[U-Boot] [PATCH 1/2] Makefile: add u-boot-spl.srec target
The u-boot-spl.srec is needed for some platforms, add target to generate this file.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Tom Rini trini@konsulko.com --- Makefile | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/Makefile b/Makefile index 57cb4b87d9..a3ce04947a 100644 --- a/Makefile +++ b/Makefile @@ -926,6 +926,11 @@ OBJCOPYFLAGS_u-boot.srec := -O srec u-boot.hex u-boot.srec: u-boot FORCE $(call if_changed,objcopy)
+OBJCOPYFLAGS_u-boot-spl.srec = $(OBJCOPYFLAGS_u-boot.srec) + +spl/u-boot-spl.srec: spl/u-boot-spl FORCE + $(call if_changed,objcopy) + OBJCOPYFLAGS_u-boot-nodtb.bin := -O binary \ $(if $(CONFIG_X86_16BIT_INIT),-R .start16 -R .resetvec)
The u-boot-spl.srec is needed for the minimon update on Gen2 SoCs, conveniently generate this file if SPL is enabled.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Tom Rini trini@konsulko.com --- include/configs/rcar-gen2-common.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index 1ceee9a429..6069220406 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -15,6 +15,10 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG
+#ifdef CONFIG_SPL +#define CONFIG_SPL_TARGET "spl/u-boot-spl.srec" +#endif + #undef CONFIG_SHOW_BOOT_PROGRESS
#define CONFIG_ARCH_CPU_INIT
Can you please convert CONFIG_SPL_TARGET to CONFIG_SPL_BUILD_TARGET, to match CONFIG_BUILD_TARGET and migrate it after CONFIG_BUILD_TARGET? Thanks!
Yeah, after the release. I dont plan to mess with it before the release. Or are you planning to convert BUILD_TARGET to Kconfig _before_ ?
I would be happy enough to take both of those at this point, yes, as they can be easily verified. Thanks!
I'll add it to my todo ...
