[U-Boot] [POWERPC v2] mgsuvd: fix coding style
Signed-off-by: Heiko Schocher hs@denx.de --- board/keymile/mgsuvd/mgsuvd.c | 98 +++++++++++++---------------------------- include/configs/mgsuvd.h | 10 ++--- 2 files changed, 35 insertions(+), 73 deletions(-)
diff --git a/board/keymile/mgsuvd/mgsuvd.c b/board/keymile/mgsuvd/mgsuvd.c index 912e177..d74cb92 100644 --- a/board/keymile/mgsuvd/mgsuvd.c +++ b/board/keymile/mgsuvd/mgsuvd.c @@ -20,11 +20,6 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ - -#if 0 -#define DEBUG -#endif - #include <common.h> #include <mpc8xx.h>
@@ -154,83 +149,52 @@ int hush_init_var (void) }
#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) + +#define FDT_SET_NODE_VALUE(nodename, reg, var, size) \ + nodeoffset = fdt_path_offset (blob, nodename); \ + if (nodeoffset >= 0) { \ + ret = fdt_setprop (blob, nodeoffset, reg, var, \ + size); \ + if (ret < 0) \ + printf("ft_blob_update(): cannot set %s/%s " \ + "property err:%s\n", nodename, reg, \ + fdt_strerror (ret)); \ + } else { \ + printf("ft_blob_update(): cannot find %s node " \ + "err:%s\n", nodename, fdt_strerror (nodeoffset)); \ + } + /* * update "memory" property in the blob */ -void ft_blob_update(void *blob, bd_t *bd) +void ft_blob_update (void *blob, bd_t *bd) { int ret, nodeoffset = 0; ulong brg_data[1] = {0}; ulong memory_data[2] = {0}; ulong flash_data[4] = {0};
- memory_data[0] = cpu_to_be32(bd->bi_memstart); - memory_data[1] = cpu_to_be32(bd->bi_memsize); - - nodeoffset = fdt_path_offset (blob, "/memory"); - if (nodeoffset >= 0) { - ret = fdt_setprop(blob, nodeoffset, "reg", memory_data, - sizeof(memory_data)); - if (ret < 0) - printf("ft_blob_update(): cannot set /memory/reg " - "property err:%s\n", fdt_strerror(ret)); - } - else { - /* memory node is required in dts */ - printf("ft_blob_update(): cannot find /memory node " - "err:%s\n", fdt_strerror(nodeoffset)); - } - - flash_data[2] = cpu_to_be32(bd->bi_flashstart); - flash_data[3] = cpu_to_be32(bd->bi_flashsize); - nodeoffset = fdt_path_offset (blob, "/localbus"); - if (nodeoffset >= 0) { - ret = fdt_setprop(blob, nodeoffset, "ranges", flash_data, - sizeof(flash_data)); - if (ret < 0) - printf("ft_blob_update(): cannot set /localbus/ranges " - "property err:%s\n", fdt_strerror(ret)); - } - else { - /* memory node is required in dts */ - printf("ft_blob_update(): cannot find /localbus node " - "err:%s\n", fdt_strerror(nodeoffset)); - } + memory_data[0] = cpu_to_be32 (bd->bi_memstart); + memory_data[1] = cpu_to_be32 (bd->bi_memsize); + FDT_SET_NODE_VALUE("/memory", "reg", memory_data, sizeof (memory_data)) + + flash_data[2] = cpu_to_be32 (bd->bi_flashstart); + flash_data[3] = cpu_to_be32 (bd->bi_flashsize); + FDT_SET_NODE_VALUE("/localbus", "ranges", flash_data, + sizeof (flash_data)) /* BRG */ - brg_data[0] = cpu_to_be32(bd->bi_busfreq); - nodeoffset = fdt_path_offset (blob, "/soc/cpm"); - if (nodeoffset >= 0) { - ret = fdt_setprop(blob, nodeoffset, "brg-frequency", brg_data, - sizeof(brg_data)); - if (ret < 0) - printf("ft_blob_update(): cannot set /soc/cpm/brg-frequency " - "property err:%s\n", fdt_strerror(ret)); - } - else { - /* memory node is required in dts */ - printf("ft_blob_update(): cannot find /soc/cpm node " - "err:%s\n", fdt_strerror(nodeoffset)); - } + brg_data[0] = cpu_to_be32 (bd->bi_busfreq); + FDT_SET_NODE_VALUE("/soc/cpm", "brg-frequency", brg_data, + sizeof (brg_data)) /* MAC Adresse */ - nodeoffset = fdt_path_offset (blob, "/soc/cpm/ethernet"); - if (nodeoffset >= 0) { - ret = fdt_setprop(blob, nodeoffset, "mac-address", bd->bi_enetaddr, - sizeof(uchar) * 6); - if (ret < 0) - printf("ft_blob_update(): cannot set /soc/cpm/scc/mac-address " - "property err:%s\n", fdt_strerror(ret)); - } - else { - /* memory node is required in dts */ - printf("ft_blob_update(): cannot find /soc/cpm/ethernet node " - "err:%s\n", fdt_strerror(nodeoffset)); - } + FDT_SET_NODE_VALUE("/soc/cpm/ethernet", "mac-address", + bd->bi_enetaddr, sizeof (uchar) * 6) }
void ft_board_setup(void *blob, bd_t *bd) { - ft_cpu_setup( blob, bd); - ft_blob_update(blob, bd); + ft_cpu_setup (blob, bd); + ft_blob_update (blob, bd); } #endif /* defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) */
diff --git a/include/configs/mgsuvd.h b/include/configs/mgsuvd.h index 7a80dad..416e4db 100644 --- a/include/configs/mgsuvd.h +++ b/include/configs/mgsuvd.h @@ -359,18 +359,16 @@ #define I2C_READ i2c_soft_read_pin () #define I2C_SDA(bit) if(bit) { \ *(unsigned short *)(I2C_BASE_DIR) &= ~SDA_CONF; \ - } \ - else { \ + } else { \ *(unsigned char *)(I2C_BASE_PORT) &= ~SDA_BIT; \ *(unsigned short *)(I2C_BASE_DIR) |= SDA_CONF; \ - } + } #define I2C_SCL(bit) if(bit) { \ *(unsigned short *)(I2C_BASE_DIR) &= ~SCL_CONF; \ - } \ - else { \ + } else { \ *(unsigned char *)(I2C_BASE_PORT) &= ~SCL_BIT; \ *(unsigned short *)(I2C_BASE_DIR) |= SCL_CONF; \ - } + } #define I2C_DELAY udelay(50) /* 1/4 I2C clock duration */
#define CONFIG_I2C_MULTI_BUS 1
Heiko Schocher
