[U-Boot] [PATCH 0/4] Enable 'ums' command on Trats2 board.
This patchset enable 'ums' command on Trats2 board. Definitions are added to pmic max77693 to enable safeout outputs. USB s3c_udc is modified to support Exnos4x12
Piotr Wilczek (4): driver:usb:s3c_udc: add support for Exynos4x12 usb:composite: use memcpy to avoid unaligned access pmic: max77693: add defines for safeout 1 and 2 trats2: enable ums support on Trats2
board/samsung/trats2/trats2.c | 133 ++++++++++++++++++++++++++++++++++++++ drivers/usb/gadget/composite.c | 3 +- drivers/usb/gadget/regs-otg.h | 5 ++ drivers/usb/gadget/s3c_udc_otg.c | 9 ++- include/configs/trats2.h | 19 ++++++ include/power/max77693_pmic.h | 3 + 6 files changed, 169 insertions(+), 3 deletions(-)
This patch add new defines for usb phy for Exynos4x12.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- drivers/usb/gadget/regs-otg.h | 5 +++++ drivers/usb/gadget/s3c_udc_otg.c | 9 +++++++-- 2 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/gadget/regs-otg.h b/drivers/usb/gadget/regs-otg.h index 3737e45..df7cda6 100644 --- a/drivers/usb/gadget/regs-otg.h +++ b/drivers/usb/gadget/regs-otg.h @@ -229,6 +229,11 @@ struct s3c_usbotg_reg { #define CLK_SEL_12MHZ (0x2 << 0) #define CLK_SEL_48MHZ (0x0 << 0)
+#define EXYNOS4X12_ID_PULLUP0 (0x01 << 3) +#define EXYNOS4X12_COMMON_ON_N0 (0x01 << 4) +#define EXYNOS4X12_CLK_SEL_12MHZ (0x02 << 0) +#define EXYNOS4X12_CLK_SEL_24MHZ (0x05 << 0) + /* Device Configuration Register DCFG */ #define DEV_SPEED_HIGH_SPEED_20 (0x0 << 0) #define DEV_SPEED_FULL_SPEED_20 (0x1 << 0) diff --git a/drivers/usb/gadget/s3c_udc_otg.c b/drivers/usb/gadget/s3c_udc_otg.c index f9d24e3..fb72662 100644 --- a/drivers/usb/gadget/s3c_udc_otg.c +++ b/drivers/usb/gadget/s3c_udc_otg.c @@ -180,8 +180,13 @@ void otg_phy_init(struct s3c_udc *dev) writel((readl(&phy->phypwr) &~(OTG_DISABLE_0 | ANALOG_PWRDOWN) &~FORCE_SUSPEND_0), &phy->phypwr);
- writel((readl(&phy->phyclk) &~(ID_PULLUP0 | COMMON_ON_N0)) | - CLK_SEL_24MHZ, &phy->phyclk); /* PLL 24Mhz */ + if (proid_is_exynos4412()) + writel((readl(&phy->phyclk) &~(EXYNOS4X12_ID_PULLUP0 | + EXYNOS4X12_COMMON_ON_N0)) | EXYNOS4X12_CLK_SEL_24MHZ, + &phy->phyclk); /* PLL 24Mhz */ + else + writel((readl(&phy->phyclk) &~(ID_PULLUP0 | COMMON_ON_N0)) | + CLK_SEL_24MHZ, &phy->phyclk); /* PLL 24Mhz */
writel((readl(&phy->rstcon) &~(LINK_SW_RST | PHYLNK_SW_RST)) | PHY_SW_RST0, &phy->rstcon);
This patch memcpy is used instead of an assignment to avoid unaligned access execption on some ARM platforms.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Lukasz Majewski l.majewski@samsung.com --- drivers/usb/gadget/composite.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/gadget/composite.c b/drivers/usb/gadget/composite.c index 2c5600e..0716e52 100644 --- a/drivers/usb/gadget/composite.c +++ b/drivers/usb/gadget/composite.c @@ -997,7 +997,8 @@ static int composite_bind(struct usb_gadget *gadget) if (status < 0) goto fail;
- cdev->desc = *composite->dev; + memcpy(&cdev->desc, composite->dev, + sizeof(struct usb_device_descriptor)); cdev->desc.bMaxPacketSize0 = gadget->ep0->maxpacket;
debug("%s: ready\n", composite->name);
Hello Piotr,
Am 10.04.2013 14:07, schrieb Piotr Wilczek:
just digged into this bug on an am335x based board, this patch helped me out!
Thanks!
Tested-by: Heiko Schocher hs@denx.de Acked-by: Heiko Schocher hs@denx.de
bye, Heiko
Hello Prafulla,
just saw, that the below patch is delegated to you: (added also Marek Vasut to cc, as he is the usb maintainer)
This fixes a bug... do you plan to work it in for this release? Or are there some issues with this patch?
bye, Heiko
Dear Heiko Schocher,
Hello Prafulla,
Applied
Best regards, Marek Vasut
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- include/power/max77693_pmic.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/power/max77693_pmic.h b/include/power/max77693_pmic.h index 07c3dd6..c43ace0 100644 --- a/include/power/max77693_pmic.h +++ b/include/power/max77693_pmic.h @@ -50,6 +50,9 @@ enum {CHARGER_ENABLE, CHARGER_DISABLE}; #define MAX77693_CHG_LOCK (0x0 << 2) /* MAX77693_CHG_CNFG_06 */ #define MAX77693_CHG_UNLOCK (0x3 << 2) /* MAX77693_CHG_CNFG_06 */
+#define MAX77693_ENSAFEOUT1 (1 << 6) +#define MAX77693_ENSAFEOUT2 (1 << 7) + #define MAX77693_PMIC_I2C_ADDR (0xCC >> 1)
int pmic_init_max77693(unsigned char bus);
This patch enables 'ums' command on Trats2 board.
--- board/samsung/trats2/trats2.c | 133 +++++++++++++++++++++++++++++++++++++++++ include/configs/trats2.h | 19 ++++++ 2 files changed, 152 insertions(+)
diff --git a/board/samsung/trats2/trats2.c b/board/samsung/trats2/trats2.c index 32fb699..d9de862 100644 --- a/board/samsung/trats2/trats2.c +++ b/board/samsung/trats2/trats2.c @@ -45,6 +45,8 @@ #include <power/max77693_fg.h> #include <libtizen.h> #include <errno.h> +#include <usb/s3c_udc.h> +#include <usb_mass_storage.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -326,6 +328,75 @@ int board_mmc_init(bd_t *bis) return err; }
+#ifdef CONFIG_USB_GADGET +static int s5pc210_phy_control(int on) +{ + int ret = 0; + unsigned int val; + + struct pmic *p = pmic_get("MAX77686_PMIC"); + if (!p) + return -ENODEV; + + if (pmic_probe(p)) + return -1; + + if (on) { + ret = max77686_set_ldo_mode(p, 12, OPMODE_ON); + + p = pmic_get("MAX77693_PMIC"); + pmic_probe(p); + if (pmic_probe(p)) + return -1; + + /* SAFEOUT */ + ret |= pmic_reg_read(p, MAX77693_SAFEOUT, &val); + val |= MAX77693_ENSAFEOUT1; + ret |= pmic_reg_write(p, MAX77693_SAFEOUT, val); + + p = pmic_get("MAX77693_MUIC"); + if (pmic_probe(p)) + return -1; + + /* PATH: USB */ + ret |= pmic_reg_write(p, MAX77693_MUIC_CONTROL1, + MAX77693_MUIC_CTRL1_DN1DP2); + + } else { + ret |= max77686_set_ldo_mode(p, 12, OPMODE_LPM); + + p = pmic_get("MAX77693_MUIC"); + if (pmic_probe(p)) + return -1; + + /* PATH: UART */ + ret |= pmic_reg_write(p, MAX77693_MUIC_CONTROL1, + MAX77693_MUIC_CTRL1_UT1UR2); + } + + if (ret) { + puts("MAX77693 setting error!\n"); + return -1; + } + + return 0; +} + +struct s3c_plat_otg_data s5pc210_otg_data = { + .phy_control = s5pc210_phy_control, + .regs_phy = EXYNOS4X12_USBPHY_BASE, + .regs_otg = EXYNOS4X12_USBOTG_BASE, + .usb_phy_ctrl = EXYNOS4X12_USBPHY_CONTROL, + .usb_flags = PHY0_SLEEP, +}; + +void board_usb_init(void) +{ + debug("USB_udc_probe\n"); + s3c_udc_probe(&s5pc210_otg_data); +} +#endif + static int pmic_init_max77686(void) { struct pmic *p = pmic_get("MAX77686_PMIC"); @@ -525,3 +596,65 @@ int misc_init_r(void) return 0; } #endif + +#ifdef CONFIG_USB_GADGET_MASS_STORAGE +static int ums_read_sector(struct ums_device *ums_dev, + ulong start, lbaint_t blkcnt, void *buf) +{ + if (ums_dev->mmc->block_dev.block_read(ums_dev->dev_num, + start + ums_dev->offset, blkcnt, buf) != blkcnt) + return -1; + + return 0; +} + +static int ums_write_sector(struct ums_device *ums_dev, + ulong start, lbaint_t blkcnt, const void *buf) +{ + if (ums_dev->mmc->block_dev.block_write(ums_dev->dev_num, + start + ums_dev->offset, blkcnt, buf) != blkcnt) + return -1; + + return 0; +} + +static void ums_get_capacity(struct ums_device *ums_dev, + long long int *capacity) +{ + long long int tmp_capacity; + + tmp_capacity = (long long int) ((ums_dev->offset + ums_dev->part_size) + * SECTOR_SIZE); + *capacity = ums_dev->mmc->capacity - tmp_capacity; +} + +static struct ums_board_info ums_board = { + .read_sector = ums_read_sector, + .write_sector = ums_write_sector, + .get_capacity = ums_get_capacity, + .name = "TRATS2 UMS disk", + .ums_dev = { + .mmc = NULL, + .dev_num = 0, + .offset = 0, + .part_size = 0. + }, +}; + +struct ums_board_info *board_ums_init(unsigned int dev_num, unsigned int offset, + unsigned int part_size) +{ + struct mmc *mmc; + + mmc = find_mmc_device(dev_num); + if (!mmc) + return NULL; + + ums_board.ums_dev.mmc = mmc; + ums_board.ums_dev.dev_num = dev_num; + ums_board.ums_dev.offset = offset; + ums_board.ums_dev.part_size = part_size; + + return &ums_board; +} +#endif diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 5637734..8f86d8c 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -133,6 +133,16 @@ #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE
+/* USB Composite download gadget - g_dnl */ +#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_DFU_FUNCTION +#define CONFIG_DFU_MMC + +/* USB Samsung's IDs */ +#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 +#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 +#define CONFIG_G_DNL_MANUFACTURER "Samsung" + /* To use the TFTPBOOT over USB, Please enable the CONFIG_CMD_NET */ #undef CONFIG_CMD_NET
@@ -288,6 +298,10 @@ #define CONFIG_POWER_MUIC_MAX77693 #define CONFIG_POWER_FG_MAX77693 #define CONFIG_POWER_BATTERY_TRATS2 +#define CONFIG_USB_GADGET +#define CONFIG_USB_GADGET_S3C_UDC_OTG +#define CONFIG_USB_GADGET_DUALSPEED +#define CONFIG_USB_GADGET_VBUS_DRAW 2
/* PWM */ #define CONFIG_PWM @@ -306,4 +320,9 @@ #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 250 * 4) + (1 << 12))
+#define CONFIG_CMD_USB_MASS_STORAGE +#if defined(CONFIG_CMD_USB_MASS_STORAGE) +#define CONFIG_USB_GADGET_MASS_STORAGE +#endif + #endif /* __CONFIG_H */
Heiko Schocher
Piotr Wilczek
