[U-Boot] [PATCH 0/4] Trats2 code cleanups
This patch series cleanups some code for Trats2.
Unused defines are removed. For envs, hardcoded names are replaced with variable names. In the board file, 'samsung_get_base' common functions are used. Tizen partions layout is updated.
This patch series is based on: http://patchwork.ozlabs.org/patch/290667/ http://patchwork.ozlabs.org/patch/293163/ http://patchwork.ozlabs.org/patch/293162/
Piotr Wilczek (4): board: trats2: remove unused defines from config file board:trats2: fix config board:trats2: fix access to samsung registers board:trats2: update Tizen partition definitions
board/samsung/trats2/trats2.c | 16 ++++++++-------- include/configs/trats2.h | 28 +++++++++++----------------- 2 files changed, 19 insertions(+), 25 deletions(-)
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- include/configs/trats2.h | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/include/configs/trats2.h b/include/configs/trats2.h index bf49dd5..8de41ff 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -20,8 +20,6 @@ #define CONFIG_EXYNOS4 /* which is in a EXYNOS4XXX */ #define CONFIG_TIZEN /* TIZEN lib */
-#define PLATFORM_NO_UNALIGNED - #include <asm/arch/cpu.h> /* get chip and board defs */
#define CONFIG_ARCH_CPU_INIT @@ -257,8 +255,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ - GENERATED_GBL_DATA_SIZE)
-#define CONFIG_SYS_HZ 1000 - /* valid baudrates */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
In this patch variable names are used instead of hardcoded names
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- include/configs/trats2.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 8de41ff..9a90941 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -199,11 +199,11 @@ "rootfstype=ext4\0" \ "console=" CONFIG_DEFAULT_CONSOLE \ "kernelname=uImage\0" \ - "loaduimage=ext4load mmc ${mmcdev}:${mmcbootpart} 0x40007FC0 uImage\0" \ - "0x40007FC0 ${kernelname}\0" \ + "loaduimage=ext4load mmc ${mmcdev}:${mmcbootpart} 0x40007FC0 " \ + "${kernelname}\0" \ "loaddtb=ext4load mmc ${mmcdev}:${mmcbootpart} ${fdtaddr} " \ "${fdtfile}\0" \ - "mmcdev=0\0" \ + "mmcdev=CONFIG_MMC_DEFAULT_DEV\0" \ "mmcbootpart=2\0" \ "mmcrootpart=5\0" \ "opts=always_resume=1\0" \
This patch use 'samsung_get_base' common functions to access registers.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- board/samsung/trats2/trats2.c | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/board/samsung/trats2/trats2.c b/board/samsung/trats2/trats2.c index b932a60..9552522 100644 --- a/board/samsung/trats2/trats2.c +++ b/board/samsung/trats2/trats2.c @@ -43,7 +43,7 @@ static void check_hw_revision(void) int modelrev = 0; int i;
- gpio2 = (struct exynos4x12_gpio_part2 *)EXYNOS4X12_GPIO_PART2_BASE; + gpio2 = (struct exynos4x12_gpio_part2 *)samsung_get_base_gpio_part2();
/* * GPM1[1:0]: MODEL_REV[1:0] @@ -93,7 +93,7 @@ static inline u32 get_model_rev(void)
static void board_external_gpio_init(void) { - gpio2 = (struct exynos4x12_gpio_part2 *)EXYNOS4X12_GPIO_PART2_BASE; + gpio2 = (struct exynos4x12_gpio_part2 *)samsung_get_base_gpio_part2();
/* * some pins which in alive block are connected with external pull-up @@ -118,8 +118,8 @@ static void board_external_gpio_init(void) #ifdef CONFIG_SYS_I2C_INIT_BOARD static void board_init_i2c(void) { - gpio1 = (struct exynos4x12_gpio_part1 *)EXYNOS4X12_GPIO_PART1_BASE; - gpio2 = (struct exynos4x12_gpio_part2 *)EXYNOS4X12_GPIO_PART2_BASE; + gpio1 = (struct exynos4x12_gpio_part1 *)samsung_get_base_gpio_part1(); + gpio2 = (struct exynos4x12_gpio_part2 *)samsung_get_base_gpio_part2();
/* I2C_7 */ s5p_gpio_direction_output(&gpio1->d0, 2, 1); @@ -150,7 +150,7 @@ static int pmic_init_max77686(void); int board_init(void) { struct exynos4_power *pwr = - (struct exynos4_power *)EXYNOS4X12_POWER_BASE; + (struct exynos4_power *)samsung_get_base_power();
gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
@@ -257,7 +257,7 @@ int board_mmc_init(bd_t *bis) { int err0, err2 = 0;
/* eMMC_EN: SD_0_CDn: GPK0[2] Output High */ s5p_gpio_direction_output(&gpio2->k0, 2, 1); @@ -513,7 +513,7 @@ void exynos_lcd_power_on(void) { struct pmic *p = pmic_get("MAX77686_PMIC");
- gpio1 = (struct exynos4x12_gpio_part1 *)EXYNOS4X12_GPIO_PART1_BASE; + gpio1 = (struct exynos4x12_gpio_part1 *)samsung_get_base_gpio_part1();
/* LCD_2.2V_EN: GPC0[1] */ s5p_gpio_set_pull(&gpio1->c0, 1, GPIO_PULL_UP); @@ -527,7 +527,7 @@ void exynos_lcd_power_on(void)
void exynos_reset_lcd(void) { - gpio1 = (struct exynos4x12_gpio_part1 *)EXYNOS4X12_GPIO_PART1_BASE; + gpio1 = (struct exynos4x12_gpio_part1 *)samsung_get_base_gpio_part1();
/* reset lcd */ s5p_gpio_direction_output(&gpio1->f2, 1, 0);
This patch updates Tizen partions layout.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- include/configs/trats2.h | 18 ++++++++---------- 1 file changed, 8 insertions(+), 10 deletions(-)
diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 9a90941..c49a969e 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -151,23 +151,21 @@ #define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* Tizen - partitions definitions */ -#define PARTS_CSA "csa-mmc" -#define PARTS_BOOTLOADER "u-boot" +#define PARTS_CSA "csa" #define PARTS_BOOT "boot" +#define PARTS_MODEM "modem" +#define PARTS_CSC "csc" #define PARTS_ROOT "platform" #define PARTS_DATA "data" -#define PARTS_CSC "csc" #define PARTS_UMS "ums"
#define PARTS_DEFAULT \ - "uuid_disk=${uuid_gpt_disk};" \ - "name="PARTS_CSA",size=8MiB,uuid=${uuid_gpt_"PARTS_CSA"};" \ - "name="PARTS_BOOTLOADER",size=60MiB," \ - "uuid=${uuid_gpt_"PARTS_BOOTLOADER"};" \ - "name="PARTS_BOOT",size=100MiB,uuid=${uuid_gpt_"PARTS_BOOT"};" \ - "name="PARTS_ROOT",size=1GiB,uuid=${uuid_gpt_"PARTS_ROOT"};" \ - "name="PARTS_DATA",size=3GiB,uuid=${uuid_gpt_"PARTS_DATA"};" \ + "name="PARTS_CSA",start=5MiB,size=8MiB,uuid=${uuid_gpt_"PARTS_CSA"};" \ + "name="PARTS_BOOT",size=64MiB,uuid=${uuid_gpt_"PARTS_BOOT"};" \ + "name="PARTS_MODEM",size=100MiB,uuid=${uuid_gpt_"PARTS_MODEM"};" \ "name="PARTS_CSC",size=150MiB,uuid=${uuid_gpt_"PARTS_CSC"};" \ + "name="PARTS_ROOT",size=1536MiB,uuid=${uuid_gpt_"PARTS_ROOT"};" \ + "name="PARTS_DATA",size=512MiB,uuid=${uuid_gpt_"PARTS_DATA"};" \ "name="PARTS_UMS",size=-,uuid=${uuid_gpt_"PARTS_UMS"}\0" \
#define CONFIG_DFU_ALT \
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Minkyu Kang
Piotr Wilczek
