[PATCH v6 0/6] rockchip: Add Binman support
This is v6 set for Binman support in rockchip, [1] here is previous patchset.
This series add single boot image with binman for arm32 and pad_cat for arm64 rockchip platforms both TPL + SPL and SPL-alone targets.
Changes for v6: - drop idbloader.img filename change patch - update rockchip.rst to include, rockchip TPL, SPI boot as TODO Changes for v5: - collect kever review tag - drop idbloader.img from clean target Changes for v4: - support all rockchip platforms - add new patches for dtsi changes - update documentation - format proper commit message - rebase on master Changes for v3: - rebase on master - add binman for rk3288, rk3328, rk3368, rk3399 - added rst documentation for rockchip Changes for v2: - Add few clean target patches - update bl31.elf env handling code, with logging - support puma itb, via BL31 and PMUM0 env - enable BUILD_TARGET for ROCKCHIP_RK3399
[1] https://patchwork.ozlabs.org/cover/1216263/
Any inputs? Jagan.
Jagan Teki (6): Makefile: Add rockchip image type Makefile: rockchip: Suffix platform type with tpl name Makefile: rockchip: Support SPL-alone mkimage arm: dts: rk3036: Add rk3036-u-boot.dtsi rockchip: Add Single boot image (with binman, pad_cat) doc: boards: Add rockchip documentation
Makefile | 36 ++++++-- arch/arm/Kconfig | 1 + arch/arm/dts/rk3036-sdk-u-boot.dtsi | 2 + arch/arm/dts/rk3036-u-boot.dtsi | 6 ++ arch/arm/dts/rk3288-u-boot.dtsi | 2 + arch/arm/dts/rockchip-u-boot.dtsi | 21 +++++ doc/board/rockchip/index.rst | 10 +++ doc/board/rockchip/rockchip.rst | 130 ++++++++++++++++++++++++++++ include/configs/rockchip-common.h | 3 + 9 files changed, 206 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/rk3036-u-boot.dtsi create mode 100644 arch/arm/dts/rockchip-u-boot.dtsi create mode 100644 doc/board/rockchip/index.rst create mode 100644 doc/board/rockchip/rockchip.rst
Add rockchip image type support. right now the image type marked with rksd, So create image type variable with required image type like rksd or rkspi.
Cc: Kever Yang kever.yang@rock-chips.com Cc: Matwey V. Kornilov matwey.kornilov@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Makefile | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index e20a206239..9998d238f3 100644 --- a/Makefile +++ b/Makefile @@ -1374,7 +1374,15 @@ u-boot-with-spl.bin: $(SPL_IMAGE) $(SPL_PAYLOAD) FORCE $(call if_changed,pad_cat)
ifeq ($(CONFIG_ARCH_ROCKCHIP),y) -MKIMAGEFLAGS_u-boot-tpl.img = -n $(CONFIG_SYS_SOC) -T rksd + +# rockchip image type +ifeq ($(CONFIG_SPI_FLASH_SUPPORT),y) +ROCKCHIP_IMG_TYPE := rkspi +else +ROCKCHIP_IMG_TYPE := rksd +endif + +MKIMAGEFLAGS_u-boot-tpl.img = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) tpl/u-boot-tpl.img: tpl/u-boot-tpl.bin FORCE $(call if_changed,mkimage) idbloader.img: tpl/u-boot-tpl.img spl/u-boot-spl.bin FORCE
Most of the platforms uses the platform type on their boot stage image naming conventions in makefile like,
u-boot-x86-start16-tpl.bin - x86 start16 TPL bin u-boot-spl-mtk.bin - Mediatek SPL bin
This would help to understand the users to what that particular image belongs to? and less confused.
On that note, suffix platform type rockchip for existing u-boot-tpl.img so now it become u-boot-tpl-rockchip.bin
Also, bin is more conventional way to include it on tools like binman, pad_cat etc in future patches.
Note: usage of platform type doesn't follow consistent order as of now.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Makefile | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/Makefile b/Makefile index 9998d238f3..e519103be4 100644 --- a/Makefile +++ b/Makefile @@ -1382,10 +1382,10 @@ else ROCKCHIP_IMG_TYPE := rksd endif
-MKIMAGEFLAGS_u-boot-tpl.img = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) -tpl/u-boot-tpl.img: tpl/u-boot-tpl.bin FORCE +MKIMAGEFLAGS_u-boot-tpl-rockchip.bin = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) +tpl/u-boot-tpl-rockchip.bin: tpl/u-boot-tpl.bin FORCE $(call if_changed,mkimage) -idbloader.img: tpl/u-boot-tpl.img spl/u-boot-spl.bin FORCE +idbloader.img: tpl/u-boot-tpl-rockchip.bin spl/u-boot-spl.bin FORCE $(call if_changed,cat) endif
Add SPL-alone mkimage tooling support via Makefile for few platforms or boards used in rockchip family.
With this users would get rid of explicitly creating mkimage tool for rockchip rksd or rkspi boot modes.
diff --git a/Makefile b/Makefile index e519103be4..d8a0f68883 100644 --- a/Makefile +++ b/Makefile @@ -908,7 +908,7 @@ ifeq ($(CONFIG_MPC85xx)$(CONFIG_OF_SEPARATE),yy) ALL-y += u-boot-with-dtb.bin endif
-ifeq ($(CONFIG_ARCH_ROCKCHIP)$(CONFIG_SPL)$(CONFIG_TPL),yyy) +ifeq ($(CONFIG_ARCH_ROCKCHIP)$(CONFIG_SPL),yy) ALL-y += idbloader.img endif
@@ -1382,11 +1382,19 @@ else ROCKCHIP_IMG_TYPE := rksd endif
+# TPL + SPL +ifeq ($(CONFIG_SPL)$(CONFIG_TPL),yy) MKIMAGEFLAGS_u-boot-tpl-rockchip.bin = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) tpl/u-boot-tpl-rockchip.bin: tpl/u-boot-tpl.bin FORCE $(call if_changed,mkimage) idbloader.img: tpl/u-boot-tpl-rockchip.bin spl/u-boot-spl.bin FORCE $(call if_changed,cat) +else +MKIMAGEFLAGS_idbloader.img = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) +idbloader.img: spl/u-boot-spl.bin FORCE + $(call if_changed,mkimage) +endif + endif
ifeq ($(CONFIG_ARCH_LPC32XX)$(CONFIG_SPL),yy)
Add U-Boot specific dtsi file for rk3036 SoC. This would help to add U-Boot specific dts nodes, properties which are common across rk3036.
Right now, the file is empty, will add required changes in future patches.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- arch/arm/dts/rk3036-sdk-u-boot.dtsi | 2 ++ arch/arm/dts/rk3036-u-boot.dtsi | 4 ++++ 2 files changed, 6 insertions(+) create mode 100644 arch/arm/dts/rk3036-u-boot.dtsi
diff --git a/arch/arm/dts/rk3036-sdk-u-boot.dtsi b/arch/arm/dts/rk3036-sdk-u-boot.dtsi index 6f15f4a8ec..754800c6e6 100644 --- a/arch/arm/dts/rk3036-sdk-u-boot.dtsi +++ b/arch/arm/dts/rk3036-sdk-u-boot.dtsi @@ -1,3 +1,5 @@ +#include "rk3036-u-boot.dtsi" + &uart2 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3036-u-boot.dtsi b/arch/arm/dts/rk3036-u-boot.dtsi new file mode 100644 index 0000000000..1e7d079315 --- /dev/null +++ b/arch/arm/dts/rk3036-u-boot.dtsi @@ -0,0 +1,4 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */
All rockchip platforms support TPL or SPL-based bootloader in mainline with U-Boot proper as final stage. For each stage we need to burn the image on to flash with respective offsets.
This patch creates a single boot image component using - binman, for arm32 rockchip platforms - pad_cat, for arm64 rockchip platforms.
This would help users to get rid of burning different boot stage images.
The new image called 'u-boot-rockchip.bin' which can burn into flash like:
₹ sudo dd if=u-boot-rockchip.bin of=/dev/sda seek=64
This would support all rockchip platforms, except rk3128 since it doesn't support for SPL yet.
Cc: Kever Yang kever.yang@rock-chips.com Cc: Matwey V. Kornilov matwey.kornilov@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Makefile | 14 ++++++++++++-- arch/arm/Kconfig | 1 + arch/arm/dts/rk3036-u-boot.dtsi | 2 ++ arch/arm/dts/rk3288-u-boot.dtsi | 2 ++ arch/arm/dts/rockchip-u-boot.dtsi | 21 +++++++++++++++++++++ include/configs/rockchip-common.h | 3 +++ 6 files changed, 41 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/rockchip-u-boot.dtsi
diff --git a/Makefile b/Makefile index d8a0f68883..cdd3eb4614 100644 --- a/Makefile +++ b/Makefile @@ -909,7 +909,7 @@ ALL-y += u-boot-with-dtb.bin endif
ifeq ($(CONFIG_ARCH_ROCKCHIP)$(CONFIG_SPL),yy) -ALL-y += idbloader.img +ALL-y += u-boot-rockchip.bin endif
LDFLAGS_u-boot += $(LDFLAGS_FINAL) @@ -1395,7 +1395,17 @@ idbloader.img: spl/u-boot-spl.bin FORCE $(call if_changed,mkimage) endif
-endif +ifeq ($(CONFIG_ARM64),) +u-boot-rockchip.bin: idbloader.img u-boot.img FORCE + $(call if_changed,binman) +else +OBJCOPYFLAGS_u-boot-rockchip.bin = -I binary -O binary \ + --pad-to=$(CONFIG_SPL_PAD_TO) --gap-fill=0xff +u-boot-rockchip.bin: idbloader.img u-boot.itb FORCE + $(call if_changed,pad_cat) +endif # CONFIG_ARM64 + +endif # CONFIG_ARCH_ROCKCHIP
ifeq ($(CONFIG_ARCH_LPC32XX)$(CONFIG_SPL),yy) MKIMAGEFLAGS_lpc32xx-spl.img = -T lpc32xximage -a $(CONFIG_SPL_TEXT_BASE) diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f9dab073ea..7bd99ba3bb 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1590,6 +1590,7 @@ config ARCH_STM32MP config ARCH_ROCKCHIP bool "Support Rockchip SoCs" select BLK + select BINMAN if !ARM64 select DM select DM_GPIO select DM_I2C diff --git a/arch/arm/dts/rk3036-u-boot.dtsi b/arch/arm/dts/rk3036-u-boot.dtsi index 1e7d079315..41ac054b81 100644 --- a/arch/arm/dts/rk3036-u-boot.dtsi +++ b/arch/arm/dts/rk3036-u-boot.dtsi @@ -2,3 +2,5 @@ /* * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com */ + +#include "rockchip-u-boot.dtsi" diff --git a/arch/arm/dts/rk3288-u-boot.dtsi b/arch/arm/dts/rk3288-u-boot.dtsi index 3f00a3b6d3..6d31735362 100644 --- a/arch/arm/dts/rk3288-u-boot.dtsi +++ b/arch/arm/dts/rk3288-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright (C) 2019 Rockchip Electronics Co., Ltd */
+#include "rockchip-u-boot.dtsi" + / { chosen { u-boot,spl-boot-order = \ diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi new file mode 100644 index 0000000000..a2559e2db0 --- /dev/null +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include <config.h> + +/ { + binman { + filename = "u-boot-rockchip.bin"; + pad-byte = <0xff>; + + blob { + filename = "idbloader.img"; + }; + + u-boot-img { + offset = <CONFIG_SPL_PAD_TO>; + }; + }; +}; diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index 68e1105a4b..b55e09a9ca 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -9,6 +9,9 @@
#define CONFIG_SYS_NS16550_MEM32
+/* ((CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR - 64) * 512) */ +#define CONFIG_SPL_PAD_TO 8355840 + #ifndef CONFIG_SPL_BUILD
/* First try to boot from SD (index 0), then eMMC (index 1) */
Hi Jagan,
This patch seems like will cause error on rock_defconfig, could you take a look:
binman: Device tree 'u-boot.dtb' does not have a 'binman' node Makefile:1400: recipe for target 'u-boot-rockchip.bin' failed
Thanks,
- Kever
- $(call if_changed,binman)
- --pad-to=$(CONFIG_SPL_PAD_TO) --gap-fill=0xff
- $(call if_changed,pad_cat)
- select BINMAN if !ARM64 select DM select DM_GPIO select DM_I2C
- Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com
- Copyright (C) 2019 Rockchip Electronics Co., Ltd
- / { chosen { u-boot,spl-boot-order = \
- binman {
pad-byte = <0xff>;
blob {
u-boot-img {
Hi Jagan,
How about adding the initial 64 blocks into the image too, so the seek isn't needed?
пт, 10 янв. 2020 г. в 12:39, Simon Glass sjg@chromium.org:
Hi Jagan,
It will break partition tables on the target device.
Rockchip has documentation file, doc/README.rockchip but which is not so readable to add or understand the existing contents. Even the format that support is legacy readme in U-Boot.
Add rockchip specific documentation file using new rst format, which describes the information about Rockchip supported boards and it's usage steps.
Added minimal information about rk3288, rk3328, rk3368 and rk3399 boards and usage. This would indeed updated further based on the requirements and updates.
Cc: Kever Yang kever.yang@rock-chips.com Cc: Matwey V. Kornilov matwey.kornilov@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- doc/board/rockchip/index.rst | 10 +++ doc/board/rockchip/rockchip.rst | 130 ++++++++++++++++++++++++++++++++ 2 files changed, 140 insertions(+) create mode 100644 doc/board/rockchip/index.rst create mode 100644 doc/board/rockchip/rockchip.rst
diff --git a/doc/board/rockchip/index.rst b/doc/board/rockchip/index.rst new file mode 100644 index 0000000000..0c377e9bbb --- /dev/null +++ b/doc/board/rockchip/index.rst @@ -0,0 +1,10 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + +Rockchip +======== + +.. toctree:: + :maxdepth: 2 + + rockchip diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst new file mode 100644 index 0000000000..6c34f1ab99 --- /dev/null +++ b/doc/board/rockchip/rockchip.rst @@ -0,0 +1,130 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + +ROCKCHIP +======== + +About this +---------- + +This document describes the information about Rockchip supported boards +and it's usage steps. + +Rockchip boards +--------------- + +Rockchip is SoC solutions provider for tablets & PCs, streaming media +TV boxes, AI audio & vision, IoT hardware. + +A wide range of Rockchip SoCs with associated boardsare supported in +mainline U-Boot. + +List of mainline supported rockchip boards: + +* rk3288 + - Evb-RK3288 + - Firefly-RK3288 + - mqmaker MiQi + - Phytec RK3288 PCM-947 + - PopMetal-RK3288 + - Radxa Rock 2 Square + - Tinker-RK3288 + - Google Jerry + - Google Mickey + - Google Minnie + - Google Speedy + - Amarula Vyasa-RK3288 +* rk3328 + - Rockchip RK3328 EVB + - Pine64 Rock64 +* rk3368 + - GeekBox + - PX5 EVB + - Rockchip sheep board + - Theobroma Systems RK3368-uQ7 SoM +* rk3399 + - 96boards RK3399 Ficus + - 96boards Rock960 + - Firefly-RK3399 Board + - Firefly ROC-RK3399-PC Board + - FriendlyElec NanoPC-T4 + - FriendlyElec NanoPi M4 + - FriendlyARM NanoPi NEO4 + - Google Bob + - Khadas Edge + - Khadas Edge-Captain + - Khadas Edge-V + - Orange Pi RK3399 Board + - Pine64 RockPro64 + - Radxa ROCK Pi 4 + - Rockchip RK3399 Evaluation Board + - Theobroma Systems RK3399-Q7 SoM + +Building +-------- + +TF-A +^^^^ + +TF-A would require to build for ARM64 Rockchip SoCs platforms. + +To build TF-A:: + + git clone https://github.com/ARM-software/arm-trusted-firmware.git + cd arm-trusted-firmware + make realclean + make CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399 + +Specify the PLAT= with desired rockchip platform to build TF-A for. + +U-Boot +^^^^^^ + +To build rk3328 boards:: + + export BL31=/path/to/arm-trusted-firmware/to/bl31.elf + make evb-rk3328_defconfig + make + +To build rk3288 boards:: + + make evb-rk3288_defconfig + make + +To build rk3368 boards:: + + export BL31=/path/to/arm-trusted-firmware/to/bl31.elf + make evb-px5_defconfig + make + +To build rk3399 boards:: + + export BL31=/path/to/arm-trusted-firmware/to/bl31.elf + make evb-rk3399_defconfig + make + +Flashing +-------- + +SD Card +^^^^^^^ + +All rockchip platforms, except rk3128 (which doesn't use SPL) are now +supporting single boot image using binman and pad_cat. + +To write an image that boots from an SD card (assumed to be /dev/sda):: + + sudo dd if=u-boot-rockchip.bin of=/dev/sda seek=64 + sync + +TODO +---- + +- Add rockchip idbloader image building +- Add rockchip TPL image building +- Document SPI flash boot +- Describe steps for eMMC flashing +- Add missing SoC's with it boards list + +.. Jagan Teki jagan@amarulasolutions.com +.. Sat Jan 4 14:00:54 IST 2020
Thanks, - Kever
+Rockchip +========
+.. toctree::
- :maxdepth: 2
- rockchip
+ROCKCHIP +========
+* rk3288
- Evb-RK3288
- Firefly-RK3288
- mqmaker MiQi
- PopMetal-RK3288
- Tinker-RK3288
- Google Jerry
- Google Mickey
- Google Minnie
- Google Speedy
+* rk3328
- Pine64 Rock64
+* rk3368
- GeekBox
- PX5 EVB
+* rk3399
- 96boards Rock960
- Google Bob
- Khadas Edge
- Khadas Edge-V
- Pine64 RockPro64
- Radxa ROCK Pi 4
+Building +--------
+TF-A +^^^^
+To build TF-A::
make realclean
+U-Boot +^^^^^^
make
make
make
make
+Flashing +--------
+SD Card +^^^^^^^
sync
+TODO +----
Add Wadim in cc,
Hi Jagan,
After this patch set apply, the phycore-rk3288 board's SPL size is overflow:
arm: + phycore-rk3288 +Error: SPL image is too large (size 0x9000 than 0x8000) +Error: Bad parameters for image type
Maybe we need to enable the TPL for this board? @Wadim
Thanks,
- Kever
Changes for v6:
Changes for v5:
Changes for v4:
- rebase on master
Changes for v3:
- rebase on master
Changes for v2:
Any inputs? Jagan.
On 07.01.20 10:59, Kever Yang wrote:
Add Wadim in cc,
Hi Jagan,
I would like it to keep the SPL for the phyCORE board. In this thread [1] I pointed out that you can drop the phycore_init() function that was sometimes blowing up the size of the phyCORE SPL image. So if there is no new other feature that increases the SPL size, we can just remove the code and the SPL should fit again. If you like I can take a look at this next week.
[1] https://lists.denx.de/pipermail/u-boot/2019-July/378112.html
Regards, Wadim
Thanks,
- Kever
Changes for v6:
Changes for v5:
Changes for v4:
- rebase on master
Changes for v3:
- rebase on master
Changes for v2:
Any inputs? Jagan.
Add Wadim in cc,
Hi Jagan,
If not, maybe we can disable BINMAN for this board? I'm sure it can revert since there would be a need to move TPL in future.
Add Wadim in cc,
Hi Jagan,
This won't help much, but one possibility is to use SPL_OF_PLATDATA (I've verified). Can you help us to try as quickly as possible? or do you want us to try?
Jagan.
Hi Jagan,
Add Wadim in cc,
Hi Jagan,
Or we can simply disable CONFIG_SPL_I2C_SUPPORT and CONFIG_SPL_POWER_SUPPORT in the phycore-rk3288_defconfig. What do you want me to do now? Testing your patches with SPL_OF_PLATDATA=y on our board? If so, I can help you next week with testing.
On Thu, Jan 9, 2020 at 8:58 PM Wadim Egorov w.egorov@phytec.de wrote:
Hi Jagan,
Add Wadim in cc,
Hi Jagan,
This seems fixed, sent the patches please test the same, thanks!
On Tue, 7 Jan 2020 at 22:59, Kever Yang kever.yang@rock-chips.com wrote:
Add Wadim in cc,
Hi Jagan,
We should look at why it is too large. Enabling BINMAN should not increase the code size of SPL, so perhaps there is a bug?
participants (5)
Jagan Teki
Kever Yang
Matwey V. Kornilov
Wadim Egorov
