[U-Boot-Users] Building U-boot 1.1.3 for PPChameleon
I want to build the U-boot 1.1.3 for PPChameleon board. I do like below :
# make PPChameleon_config ......................
# make all ............
then, the build process fails and type this error : ....................................................... ....................................................... ppc_4xx-ld: .bss section too big, overlaps .ppcenv section. Please update your confguration: CFG_MONITOR_BASE, CFG_MONITOR_LEN and TEXT_BASE may need to be modified. make: *** [u-boot] Error 1
Please help me what i have to do.
------------------------------------------------------------- Bests regards, Mehdi Abolghasemi,
Programmable Controller Group, Farineh Technology Co., Tehran, Iran.
In message 510e98c90511080702h2fe9d845obb8308669713e1f5@mail.gmail.com you wrote:
And you don't get an errro message??? I see
-> make PPChameleon_config make: *** No rule to make target `PPChameleon_config'. Stop.
You can either use tools which provide better optimization (for me the code compiles and links fine), or you must follow the advice and reserve more room for the U-Boot image in flash (adjust the aforementioned config variables as needed).
Current top of tree code gives for me:
-> MAKEALL PPChameleonEVB Configuring for PPChameleonEVB board... text data bss dec hex filename 192900 27252 19236 239388 3a71c u-boot -> ppc_4xx-gcc -v Reading specs from /opt/eldk/3.1.1/usr/bin/../lib/gcc-lib/ppc-linux/3.3.3/specs Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --disable-checking --with-system-zlib --enable-__cxa_atexit --with-newlib --enable-languages=c,c++ --disable-libgcj --host=i386-redhat-linux --target=ppc-linux Thread model: posix gcc version 3.3.3 (DENX ELDK 3.1.1 3.3.3-9)
Mehdi Abolghasemi
