[PATCH] net: Fix the displayed value of bytes transferred
In the case of NETLOOP_SUCCESS, the decimal value of the u32 variable "net_boot_file_size" is printed using "%d", resulting in negative values being reported for large file sizes. Fix this by using "%lu" to print the decimal value corresponding to the bytes transferred.
Fixes: 1411157d8578 ("net: cosmetic: Fixup var names related to boot file") Signed-off-by: Siddharth Vadapalli s-vadapalli@ti.com --- net/net.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/net.c b/net/net.c index 43abbac7c3..7aaeafc247 100644 --- a/net/net.c +++ b/net/net.c @@ -716,7 +716,7 @@ restart: case NETLOOP_SUCCESS: net_cleanup_loop(); if (net_boot_file_size > 0) { - printf("Bytes transferred = %d (%x hex)\n", + printf("Bytes transferred = %lu (%x hex)\n", net_boot_file_size, net_boot_file_size); env_set_hex("filesize", net_boot_file_size); env_set_hex("fileaddr", image_load_addr);
Siddharth,
'net_boot_file_size' is of type u32. Using "%lu" will throw a warning for this. As per [0], format specifier for 'unsigned int' is "%d, %x'.
You could perhaps change the data type of 'net_boot_file_size' to 'ulong' as well.
[0] - https://u-boot.readthedocs.io/en/latest/develop/printf.html
Ravi,
On 10/08/23 17:00, Ravi Gunasekaran wrote:
Siddharth,
The issue here isn't the size of the variable itself, but the format specifier. For large file sizes, the hex value printed for the variable is correct, but the decimal value is negative.
On Fri, Aug 11, 2023 at 10:49:23AM +0530, Siddharth Vadapalli wrote:
Ravi,
Siddharth,
Uh, maybe I'm just missing something, but I think there's two things. First, this should be "%u" for "unsigned decimal". Second, doc/develop/printf.rst needs to be fixed since: int %d, %x unsigned int %d, %x
Should is wrong and should say %u, %x, because, well, that's what would be correct, yes?
Hello Tom,
Ravi,
Siddharth,
Thank you for reviewing the patch. Yes, %u works well and can print u32 variable accurately. I tested it for 0xffffffff. %d prints -1 for the same. So, %lu isn't necessary and %u is sufficient. I will replace %lu with %u and post the v2 patch. Additionally, I will include a patch in the v2 series to update the Documentation as pointed out by you.
On 14/08/23 10:06, Siddharth Vadapalli wrote:
Hello Tom,
Ravi,
I have posted the v2 series at: https://patchwork.ozlabs.org/project/uboot/list/?series=368661&state=%2A...
Ravi Gunasekaran
Siddharth Vadapalli
