[PATCH] powerpc, mpc83xx: Remove CONFIG_ELBC_BRx_ORx
Commit fe7d654d04 ("mpc83xx: Migrate CONFIG_SYS_{BR, OR}*_PRELIM to Kconfig") converted CONFIG_SYS_{BRx/ORx}_PRELIM to Kconfig by implementing a fine-grained selection of every bit in Kconfig.
But commit c7fad78ec0 ("Convert CONFIG_SYS_BR0_PRELIM et al to Kconfig") reworked it so that you now just have to provide the raw value of each register in Kconfig. However, all fine-grained Kconfig items remained allthough they are not used anymore.
Remove them all.
Fixes: c7fad78ec0 ("Convert CONFIG_SYS_BR0_PRELIM et al to Kconfig") Signed-off-by: Christophe Leroy christophe.leroy@csgroup.eu --- arch/powerpc/cpu/mpc83xx/elbc/Kconfig | 6 - arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc0 | 733 -------------------- arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc1 | 733 -------------------- arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc2 | 733 -------------------- arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc3 | 733 -------------------- arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc4 | 733 -------------------- configs/MPC837XERDB_defconfig | 31 - configs/gazerbeam_defconfig | 25 - configs/kmcoge5ne_defconfig | 37 - configs/kmeter1_defconfig | 28 - configs/kmopti2_defconfig | 34 - configs/kmsupx5_defconfig | 28 - configs/kmtepr2_defconfig | 34 - configs/tuge1_defconfig | 28 - configs/tuxx1_defconfig | 36 - 15 files changed, 3952 deletions(-) delete mode 100644 arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc0 delete mode 100644 arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc1 delete mode 100644 arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc2 delete mode 100644 arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc3 delete mode 100644 arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc4
diff --git a/arch/powerpc/cpu/mpc83xx/elbc/Kconfig b/arch/powerpc/cpu/mpc83xx/elbc/Kconfig index 74c4ff3ed4..06841523ef 100644 --- a/arch/powerpc/cpu/mpc83xx/elbc/Kconfig +++ b/arch/powerpc/cpu/mpc83xx/elbc/Kconfig @@ -23,10 +23,4 @@ config ELBC_BR_OR_NAND_PRELIM_4
endchoice
-source "arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc0" -source "arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc1" -source "arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc2" -source "arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc3" -source "arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc4" - endmenu diff --git a/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc0 b/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc0 deleted file mode 100644 index 208eed0495..0000000000 --- a/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc0 +++ /dev/null @@ -1,733 +0,0 @@ -menuconfig ELBC_BR0_OR0 - bool "ELBC BR0/OR0" - -if ELBC_BR0_OR0 - -config BR0_OR0_NAME - string "Identifier" - -config BR0_OR0_BASE - hex "Port base" - -choice - prompt "Port size" - -config BR0_PORTSIZE_8BIT - bool "8-bit" - -config BR0_PORTSIZE_16BIT - depends on !BR0_MACHINE_FCM - bool "16-bit" - - -config BR0_PORTSIZE_32BIT - depends on !BR0_MACHINE_FCM - depends on ARCH_MPC8360 || ARCH_MPC8379 - bool "32-bit" - -endchoice - -if BR0_MACHINE_FCM - -choice - prompt "Data Error Checking" - -config BR0_ERRORCHECKING_DISABLED - bool "Disabled" - -config BR0_ERRORCHECKING_ECC_CHECKING - bool "ECC checking / No ECC generation" - -config BR0_ERRORCHECKING_BOTH - bool "ECC checking and generation" - -endchoice - -endif - -config BR0_WRITE_PROTECT - bool "Write-protect" - -config BR0_MACHINE_UPM - bool - -choice - prompt "Machine select" - -config BR0_MACHINE_GPCM - bool "GPCM" - -config BR0_MACHINE_FCM - depends on !ARCH_MPC832X && !ARCH_MPC8360 - bool "FCM" - -config BR0_MACHINE_SDRAM - depends on ARCH_MPC8360 - bool "SDRAM" - -config BR0_MACHINE_UPMA - select BR0_MACHINE_UPM - bool "UPM (A)" - -config BR0_MACHINE_UPMB - select BR0_MACHINE_UPM - bool "UPM (B)" - -config BR0_MACHINE_UPMC - select BR0_MACHINE_UPM - bool "UPM (C)" - -endchoice - -if ARCH_MPC8313 || ARCH_MPC8323 || ARCH_MPC8360 - -choice - prompt "Atomic operations" - -config BR0_ATOMIC_NONE - bool "No atomic operations" - -config BR0_ATOMIC_RAWA - bool "Read-after-write-atomic" - -config BR0_ATOMIC_WARA - bool "Write-after-read-atomic" - -endchoice - -endif - -if BR0_MACHINE_GPCM || BR0_MACHINE_FCM || BR0_MACHINE_UPM || BR0_MACHINE_SDRAM - -choice - prompt "Address mask" - -config OR0_AM_32_KBYTES - depends on !BR0_MACHINE_SDRAM - bool "32 kb" - -config OR0_AM_64_KBYTES - bool "64 kb" - -config OR0_AM_128_KBYTES - bool "128 kb" - -config OR0_AM_256_KBYTES - bool "256 kb" - -config OR0_AM_512_KBYTES - bool "512 kb" - -config OR0_AM_1_MBYTES - bool "1 mb" - -config OR0_AM_2_MBYTES - bool "2 mb" - -config OR0_AM_4_MBYTES - bool "4 mb" - -config OR0_AM_8_MBYTES - bool "8 mb" - -config OR0_AM_16_MBYTES - bool "16 mb" - -config OR0_AM_32_MBYTES - bool "32 mb" - -config OR0_AM_64_MBYTES - bool "64 mb" - -# XXX: Some boards define 128MB AM with GPCM, even though it should not be -# possible according to the manuals -config OR0_AM_128_MBYTES - bool "128 mb" - -# XXX: Some boards define 256MB AM with GPCM, even though it should not be -# possible according to the manuals -config OR0_AM_256_MBYTES - bool "256 mb" - -config OR0_AM_512_MBYTES - depends on BR0_MACHINE_FCM - bool "512 mb" - -# XXX: Some boards define 1GB AM with GPCM, even though it should not be -# possible according to the manuals -config OR0_AM_1_GBYTES - bool "1 gb" - -config OR0_AM_2_GBYTES - depends on BR0_MACHINE_FCM - bool "2 gb" - -config OR0_AM_4_GBYTES - depends on BR0_MACHINE_FCM - bool "4 gb" - -endchoice - -config OR0_XAM_SET - bool "Set unused bytes after address mask" -choice - prompt "Buffer control disable" - -config OR0_BCTLD_ASSERTED - bool "Asserted" - -config OR0_BCTLD_NOT_ASSERTED - bool "Not asserted" - -endchoice - -endif - -if BR0_MACHINE_GPCM || BR0_MACHINE_FCM - -choice - prompt "Cycle length in bus clocks" - -config OR0_SCY_0 - bool "No wait states" - -config OR0_SCY_1 - bool "1 wait state" - -config OR0_SCY_2 - bool "2 wait states" - -config OR0_SCY_3 - bool "3 wait states" - -config OR0_SCY_4 - bool "4 wait states" - -config OR0_SCY_5 - bool "5 wait states" - -config OR0_SCY_6 - bool "6 wait states" - -config OR0_SCY_7 - bool "7 wait states" - -config OR0_SCY_8 - depends on BR0_MACHINE_GPCM - bool "8 wait states" - -config OR0_SCY_9 - depends on BR0_MACHINE_GPCM - bool "9 wait states" - -config OR0_SCY_10 - depends on BR0_MACHINE_GPCM - bool "10 wait states" - -config OR0_SCY_11 - depends on BR0_MACHINE_GPCM - bool "11 wait states" - -config OR0_SCY_12 - depends on BR0_MACHINE_GPCM - bool "12 wait states" - -config OR0_SCY_13 - depends on BR0_MACHINE_GPCM - bool "13 wait states" - -config OR0_SCY_14 - depends on BR0_MACHINE_GPCM - bool "14 wait states" - -config OR0_SCY_15 - depends on BR0_MACHINE_GPCM - bool "15 wait states" - -endchoice - -endif # BR0_MACHINE_GPCM || BR0_MACHINE_FCM - -if BR0_MACHINE_GPCM - -choice - prompt "Chip select negotiation time" - -config OR0_CSNT_NORMAL - bool "Normal" - -config OR0_CSNT_EARLIER - bool "Earlier" - -endchoice - -choice - prompt "Address to chip-select setup" - -config OR0_ACS_SAME_TIME - bool "At the same time" - -config OR0_ACS_HALF_CYCLE_EARLIER - bool "Half of a bus clock cycle earlier" - -config OR0_ACS_QUARTER_CYCLE_EARLIER - bool "Half/Quarter of a bus clock cycle earlier" - -endchoice - -choice - prompt "Extra address to check-select setup" - -config OR0_XACS_NORMAL - bool "Normal" - -config OR0_XACS_EXTENDED - bool "Extended" - -endchoice - -choice - prompt "External address termination" - -config OR0_SETA_INTERNAL - bool "Access is terminated internally" - -config OR0_SETA_EXTERNAL - bool "Access is terminated externally" - -endchoice - -endif # BR0_MACHINE_GPCM - -if BR0_MACHINE_FCM - -choice - prompt "NAND Flash EEPROM page size" - -config OR0_PGS_SMALL - bool "Small page device" - -config OR0_PGS_LARGE - bool "Large page device" - -endchoice - -choice - prompt "Chip select to command time" - -config OR0_CSCT_1_CYCLE - depends on OR0_TRLX_NORMAL - bool "1 cycle" - -config OR0_CSCT_2_CYCLE - depends on OR0_TRLX_RELAXED - bool "2 cycles" - -config OR0_CSCT_4_CYCLE - depends on OR0_TRLX_NORMAL - bool "4 cycles" - -config OR0_CSCT_8_CYCLE - depends on OR0_TRLX_RELAXED - bool "8 cycles" - -endchoice - -choice - prompt "Command setup time" - -config OR0_CST_COINCIDENT - depends on OR0_TRLX_NORMAL - bool "Coincident with any command" - -config OR0_CST_QUARTER_CLOCK - depends on OR0_TRLX_NORMAL - bool "0.25 clocks after" - -config OR0_CST_HALF_CLOCK - depends on OR0_TRLX_RELAXED - bool "0.5 clocks after" - -config OR0_CST_ONE_CLOCK - depends on OR0_TRLX_RELAXED - bool "1 clock after" - -endchoice - -choice - prompt "Command hold time" - -config OR0_CHT_HALF_CLOCK - depends on OR0_TRLX_NORMAL - bool "0.5 clocks before" - -config OR0_CHT_ONE_CLOCK - depends on OR0_TRLX_NORMAL - bool "1 clock before" - -config OR0_CHT_ONE_HALF_CLOCK - depends on OR0_TRLX_RELAXED - bool "1.5 clocks before" - -config OR0_CHT_TWO_CLOCK - depends on OR0_TRLX_RELAXED - bool "2 clocks before" - -endchoice - -choice - prompt "Reset setup time" - -config OR0_RST_THREE_QUARTER_CLOCK - depends on OR0_TRLX_NORMAL - bool "0.75 clocks prior" - -config OR0_RST_ONE_HALF_CLOCK - depends on OR0_TRLX_RELAXED - bool "0.5 clocks prior" - -config OR0_RST_ONE_CLOCK - bool "1 clock prior" - -endchoice - -endif # BR0_MACHINE_FCM - -if BR0_MACHINE_UPM - -choice - prompt "Burst inhibit" - -config OR0_BI_BURSTSUPPORT - bool "Support burst access" - -config OR0_BI_BURSTINHIBIT - bool "Inhibit burst access" - -endchoice - -endif # BR0_MACHINE_UPM - -if BR0_MACHINE_SDRAM - -choice - prompt "Number of column address lines" - -config OR0_COLS_7 - bool "7" - -config OR0_COLS_8 - bool "8" - -config OR0_COLS_9 - bool "9" - -config OR0_COLS_10 - bool "10" - -config OR0_COLS_11 - bool "11" - -config OR0_COLS_12 - bool "12" - -config OR0_COLS_13 - bool "13" - -config OR0_COLS_14 - bool "14" - -endchoice - -choice - prompt "Number of rows address lines" - -config OR0_ROWS_9 - bool "9" - -config OR0_ROWS_10 - bool "10" - -config OR0_ROWS_11 - bool "11" - -config OR0_ROWS_12 - bool "12" - -config OR0_ROWS_13 - bool "13" - -config OR0_ROWS_14 - bool "14" - -config OR0_ROWS_15 - bool "15" - -endchoice - -choice - prompt "Page mode select" - -config OR0_PMSEL_BTB - bool "Back-to-back" - -config OR0_PMSEL_KEPT_OPEN - bool "Page kept open until page miss or refresh" - -endchoice - -endif # BR0_MACHINE_SDRAM - -choice - prompt "Relaxed timing" - -config OR0_TRLX_NORMAL - bool "Normal" - -config OR0_TRLX_RELAXED - bool "Relaxed" - -endchoice - -choice - prompt "Extended hold time" - -config OR0_EHTR_NORMAL - depends on OR0_TRLX_NORMAL - bool "Normal" - -config OR0_EHTR_1_CYCLE - depends on OR0_TRLX_NORMAL - bool "1 idle clock cycle inserted" - -config OR0_EHTR_4_CYCLE - depends on OR0_TRLX_RELAXED - bool "4 idle clock cycles inserted" - -config OR0_EHTR_8_CYCLE - depends on OR0_TRLX_RELAXED - bool "8 idle clock cycles inserted" - -endchoice - -if !ARCH_MPC8308 - -choice - prompt "External address latch delay" - -config OR0_EAD_NONE - bool "None" - -config OR0_EAD_EXTRA - bool "Extra" - -endchoice - -endif # !ARCH_MPC8308 - -endif # ELBC_BR0_OR0 - -config BR0_PORTSIZE - hex - default 0x800 if BR0_PORTSIZE_8BIT - default 0x1000 if BR0_PORTSIZE_16BIT - default 0x1800 if BR0_PORTSIZE_32BIT - -config BR0_ERRORCHECKING - hex - default 0x0 if !BR0_MACHINE_FCM - default 0x0 if BR0_ERRORCHECKING_DISABLED - default 0x200 if BR0_ERRORCHECKING_ECC_CHECKING - default 0x400 if BR0_ERRORCHECKING_BOTH - -config BR0_WRITE_PROTECT_BIT - hex - default 0x0 if !BR0_WRITE_PROTECT - default 0x100 if BR0_WRITE_PROTECT - -config BR0_MACHINE - hex - default 0x0 if BR0_MACHINE_GPCM - default 0x20 if BR0_MACHINE_FCM - default 0x60 if BR0_MACHINE_SDRAM - default 0x80 if BR0_MACHINE_UPMA - default 0xa0 if BR0_MACHINE_UPMB - default 0xc0 if BR0_MACHINE_UPMC - -config BR0_ATOMIC - hex - default 0x0 if !ARCH_MPC8313 && !ARCH_MPC8323 && !ARCH_MPC8360 - default 0x0 if BR0_ATOMIC_NONE - default 0x4 if BR0_ATOMIC_RAWA - default 0x8 if BR0_ATOMIC_WARA - -config BR0_VALID_BIT - hex - default 0x0 if !ELBC_BR0_OR0 - default 0x1 if ELBC_BR0_OR0 - -config OR0_AM - hex - default 0xffff8000 if OR0_AM_32_KBYTES && !BR0_MACHINE_SDRAM - default 0xffff0000 if OR0_AM_64_KBYTES - default 0xfffe0000 if OR0_AM_128_KBYTES - default 0xfffc0000 if OR0_AM_256_KBYTES - default 0xfff80000 if OR0_AM_512_KBYTES - default 0xfff00000 if OR0_AM_1_MBYTES - default 0xffe00000 if OR0_AM_2_MBYTES - default 0xffc00000 if OR0_AM_4_MBYTES - default 0xff800000 if OR0_AM_8_MBYTES - default 0xff000000 if OR0_AM_16_MBYTES - default 0xfe000000 if OR0_AM_32_MBYTES - default 0xfc000000 if OR0_AM_64_MBYTES - default 0xf8000000 if OR0_AM_128_MBYTES - default 0xf0000000 if OR0_AM_256_MBYTES - default 0xe0000000 if OR0_AM_512_MBYTES - default 0xc0000000 if OR0_AM_1_GBYTES - default 0x80000000 if OR0_AM_2_GBYTES - default 0x00000000 if OR0_AM_4_GBYTES - -config OR0_XAM - hex - default 0x0 if !OR0_XAM_SET - default 0x6000 if OR0_XAM_SET - -config OR0_BCTLD - hex - default 0x0 if OR0_BCTLD_ASSERTED - default 0x1000 if OR0_BCTLD_NOT_ASSERTED - -config OR0_BI - hex - default 0x0 if !BR0_MACHINE_UPM - default 0x0 if OR0_BI_BURSTSUPPORT - default 0x100 if OR0_BI_BURSTINHIBIT - -config OR0_COLS - hex - default 0x0 if !BR0_MACHINE_SDRAM - default 0x0 if OR0_COLS_7 - default 0x400 if OR0_COLS_8 - default 0x800 if OR0_COLS_9 - default 0xc00 if OR0_COLS_10 - default 0x1000 if OR0_COLS_11 - default 0x1400 if OR0_COLS_12 - default 0x1800 if OR0_COLS_13 - default 0x1c00 if OR0_COLS_14 - -config OR0_ROWS - hex - default 0x0 if !BR0_MACHINE_SDRAM - default 0x0 if OR0_ROWS_9 - default 0x40 if OR0_ROWS_10 - default 0x80 if OR0_ROWS_11 - default 0xc0 if OR0_ROWS_12 - default 0x100 if OR0_ROWS_13 - default 0x140 if OR0_ROWS_14 - default 0x180 if OR0_ROWS_15 - -config OR0_PMSEL - hex - default 0x0 if !BR0_MACHINE_SDRAM - default 0x0 if OR0_PMSEL_BTB - default 0x20 if OR0_PMSEL_KEPT_OPEN - -config OR0_SCY - hex - default 0x0 if !BR0_MACHINE_GPCM && !BR0_MACHINE_FCM - default 0x0 if OR0_SCY_0 - default 0x10 if OR0_SCY_1 - default 0x20 if OR0_SCY_2 - default 0x30 if OR0_SCY_3 - default 0x40 if OR0_SCY_4 - default 0x50 if OR0_SCY_5 - default 0x60 if OR0_SCY_6 - default 0x70 if OR0_SCY_7 - default 0x80 if OR0_SCY_8 - default 0x90 if OR0_SCY_9 - default 0xa0 if OR0_SCY_10 - default 0xb0 if OR0_SCY_11 - default 0xc0 if OR0_SCY_12 - default 0xd0 if OR0_SCY_13 - default 0xe0 if OR0_SCY_14 - default 0xf0 if OR0_SCY_15 - -config OR0_PGS - hex - default 0x0 if !BR0_MACHINE_FCM - default 0x0 if OR0_PGS_SMALL - default 0x400 if OR0_PGS_LARGE - -config OR0_CSCT - hex - default 0x0 if !BR0_MACHINE_FCM - default 0x0 if OR0_CSCT_1_CYCLE - default 0x0 if OR0_CSCT_2_CYCLE - default 0x200 if OR0_CSCT_4_CYCLE - default 0x200 if OR0_CSCT_8_CYCLE - -config OR0_CST - hex - default 0x0 if !BR0_MACHINE_FCM - default 0x0 if OR0_CST_COINCIDENT - default 0x100 if OR0_CST_QUARTER_CLOCK - default 0x0 if OR0_CST_HALF_CLOCK - default 0x100 if OR0_CST_ONE_CLOCK - -config OR0_CHT - hex - default 0x0 if !BR0_MACHINE_FCM - default 0x0 if OR0_CHT_HALF_CLOCK - default 0x80 if OR0_CHT_ONE_CLOCK - default 0x0 if OR0_CHT_ONE_HALF_CLOCK - default 0x80 if OR0_CHT_TWO_CLOCK - -config OR0_RST - hex - default 0x0 if !BR0_MACHINE_FCM - default 0x0 if OR0_RST_THREE_QUARTER_CLOCK - default 0x8 if OR0_RST_ONE_CLOCK - default 0x0 if OR0_RST_ONE_HALF_CLOCK - -config OR0_CSNT - hex - default 0x0 if !BR0_MACHINE_GPCM - default 0x0 if OR0_CSNT_NORMAL - default 0x800 if OR0_CSNT_EARLIER - -config OR0_ACS - hex - default 0x0 if !BR0_MACHINE_GPCM - default 0x0 if OR0_ACS_SAME_TIME - default 0x400 if OR0_ACS_QUARTER_CYCLE_EARLIER - default 0x600 if OR0_ACS_HALF_CYCLE_EARLIER - -config OR0_XACS - hex - default 0x0 if !BR0_MACHINE_GPCM - default 0x0 if OR0_XACS_NORMAL - default 0x100 if OR0_XACS_EXTENDED - -config OR0_SETA - hex - default 0x0 if !BR0_MACHINE_GPCM - default 0x0 if OR0_SETA_INTERNAL - default 0x8 if OR0_SETA_EXTERNAL - -config OR0_TRLX - hex - default 0x0 if OR0_TRLX_NORMAL - default 0x4 if OR0_TRLX_RELAXED - -config OR0_EHTR - hex - default 0x0 if OR0_EHTR_NORMAL - default 0x2 if OR0_EHTR_1_CYCLE - default 0x0 if OR0_EHTR_4_CYCLE - default 0x2 if OR0_EHTR_8_CYCLE - -config OR0_EAD - hex - default 0x0 if ARCH_MPC8308 - default 0x0 if OR0_EAD_NONE - default 0x1 if OR0_EAD_EXTRA diff --git a/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc1 b/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc1 deleted file mode 100644 index 1dc3e75076..0000000000 --- a/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc1 +++ /dev/null @@ -1,733 +0,0 @@ -menuconfig ELBC_BR1_OR1 - bool "ELBC BR1/OR1" - -if ELBC_BR1_OR1 - -config BR1_OR1_NAME - string "Identifier" - -config BR1_OR1_BASE - hex "Port base" - -choice - prompt "Port size" - -config BR1_PORTSIZE_8BIT - bool "8-bit" - -config BR1_PORTSIZE_16BIT - depends on !BR1_MACHINE_FCM - bool "16-bit" - - -config BR1_PORTSIZE_32BIT - depends on !BR1_MACHINE_FCM - depends on ARCH_MPC8360 || ARCH_MPC8379 - bool "32-bit" - -endchoice - -if BR1_MACHINE_FCM - -choice - prompt "Data Error Checking" - -config BR1_ERRORCHECKING_DISABLED - bool "Disabled" - -config BR1_ERRORCHECKING_ECC_CHECKING - bool "ECC checking / No ECC generation" - -config BR1_ERRORCHECKING_BOTH - bool "ECC checking and generation" - -endchoice - -endif - -config BR1_WRITE_PROTECT - bool "Write-protect" - -config BR1_MACHINE_UPM - bool - -choice - prompt "Machine select" - -config BR1_MACHINE_GPCM - bool "GPCM" - -config BR1_MACHINE_FCM - depends on !ARCH_MPC832X && !ARCH_MPC8360 - bool "FCM" - -config BR1_MACHINE_SDRAM - depends on ARCH_MPC8360 - bool "SDRAM" - -config BR1_MACHINE_UPMA - select BR1_MACHINE_UPM - bool "UPM (A)" - -config BR1_MACHINE_UPMB - select BR1_MACHINE_UPM - bool "UPM (B)" - -config BR1_MACHINE_UPMC - select BR1_MACHINE_UPM - bool "UPM (C)" - -endchoice - -if ARCH_MPC8313 || ARCH_MPC8323 || ARCH_MPC8360 - -choice - prompt "Atomic operations" - -config BR1_ATOMIC_NONE - bool "No atomic operations" - -config BR1_ATOMIC_RAWA - bool "Read-after-write-atomic" - -config BR1_ATOMIC_WARA - bool "Write-after-read-atomic" - -endchoice - -endif - -if BR1_MACHINE_GPCM || BR1_MACHINE_FCM || BR1_MACHINE_UPM || BR1_MACHINE_SDRAM - -choice - prompt "Address mask" - -config OR1_AM_32_KBYTES - depends on !BR1_MACHINE_SDRAM - bool "32 kb" - -config OR1_AM_64_KBYTES - bool "64 kb" - -config OR1_AM_128_KBYTES - bool "128 kb" - -config OR1_AM_256_KBYTES - bool "256 kb" - -config OR1_AM_512_KBYTES - bool "512 kb" - -config OR1_AM_1_MBYTES - bool "1 mb" - -config OR1_AM_2_MBYTES - bool "2 mb" - -config OR1_AM_4_MBYTES - bool "4 mb" - -config OR1_AM_8_MBYTES - bool "8 mb" - -config OR1_AM_16_MBYTES - bool "16 mb" - -config OR1_AM_32_MBYTES - bool "32 mb" - -config OR1_AM_64_MBYTES - bool "64 mb" - -# XXX: Some boards define 128MB AM with GPCM, even though it should not be -# possible according to the manuals -config OR1_AM_128_MBYTES - bool "128 mb" - -# XXX: Some boards define 256MB AM with GPCM, even though it should not be -# possible according to the manuals -config OR1_AM_256_MBYTES - bool "256 mb" - -config OR1_AM_512_MBYTES - depends on BR1_MACHINE_FCM - bool "512 mb" - -# XXX: Some boards define 1GB AM with GPCM, even though it should not be -# possible according to the manuals -config OR1_AM_1_GBYTES - bool "1 gb" - -config OR1_AM_2_GBYTES - depends on BR1_MACHINE_FCM - bool "2 gb" - -config OR1_AM_4_GBYTES - depends on BR1_MACHINE_FCM - bool "4 gb" - -endchoice - -config OR1_XAM_SET - bool "Set unused bytes after address mask" -choice - prompt "Buffer control disable" - -config OR1_BCTLD_ASSERTED - bool "Asserted" - -config OR1_BCTLD_NOT_ASSERTED - bool "Not asserted" - -endchoice - -endif - -if BR1_MACHINE_GPCM || BR1_MACHINE_FCM - -choice - prompt "Cycle length in bus clocks" - -config OR1_SCY_0 - bool "No wait states" - -config OR1_SCY_1 - bool "1 wait state" - -config OR1_SCY_2 - bool "2 wait states" - -config OR1_SCY_3 - bool "3 wait states" - -config OR1_SCY_4 - bool "4 wait states" - -config OR1_SCY_5 - bool "5 wait states" - -config OR1_SCY_6 - bool "6 wait states" - -config OR1_SCY_7 - bool "7 wait states" - -config OR1_SCY_8 - depends on BR1_MACHINE_GPCM - bool "8 wait states" - -config OR1_SCY_9 - depends on BR1_MACHINE_GPCM - bool "9 wait states" - -config OR1_SCY_10 - depends on BR1_MACHINE_GPCM - bool "10 wait states" - -config OR1_SCY_11 - depends on BR1_MACHINE_GPCM - bool "11 wait states" - -config OR1_SCY_12 - depends on BR1_MACHINE_GPCM - bool "12 wait states" - -config OR1_SCY_13 - depends on BR1_MACHINE_GPCM - bool "13 wait states" - -config OR1_SCY_14 - depends on BR1_MACHINE_GPCM - bool "14 wait states" - -config OR1_SCY_15 - depends on BR1_MACHINE_GPCM - bool "15 wait states" - -endchoice - -endif # BR1_MACHINE_GPCM || BR1_MACHINE_FCM - -if BR1_MACHINE_GPCM - -choice - prompt "Chip select negotiation time" - -config OR1_CSNT_NORMAL - bool "Normal" - -config OR1_CSNT_EARLIER - bool "Earlier" - -endchoice - -choice - prompt "Address to chip-select setup" - -config OR1_ACS_SAME_TIME - bool "At the same time" - -config OR1_ACS_HALF_CYCLE_EARLIER - bool "Half of a bus clock cycle earlier" - -config OR1_ACS_QUARTER_CYCLE_EARLIER - bool "Half/Quarter of a bus clock cycle earlier" - -endchoice - -choice - prompt "Extra address to check-select setup" - -config OR1_XACS_NORMAL - bool "Normal" - -config OR1_XACS_EXTENDED - bool "Extended" - -endchoice - -choice - prompt "External address termination" - -config OR1_SETA_INTERNAL - bool "Access is terminated internally" - -config OR1_SETA_EXTERNAL - bool "Access is terminated externally" - -endchoice - -endif # BR1_MACHINE_GPCM - -if BR1_MACHINE_FCM - -choice - prompt "NAND Flash EEPROM page size" - -config OR1_PGS_SMALL - bool "Small page device" - -config OR1_PGS_LARGE - bool "Large page device" - -endchoice - -choice - prompt "Chip select to command time" - -config OR1_CSCT_1_CYCLE - depends on OR1_TRLX_NORMAL - bool "1 cycle" - -config OR1_CSCT_2_CYCLE - depends on OR1_TRLX_RELAXED - bool "2 cycles" - -config OR1_CSCT_4_CYCLE - depends on OR1_TRLX_NORMAL - bool "4 cycles" - -config OR1_CSCT_8_CYCLE - depends on OR1_TRLX_RELAXED - bool "8 cycles" - -endchoice - -choice - prompt "Command setup time" - -config OR1_CST_COINCIDENT - depends on OR1_TRLX_NORMAL - bool "Coincident with any command" - -config OR1_CST_QUARTER_CLOCK - depends on OR1_TRLX_NORMAL - bool "0.25 clocks after" - -config OR1_CST_HALF_CLOCK - depends on OR1_TRLX_RELAXED - bool "0.5 clocks after" - -config OR1_CST_ONE_CLOCK - depends on OR1_TRLX_RELAXED - bool "1 clock after" - -endchoice - -choice - prompt "Command hold time" - -config OR1_CHT_HALF_CLOCK - depends on OR1_TRLX_NORMAL - bool "0.5 clocks before" - -config OR1_CHT_ONE_CLOCK - depends on OR1_TRLX_NORMAL - bool "1 clock before" - -config OR1_CHT_ONE_HALF_CLOCK - depends on OR1_TRLX_RELAXED - bool "1.5 clocks before" - -config OR1_CHT_TWO_CLOCK - depends on OR1_TRLX_RELAXED - bool "2 clocks before" - -endchoice - -choice - prompt "Reset setup time" - -config OR1_RST_THREE_QUARTER_CLOCK - depends on OR1_TRLX_NORMAL - bool "0.75 clocks prior" - -config OR1_RST_ONE_HALF_CLOCK - depends on OR1_TRLX_RELAXED - bool "0.5 clocks prior" - -config OR1_RST_ONE_CLOCK - bool "1 clock prior" - -endchoice - -endif # BR1_MACHINE_FCM - -if BR1_MACHINE_UPM - -choice - prompt "Burst inhibit" - -config OR1_BI_BURSTSUPPORT - bool "Support burst access" - -config OR1_BI_BURSTINHIBIT - bool "Inhibit burst access" - -endchoice - -endif # BR1_MACHINE_UPM - -if BR1_MACHINE_SDRAM - -choice - prompt "Number of column address lines" - -config OR1_COLS_7 - bool "7" - -config OR1_COLS_8 - bool "8" - -config OR1_COLS_9 - bool "9" - -config OR1_COLS_10 - bool "10" - -config OR1_COLS_11 - bool "11" - -config OR1_COLS_12 - bool "12" - -config OR1_COLS_13 - bool "13" - -config OR1_COLS_14 - bool "14" - -endchoice - -choice - prompt "Number of rows address lines" - -config OR1_ROWS_9 - bool "9" - -config OR1_ROWS_10 - bool "10" - -config OR1_ROWS_11 - bool "11" - -config OR1_ROWS_12 - bool "12" - -config OR1_ROWS_13 - bool "13" - -config OR1_ROWS_14 - bool "14" - -config OR1_ROWS_15 - bool "15" - -endchoice - -choice - prompt "Page mode select" - -config OR1_PMSEL_BTB - bool "Back-to-back" - -config OR1_PMSEL_KEPT_OPEN - bool "Page kept open until page miss or refresh" - -endchoice - -endif # BR1_MACHINE_SDRAM - -choice - prompt "Relaxed timing" - -config OR1_TRLX_NORMAL - bool "Normal" - -config OR1_TRLX_RELAXED - bool "Relaxed" - -endchoice - -choice - prompt "Extended hold time" - -config OR1_EHTR_NORMAL - depends on OR1_TRLX_NORMAL - bool "Normal" - -config OR1_EHTR_1_CYCLE - depends on OR1_TRLX_NORMAL - bool "1 idle clock cycle inserted" - -config OR1_EHTR_4_CYCLE - depends on OR1_TRLX_RELAXED - bool "4 idle clock cycles inserted" - -config OR1_EHTR_8_CYCLE - depends on OR1_TRLX_RELAXED - bool "8 idle clock cycles inserted" - -endchoice - -if !ARCH_MPC8308 - -choice - prompt "External address latch delay" - -config OR1_EAD_NONE - bool "None" - -config OR1_EAD_EXTRA - bool "Extra" - -endchoice - -endif # !ARCH_MPC8308 - -endif # ELBC_BR1_OR1 - -config BR1_PORTSIZE - hex - default 0x800 if BR1_PORTSIZE_8BIT - default 0x1000 if BR1_PORTSIZE_16BIT - default 0x1800 if BR1_PORTSIZE_32BIT - -config BR1_ERRORCHECKING - hex - default 0x0 if !BR1_MACHINE_FCM - default 0x0 if BR1_ERRORCHECKING_DISABLED - default 0x200 if BR1_ERRORCHECKING_ECC_CHECKING - default 0x400 if BR1_ERRORCHECKING_BOTH - -config BR1_WRITE_PROTECT_BIT - hex - default 0x0 if !BR1_WRITE_PROTECT - default 0x100 if BR1_WRITE_PROTECT - -config BR1_MACHINE - hex - default 0x0 if BR1_MACHINE_GPCM - default 0x20 if BR1_MACHINE_FCM - default 0x60 if BR1_MACHINE_SDRAM - default 0x80 if BR1_MACHINE_UPMA - default 0xa0 if BR1_MACHINE_UPMB - default 0xc0 if BR1_MACHINE_UPMC - -config BR1_ATOMIC - hex - default 0x0 if !ARCH_MPC8313 && !ARCH_MPC8323 && !ARCH_MPC8360 - default 0x0 if BR1_ATOMIC_NONE - default 0x4 if BR1_ATOMIC_RAWA - default 0x8 if BR1_ATOMIC_WARA - -config BR1_VALID_BIT - hex - default 0x0 if !ELBC_BR1_OR1 - default 0x1 if ELBC_BR1_OR1 - -config OR1_AM - hex - default 0xffff8000 if OR1_AM_32_KBYTES && !BR1_MACHINE_SDRAM - default 0xffff0000 if OR1_AM_64_KBYTES - default 0xfffe0000 if OR1_AM_128_KBYTES - default 0xfffc0000 if OR1_AM_256_KBYTES - default 0xfff80000 if OR1_AM_512_KBYTES - default 0xfff00000 if OR1_AM_1_MBYTES - default 0xffe00000 if OR1_AM_2_MBYTES - default 0xffc00000 if OR1_AM_4_MBYTES - default 0xff800000 if OR1_AM_8_MBYTES - default 0xff000000 if OR1_AM_16_MBYTES - default 0xfe000000 if OR1_AM_32_MBYTES - default 0xfc000000 if OR1_AM_64_MBYTES - default 0xf8000000 if OR1_AM_128_MBYTES - default 0xf0000000 if OR1_AM_256_MBYTES - default 0xe0000000 if OR1_AM_512_MBYTES - default 0xc0000000 if OR1_AM_1_GBYTES - default 0x80000000 if OR1_AM_2_GBYTES - default 0x00000000 if OR1_AM_4_GBYTES - -config OR1_XAM - hex - default 0x0 if !OR1_XAM_SET - default 0x6000 if OR1_XAM_SET - -config OR1_BCTLD - hex - default 0x0 if OR1_BCTLD_ASSERTED - default 0x1000 if OR1_BCTLD_NOT_ASSERTED - -config OR1_BI - hex - default 0x0 if !BR1_MACHINE_UPM - default 0x0 if OR1_BI_BURSTSUPPORT - default 0x100 if OR1_BI_BURSTINHIBIT - -config OR1_COLS - hex - default 0x0 if !BR1_MACHINE_SDRAM - default 0x0 if OR1_COLS_7 - default 0x400 if OR1_COLS_8 - default 0x800 if OR1_COLS_9 - default 0xc00 if OR1_COLS_10 - default 0x1000 if OR1_COLS_11 - default 0x1400 if OR1_COLS_12 - default 0x1800 if OR1_COLS_13 - default 0x1c00 if OR1_COLS_14 - -config OR1_ROWS - hex - default 0x0 if !BR1_MACHINE_SDRAM - default 0x0 if OR1_ROWS_9 - default 0x40 if OR1_ROWS_10 - default 0x80 if OR1_ROWS_11 - default 0xc0 if OR1_ROWS_12 - default 0x100 if OR1_ROWS_13 - default 0x140 if OR1_ROWS_14 - default 0x180 if OR1_ROWS_15 - -config OR1_PMSEL - hex - default 0x0 if !BR1_MACHINE_SDRAM - default 0x0 if OR1_PMSEL_BTB - default 0x20 if OR1_PMSEL_KEPT_OPEN - -config OR1_SCY - hex - default 0x0 if !BR1_MACHINE_GPCM && !BR1_MACHINE_FCM - default 0x0 if OR1_SCY_0 - default 0x10 if OR1_SCY_1 - default 0x20 if OR1_SCY_2 - default 0x30 if OR1_SCY_3 - default 0x40 if OR1_SCY_4 - default 0x50 if OR1_SCY_5 - default 0x60 if OR1_SCY_6 - default 0x70 if OR1_SCY_7 - default 0x80 if OR1_SCY_8 - default 0x90 if OR1_SCY_9 - default 0xa0 if OR1_SCY_10 - default 0xb0 if OR1_SCY_11 - default 0xc0 if OR1_SCY_12 - default 0xd0 if OR1_SCY_13 - default 0xe0 if OR1_SCY_14 - default 0xf0 if OR1_SCY_15 - -config OR1_PGS - hex - default 0x0 if !BR1_MACHINE_FCM - default 0x0 if OR1_PGS_SMALL - default 0x400 if OR1_PGS_LARGE - -config OR1_CSCT - hex - default 0x0 if !BR1_MACHINE_FCM - default 0x0 if OR1_CSCT_1_CYCLE - default 0x0 if OR1_CSCT_2_CYCLE - default 0x200 if OR1_CSCT_4_CYCLE - default 0x200 if OR1_CSCT_8_CYCLE - -config OR1_CST - hex - default 0x0 if !BR1_MACHINE_FCM - default 0x0 if OR1_CST_COINCIDENT - default 0x100 if OR1_CST_QUARTER_CLOCK - default 0x0 if OR1_CST_HALF_CLOCK - default 0x100 if OR1_CST_ONE_CLOCK - -config OR1_CHT - hex - default 0x0 if !BR1_MACHINE_FCM - default 0x0 if OR1_CHT_HALF_CLOCK - default 0x80 if OR1_CHT_ONE_CLOCK - default 0x0 if OR1_CHT_ONE_HALF_CLOCK - default 0x80 if OR1_CHT_TWO_CLOCK - -config OR1_RST - hex - default 0x0 if !BR1_MACHINE_FCM - default 0x0 if OR1_RST_THREE_QUARTER_CLOCK - default 0x8 if OR1_RST_ONE_CLOCK - default 0x0 if OR1_RST_ONE_HALF_CLOCK - -config OR1_CSNT - hex - default 0x0 if !BR1_MACHINE_GPCM - default 0x0 if OR1_CSNT_NORMAL - default 0x800 if OR1_CSNT_EARLIER - -config OR1_ACS - hex - default 0x0 if !BR1_MACHINE_GPCM - default 0x0 if OR1_ACS_SAME_TIME - default 0x400 if OR1_ACS_QUARTER_CYCLE_EARLIER - default 0x600 if OR1_ACS_HALF_CYCLE_EARLIER - -config OR1_XACS - hex - default 0x0 if !BR1_MACHINE_GPCM - default 0x0 if OR1_XACS_NORMAL - default 0x100 if OR1_XACS_EXTENDED - -config OR1_SETA - hex - default 0x0 if !BR1_MACHINE_GPCM - default 0x0 if OR1_SETA_INTERNAL - default 0x8 if OR1_SETA_EXTERNAL - -config OR1_TRLX - hex - default 0x0 if OR1_TRLX_NORMAL - default 0x4 if OR1_TRLX_RELAXED - -config OR1_EHTR - hex - default 0x0 if OR1_EHTR_NORMAL - default 0x2 if OR1_EHTR_1_CYCLE - default 0x0 if OR1_EHTR_4_CYCLE - default 0x2 if OR1_EHTR_8_CYCLE - -config OR1_EAD - hex - default 0x0 if ARCH_MPC8308 - default 0x0 if OR1_EAD_NONE - default 0x1 if OR1_EAD_EXTRA diff --git a/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc2 b/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc2 deleted file mode 100644 index a9b2546cd8..0000000000 --- a/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc2 +++ /dev/null @@ -1,733 +0,0 @@ -menuconfig ELBC_BR2_OR2 - bool "ELBC BR2/OR2" - -if ELBC_BR2_OR2 - -config BR2_OR2_NAME - string "Identifier" - -config BR2_OR2_BASE - hex "Port base" - -choice - prompt "Port size" - -config BR2_PORTSIZE_8BIT - bool "8-bit" - -config BR2_PORTSIZE_16BIT - depends on !BR2_MACHINE_FCM - bool "16-bit" - - -config BR2_PORTSIZE_32BIT - depends on !BR2_MACHINE_FCM - depends on ARCH_MPC8360 || ARCH_MPC8379 - bool "32-bit" - -endchoice - -if BR2_MACHINE_FCM - -choice - prompt "Data Error Checking" - -config BR2_ERRORCHECKING_DISABLED - bool "Disabled" - -config BR2_ERRORCHECKING_ECC_CHECKING - bool "ECC checking / No ECC generation" - -config BR2_ERRORCHECKING_BOTH - bool "ECC checking and generation" - -endchoice - -endif - -config BR2_WRITE_PROTECT - bool "Write-protect" - -config BR2_MACHINE_UPM - bool - -choice - prompt "Machine select" - -config BR2_MACHINE_GPCM - bool "GPCM" - -config BR2_MACHINE_FCM - depends on !ARCH_MPC832X && !ARCH_MPC8360 - bool "FCM" - -config BR2_MACHINE_SDRAM - depends on ARCH_MPC8360 - bool "SDRAM" - -config BR2_MACHINE_UPMA - select BR2_MACHINE_UPM - bool "UPM (A)" - -config BR2_MACHINE_UPMB - select BR2_MACHINE_UPM - bool "UPM (B)" - -config BR2_MACHINE_UPMC - select BR2_MACHINE_UPM - bool "UPM (C)" - -endchoice - -if ARCH_MPC8313 || ARCH_MPC8323 || ARCH_MPC8360 - -choice - prompt "Atomic operations" - -config BR2_ATOMIC_NONE - bool "No atomic operations" - -config BR2_ATOMIC_RAWA - bool "Read-after-write-atomic" - -config BR2_ATOMIC_WARA - bool "Write-after-read-atomic" - -endchoice - -endif - -if BR2_MACHINE_GPCM || BR2_MACHINE_FCM || BR2_MACHINE_UPM || BR2_MACHINE_SDRAM - -choice - prompt "Address mask" - -config OR2_AM_32_KBYTES - depends on !BR2_MACHINE_SDRAM - bool "32 kb" - -config OR2_AM_64_KBYTES - bool "64 kb" - -config OR2_AM_128_KBYTES - bool "128 kb" - -config OR2_AM_256_KBYTES - bool "256 kb" - -config OR2_AM_512_KBYTES - bool "512 kb" - -config OR2_AM_1_MBYTES - bool "1 mb" - -config OR2_AM_2_MBYTES - bool "2 mb" - -config OR2_AM_4_MBYTES - bool "4 mb" - -config OR2_AM_8_MBYTES - bool "8 mb" - -config OR2_AM_16_MBYTES - bool "16 mb" - -config OR2_AM_32_MBYTES - bool "32 mb" - -config OR2_AM_64_MBYTES - bool "64 mb" - -# XXX: Some boards define 128MB AM with GPCM, even though it should not be -# possible according to the manuals -config OR2_AM_128_MBYTES - bool "128 mb" - -# XXX: Some boards define 256MB AM with GPCM, even though it should not be -# possible according to the manuals -config OR2_AM_256_MBYTES - bool "256 mb" - -config OR2_AM_512_MBYTES - depends on BR2_MACHINE_FCM - bool "512 mb" - -# XXX: Some boards define 1GB AM with GPCM, even though it should not be -# possible according to the manuals -config OR2_AM_1_GBYTES - bool "1 gb" - -config OR2_AM_2_GBYTES - depends on BR2_MACHINE_FCM - bool "2 gb" - -config OR2_AM_4_GBYTES - depends on BR2_MACHINE_FCM - bool "4 gb" - -endchoice - -config OR2_XAM_SET - bool "Set unused bytes after address mask" -choice - prompt "Buffer control disable" - -config OR2_BCTLD_ASSERTED - bool "Asserted" - -config OR2_BCTLD_NOT_ASSERTED - bool "Not asserted" - -endchoice - -endif - -if BR2_MACHINE_GPCM || BR2_MACHINE_FCM - -choice - prompt "Cycle length in bus clocks" - -config OR2_SCY_0 - bool "No wait states" - -config OR2_SCY_1 - bool "1 wait state" - -config OR2_SCY_2 - bool "2 wait states" - -config OR2_SCY_3 - bool "3 wait states" - -config OR2_SCY_4 - bool "4 wait states" - -config OR2_SCY_5 - bool "5 wait states" - -config OR2_SCY_6 - bool "6 wait states" - -config OR2_SCY_7 - bool "7 wait states" - -config OR2_SCY_8 - depends on BR2_MACHINE_GPCM - bool "8 wait states" - -config OR2_SCY_9 - depends on BR2_MACHINE_GPCM - bool "9 wait states" - -config OR2_SCY_10 - depends on BR2_MACHINE_GPCM - bool "10 wait states" - -config OR2_SCY_11 - depends on BR2_MACHINE_GPCM - bool "11 wait states" - -config OR2_SCY_12 - depends on BR2_MACHINE_GPCM - bool "12 wait states" - -config OR2_SCY_13 - depends on BR2_MACHINE_GPCM - bool "13 wait states" - -config OR2_SCY_14 - depends on BR2_MACHINE_GPCM - bool "14 wait states" - -config OR2_SCY_15 - depends on BR2_MACHINE_GPCM - bool "15 wait states" - -endchoice - -endif # BR2_MACHINE_GPCM || BR2_MACHINE_FCM - -if BR2_MACHINE_GPCM - -choice - prompt "Chip select negotiation time" - -config OR2_CSNT_NORMAL - bool "Normal" - -config OR2_CSNT_EARLIER - bool "Earlier" - -endchoice - -choice - prompt "Address to chip-select setup" - -config OR2_ACS_SAME_TIME - bool "At the same time" - -config OR2_ACS_HALF_CYCLE_EARLIER - bool "Half of a bus clock cycle earlier" - -config OR2_ACS_QUARTER_CYCLE_EARLIER - bool "Half/Quarter of a bus clock cycle earlier" - -endchoice - -choice - prompt "Extra address to check-select setup" - -config OR2_XACS_NORMAL - bool "Normal" - -config OR2_XACS_EXTENDED - bool "Extended" - -endchoice - -choice - prompt "External address termination" - -config OR2_SETA_INTERNAL - bool "Access is terminated internally" - -config OR2_SETA_EXTERNAL - bool "Access is terminated externally" - -endchoice - -endif # BR2_MACHINE_GPCM - -if BR2_MACHINE_FCM - -choice - prompt "NAND Flash EEPROM page size" - -config OR2_PGS_SMALL - bool "Small page device" - -config OR2_PGS_LARGE - bool "Large page device" - -endchoice - -choice - prompt "Chip select to command time" - -config OR2_CSCT_1_CYCLE - depends on OR2_TRLX_NORMAL - bool "1 cycle" - -config OR2_CSCT_2_CYCLE - depends on OR2_TRLX_RELAXED - bool "2 cycles" - -config OR2_CSCT_4_CYCLE - depends on OR2_TRLX_NORMAL - bool "4 cycles" - -config OR2_CSCT_8_CYCLE - depends on OR2_TRLX_RELAXED - bool "8 cycles" - -endchoice - -choice - prompt "Command setup time" - -config OR2_CST_COINCIDENT - depends on OR2_TRLX_NORMAL - bool "Coincident with any command" - -config OR2_CST_QUARTER_CLOCK - depends on OR2_TRLX_NORMAL - bool "0.25 clocks after" - -config OR2_CST_HALF_CLOCK - depends on OR2_TRLX_RELAXED - bool "0.5 clocks after" - -config OR2_CST_ONE_CLOCK - depends on OR2_TRLX_RELAXED - bool "1 clock after" - -endchoice - -choice - prompt "Command hold time" - -config OR2_CHT_HALF_CLOCK - depends on OR2_TRLX_NORMAL - bool "0.5 clocks before" - -config OR2_CHT_ONE_CLOCK - depends on OR2_TRLX_NORMAL - bool "1 clock before" - -config OR2_CHT_ONE_HALF_CLOCK - depends on OR2_TRLX_RELAXED - bool "1.5 clocks before" - -config OR2_CHT_TWO_CLOCK - depends on OR2_TRLX_RELAXED - bool "2 clocks before" - -endchoice - -choice - prompt "Reset setup time" - -config OR2_RST_THREE_QUARTER_CLOCK - depends on OR2_TRLX_NORMAL - bool "0.75 clocks prior" - -config OR2_RST_ONE_HALF_CLOCK - depends on OR2_TRLX_RELAXED - bool "0.5 clocks prior" - -config OR2_RST_ONE_CLOCK - bool "1 clock prior" - -endchoice - -endif # BR2_MACHINE_FCM - -if BR2_MACHINE_UPM - -choice - prompt "Burst inhibit" - -config OR2_BI_BURSTSUPPORT - bool "Support burst access" - -config OR2_BI_BURSTINHIBIT - bool "Inhibit burst access" - -endchoice - -endif # BR2_MACHINE_UPM - -if BR2_MACHINE_SDRAM - -choice - prompt "Number of column address lines" - -config OR2_COLS_7 - bool "7" - -config OR2_COLS_8 - bool "8" - -config OR2_COLS_9 - bool "9" - -config OR2_COLS_10 - bool "10" - -config OR2_COLS_11 - bool "11" - -config OR2_COLS_12 - bool "12" - -config OR2_COLS_13 - bool "13" - -config OR2_COLS_14 - bool "14" - -endchoice - -choice - prompt "Number of rows address lines" - -config OR2_ROWS_9 - bool "9" - -config OR2_ROWS_10 - bool "10" - -config OR2_ROWS_11 - bool "11" - -config OR2_ROWS_12 - bool "12" - -config OR2_ROWS_13 - bool "13" - -config OR2_ROWS_14 - bool "14" - -config OR2_ROWS_15 - bool "15" - -endchoice - -choice - prompt "Page mode select" - -config OR2_PMSEL_BTB - bool "Back-to-back" - -config OR2_PMSEL_KEPT_OPEN - bool "Page kept open until page miss or refresh" - -endchoice - -endif # BR2_MACHINE_SDRAM - -choice - prompt "Relaxed timing" - -config OR2_TRLX_NORMAL - bool "Normal" - -config OR2_TRLX_RELAXED - bool "Relaxed" - -endchoice - -choice - prompt "Extended hold time" - -config OR2_EHTR_NORMAL - depends on OR2_TRLX_NORMAL - bool "Normal" - -config OR2_EHTR_1_CYCLE - depends on OR2_TRLX_NORMAL - bool "1 idle clock cycle inserted" - -config OR2_EHTR_4_CYCLE - depends on OR2_TRLX_RELAXED - bool "4 idle clock cycles inserted" - -config OR2_EHTR_8_CYCLE - depends on OR2_TRLX_RELAXED - bool "8 idle clock cycles inserted" - -endchoice - -if !ARCH_MPC8308 - -choice - prompt "External address latch delay" - -config OR2_EAD_NONE - bool "None" - -config OR2_EAD_EXTRA - bool "Extra" - -endchoice - -endif # !ARCH_MPC8308 - -endif # ELBC_BR2_OR2 - -config BR2_PORTSIZE - hex - default 0x800 if BR2_PORTSIZE_8BIT - default 0x1000 if BR2_PORTSIZE_16BIT - default 0x1800 if BR2_PORTSIZE_32BIT - -config BR2_ERRORCHECKING - hex - default 0x0 if !BR2_MACHINE_FCM - default 0x0 if BR2_ERRORCHECKING_DISABLED - default 0x200 if BR2_ERRORCHECKING_ECC_CHECKING - default 0x400 if BR2_ERRORCHECKING_BOTH - -config BR2_WRITE_PROTECT_BIT - hex - default 0x0 if !BR2_WRITE_PROTECT - default 0x100 if BR2_WRITE_PROTECT - -config BR2_MACHINE - hex - default 0x0 if BR2_MACHINE_GPCM - default 0x20 if BR2_MACHINE_FCM - default 0x60 if BR2_MACHINE_SDRAM - default 0x80 if BR2_MACHINE_UPMA - default 0xa0 if BR2_MACHINE_UPMB - default 0xc0 if BR2_MACHINE_UPMC - -config BR2_ATOMIC - hex - default 0x0 if !ARCH_MPC8313 && !ARCH_MPC8323 && !ARCH_MPC8360 - default 0x0 if BR2_ATOMIC_NONE - default 0x4 if BR2_ATOMIC_RAWA - default 0x8 if BR2_ATOMIC_WARA - -config BR2_VALID_BIT - hex - default 0x0 if !ELBC_BR2_OR2 - default 0x1 if ELBC_BR2_OR2 - -config OR2_AM - hex - default 0xffff8000 if OR2_AM_32_KBYTES && !BR2_MACHINE_SDRAM - default 0xffff0000 if OR2_AM_64_KBYTES - default 0xfffe0000 if OR2_AM_128_KBYTES - default 0xfffc0000 if OR2_AM_256_KBYTES - default 0xfff80000 if OR2_AM_512_KBYTES - default 0xfff00000 if OR2_AM_1_MBYTES - default 0xffe00000 if OR2_AM_2_MBYTES - default 0xffc00000 if OR2_AM_4_MBYTES - default 0xff800000 if OR2_AM_8_MBYTES - default 0xff000000 if OR2_AM_16_MBYTES - default 0xfe000000 if OR2_AM_32_MBYTES - default 0xfc000000 if OR2_AM_64_MBYTES - default 0xf8000000 if OR2_AM_128_MBYTES - default 0xf0000000 if OR2_AM_256_MBYTES - default 0xe0000000 if OR2_AM_512_MBYTES - default 0xc0000000 if OR2_AM_1_GBYTES - default 0x80000000 if OR2_AM_2_GBYTES - default 0x00000000 if OR2_AM_4_GBYTES - -config OR2_XAM - hex - default 0x0 if !OR2_XAM_SET - default 0x6000 if OR2_XAM_SET - -config OR2_BCTLD - hex - default 0x0 if OR2_BCTLD_ASSERTED - default 0x1000 if OR2_BCTLD_NOT_ASSERTED - -config OR2_BI - hex - default 0x0 if !BR2_MACHINE_UPM - default 0x0 if OR2_BI_BURSTSUPPORT - default 0x100 if OR2_BI_BURSTINHIBIT - -config OR2_COLS - hex - default 0x0 if !BR2_MACHINE_SDRAM - default 0x0 if OR2_COLS_7 - default 0x400 if OR2_COLS_8 - default 0x800 if OR2_COLS_9 - default 0xc00 if OR2_COLS_10 - default 0x1000 if OR2_COLS_11 - default 0x1400 if OR2_COLS_12 - default 0x1800 if OR2_COLS_13 - default 0x1c00 if OR2_COLS_14 - -config OR2_ROWS - hex - default 0x0 if !BR2_MACHINE_SDRAM - default 0x0 if OR2_ROWS_9 - default 0x40 if OR2_ROWS_10 - default 0x80 if OR2_ROWS_11 - default 0xc0 if OR2_ROWS_12 - default 0x100 if OR2_ROWS_13 - default 0x140 if OR2_ROWS_14 - default 0x180 if OR2_ROWS_15 - -config OR2_PMSEL - hex - default 0x0 if !BR2_MACHINE_SDRAM - default 0x0 if OR2_PMSEL_BTB - default 0x20 if OR2_PMSEL_KEPT_OPEN - -config OR2_SCY - hex - default 0x0 if !BR2_MACHINE_GPCM && !BR2_MACHINE_FCM - default 0x0 if OR2_SCY_0 - default 0x10 if OR2_SCY_1 - default 0x20 if OR2_SCY_2 - default 0x30 if OR2_SCY_3 - default 0x40 if OR2_SCY_4 - default 0x50 if OR2_SCY_5 - default 0x60 if OR2_SCY_6 - default 0x70 if OR2_SCY_7 - default 0x80 if OR2_SCY_8 - default 0x90 if OR2_SCY_9 - default 0xa0 if OR2_SCY_10 - default 0xb0 if OR2_SCY_11 - default 0xc0 if OR2_SCY_12 - default 0xd0 if OR2_SCY_13 - default 0xe0 if OR2_SCY_14 - default 0xf0 if OR2_SCY_15 - -config OR2_PGS - hex - default 0x0 if !BR2_MACHINE_FCM - default 0x0 if OR2_PGS_SMALL - default 0x400 if OR2_PGS_LARGE - -config OR2_CSCT - hex - default 0x0 if !BR2_MACHINE_FCM - default 0x0 if OR2_CSCT_1_CYCLE - default 0x0 if OR2_CSCT_2_CYCLE - default 0x200 if OR2_CSCT_4_CYCLE - default 0x200 if OR2_CSCT_8_CYCLE - -config OR2_CST - hex - default 0x0 if !BR2_MACHINE_FCM - default 0x0 if OR2_CST_COINCIDENT - default 0x100 if OR2_CST_QUARTER_CLOCK - default 0x0 if OR2_CST_HALF_CLOCK - default 0x100 if OR2_CST_ONE_CLOCK - -config OR2_CHT - hex - default 0x0 if !BR2_MACHINE_FCM - default 0x0 if OR2_CHT_HALF_CLOCK - default 0x80 if OR2_CHT_ONE_CLOCK - default 0x0 if OR2_CHT_ONE_HALF_CLOCK - default 0x80 if OR2_CHT_TWO_CLOCK - -config OR2_RST - hex - default 0x0 if !BR2_MACHINE_FCM - default 0x0 if OR2_RST_THREE_QUARTER_CLOCK - default 0x8 if OR2_RST_ONE_CLOCK - default 0x0 if OR2_RST_ONE_HALF_CLOCK - -config OR2_CSNT - hex - default 0x0 if !BR2_MACHINE_GPCM - default 0x0 if OR2_CSNT_NORMAL - default 0x800 if OR2_CSNT_EARLIER - -config OR2_ACS - hex - default 0x0 if !BR2_MACHINE_GPCM - default 0x0 if OR2_ACS_SAME_TIME - default 0x400 if OR2_ACS_QUARTER_CYCLE_EARLIER - default 0x600 if OR2_ACS_HALF_CYCLE_EARLIER - -config OR2_XACS - hex - default 0x0 if !BR2_MACHINE_GPCM - default 0x0 if OR2_XACS_NORMAL - default 0x100 if OR2_XACS_EXTENDED - -config OR2_SETA - hex - default 0x0 if !BR2_MACHINE_GPCM - default 0x0 if OR2_SETA_INTERNAL - default 0x8 if OR2_SETA_EXTERNAL - -config OR2_TRLX - hex - default 0x0 if OR2_TRLX_NORMAL - default 0x4 if OR2_TRLX_RELAXED - -config OR2_EHTR - hex - default 0x0 if OR2_EHTR_NORMAL - default 0x2 if OR2_EHTR_1_CYCLE - default 0x0 if OR2_EHTR_4_CYCLE - default 0x2 if OR2_EHTR_8_CYCLE - -config OR2_EAD - hex - default 0x0 if ARCH_MPC8308 - default 0x0 if OR2_EAD_NONE - default 0x1 if OR2_EAD_EXTRA diff --git a/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc3 b/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc3 deleted file mode 100644 index 94442cdc97..0000000000 --- a/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc3 +++ /dev/null @@ -1,733 +0,0 @@ -menuconfig ELBC_BR3_OR3 - bool "ELBC BR3/OR3" - -if ELBC_BR3_OR3 - -config BR3_OR3_NAME - string "Identifier" - -config BR3_OR3_BASE - hex "Port base" - -choice - prompt "Port size" - -config BR3_PORTSIZE_8BIT - bool "8-bit" - -config BR3_PORTSIZE_16BIT - depends on !BR3_MACHINE_FCM - bool "16-bit" - - -config BR3_PORTSIZE_32BIT - depends on !BR3_MACHINE_FCM - depends on ARCH_MPC8360 || ARCH_MPC8379 - bool "32-bit" - -endchoice - -if BR3_MACHINE_FCM - -choice - prompt "Data Error Checking" - -config BR3_ERRORCHECKING_DISABLED - bool "Disabled" - -config BR3_ERRORCHECKING_ECC_CHECKING - bool "ECC checking / No ECC generation" - -config BR3_ERRORCHECKING_BOTH - bool "ECC checking and generation" - -endchoice - -endif - -config BR3_WRITE_PROTECT - bool "Write-protect" - -config BR3_MACHINE_UPM - bool - -choice - prompt "Machine select" - -config BR3_MACHINE_GPCM - bool "GPCM" - -config BR3_MACHINE_FCM - depends on !ARCH_MPC832X && !ARCH_MPC8360 - bool "FCM" - -config BR3_MACHINE_SDRAM - depends on ARCH_MPC8360 - bool "SDRAM" - -config BR3_MACHINE_UPMA - select BR3_MACHINE_UPM - bool "UPM (A)" - -config BR3_MACHINE_UPMB - select BR3_MACHINE_UPM - bool "UPM (B)" - -config BR3_MACHINE_UPMC - select BR3_MACHINE_UPM - bool "UPM (C)" - -endchoice - -if ARCH_MPC8313 || ARCH_MPC8323 || ARCH_MPC8360 - -choice - prompt "Atomic operations" - -config BR3_ATOMIC_NONE - bool "No atomic operations" - -config BR3_ATOMIC_RAWA - bool "Read-after-write-atomic" - -config BR3_ATOMIC_WARA - bool "Write-after-read-atomic" - -endchoice - -endif - -if BR3_MACHINE_GPCM || BR3_MACHINE_FCM || BR3_MACHINE_UPM || BR3_MACHINE_SDRAM - -choice - prompt "Address mask" - -config OR3_AM_32_KBYTES - depends on !BR3_MACHINE_SDRAM - bool "32 kb" - -config OR3_AM_64_KBYTES - bool "64 kb" - -config OR3_AM_128_KBYTES - bool "128 kb" - -config OR3_AM_256_KBYTES - bool "256 kb" - -config OR3_AM_512_KBYTES - bool "512 kb" - -config OR3_AM_1_MBYTES - bool "1 mb" - -config OR3_AM_2_MBYTES - bool "2 mb" - -config OR3_AM_4_MBYTES - bool "4 mb" - -config OR3_AM_8_MBYTES - bool "8 mb" - -config OR3_AM_16_MBYTES - bool "16 mb" - -config OR3_AM_32_MBYTES - bool "32 mb" - -config OR3_AM_64_MBYTES - bool "64 mb" - -# XXX: Some boards define 128MB AM with GPCM, even though it should not be -# possible according to the manuals -config OR3_AM_128_MBYTES - bool "128 mb" - -# XXX: Some boards define 256MB AM with GPCM, even though it should not be -# possible according to the manuals -config OR3_AM_256_MBYTES - bool "256 mb" - -config OR3_AM_512_MBYTES - depends on BR3_MACHINE_FCM - bool "512 mb" - -# XXX: Some boards define 1GB AM with GPCM, even though it should not be -# possible according to the manuals -config OR3_AM_1_GBYTES - bool "1 gb" - -config OR3_AM_2_GBYTES - depends on BR3_MACHINE_FCM - bool "2 gb" - -config OR3_AM_4_GBYTES - depends on BR3_MACHINE_FCM - bool "4 gb" - -endchoice - -config OR3_XAM_SET - bool "Set unused bytes after address mask" -choice - prompt "Buffer control disable" - -config OR3_BCTLD_ASSERTED - bool "Asserted" - -config OR3_BCTLD_NOT_ASSERTED - bool "Not asserted" - -endchoice - -endif - -if BR3_MACHINE_GPCM || BR3_MACHINE_FCM - -choice - prompt "Cycle length in bus clocks" - -config OR3_SCY_0 - bool "No wait states" - -config OR3_SCY_1 - bool "1 wait state" - -config OR3_SCY_2 - bool "2 wait states" - -config OR3_SCY_3 - bool "3 wait states" - -config OR3_SCY_4 - bool "4 wait states" - -config OR3_SCY_5 - bool "5 wait states" - -config OR3_SCY_6 - bool "6 wait states" - -config OR3_SCY_7 - bool "7 wait states" - -config OR3_SCY_8 - depends on BR3_MACHINE_GPCM - bool "8 wait states" - -config OR3_SCY_9 - depends on BR3_MACHINE_GPCM - bool "9 wait states" - -config OR3_SCY_10 - depends on BR3_MACHINE_GPCM - bool "10 wait states" - -config OR3_SCY_11 - depends on BR3_MACHINE_GPCM - bool "11 wait states" - -config OR3_SCY_12 - depends on BR3_MACHINE_GPCM - bool "12 wait states" - -config OR3_SCY_13 - depends on BR3_MACHINE_GPCM - bool "13 wait states" - -config OR3_SCY_14 - depends on BR3_MACHINE_GPCM - bool "14 wait states" - -config OR3_SCY_15 - depends on BR3_MACHINE_GPCM - bool "15 wait states" - -endchoice - -endif # BR3_MACHINE_GPCM || BR3_MACHINE_FCM - -if BR3_MACHINE_GPCM - -choice - prompt "Chip select negotiation time" - -config OR3_CSNT_NORMAL - bool "Normal" - -config OR3_CSNT_EARLIER - bool "Earlier" - -endchoice - -choice - prompt "Address to chip-select setup" - -config OR3_ACS_SAME_TIME - bool "At the same time" - -config OR3_ACS_HALF_CYCLE_EARLIER - bool "Half of a bus clock cycle earlier" - -config OR3_ACS_QUARTER_CYCLE_EARLIER - bool "Half/Quarter of a bus clock cycle earlier" - -endchoice - -choice - prompt "Extra address to check-select setup" - -config OR3_XACS_NORMAL - bool "Normal" - -config OR3_XACS_EXTENDED - bool "Extended" - -endchoice - -choice - prompt "External address termination" - -config OR3_SETA_INTERNAL - bool "Access is terminated internally" - -config OR3_SETA_EXTERNAL - bool "Access is terminated externally" - -endchoice - -endif # BR3_MACHINE_GPCM - -if BR3_MACHINE_FCM - -choice - prompt "NAND Flash EEPROM page size" - -config OR3_PGS_SMALL - bool "Small page device" - -config OR3_PGS_LARGE - bool "Large page device" - -endchoice - -choice - prompt "Chip select to command time" - -config OR3_CSCT_1_CYCLE - depends on OR3_TRLX_NORMAL - bool "1 cycle" - -config OR3_CSCT_2_CYCLE - depends on OR3_TRLX_RELAXED - bool "2 cycles" - -config OR3_CSCT_4_CYCLE - depends on OR3_TRLX_NORMAL - bool "4 cycles" - -config OR3_CSCT_8_CYCLE - depends on OR3_TRLX_RELAXED - bool "8 cycles" - -endchoice - -choice - prompt "Command setup time" - -config OR3_CST_COINCIDENT - depends on OR3_TRLX_NORMAL - bool "Coincident with any command" - -config OR3_CST_QUARTER_CLOCK - depends on OR3_TRLX_NORMAL - bool "0.25 clocks after" - -config OR3_CST_HALF_CLOCK - depends on OR3_TRLX_RELAXED - bool "0.5 clocks after" - -config OR3_CST_ONE_CLOCK - depends on OR3_TRLX_RELAXED - bool "1 clock after" - -endchoice - -choice - prompt "Command hold time" - -config OR3_CHT_HALF_CLOCK - depends on OR3_TRLX_NORMAL - bool "0.5 clocks before" - -config OR3_CHT_ONE_CLOCK - depends on OR3_TRLX_NORMAL - bool "1 clock before" - -config OR3_CHT_ONE_HALF_CLOCK - depends on OR3_TRLX_RELAXED - bool "1.5 clocks before" - -config OR3_CHT_TWO_CLOCK - depends on OR3_TRLX_RELAXED - bool "2 clocks before" - -endchoice - -choice - prompt "Reset setup time" - -config OR3_RST_THREE_QUARTER_CLOCK - depends on OR3_TRLX_NORMAL - bool "0.75 clocks prior" - -config OR3_RST_ONE_HALF_CLOCK - depends on OR3_TRLX_RELAXED - bool "0.5 clocks prior" - -config OR3_RST_ONE_CLOCK - bool "1 clock prior" - -endchoice - -endif # BR3_MACHINE_FCM - -if BR3_MACHINE_UPM - -choice - prompt "Burst inhibit" - -config OR3_BI_BURSTSUPPORT - bool "Support burst access" - -config OR3_BI_BURSTINHIBIT - bool "Inhibit burst access" - -endchoice - -endif # BR3_MACHINE_UPM - -if BR3_MACHINE_SDRAM - -choice - prompt "Number of column address lines" - -config OR3_COLS_7 - bool "7" - -config OR3_COLS_8 - bool "8" - -config OR3_COLS_9 - bool "9" - -config OR3_COLS_10 - bool "10" - -config OR3_COLS_11 - bool "11" - -config OR3_COLS_12 - bool "12" - -config OR3_COLS_13 - bool "13" - -config OR3_COLS_14 - bool "14" - -endchoice - -choice - prompt "Number of rows address lines" - -config OR3_ROWS_9 - bool "9" - -config OR3_ROWS_10 - bool "10" - -config OR3_ROWS_11 - bool "11" - -config OR3_ROWS_12 - bool "12" - -config OR3_ROWS_13 - bool "13" - -config OR3_ROWS_14 - bool "14" - -config OR3_ROWS_15 - bool "15" - -endchoice - -choice - prompt "Page mode select" - -config OR3_PMSEL_BTB - bool "Back-to-back" - -config OR3_PMSEL_KEPT_OPEN - bool "Page kept open until page miss or refresh" - -endchoice - -endif # BR3_MACHINE_SDRAM - -choice - prompt "Relaxed timing" - -config OR3_TRLX_NORMAL - bool "Normal" - -config OR3_TRLX_RELAXED - bool "Relaxed" - -endchoice - -choice - prompt "Extended hold time" - -config OR3_EHTR_NORMAL - depends on OR3_TRLX_NORMAL - bool "Normal" - -config OR3_EHTR_1_CYCLE - depends on OR3_TRLX_NORMAL - bool "1 idle clock cycle inserted" - -config OR3_EHTR_4_CYCLE - depends on OR3_TRLX_RELAXED - bool "4 idle clock cycles inserted" - -config OR3_EHTR_8_CYCLE - depends on OR3_TRLX_RELAXED - bool "8 idle clock cycles inserted" - -endchoice - -if !ARCH_MPC8308 - -choice - prompt "External address latch delay" - -config OR3_EAD_NONE - bool "None" - -config OR3_EAD_EXTRA - bool "Extra" - -endchoice - -endif # !ARCH_MPC8308 - -endif # ELBC_BR3_OR3 - -config BR3_PORTSIZE - hex - default 0x800 if BR3_PORTSIZE_8BIT - default 0x1000 if BR3_PORTSIZE_16BIT - default 0x1800 if BR3_PORTSIZE_32BIT - -config BR3_ERRORCHECKING - hex - default 0x0 if !BR3_MACHINE_FCM - default 0x0 if BR3_ERRORCHECKING_DISABLED - default 0x200 if BR3_ERRORCHECKING_ECC_CHECKING - default 0x400 if BR3_ERRORCHECKING_BOTH - -config BR3_WRITE_PROTECT_BIT - hex - default 0x0 if !BR3_WRITE_PROTECT - default 0x100 if BR3_WRITE_PROTECT - -config BR3_MACHINE - hex - default 0x0 if BR3_MACHINE_GPCM - default 0x20 if BR3_MACHINE_FCM - default 0x60 if BR3_MACHINE_SDRAM - default 0x80 if BR3_MACHINE_UPMA - default 0xa0 if BR3_MACHINE_UPMB - default 0xc0 if BR3_MACHINE_UPMC - -config BR3_ATOMIC - hex - default 0x0 if !ARCH_MPC8313 && !ARCH_MPC8323 && !ARCH_MPC8360 - default 0x0 if BR3_ATOMIC_NONE - default 0x4 if BR3_ATOMIC_RAWA - default 0x8 if BR3_ATOMIC_WARA - -config BR3_VALID_BIT - hex - default 0x0 if !ELBC_BR3_OR3 - default 0x1 if ELBC_BR3_OR3 - -config OR3_AM - hex - default 0xffff8000 if OR3_AM_32_KBYTES && !BR3_MACHINE_SDRAM - default 0xffff0000 if OR3_AM_64_KBYTES - default 0xfffe0000 if OR3_AM_128_KBYTES - default 0xfffc0000 if OR3_AM_256_KBYTES - default 0xfff80000 if OR3_AM_512_KBYTES - default 0xfff00000 if OR3_AM_1_MBYTES - default 0xffe00000 if OR3_AM_2_MBYTES - default 0xffc00000 if OR3_AM_4_MBYTES - default 0xff800000 if OR3_AM_8_MBYTES - default 0xff000000 if OR3_AM_16_MBYTES - default 0xfe000000 if OR3_AM_32_MBYTES - default 0xfc000000 if OR3_AM_64_MBYTES - default 0xf8000000 if OR3_AM_128_MBYTES - default 0xf0000000 if OR3_AM_256_MBYTES - default 0xe0000000 if OR3_AM_512_MBYTES - default 0xc0000000 if OR3_AM_1_GBYTES - default 0x80000000 if OR3_AM_2_GBYTES - default 0x00000000 if OR3_AM_4_GBYTES - -config OR3_XAM - hex - default 0x0 if !OR3_XAM_SET - default 0x6000 if OR3_XAM_SET - -config OR3_BCTLD - hex - default 0x0 if OR3_BCTLD_ASSERTED - default 0x1000 if OR3_BCTLD_NOT_ASSERTED - -config OR3_BI - hex - default 0x0 if !BR3_MACHINE_UPM - default 0x0 if OR3_BI_BURSTSUPPORT - default 0x100 if OR3_BI_BURSTINHIBIT - -config OR3_COLS - hex - default 0x0 if !BR3_MACHINE_SDRAM - default 0x0 if OR3_COLS_7 - default 0x400 if OR3_COLS_8 - default 0x800 if OR3_COLS_9 - default 0xc00 if OR3_COLS_10 - default 0x1000 if OR3_COLS_11 - default 0x1400 if OR3_COLS_12 - default 0x1800 if OR3_COLS_13 - default 0x1c00 if OR3_COLS_14 - -config OR3_ROWS - hex - default 0x0 if !BR3_MACHINE_SDRAM - default 0x0 if OR3_ROWS_9 - default 0x40 if OR3_ROWS_10 - default 0x80 if OR3_ROWS_11 - default 0xc0 if OR3_ROWS_12 - default 0x100 if OR3_ROWS_13 - default 0x140 if OR3_ROWS_14 - default 0x180 if OR3_ROWS_15 - -config OR3_PMSEL - hex - default 0x0 if !BR3_MACHINE_SDRAM - default 0x0 if OR3_PMSEL_BTB - default 0x20 if OR3_PMSEL_KEPT_OPEN - -config OR3_SCY - hex - default 0x0 if !BR3_MACHINE_GPCM && !BR3_MACHINE_FCM - default 0x0 if OR3_SCY_0 - default 0x10 if OR3_SCY_1 - default 0x20 if OR3_SCY_2 - default 0x30 if OR3_SCY_3 - default 0x40 if OR3_SCY_4 - default 0x50 if OR3_SCY_5 - default 0x60 if OR3_SCY_6 - default 0x70 if OR3_SCY_7 - default 0x80 if OR3_SCY_8 - default 0x90 if OR3_SCY_9 - default 0xa0 if OR3_SCY_10 - default 0xb0 if OR3_SCY_11 - default 0xc0 if OR3_SCY_12 - default 0xd0 if OR3_SCY_13 - default 0xe0 if OR3_SCY_14 - default 0xf0 if OR3_SCY_15 - -config OR3_PGS - hex - default 0x0 if !BR3_MACHINE_FCM - default 0x0 if OR3_PGS_SMALL - default 0x400 if OR3_PGS_LARGE - -config OR3_CSCT - hex - default 0x0 if !BR3_MACHINE_FCM - default 0x0 if OR3_CSCT_1_CYCLE - default 0x0 if OR3_CSCT_2_CYCLE - default 0x200 if OR3_CSCT_4_CYCLE - default 0x200 if OR3_CSCT_8_CYCLE - -config OR3_CST - hex - default 0x0 if !BR3_MACHINE_FCM - default 0x0 if OR3_CST_COINCIDENT - default 0x100 if OR3_CST_QUARTER_CLOCK - default 0x0 if OR3_CST_HALF_CLOCK - default 0x100 if OR3_CST_ONE_CLOCK - -config OR3_CHT - hex - default 0x0 if !BR3_MACHINE_FCM - default 0x0 if OR3_CHT_HALF_CLOCK - default 0x80 if OR3_CHT_ONE_CLOCK - default 0x0 if OR3_CHT_ONE_HALF_CLOCK - default 0x80 if OR3_CHT_TWO_CLOCK - -config OR3_RST - hex - default 0x0 if !BR3_MACHINE_FCM - default 0x0 if OR3_RST_THREE_QUARTER_CLOCK - default 0x8 if OR3_RST_ONE_CLOCK - default 0x0 if OR3_RST_ONE_HALF_CLOCK - -config OR3_CSNT - hex - default 0x0 if !BR3_MACHINE_GPCM - default 0x0 if OR3_CSNT_NORMAL - default 0x800 if OR3_CSNT_EARLIER - -config OR3_ACS - hex - default 0x0 if !BR3_MACHINE_GPCM - default 0x0 if OR3_ACS_SAME_TIME - default 0x400 if OR3_ACS_QUARTER_CYCLE_EARLIER - default 0x600 if OR3_ACS_HALF_CYCLE_EARLIER - -config OR3_XACS - hex - default 0x0 if !BR3_MACHINE_GPCM - default 0x0 if OR3_XACS_NORMAL - default 0x100 if OR3_XACS_EXTENDED - -config OR3_SETA - hex - default 0x0 if !BR3_MACHINE_GPCM - default 0x0 if OR3_SETA_INTERNAL - default 0x8 if OR3_SETA_EXTERNAL - -config OR3_TRLX - hex - default 0x0 if OR3_TRLX_NORMAL - default 0x4 if OR3_TRLX_RELAXED - -config OR3_EHTR - hex - default 0x0 if OR3_EHTR_NORMAL - default 0x2 if OR3_EHTR_1_CYCLE - default 0x0 if OR3_EHTR_4_CYCLE - default 0x2 if OR3_EHTR_8_CYCLE - -config OR3_EAD - hex - default 0x0 if ARCH_MPC8308 - default 0x0 if OR3_EAD_NONE - default 0x1 if OR3_EAD_EXTRA diff --git a/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc4 b/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc4 deleted file mode 100644 index 5d69385a23..0000000000 --- a/arch/powerpc/cpu/mpc83xx/elbc/Kconfig.elbc4 +++ /dev/null @@ -1,733 +0,0 @@ -menuconfig ELBC_BR4_OR4 - bool "ELBC BR4/OR4" - -if ELBC_BR4_OR4 - -config BR4_OR4_NAME - string "Identifier" - -config BR4_OR4_BASE - hex "Port base" - -choice - prompt "Port size" - -config BR4_PORTSIZE_8BIT - bool "8-bit" - -config BR4_PORTSIZE_16BIT - depends on !BR4_MACHINE_FCM - bool "16-bit" - - -config BR4_PORTSIZE_32BIT - depends on !BR4_MACHINE_FCM - depends on ARCH_MPC8360 || ARCH_MPC8379 - bool "32-bit" - -endchoice - -if BR4_MACHINE_FCM - -choice - prompt "Data Error Checking" - -config BR4_ERRORCHECKING_DISABLED - bool "Disabled" - -config BR4_ERRORCHECKING_ECC_CHECKING - bool "ECC checking / No ECC generation" - -config BR4_ERRORCHECKING_BOTH - bool "ECC checking and generation" - -endchoice - -endif - -config BR4_WRITE_PROTECT - bool "Write-protect" - -config BR4_MACHINE_UPM - bool - -choice - prompt "Machine select" - -config BR4_MACHINE_GPCM - bool "GPCM" - -config BR4_MACHINE_FCM - depends on !ARCH_MPC832X && !ARCH_MPC8360 - bool "FCM" - -config BR4_MACHINE_SDRAM - depends on ARCH_MPC8360 - bool "SDRAM" - -config BR4_MACHINE_UPMA - select BR4_MACHINE_UPM - bool "UPM (A)" - -config BR4_MACHINE_UPMB - select BR4_MACHINE_UPM - bool "UPM (B)" - -config BR4_MACHINE_UPMC - select BR4_MACHINE_UPM - bool "UPM (C)" - -endchoice - -if ARCH_MPC8313 || ARCH_MPC8323 || ARCH_MPC8360 - -choice - prompt "Atomic operations" - -config BR4_ATOMIC_NONE - bool "No atomic operations" - -config BR4_ATOMIC_RAWA - bool "Read-after-write-atomic" - -config BR4_ATOMIC_WARA - bool "Write-after-read-atomic" - -endchoice - -endif - -if BR4_MACHINE_GPCM || BR4_MACHINE_FCM || BR4_MACHINE_UPM || BR4_MACHINE_SDRAM - -choice - prompt "Address mask" - -config OR4_AM_32_KBYTES - depends on !BR4_MACHINE_SDRAM - bool "32 kb" - -config OR4_AM_64_KBYTES - bool "64 kb" - -config OR4_AM_128_KBYTES - bool "128 kb" - -config OR4_AM_256_KBYTES - bool "256 kb" - -config OR4_AM_512_KBYTES - bool "512 kb" - -config OR4_AM_1_MBYTES - bool "1 mb" - -config OR4_AM_2_MBYTES - bool "2 mb" - -config OR4_AM_4_MBYTES - bool "4 mb" - -config OR4_AM_8_MBYTES - bool "8 mb" - -config OR4_AM_16_MBYTES - bool "16 mb" - -config OR4_AM_32_MBYTES - bool "32 mb" - -config OR4_AM_64_MBYTES - bool "64 mb" - -# XXX: Some boards define 128MB AM with GPCM, even though it should not be -# possible according to the manuals -config OR4_AM_128_MBYTES - bool "128 mb" - -# XXX: Some boards define 256MB AM with GPCM, even though it should not be -# possible according to the manuals -config OR4_AM_256_MBYTES - bool "256 mb" - -config OR4_AM_512_MBYTES - depends on BR4_MACHINE_FCM - bool "512 mb" - -# XXX: Some boards define 1GB AM with GPCM, even though it should not be -# possible according to the manuals -config OR4_AM_1_GBYTES - bool "1 gb" - -config OR4_AM_2_GBYTES - depends on BR4_MACHINE_FCM - bool "2 gb" - -config OR4_AM_4_GBYTES - depends on BR4_MACHINE_FCM - bool "4 gb" - -endchoice - -config OR4_XAM_SET - bool "Set unused bytes after address mask" -choice - prompt "Buffer control disable" - -config OR4_BCTLD_ASSERTED - bool "Asserted" - -config OR4_BCTLD_NOT_ASSERTED - bool "Not asserted" - -endchoice - -endif - -if BR4_MACHINE_GPCM || BR4_MACHINE_FCM - -choice - prompt "Cycle length in bus clocks" - -config OR4_SCY_0 - bool "No wait states" - -config OR4_SCY_1 - bool "1 wait state" - -config OR4_SCY_2 - bool "2 wait states" - -config OR4_SCY_3 - bool "3 wait states" - -config OR4_SCY_4 - bool "4 wait states" - -config OR4_SCY_5 - bool "5 wait states" - -config OR4_SCY_6 - bool "6 wait states" - -config OR4_SCY_7 - bool "7 wait states" - -config OR4_SCY_8 - depends on BR4_MACHINE_GPCM - bool "8 wait states" - -config OR4_SCY_9 - depends on BR4_MACHINE_GPCM - bool "9 wait states" - -config OR4_SCY_10 - depends on BR4_MACHINE_GPCM - bool "10 wait states" - -config OR4_SCY_11 - depends on BR4_MACHINE_GPCM - bool "11 wait states" - -config OR4_SCY_12 - depends on BR4_MACHINE_GPCM - bool "12 wait states" - -config OR4_SCY_13 - depends on BR4_MACHINE_GPCM - bool "13 wait states" - -config OR4_SCY_14 - depends on BR4_MACHINE_GPCM - bool "14 wait states" - -config OR4_SCY_15 - depends on BR4_MACHINE_GPCM - bool "15 wait states" - -endchoice - -endif # BR4_MACHINE_GPCM || BR4_MACHINE_FCM - -if BR4_MACHINE_GPCM - -choice - prompt "Chip select negotiation time" - -config OR4_CSNT_NORMAL - bool "Normal" - -config OR4_CSNT_EARLIER - bool "Earlier" - -endchoice - -choice - prompt "Address to chip-select setup" - -config OR4_ACS_SAME_TIME - bool "At the same time" - -config OR4_ACS_HALF_CYCLE_EARLIER - bool "Half of a bus clock cycle earlier" - -config OR4_ACS_QUARTER_CYCLE_EARLIER - bool "Half/Quarter of a bus clock cycle earlier" - -endchoice - -choice - prompt "Extra address to check-select setup" - -config OR4_XACS_NORMAL - bool "Normal" - -config OR4_XACS_EXTENDED - bool "Extended" - -endchoice - -choice - prompt "External address termination" - -config OR4_SETA_INTERNAL - bool "Access is terminated internally" - -config OR4_SETA_EXTERNAL - bool "Access is terminated externally" - -endchoice - -endif # BR4_MACHINE_GPCM - -if BR4_MACHINE_FCM - -choice - prompt "NAND Flash EEPROM page size" - -config OR4_PGS_SMALL - bool "Small page device" - -config OR4_PGS_LARGE - bool "Large page device" - -endchoice - -choice - prompt "Chip select to command time" - -config OR4_CSCT_1_CYCLE - depends on OR4_TRLX_NORMAL - bool "1 cycle" - -config OR4_CSCT_2_CYCLE - depends on OR4_TRLX_RELAXED - bool "2 cycles" - -config OR4_CSCT_4_CYCLE - depends on OR4_TRLX_NORMAL - bool "4 cycles" - -config OR4_CSCT_8_CYCLE - depends on OR4_TRLX_RELAXED - bool "8 cycles" - -endchoice - -choice - prompt "Command setup time" - -config OR4_CST_COINCIDENT - depends on OR4_TRLX_NORMAL - bool "Coincident with any command" - -config OR4_CST_QUARTER_CLOCK - depends on OR4_TRLX_NORMAL - bool "0.25 clocks after" - -config OR4_CST_HALF_CLOCK - depends on OR4_TRLX_RELAXED - bool "0.5 clocks after" - -config OR4_CST_ONE_CLOCK - depends on OR4_TRLX_RELAXED - bool "1 clock after" - -endchoice - -choice - prompt "Command hold time" - -config OR4_CHT_HALF_CLOCK - depends on OR4_TRLX_NORMAL - bool "0.5 clocks before" - -config OR4_CHT_ONE_CLOCK - depends on OR4_TRLX_NORMAL - bool "1 clock before" - -config OR4_CHT_ONE_HALF_CLOCK - depends on OR4_TRLX_RELAXED - bool "1.5 clocks before" - -config OR4_CHT_TWO_CLOCK - depends on OR4_TRLX_RELAXED - bool "2 clocks before" - -endchoice - -choice - prompt "Reset setup time" - -config OR4_RST_THREE_QUARTER_CLOCK - depends on OR4_TRLX_NORMAL - bool "0.75 clocks prior" - -config OR4_RST_ONE_HALF_CLOCK - depends on OR4_TRLX_RELAXED - bool "0.5 clocks prior" - -config OR4_RST_ONE_CLOCK - bool "1 clock prior" - -endchoice - -endif # BR4_MACHINE_FCM - -if BR4_MACHINE_UPM - -choice - prompt "Burst inhibit" - -config OR4_BI_BURSTSUPPORT - bool "Support burst access" - -config OR4_BI_BURSTINHIBIT - bool "Inhibit burst access" - -endchoice - -endif # BR4_MACHINE_UPM - -if BR4_MACHINE_SDRAM - -choice - prompt "Number of column address lines" - -config OR4_COLS_7 - bool "7" - -config OR4_COLS_8 - bool "8" - -config OR4_COLS_9 - bool "9" - -config OR4_COLS_10 - bool "10" - -config OR4_COLS_11 - bool "11" - -config OR4_COLS_12 - bool "12" - -config OR4_COLS_13 - bool "13" - -config OR4_COLS_14 - bool "14" - -endchoice - -choice - prompt "Number of rows address lines" - -config OR4_ROWS_9 - bool "9" - -config OR4_ROWS_10 - bool "10" - -config OR4_ROWS_11 - bool "11" - -config OR4_ROWS_12 - bool "12" - -config OR4_ROWS_13 - bool "13" - -config OR4_ROWS_14 - bool "14" - -config OR4_ROWS_15 - bool "15" - -endchoice - -choice - prompt "Page mode select" - -config OR4_PMSEL_BTB - bool "Back-to-back" - -config OR4_PMSEL_KEPT_OPEN - bool "Page kept open until page miss or refresh" - -endchoice - -endif # BR4_MACHINE_SDRAM - -choice - prompt "Relaxed timing" - -config OR4_TRLX_NORMAL - bool "Normal" - -config OR4_TRLX_RELAXED - bool "Relaxed" - -endchoice - -choice - prompt "Extended hold time" - -config OR4_EHTR_NORMAL - depends on OR4_TRLX_NORMAL - bool "Normal" - -config OR4_EHTR_1_CYCLE - depends on OR4_TRLX_NORMAL - bool "1 idle clock cycle inserted" - -config OR4_EHTR_4_CYCLE - depends on OR4_TRLX_RELAXED - bool "4 idle clock cycles inserted" - -config OR4_EHTR_8_CYCLE - depends on OR4_TRLX_RELAXED - bool "8 idle clock cycles inserted" - -endchoice - -if !ARCH_MPC8308 - -choice - prompt "External address latch delay" - -config OR4_EAD_NONE - bool "None" - -config OR4_EAD_EXTRA - bool "Extra" - -endchoice - -endif # !ARCH_MPC8308 - -endif # ELBC_BR4_OR4 - -config BR4_PORTSIZE - hex - default 0x800 if BR4_PORTSIZE_8BIT - default 0x1000 if BR4_PORTSIZE_16BIT - default 0x1800 if BR4_PORTSIZE_32BIT - -config BR4_ERRORCHECKING - hex - default 0x0 if !BR4_MACHINE_FCM - default 0x0 if BR4_ERRORCHECKING_DISABLED - default 0x200 if BR4_ERRORCHECKING_ECC_CHECKING - default 0x400 if BR4_ERRORCHECKING_BOTH - -config BR4_WRITE_PROTECT_BIT - hex - default 0x0 if !BR4_WRITE_PROTECT - default 0x100 if BR4_WRITE_PROTECT - -config BR4_MACHINE - hex - default 0x0 if BR4_MACHINE_GPCM - default 0x20 if BR4_MACHINE_FCM - default 0x60 if BR4_MACHINE_SDRAM - default 0x80 if BR4_MACHINE_UPMA - default 0xa0 if BR4_MACHINE_UPMB - default 0xc0 if BR4_MACHINE_UPMC - -config BR4_ATOMIC - hex - default 0x0 if !ARCH_MPC8313 && !ARCH_MPC8323 && !ARCH_MPC8360 - default 0x0 if BR4_ATOMIC_NONE - default 0x4 if BR4_ATOMIC_RAWA - default 0x8 if BR4_ATOMIC_WARA - -config BR4_VALID_BIT - hex - default 0x0 if !ELBC_BR4_OR4 - default 0x1 if ELBC_BR4_OR4 - -config OR4_AM - hex - default 0xffff8000 if OR4_AM_32_KBYTES && !BR4_MACHINE_SDRAM - default 0xffff0000 if OR4_AM_64_KBYTES - default 0xfffe0000 if OR4_AM_128_KBYTES - default 0xfffc0000 if OR4_AM_256_KBYTES - default 0xfff80000 if OR4_AM_512_KBYTES - default 0xfff00000 if OR4_AM_1_MBYTES - default 0xffe00000 if OR4_AM_2_MBYTES - default 0xffc00000 if OR4_AM_4_MBYTES - default 0xff800000 if OR4_AM_8_MBYTES - default 0xff000000 if OR4_AM_16_MBYTES - default 0xfe000000 if OR4_AM_32_MBYTES - default 0xfc000000 if OR4_AM_64_MBYTES - default 0xf8000000 if OR4_AM_128_MBYTES - default 0xf0000000 if OR4_AM_256_MBYTES - default 0xe0000000 if OR4_AM_512_MBYTES - default 0xc0000000 if OR4_AM_1_GBYTES - default 0x80000000 if OR4_AM_2_GBYTES - default 0x00000000 if OR4_AM_4_GBYTES - -config OR4_XAM - hex - default 0x0 if !OR4_XAM_SET - default 0x6000 if OR4_XAM_SET - -config OR4_BCTLD - hex - default 0x0 if OR4_BCTLD_ASSERTED - default 0x1000 if OR4_BCTLD_NOT_ASSERTED - -config OR4_BI - hex - default 0x0 if !BR4_MACHINE_UPM - default 0x0 if OR4_BI_BURSTSUPPORT - default 0x100 if OR4_BI_BURSTINHIBIT - -config OR4_COLS - hex - default 0x0 if !BR4_MACHINE_SDRAM - default 0x0 if OR4_COLS_7 - default 0x400 if OR4_COLS_8 - default 0x800 if OR4_COLS_9 - default 0xc00 if OR4_COLS_10 - default 0x1000 if OR4_COLS_11 - default 0x1400 if OR4_COLS_12 - default 0x1800 if OR4_COLS_13 - default 0x1c00 if OR4_COLS_14 - -config OR4_ROWS - hex - default 0x0 if !BR4_MACHINE_SDRAM - default 0x0 if OR4_ROWS_9 - default 0x40 if OR4_ROWS_10 - default 0x80 if OR4_ROWS_11 - default 0xc0 if OR4_ROWS_12 - default 0x100 if OR4_ROWS_13 - default 0x140 if OR4_ROWS_14 - default 0x180 if OR4_ROWS_15 - -config OR4_PMSEL - hex - default 0x0 if !BR4_MACHINE_SDRAM - default 0x0 if OR4_PMSEL_BTB - default 0x20 if OR4_PMSEL_KEPT_OPEN - -config OR4_SCY - hex - default 0x0 if !BR4_MACHINE_GPCM && !BR4_MACHINE_FCM - default 0x0 if OR4_SCY_0 - default 0x10 if OR4_SCY_1 - default 0x20 if OR4_SCY_2 - default 0x30 if OR4_SCY_3 - default 0x40 if OR4_SCY_4 - default 0x50 if OR4_SCY_5 - default 0x60 if OR4_SCY_6 - default 0x70 if OR4_SCY_7 - default 0x80 if OR4_SCY_8 - default 0x90 if OR4_SCY_9 - default 0xa0 if OR4_SCY_10 - default 0xb0 if OR4_SCY_11 - default 0xc0 if OR4_SCY_12 - default 0xd0 if OR4_SCY_13 - default 0xe0 if OR4_SCY_14 - default 0xf0 if OR4_SCY_15 - -config OR4_PGS - hex - default 0x0 if !BR4_MACHINE_FCM - default 0x0 if OR4_PGS_SMALL - default 0x400 if OR4_PGS_LARGE - -config OR4_CSCT - hex - default 0x0 if !BR4_MACHINE_FCM - default 0x0 if OR4_CSCT_1_CYCLE - default 0x0 if OR4_CSCT_2_CYCLE - default 0x200 if OR4_CSCT_4_CYCLE - default 0x200 if OR4_CSCT_8_CYCLE - -config OR4_CST - hex - default 0x0 if !BR4_MACHINE_FCM - default 0x0 if OR4_CST_COINCIDENT - default 0x100 if OR4_CST_QUARTER_CLOCK - default 0x0 if OR4_CST_HALF_CLOCK - default 0x100 if OR4_CST_ONE_CLOCK - -config OR4_CHT - hex - default 0x0 if !BR4_MACHINE_FCM - default 0x0 if OR4_CHT_HALF_CLOCK - default 0x80 if OR4_CHT_ONE_CLOCK - default 0x0 if OR4_CHT_ONE_HALF_CLOCK - default 0x80 if OR4_CHT_TWO_CLOCK - -config OR4_RST - hex - default 0x0 if !BR4_MACHINE_FCM - default 0x0 if OR4_RST_THREE_QUARTER_CLOCK - default 0x8 if OR4_RST_ONE_CLOCK - default 0x0 if OR4_RST_ONE_HALF_CLOCK - -config OR4_CSNT - hex - default 0x0 if !BR4_MACHINE_GPCM - default 0x0 if OR4_CSNT_NORMAL - default 0x800 if OR4_CSNT_EARLIER - -config OR4_ACS - hex - default 0x0 if !BR4_MACHINE_GPCM - default 0x0 if OR4_ACS_SAME_TIME - default 0x400 if OR4_ACS_QUARTER_CYCLE_EARLIER - default 0x600 if OR4_ACS_HALF_CYCLE_EARLIER - -config OR4_XACS - hex - default 0x0 if !BR4_MACHINE_GPCM - default 0x0 if OR4_XACS_NORMAL - default 0x100 if OR4_XACS_EXTENDED - -config OR4_SETA - hex - default 0x0 if !BR4_MACHINE_GPCM - default 0x0 if OR4_SETA_INTERNAL - default 0x8 if OR4_SETA_EXTERNAL - -config OR4_TRLX - hex - default 0x0 if OR4_TRLX_NORMAL - default 0x4 if OR4_TRLX_RELAXED - -config OR4_EHTR - hex - default 0x0 if OR4_EHTR_NORMAL - default 0x2 if OR4_EHTR_1_CYCLE - default 0x0 if OR4_EHTR_4_CYCLE - default 0x2 if OR4_EHTR_8_CYCLE - -config OR4_EAD - hex - default 0x0 if ARCH_MPC8308 - default 0x0 if OR4_EAD_NONE - default 0x1 if OR4_EAD_EXTRA diff --git a/configs/MPC837XERDB_defconfig b/configs/MPC837XERDB_defconfig index 7287ca6b24..8f3f54cb4f 100644 --- a/configs/MPC837XERDB_defconfig +++ b/configs/MPC837XERDB_defconfig @@ -108,37 +108,6 @@ CONFIG_LBLAW2=y CONFIG_LBLAW2_BASE=0xF0000000 CONFIG_LBLAW2_NAME="VSC7385" CONFIG_LBLAW2_LENGTH_128_KBYTES=y -CONFIG_ELBC_BR0_OR0=y -CONFIG_BR0_OR0_NAME="FLASH" -CONFIG_BR0_OR0_BASE=0xFE000000 -CONFIG_BR0_PORTSIZE_16BIT=y -CONFIG_OR0_AM_8_MBYTES=y -CONFIG_OR0_SCY_9=y -CONFIG_OR0_XACS_EXTENDED=y -CONFIG_OR0_EHTR_1_CYCLE=y -CONFIG_OR0_EAD_EXTRA=y -CONFIG_ELBC_BR1_OR1=y -CONFIG_BR1_OR1_NAME="NAND" -CONFIG_BR1_OR1_BASE=0xE0600000 -CONFIG_BR1_ERRORCHECKING_BOTH=y -CONFIG_BR1_MACHINE_FCM=y -CONFIG_OR1_SCY_1=y -CONFIG_OR1_CSCT_8_CYCLE=y -CONFIG_OR1_CST_ONE_CLOCK=y -CONFIG_OR1_CHT_TWO_CLOCK=y -CONFIG_OR1_TRLX_RELAXED=y -CONFIG_OR1_EHTR_8_CYCLE=y -CONFIG_ELBC_BR2_OR2=y -CONFIG_BR2_OR2_NAME="VSC7385" -CONFIG_BR2_OR2_BASE=0xF0000000 -CONFIG_OR2_AM_128_KBYTES=y -CONFIG_OR2_SCY_15=y -CONFIG_OR2_CSNT_EARLIER=y -CONFIG_OR2_XACS_EXTENDED=y -CONFIG_OR2_SETA_EXTERNAL=y -CONFIG_OR2_TRLX_RELAXED=y -CONFIG_OR2_EHTR_8_CYCLE=y -CONFIG_OR2_EAD_EXTRA=y CONFIG_HID0_FINAL_EMCP=y CONFIG_HID0_FINAL_ICE=y CONFIG_HID2_HBE=y diff --git a/configs/gazerbeam_defconfig b/configs/gazerbeam_defconfig index 63051af411..63488da30a 100644 --- a/configs/gazerbeam_defconfig +++ b/configs/gazerbeam_defconfig @@ -67,31 +67,6 @@ CONFIG_LBLAW2=y CONFIG_LBLAW2_BASE=0xE0700000 CONFIG_LBLAW2_NAME="FPGA1" CONFIG_LBLAW2_LENGTH_1_MBYTES=y -CONFIG_ELBC_BR0_OR0=y -CONFIG_BR0_OR0_NAME="FLASH" -CONFIG_BR0_OR0_BASE=0xFE000000 -CONFIG_BR0_PORTSIZE_16BIT=y -CONFIG_OR0_AM_8_MBYTES=y -CONFIG_OR0_SCY_15=y -CONFIG_OR0_CSNT_EARLIER=y -CONFIG_OR0_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR0_XACS_EXTENDED=y -CONFIG_OR0_TRLX_RELAXED=y -CONFIG_OR0_EHTR_8_CYCLE=y -CONFIG_ELBC_BR1_OR1=y -CONFIG_BR1_OR1_NAME="FPGA0" -CONFIG_BR1_OR1_BASE=0xE0600000 -CONFIG_BR1_PORTSIZE_16BIT=y -CONFIG_OR1_AM_1_MBYTES=y -CONFIG_OR1_SCY_5=y -CONFIG_OR1_CSNT_EARLIER=y -CONFIG_ELBC_BR2_OR2=y -CONFIG_BR2_OR2_NAME="FPGA1" -CONFIG_BR2_OR2_BASE=0xE0700000 -CONFIG_BR2_PORTSIZE_16BIT=y -CONFIG_OR2_AM_1_MBYTES=y -CONFIG_OR2_SCY_5=y -CONFIG_OR2_CSNT_EARLIER=y CONFIG_HID0_FINAL_EMCP=y CONFIG_HID0_FINAL_DPM=y CONFIG_HID0_FINAL_ICE=y diff --git a/configs/kmcoge5ne_defconfig b/configs/kmcoge5ne_defconfig index 4ea7da8d32..40e2b22894 100644 --- a/configs/kmcoge5ne_defconfig +++ b/configs/kmcoge5ne_defconfig @@ -111,43 +111,6 @@ CONFIG_LBLAW3=y CONFIG_LBLAW3_BASE=0xA0000000 CONFIG_LBLAW3_NAME="PAXE" CONFIG_LBLAW3_LENGTH_512_MBYTES=y -CONFIG_ELBC_BR0_OR0=y -CONFIG_BR0_OR0_NAME="FLASH" -CONFIG_BR0_OR0_BASE=0xF0000000 -CONFIG_BR0_PORTSIZE_16BIT=y -CONFIG_OR0_AM_256_MBYTES=y -CONFIG_OR0_SCY_5=y -CONFIG_OR0_CSNT_EARLIER=y -CONFIG_OR0_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR0_TRLX_RELAXED=y -CONFIG_OR0_EAD_EXTRA=y -CONFIG_ELBC_BR1_OR1=y -CONFIG_BR1_OR1_NAME="KMBEC_FPGA" -CONFIG_BR1_OR1_BASE=0xE8000000 -CONFIG_OR1_AM_64_MBYTES=y -CONFIG_OR1_SCY_2=y -CONFIG_OR1_CSNT_EARLIER=y -CONFIG_OR1_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR1_TRLX_RELAXED=y -CONFIG_OR1_EAD_EXTRA=y -CONFIG_ELBC_BR3_OR3=y -CONFIG_BR3_OR3_NAME="PAXE" -CONFIG_BR3_OR3_BASE=0xA0000000 -CONFIG_OR3_AM_256_MBYTES=y -CONFIG_OR3_SCY_2=y -CONFIG_OR3_CSNT_EARLIER=y -CONFIG_OR3_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR3_TRLX_RELAXED=y -CONFIG_OR3_EAD_EXTRA=y -CONFIG_ELBC_BR4_OR4=y -CONFIG_BR4_OR4_NAME="BFTIC3" -CONFIG_BR4_OR4_BASE=0xB0000000 -CONFIG_OR4_AM_256_MBYTES=y -CONFIG_OR4_SCY_2=y -CONFIG_OR4_CSNT_EARLIER=y -CONFIG_OR4_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR4_TRLX_RELAXED=y -CONFIG_OR4_EAD_EXTRA=y CONFIG_HID0_FINAL_EMCP=y CONFIG_HID0_FINAL_ICE=y CONFIG_HID2_HBE=y diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index 96298ed0c3..f49367595d 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -91,34 +91,6 @@ CONFIG_LBLAW3=y CONFIG_LBLAW3_BASE=0xA0000000 CONFIG_LBLAW3_NAME="PAXE" CONFIG_LBLAW3_LENGTH_512_MBYTES=y -CONFIG_ELBC_BR0_OR0=y -CONFIG_BR0_OR0_NAME="FLASH" -CONFIG_BR0_OR0_BASE=0xF0000000 -CONFIG_BR0_PORTSIZE_16BIT=y -CONFIG_OR0_AM_256_MBYTES=y -CONFIG_OR0_SCY_5=y -CONFIG_OR0_CSNT_EARLIER=y -CONFIG_OR0_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR0_TRLX_RELAXED=y -CONFIG_OR0_EAD_EXTRA=y -CONFIG_ELBC_BR1_OR1=y -CONFIG_BR1_OR1_NAME="KMBEC_FPGA" -CONFIG_BR1_OR1_BASE=0xE8000000 -CONFIG_OR1_AM_64_MBYTES=y -CONFIG_OR1_SCY_2=y -CONFIG_OR1_CSNT_EARLIER=y -CONFIG_OR1_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR1_TRLX_RELAXED=y -CONFIG_OR1_EAD_EXTRA=y -CONFIG_ELBC_BR3_OR3=y -CONFIG_BR3_OR3_NAME="PAXE" -CONFIG_BR3_OR3_BASE=0xA0000000 -CONFIG_OR3_AM_256_MBYTES=y -CONFIG_OR3_SCY_2=y -CONFIG_OR3_CSNT_EARLIER=y -CONFIG_OR3_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR3_TRLX_RELAXED=y -CONFIG_OR3_EAD_EXTRA=y CONFIG_HID0_FINAL_EMCP=y CONFIG_HID0_FINAL_ICE=y CONFIG_HID2_HBE=y diff --git a/configs/kmopti2_defconfig b/configs/kmopti2_defconfig index db717e4a15..9a1b6b894b 100644 --- a/configs/kmopti2_defconfig +++ b/configs/kmopti2_defconfig @@ -99,40 +99,6 @@ CONFIG_LBLAW3=y CONFIG_LBLAW3_BASE=0xB0000000 CONFIG_LBLAW3_NAME="APP2" CONFIG_LBLAW3_LENGTH_256_MBYTES=y -CONFIG_ELBC_BR0_OR0=y -CONFIG_BR0_OR0_NAME="FLASH" -CONFIG_BR0_OR0_BASE=0xF0000000 -CONFIG_BR0_PORTSIZE_16BIT=y -CONFIG_OR0_AM_256_MBYTES=y -CONFIG_OR0_SCY_5=y -CONFIG_OR0_CSNT_EARLIER=y -CONFIG_OR0_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR0_TRLX_RELAXED=y -CONFIG_OR0_EAD_EXTRA=y -CONFIG_ELBC_BR1_OR1=y -CONFIG_BR1_OR1_NAME="KMBEC_FPGA" -CONFIG_BR1_OR1_BASE=0xE8000000 -CONFIG_OR1_AM_128_MBYTES=y -CONFIG_OR1_SCY_2=y -CONFIG_OR1_CSNT_EARLIER=y -CONFIG_OR1_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR1_TRLX_RELAXED=y -CONFIG_OR1_EAD_EXTRA=y -CONFIG_ELBC_BR2_OR2=y -CONFIG_BR2_OR2_NAME="APP1" -CONFIG_BR2_OR2_BASE=0xA0000000 -CONFIG_OR2_AM_256_MBYTES=y -CONFIG_OR2_SCY_2=y -CONFIG_OR2_CSNT_EARLIER=y -CONFIG_OR2_ACS_QUARTER_CYCLE_EARLIER=y -CONFIG_OR2_TRLX_RELAXED=y -CONFIG_OR2_EAD_EXTRA=y -CONFIG_ELBC_BR3_OR3=y -CONFIG_BR3_OR3_NAME="APP2" -CONFIG_BR3_OR3_BASE=0xB0000000 -CONFIG_BR3_PORTSIZE_16BIT=y -CONFIG_OR3_AM_256_MBYTES=y -CONFIG_OR3_SCY_4=y CONFIG_HID0_FINAL_EMCP=y CONFIG_HID0_FINAL_ICE=y CONFIG_HID2_HBE=y diff --git a/configs/kmsupx5_defconfig b/configs/kmsupx5_defconfig index 69de685baf..cafe39a545 100644 --- a/configs/kmsupx5_defconfig +++ b/configs/kmsupx5_defconfig @@ -85,34 +85,6 @@ CONFIG_LBLAW2=y CONFIG_LBLAW2_BASE=0xA0000000 CONFIG_LBLAW2_NAME="APP1" CONFIG_LBLAW2_LENGTH_256_MBYTES=y -CONFIG_ELBC_BR0_OR0=y -CONFIG_BR0_OR0_NAME="FLASH" -CONFIG_BR0_OR0_BASE=0xF0000000 -CONFIG_BR0_PORTSIZE_16BIT=y -CONFIG_OR0_AM_256_MBYTES=y -CONFIG_OR0_SCY_5=y -CONFIG_OR0_CSNT_EARLIER=y -CONFIG_OR0_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR0_TRLX_RELAXED=y -CONFIG_OR0_EAD_EXTRA=y -CONFIG_ELBC_BR1_OR1=y -CONFIG_BR1_OR1_NAME="KMBEC_FPGA" -CONFIG_BR1_OR1_BASE=0xE8000000 -CONFIG_OR1_AM_128_MBYTES=y -CONFIG_OR1_SCY_2=y -CONFIG_OR1_CSNT_EARLIER=y -CONFIG_OR1_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR1_TRLX_RELAXED=y -CONFIG_OR1_EAD_EXTRA=y -CONFIG_ELBC_BR2_OR2=y -CONFIG_BR2_OR2_NAME="APP1" -CONFIG_BR2_OR2_BASE=0xA0000000 -CONFIG_OR2_AM_256_MBYTES=y -CONFIG_OR2_SCY_2=y -CONFIG_OR2_CSNT_EARLIER=y -CONFIG_OR2_ACS_QUARTER_CYCLE_EARLIER=y -CONFIG_OR2_TRLX_RELAXED=y -CONFIG_OR2_EAD_EXTRA=y CONFIG_HID0_FINAL_EMCP=y CONFIG_HID0_FINAL_ICE=y CONFIG_HID2_HBE=y diff --git a/configs/kmtepr2_defconfig b/configs/kmtepr2_defconfig index 92f2b0adec..0b88ebdfd3 100644 --- a/configs/kmtepr2_defconfig +++ b/configs/kmtepr2_defconfig @@ -99,40 +99,6 @@ CONFIG_LBLAW3=y CONFIG_LBLAW3_BASE=0xB0000000 CONFIG_LBLAW3_NAME="APP2" CONFIG_LBLAW3_LENGTH_256_MBYTES=y -CONFIG_ELBC_BR0_OR0=y -CONFIG_BR0_OR0_NAME="FLASH" -CONFIG_BR0_OR0_BASE=0xF0000000 -CONFIG_BR0_PORTSIZE_16BIT=y -CONFIG_OR0_AM_256_MBYTES=y -CONFIG_OR0_SCY_5=y -CONFIG_OR0_CSNT_EARLIER=y -CONFIG_OR0_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR0_TRLX_RELAXED=y -CONFIG_OR0_EAD_EXTRA=y -CONFIG_ELBC_BR1_OR1=y -CONFIG_BR1_OR1_NAME="KMBEC_FPGA" -CONFIG_BR1_OR1_BASE=0xE8000000 -CONFIG_OR1_AM_128_MBYTES=y -CONFIG_OR1_SCY_2=y -CONFIG_OR1_CSNT_EARLIER=y -CONFIG_OR1_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR1_TRLX_RELAXED=y -CONFIG_OR1_EAD_EXTRA=y -CONFIG_ELBC_BR2_OR2=y -CONFIG_BR2_OR2_NAME="APP1" -CONFIG_BR2_OR2_BASE=0xA0000000 -CONFIG_OR2_AM_256_MBYTES=y -CONFIG_OR2_SCY_2=y -CONFIG_OR2_CSNT_EARLIER=y -CONFIG_OR2_ACS_QUARTER_CYCLE_EARLIER=y -CONFIG_OR2_TRLX_RELAXED=y -CONFIG_OR2_EAD_EXTRA=y -CONFIG_ELBC_BR3_OR3=y -CONFIG_BR3_OR3_NAME="APP2" -CONFIG_BR3_OR3_BASE=0xB0000000 -CONFIG_BR3_PORTSIZE_16BIT=y -CONFIG_OR3_AM_256_MBYTES=y -CONFIG_OR3_SCY_4=y CONFIG_HID0_FINAL_EMCP=y CONFIG_HID0_FINAL_ICE=y CONFIG_HID2_HBE=y diff --git a/configs/tuge1_defconfig b/configs/tuge1_defconfig index 0c3381461e..6df74b5077 100644 --- a/configs/tuge1_defconfig +++ b/configs/tuge1_defconfig @@ -85,34 +85,6 @@ CONFIG_LBLAW2=y CONFIG_LBLAW2_BASE=0xA0000000 CONFIG_LBLAW2_NAME="APP1" CONFIG_LBLAW2_LENGTH_256_MBYTES=y -CONFIG_ELBC_BR0_OR0=y -CONFIG_BR0_OR0_NAME="FLASH" -CONFIG_BR0_OR0_BASE=0xF0000000 -CONFIG_BR0_PORTSIZE_16BIT=y -CONFIG_OR0_AM_256_MBYTES=y -CONFIG_OR0_SCY_5=y -CONFIG_OR0_CSNT_EARLIER=y -CONFIG_OR0_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR0_TRLX_RELAXED=y -CONFIG_OR0_EAD_EXTRA=y -CONFIG_ELBC_BR1_OR1=y -CONFIG_BR1_OR1_NAME="KMBEC_FPGA" -CONFIG_BR1_OR1_BASE=0xE8000000 -CONFIG_OR1_AM_128_MBYTES=y -CONFIG_OR1_SCY_2=y -CONFIG_OR1_CSNT_EARLIER=y -CONFIG_OR1_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR1_TRLX_RELAXED=y -CONFIG_OR1_EAD_EXTRA=y -CONFIG_ELBC_BR2_OR2=y -CONFIG_BR2_OR2_NAME="APP1" -CONFIG_BR2_OR2_BASE=0xA0000000 -CONFIG_OR2_AM_256_MBYTES=y -CONFIG_OR2_SCY_2=y -CONFIG_OR2_CSNT_EARLIER=y -CONFIG_OR2_ACS_QUARTER_CYCLE_EARLIER=y -CONFIG_OR2_TRLX_RELAXED=y -CONFIG_OR2_EAD_EXTRA=y CONFIG_HID0_FINAL_EMCP=y CONFIG_HID0_FINAL_ICE=y CONFIG_HID2_HBE=y diff --git a/configs/tuxx1_defconfig b/configs/tuxx1_defconfig index 4f192ad262..837098f0e5 100644 --- a/configs/tuxx1_defconfig +++ b/configs/tuxx1_defconfig @@ -99,42 +99,6 @@ CONFIG_LBLAW3=y CONFIG_LBLAW3_BASE=0xB0000000 CONFIG_LBLAW3_NAME="APP2" CONFIG_LBLAW3_LENGTH_256_MBYTES=y -CONFIG_ELBC_BR0_OR0=y -CONFIG_BR0_OR0_NAME="FLASH" -CONFIG_BR0_OR0_BASE=0xF0000000 -CONFIG_BR0_PORTSIZE_16BIT=y -CONFIG_OR0_AM_256_MBYTES=y -CONFIG_OR0_SCY_5=y -CONFIG_OR0_CSNT_EARLIER=y -CONFIG_OR0_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR0_TRLX_RELAXED=y -CONFIG_OR0_EAD_EXTRA=y -CONFIG_ELBC_BR1_OR1=y -CONFIG_BR1_OR1_NAME="KMBEC_FPGA" -CONFIG_BR1_OR1_BASE=0xE8000000 -CONFIG_OR1_AM_128_MBYTES=y -CONFIG_OR1_SCY_2=y -CONFIG_OR1_CSNT_EARLIER=y -CONFIG_OR1_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR1_TRLX_RELAXED=y -CONFIG_OR1_EAD_EXTRA=y -CONFIG_ELBC_BR2_OR2=y -CONFIG_BR2_OR2_NAME="APP1" -CONFIG_BR2_OR2_BASE=0xA0000000 -CONFIG_OR2_AM_256_MBYTES=y -CONFIG_OR2_SCY_2=y -CONFIG_OR2_CSNT_EARLIER=y -CONFIG_OR2_ACS_QUARTER_CYCLE_EARLIER=y -CONFIG_OR2_TRLX_RELAXED=y -CONFIG_OR2_EAD_EXTRA=y -CONFIG_ELBC_BR3_OR3=y -CONFIG_BR3_OR3_NAME="APP2" -CONFIG_BR3_OR3_BASE=0xB0000000 -CONFIG_OR3_AM_256_MBYTES=y -CONFIG_OR3_SCY_2=y -CONFIG_OR3_CSNT_EARLIER=y -CONFIG_OR3_ACS_HALF_CYCLE_EARLIER=y -CONFIG_OR3_TRLX_RELAXED=y CONFIG_HID0_FINAL_EMCP=y CONFIG_HID0_FINAL_ICE=y CONFIG_HID2_HBE=y
On Sun, Feb 26, 2023 at 10:44:09AM +0100, Christophe Leroy wrote:
Commit fe7d654d04 ("mpc83xx: Migrate CONFIG_SYS_{BR, OR}*_PRELIM to Kconfig") converted CONFIG_SYS_{BRx/ORx}_PRELIM to Kconfig by implementing a fine-grained selection of every bit in Kconfig.
But commit c7fad78ec0 ("Convert CONFIG_SYS_BR0_PRELIM et al to Kconfig") reworked it so that you now just have to provide the raw value of each register in Kconfig. However, all fine-grained Kconfig items remained allthough they are not used anymore.
Remove them all.
Fixes: c7fad78ec0 ("Convert CONFIG_SYS_BR0_PRELIM et al to Kconfig") Signed-off-by: Christophe Leroy christophe.leroy@csgroup.eu
Christophe Leroy
