> 1 file changed, 8 insertions(+) >>> >>> diff --git a/.travis.yml b/.travis.yml >>> index 6e4b4ba0a34a..e14e6987e4cf 100644 >>> --- a/.travis.yml >>> +++ b/.travis.yml >>> @@ -454,6 +454,14 @@ matrix: >>> QEMU_TARGET="arm-softmmu" >>> TEST_PY_ID="--id qemu" >>> BUILDMAN="^zynq_zc702$" >>> + - name: "test/py xilinx_versal_virt" >>> + env: >>> + - TEST_PY_BD="xilinx_versal_virt" >>> + TEST_PY_TEST_SPEC="not sleep" >>> + QEMU_TARGET="aarch64-softmmu" >>> + QEMU_VERSION="v3.1.0" >>> + TEST_PY_ID="--id qemu" >>> + BUILDMAN="^xilinx_versal_virt$" >> >> Can we turn on 3.1.0 for all QEMU targets? > > I expected this question. > First of all I wanted to enable an option to be able to wire whatever > version. Even sha1 for not released version. > > I think we can try to test v3.1.0 qemu version for all boards but I will > let Tom to decide is we can move or not. >
What do you think?
I have created new pull request for fixing that network issue here. https://github.com/swarren/uboot-test-hooks/pull/22
But for vexpress_ca15_tc2 there is still an issue with helloworld efi. It works on v3.0 but not on v3.1.
=> => tftpboot 80000000 lib/efi_loader/helloworld.efi smc911x: MAC 52:54:00:12:34:56 smc911x: detected LAN9118 controller smc911x: phy initialized smc911x: MAC 52:54:00:12:34:56 Using smc911x-0 device TFTP from server 10.0.2.2; our IP address is 10.0.2.15 Filename 'lib/efi_loader/helloworld.efi'. Load address: 0x80000000 Loading: # 2 MiB/s done Bytes transferred = 2144 (860 hex) smc911x: MAC 52:54:00:12:34:56 => => crc32 80000000 $filesize CRC32 for 80000000 ... 8000085f ==> b76d87c0 => => bootefi 80000000 Scanning disks on mmc... ^[[61;213RCard did not respond to voltage select! MMC Device 1 not found MMC Device 2 not found MMC Device 3 not found Found 0 disks WARNING: booting without device tree ## Starting EFI application at 80000000 ... Fs+u-boot-test-reset vexpress_ca15_tc2 qemu
I need to move to something else instead of hacking this target.
My goal is to get Versal to travis to make sure that none is breaking it not debugging issues with platform I don't know. Can I keep this platform on v3.0 and move the rest to 3.1?
Thanks, Michal
On Thu, Dec 20, 2018 at 04:30:19PM +0800, Bin Meng wrote: > Hi Michal, > > On Thu, Dec 20, 2018 at 4:17 PM Michal Simek michal.simek@xilinx.com wrote: >> >> On 20. 12. 18 9:09, Bin Meng wrote: >>> On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: >>>> >>>> Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. >>>> >>>> Signed-off-by: Michal Simek michal.simek@xilinx.com >>>> --- >>>> >>>> Patch needs to be applied when this PR is merged. >>>> https://github.com/swarren/uboot-test-hooks/pull/21 >>>> >>>> --- >>>> .travis.yml | 8 ++++++++ >>>> 1 file changed, 8 insertions(+) >>>> >>>> diff --git a/.travis.yml b/.travis.yml >>>> index 6e4b4ba0a34a..e14e6987e4cf 100644 >>>> --- a/.travis.yml >>>> +++ b/.travis.yml >>>> @@ -454,6 +454,14 @@ matrix: >>>> QEMU_TARGET="arm-softmmu" >>>> TEST_PY_ID="--id qemu" >>>> BUILDMAN="^zynq_zc702$" >>>> + - name: "test/py xilinx_versal_virt" >>>> + env: >>>> + - TEST_PY_BD="xilinx_versal_virt" >>>> + TEST_PY_TEST_SPEC="not sleep" >>>> + QEMU_TARGET="aarch64-softmmu" >>>> + QEMU_VERSION="v3.1.0" >>>> + TEST_PY_ID="--id qemu" >>>> + BUILDMAN="^xilinx_versal_virt$" >>> >>> Can we turn on 3.1.0 for all QEMU targets? >> >> I expected this question. >> First of all I wanted to enable an option to be able to wire whatever >> version. Even sha1 for not released version. >> >> I think we can try to test v3.1.0 qemu version for all boards but I will >> let Tom to decide is we can move or not. >> > > Yes, please try to test that. If everything is good, I see no reason > not using it.
What do you think?
Alex, any ideas? Can you take a look? Thanks!
On 26. 12. 18 15:29, Tom Rini wrote: > On Thu, Dec 20, 2018 at 04:30:19PM +0800, Bin Meng wrote: >> Hi Michal, >> >> On Thu, Dec 20, 2018 at 4:17 PM Michal Simek michal.simek@xilinx.com wrote: >>> >>> On 20. 12. 18 9:09, Bin Meng wrote: >>>> On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: >>>>> >>>>> Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. >>>>> >>>>> Signed-off-by: Michal Simek michal.simek@xilinx.com >>>>> --- >>>>> >>>>> Patch needs to be applied when this PR is merged. >>>>> https://github.com/swarren/uboot-test-hooks/pull/21 >>>>> >>>>> --- >>>>> .travis.yml | 8 ++++++++ >>>>> 1 file changed, 8 insertions(+) >>>>> >>>>> diff --git a/.travis.yml b/.travis.yml >>>>> index 6e4b4ba0a34a..e14e6987e4cf 100644 >>>>> --- a/.travis.yml >>>>> +++ b/.travis.yml >>>>> @@ -454,6 +454,14 @@ matrix: >>>>> QEMU_TARGET="arm-softmmu" >>>>> TEST_PY_ID="--id qemu" >>>>> BUILDMAN="^zynq_zc702$" >>>>> + - name: "test/py xilinx_versal_virt" >>>>> + env: >>>>> + - TEST_PY_BD="xilinx_versal_virt" >>>>> + TEST_PY_TEST_SPEC="not sleep" >>>>> + QEMU_TARGET="aarch64-softmmu" >>>>> + QEMU_VERSION="v3.1.0" >>>>> + TEST_PY_ID="--id qemu" >>>>> + BUILDMAN="^xilinx_versal_virt$" >>>> >>>> Can we turn on 3.1.0 for all QEMU targets? >>> >>> I expected this question. >>> First of all I wanted to enable an option to be able to wire whatever >>> version. Even sha1 for not released version. >>> >>> I think we can try to test v3.1.0 qemu version for all boards but I will >>> let Tom to decide is we can move or not. >>> >> >> Yes, please try to test that. If everything is good, I see no reason >> not using it. > > Yes, I would also like to move everyone up to v3.1.0 and also having the > version we use be spelled out will help with future reproducibility. >
What do you think?
Just in case you want to see some logs from travis. https://travis-ci.org/michalsimek/u-boot/builds/475350468
M
On Thu, Jan 03, 2019 at 09:00:41AM +0100, Michal Simek wrote: > On 26. 12. 18 15:29, Tom Rini wrote: >> On Thu, Dec 20, 2018 at 04:30:19PM +0800, Bin Meng wrote: >>> Hi Michal, >>> >>> On Thu, Dec 20, 2018 at 4:17 PM Michal Simek michal.simek@xilinx.com wrote: >>>> On 20. 12. 18 9:09, Bin Meng wrote: >>>>> On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>> Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. >>>>>> >>>>>> Signed-off-by: Michal Simek michal.simek@xilinx.com >>>>>> --- >>>>>> >>>>>> Patch needs to be applied when this PR is merged. >>>>>> https://github.com/swarren/uboot-test-hooks/pull/21 >>>>>> >>>>>> --- >>>>>> .travis.yml | 8 ++++++++ >>>>>> 1 file changed, 8 insertions(+) >>>>>> >>>>>> diff --git a/.travis.yml b/.travis.yml >>>>>> index 6e4b4ba0a34a..e14e6987e4cf 100644 >>>>>> --- a/.travis.yml >>>>>> +++ b/.travis.yml >>>>>> @@ -454,6 +454,14 @@ matrix: >>>>>> QEMU_TARGET="arm-softmmu" >>>>>> TEST_PY_ID="--id qemu" >>>>>> BUILDMAN="^zynq_zc702$" >>>>>> + - name: "test/py xilinx_versal_virt" >>>>>> + env: >>>>>> + - TEST_PY_BD="xilinx_versal_virt" >>>>>> + TEST_PY_TEST_SPEC="not sleep" >>>>>> + QEMU_TARGET="aarch64-softmmu" >>>>>> + QEMU_VERSION="v3.1.0" >>>>>> + TEST_PY_ID="--id qemu" >>>>>> + BUILDMAN="^xilinx_versal_virt$" >>>>> Can we turn on 3.1.0 for all QEMU targets? >>>> I expected this question. >>>> First of all I wanted to enable an option to be able to wire whatever >>>> version. Even sha1 for not released version. >>>> >>>> I think we can try to test v3.1.0 qemu version for all boards but I will >>>> let Tom to decide is we can move or not. >>>> >>> Yes, please try to test that. If everything is good, I see no reason >>> not using it. >> Yes, I would also like to move everyone up to v3.1.0 and also having the >> version we use be spelled out will help with future reproducibility. >> > v3.1 is not working on vexpress_ca9x4 and vexpress_ca15_tc2. > take a look at https://travis-ci.org/michalsimek/u-boot/builds/470873127 > I am happy to keep them on v3.0 and move the rest to v3.1 and let > vexpress guys to figured out what's wrong with v3.1 and configs around. > > What do you think? The error is: ---------------------------- Captured stdout setup ----------------------------- +u-boot-test-reset vexpress_ca15_tc2 qemu qemu-system-arm: -tftp: invalid option
So the offending change is a new capability in QEMU that exposes EL2 (HYP) mode on the Cortex-A15 core which this vexpress model uses. There are 2 steps here IMHO:
1) Disable EL2 again by hand. This is easily doable by passing "-cpu cortex-a15,has_el2=off" to the QEMU command line. That restores the previous behavior 2) Find out *why* it's broken. That's probably a U-Boot bug.
Alex
On Thu, Jan 3, 2019 at 9:39 PM Tom Rini trini@konsulko.com wrote: >On Thu, Jan 03, 2019 at 09:00:41AM +0100, Michal Simek wrote: >>On 26. 12. 18 15:29, Tom Rini wrote: >>>On Thu, Dec 20, 2018 at 04:30:19PM +0800, Bin Meng wrote: >>>>Hi Michal, >>>> >>>>On Thu, Dec 20, 2018 at 4:17 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>On 20. 12. 18 9:09, Bin Meng wrote: >>>>>>On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. >>>>>>> >>>>>>>Signed-off-by: Michal Simek michal.simek@xilinx.com >>>>>>>--- >>>>>>> >>>>>>>Patch needs to be applied when this PR is merged. >>>>>>>https://github.com/swarren/uboot-test-hooks/pull/21 >>>>>>> >>>>>>>--- >>>>>>> .travis.yml | 8 ++++++++ >>>>>>> 1 file changed, 8 insertions(+) >>>>>>> >>>>>>>diff --git a/.travis.yml b/.travis.yml >>>>>>>index 6e4b4ba0a34a..e14e6987e4cf 100644 >>>>>>>--- a/.travis.yml >>>>>>>+++ b/.travis.yml >>>>>>>@@ -454,6 +454,14 @@ matrix: >>>>>>> QEMU_TARGET="arm-softmmu" >>>>>>> TEST_PY_ID="--id qemu" >>>>>>> BUILDMAN="^zynq_zc702$" >>>>>>>+ - name: "test/py xilinx_versal_virt" >>>>>>>+ env: >>>>>>>+ - TEST_PY_BD="xilinx_versal_virt" >>>>>>>+ TEST_PY_TEST_SPEC="not sleep" >>>>>>>+ QEMU_TARGET="aarch64-softmmu" >>>>>>>+ QEMU_VERSION="v3.1.0" >>>>>>>+ TEST_PY_ID="--id qemu" >>>>>>>+ BUILDMAN="^xilinx_versal_virt$" >>>>>>Can we turn on 3.1.0 for all QEMU targets? >>>>>I expected this question. >>>>>First of all I wanted to enable an option to be able to wire whatever >>>>>version. Even sha1 for not released version. >>>>> >>>>>I think we can try to test v3.1.0 qemu version for all boards but I will >>>>>let Tom to decide is we can move or not. >>>>> >>>>Yes, please try to test that. If everything is good, I see no reason >>>>not using it. >>>Yes, I would also like to move everyone up to v3.1.0 and also having the >>>version we use be spelled out will help with future reproducibility. >>> >>v3.1 is not working on vexpress_ca9x4 and vexpress_ca15_tc2. >>take a look at https://travis-ci.org/michalsimek/u-boot/builds/470873127 >>I am happy to keep them on v3.0 and move the rest to v3.1 and let >>vexpress guys to figured out what's wrong with v3.1 and configs around. >> >>What do you think? >The error is: >---------------------------- Captured stdout setup ----------------------------- >+u-boot-test-reset vexpress_ca15_tc2 qemu >qemu-system-arm: -tftp: invalid option > >And I guess the problem is that by v3.1.0 -tftp has been removed and we >need to use -netdev user,id=net0,tftp=${UBOOT_TRAVIS_BUILD_DIR} like on >the other QEMU-based targets. Can you update uboot-test-hooks (change >.travis.yml to clone your fork of uboot-test-hooks rather than >swarren's) to have the modern syntax? Thanks! I think the correct approach is to update uboot-test-hooks and send PR to Stephen, then apply this 3.1.0 patch on the U-Boot side. We should still have U-Boot's .travis.yml point to swarren's git repo, no?
- Disable EL2 again by hand. This is easily doable by passing "-cpu
... which is one more change to the uboot-test-scripts repo, can someone please? Thanks.
- Find out *why* it's broken. That's probably a U-Boot bug.
Agreed.
On Fri, Jan 04, 2019 at 09:29:47AM +0800, Bin Meng wrote: > On Thu, Jan 3, 2019 at 9:39 PM Tom Rini trini@konsulko.com wrote: >> On Thu, Jan 03, 2019 at 09:00:41AM +0100, Michal Simek wrote: >>> On 26. 12. 18 15:29, Tom Rini wrote: >>>> On Thu, Dec 20, 2018 at 04:30:19PM +0800, Bin Meng wrote: >>>>> Hi Michal, >>>>> >>>>> On Thu, Dec 20, 2018 at 4:17 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>> On 20. 12. 18 9:09, Bin Meng wrote: >>>>>>> On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>> Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. >>>>>>>> >>>>>>>> Signed-off-by: Michal Simek michal.simek@xilinx.com >>>>>>>> --- >>>>>>>> >>>>>>>> Patch needs to be applied when this PR is merged. >>>>>>>> https://github.com/swarren/uboot-test-hooks/pull/21 >>>>>>>> >>>>>>>> --- >>>>>>>> .travis.yml | 8 ++++++++ >>>>>>>> 1 file changed, 8 insertions(+) >>>>>>>> >>>>>>>> diff --git a/.travis.yml b/.travis.yml >>>>>>>> index 6e4b4ba0a34a..e14e6987e4cf 100644 >>>>>>>> --- a/.travis.yml >>>>>>>> +++ b/.travis.yml >>>>>>>> @@ -454,6 +454,14 @@ matrix: >>>>>>>> QEMU_TARGET="arm-softmmu" >>>>>>>> TEST_PY_ID="--id qemu" >>>>>>>> BUILDMAN="^zynq_zc702$" >>>>>>>> + - name: "test/py xilinx_versal_virt" >>>>>>>> + env: >>>>>>>> + - TEST_PY_BD="xilinx_versal_virt" >>>>>>>> + TEST_PY_TEST_SPEC="not sleep" >>>>>>>> + QEMU_TARGET="aarch64-softmmu" >>>>>>>> + QEMU_VERSION="v3.1.0" >>>>>>>> + TEST_PY_ID="--id qemu" >>>>>>>> + BUILDMAN="^xilinx_versal_virt$" >>>>>>> Can we turn on 3.1.0 for all QEMU targets? >>>>>> I expected this question. >>>>>> First of all I wanted to enable an option to be able to wire whatever >>>>>> version. Even sha1 for not released version. >>>>>> >>>>>> I think we can try to test v3.1.0 qemu version for all boards but I will >>>>>> let Tom to decide is we can move or not. >>>>>> >>>>> Yes, please try to test that. If everything is good, I see no reason >>>>> not using it. >>>> Yes, I would also like to move everyone up to v3.1.0 and also having the >>>> version we use be spelled out will help with future reproducibility. >>>> >>> v3.1 is not working on vexpress_ca9x4 and vexpress_ca15_tc2. >>> take a look at https://travis-ci.org/michalsimek/u-boot/builds/470873127 >>> I am happy to keep them on v3.0 and move the rest to v3.1 and let >>> vexpress guys to figured out what's wrong with v3.1 and configs around. >>> >>> What do you think? >> The error is: >> ---------------------------- Captured stdout setup ----------------------------- >> +u-boot-test-reset vexpress_ca15_tc2 qemu >> qemu-system-arm: -tftp: invalid option >> >> And I guess the problem is that by v3.1.0 -tftp has been removed and we >> need to use -netdev user,id=net0,tftp=${UBOOT_TRAVIS_BUILD_DIR} like on >> the other QEMU-based targets. Can you update uboot-test-hooks (change >> .travis.yml to clone your fork of uboot-test-hooks rather than >> swarren's) to have the modern syntax? Thanks! > I think the correct approach is to update uboot-test-hooks and send PR > to Stephen, then apply this 3.1.0 patch on the U-Boot side. We should > still have U-Boot's .travis.yml point to swarren's git repo, no? Yes, sorry, to be clear, I was just saying how to debug / confirm the changes to uboot-test-hooks.
Done: https://github.com/swarren/uboot-test-hooks/pull/23
Alex
On 04. 01. 19 4:01, Tom Rini wrote: > On Fri, Jan 04, 2019 at 09:29:47AM +0800, Bin Meng wrote: >> On Thu, Jan 3, 2019 at 9:39 PM Tom Rini trini@konsulko.com wrote: >>> On Thu, Jan 03, 2019 at 09:00:41AM +0100, Michal Simek wrote: >>>> On 26. 12. 18 15:29, Tom Rini wrote: >>>>> On Thu, Dec 20, 2018 at 04:30:19PM +0800, Bin Meng wrote: >>>>>> Hi Michal, >>>>>> >>>>>> On Thu, Dec 20, 2018 at 4:17 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>> On 20. 12. 18 9:09, Bin Meng wrote: >>>>>>>> On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>>> Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. >>>>>>>>> >>>>>>>>> Signed-off-by: Michal Simek michal.simek@xilinx.com >>>>>>>>> --- >>>>>>>>> >>>>>>>>> Patch needs to be applied when this PR is merged. >>>>>>>>> https://github.com/swarren/uboot-test-hooks/pull/21 >>>>>>>>> >>>>>>>>> --- >>>>>>>>> .travis.yml | 8 ++++++++ >>>>>>>>> 1 file changed, 8 insertions(+) >>>>>>>>> >>>>>>>>> diff --git a/.travis.yml b/.travis.yml >>>>>>>>> index 6e4b4ba0a34a..e14e6987e4cf 100644 >>>>>>>>> --- a/.travis.yml >>>>>>>>> +++ b/.travis.yml >>>>>>>>> @@ -454,6 +454,14 @@ matrix: >>>>>>>>> QEMU_TARGET="arm-softmmu" >>>>>>>>> TEST_PY_ID="--id qemu" >>>>>>>>> BUILDMAN="^zynq_zc702$" >>>>>>>>> + - name: "test/py xilinx_versal_virt" >>>>>>>>> + env: >>>>>>>>> + - TEST_PY_BD="xilinx_versal_virt" >>>>>>>>> + TEST_PY_TEST_SPEC="not sleep" >>>>>>>>> + QEMU_TARGET="aarch64-softmmu" >>>>>>>>> + QEMU_VERSION="v3.1.0" >>>>>>>>> + TEST_PY_ID="--id qemu" >>>>>>>>> + BUILDMAN="^xilinx_versal_virt$" >>>>>>>> Can we turn on 3.1.0 for all QEMU targets? >>>>>>> I expected this question. >>>>>>> First of all I wanted to enable an option to be able to wire whatever >>>>>>> version. Even sha1 for not released version. >>>>>>> >>>>>>> I think we can try to test v3.1.0 qemu version for all boards but I will >>>>>>> let Tom to decide is we can move or not. >>>>>>> >>>>>> Yes, please try to test that. If everything is good, I see no reason >>>>>> not using it. >>>>> Yes, I would also like to move everyone up to v3.1.0 and also having the >>>>> version we use be spelled out will help with future reproducibility. >>>>> >>>> v3.1 is not working on vexpress_ca9x4 and vexpress_ca15_tc2. >>>> take a look at https://travis-ci.org/michalsimek/u-boot/builds/470873127 >>>> I am happy to keep them on v3.0 and move the rest to v3.1 and let >>>> vexpress guys to figured out what's wrong with v3.1 and configs around. >>>> >>>> What do you think? >>> The error is: >>> ---------------------------- Captured stdout setup ----------------------------- >>> +u-boot-test-reset vexpress_ca15_tc2 qemu >>> qemu-system-arm: -tftp: invalid option >>> >>> And I guess the problem is that by v3.1.0 -tftp has been removed and we >>> need to use -netdev user,id=net0,tftp=${UBOOT_TRAVIS_BUILD_DIR} like on >>> the other QEMU-based targets. Can you update uboot-test-hooks (change >>> .travis.yml to clone your fork of uboot-test-hooks rather than >>> swarren's) to have the modern syntax? Thanks! >> I think the correct approach is to update uboot-test-hooks and send PR >> to Stephen, then apply this 3.1.0 patch on the U-Boot side. We should >> still have U-Boot's .travis.yml point to swarren's git repo, no? > Yes, sorry, to be clear, I was just saying how to debug / confirm the > changes to uboot-test-hooks. I have created new pull request for fixing that network issue here. https://github.com/swarren/uboot-test-hooks/pull/22
aaaand this breaks older QEMU. I think for the moment, can you please revert this Stephen? We'll take the QEMU version bump early on in the next release and I'll let you know off-list when I'm grabbing it. Thanks!
It's done.
On Mon, Jan 07, 2019 at 01:18:46PM +0100, Michal Simek wrote: > On 04. 01. 19 4:01, Tom Rini wrote: >> On Fri, Jan 04, 2019 at 09:29:47AM +0800, Bin Meng wrote: >>> On Thu, Jan 3, 2019 at 9:39 PM Tom Rini trini@konsulko.com wrote: >>>> On Thu, Jan 03, 2019 at 09:00:41AM +0100, Michal Simek wrote: >>>>> On 26. 12. 18 15:29, Tom Rini wrote: >>>>>> On Thu, Dec 20, 2018 at 04:30:19PM +0800, Bin Meng wrote: >>>>>>> Hi Michal, >>>>>>> >>>>>>> On Thu, Dec 20, 2018 at 4:17 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>> On 20. 12. 18 9:09, Bin Meng wrote: >>>>>>>>> On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>>>> Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. >>>>>>>>>> >>>>>>>>>> Signed-off-by: Michal Simek michal.simek@xilinx.com >>>>>>>>>> --- >>>>>>>>>> >>>>>>>>>> Patch needs to be applied when this PR is merged. >>>>>>>>>> https://github.com/swarren/uboot-test-hooks/pull/21 >>>>>>>>>> >>>>>>>>>> --- >>>>>>>>>> .travis.yml | 8 ++++++++ >>>>>>>>>> 1 file changed, 8 insertions(+) >>>>>>>>>> >>>>>>>>>> diff --git a/.travis.yml b/.travis.yml >>>>>>>>>> index 6e4b4ba0a34a..e14e6987e4cf 100644 >>>>>>>>>> --- a/.travis.yml >>>>>>>>>> +++ b/.travis.yml >>>>>>>>>> @@ -454,6 +454,14 @@ matrix: >>>>>>>>>> QEMU_TARGET="arm-softmmu" >>>>>>>>>> TEST_PY_ID="--id qemu" >>>>>>>>>> BUILDMAN="^zynq_zc702$" >>>>>>>>>> + - name: "test/py xilinx_versal_virt" >>>>>>>>>> + env: >>>>>>>>>> + - TEST_PY_BD="xilinx_versal_virt" >>>>>>>>>> + TEST_PY_TEST_SPEC="not sleep" >>>>>>>>>> + QEMU_TARGET="aarch64-softmmu" >>>>>>>>>> + QEMU_VERSION="v3.1.0" >>>>>>>>>> + TEST_PY_ID="--id qemu" >>>>>>>>>> + BUILDMAN="^xilinx_versal_virt$" >>>>>>>>> Can we turn on 3.1.0 for all QEMU targets? >>>>>>>> I expected this question. >>>>>>>> First of all I wanted to enable an option to be able to wire whatever >>>>>>>> version. Even sha1 for not released version. >>>>>>>> >>>>>>>> I think we can try to test v3.1.0 qemu version for all boards but I will >>>>>>>> let Tom to decide is we can move or not. >>>>>>>> >>>>>>> Yes, please try to test that. If everything is good, I see no reason >>>>>>> not using it. >>>>>> Yes, I would also like to move everyone up to v3.1.0 and also having the >>>>>> version we use be spelled out will help with future reproducibility. >>>>>> >>>>> v3.1 is not working on vexpress_ca9x4 and vexpress_ca15_tc2. >>>>> take a look at https://travis-ci.org/michalsimek/u-boot/builds/470873127 >>>>> I am happy to keep them on v3.0 and move the rest to v3.1 and let >>>>> vexpress guys to figured out what's wrong with v3.1 and configs around. >>>>> >>>>> What do you think? >>>> The error is: >>>> ---------------------------- Captured stdout setup ----------------------------- >>>> +u-boot-test-reset vexpress_ca15_tc2 qemu >>>> qemu-system-arm: -tftp: invalid option >>>> >>>> And I guess the problem is that by v3.1.0 -tftp has been removed and we >>>> need to use -netdev user,id=net0,tftp=${UBOOT_TRAVIS_BUILD_DIR} like on >>>> the other QEMU-based targets. Can you update uboot-test-hooks (change >>>> .travis.yml to clone your fork of uboot-test-hooks rather than >>>> swarren's) to have the modern syntax? Thanks! >>> I think the correct approach is to update uboot-test-hooks and send PR >>> to Stephen, then apply this 3.1.0 patch on the U-Boot side. We should >>> still have U-Boot's .travis.yml point to swarren's git repo, no? >> Yes, sorry, to be clear, I was just saying how to debug / confirm the >> changes to uboot-test-hooks. > I have created new pull request for fixing that network issue here. > https://github.com/swarren/uboot-test-hooks/pull/22 > > But for vexpress_ca15_tc2 there is still an issue with helloworld efi. > It works on v3.0 but not on v3.1. > > => => tftpboot 80000000 lib/efi_loader/helloworld.efi > smc911x: MAC 52:54:00:12:34:56 > smc911x: detected LAN9118 controller > smc911x: phy initialized > smc911x: MAC 52:54:00:12:34:56 > Using smc911x-0 device > TFTP from server 10.0.2.2; our IP address is 10.0.2.15 > Filename 'lib/efi_loader/helloworld.efi'. > Load address: 0x80000000 > Loading: # > 2 MiB/s > done > Bytes transferred = 2144 (860 hex) > smc911x: MAC 52:54:00:12:34:56 > => => crc32 80000000 $filesize > CRC32 for 80000000 ... 8000085f ==> b76d87c0 > => => bootefi 80000000 > Scanning disks on mmc... > ^[[61;213RCard did not respond to voltage select! > MMC Device 1 not found > MMC Device 2 not found > MMC Device 3 not found > Found 0 disks > WARNING: booting without device tree > ## Starting EFI application at 80000000 ... > Fs+u-boot-test-reset vexpress_ca15_tc2 qemu > > I need to move to something else instead of hacking this target. > > My goal is to get Versal to travis to make sure that none is breaking it > not debugging issues with platform I don't know. > Can I keep this platform on v3.0 and move the rest to 3.1? Alex, any ideas? Can you take a look? Thanks!
Alex: I expect this hook patch is not needed when you qemu patch is applied. Did it go to qemu tree?
Tom: I am proposing this way for upgrade.
Apply this one: https://patchwork.ozlabs.org/patch/1016580/
Bump up qemu version to v3.1.0 with setting up a) QEMU_VERSION="v3.0.0" for vexpress or b) QEMU_VERSION="qemu with Alex fix sha1" for vexpress
Please let me know which way you would like to go and I can create that patches.
Thanks, Michal
On 07. 01. 19 13:28, Tom Rini wrote: > On Mon, Jan 07, 2019 at 01:18:46PM +0100, Michal Simek wrote: >> On 04. 01. 19 4:01, Tom Rini wrote: >>> On Fri, Jan 04, 2019 at 09:29:47AM +0800, Bin Meng wrote: >>>> On Thu, Jan 3, 2019 at 9:39 PM Tom Rini trini@konsulko.com wrote: >>>>> On Thu, Jan 03, 2019 at 09:00:41AM +0100, Michal Simek wrote: >>>>>> On 26. 12. 18 15:29, Tom Rini wrote: >>>>>>> On Thu, Dec 20, 2018 at 04:30:19PM +0800, Bin Meng wrote: >>>>>>>> Hi Michal, >>>>>>>> >>>>>>>> On Thu, Dec 20, 2018 at 4:17 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>>> On 20. 12. 18 9:09, Bin Meng wrote: >>>>>>>>>> On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>>>>> Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. >>>>>>>>>>> >>>>>>>>>>> Signed-off-by: Michal Simek michal.simek@xilinx.com >>>>>>>>>>> --- >>>>>>>>>>> >>>>>>>>>>> Patch needs to be applied when this PR is merged. >>>>>>>>>>> https://github.com/swarren/uboot-test-hooks/pull/21 >>>>>>>>>>> >>>>>>>>>>> --- >>>>>>>>>>> .travis.yml | 8 ++++++++ >>>>>>>>>>> 1 file changed, 8 insertions(+) >>>>>>>>>>> >>>>>>>>>>> diff --git a/.travis.yml b/.travis.yml >>>>>>>>>>> index 6e4b4ba0a34a..e14e6987e4cf 100644 >>>>>>>>>>> --- a/.travis.yml >>>>>>>>>>> +++ b/.travis.yml >>>>>>>>>>> @@ -454,6 +454,14 @@ matrix: >>>>>>>>>>> QEMU_TARGET="arm-softmmu" >>>>>>>>>>> TEST_PY_ID="--id qemu" >>>>>>>>>>> BUILDMAN="^zynq_zc702$" >>>>>>>>>>> + - name: "test/py xilinx_versal_virt" >>>>>>>>>>> + env: >>>>>>>>>>> + - TEST_PY_BD="xilinx_versal_virt" >>>>>>>>>>> + TEST_PY_TEST_SPEC="not sleep" >>>>>>>>>>> + QEMU_TARGET="aarch64-softmmu" >>>>>>>>>>> + QEMU_VERSION="v3.1.0" >>>>>>>>>>> + TEST_PY_ID="--id qemu" >>>>>>>>>>> + BUILDMAN="^xilinx_versal_virt$" >>>>>>>>>> Can we turn on 3.1.0 for all QEMU targets? >>>>>>>>> I expected this question. >>>>>>>>> First of all I wanted to enable an option to be able to wire whatever >>>>>>>>> version. Even sha1 for not released version. >>>>>>>>> >>>>>>>>> I think we can try to test v3.1.0 qemu version for all boards but I will >>>>>>>>> let Tom to decide is we can move or not. >>>>>>>>> >>>>>>>> Yes, please try to test that. If everything is good, I see no reason >>>>>>>> not using it. >>>>>>> Yes, I would also like to move everyone up to v3.1.0 and also having the >>>>>>> version we use be spelled out will help with future reproducibility. >>>>>>> >>>>>> v3.1 is not working on vexpress_ca9x4 and vexpress_ca15_tc2. >>>>>> take a look at https://travis-ci.org/michalsimek/u-boot/builds/470873127 >>>>>> I am happy to keep them on v3.0 and move the rest to v3.1 and let >>>>>> vexpress guys to figured out what's wrong with v3.1 and configs around. >>>>>> >>>>>> What do you think? >>>>> The error is: >>>>> ---------------------------- Captured stdout setup ----------------------------- >>>>> +u-boot-test-reset vexpress_ca15_tc2 qemu >>>>> qemu-system-arm: -tftp: invalid option >>>>> >>>>> And I guess the problem is that by v3.1.0 -tftp has been removed and we >>>>> need to use -netdev user,id=net0,tftp=${UBOOT_TRAVIS_BUILD_DIR} like on >>>>> the other QEMU-based targets. Can you update uboot-test-hooks (change >>>>> .travis.yml to clone your fork of uboot-test-hooks rather than >>>>> swarren's) to have the modern syntax? Thanks! >>>> I think the correct approach is to update uboot-test-hooks and send PR >>>> to Stephen, then apply this 3.1.0 patch on the U-Boot side. We should >>>> still have U-Boot's .travis.yml point to swarren's git repo, no? >>> Yes, sorry, to be clear, I was just saying how to debug / confirm the >>> changes to uboot-test-hooks. >> I have created new pull request for fixing that network issue here. >> https://github.com/swarren/uboot-test-hooks/pull/22 >> >> But for vexpress_ca15_tc2 there is still an issue with helloworld efi. >> It works on v3.0 but not on v3.1. >> >> => => tftpboot 80000000 lib/efi_loader/helloworld.efi >> smc911x: MAC 52:54:00:12:34:56 >> smc911x: detected LAN9118 controller >> smc911x: phy initialized >> smc911x: MAC 52:54:00:12:34:56 >> Using smc911x-0 device >> TFTP from server 10.0.2.2; our IP address is 10.0.2.15 >> Filename 'lib/efi_loader/helloworld.efi'. >> Load address: 0x80000000 >> Loading: # >> 2 MiB/s >> done >> Bytes transferred = 2144 (860 hex) >> smc911x: MAC 52:54:00:12:34:56 >> => => crc32 80000000 $filesize >> CRC32 for 80000000 ... 8000085f ==> b76d87c0 >> => => bootefi 80000000 >> Scanning disks on mmc... >> ^[[61;213RCard did not respond to voltage select! >> MMC Device 1 not found >> MMC Device 2 not found >> MMC Device 3 not found >> Found 0 disks >> WARNING: booting without device tree >> ## Starting EFI application at 80000000 ... >> Fs+u-boot-test-reset vexpress_ca15_tc2 qemu >> >> I need to move to something else instead of hacking this target. >> >> My goal is to get Versal to travis to make sure that none is breaking it >> not debugging issues with platform I don't know. >> Can I keep this platform on v3.0 and move the rest to 3.1? > Alex, any ideas? Can you take a look? Thanks! > Just in case you want to see some logs from travis. https://travis-ci.org/michalsimek/u-boot/builds/475350468
Peter promised he would apply it (he maintains the arm tree in QEMU), but it's not in QEMU's master yet.
v3.0.0 for now, then move everyone over to v3.2.0 (or v3.1.1) when it's out I'd say.
Alex
Thanks, Michal
On 01/07/2019 01:46 PM, Michal Simek wrote: > On 07. 01. 19 13:28, Tom Rini wrote: >> On Mon, Jan 07, 2019 at 01:18:46PM +0100, Michal Simek wrote: >>> On 04. 01. 19 4:01, Tom Rini wrote: >>>> On Fri, Jan 04, 2019 at 09:29:47AM +0800, Bin Meng wrote: >>>>> On Thu, Jan 3, 2019 at 9:39 PM Tom Rini trini@konsulko.com wrote: >>>>>> On Thu, Jan 03, 2019 at 09:00:41AM +0100, Michal Simek wrote: >>>>>>> On 26. 12. 18 15:29, Tom Rini wrote: >>>>>>>> On Thu, Dec 20, 2018 at 04:30:19PM +0800, Bin Meng wrote: >>>>>>>>> Hi Michal, >>>>>>>>> >>>>>>>>> On Thu, Dec 20, 2018 at 4:17 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>>>> On 20. 12. 18 9:09, Bin Meng wrote: >>>>>>>>>>> On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>>>>>> Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. >>>>>>>>>>>> >>>>>>>>>>>> Signed-off-by: Michal Simek michal.simek@xilinx.com >>>>>>>>>>>> --- >>>>>>>>>>>> >>>>>>>>>>>> Patch needs to be applied when this PR is merged. >>>>>>>>>>>> https://github.com/swarren/uboot-test-hooks/pull/21 >>>>>>>>>>>> >>>>>>>>>>>> --- >>>>>>>>>>>> .travis.yml | 8 ++++++++ >>>>>>>>>>>> 1 file changed, 8 insertions(+) >>>>>>>>>>>> >>>>>>>>>>>> diff --git a/.travis.yml b/.travis.yml >>>>>>>>>>>> index 6e4b4ba0a34a..e14e6987e4cf 100644 >>>>>>>>>>>> --- a/.travis.yml >>>>>>>>>>>> +++ b/.travis.yml >>>>>>>>>>>> @@ -454,6 +454,14 @@ matrix: >>>>>>>>>>>> QEMU_TARGET="arm-softmmu" >>>>>>>>>>>> TEST_PY_ID="--id qemu" >>>>>>>>>>>> BUILDMAN="^zynq_zc702$" >>>>>>>>>>>> + - name: "test/py xilinx_versal_virt" >>>>>>>>>>>> + env: >>>>>>>>>>>> + - TEST_PY_BD="xilinx_versal_virt" >>>>>>>>>>>> + TEST_PY_TEST_SPEC="not sleep" >>>>>>>>>>>> + QEMU_TARGET="aarch64-softmmu" >>>>>>>>>>>> + QEMU_VERSION="v3.1.0" >>>>>>>>>>>> + TEST_PY_ID="--id qemu" >>>>>>>>>>>> + BUILDMAN="^xilinx_versal_virt$" >>>>>>>>>>> Can we turn on 3.1.0 for all QEMU targets? >>>>>>>>>> I expected this question. >>>>>>>>>> First of all I wanted to enable an option to be able to wire whatever >>>>>>>>>> version. Even sha1 for not released version. >>>>>>>>>> >>>>>>>>>> I think we can try to test v3.1.0 qemu version for all boards but I will >>>>>>>>>> let Tom to decide is we can move or not. >>>>>>>>>> >>>>>>>>> Yes, please try to test that. If everything is good, I see no reason >>>>>>>>> not using it. >>>>>>>> Yes, I would also like to move everyone up to v3.1.0 and also having the >>>>>>>> version we use be spelled out will help with future reproducibility. >>>>>>>> >>>>>>> v3.1 is not working on vexpress_ca9x4 and vexpress_ca15_tc2. >>>>>>> take a look at https://travis-ci.org/michalsimek/u-boot/builds/470873127 >>>>>>> I am happy to keep them on v3.0 and move the rest to v3.1 and let >>>>>>> vexpress guys to figured out what's wrong with v3.1 and configs around. >>>>>>> >>>>>>> What do you think? >>>>>> The error is: >>>>>> ---------------------------- Captured stdout setup ----------------------------- >>>>>> +u-boot-test-reset vexpress_ca15_tc2 qemu >>>>>> qemu-system-arm: -tftp: invalid option >>>>>> >>>>>> And I guess the problem is that by v3.1.0 -tftp has been removed and we >>>>>> need to use -netdev user,id=net0,tftp=${UBOOT_TRAVIS_BUILD_DIR} like on >>>>>> the other QEMU-based targets. Can you update uboot-test-hooks (change >>>>>> .travis.yml to clone your fork of uboot-test-hooks rather than >>>>>> swarren's) to have the modern syntax? Thanks! >>>>> I think the correct approach is to update uboot-test-hooks and send PR >>>>> to Stephen, then apply this 3.1.0 patch on the U-Boot side. We should >>>>> still have U-Boot's .travis.yml point to swarren's git repo, no? >>>> Yes, sorry, to be clear, I was just saying how to debug / confirm the >>>> changes to uboot-test-hooks. >>> I have created new pull request for fixing that network issue here. >>> https://github.com/swarren/uboot-test-hooks/pull/22 >>> >>> But for vexpress_ca15_tc2 there is still an issue with helloworld efi. >>> It works on v3.0 but not on v3.1. >>> >>> => => tftpboot 80000000 lib/efi_loader/helloworld.efi >>> smc911x: MAC 52:54:00:12:34:56 >>> smc911x: detected LAN9118 controller >>> smc911x: phy initialized >>> smc911x: MAC 52:54:00:12:34:56 >>> Using smc911x-0 device >>> TFTP from server 10.0.2.2; our IP address is 10.0.2.15 >>> Filename 'lib/efi_loader/helloworld.efi'. >>> Load address: 0x80000000 >>> Loading: # >>> 2 MiB/s >>> done >>> Bytes transferred = 2144 (860 hex) >>> smc911x: MAC 52:54:00:12:34:56 >>> => => crc32 80000000 $filesize >>> CRC32 for 80000000 ... 8000085f ==> b76d87c0 >>> => => bootefi 80000000 >>> Scanning disks on mmc... >>> ^[[61;213RCard did not respond to voltage select! >>> MMC Device 1 not found >>> MMC Device 2 not found >>> MMC Device 3 not found >>> Found 0 disks >>> WARNING: booting without device tree >>> ## Starting EFI application at 80000000 ... >>> Fs+u-boot-test-reset vexpress_ca15_tc2 qemu >>> >>> I need to move to something else instead of hacking this target. >>> >>> My goal is to get Versal to travis to make sure that none is breaking it >>> not debugging issues with platform I don't know. >>> Can I keep this platform on v3.0 and move the rest to 3.1? >> Alex, any ideas? Can you take a look? Thanks! >> > Just in case you want to see some logs from travis. > https://travis-ci.org/michalsimek/u-boot/builds/475350468
Then I would like to use that patches I have sent already and enabled verson on v3.1.0 just for versal.
Thanks, Michal
On Mon, Jan 07, 2019 at 05:57:10PM +0100, Alexander Graf wrote: > On 01/07/2019 01:46 PM, Michal Simek wrote: >> On 07. 01. 19 13:28, Tom Rini wrote: >>> On Mon, Jan 07, 2019 at 01:18:46PM +0100, Michal Simek wrote: >>>> On 04. 01. 19 4:01, Tom Rini wrote: >>>>> On Fri, Jan 04, 2019 at 09:29:47AM +0800, Bin Meng wrote: >>>>>> On Thu, Jan 3, 2019 at 9:39 PM Tom Rini trini@konsulko.com wrote: >>>>>>> On Thu, Jan 03, 2019 at 09:00:41AM +0100, Michal Simek wrote: >>>>>>>> On 26. 12. 18 15:29, Tom Rini wrote: >>>>>>>>> On Thu, Dec 20, 2018 at 04:30:19PM +0800, Bin Meng wrote: >>>>>>>>>> Hi Michal, >>>>>>>>>> >>>>>>>>>> On Thu, Dec 20, 2018 at 4:17 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>>>>> On 20. 12. 18 9:09, Bin Meng wrote: >>>>>>>>>>>> On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>>>>>>> Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. >>>>>>>>>>>>> >>>>>>>>>>>>> Signed-off-by: Michal Simek michal.simek@xilinx.com >>>>>>>>>>>>> --- >>>>>>>>>>>>> >>>>>>>>>>>>> Patch needs to be applied when this PR is merged. >>>>>>>>>>>>> https://github.com/swarren/uboot-test-hooks/pull/21 >>>>>>>>>>>>> >>>>>>>>>>>>> --- >>>>>>>>>>>>> .travis.yml | 8 ++++++++ >>>>>>>>>>>>> 1 file changed, 8 insertions(+) >>>>>>>>>>>>> >>>>>>>>>>>>> diff --git a/.travis.yml b/.travis.yml >>>>>>>>>>>>> index 6e4b4ba0a34a..e14e6987e4cf 100644 >>>>>>>>>>>>> --- a/.travis.yml >>>>>>>>>>>>> +++ b/.travis.yml >>>>>>>>>>>>> @@ -454,6 +454,14 @@ matrix: >>>>>>>>>>>>> QEMU_TARGET="arm-softmmu" >>>>>>>>>>>>> TEST_PY_ID="--id qemu" >>>>>>>>>>>>> BUILDMAN="^zynq_zc702$" >>>>>>>>>>>>> + - name: "test/py xilinx_versal_virt" >>>>>>>>>>>>> + env: >>>>>>>>>>>>> + - TEST_PY_BD="xilinx_versal_virt" >>>>>>>>>>>>> + TEST_PY_TEST_SPEC="not sleep" >>>>>>>>>>>>> + QEMU_TARGET="aarch64-softmmu" >>>>>>>>>>>>> + QEMU_VERSION="v3.1.0" >>>>>>>>>>>>> + TEST_PY_ID="--id qemu" >>>>>>>>>>>>> + BUILDMAN="^xilinx_versal_virt$" >>>>>>>>>>>> Can we turn on 3.1.0 for all QEMU targets? >>>>>>>>>>> I expected this question. >>>>>>>>>>> First of all I wanted to enable an option to be able to wire whatever >>>>>>>>>>> version. Even sha1 for not released version. >>>>>>>>>>> >>>>>>>>>>> I think we can try to test v3.1.0 qemu version for all boards but I will >>>>>>>>>>> let Tom to decide is we can move or not. >>>>>>>>>>> >>>>>>>>>> Yes, please try to test that. If everything is good, I see no reason >>>>>>>>>> not using it. >>>>>>>>> Yes, I would also like to move everyone up to v3.1.0 and also having the >>>>>>>>> version we use be spelled out will help with future reproducibility. >>>>>>>>> >>>>>>>> v3.1 is not working on vexpress_ca9x4 and vexpress_ca15_tc2. >>>>>>>> take a look at https://travis-ci.org/michalsimek/u-boot/builds/470873127 >>>>>>>> I am happy to keep them on v3.0 and move the rest to v3.1 and let >>>>>>>> vexpress guys to figured out what's wrong with v3.1 and configs around. >>>>>>>> >>>>>>>> What do you think? >>>>>>> The error is: >>>>>>> ---------------------------- Captured stdout setup ----------------------------- >>>>>>> +u-boot-test-reset vexpress_ca15_tc2 qemu >>>>>>> qemu-system-arm: -tftp: invalid option >>>>>>> >>>>>>> And I guess the problem is that by v3.1.0 -tftp has been removed and we >>>>>>> need to use -netdev user,id=net0,tftp=${UBOOT_TRAVIS_BUILD_DIR} like on >>>>>>> the other QEMU-based targets. Can you update uboot-test-hooks (change >>>>>>> .travis.yml to clone your fork of uboot-test-hooks rather than >>>>>>> swarren's) to have the modern syntax? Thanks! >>>>>> I think the correct approach is to update uboot-test-hooks and send PR >>>>>> to Stephen, then apply this 3.1.0 patch on the U-Boot side. We should >>>>>> still have U-Boot's .travis.yml point to swarren's git repo, no? >>>>> Yes, sorry, to be clear, I was just saying how to debug / confirm the >>>>> changes to uboot-test-hooks. >>>> I have created new pull request for fixing that network issue here. >>>> https://github.com/swarren/uboot-test-hooks/pull/22 >>>> >>>> But for vexpress_ca15_tc2 there is still an issue with helloworld efi. >>>> It works on v3.0 but not on v3.1. >>>> >>>> => => tftpboot 80000000 lib/efi_loader/helloworld.efi >>>> smc911x: MAC 52:54:00:12:34:56 >>>> smc911x: detected LAN9118 controller >>>> smc911x: phy initialized >>>> smc911x: MAC 52:54:00:12:34:56 >>>> Using smc911x-0 device >>>> TFTP from server 10.0.2.2; our IP address is 10.0.2.15 >>>> Filename 'lib/efi_loader/helloworld.efi'. >>>> Load address: 0x80000000 >>>> Loading: # >>>> 2 MiB/s >>>> done >>>> Bytes transferred = 2144 (860 hex) >>>> smc911x: MAC 52:54:00:12:34:56 >>>> => => crc32 80000000 $filesize >>>> CRC32 for 80000000 ... 8000085f ==> b76d87c0 >>>> => => bootefi 80000000 >>>> Scanning disks on mmc... >>>> ^[[61;213RCard did not respond to voltage select! >>>> MMC Device 1 not found >>>> MMC Device 2 not found >>>> MMC Device 3 not found >>>> Found 0 disks >>>> WARNING: booting without device tree >>>> ## Starting EFI application at 80000000 ... >>>> Fs+u-boot-test-reset vexpress_ca15_tc2 qemu >>>> >>>> I need to move to something else instead of hacking this target. >>>> >>>> My goal is to get Versal to travis to make sure that none is breaking it >>>> not debugging issues with platform I don't know. >>>> Can I keep this platform on v3.0 and move the rest to 3.1? >>> Alex, any ideas? Can you take a look? Thanks! >>> >> Just in case you want to see some logs from travis. >> https://travis-ci.org/michalsimek/u-boot/builds/475350468 > > > So the offending change is a new capability in QEMU that exposes EL2 (HYP) > mode on the Cortex-A15 core which this vexpress model uses. There are 2 > steps here IMHO: > > 1) Disable EL2 again by hand. This is easily doable by passing "-cpu > cortex-a15,has_el2=off" to the QEMU command line. That restores the previous > behavior
Ah, sorry, what I was trying to say was "v3.1.0 for everyone but vexpress, v3.0.0 for vexpress_a15" and then "v3.2.0 for everyone once it's out".
If we have to have one exception, we may as well have the broken case be the exception, which is vexpress_15 :).
Alex
On 07.01.19 18:13, Tom Rini wrote: > On Mon, Jan 07, 2019 at 05:57:10PM +0100, Alexander Graf wrote: >> On 01/07/2019 01:46 PM, Michal Simek wrote: >>> On 07. 01. 19 13:28, Tom Rini wrote: >>>> On Mon, Jan 07, 2019 at 01:18:46PM +0100, Michal Simek wrote: >>>>> On 04. 01. 19 4:01, Tom Rini wrote: >>>>>> On Fri, Jan 04, 2019 at 09:29:47AM +0800, Bin Meng wrote: >>>>>>> On Thu, Jan 3, 2019 at 9:39 PM Tom Rini trini@konsulko.com wrote: >>>>>>>> On Thu, Jan 03, 2019 at 09:00:41AM +0100, Michal Simek wrote: >>>>>>>>> On 26. 12. 18 15:29, Tom Rini wrote: >>>>>>>>>> On Thu, Dec 20, 2018 at 04:30:19PM +0800, Bin Meng wrote: >>>>>>>>>>> Hi Michal, >>>>>>>>>>> >>>>>>>>>>> On Thu, Dec 20, 2018 at 4:17 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>>>>>> On 20. 12. 18 9:09, Bin Meng wrote: >>>>>>>>>>>>> On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>>>>>>>> Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. >>>>>>>>>>>>>> >>>>>>>>>>>>>> Signed-off-by: Michal Simek michal.simek@xilinx.com >>>>>>>>>>>>>> --- >>>>>>>>>>>>>> >>>>>>>>>>>>>> Patch needs to be applied when this PR is merged. >>>>>>>>>>>>>> https://github.com/swarren/uboot-test-hooks/pull/21 >>>>>>>>>>>>>> >>>>>>>>>>>>>> --- >>>>>>>>>>>>>> .travis.yml | 8 ++++++++ >>>>>>>>>>>>>> 1 file changed, 8 insertions(+) >>>>>>>>>>>>>> >>>>>>>>>>>>>> diff --git a/.travis.yml b/.travis.yml >>>>>>>>>>>>>> index 6e4b4ba0a34a..e14e6987e4cf 100644 >>>>>>>>>>>>>> --- a/.travis.yml >>>>>>>>>>>>>> +++ b/.travis.yml >>>>>>>>>>>>>> @@ -454,6 +454,14 @@ matrix: >>>>>>>>>>>>>> QEMU_TARGET="arm-softmmu" >>>>>>>>>>>>>> TEST_PY_ID="--id qemu" >>>>>>>>>>>>>> BUILDMAN="^zynq_zc702$" >>>>>>>>>>>>>> + - name: "test/py xilinx_versal_virt" >>>>>>>>>>>>>> + env: >>>>>>>>>>>>>> + - TEST_PY_BD="xilinx_versal_virt" >>>>>>>>>>>>>> + TEST_PY_TEST_SPEC="not sleep" >>>>>>>>>>>>>> + QEMU_TARGET="aarch64-softmmu" >>>>>>>>>>>>>> + QEMU_VERSION="v3.1.0" >>>>>>>>>>>>>> + TEST_PY_ID="--id qemu" >>>>>>>>>>>>>> + BUILDMAN="^xilinx_versal_virt$" >>>>>>>>>>>>> Can we turn on 3.1.0 for all QEMU targets? >>>>>>>>>>>> I expected this question. >>>>>>>>>>>> First of all I wanted to enable an option to be able to wire whatever >>>>>>>>>>>> version. Even sha1 for not released version. >>>>>>>>>>>> >>>>>>>>>>>> I think we can try to test v3.1.0 qemu version for all boards but I will >>>>>>>>>>>> let Tom to decide is we can move or not. >>>>>>>>>>>> >>>>>>>>>>> Yes, please try to test that. If everything is good, I see no reason >>>>>>>>>>> not using it. >>>>>>>>>> Yes, I would also like to move everyone up to v3.1.0 and also having the >>>>>>>>>> version we use be spelled out will help with future reproducibility. >>>>>>>>>> >>>>>>>>> v3.1 is not working on vexpress_ca9x4 and vexpress_ca15_tc2. >>>>>>>>> take a look at https://travis-ci.org/michalsimek/u-boot/builds/470873127 >>>>>>>>> I am happy to keep them on v3.0 and move the rest to v3.1 and let >>>>>>>>> vexpress guys to figured out what's wrong with v3.1 and configs around. >>>>>>>>> >>>>>>>>> What do you think? >>>>>>>> The error is: >>>>>>>> ---------------------------- Captured stdout setup ----------------------------- >>>>>>>> +u-boot-test-reset vexpress_ca15_tc2 qemu >>>>>>>> qemu-system-arm: -tftp: invalid option >>>>>>>> >>>>>>>> And I guess the problem is that by v3.1.0 -tftp has been removed and we >>>>>>>> need to use -netdev user,id=net0,tftp=${UBOOT_TRAVIS_BUILD_DIR} like on >>>>>>>> the other QEMU-based targets. Can you update uboot-test-hooks (change >>>>>>>> .travis.yml to clone your fork of uboot-test-hooks rather than >>>>>>>> swarren's) to have the modern syntax? Thanks! >>>>>>> I think the correct approach is to update uboot-test-hooks and send PR >>>>>>> to Stephen, then apply this 3.1.0 patch on the U-Boot side. We should >>>>>>> still have U-Boot's .travis.yml point to swarren's git repo, no? >>>>>> Yes, sorry, to be clear, I was just saying how to debug / confirm the >>>>>> changes to uboot-test-hooks. >>>>> I have created new pull request for fixing that network issue here. >>>>> https://github.com/swarren/uboot-test-hooks/pull/22 >>>>> >>>>> But for vexpress_ca15_tc2 there is still an issue with helloworld efi. >>>>> It works on v3.0 but not on v3.1. >>>>> >>>>> => => tftpboot 80000000 lib/efi_loader/helloworld.efi >>>>> smc911x: MAC 52:54:00:12:34:56 >>>>> smc911x: detected LAN9118 controller >>>>> smc911x: phy initialized >>>>> smc911x: MAC 52:54:00:12:34:56 >>>>> Using smc911x-0 device >>>>> TFTP from server 10.0.2.2; our IP address is 10.0.2.15 >>>>> Filename 'lib/efi_loader/helloworld.efi'. >>>>> Load address: 0x80000000 >>>>> Loading: # >>>>> 2 MiB/s >>>>> done >>>>> Bytes transferred = 2144 (860 hex) >>>>> smc911x: MAC 52:54:00:12:34:56 >>>>> => => crc32 80000000 $filesize >>>>> CRC32 for 80000000 ... 8000085f ==> b76d87c0 >>>>> => => bootefi 80000000 >>>>> Scanning disks on mmc... >>>>> ^[[61;213RCard did not respond to voltage select! >>>>> MMC Device 1 not found >>>>> MMC Device 2 not found >>>>> MMC Device 3 not found >>>>> Found 0 disks >>>>> WARNING: booting without device tree >>>>> ## Starting EFI application at 80000000 ... >>>>> Fs+u-boot-test-reset vexpress_ca15_tc2 qemu >>>>> >>>>> I need to move to something else instead of hacking this target. >>>>> >>>>> My goal is to get Versal to travis to make sure that none is breaking it >>>>> not debugging issues with platform I don't know. >>>>> Can I keep this platform on v3.0 and move the rest to 3.1? >>>> Alex, any ideas? Can you take a look? Thanks! >>>> >>> Just in case you want to see some logs from travis. >>> https://travis-ci.org/michalsimek/u-boot/builds/475350468 >> >> >> So the offending change is a new capability in QEMU that exposes EL2 (HYP) >> mode on the Cortex-A15 core which this vexpress model uses. There are 2 >> steps here IMHO: >> >> 1) Disable EL2 again by hand. This is easily doable by passing "-cpu >> cortex-a15,has_el2=off" to the QEMU command line. That restores the previous >> behavior > > ... which is one more change to the uboot-test-scripts repo, can someone > please? Thanks.
Yes, please, lets see a v2 with v3.0.0 for just vexpress_ca15_tc2 and v3.1.0 for everyone else, and then we can bump to v3.1.1 / v3.2.0 / whatever globally once the bugfix is in. Thanks!
On Mon, Jan 07, 2019 at 09:15:17PM +0100, Alexander Graf wrote: > > > On 07.01.19 18:13, Tom Rini wrote: >> On Mon, Jan 07, 2019 at 05:57:10PM +0100, Alexander Graf wrote: >>> On 01/07/2019 01:46 PM, Michal Simek wrote: >>>> On 07. 01. 19 13:28, Tom Rini wrote: >>>>> On Mon, Jan 07, 2019 at 01:18:46PM +0100, Michal Simek wrote: >>>>>> On 04. 01. 19 4:01, Tom Rini wrote: >>>>>>> On Fri, Jan 04, 2019 at 09:29:47AM +0800, Bin Meng wrote: >>>>>>>> On Thu, Jan 3, 2019 at 9:39 PM Tom Rini trini@konsulko.com wrote: >>>>>>>>> On Thu, Jan 03, 2019 at 09:00:41AM +0100, Michal Simek wrote: >>>>>>>>>> On 26. 12. 18 15:29, Tom Rini wrote: >>>>>>>>>>> On Thu, Dec 20, 2018 at 04:30:19PM +0800, Bin Meng wrote: >>>>>>>>>>>> Hi Michal, >>>>>>>>>>>> >>>>>>>>>>>> On Thu, Dec 20, 2018 at 4:17 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>>>>>>> On 20. 12. 18 9:09, Bin Meng wrote: >>>>>>>>>>>>>> On Thu, Dec 20, 2018 at 3:55 PM Michal Simek michal.simek@xilinx.com wrote: >>>>>>>>>>>>>>> Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. >>>>>>>>>>>>>>> >>>>>>>>>>>>>>> Signed-off-by: Michal Simek michal.simek@xilinx.com >>>>>>>>>>>>>>> --- >>>>>>>>>>>>>>> >>>>>>>>>>>>>>> Patch needs to be applied when this PR is merged. >>>>>>>>>>>>>>> https://github.com/swarren/uboot-test-hooks/pull/21 >>>>>>>>>>>>>>> >>>>>>>>>>>>>>> --- >>>>>>>>>>>>>>> .travis.yml | 8 ++++++++ >>>>>>>>>>>>>>> 1 file changed, 8 insertions(+) >>>>>>>>>>>>>>> >>>>>>>>>>>>>>> diff --git a/.travis.yml b/.travis.yml >>>>>>>>>>>>>>> index 6e4b4ba0a34a..e14e6987e4cf 100644 >>>>>>>>>>>>>>> --- a/.travis.yml >>>>>>>>>>>>>>> +++ b/.travis.yml >>>>>>>>>>>>>>> @@ -454,6 +454,14 @@ matrix: >>>>>>>>>>>>>>> QEMU_TARGET="arm-softmmu" >>>>>>>>>>>>>>> TEST_PY_ID="--id qemu" >>>>>>>>>>>>>>> BUILDMAN="^zynq_zc702$" >>>>>>>>>>>>>>> + - name: "test/py xilinx_versal_virt" >>>>>>>>>>>>>>> + env: >>>>>>>>>>>>>>> + - TEST_PY_BD="xilinx_versal_virt" >>>>>>>>>>>>>>> + TEST_PY_TEST_SPEC="not sleep" >>>>>>>>>>>>>>> + QEMU_TARGET="aarch64-softmmu" >>>>>>>>>>>>>>> + QEMU_VERSION="v3.1.0" >>>>>>>>>>>>>>> + TEST_PY_ID="--id qemu" >>>>>>>>>>>>>>> + BUILDMAN="^xilinx_versal_virt$" >>>>>>>>>>>>>> Can we turn on 3.1.0 for all QEMU targets? >>>>>>>>>>>>> I expected this question. >>>>>>>>>>>>> First of all I wanted to enable an option to be able to wire whatever >>>>>>>>>>>>> version. Even sha1 for not released version. >>>>>>>>>>>>> >>>>>>>>>>>>> I think we can try to test v3.1.0 qemu version for all boards but I will >>>>>>>>>>>>> let Tom to decide is we can move or not. >>>>>>>>>>>>> >>>>>>>>>>>> Yes, please try to test that. If everything is good, I see no reason >>>>>>>>>>>> not using it. >>>>>>>>>>> Yes, I would also like to move everyone up to v3.1.0 and also having the >>>>>>>>>>> version we use be spelled out will help with future reproducibility. >>>>>>>>>>> >>>>>>>>>> v3.1 is not working on vexpress_ca9x4 and vexpress_ca15_tc2. >>>>>>>>>> take a look at https://travis-ci.org/michalsimek/u-boot/builds/470873127 >>>>>>>>>> I am happy to keep them on v3.0 and move the rest to v3.1 and let >>>>>>>>>> vexpress guys to figured out what's wrong with v3.1 and configs around. >>>>>>>>>> >>>>>>>>>> What do you think? >>>>>>>>> The error is: >>>>>>>>> ---------------------------- Captured stdout setup ----------------------------- >>>>>>>>> +u-boot-test-reset vexpress_ca15_tc2 qemu >>>>>>>>> qemu-system-arm: -tftp: invalid option >>>>>>>>> >>>>>>>>> And I guess the problem is that by v3.1.0 -tftp has been removed and we >>>>>>>>> need to use -netdev user,id=net0,tftp=${UBOOT_TRAVIS_BUILD_DIR} like on >>>>>>>>> the other QEMU-based targets. Can you update uboot-test-hooks (change >>>>>>>>> .travis.yml to clone your fork of uboot-test-hooks rather than >>>>>>>>> swarren's) to have the modern syntax? Thanks! >>>>>>>> I think the correct approach is to update uboot-test-hooks and send PR >>>>>>>> to Stephen, then apply this 3.1.0 patch on the U-Boot side. We should >>>>>>>> still have U-Boot's .travis.yml point to swarren's git repo, no? >>>>>>> Yes, sorry, to be clear, I was just saying how to debug / confirm the >>>>>>> changes to uboot-test-hooks. >>>>>> I have created new pull request for fixing that network issue here. >>>>>> https://github.com/swarren/uboot-test-hooks/pull/22 >>>>>> >>>>>> But for vexpress_ca15_tc2 there is still an issue with helloworld efi. >>>>>> It works on v3.0 but not on v3.1. >>>>>> >>>>>> => => tftpboot 80000000 lib/efi_loader/helloworld.efi >>>>>> smc911x: MAC 52:54:00:12:34:56 >>>>>> smc911x: detected LAN9118 controller >>>>>> smc911x: phy initialized >>>>>> smc911x: MAC 52:54:00:12:34:56 >>>>>> Using smc911x-0 device >>>>>> TFTP from server 10.0.2.2; our IP address is 10.0.2.15 >>>>>> Filename 'lib/efi_loader/helloworld.efi'. >>>>>> Load address: 0x80000000 >>>>>> Loading: # >>>>>> 2 MiB/s >>>>>> done >>>>>> Bytes transferred = 2144 (860 hex) >>>>>> smc911x: MAC 52:54:00:12:34:56 >>>>>> => => crc32 80000000 $filesize >>>>>> CRC32 for 80000000 ... 8000085f ==> b76d87c0 >>>>>> => => bootefi 80000000 >>>>>> Scanning disks on mmc... >>>>>> ^[[61;213RCard did not respond to voltage select! >>>>>> MMC Device 1 not found >>>>>> MMC Device 2 not found >>>>>> MMC Device 3 not found >>>>>> Found 0 disks >>>>>> WARNING: booting without device tree >>>>>> ## Starting EFI application at 80000000 ... >>>>>> Fs+u-boot-test-reset vexpress_ca15_tc2 qemu >>>>>> >>>>>> I need to move to something else instead of hacking this target. >>>>>> >>>>>> My goal is to get Versal to travis to make sure that none is breaking it >>>>>> not debugging issues with platform I don't know. >>>>>> Can I keep this platform on v3.0 and move the rest to 3.1? >>>>> Alex, any ideas? Can you take a look? Thanks! >>>>> >>>> Just in case you want to see some logs from travis. >>>> https://travis-ci.org/michalsimek/u-boot/builds/475350468 >>> >>> >>> So the offending change is a new capability in QEMU that exposes EL2 (HYP) >>> mode on the Cortex-A15 core which this vexpress model uses. There are 2 >>> steps here IMHO: >>> >>> 1) Disable EL2 again by hand. This is easily doable by passing "-cpu >>> cortex-a15,has_el2=off" to the QEMU command line. That restores the previous >>> behavior >> >> ... which is one more change to the uboot-test-scripts repo, can someone >> please? Thanks. > > Done: https://github.com/swarren/uboot-test-hooks/pull/23
I have sent v2 with this. I will push versal enabling via my tree when this is applied. I have tested it on the top of my xilinx changes and things looks good. https://travis-ci.org/michalsimek/u-boot/builds/479836458
Thanks, Michal
This change enables setting up specific Qemu version or sha1 for new targets which are added after (current) v3.0.0 version. This changes is preparation step for adding new Xilinx Versal Virt platform which was merge after v3.0.0.
.travis.yml | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
participants (5)
Alexander Graf
Bin Meng
Michal Simek
Stephen Warren
