[U-Boot-Users] [PATCH v3 9/10] drivers: Add the support for Freescale SATA controller
Add the Freescale on-chip SATA controller driver to u-boot, The SATA controller is used on the 837x and 8315 targets, The driver can be used to load kernel, fs and dtb.
The features list: - 1.5/3 Gbps link speed - LBA48, LBA28 support - DMA and FPDMA support - Two ports support
Signed-off-by: Dave Liu daveliu@freescale.com --- drivers/block/Makefile | 1 + drivers/block/fsl_sata.c | 921 ++++++++++++++++++++++++++++++++++++++++++++++ drivers/block/fsl_sata.h | 374 +++++++++++++++++++ 3 files changed, 1296 insertions(+), 0 deletions(-) create mode 100644 drivers/block/fsl_sata.c create mode 100644 drivers/block/fsl_sata.h
diff --git a/drivers/block/Makefile b/drivers/block/Makefile index d63ca2d..dca3547 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -27,6 +27,7 @@ LIB := $(obj)libblock.a
COBJS-y += ahci.o COBJS-y += ata_piix.o +COBJS-$(CONFIG_FSL_SATA) += fsl_sata.o COBJS-$(CONFIG_LIBATA) += libata.o COBJS-y += sil680.o COBJS-y += sym53c8xx.o diff --git a/drivers/block/fsl_sata.c b/drivers/block/fsl_sata.c new file mode 100644 index 0000000..df00446 --- /dev/null +++ b/drivers/block/fsl_sata.c @@ -0,0 +1,921 @@ +/* + * Copyright (C) 2008 Freescale Semiconductor, Inc. + * Dave Liu daveliu@freescale.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <asm/io.h> +#include <malloc.h> +#include <libata.h> +#include <fis.h> +#include "fsl_sata.h" + +extern block_dev_desc_t sata_dev_desc[CFG_SATA_MAX_DEVICE]; + +#ifndef CFG_SATA1_FLAGS + #define CFG_SATA1_FLAGS FLAGS_DMA +#endif +#ifndef CFG_SATA2_FLAGS + #define CFG_SATA2_FLAGS FLAGS_DMA +#endif + +static struct fsl_sata_info fsl_sata_info[] = { +#ifdef CONFIG_SATA1 + {CFG_SATA1, CFG_SATA1_FLAGS}, +#else + {0, 0}, +#endif +#ifdef CONFIG_SATA2 + {CFG_SATA2, CFG_SATA2_FLAGS}, +#else + {0, 0}, +#endif +}; + +static inline void mdelay(unsigned long msec) +{ + unsigned long i; + for (i = 0; i < msec; i++) + udelay(1000); +} + +static inline void sdelay(unsigned long sec) +{ + unsigned long i; + for (i = 0; i < sec; i++) + mdelay(1000); +} + +void dprint_buffer(unsigned char *buf, int len) +{ + int i, j; + + i = 0; + j = 0; + printf("\n\r"); + + for (i = 0; i < len; i++) { + printf("%02x ", *buf++); + j++; + if (j == 16) { + printf("\n\r"); + j = 0; + } + } + printf("\n\r"); +} + +static void fsl_sata_dump_sfis(struct sfis *s) +{ + printf("Status FIS dump:\n\r"); + printf("fis_type: %02x\n\r", s->fis_type); + printf("pm_port_i: %02x\n\r", s->pm_port_i); + printf("status: %02x\n\r", s->status); + printf("error: %02x\n\r", s->error); + printf("lba_low: %02x\n\r", s->lba_low); + printf("lba_mid: %02x\n\r", s->lba_mid); + printf("lba_high: %02x\n\r", s->lba_high); + printf("device: %02x\n\r", s->device); + printf("lba_low_exp: %02x\n\r", s->lba_low_exp); + printf("lba_mid_exp: %02x\n\r", s->lba_mid_exp); + printf("lba_high_exp: %02x\n\r", s->lba_high_exp); + printf("res1: %02x\n\r", s->res1); + printf("sector_count: %02x\n\r", s->sector_count); + printf("sector_count_exp: %02x\n\r", s->sector_count_exp); +} + +static int ata_wait_register(volatile unsigned *addr, u32 mask, + u32 val, u32 timeout_msec) +{ + int i; + u32 temp; + + for (i = 0; (((temp = in_le32(addr)) & mask) != val) + && i < timeout_msec; i++) + mdelay(1); + return (i < timeout_msec) ? 0 : -1; +} + +static int fsl_sata_init(int dev) +{ + u32 length, align; + cmd_hdr_tbl_t *cmd_hdr; + u32 cda; + u32 val32; + fsl_sata_reg_t *reg; + u32 sig; + int i; + fsl_sata_t *sata; + + if (dev < 0 || dev > (CFG_SATA_MAX_DEVICE - 1)) { + printf("the sata index %d is out of ranges\n\r", dev); + return -1; + } + + /* Allocate SATA device driver struct */ + sata = (fsl_sata_t *)malloc(sizeof(fsl_sata_t)); + if (!sata) { + printf("alloc the sata device struct failed\n\r"); + return -1; + } + /* Zero all of the device driver struct */ + memset((void *)sata, 0, sizeof(fsl_sata_t)); + + /* Save the private struct to block device struct */ + sata_dev_desc[dev].priv = (void *)sata; + + sprintf(sata->name, "SATA%d", dev); + + /* Set the controller register base address to device struct */ + reg = (fsl_sata_reg_t *)(fsl_sata_info[dev].sata_reg_base); + sata->reg_base = reg; + + /* Allocate the command header table, 4 bytes aligned */ + length = sizeof(struct cmd_hdr_tbl); + align = SATA_HC_CMD_HDR_TBL_ALIGN; + sata->cmd_hdr_tbl_offset = (void *)malloc(length + align); + if (!sata) { + printf("alloc the command header failed\n\r"); + return -1; + } + + cmd_hdr = (cmd_hdr_tbl_t *)(((u32)sata->cmd_hdr_tbl_offset + align) + & ~(align - 1)); + sata->cmd_hdr = cmd_hdr; + + /* Zero all of the command header table */ + memset((void *)sata->cmd_hdr_tbl_offset, 0, length + align); + + /* Allocate command descriptor for all command */ + length = sizeof(struct cmd_desc) * SATA_HC_MAX_CMD; + align = SATA_HC_CMD_DESC_ALIGN; + sata->cmd_desc_offset = (void *)malloc(length + align); + if (!sata->cmd_desc_offset) { + printf("alloc the command descriptor failed\n\r"); + return -1; + } + sata->cmd_desc = (cmd_desc_t *)(((u32)sata->cmd_desc_offset + align) + & ~(align - 1)); + /* Zero all of command descriptor */ + memset((void *)sata->cmd_desc_offset, 0, length + align); + + /* Link the command descriptor to command header */ + for (i = 0; i < SATA_HC_MAX_CMD; i++) { + cda = ((u32)sata->cmd_desc + SATA_HC_CMD_DESC_SIZE * i) + & ~(CMD_HDR_CDA_ALIGN - 1); + cmd_hdr->cmd_slot[i].cda = cpu_to_le32(cda); + } + + /* To have safe state, force the controller offline */ + val32 = in_le32(®->hcontrol); + val32 &= ~HCONTROL_ONOFF; + val32 |= HCONTROL_FORCE_OFFLINE; + out_le32(®->hcontrol, val32); + + /* Wait the controller offline */ + ata_wait_register(®->hstatus, HSTATUS_ONOFF, 0, 1000); + + /* Set the command header base address to CHBA register to tell DMA */ + out_le32(®->chba, (u32)cmd_hdr & ~0x3); + + /* Snoop for the command header */ + val32 = in_le32(®->hcontrol); + val32 |= HCONTROL_HDR_SNOOP; + out_le32(®->hcontrol, val32); + + /* Disable all of interrupts */ + val32 = in_le32(®->hcontrol); + val32 &= ~HCONTROL_INT_EN_ALL; + out_le32(®->hcontrol, val32); + + /* Clear all of interrupts */ + val32 = in_le32(®->hstatus); + out_le32(®->hstatus, val32); + + /* Set the ICC, no interrupt coalescing */ + out_le32(®->icc, 0x01000000); + + /* No PM attatched, the SATA device direct connect */ + out_le32(®->cqpmp, 0); + + /* Clear SError register */ + val32 = in_le32(®->serror); + out_le32(®->serror, val32); + + /* Clear CER register */ + val32 = in_le32(®->cer); + out_le32(®->cer, val32); + + /* Clear DER register */ + val32 = in_le32(®->der); + out_le32(®->der, val32); + + /* No device detection or initialization action requested */ + out_le32(®->scontrol, 0x00000300); + + /* Configure the transport layer, default value */ + out_le32(®->transcfg, 0x08000016); + + /* Configure the link layer, default value */ + out_le32(®->linkcfg, 0x0000ff34); + + /* Bring the controller online */ + val32 = in_le32(®->hcontrol); + val32 |= HCONTROL_ONOFF; + out_le32(®->hcontrol, val32); + + mdelay(100); + + /* print sata device name */ + if (!dev) + printf("%s ", sata->name); + else + printf(" %s ", sata->name); + + /* Check PHYRDY */ + val32 = in_le32(®->hstatus); + if (val32 & HSTATUS_PHY_RDY) { + sata->link = 1; + } else { + sata->link = 0; + printf("(No RDY)\n\r"); + return -1; + } + + if (val32 & HSTATUS_SIGNATURE) { + sig = in_le32(®->sig); + debug("Signature updated, the sig =%08x\n\r", sig); + sata->ata_device_type = ata_dev_classify(sig); + } + + /* Check the speed */ + val32 = in_le32(®->sstatus); + if ((val32 & SSTATUS_SPD_MASK) == SSTATUS_SPD_GEN1) + printf("(1.5 Gbps)\n\r"); + else if ((val32 & SSTATUS_SPD_MASK) == SSTATUS_SPD_GEN2) + printf("(3 Gbps)\n\r"); + + return 0; +} + +/* Hardware reset, like Power-on and COMRESET */ +void fsl_sata_hardware_reset(u32 reg_base) +{ + fsl_sata_reg_t *reg = (fsl_sata_reg_t *)reg_base; + u32 scontrol; + + /* Disable the SATA interface and put PHY offline */ + scontrol = in_le32(®->scontrol); + scontrol = (scontrol & 0x0f0) | 0x304; + out_le32(®->scontrol, scontrol); + + /* No speed strict */ + scontrol = in_le32(®->scontrol); + scontrol = scontrol & ~0x0f0; + out_le32(®->scontrol, scontrol); + + /* Issue PHY wake/reset, Hardware_reset_asserted */ + scontrol = in_le32(®->scontrol); + scontrol = (scontrol & 0x0f0) | 0x301; + out_le32(®->scontrol, scontrol); + + mdelay(100); + + /* Resume PHY, COMRESET negated, the device initialize hardware + * and execute diagnostics, send good status-signature to host, + * which is D2H register FIS, and then the device enter idle state. + */ + scontrol = in_le32(®->scontrol); + scontrol = (scontrol & 0x0f0) | 0x300; + out_le32(®->scontrol, scontrol); + + mdelay(100); + return; +} + +static void fsl_sata_dump_regs(fsl_sata_reg_t *reg) +{ + printf("\n\rSATA: %08x\n\r", (u32)reg); + printf("CQR: %08x\n\r", in_le32(®->cqr)); + printf("CAR: %08x\n\r", in_le32(®->car)); + printf("CCR: %08x\n\r", in_le32(®->ccr)); + printf("CER: %08x\n\r", in_le32(®->cer)); + printf("CQR: %08x\n\r", in_le32(®->cqr)); + printf("DER: %08x\n\r", in_le32(®->der)); + printf("CHBA: %08x\n\r", in_le32(®->chba)); + printf("HStatus: %08x\n\r", in_le32(®->hstatus)); + printf("HControl: %08x\n\r", in_le32(®->hcontrol)); + printf("CQPMP: %08x\n\r", in_le32(®->cqpmp)); + printf("SIG: %08x\n\r", in_le32(®->sig)); + printf("ICC: %08x\n\r", in_le32(®->icc)); + printf("SStatus: %08x\n\r", in_le32(®->sstatus)); + printf("SError: %08x\n\r", in_le32(®->serror)); + printf("SControl: %08x\n\r", in_le32(®->scontrol)); + printf("SNotification: %08x\n\r", in_le32(®->snotification)); + printf("TransCfg: %08x\n\r", in_le32(®->transcfg)); + printf("TransStatus: %08x\n\r", in_le32(®->transstatus)); + printf("LinkCfg: %08x\n\r", in_le32(®->linkcfg)); + printf("LinkCfg1: %08x\n\r", in_le32(®->linkcfg1)); + printf("LinkCfg2: %08x\n\r", in_le32(®->linkcfg2)); + printf("LinkStatus: %08x\n\r", in_le32(®->linkstatus)); + printf("LinkStatus1: %08x\n\r", in_le32(®->linkstatus1)); + printf("PhyCtrlCfg: %08x\n\r", in_le32(®->phyctrlcfg)); + printf("SYSPR: %08x\n\r", in_be32(®->syspr)); +} + +static int fsl_ata_exec_ata_cmd(struct fsl_sata *sata, struct cfis *cfis, + int is_ncq, int tag, u8 *buffer, u32 len) +{ + cmd_hdr_entry_t *cmd_hdr; + cmd_desc_t *cmd_desc; + sata_fis_h2d_t *h2d; + prd_entry_t *prde; + u32 ext_c_ddc; + u32 prde_count; + u32 val32; + u32 ttl; + fsl_sata_reg_t *reg = sata->reg_base; + int i; + + /* Check xfer length */ + if (len > SATA_HC_MAX_XFER_LEN) { + printf("max transfer length is 64MB\n\r"); + return 0; + } + + /* Setup the command descriptor */ + cmd_desc = sata->cmd_desc + tag; + + /* Get the pointer cfis of command descriptor */ + h2d = (sata_fis_h2d_t *)cmd_desc->cfis; + + /* Zero the cfis of command descriptor */ + memset((void *)h2d, 0, SATA_HC_CMD_DESC_CFIS_SIZE); + + /* Copy the cfis from user to command descriptor */ + h2d->fis_type = cfis->fis_type; + h2d->pm_port_c = cfis->pm_port_c; + h2d->command = cfis->command; + + h2d->features = cfis->features; + h2d->features_exp = cfis->features_exp; + + h2d->lba_low = cfis->lba_low; + h2d->lba_mid = cfis->lba_mid; + h2d->lba_high = cfis->lba_high; + h2d->lba_low_exp = cfis->lba_low_exp; + h2d->lba_mid_exp = cfis->lba_mid_exp; + h2d->lba_high_exp = cfis->lba_high_exp; + + if (!is_ncq) { + h2d->sector_count = cfis->sector_count; + h2d->sector_count_exp = cfis->sector_count_exp; + } else { /* NCQ */ + h2d->sector_count = (u8)(tag << 3); + } + + h2d->device = cfis->device; + h2d->control = cfis->control; + + /* Setup the PRD table */ + prde = (prd_entry_t *)cmd_desc->prdt; + memset((void *)prde, 0, sizeof(struct prdt)); + + prde_count = 0; + ttl = len; + for (i = 0; i < SATA_HC_MAX_PRD_DIRECT; i++) { + if (!len) + break; + prde->dba = cpu_to_le32((u32)buffer & ~0x3); + debug("dba = %08x\n\r", (u32)buffer); + + if (len < PRD_ENTRY_MAX_XFER_SZ) { + ext_c_ddc = PRD_ENTRY_DATA_SNOOP | len; + debug("ext_c_ddc1 = %08x, len = %08x\n\r", ext_c_ddc, len); + prde->ext_c_ddc = cpu_to_le32(ext_c_ddc); + prde_count++; + prde++; + break; + } else { + ext_c_ddc = PRD_ENTRY_DATA_SNOOP; /* 4M bytes */ + debug("ext_c_ddc2 = %08x, len = %08x\n\r", ext_c_ddc, len); + prde->ext_c_ddc = cpu_to_le32(ext_c_ddc); + buffer += PRD_ENTRY_MAX_XFER_SZ; + len -= PRD_ENTRY_MAX_XFER_SZ; + prde_count++; + prde++; + } + } + + /* Setup the command slot of cmd hdr */ + cmd_hdr = (cmd_hdr_entry_t *)&sata->cmd_hdr->cmd_slot[tag]; + + cmd_hdr->cda = cpu_to_le32((u32)cmd_desc & ~0x3); + + val32 = prde_count << CMD_HDR_PRD_ENTRY_SHIFT; + val32 |= sizeof(sata_fis_h2d_t); + cmd_hdr->prde_fis_len = cpu_to_le32(val32); + + cmd_hdr->ttl = cpu_to_le32(ttl); + + if (!is_ncq) { + val32 = CMD_HDR_ATTR_RES | CMD_HDR_ATTR_SNOOP; + } else { + val32 = CMD_HDR_ATTR_RES | CMD_HDR_ATTR_SNOOP | CMD_HDR_ATTR_FPDMA; + } + + tag &= CMD_HDR_ATTR_TAG; + val32 |= tag; + + debug("attribute = %08x\n\r", val32); + cmd_hdr->attribute = cpu_to_le32(val32); + + /* Make sure cmd desc and cmd slot valid before commmand issue */ + sync(); + + /* PMP*/ + val32 = (u32)(h2d->pm_port_c & 0x0f); + out_le32(®->cqpmp, val32); + + /* Wait no active */ + if (ata_wait_register(®->car, (1 << tag), 0, 10000)) + printf("Wait no active time out\n\r"); + + /* Issue command */ + if (!(in_le32(®->cqr) & (1 << tag))) { + val32 = 1 << tag; + out_le32(®->cqr, val32); + } + + /* Wait command completed for 10s */ + if (ata_wait_register(®->ccr, (1 << tag), (1 << tag), 10000)) { + if (!is_ncq) + printf("Non-NCQ command time out\n\r"); + else + printf("NCQ command time out\n\r"); + } + + val32 = in_le32(®->cer); + + if (val32) { + u32 der; + fsl_sata_dump_sfis((struct sfis *)cmd_desc->sfis); + printf("CE at device\n\r"); + fsl_sata_dump_regs(reg); + der = in_le32(®->der); + out_le32(®->cer, val32); + out_le32(®->der, der); + } + + /* Clear complete flags */ + val32 = in_le32(®->ccr); + out_le32(®->ccr, val32); + + return len; +} + +static int fsl_ata_exec_reset_cmd(struct fsl_sata *sata, struct cfis *cfis, + int tag, u8 *buffer, u32 len) +{ + return 0; +} + +static int fsl_sata_exec_cmd(struct fsl_sata *sata, struct cfis *cfis, + enum cmd_type command_type, int tag, u8 *buffer, u32 len) +{ + int rc; + + if (tag > SATA_HC_MAX_CMD || tag < 0) { + printf("tag is out of range, tag=\n\r", tag); + return -1; + } + + switch (command_type) { + case CMD_ATA: + rc = fsl_ata_exec_ata_cmd(sata, cfis, 0, tag, buffer, len); + return rc; + case CMD_RESET: + rc = fsl_ata_exec_reset_cmd(sata, cfis, tag, buffer, len); + return rc; + case CMD_NCQ: + rc = fsl_ata_exec_ata_cmd(sata, cfis, 1, tag, buffer, len); + return rc; + case CMD_ATAPI: + case CMD_VENDOR_BIST: + case CMD_BIST: + printf("not support now\n\r"); + return -1; + default: + break; + } + + return -1; +} + +static void fsl_sata_identify(int dev, u16 *id) +{ + fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; + struct sata_fis_h2d h2d; + struct cfis *cfis; + + cfis = (struct cfis *)&h2d; + memset((void *)cfis, 0, sizeof(struct cfis)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = ATA_CMD_ID_ATA; + + fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, (u8 *)id, ATA_ID_WORDS * 2); + ata_swap_buf_le16(id, ATA_ID_WORDS); +} + +static void fsl_sata_xfer_mode(int dev, u16 *id) +{ + fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; + + sata->pio = id[ATA_ID_PIO_MODES]; + sata->mwdma = id[ATA_ID_MWDMA_MODES]; + sata->udma = id[ATA_ID_UDMA_MODES]; + debug("pio %04x, mwdma %04x, udma %04x\n\r", sata->pio, sata->mwdma, sata->udma); +} + +static void fsl_sata_set_features(int dev) +{ + fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; + struct sata_fis_h2d h2d; + struct cfis *cfis; + u8 udma_cap; + + cfis = (struct cfis *)&h2d; + memset((void *)cfis, 0, sizeof(struct cfis)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = ATA_CMD_SET_FEATURES; + cfis->features = SETFEATURES_XFER; + + /* First check the device capablity */ + udma_cap = (u8)(sata->udma & 0xff); + debug("udma_cap %02x\n\r", udma_cap); + + if (udma_cap == ATA_UDMA6) + cfis->sector_count = XFER_UDMA_6; + if (udma_cap == ATA_UDMA5) + cfis->sector_count = XFER_UDMA_5; + if (udma_cap == ATA_UDMA4) + cfis->sector_count = XFER_UDMA_4; + if (udma_cap == ATA_UDMA3) + cfis->sector_count = XFER_UDMA_3; + + fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, NULL, 0); +} + +static u32 fsl_sata_rw_cmd(int dev, u32 start, u32 blkcnt, u8 *buffer, int is_write) +{ + fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; + struct sata_fis_h2d h2d; + struct cfis *cfis; + u32 block; + + block = start; + cfis = (struct cfis *)&h2d; + + memset((void *)cfis, 0, sizeof(struct cfis)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = (is_write) ? ATA_CMD_WRITE_DMA : ATA_CMD_READ_DMA; + cfis->device = ATA_LBA; + + cfis->device |= (block >> 24) & 0xf; + cfis->lba_high = (block >> 16) & 0xff; + cfis->lba_mid = (block >> 8) & 0xff; + cfis->lba_low = block & 0xff; + cfis->sector_count = (u8)(blkcnt & 0xff); + + fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, buffer, ATA_SECT_SIZE * blkcnt); + return blkcnt; +} + +void fsl_sata_flush_cache(int dev) +{ + fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; + struct sata_fis_h2d h2d; + struct cfis *cfis; + + cfis = (struct cfis *)&h2d; + + memset((void *)cfis, 0, sizeof(struct cfis)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = ATA_CMD_FLUSH_CACHE; + + fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, NULL, 0); +} + +static u32 fsl_sata_rw_cmd_ext(int dev, u32 start, u32 blkcnt, u8 *buffer, int is_write) +{ + fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; + struct sata_fis_h2d h2d; + struct cfis *cfis; + u64 block; + + block = (u64)start; + cfis = (struct cfis *)&h2d; + + memset((void *)cfis, 0, sizeof(struct cfis)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + + cfis->command = (is_write) ? ATA_CMD_WRITE_DMA_EXT + : ATA_CMD_READ_DMA_EXT; + + cfis->lba_high_exp = (block >> 40) & 0xff; + cfis->lba_mid_exp = (block >> 32) & 0xff; + cfis->lba_low_exp = (block >> 24) & 0xff; + cfis->lba_high = (block >> 16) & 0xff; + cfis->lba_mid = (block >> 8) & 0xff; + cfis->lba_low = block & 0xff; + cfis->device = ATA_LBA; + cfis->sector_count_exp = (blkcnt >> 8) & 0xff; + cfis->sector_count = blkcnt & 0xff; + + fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, buffer, ATA_SECT_SIZE * blkcnt); + return blkcnt; +} + +u32 fsl_sata_rw_ncq_cmd(int dev, u32 start, u32 blkcnt, u8 *buffer, int is_write) +{ + fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; + struct sata_fis_h2d h2d; + struct cfis *cfis; + int ncq_channel; + u64 block; + + if (sata_dev_desc[dev].lba48 != 1) { + printf("execute FPDMA command on non-LBA48 hard disk\n\r"); + return -1; + } + + block = (u64)start; + cfis = (struct cfis *)&h2d; + + memset((void *)cfis, 0, sizeof(struct cfis)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + + cfis->command = (is_write) ? ATA_CMD_WRITE_FPDMA_QUEUED + : ATA_CMD_READ_FPDMA_QUEUED; + + cfis->lba_high_exp = (block >> 40) & 0xff; + cfis->lba_mid_exp = (block >> 32) & 0xff; + cfis->lba_low_exp = (block >> 24) & 0xff; + cfis->lba_high = (block >> 16) & 0xff; + cfis->lba_mid = (block >> 8) & 0xff; + cfis->lba_low = block & 0xff; + + cfis->device = ATA_LBA; + cfis->features_exp = (blkcnt >> 8) & 0xff; + cfis->features = blkcnt & 0xff; + + if (sata->queue_depth >= SATA_HC_MAX_CMD) + ncq_channel = SATA_HC_MAX_CMD - 1; + else + ncq_channel = sata->queue_depth - 1; + + /* Use the latest queue */ + fsl_sata_exec_cmd(sata, cfis, CMD_NCQ, ncq_channel, buffer, ATA_SECT_SIZE * blkcnt); + return blkcnt; +} + +void fsl_sata_flush_cache_ext(int dev) +{ + fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; + struct sata_fis_h2d h2d; + struct cfis *cfis; + + cfis = (struct cfis *)&h2d; + + memset((void *)cfis, 0, sizeof(struct cfis)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = ATA_CMD_FLUSH_CACHE_EXT; + + fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, NULL, 0); +} + +/* Software reset, set SRST of the Device Control register */ +void fsl_sata_software_reset(int dev) +{ + return; +} + +static void fsl_sata_init_wcache(int dev, u16 *id) +{ + fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; + + if (ata_id_has_wcache(id) && ata_id_wcache_enabled(id)) + sata->wcache = 1; + if (ata_id_has_flush(id)) + sata->flush = 1; + if (ata_id_has_flush_ext(id)) + sata->flush_ext = 1; +} + +static int fsl_sata_get_wcache(int dev) +{ + fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; + return sata->wcache; +} + +static int fsl_sata_get_flush(int dev) +{ + fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; + return sata->flush; +} + +static int fsl_sata_get_flush_ext(int dev) +{ + fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; + return sata->flush_ext; +} + +u32 ata_low_level_rw_lba48(int dev, u32 blknr, u32 blkcnt, void *buffer, int is_write) +{ + u32 start, blks; + u8 *addr; + int max_blks; + + start = blknr; + blks = blkcnt; + addr = (u8 *)buffer; + + max_blks = ATA_MAX_SECTORS_LBA48; + do { + if (blks > max_blks) { + if (fsl_sata_info[dev].flags != FLAGS_FPDMA) + fsl_sata_rw_cmd_ext(dev, start, max_blks, addr, is_write); + else + fsl_sata_rw_ncq_cmd(dev, start, max_blks, addr, is_write); + start += max_blks; + blks -= max_blks; + addr += ATA_SECT_SIZE * max_blks; + } else { + if (fsl_sata_info[dev].flags != FLAGS_FPDMA) + fsl_sata_rw_cmd_ext(dev, start, blks, addr, is_write); + else + fsl_sata_rw_ncq_cmd(dev, start, blks, addr, is_write); + start += blks; + blks = 0; + addr += ATA_SECT_SIZE * blks; + } + } while (blks != 0); + + return blkcnt; +} + +u32 ata_low_level_rw_lba28(int dev, u32 blknr, u32 blkcnt, void *buffer, int is_write) +{ + u32 start, blks; + u8 *addr; + int max_blks; + + start = blknr; + blks = blkcnt; + addr = (u8 *)buffer; + + max_blks = ATA_MAX_SECTORS; + do { + if (blks > max_blks) { + fsl_sata_rw_cmd(dev, start, max_blks, addr, is_write); + start += max_blks; + blks -= max_blks; + addr += ATA_SECT_SIZE * max_blks; + } else { + fsl_sata_rw_cmd(dev, start, blks, addr, is_write); + start += blks; + blks = 0; + addr += ATA_SECT_SIZE * blks; + } + } while (blks != 0); + + return blkcnt; +} + +/******************************************************************** + * SATA interface between low level driver and command layer + *******************************************************************/ +u32 sata_low_level_read(int dev, u32 blknr, u32 blkcnt, void *buffer) +{ + u32 rc; + + if (sata_dev_desc[dev].lba48) + rc = ata_low_level_rw_lba48(dev, blknr, blkcnt, buffer, READ_CMD); + else + rc = ata_low_level_rw_lba28(dev, blknr, blkcnt, buffer, READ_CMD); + return rc; +} + +u32 sata_low_level_write(int dev, u32 blknr, u32 blkcnt, void *buffer) +{ + u32 rc; + + if (sata_dev_desc[dev].lba48) { + rc = ata_low_level_rw_lba48(dev, blknr, blkcnt, buffer, WRITE_CMD); + if (fsl_sata_get_wcache(dev) && fsl_sata_get_flush_ext(dev)) + fsl_sata_flush_cache_ext(dev); + } else { + rc = ata_low_level_rw_lba28(dev, blknr, blkcnt, buffer, WRITE_CMD); + if (fsl_sata_get_wcache(dev) && fsl_sata_get_flush(dev)) + fsl_sata_flush_cache(dev); + } + return rc; +} + +int sata_low_level_init(int dev) +{ + return fsl_sata_init(dev); +} + +int sata_low_level_scan(int dev) +{ + fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; + unsigned char serial[ATA_ID_SERNO_LEN + 1]; + unsigned char firmware[ATA_ID_FW_REV_LEN + 1]; + unsigned char product[ATA_ID_PROD_LEN + 1]; + u16 *id; + u64 n_sectors; + + /* if no detected link */ + if (!sata->link) + return -1; + + id = (u16 *)malloc(ATA_ID_WORDS * 2); + if (!id) { + printf("id malloc failed\n\r"); + return -1; + } + + /* Identify device to get information */ + fsl_sata_identify(dev, id); + + /* Serial number */ + ata_id_c_string(id, serial, ATA_ID_SERNO, sizeof(serial)); + memcpy(sata_dev_desc[dev].product, serial, sizeof(serial)); + + /* Firmware version */ + ata_id_c_string(id, firmware, ATA_ID_FW_REV, sizeof(firmware)); + memcpy(sata_dev_desc[dev].revision, firmware, sizeof(firmware)); + + /* Product model */ + ata_id_c_string(id, product, ATA_ID_PROD, sizeof(product)); + memcpy(sata_dev_desc[dev].vendor, product, sizeof(product)); + + /* Totoal sectors */ + n_sectors = ata_id_n_sectors(id); + sata_dev_desc[dev].lba = (u32)n_sectors; + + /* Check if support LBA48 */ + if (ata_id_has_lba48(id)) { + sata_dev_desc[dev].lba48 = 1; + debug("Device support LBA48\n\r"); + } + + /* Get the NCQ queue depth from device */ + sata->queue_depth = ata_id_queue_depth(id); + + /* Get the xfer mode from device */ + fsl_sata_xfer_mode(dev, id); + + /* Get the write cache status from device */ + fsl_sata_init_wcache(dev, id); + + /* Set the xfer mode to highest speed */ + fsl_sata_set_features(dev); +#ifdef DEBUG + fsl_sata_identify(dev, id); + ata_dump_id(id); +#endif + free((void *)id); + return 0; +} diff --git a/drivers/block/fsl_sata.h b/drivers/block/fsl_sata.h new file mode 100644 index 0000000..874c0dc --- /dev/null +++ b/drivers/block/fsl_sata.h @@ -0,0 +1,374 @@ +/* + * Copyright (C) 2007-2008 Freescale Semiconductor, Inc. + * Dave Liu daveliu@freescale.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __FSL_SATA_H__ +#define __FSL_SATA_H__ + +#define SATA_HC_MAX_NUM 4 /* Max host controller numbers */ +#define SATA_HC_MAX_CMD 16 /* Max command queue depth per host controller */ +#define SATA_HC_MAX_PORT 16 /* Max port number per host controller */ + +/* +* SATA Host Controller Registers +*/ +typedef struct fsl_sata_reg { + /* SATA command registers */ + u32 cqr; /* Command queue register */ + u8 res1[0x4]; + u32 car; /* Command active register */ + u8 res2[0x4]; + u32 ccr; /* Command completed register */ + u8 res3[0x4]; + u32 cer; /* Command error register */ + u8 res4[0x4]; + u32 der; /* Device error register */ + u32 chba; /* Command header base address */ + u32 hstatus; /* Host status register */ + u32 hcontrol; /* Host control register */ + u32 cqpmp; /* Port number queue register */ + u32 sig; /* Signature register */ + u32 icc; /* Interrupt coalescing control register */ + u8 res5[0xc4]; + + /* SATA supperset registers */ + u32 sstatus; /* SATA interface status register */ + u32 serror; /* SATA interface error register */ + u32 scontrol; /* SATA interface control register */ + u32 snotification; /* SATA interface notification register */ + u8 res6[0x30]; + + /* SATA control status registers */ + u32 transcfg; /* Transport layer configuration */ + u32 transstatus; /* Transport layer status */ + u32 linkcfg; /* Link layer configuration */ + u32 linkcfg1; /* Link layer configuration1 */ + u32 linkcfg2; /* Link layer configuration2 */ + u32 linkstatus; /* Link layer status */ + u32 linkstatus1; /* Link layer status1 */ + u32 phyctrlcfg; /* PHY control configuration */ + u8 res7[0x2b0]; + + /* SATA system control registers */ + u32 syspr; /* System priority register - big endian */ + u8 res8[0xbec]; +} __attribute__ ((packed)) fsl_sata_reg_t; + +/* HStatus register +*/ +#define HSTATUS_ONOFF 0x80000000 /* Online/offline status */ +#define HSTATUS_FORCE_OFFLINE 0x40000000 /* In process going offline */ +#define HSTATUS_BIST_ERR 0x20000000 + +/* Fatal error */ +#define HSTATUS_MASTER_ERR 0x00004000 +#define HSTATUS_DATA_UNDERRUN 0x00002000 +#define HSTATUS_DATA_OVERRUN 0x00001000 +#define HSTATUS_CRC_ERR_TX 0x00000800 +#define HSTATUS_CRC_ERR_RX 0x00000400 +#define HSTATUS_FIFO_OVERFLOW_TX 0x00000200 +#define HSTATUS_FIFO_OVERFLOW_RX 0x00000100 +#define HSTATUS_FATAL_ERR_ALL (HSTATUS_MASTER_ERR | \ + HSTATUS_DATA_UNDERRUN | \ + HSTATUS_DATA_OVERRUN | \ + HSTATUS_CRC_ERR_TX | \ + HSTATUS_CRC_ERR_RX | \ + HSTATUS_FIFO_OVERFLOW_TX | \ + HSTATUS_FIFO_OVERFLOW_RX) +/* Interrupt status */ +#define HSTATUS_FATAL_ERR 0x00000020 +#define HSTATUS_PHY_RDY 0x00000010 +#define HSTATUS_SIGNATURE 0x00000008 +#define HSTATUS_SNOTIFY 0x00000004 +#define HSTATUS_DEVICE_ERR 0x00000002 +#define HSTATUS_CMD_COMPLETE 0x00000001 + +/* HControl register +*/ +#define HCONTROL_ONOFF 0x80000000 /* Online or offline request */ +#define HCONTROL_FORCE_OFFLINE 0x40000000 /* Force offline request */ +#define HCONTROL_HDR_SNOOP 0x00000400 /* Command header snoop */ +#define HCONTROL_PMP_ATTACHED 0x00000200 /* Port multiplier attached */ + +/* Interrupt enable */ +#define HCONTROL_FATAL_ERR 0x00000020 +#define HCONTROL_PHY_RDY 0x00000010 +#define HCONTROL_SIGNATURE 0x00000008 +#define HCONTROL_SNOTIFY 0x00000004 +#define HCONTROL_DEVICE_ERR 0x00000002 +#define HCONTROL_CMD_COMPLETE 0x00000001 + +#define HCONTROL_INT_EN_ALL (HCONTROL_FATAL_ERR | \ + HCONTROL_PHY_RDY | \ + HCONTROL_SIGNATURE | \ + HCONTROL_SNOTIFY | \ + HCONTROL_DEVICE_ERR | \ + HCONTROL_CMD_COMPLETE) + +/* SStatus register +*/ +#define SSTATUS_IPM_MASK 0x00000780 +#define SSTATUS_IPM_NOPRESENT 0x00000000 +#define SSTATUS_IPM_ACTIVE 0x00000080 +#define SSTATUS_IPM_PATIAL 0x00000100 +#define SSTATUS_IPM_SLUMBER 0x00000300 + +#define SSTATUS_SPD_MASK 0x000000f0 +#define SSTATUS_SPD_GEN1 0x00000010 +#define SSTATUS_SPD_GEN2 0x00000020 + +#define SSTATUS_DET_MASK 0x0000000f +#define SSTATUS_DET_NODEVICE 0x00000000 +#define SSTATUS_DET_DISCONNECT 0x00000001 +#define SSTATUS_DET_CONNECT 0x00000003 +#define SSTATUS_DET_PHY_OFFLINE 0x00000004 + +/* SControl register +*/ +#define SCONTROL_SPM_MASK 0x0000f000 +#define SCONTROL_SPM_GO_PARTIAL 0x00001000 +#define SCONTROL_SPM_GO_SLUMBER 0x00002000 +#define SCONTROL_SPM_GO_ACTIVE 0x00004000 + +#define SCONTROL_IPM_MASK 0x00000f00 +#define SCONTROL_IPM_NO_RESTRICT 0x00000000 +#define SCONTROL_IPM_PARTIAL 0x00000100 +#define SCONTROL_IPM_SLUMBER 0x00000200 +#define SCONTROL_IPM_PART_SLUM 0x00000300 + +#define SCONTROL_SPD_MASK 0x000000f0 +#define SCONTROL_SPD_NO_RESTRICT 0x00000000 +#define SCONTROL_SPD_GEN1 0x00000010 +#define SCONTROL_SPD_GEN2 0x00000020 + +#define SCONTROL_DET_MASK 0x0000000f +#define SCONTROL_DET_HRESET 0x00000001 +#define SCONTROL_DET_DISABLE 0x00000004 + +/* TransCfg register +*/ +#define TRANSCFG_DFIS_SIZE_SHIFT 16 +#define TRANSCFG_RX_WATER_MARK_MASK 0x0000001f + +/* PhyCtrlCfg register +*/ +#define PHYCTRLCFG_FPRFTI_MASK 0x00000018 +#define PHYCTRLCFG_LOOPBACK_MASK 0x0000000e + +/* +* Command Header Entry +*/ +typedef struct cmd_hdr_entry { + u32 cda; /* Command Descriptor Address, 4 bytes aligned */ + u32 prde_fis_len; /* Number of PRD entries and FIS length */ + u32 ttl; /* Total transfer length */ + u32 attribute; /* the attribute of command */ +} __attribute__ ((packed)) cmd_hdr_entry_t; + +#define SATA_HC_CMD_HDR_ENTRY_SIZE sizeof(struct cmd_hdr_entry) + +/* cda +*/ +#define CMD_HDR_CDA_ALIGN 4 + +/* prde_fis_len +*/ +#define CMD_HDR_PRD_ENTRY_SHIFT 16 +#define CMD_HDR_PRD_ENTRY_MASK 0x003f0000 +#define CMD_HDR_FIS_LEN_SHIFT 2 + +/* attribute +*/ +#define CMD_HDR_ATTR_RES 0x00000800 /* Reserved bit, should be 1 */ +#define CMD_HDR_ATTR_VBIST 0x00000400 /* Vendor BIST */ +#define CMD_HDR_ATTR_SNOOP 0x00000200 /* Snoop enable for all descriptor */ +#define CMD_HDR_ATTR_FPDMA 0x00000100 /* FPDMA queued command */ +#define CMD_HDR_ATTR_RESET 0x00000080 /* Reset - a SRST or device reset */ +#define CMD_HDR_ATTR_BIST 0x00000040 /* BIST - require the host to enter BIST mode */ +#define CMD_HDR_ATTR_ATAPI 0x00000020 /* ATAPI command */ +#define CMD_HDR_ATTR_TAG 0x0000001f /* TAG mask */ + +/* command type +*/ +enum cmd_type { + CMD_VENDOR_BIST, + CMD_BIST, + CMD_RESET, /* SRST or device reset */ + CMD_ATAPI, + CMD_NCQ, + CMD_ATA, /* None of all above */ +}; + +/* +* Command Header Table +*/ +typedef struct cmd_hdr_tbl { + cmd_hdr_entry_t cmd_slot[SATA_HC_MAX_CMD]; +} __attribute__ ((packed)) cmd_hdr_tbl_t; + +#define SATA_HC_CMD_HDR_TBL_SIZE sizeof(struct cmd_hdr_tbl) +#define SATA_HC_CMD_HDR_TBL_ALIGN 4 + +/* +* PRD entry - Physical Region Descriptor entry +*/ +typedef struct prd_entry { + u32 dba; /* Data base address, 4 bytes aligned */ + u32 res1; + u32 res2; + u32 ext_c_ddc; /* Indirect PRD flags, snoop and data word count */ +} __attribute__ ((packed)) prd_entry_t; + +#define SATA_HC_CMD_DESC_PRD_SIZE sizeof(struct prd_entry) + +/* dba +*/ +#define PRD_ENTRY_DBA_ALIGN 4 + +/* ext_c_ddc +*/ +#define PRD_ENTRY_EXT 0x80000000 /* extension flag or called indirect descriptor flag */ +#define PRD_ENTRY_DATA_SNOOP 0x00400000 /* Snoop enable for all data associated with the PRD entry */ +#define PRD_ENTRY_LEN_MASK 0x003fffff /* Data word count */ + +#define PRD_ENTRY_MAX_XFER_SZ (PRD_ENTRY_LEN_MASK + 1) + +/* + * This SATA host controller supports a max of 16 direct PRD entries, but if use + * chained indirect PRD entries, then the contollers supports upto a max of 63 + * entries including direct and indirect PRD entries. + * The PRDT is an array of 63 PRD entries contigiously, but the PRD entries#15 + * will be setup as an indirect descriptor, pointing to it's next (contigious) + * PRD entries#16. + */ +#define SATA_HC_MAX_PRD 63 /* Max PRD entry numbers per command */ +#define SATA_HC_MAX_PRD_DIRECT 16 /* Direct PRDT entries */ +#define SATA_HC_MAX_PRD_USABLE (SATA_HC_MAX_PRD - 1) +#define SATA_HC_MAX_XFER_LEN 0x4000000 + +/* +* PRDT - Physical Region Descriptor Table +*/ +typedef struct prdt { + prd_entry_t prdt[SATA_HC_MAX_PRD]; +} __attribute__ ((packed)) prdt_t; + +/* +* Command Descriptor +*/ +#define SATA_HC_CMD_DESC_CFIS_SIZE 32 /* bytes */ +#define SATA_HC_CMD_DESC_SFIS_SIZE 32 /* bytes */ +#define SATA_HC_CMD_DESC_ACMD_SIZE 16 /* bytes */ +#define SATA_HC_CMD_DESC_RES 16 /* bytes */ + +typedef struct cmd_desc { + u8 cfis[SATA_HC_CMD_DESC_CFIS_SIZE]; + u8 sfis[SATA_HC_CMD_DESC_SFIS_SIZE]; + u8 acmd[SATA_HC_CMD_DESC_ACMD_SIZE]; + u8 res[SATA_HC_CMD_DESC_RES]; + prd_entry_t prdt[SATA_HC_MAX_PRD]; +} __attribute__ ((packed)) cmd_desc_t; + +#define SATA_HC_CMD_DESC_SIZE sizeof(struct cmd_desc) +#define SATA_HC_CMD_DESC_ALIGN 4 + +/* +* CFIS - Command FIS, which is H2D register FIS, the struct defination +* of Non-Queued command is different than NCQ command. see them is sata2.h +*/ +typedef struct cfis { + u8 fis_type; + u8 pm_port_c; + u8 command; + u8 features; + u8 lba_low; + u8 lba_mid; + u8 lba_high; + u8 device; + u8 lba_low_exp; + u8 lba_mid_exp; + u8 lba_high_exp; + u8 features_exp; + u8 sector_count; + u8 sector_count_exp; + u8 res1; + u8 control; + u8 res2[4]; +} __attribute__ ((packed)) cfis_t; + +/* +* SFIS - Status FIS, which is D2H register FIS. +*/ +typedef struct sfis { + u8 fis_type; + u8 pm_port_i; + u8 status; + u8 error; + u8 lba_low; + u8 lba_mid; + u8 lba_high; + u8 device; + u8 lba_low_exp; + u8 lba_mid_exp; + u8 lba_high_exp; + u8 res1; + u8 sector_count; + u8 sector_count_exp; + u8 res2[2]; + u8 res3[4]; +} __attribute__ ((packed)) sfis_t; + +/* + * SATA device driver info + */ +typedef struct fsl_sata_info { + u32 sata_reg_base; + u32 flags; +} fsl_sata_info_t; + +#define FLAGS_DMA 0x00000000 +#define FLAGS_FPDMA 0x00000001 + +/* + * SATA device driver struct + */ +typedef struct fsl_sata { + char name[12]; + fsl_sata_reg_t *reg_base; /* the base address of controller register */ + void *cmd_hdr_tbl_offset; /* alloc address of command header table */ + cmd_hdr_tbl_t *cmd_hdr; /* aligned address of command header table */ + void *cmd_desc_offset; /* alloc address of command descriptor */ + cmd_desc_t *cmd_desc; /* aligned address of command descriptor */ + int link; /* PHY link status */ + /* device attribute */ + int ata_device_type; /* device type */ + int lba48; + int queue_depth; /* Max NCQ queue depth */ + u16 pio; + u16 mwdma; + u16 udma; + int wcache; + int flush; + int flush_ext; +} fsl_sata_t; + +#define READ_CMD 0 +#define WRITE_CMD 1 + +#endif /* __FSL_SATA_H__ */
Dave Liu
