[PATCH 0/4] Update Microchip PolarFire SoC
This patch set updates Microchip PolarFire SoC Icicle Kit support of RISC-V U-Boot.
The patches are based upon latest U-Boot tree (https://source.denx.de/u-boot/u-boot) at commit id 3724ddf157aab3bd009c1da234b9a1af1621b544
The memory device node is updated in the device tree based on the latest FPGA reference design and a small 4MB reservation is made at the end of 32-bit DDR to provide some memory for the HSS to use, add Microchip QSPI driver.
Padmarao Begari (4): riscv: dts: update memory configuration riscv: dts: Add QSPI NAND device node riscv: Update Microchip MPFS Icicle Kit support spi: Add Microchip PolarFire SoC QSPI driver
arch/riscv/dts/microchip-mpfs-icicle-kit.dts | 85 ++-- board/microchip/mpfs_icicle/Kconfig | 7 + configs/microchip_mpfs_icicle_defconfig | 1 + drivers/spi/Kconfig | 6 + drivers/spi/Makefile | 1 + drivers/spi/microchip_qspi.c | 504 +++++++++++++++++++ 6 files changed, 548 insertions(+), 56 deletions(-) create mode 100644 drivers/spi/microchip_qspi.c
In the v2022.10 Icicle reference design, the seg registers are going to be changed, resulting in a required change to the memory map. A small 4MB reservation is made at the end of 32-bit DDR to provide some memory for the HSS to use, so that it can cache its payload between reboots of a specific context.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Signed-off-by: Conor Dooley conor.dooley@microchip.com --- arch/riscv/dts/microchip-mpfs-icicle-kit.dts | 70 ++++---------------- 1 file changed, 14 insertions(+), 56 deletions(-)
diff --git a/arch/riscv/dts/microchip-mpfs-icicle-kit.dts b/arch/riscv/dts/microchip-mpfs-icicle-kit.dts index 287ef3d23b..876c475069 100644 --- a/arch/riscv/dts/microchip-mpfs-icicle-kit.dts +++ b/arch/riscv/dts/microchip-mpfs-icicle-kit.dts @@ -1,6 +1,6 @@ // SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * Copyright (C) 2021 Microchip Technology Inc. + * Copyright (C) 2021-2022 Microchip Technology Inc. * Padmarao Begari padmarao.begari@microchip.com */
@@ -28,70 +28,28 @@ timebase-frequency = <RTCCLK_FREQ>; };
- reserved-memory { - ranges; - #size-cells = <2>; - #address-cells = <2>; - - fabricbuf0: fabricbuf@0 { - compatible = "shared-dma-pool"; - reg = <0x0 0xae000000 0x0 0x2000000>; - label = "fabricbuf0-ddr-c"; - }; - - fabricbuf1: fabricbuf@1 { - compatible = "shared-dma-pool"; - reg = <0x0 0xc0000000 0x0 0x8000000>; - label = "fabricbuf1-ddr-nc"; - }; - - fabricbuf2: fabricbuf@2 { - compatible = "shared-dma-pool"; - reg = <0x0 0xd8000000 0x0 0x8000000>; - label = "fabricbuf2-ddr-nc-wcb"; - }; - }; - - udmabuf0 { - compatible = "ikwzm,u-dma-buf"; - device-name = "udmabuf-ddr-c0"; - minor-number = <0>; - size = <0x0 0x2000000>; - memory-region = <&fabricbuf0>; - sync-mode = <3>; - }; - - udmabuf1 { - compatible = "ikwzm,u-dma-buf"; - device-name = "udmabuf-ddr-nc0"; - minor-number = <1>; - size = <0x0 0x8000000>; - memory-region = <&fabricbuf1>; - sync-mode = <3>; - }; - - udmabuf2 { - compatible = "ikwzm,u-dma-buf"; - device-name = "udmabuf-ddr-nc-wcb0"; - minor-number = <2>; - size = <0x0 0x8000000>; - memory-region = <&fabricbuf2>; - sync-mode = <3>; - }; - ddrc_cache_lo: memory@80000000 { device_type = "memory"; - reg = <0x0 0x80000000 0x0 0x2e000000>; - clocks = <&clkcfg CLK_DDRC>; + reg = <0x0 0x80000000 0x0 0x40000000>; status = "okay"; };
ddrc_cache_hi: memory@1000000000 { device_type = "memory"; - reg = <0x10 0x0 0x0 0x40000000>; - clocks = <&clkcfg CLK_DDRC>; + reg = <0x10 0x40000000 0x0 0x40000000>; status = "okay"; }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + hss_payload: region@BFC00000 { + reg = <0x0 0xBFC00000 0x0 0x400000>; + no-map; + }; + }; };
&uart1 {
Hmm, not sure that my SoB here is correct. If you took my patch directly, then you should change the patch so that I am the author or otherwise I think it should be: Co-developed-by: Conor Dooley conor.dooley@microchip.com Signed-off-by: Conor Dooley conor.dooley@microchip.com Signed-off-by: Padmarao Begari padmarao.begari@microchip.com
I assume that it is the same for the QSPI driver? Otherwise, LGTM: Reviewed-by: Conor Dooley conor.dooley@microchip.com
Thanks, Conor.
- Copyright (C) 2021 Microchip Technology Inc.
- Copyright (C) 2021-2022 Microchip Technology Inc.
- Padmarao Begari padmarao.begari@microchip.com
- reserved-memory {
ranges;
#size-cells = <2>;
- udmabuf0 {
minor-number = <0>;
sync-mode = <3>;
- udmabuf1 {
minor-number = <1>;
sync-mode = <3>;
- udmabuf2 {
minor-number = <2>;
sync-mode = <3>;
status = "okay"; };
status = "okay"; };reg = <0x10 0x40000000 0x0 0x40000000>;
- reserved-memory {
#size-cells = <2>;
ranges;
no-map;
&uart1 {
2.25.1
Hi Conor,
Ok. will add you with "Co-developed-by"
Regards Padmarao
Thanks, Conor.
reserved-memory {
ranges;
#size-cells = <2>;
udmabuf0 {
minor-number = <0>;
sync-mode = <3>;
udmabuf1 {
minor-number = <1>;
sync-mode = <3>;
udmabuf2 {
minor-number = <2>;
sync-mode = <3>;
reg = <0x0 0x80000000 0x0 0x40000000>; status = "okay"; }; ddrc_cache_hi: memory@1000000000 { device_type = "memory";
reserved-memory {
#size-cells = <2>;
ranges;
no-map;
&uart1 {
2.25.1
Add QSPI NAND device node to the Microchip PolarFire SoC Icicle kit device tree
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com --- arch/riscv/dts/microchip-mpfs-icicle-kit.dts | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/arch/riscv/dts/microchip-mpfs-icicle-kit.dts b/arch/riscv/dts/microchip-mpfs-icicle-kit.dts index 876c475069..679221e13f 100644 --- a/arch/riscv/dts/microchip-mpfs-icicle-kit.dts +++ b/arch/riscv/dts/microchip-mpfs-icicle-kit.dts @@ -18,6 +18,7 @@ aliases { serial1 = &uart1; ethernet0 = &mac1; + spi0 = &qspi; };
chosen { @@ -113,3 +114,17 @@ ti,fifo-depth = <0x1>; }; }; + +&qspi { + status = "okay"; + num-cs = <1>; + flash0: spi-nand@0 { + compatible = "spi-nand"; + reg = <0x0>; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; + spi-max-frequency = <20000000>; + spi-cpol; + spi-cpha; + }; +};
Hi Tudor,
On Wed, 2022-10-19 at 15:28 +0000, Tudor Ambarus - M18064 wrote: On 10/19/22 17:53, Padmarao Begari wrote:
the node should have generic name according to the dt specification, so please s/spi-nand/flash.
Ok, will use "flash"
Regards Padmarao
-- Cheers, ta
I didn't notice this on 1/3, but I think we need to mention which board that this is being added for in the shortlog. Thanks, Conor.
spi0 = &qspi;
chosen {
+&qspi {
- status = "okay";
- num-cs = <1>;
- flash0: spi-nand@0 {
reg = <0x0>;
spi-cpol;
spi-cpha;
2.25.1
Hi Conor,
Ok, will board details.
Regards Padmarao
Thanks, Conor.
spi0 = &qspi; }; chosen {
+&qspi {
status = "okay";
num-cs = <1>;
reg = <0x0>;
spi-cpol;
spi-cpha;
2.25.1
This patch updates Microchip MPFS Icicle Kit support. For now, add Microchip QSPI driver and a small 4MB reservation is made at the end of 32-bit DDR to provide some memory for the HSS to use.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com --- board/microchip/mpfs_icicle/Kconfig | 7 +++++++ configs/microchip_mpfs_icicle_defconfig | 1 + 2 files changed, 8 insertions(+)
diff --git a/board/microchip/mpfs_icicle/Kconfig b/board/microchip/mpfs_icicle/Kconfig index 092e411215..230f96b033 100644 --- a/board/microchip/mpfs_icicle/Kconfig +++ b/board/microchip/mpfs_icicle/Kconfig @@ -50,5 +50,12 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply CMD_I2C imply DM_I2C imply SYS_I2C_MICROCHIP + imply SPI + imply DM_SPI + imply MICROCHIP_QSPI + imply MTD_SPI_NAND + imply CMD_MTD + imply MTD_PARTITIONS + imply CMD_MTDPARTS
endif diff --git a/configs/microchip_mpfs_icicle_defconfig b/configs/microchip_mpfs_icicle_defconfig index 6113c5be80..c295b9bad3 100644 --- a/configs/microchip_mpfs_icicle_defconfig +++ b/configs/microchip_mpfs_icicle_defconfig @@ -17,6 +17,7 @@ CONFIG_DISPLAY_BOARDINFO=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=282 CONFIG_SYS_BOOTM_LEN=0x4000000 +CONFIG_SYS_MEM_TOP_HIDE=0x400000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM_MTD=y
- imply SPI
- imply DM_SPI
- imply MICROCHIP_QSPI
- imply MTD_SPI_NAND
- imply CMD_MTD
- imply MTD_PARTITIONS
- imply CMD_MTDPARTS
Ah cool, I'd done my patch for our stuff against v2022.01 and this IIRC was not a "real" config option then. Nice to see that it got "promoted" to a kconfig option :) Stuff here LGTM so: Reviewed-by: Conor Dooley conor.dooley@microchip.com Thanks, Conor.
CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM_MTD=y -- 2.25.1
Add QSPI driver code for the Microchip PolarFire SoC. This driver supports the qspi standard, dual and quad mode interfaces.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Signed-off-by: Naga Sureshkumar Relli nagasuresh.relli@microchip.com --- drivers/spi/Kconfig | 6 + drivers/spi/Makefile | 1 + drivers/spi/microchip_qspi.c | 504 +++++++++++++++++++++++++++++++++++ 3 files changed, 511 insertions(+) create mode 100644 drivers/spi/microchip_qspi.c
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 2f12081f88..690306309a 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -237,6 +237,12 @@ config MESON_SPIFC This driver can be used to access the SPI NOR flash chips on Amlogic Meson SoCs.
+config MICROCHIP_QSPI + bool "Microchip Quad SPI driver" + help + Enable the Microchip Quad SPI controller driver. This driver can be + used on Polarfire SoCs. + config MPC8XX_SPI bool "MPC8XX SPI Driver" depends on MPC8xx diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 50ba43550b..010855ae1d 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -40,6 +40,7 @@ obj-$(CONFIG_ICH_SPI) += ich.o obj-$(CONFIG_IPROC_QSPI) += iproc_qspi.o obj-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o obj-$(CONFIG_MESON_SPIFC) += meson_spifc.o +obj-$(CONFIG_MICROCHIP_QSPI) += microchip_qspi.o obj-$(CONFIG_MPC8XX_SPI) += mpc8xx_spi.o obj-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o obj-$(CONFIG_MTK_SNFI_SPI) += mtk_snfi_spi.o diff --git a/drivers/spi/microchip_qspi.c b/drivers/spi/microchip_qspi.c new file mode 100644 index 0000000000..2c803f6d2f --- /dev/null +++ b/drivers/spi/microchip_qspi.c @@ -0,0 +1,504 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Microchip Technology Inc. + * Padmarao Begari padmarao.begari@microchip.com + * Naga Sureshkumar Relli nagasuresh.relli@microchip.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <log.h> +#include <malloc.h> +#include <spi.h> +#include <spi-mem.h> +#include <asm/io.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/types.h> +#include <linux/sizes.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * QSPI Control register mask defines + */ +#define CONTROL_ENABLE BIT(0) +#define CONTROL_MASTER BIT(1) +#define CONTROL_XIP BIT(2) +#define CONTROL_XIPADDR BIT(3) +#define CONTROL_CLKIDLE BIT(10) +#define CONTROL_SAMPLE_MASK GENMASK(12, 11) +#define CONTROL_MODE0 BIT(13) +#define CONTROL_MODE12_MASK GENMASK(15, 14) +#define CONTROL_MODE12_EX_RO BIT(14) +#define CONTROL_MODE12_EX_RW BIT(15) +#define CONTROL_MODE12_FULL GENMASK(15, 14) +#define CONTROL_FLAGSX4 BIT(16) +#define CONTROL_CLKRATE_MASK GENMASK(27, 24) +#define CONTROL_CLKRATE_SHIFT 24 + +/* + * QSPI Frames register mask defines + */ +#define FRAMES_TOTALBYTES_MASK GENMASK(15, 0) +#define FRAMES_CMDBYTES_MASK GENMASK(24, 16) +#define FRAMES_CMDBYTES_SHIFT 16 +#define FRAMES_SHIFT 25 +#define FRAMES_IDLE_MASK GENMASK(29, 26) +#define FRAMES_IDLE_SHIFT 26 +#define FRAMES_FLAGBYTE BIT(30) +#define FRAMES_FLAGWORD BIT(31) + +/* + * QSPI Interrupt Enable register mask defines + */ +#define IEN_TXDONE BIT(0) +#define IEN_RXDONE BIT(1) +#define IEN_RXAVAILABLE BIT(2) +#define IEN_TXAVAILABLE BIT(3) +#define IEN_RXFIFOEMPTY BIT(4) +#define IEN_TXFIFOFULL BIT(5) + +/* + * QSPI Status register mask defines + */ +#define STATUS_TXDONE BIT(0) +#define STATUS_RXDONE BIT(1) +#define STATUS_RXAVAILABLE BIT(2) +#define STATUS_TXAVAILABLE BIT(3) +#define STATUS_RXFIFOEMPTY BIT(4) +#define STATUS_TXFIFOFULL BIT(5) +#define STATUS_READY BIT(7) +#define STATUS_FLAGSX4 BIT(8) +#define STATUS_MASK GENMASK(8, 0) + +#define BYTESUPPER_MASK GENMASK(31, 16) +#define BYTESLOWER_MASK GENMASK(15, 0) + +#define MAX_DIVIDER 16 +#define MIN_DIVIDER 0 +#define MAX_DATA_CMD_LEN 256 + +/* QSPI ready time out value */ +#define TIMEOUT_MS (1000 * 60) + +/* + * QSPI Register offsets. + */ +#define REG_CONTROL (0x00) +#define REG_FRAMES (0x04) +#define REG_IEN (0x0c) +#define REG_STATUS (0x10) +#define REG_DIRECT_ACCESS (0x14) +#define REG_UPPER_ACCESS (0x18) +#define REG_RX_DATA (0x40) +#define REG_TX_DATA (0x44) +#define REG_X4_RX_DATA (0x48) +#define REG_X4_TX_DATA (0x4c) +#define REG_FRAMESUP (0x50) + +/** + * struct mchp_coreqspi - Defines qspi driver instance + * @regs: Address of the QSPI controller registers + * @freq: QSPI Input frequency + * @txbuf: TX buffer + * @rxbuf: RX buffer + * @tx_len: Number of bytes left to transfer + * @rx_len: Number of bytes left to receive + */ +struct mchp_coreqspi { + void __iomem *regs; + u32 freq; + u8 *txbuf; + u8 *rxbuf; + int tx_len; + int rx_len; +}; + +static void mchp_coreqspi_init_hw(struct mchp_coreqspi *qspi) +{ + u32 control; + + control = CONTROL_CLKIDLE | CONTROL_ENABLE; + + writel(control, qspi->regs + REG_CONTROL); + writel(0, qspi->regs + REG_IEN); +} + +static inline void mchp_coreqspi_read_op(struct mchp_coreqspi *qspi) +{ + u32 control, data; + + if (!qspi->rx_len) + return; + + control = readl(qspi->regs + REG_CONTROL); + + /* + * Read 4-bytes from the SPI FIFO in single transaction and then read + * the reamaining data byte wise. + */ + control |= CONTROL_FLAGSX4; + writel(control, qspi->regs + REG_CONTROL); + + while (qspi->rx_len >= 4) { + while (readl(qspi->regs + REG_STATUS) & STATUS_RXFIFOEMPTY) + ; + data = readl(qspi->regs + REG_X4_RX_DATA); + *(u32 *)qspi->rxbuf = data; + qspi->rxbuf += 4; + qspi->rx_len -= 4; + } + + control &= ~CONTROL_FLAGSX4; + writel(control, qspi->regs + REG_CONTROL); + + while (qspi->rx_len--) { + while (readl(qspi->regs + REG_STATUS) & STATUS_RXFIFOEMPTY) + ; + data = readl(qspi->regs + REG_RX_DATA); + *qspi->rxbuf++ = (data & 0xFF); + } +} + +static inline void mchp_coreqspi_write_op(struct mchp_coreqspi *qspi, bool word) +{ + u32 control, data; + + control = readl(qspi->regs + REG_CONTROL); + control |= CONTROL_FLAGSX4; + writel(control, qspi->regs + REG_CONTROL); + + while (qspi->tx_len >= 4) { + while (readl(qspi->regs + REG_STATUS) & STATUS_TXFIFOFULL) + ; + data = *(u32 *)qspi->txbuf; + qspi->txbuf += 4; + qspi->tx_len -= 4; + writel(data, qspi->regs + REG_X4_TX_DATA); + } + + control &= ~CONTROL_FLAGSX4; + writel(control, qspi->regs + REG_CONTROL); + + while (qspi->tx_len--) { + while (readl(qspi->regs + REG_STATUS) & STATUS_TXFIFOFULL) + ; + data = *qspi->txbuf++; + writel(data, qspi->regs + REG_TX_DATA); + } +} + +static inline void mchp_coreqspi_config_op(struct mchp_coreqspi *qspi, + const struct spi_mem_op *op) +{ + u32 idle_cycles = 0; + int total_bytes, cmd_bytes, frames, ctrl; + + cmd_bytes = op->cmd.nbytes + op->addr.nbytes; + total_bytes = cmd_bytes + op->data.nbytes; + + /* + * As per the coreQSPI IP spec,the number of command and data bytes are + * controlled by the frames register for each SPI sequence. This supports + * the SPI flash memory read and writes sequences as below. so configure + * the cmd and total bytes accordingly. + * --------------------------------------------------------------------- + * TOTAL BYTES | CMD BYTES | What happens | + * ______________________________________________________________________ + * | | | + * 1 | 1 | The SPI core will transmit a single byte | + * | | and receive data is discarded | + * | | | + * 1 | 0 | The SPI core will transmit a single byte | + * | | and return a single byte | + * | | | + * 10 | 4 | The SPI core will transmit 4 command | + * | | bytes discarding the receive data and | + * | | transmits 6 dummy bytes returning the 6 | + * | | received bytes and return a single byte | + * | | | + * 10 | 10 | The SPI core will transmit 10 command | + * | | | + * 10 | 0 | The SPI core will transmit 10 command | + * | | bytes and returning 10 received bytes | + * ______________________________________________________________________ + */ + + if (!(op->data.dir == SPI_MEM_DATA_IN)) + cmd_bytes = total_bytes; + + frames = total_bytes & BYTESUPPER_MASK; + writel(frames, qspi->regs + REG_FRAMESUP); + frames = total_bytes & BYTESLOWER_MASK; + frames |= cmd_bytes << FRAMES_CMDBYTES_SHIFT; + + if (op->dummy.buswidth) + idle_cycles = op->dummy.nbytes * 8 / op->dummy.buswidth; + + frames |= idle_cycles << FRAMES_IDLE_SHIFT; + ctrl = readl(qspi->regs + REG_CONTROL); + + if (ctrl & CONTROL_MODE12_MASK) + frames |= (1 << FRAMES_SHIFT); + + frames |= FRAMES_FLAGWORD; + writel(frames, qspi->regs + REG_FRAMES); +} + +static int mchp_coreqspi_wait_for_ready(struct spi_slave *slave) +{ + struct mchp_coreqspi *qspi = dev_get_priv(slave->dev->parent); + unsigned long count = 0; + + while (1) { + if (readl(qspi->regs + REG_STATUS) & STATUS_READY) + return 0; + + udelay(1); + count += 1; + if (count == TIMEOUT_MS) + return -ETIMEDOUT; + } +} + +static int mchp_coreqspi_set_operate_mode(struct mchp_coreqspi *qspi, + const struct spi_mem_op *op) +{ + u32 control = readl(qspi->regs + REG_CONTROL); + + /* + * The operating mode can be configured based on the command that needs + * to be send. + * bits[15:14]: Sets whether multiple bit SPI operates in normal, + * extended or full modes. + * 00: Normal (single DQ0 TX and single DQ1 RX lines) + * 01: Extended RO (command and address bytes on DQ0 only) + * 10: Extended RW (command byte on DQ0 only) + * 11: Full. (command and address are on all DQ lines) + * bit[13]: Sets whether multiple bit SPI uses 2 or 4 bits of data + * 0: 2-bits (BSPI) + * 1: 4-bits (QSPI) + */ + if (op->data.buswidth == 4 || op->data.buswidth == 2) { + control &= ~CONTROL_MODE12_MASK; + if (op->cmd.buswidth == 1 && (op->addr.buswidth == 1 || + op->addr.buswidth == 0)) + control |= CONTROL_MODE12_EX_RO; + else if (op->cmd.buswidth == 1) + control |= CONTROL_MODE12_EX_RW; + else + control |= CONTROL_MODE12_FULL; + + control |= CONTROL_MODE0; + } else { + control &= ~(CONTROL_MODE12_MASK | CONTROL_MODE0); + } + + writel(control, qspi->regs + REG_CONTROL); + + return 0; +} + +static int mchp_coreqspi_exec_op(struct spi_slave *slave, + const struct spi_mem_op *op) +{ + struct mchp_coreqspi *qspi = dev_get_priv(slave->dev->parent); + + u32 address = op->addr.val; + u8 opcode = op->cmd.opcode; + u8 opaddr[5]; + int err = 0, i; + + err = mchp_coreqspi_wait_for_ready(slave); + if (err) + return err; + + err = mchp_coreqspi_set_operate_mode(qspi, op); + if (err) + return err; + + mchp_coreqspi_config_op(qspi, op); + if (op->cmd.opcode) { + qspi->txbuf = &opcode; + qspi->rxbuf = NULL; + qspi->tx_len = op->cmd.nbytes; + qspi->rx_len = 0; + mchp_coreqspi_write_op(qspi, false); + } + + qspi->txbuf = &opaddr[0]; + if (op->addr.nbytes) { + for (i = 0; i < op->addr.nbytes; i++) + qspi->txbuf[i] = address >> (8 * (op->addr.nbytes - i - 1)); + + qspi->rxbuf = NULL; + qspi->tx_len = op->addr.nbytes; + qspi->rx_len = 0; + mchp_coreqspi_write_op(qspi, false); + } + + if (op->data.nbytes) { + if (op->data.dir == SPI_MEM_DATA_OUT) { + qspi->txbuf = (u8 *)op->data.buf.out; + qspi->rxbuf = NULL; + qspi->rx_len = 0; + qspi->tx_len = op->data.nbytes; + mchp_coreqspi_write_op(qspi, true); + } else { + qspi->txbuf = NULL; + qspi->rxbuf = (u8 *)op->data.buf.in; + qspi->rx_len = op->data.nbytes; + qspi->tx_len = 0; + mchp_coreqspi_read_op(qspi); + } + } + + return 0; +} + +static bool mchp_coreqspi_supports_op(struct spi_slave *slave, + const struct spi_mem_op *op) +{ + if (!spi_mem_default_supports_op(slave, op)) + return false; + + if ((op->data.buswidth == 4 || op->data.buswidth == 2) && + (op->cmd.buswidth == 1 && (op->addr.buswidth == 1 || + op->addr.buswidth == 0))) { + /* + * If the command and address are on DQ0 only, then this + * controller doesn't support sending data on dual and + * quad lines. but it supports reading data on dual and + * quad lines with same configuration as command and + * address on DQ0. + * i.e. The control register[15:13] :EX_RO(read only) is + * meant only for the command and address are on DQ0 but + * not to write data, it is just to read. + * Ex: 0x34h is Quad Load Program Data which is not + * supported. Then the spi-mem layer will iterate over + * each command and it will chose the supported one. + */ + if (op->data.dir == SPI_MEM_DATA_OUT) + return false; + } + + return true; +} + +static int mchp_coreqspi_adjust_op_size(struct spi_slave *slave, + struct spi_mem_op *op) +{ + if (op->data.dir == SPI_MEM_DATA_OUT) { + if (op->data.nbytes > MAX_DATA_CMD_LEN) + op->data.nbytes = MAX_DATA_CMD_LEN; + } + + return 0; +} + +static int mchp_coreqspi_set_speed(struct udevice *dev, uint speed) +{ + struct mchp_coreqspi *qspi = dev_get_priv(dev); + u32 control, baud_rate_val = 0; + + if (speed > (qspi->freq / 2)) + speed = qspi->freq / 2; + + baud_rate_val = DIV_ROUND_UP(qspi->freq, 2 * speed); + if (baud_rate_val >= MAX_DIVIDER || baud_rate_val <= MIN_DIVIDER) + return -EINVAL; + + control = readl(qspi->regs + REG_CONTROL); + control &= ~CONTROL_CLKRATE_MASK; + control |= baud_rate_val << CONTROL_CLKRATE_SHIFT; + writel(control, qspi->regs + REG_CONTROL); + + return 0; +} + +static int mchp_coreqspi_set_mode(struct udevice *dev, uint mode) +{ + struct mchp_coreqspi *qspi = dev_get_priv(dev); + u32 control; + + control = readl(qspi->regs + REG_CONTROL); + + if ((mode & SPI_CPOL) && (mode & SPI_CPHA)) + control |= CONTROL_CLKIDLE; + else + control &= ~CONTROL_CLKIDLE; + + writel(control, qspi->regs + REG_CONTROL); + + return 0; +} + +static int mchp_coreqspi_claim_bus(struct udevice *dev) +{ + return 0; +} + +static int mchp_coreqspi_release_bus(struct udevice *dev) +{ + return 0; +} + +static int mchp_coreqspi_probe(struct udevice *dev) +{ + struct mchp_coreqspi *qspi = dev_get_priv(dev); + struct clk clk; + ulong clk_rate; + int ret; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret) + return -EINVAL; + + ret = clk_enable(&clk); + if (ret) + return ret; + + clk_rate = clk_get_rate(&clk); + if (!clk_rate) + return -EINVAL; + qspi->freq = clk_rate; + + qspi->regs = dev_read_addr_ptr(dev); + if (!qspi->regs) + return -EINVAL; + + /* Init the mpfs qspi hw */ + mchp_coreqspi_init_hw(qspi); + + return 0; +} + +static const struct spi_controller_mem_ops mchp_coreqspi_mem_ops = { + .adjust_op_size = mchp_coreqspi_adjust_op_size, + .supports_op = mchp_coreqspi_supports_op, + .exec_op = mchp_coreqspi_exec_op, +}; + +static const struct dm_spi_ops mchp_coreqspi_ops = { + .claim_bus = mchp_coreqspi_claim_bus, + .release_bus = mchp_coreqspi_release_bus, + .set_speed = mchp_coreqspi_set_speed, + .set_mode = mchp_coreqspi_set_mode, + .mem_ops = &mchp_coreqspi_mem_ops, +}; + +static const struct udevice_id mchp_coreqspi_ids[] = { + { .compatible = "microchip,mpfs-qspi" }, + { } +}; + +U_BOOT_DRIVER(mchp_coreqspi) = { + .name = "mchp_coreqspi", + .id = UCLASS_SPI, + .of_match = mchp_coreqspi_ids, + .ops = &mchp_coreqspi_ops, + .priv_auto = sizeof(struct mchp_coreqspi), + .probe = mchp_coreqspi_probe, +};
Hi!
The name is too generic, there are multiple QSPI IPs inside mchp. I would suggest to create an mchp directory and rename your c file to maybe something like mpfs-qspi?
On Wed, Oct 19, 2022 at 03:16:01PM +0000, Tudor.Ambarus@microchip.com wrote:
Hi!
The (linux) driver works for both the "hard" peripheral on mpfs & for the core in FPGA fabric. I would wouldn't mind copying the linux naming and using "microchip-corespi" & "microchip-coreqspi" as the underlying IPs are called CoreSPI and CoreQSPI respectively.
Hi Conor,
Hi!
Ok, will use "microchip-coreqspi" name.
Regards Padmarao
Can this be MICROCHIP_COREQSPI to match my proposed name of the driver and the function/structure names in the driver?
- { .compatible = "microchip,mpfs-qspi" },
Could we add microchip,coreqspi-rtl-v2 to the compatible list here please to match the linux driver? The linux driver works perfectly well with the fabric core and I assume that's the case for the the U-Boot driver too?
Thanks, Conor.
- .name = "mchp_coreqspi",
- .id = UCLASS_SPI,
- .of_match = mchp_coreqspi_ids,
- .ops = &mchp_coreqspi_ops,
- .priv_auto = sizeof(struct mchp_coreqspi),
- .probe = mchp_coreqspi_probe,
2.25.1
Hi Conor,
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Signed-off-by: Naga Sureshkumar Relli < nagasuresh.relli@microchip.com>
Ok
Ok
Regards Padmarao
Thanks, Conor.
.id = UCLASS_SPI,
2.25.1
Conor Dooley
Padmarao Begari
Padmarao.Begari@microchip.com
