[U-Boot] [PATCH 1/3] dts: rk3288: correct sdram setting for miniarm
miniarm board use lpddr3
Signed-off-by: Jacob Chen jacob2.chen@rock-chips.com ---
arch/arm/dts/rk3288-miniarm.dts | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/rk3288-miniarm.dts b/arch/arm/dts/rk3288-miniarm.dts index 9083028..3dd40e6 100644 --- a/arch/arm/dts/rk3288-miniarm.dts +++ b/arch/arm/dts/rk3288-miniarm.dts @@ -17,14 +17,14 @@ };
&dmc { - rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa - 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 - 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 - 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 - 0x5 0x0>; - rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 - 0xa60 0x40 0x10 0x0>; - rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; + rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d + 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 + 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 + 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 + 0x8 0x1f4>; + rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 + 0x0 0xc3 0x6 0x2>; + rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 0>; };
include/configs/evb_rk3288.h | 9 +++++++++ include/configs/fennec_rk3288.h | 9 +++++++++ include/configs/miniarm_rk3288.h | 9 +++++++++ include/configs/popmetal_rk3288.h | 9 +++++++++ 4 files changed, 36 insertions(+)
diff --git a/include/configs/evb_rk3288.h b/include/configs/evb_rk3288.h index 390c243..90b810a 100644 --- a/include/configs/evb_rk3288.h +++ b/include/configs/evb_rk3288.h @@ -12,11 +12,20 @@
#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 + +#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +/* SPL @ 32k for 34k + * u-boot directly after @ 68k for 400k or so + * ENV @ 992k + */ +#define CONFIG_ENV_OFFSET ((1024-32) * 1024) +#else /* SPL @ 32k for ~36k * ENV @ 96k * u-boot @ 128K */ #define CONFIG_ENV_OFFSET (96 * 1024) +#endif
#define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_CONSOLE_SCROLL_LINES 10 diff --git a/include/configs/fennec_rk3288.h b/include/configs/fennec_rk3288.h index 390c243..90b810a 100644 --- a/include/configs/fennec_rk3288.h +++ b/include/configs/fennec_rk3288.h @@ -12,11 +12,20 @@
#define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_CONSOLE_SCROLL_LINES 10 diff --git a/include/configs/miniarm_rk3288.h b/include/configs/miniarm_rk3288.h index aa259db..645d023 100644 --- a/include/configs/miniarm_rk3288.h +++ b/include/configs/miniarm_rk3288.h @@ -17,11 +17,20 @@
#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 + +#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +/* SPL @ 32k for 34k + * u-boot directly after @ 68k for 400k or so + * ENV @ 992k + */ +#define CONFIG_ENV_OFFSET ((1024-32) * 1024) +#else /* SPL @ 32k for ~36k * ENV @ 96k * u-boot @ 128K */ #define CONFIG_ENV_OFFSET (96 * 1024) +#endif
#define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_CONSOLE_SCROLL_LINES 10 diff --git a/include/configs/popmetal_rk3288.h b/include/configs/popmetal_rk3288.h index 390c243..90b810a 100644 --- a/include/configs/popmetal_rk3288.h +++ b/include/configs/popmetal_rk3288.h @@ -12,11 +12,20 @@
Hi Jacob,
Please can you add a commit message? What is the problem? What change are you making?
Regards, SImon
include/configs/kylin_rk3036.h | 17 ++++++++++++++--- 1 file changed, 14 insertions(+), 3 deletions(-)
diff --git a/include/configs/kylin_rk3036.h b/include/configs/kylin_rk3036.h index 4f0bd84..bc28525 100644 --- a/include/configs/kylin_rk3036.h +++ b/include/configs/kylin_rk3036.h @@ -19,9 +19,20 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 /* emmc */ #define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ -#define CONFIG_ENV_OFFSET (SZ_4M - SZ_64K) /* reserved area */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT + +#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +/* SPL @ 32k for 34k + * u-boot directly after @ 68k for 400k or so + * ENV @ 992k + */ +#define CONFIG_ENV_OFFSET ((1024-32) * 1024) +#else +/* SPL @ 32k for ~36k + * ENV @ 96k + * u-boot @ 128K + */ +#define CONFIG_ENV_OFFSET (96 * 1024) +#endif
#endif
Hi Jacob
Please add a commit message.
For the subject 'same as rk3288' rather than 'same with rk3288'
2016-11-18 9:13 GMT+08:00 Simon Glass sjg@chromium.org:
Acked-by: Simon Glass sjg@chromium.org _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Sorry for sending patch in disorder. It seems this patch have been ignored.
Yes I marked it superseded. It looks like I was confused by your patch series.
See http://patchwork.ozlabs.org/project/uboot/list/?submitter=69649&state=*&...
It looks like you sent a v2 series, but left out this patch and I didn't notice. Anyway:
Applied to u-boot-rockchip, thanks!
Jacob Chen
Jacob Chen
