[PATCH v2 1/6] rockchip: gpio: rk_gpio: use ROCKCHIP_GPIOS_PER_BANK as divider
The current divider to calculate the bank ID can change. Given the Rockchip TRM not all gpio-banks have 32 pins per bank. The "gpio-ranges" syntax allows multiple items with variable number of pins. Use a constant ROCKCHIP_GPIOS_PER_BANK as fixed divider.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- drivers/gpio/rk_gpio.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/gpio/rk_gpio.c b/drivers/gpio/rk_gpio.c index f7ad4d68..0a2acf18 100644 --- a/drivers/gpio/rk_gpio.c +++ b/drivers/gpio/rk_gpio.c @@ -160,7 +160,7 @@ static int rockchip_gpio_probe(struct udevice *dev) 0, &args); if (!ret || ret != -ENOENT) { uc_priv->gpio_count = args.args[2]; - priv->bank = args.args[1] / args.args[2]; + priv->bank = args.args[1] / ROCKCHIP_GPIOS_PER_BANK; } else { uc_priv->gpio_count = ROCKCHIP_GPIOS_PER_BANK; end = strrchr(dev->name, '@'); -- 2.20.1
The gpio node names are made generic, but without gpio bank ID. Add gpio-ranges to rk3066a-u-boot.dtsi for now till a better method is found. Disable gpio6 as the driver gives an error code on return as status.
Changed V2: disable gpio6 --- arch/arm/dts/rk3066a-u-boot.dtsi | 25 +++++++++++++++++++++++++ 1 file changed, 25 insertions(+)
diff --git a/arch/arm/dts/rk3066a-u-boot.dtsi b/arch/arm/dts/rk3066a-u-boot.dtsi index bc6e609d..06f405ca 100644 --- a/arch/arm/dts/rk3066a-u-boot.dtsi +++ b/arch/arm/dts/rk3066a-u-boot.dtsi @@ -2,3 +2,28 @@
#include "rockchip-u-boot.dtsi" #include "rk3xxx-u-boot.dtsi" + +&gpio0 { + gpio-ranges = <&pinctrl 0 0 32>; +}; + +&gpio1 { + gpio-ranges = <&pinctrl 0 32 32>; +}; + +&gpio2 { + gpio-ranges = <&pinctrl 0 64 32>; +}; + +&gpio3 { + gpio-ranges = <&pinctrl 0 96 32>; +}; + +&gpio4 { + gpio-ranges = <&pinctrl 0 128 32>; +}; + +&gpio6 { + status = "disabled"; +}; + -- 2.20.1
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
+&gpio0 {
- gpio-ranges = <&pinctrl 0 0 32>;
+&gpio1 {
- gpio-ranges = <&pinctrl 0 32 32>;
+&gpio2 {
- gpio-ranges = <&pinctrl 0 64 32>;
+&gpio3 {
- gpio-ranges = <&pinctrl 0 96 32>;
+&gpio4 {
- gpio-ranges = <&pinctrl 0 128 32>;
+&gpio6 {
- status = "disabled";
-- 2.20.1
The gpio node names are made generic, but without gpio bank ID. Add gpio-ranges to rk3188-u-boot.dtsi for now till a better method is found.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- arch/arm/dts/rk3188-u-boot.dtsi | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/dts/rk3188-u-boot.dtsi b/arch/arm/dts/rk3188-u-boot.dtsi index 735776c1..176f9e65 100644 --- a/arch/arm/dts/rk3188-u-boot.dtsi +++ b/arch/arm/dts/rk3188-u-boot.dtsi @@ -12,6 +12,19 @@
&gpio0 { compatible = "rockchip,gpio-bank"; + gpio-ranges = <&pinctrl 0 0 32>; +}; + +&gpio1 { + gpio-ranges = <&pinctrl 0 32 32>; +}; + +&gpio2 { + gpio-ranges = <&pinctrl 0 64 32>; +}; + +&gpio3 { + gpio-ranges = <&pinctrl 0 96 32>; };
&pmu { -- 2.20.1
Thanks, - Kever
+&gpio1 {
+&gpio2 {
+&gpio3 {
&pmu {
-- 2.20.1
Sync rk3066/rk3188 DT files from Linux. This is the state as of linux-next v6.2-rc4. New nfc node for MK808 rk3066a. CRU nodes now have a clock property. To prefend dtoc errors a fixed clock must also be included for tpl/spl in the rk3xxx-u-boot.dtsi file.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- arch/arm/dts/rk3066a-mk808.dts | 27 ++++++++++++++++++++++++++- arch/arm/dts/rk3066a.dtsi | 3 ++- arch/arm/dts/rk3188-radxarock.dts | 24 +++++++++++++----------- arch/arm/dts/rk3188.dtsi | 27 ++++++++++++++++----------- arch/arm/dts/rk3xxx-u-boot.dtsi | 4 ++++ arch/arm/dts/rk3xxx.dtsi | 9 +++++++-- 6 files changed, 68 insertions(+), 26 deletions(-)
diff --git a/arch/arm/dts/rk3066a-mk808.dts b/arch/arm/dts/rk3066a-mk808.dts index 667d57a4..06790f05 100644 --- a/arch/arm/dts/rk3066a-mk808.dts +++ b/arch/arm/dts/rk3066a-mk808.dts @@ -32,7 +32,7 @@ keyup-threshold-microvolt = <2500000>; poll-interval = <100>;
- recovery { + button-recovery { label = "recovery"; linux,code = <KEY_VENDOR>; press-threshold-microvolt = <0>; @@ -157,7 +157,32 @@ pinctrl-0 = <&sd1_clk &sd1_cmd &sd1_bus4>; pinctrl-names = "default"; vmmc-supply = <&vcc_wifi>; + #address-cells = <1>; + #size-cells = <0>; status = "okay"; + + brcmf: wifi@1 { + compatible = "brcm,bcm4329-fmac"; + reg = <1>; + }; +}; + +&nfc { + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + nand@0 { + reg = <0>; + label = "rk-nand"; + nand-bus-width = <8>; + nand-ecc-mode = "hw"; + nand-ecc-step-size = <1024>; + nand-ecc-strength = <40>; + nand-is-boot-medium; + rockchip,boot-blks = <8>; + rockchip,boot-ecc-strength = <24>; + }; };
&pinctrl { diff --git a/arch/arm/dts/rk3066a.dtsi b/arch/arm/dts/rk3066a.dtsi index c25b9695..de9915d9 100644 --- a/arch/arm/dts/rk3066a.dtsi +++ b/arch/arm/dts/rk3066a.dtsi @@ -202,8 +202,9 @@ cru: clock-controller@20000000 { compatible = "rockchip,rk3066a-cru"; reg = <0x20000000 0x1000>; + clocks = <&xin24m>; + clock-names = "xin24m"; rockchip,grf = <&grf>; - #clock-cells = <1>; #reset-cells = <1>; assigned-clocks = <&cru PLL_CPLL>, <&cru PLL_GPLL>, diff --git a/arch/arm/dts/rk3188-radxarock.dts b/arch/arm/dts/rk3188-radxarock.dts index e7138a4a..118deacd 100644 --- a/arch/arm/dts/rk3188-radxarock.dts +++ b/arch/arm/dts/rk3188-radxarock.dts @@ -6,7 +6,6 @@ /dts-v1/; #include <dt-bindings/input/input.h> #include "rk3188.dtsi" -#include "rk3188-radxarock-u-boot.dtsi"
/ { model = "Radxa Rock"; @@ -25,7 +24,7 @@ compatible = "gpio-keys"; autorepeat;
- power { + key-power { gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; linux,code = <KEY_POWER>; label = "GPIO Key Power"; @@ -72,7 +71,7 @@ #sound-dai-cells = <0>; };
- ir_recv: gpio-ir-receiver { + ir_recv: ir-receiver { compatible = "gpio-ir-receiver"; gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; @@ -127,18 +126,21 @@ };
&emac { - status = "okay"; - + phy = <&phy0>; + phy-supply = <&vcc_rmii>; pinctrl-names = "default"; pinctrl-0 = <&emac_xfer>, <&emac_mdio>, <&phy_int>; + status = "okay";
- phy = <&phy0>; - phy-supply = <&vcc_rmii>; + mdio { + #address-cells = <1>; + #size-cells = <0>;
- phy0: ethernet-phy@0 { - reg = <0>; - interrupt-parent = <&gpio3>; - interrupts = <RK_PD2 IRQ_TYPE_LEVEL_LOW>; + phy0: ethernet-phy@0 { + reg = <0>; + interrupt-parent = <&gpio3>; + interrupts = <RK_PD2 IRQ_TYPE_LEVEL_LOW>; + }; }; };
diff --git a/arch/arm/dts/rk3188.dtsi b/arch/arm/dts/rk3188.dtsi index 9a80f83a..44b54af0 100644 --- a/arch/arm/dts/rk3188.dtsi +++ b/arch/arm/dts/rk3188.dtsi @@ -54,7 +54,7 @@ }; };
- cpu0_opp_table: opp_table0 { + cpu0_opp_table: opp-table-0 { compatible = "operating-points-v2"; opp-shared;
@@ -195,8 +195,9 @@ cru: clock-controller@20000000 { compatible = "rockchip,rk3188-cru"; reg = <0x20000000 0x1000>; + clocks = <&xin24m>; + clock-names = "xin24m"; rockchip,grf = <&grf>; - #clock-cells = <1>; #reset-cells = <1>; }; @@ -223,7 +224,7 @@ #size-cells = <1>; ranges;
- gpio0: gpio0@2000a000 { + gpio0: gpio@2000a000 { compatible = "rockchip,rk3188-gpio-bank0"; reg = <0x2000a000 0x100>; interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; @@ -236,7 +237,7 @@ #interrupt-cells = <2>; };
- gpio1: gpio1@2003c000 { + gpio1: gpio@2003c000 { compatible = "rockchip,gpio-bank"; reg = <0x2003c000 0x100>; interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; @@ -249,7 +250,7 @@ #interrupt-cells = <2>; };
- gpio2: gpio2@2003e000 { + gpio2: gpio@2003e000 { compatible = "rockchip,gpio-bank"; reg = <0x2003e000 0x100>; interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; @@ -262,7 +263,7 @@ #interrupt-cells = <2>; };
- gpio3: gpio3@20080000 { + gpio3: gpio@20080000 { compatible = "rockchip,gpio-bank"; reg = <0x20080000 0x100>; interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; @@ -275,15 +276,15 @@ #interrupt-cells = <2>; };
- pcfg_pull_up: pcfg_pull_up { + pcfg_pull_up: pcfg-pull-up { bias-pull-up; };
- pcfg_pull_down: pcfg_pull_down { + pcfg_pull_down: pcfg-pull-down { bias-pull-down; };
- pcfg_pull_none: pcfg_pull_none { + pcfg_pull_none: pcfg-pull-none { bias-disable; };
@@ -378,7 +379,7 @@ rockchip,pins = <2 RK_PD3 1 &pcfg_pull_none>; };
- lcdc1_rgb24: ldcd1-rgb24 { + lcdc1_rgb24: lcdc1-rgb24 { rockchip,pins = <2 RK_PA0 1 &pcfg_pull_none>, <2 RK_PA1 1 &pcfg_pull_none>, <2 RK_PA2 1 &pcfg_pull_none>, @@ -606,7 +607,6 @@
&global_timer { interrupts = <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_EDGE_RISING)>; - status = "disabled"; };
&local_timer { @@ -641,6 +641,11 @@ &grf { compatible = "rockchip,rk3188-grf", "syscon", "simple-mfd";
+ io_domains: io-domains { + compatible = "rockchip,rk3188-io-voltage-domain"; + status = "disabled"; + }; + usbphy: usbphy { compatible = "rockchip,rk3188-usb-phy"; #address-cells = <1>; diff --git a/arch/arm/dts/rk3xxx-u-boot.dtsi b/arch/arm/dts/rk3xxx-u-boot.dtsi index e67432fb..c77d1fae 100644 --- a/arch/arm/dts/rk3xxx-u-boot.dtsi +++ b/arch/arm/dts/rk3xxx-u-boot.dtsi @@ -33,3 +33,7 @@ &uart2 { clock-frequency = <24000000>; }; + +&xin24m { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/rk3xxx.dtsi b/arch/arm/dts/rk3xxx.dtsi index 616a828e..cb4e42ed 100644 --- a/arch/arm/dts/rk3xxx.dtsi +++ b/arch/arm/dts/rk3xxx.dtsi @@ -76,6 +76,13 @@ reg = <0x1013c200 0x20>; interrupts = <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_EDGE_RISING)>; clocks = <&cru CORE_PERI>; + status = "disabled"; + /* The clock source and the sched_clock provided by the arm_global_timer + * on Rockchip rk3066a/rk3188 are quite unstable because their rates + * depend on the CPU frequency. + * Keep the arm_global_timer disabled in order to have the + * DW_APB_TIMER (rk3066a) or ROCKCHIP_TIMER (rk3188) selected by default. + */ };
local_timer: local-timer@1013c600 { @@ -186,8 +193,6 @@ compatible = "snps,arc-emac"; reg = <0x10204000 0x3c>; interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>;
-- 2.20.1
Thanks, - Kever
recovery {
- #size-cells = <0>; status = "okay";
- brcmf: wifi@1 {
reg = <1>;
+&nfc {
#size-cells = <0>;
status = "okay";
nand@0 {
reg = <0>;
label = "rk-nand";
&pinctrl {
clocks = <&xin24m>;
rockchip,grf = <&grf>;clock-names = "xin24m";
power {
- ir_recv: ir-receiver { compatible = "gpio-ir-receiver"; gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; pinctrl-names = "default";
&emac {
- status = "okay";
- phy = <&phy0>;
- phy-supply = <&vcc_rmii>; pinctrl-names = "default"; pinctrl-0 = <&emac_xfer>, <&emac_mdio>, <&phy_int>;
- status = "okay";
- phy = <&phy0>;
- mdio {
#size-cells = <0>;
reg = <0>;
reg = <0>;
- cpu0_opp_table: opp-table-0 { compatible = "operating-points-v2"; opp-shared;
clocks = <&xin24m>;
};pcfg_pull_up: pcfg-pull-up { bias-pull-up;
};pcfg_pull_down: pcfg-pull-down { bias-pull-down;
};pcfg_pull_none: pcfg-pull-none { bias-disable;
@@ -606,7 +607,6 @@
&local_timer {
- io_domains: io-domains {
- usbphy: usbphy { compatible = "rockchip,rk3188-usb-phy"; #address-cells = <1>;
+&xin24m {
- u-boot,dm-pre-reloc;
#size-cells = <0>;
-- 2.20.1
Currently the Rockchip rk3066a u-boot-tpl.bin file needs to add the characters "RK30", while the other SoCs replace the first 4 bytes. Bring this in line with the rest by lowering CONFIG_TPL_TEXT_BASE and update rockchip.rst instructions.
Changed V2: use lower case hex --- configs/mk808_defconfig | 2 +- doc/board/rockchip/rockchip.rst | 7 +++---- 2 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/configs/mk808_defconfig b/configs/mk808_defconfig index c080706d..5a264eb9 100644 --- a/configs/mk808_defconfig +++ b/configs/mk808_defconfig @@ -18,7 +18,7 @@ CONFIG_SPL_TEXT_BASE=0x60000000 CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3066=y # CONFIG_ROCKCHIP_STIMER is not set -CONFIG_TPL_TEXT_BASE=0x10080C04 +CONFIG_TPL_TEXT_BASE=0x10080c00 CONFIG_TPL_STACK=0x1008FFFF CONFIG_TARGET_MK808=y CONFIG_SPL_STACK_R_ADDR=0x70000000 diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index b5563b8f..7d903946 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -380,9 +380,8 @@ Program with commands in a bash script ./flash.sh:
#!/bin/sh
- printf "RK30" > tplspl.bin - dd if=u-boot-tpl.bin >> tplspl.bin - truncate -s %2048 tplspl.bin + printf "RK30" | dd conv=notrunc bs=4 count=1 of=u-boot-tpl.bin + truncate -s %2048 u-boot-tpl.bin truncate -s %2048 u-boot-spl.bin ../tools/boot_merger --verbose config-flash.ini ../tools/upgrade_tool ul ./RK30xxLoader_uboot.bin @@ -406,7 +405,7 @@ config-flash.ini: NUM=2 LOADER1=FlashData LOADER2=FlashBoot - FlashData=tplspl.bin + FlashData=u-boot-tpl.bin FlashBoot=u-boot-spl.bin [OUTPUT] PATH=RK30xxLoader_uboot.bin -- 2.20.1
Thanks, - Kever
#!/bin/sh
-- 2.20.1
Enable usb support in the mk808_defconfig.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- configs/mk808_defconfig | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/configs/mk808_defconfig b/configs/mk808_defconfig index 5a264eb9..b7dcd163 100644 --- a/configs/mk808_defconfig +++ b/configs/mk808_defconfig @@ -53,6 +53,9 @@ CONFIG_SYS_PBSIZE=276 # CONFIG_BOOTM_VXWORKS is not set CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y @@ -78,6 +81,7 @@ CONFIG_TPL_SYSCON=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_TPL_CLK=y +CONFIG_FASTBOOT_BUF_ADDR=0x80000000 CONFIG_ROCKCHIP_GPIO=y # CONFIG_SPL_DM_I2C is not set CONFIG_LED=y @@ -106,6 +110,12 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_TPL_TIMER=y CONFIG_DESIGNWARE_APB_TIMER=y +CONFIG_USB=y +CONFIG_USB_DWC2=y +CONFIG_ROCKCHIP_USB2_PHY=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_FUNCTION_ROCKUSB=y CONFIG_SPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y # CONFIG_TPL_OF_LIBFDT is not set -- 2.20.1
Thanks, - Kever
2.20.1
Thanks, - Kever
} else { uc_priv->gpio_count = ROCKCHIP_GPIOS_PER_BANK; end = strrchr(dev->name, '@');priv->bank = args.args[1] / ROCKCHIP_GPIOS_PER_BANK;
-- 2.20.1
Johan Jonker
Kever Yang
