[U-Boot] [PATCH] ppc/85xx: Add a structure defn for PIXIS registers
The various boards that have PIXIS FPGAs have slightly different register definitions, however there is some common functionality (like reset, ICS307 clk control, etc) that can be shared.
The struct definition exists for MPC8536DS, MPC8544DS, MPC8572DS, MPC8610HPCD, and MPC8641HPCN boards.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/common/pixis.h | 182 ++++++++++++++++++++++++++++++++++++++++ 1 files changed, 182 insertions(+), 0 deletions(-) create mode 100644 board/freescale/common/pixis.h
diff --git a/board/freescale/common/pixis.h b/board/freescale/common/pixis.h new file mode 100644 index 0000000..bc57d42 --- /dev/null +++ b/board/freescale/common/pixis.h @@ -0,0 +1,182 @@ +/* + * Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef __PIXIS_H_ +#define __PIXIS_H_ 1 + +/* PIXIS register set. */ +#if defined(CONFIG_MPC8536DS) +typedef struct pixis { + u8 id; + u8 ver; + u8 pver; + u8 csr; + u8 rst; + u8 rst2; + u8 aux1; + u8 spd; + u8 aux2; + u8 csr2; + u8 watch; + u8 led; + u8 pwr; + u8 res[3]; + u8 vctl; + u8 vstat; + u8 vcfgen0; + u8 vcfgen1; + u8 vcore0; + u8 res1; + u8 vboot; + u8 vspeed[3]; + u8 sclk[3]; + u8 dclk[3]; + u8 i2cdacr; + u8 vcoreacc[4]; + u8 vcorecnt[3]; + u8 vcoremax[2]; + u8 vplatacc[4]; + u8 vplatcnt[3]; + u8 vplatmax[2]; + u8 vtempacc[4]; + u8 vtempcnt[3]; + u8 vtempmax[2]; + u8 res2[4]; +} pixis_t __attribute__ ((aligned(1))); + +#elif defined(CONFIG_MPC8544DS) +typedef struct pixis { + u8 id; + u8 ver; + u8 pver; + u8 csr; + u8 rst; + u8 pwr; + u8 aux1; + u8 spd; + u8 res[8]; + u8 vctl; + u8 vstat; + u8 vcfgen0; + u8 vcfgen1; + u8 vcore0; + u8 res1; + u8 vboot; + u8 vspeed[2]; + u8 vclkh; + u8 vclkl; + u8 watch; + u8 led; + u8 vspeed2; + u8 res2[34]; +} pixis_t __attribute__ ((aligned(1))); + +#elif defined(CONFIG_MPC8572DS) +typedef struct pixis { + u8 id; + u8 ver; + u8 pver; + u8 csr; + u8 rst; + u8 pwr1; + u8 aux1; + u8 spd; + u8 aux2; + u8 res[7]; + u8 vctl; + u8 vstat; + u8 vcfgen0; + u8 vcfgen1; + u8 vcore0; + u8 res1; + u8 vboot; + u8 vspeed[3]; + u8 res2[2]; + u8 sclk[3]; + u8 dclk[3]; + u8 res3[2]; + u8 watch; + u8 led; + u8 res4[25]; +} pixis_t __attribute__ ((aligned(1))); + +#elif defined(CONFIG_MPC8610HPCD) +typedef struct pixis { + u8 id; + u8 ver; /* also called arch */ + u8 pver; + u8 csr; + u8 rst; + u8 pwr; + u8 aux; + u8 spd; + u8 brdcfg0; + u8 brdcfg1; + u8 res[4]; + u8 led; + u8 serno; + u8 vctl; + u8 vstat; + u8 vcfgen0; + u8 vcfgen1; + u8 vcore0; + u8 res1; + u8 vboot; + u8 vspeed[2]; + u8 res2; + u8 sclk[3]; + u8 res3; + u8 watch; + u8 res4[33]; +} pixis_t __attribute__ ((aligned(1))); + +#elif defined(CONFIG_MPC8641HPCN) +typedef struct pixis { + u8 id; + u8 ver; + u8 pver; + u8 csr; + u8 rst; + u8 pwr; + u8 aux; + u8 spd; + u8 res[8]; + u8 vctl; + u8 vstat; + u8 vcfgen0; + u8 vcfgen1; + u8 vcore0; + u8 res1; + u8 vboot; + u8 vspeed[2]; + u8 vclkh; + u8 vclkl; + u8 watch; + u8 res3[36]; +} pixis_t __attribute__ ((aligned(1))); +#else +#error Need to define pixis_t for this board +#endif + +/* Pointer to the PIXIS register set */ +#define pixis ((pixis_t *)PIXIS_BASE) + +#endif /* __PIXIS_H_ */
- u8 id;
- u8 ver;
- u8 pver;
- u8 csr;
- u8 rst;
- u8 rst2;
- u8 aux1;
- u8 spd;
u8 aux2;
u8 csr2;
u8 watch;
May I suggest this instead:
typedef struct pixis { u8 id; u8 ver; u8 pver; u8 csr; u8 rst; #ifdef CONFIG_MPC8536DS ... #elsif CONFIG_MPC8544DS ...
and so on.
Besides being more compact, my editor has built-in cscope functionality, and it gets confused if there's more than one "typedef struct pixis" in the file.
You don't have to worry about any more boards using these structures. Gary M. said that all future boards will use ngpixis.
u8 id;
u8 ver;
u8 pver;
u8 csr;
u8 rst;
u8 rst2;
u8 aux1;
u8 spd;
u8 aux2;
u8 csr2;
u8 watch;
and so on.
I'm leaving them as is. Its too much noise in the file to deal with the differences and is not worth it to me.
- k
- u8 id;
- u8 ver;
- u8 pver;
- u8 csr;
- u8 rst;
- u8 rst2;
- u8 aux1;
- u8 spd;
- u8 aux2;
- u8 csr2;
- u8 watch;
- u8 led;
- u8 pwr;
- u8 res[3];
- u8 vctl;
- u8 vstat;
- u8 vcfgen0;
- u8 vcfgen1;
- u8 vcore0;
- u8 res1;
- u8 vboot;
- u8 vspeed[3];
- u8 sclk[3];
- u8 dclk[3];
- u8 i2cdacr;
- u8 vcoreacc[4];
- u8 vcorecnt[3];
- u8 vcoremax[2];
- u8 vplatacc[4];
- u8 vplatcnt[3];
- u8 vplatmax[2];
- u8 vtempacc[4];
- u8 vtempcnt[3];
- u8 vtempmax[2];
- u8 res2[4];
What's the aligned(1) for?
-Scott
- u8 id;
- u8 ver;
- u8 pver;
- u8 csr;
- u8 rst;
- u8 rst2;
- u8 aux1;
- u8 spd;
- u8 aux2;
- u8 csr2;
- u8 watch;
- u8 led;
- u8 pwr;
- u8 res[3];
- u8 vctl;
- u8 vstat;
- u8 vcfgen0;
- u8 vcfgen1;
- u8 vcore0;
- u8 res1;
- u8 vboot;
- u8 vspeed[3];
- u8 sclk[3];
- u8 dclk[3];
- u8 i2cdacr;
- u8 vcoreacc[4];
- u8 vcorecnt[3];
- u8 vcoremax[2];
- u8 vplatacc[4];
- u8 vplatcnt[3];
- u8 vplatmax[2];
- u8 vtempacc[4];
- u8 vtempcnt[3];
- u8 vtempmax[2];
- u8 res2[4];
Asked Timur, I copied it from the ngpixis.h header
- k
Hmmm... I think I might have meant __packed__ instead of aligned(1).
I'll fix ngpixis as well in updated patch.
- k
Also fixed ngpixis to be __packed__ instead of aligned.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- * Changed alignged attribute to packed * Fixed ngpixis as well
- k
board/freescale/common/ngpixis.h | 2 +- board/freescale/common/pixis.h | 182 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 183 insertions(+), 1 deletions(-) create mode 100644 board/freescale/common/pixis.h
diff --git a/board/freescale/common/ngpixis.h b/board/freescale/common/ngpixis.h index 3c59ea8..089408b 100644 --- a/board/freescale/common/ngpixis.h +++ b/board/freescale/common/ngpixis.h @@ -45,7 +45,7 @@ typedef struct ngpixis { u8 sw; u8 en; } s[8]; -} ngpixis_t __attribute__ ((aligned(1))); +} __attribute__ ((packed)) ngpixis_t;
/* Pointer to the PIXIS register set */ #define pixis ((ngpixis_t *)PIXIS_BASE) diff --git a/board/freescale/common/pixis.h b/board/freescale/common/pixis.h new file mode 100644 index 0000000..7f86de7 --- /dev/null +++ b/board/freescale/common/pixis.h @@ -0,0 +1,182 @@ +/* + * Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef __PIXIS_H_ +#define __PIXIS_H_ 1 + +/* PIXIS register set. */ +#if defined(CONFIG_MPC8536DS) +typedef struct pixis { + u8 id; + u8 ver; + u8 pver; + u8 csr; + u8 rst; + u8 rst2; + u8 aux1; + u8 spd; + u8 aux2; + u8 csr2; + u8 watch; + u8 led; + u8 pwr; + u8 res[3]; + u8 vctl; + u8 vstat; + u8 vcfgen0; + u8 vcfgen1; + u8 vcore0; + u8 res1; + u8 vboot; + u8 vspeed[3]; + u8 sclk[3]; + u8 dclk[3]; + u8 i2cdacr; + u8 vcoreacc[4]; + u8 vcorecnt[3]; + u8 vcoremax[2]; + u8 vplatacc[4]; + u8 vplatcnt[3]; + u8 vplatmax[2]; + u8 vtempacc[4]; + u8 vtempcnt[3]; + u8 vtempmax[2]; + u8 res2[4]; +} __attribute__ ((packed)) pixis_t; + +#elif defined(CONFIG_MPC8544DS) +typedef struct pixis { + u8 id; + u8 ver; + u8 pver; + u8 csr; + u8 rst; + u8 pwr; + u8 aux1; + u8 spd; + u8 res[8]; + u8 vctl; + u8 vstat; + u8 vcfgen0; + u8 vcfgen1; + u8 vcore0; + u8 res1; + u8 vboot; + u8 vspeed[2]; + u8 vclkh; + u8 vclkl; + u8 watch; + u8 led; + u8 vspeed2; + u8 res2[34]; +} __attribute__ ((packed)) pixis_t; + +#elif defined(CONFIG_MPC8572DS) +typedef struct pixis { + u8 id; + u8 ver; + u8 pver; + u8 csr; + u8 rst; + u8 pwr1; + u8 aux1; + u8 spd; + u8 aux2; + u8 res[7]; + u8 vctl; + u8 vstat; + u8 vcfgen0; + u8 vcfgen1; + u8 vcore0; + u8 res1; + u8 vboot; + u8 vspeed[3]; + u8 res2[2]; + u8 sclk[3]; + u8 dclk[3]; + u8 res3[2]; + u8 watch; + u8 led; + u8 res4[25]; +} __attribute__ ((packed)) pixis_t; + +#elif defined(CONFIG_MPC8610HPCD) +typedef struct pixis { + u8 id; + u8 ver; /* also called arch */ + u8 pver; + u8 csr; + u8 rst; + u8 pwr; + u8 aux; + u8 spd; + u8 brdcfg0; + u8 brdcfg1; + u8 res[4]; + u8 led; + u8 serno; + u8 vctl; + u8 vstat; + u8 vcfgen0; + u8 vcfgen1; + u8 vcore0; + u8 res1; + u8 vboot; + u8 vspeed[2]; + u8 res2; + u8 sclk[3]; + u8 res3; + u8 watch; + u8 res4[33]; +} __attribute__ ((packed)) pixis_t; + +#elif defined(CONFIG_MPC8641HPCN) +typedef struct pixis { + u8 id; + u8 ver; + u8 pver; + u8 csr; + u8 rst; + u8 pwr; + u8 aux; + u8 spd; + u8 res[8]; + u8 vctl; + u8 vstat; + u8 vcfgen0; + u8 vcfgen1; + u8 vcore0; + u8 res1; + u8 vboot; + u8 vspeed[2]; + u8 vclkh; + u8 vclkl; + u8 watch; + u8 res3[36]; +} __attribute__ ((packed)) pixis_t; +#else +#error Need to define pixis_t for this board +#endif + +/* Pointer to the PIXIS register set */ +#define pixis ((pixis_t *)PIXIS_BASE) + +#endif /* __PIXIS_H_ */
- Changed alignged attribute to packed
- Fixed ngpixis as well
- k
applied to 85xx
- k
Kumar Gala
Scott Wood
Timur Tabi
