[U-Boot-Users] Can't get correct VSC8201 PHYID on MPC8347 in uboot-1.1.3 issue
Dear All,
Now I use VSC8201PHY on MPC8347 with uboot-1.1.3,I think VSC8201 PHY is similar to CIS8201PHY,so I add struct phy_info_vsc8201 based on struct phy_info_cis8201 in tsec.c and related registers in tsec.h, but during bootup I meet below problem in tsec.c when it goes to read phy_id in function read_phy_reg(), the phy_id is always ffffffff, the log file is as follow:
Net: TSEC initialize begin... In Read reg func PHY ID is:0 Register number MIIMADD is 2 PHY Reg after read PHYIR1 is:ffff PHY Reg High 16 bit is:ffff0000 Begin Read phy reg! In Read reg func PHY ID is:0 Register number MIIMADD is 3 PHY Reg after read PHYIR2 is:ffff Tsec: read from reg is ffffffff Freescale TSEC0: PHY id ffffffff is not supported! Freescale TSEC0: No PHY found TSEC initialize begin... In Read reg func PHY ID is:1 Register number MIIMADD is 102 PHY Reg after read PHYIR1 is:ffff PHY Reg High 16 bit is:ffff0000 Begin Read phy reg! In Read reg func PHY ID is:1 Register number MIIMADD is 103 PHY Reg after read PHYIR2 is:ffff Tsec: read from reg is ffffffff Freescale TSEC1: PHY id ffffffff is not supported! Freescale TSEC1: No PHY found Freescale TSEC0, Freescale TSEC1
Thanks in advance.
Best Regards SImon
Simon
check your config file settings for:
#define TSEC1_PHY_ADDR 0 #define TSEC1_PHYIDX 0 #define TSEC2_PHY_ADDR 1 #define TSEC2_PHYIDX 0
for sanity of MDIO stuff.
Dear All,
Thanks in advance.
Best Regards SImon
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files for problems? Stop! Download the new AJAX search engine that makes searching your log files as easy as surfing the web. DOWNLOAD SPLUNK! http://ads.osdn.com/?ad_idv37&alloc_id%16865&op=click
Hi David,
I have checked the config file settings, they are correct.
For the MDIO I get nothing on MDIO read frame and write frame of SMI when the uboot is running.What's wrong with it?
2005/11/29, David Updegraff dave@cray.com:
Simon
Dear All,
Thanks in advance.
Best Regards SImon
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files for problems? Stop! Download the new AJAX search engine that makes searching your log files as easy as surfing the web. DOWNLOAD SPLUNK! http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Does anybody use this PHY before and it works well before? Please give me some comment on it, thanks a lot!
2005/11/29, Simon Yang bestwish.simon@gmail.com:
Hi David,
Simon
Dear All,
Thanks in advance.
Best Regards SImon
David Updegraff
Simon Yang
