[U-Boot] [PATCH] km/arm: set SPI NOR Flash default parameters
These parameters are used by the the sf probe command that are used by our update script and they therefore need to be set for all of our boards.
The timing is the same as for the ENV SPI NOR Flash (since it's the same physical device) and takes the boco2 delay on the bus into account.
Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com cc: Holger Brunck holger.brunck@keymile.com --- include/configs/km/km_arm.h | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 2d573e4..055d946 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -57,6 +57,10 @@ #define CONFIG_CMD_SF #define CONFIG_SOFT_I2C /* I2C bit-banged */
+/* SPI NOR Flash default params, used by sf commands */ +#define CONFIG_SF_DEFAULT_SPEED 8100000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 + #if defined CONFIG_KM_ENV_IS_IN_SPI_NOR #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0
-----Original Message----- From: Valentin Longchamp [mailto:valentin.longchamp@keymile.com] Sent: 14 August 2012 17:09 To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Valentin Longchamp; Holger Brunck Subject: [PATCH] km/arm: set SPI NOR Flash default parameters
What is boco2? Is it typo mistake?
account.
Regards... Prafulla . . .
Hi Prafulla,
No typo mistake. It's the name of a chip developped at Keymile that is the the SPI bus as well.
account.
-----Original Message----- From: Valentin Longchamp [mailto:valentin.longchamp@keymile.com] Sent: 15 August 2012 20:46 To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Holger Brunck Subject: Re: [PATCH] km/arm: set SPI NOR Flash default parameters
Hi Prafulla,
by
Thanks for clarification.
Acked-by: Prafulla Wadaskar Prafulla@marvell.com Will pull this patch soon.
-----Original Message----- From: Prafulla Wadaskar Sent: 16 August 2012 09:46 To: 'Valentin Longchamp' Cc: u-boot@lists.denx.de; Holger Brunck Subject: RE: [PATCH] km/arm: set SPI NOR Flash default parameters
Hi Prafulla,
used
by
our
boards.
the
is
Applied to u-boot-marvell.git master branch
Prafulla Wadaskar
Valentin Longchamp
