[PATCH] doc: add texinfodocs and infodocs targets
Sphinx supports generating Texinfo sources and Info documentation, which can be navigated easily and is convenient to search (via the indexed nodes or anchors, for example). This is basically the same as 1f050e904dd6f2955eecbd22031d912ccb2e7683, which was recently applied to the Linux kernel.
Signed-off-by: Maxim Cournoyer maxim.cournoyer@savoirfairelinux.com ---
Makefile | 2 +- doc/Makefile | 11 +++++++++++ doc/media/Makefile | 3 ++- 3 files changed, 14 insertions(+), 2 deletions(-)
diff --git a/Makefile b/Makefile index de5746399a..597a8886c3 100644 --- a/Makefile +++ b/Makefile @@ -2372,7 +2372,7 @@ tcheck: # Documentation targets # --------------------------------------------------------------------------- DOC_TARGETS := xmldocs latexdocs pdfdocs htmldocs epubdocs cleandocs \ - linkcheckdocs dochelp refcheckdocs + linkcheckdocs dochelp refcheckdocs texinfodocs infodocs PHONY += $(DOC_TARGETS) $(DOC_TARGETS): scripts_basic FORCE $(Q)$(MAKE) $(build)=doc $@ diff --git a/doc/Makefile b/doc/Makefile index f5de65e927..62effd0fec 100644 --- a/doc/Makefile +++ b/doc/Makefile @@ -69,6 +69,15 @@ quiet_cmd_sphinx = SPHINX $@ --> file://$(abspath $(BUILDDIR)/$3/$4) htmldocs: @+$(foreach var,$(SPHINXDIRS),$(call loop_cmd,sphinx,html,$(var),,$(var)))
+texinfodocs: + @$(srctree)/scripts/sphinx-pre-install --version-check + @+$(foreach var,$(SPHINXDIRS),$(call loop_cmd,sphinx,texinfo,$(var),texinfo,$(var))) + +# Note: the 'info' Make target is generated by sphinx itself when +# running the texinfodocs target defined above. +infodocs: texinfodocs + $(MAKE) -C $(BUILDDIR)/texinfo info + linkcheckdocs: @$(foreach var,$(SPHINXDIRS),$(call loop_cmd,sphinx,linkcheck,$(var),,$(var)))
@@ -109,6 +118,8 @@ cleandocs: dochelp: @echo ' U-Boot documentation in different formats from ReST:' @echo ' htmldocs - HTML' + @echo ' texinfodocs - Texinfo' + @echo ' infodocs - Info' @echo ' latexdocs - LaTeX' @echo ' pdfdocs - PDF' @echo ' epubdocs - EPUB' diff --git a/doc/media/Makefile b/doc/media/Makefile index b9b43a34c3..9b32258696 100644 --- a/doc/media/Makefile +++ b/doc/media/Makefile @@ -22,10 +22,11 @@ $(BUILDDIR)/linker_lists.h.rst: ${API}/linker_lists.h ${PARSER} $(SRC_DIR)/linke
# Media build rules
-.PHONY: all html epub xml latex +.PHONY: all html texinfo epub xml latex
all: $(IMGDOT) $(BUILDDIR) ${TARGETS} html: all +texinfo: all epub: all xml: all latex: $(IMGPDF) all
base-commit: 9bd3d354a1a0712ac27c717df9ad60566b0406ee
PHONY += $(DOC_TARGETS) $(DOC_TARGETS): scripts_basic FORCE $(Q)$(MAKE) $(build)=doc $@linkcheckdocs dochelp refcheckdocs texinfodocs infodocs
+texinfodocs:
- @$(srctree)/scripts/sphinx-pre-install --version-check
- @+$(foreach var,$(SPHINXDIRS),$(call loop_cmd,sphinx,texinfo,$(var),texinfo,$(var)))
- $(MAKE) -C $(BUILDDIR)/texinfo info
- linkcheckdocs: @$(foreach var,$(SPHINXDIRS),$(call loop_cmd,sphinx,linkcheck,$(var),,$(var)))
- @echo ' texinfodocs - Texinfo'
- @echo ' infodocs - Info'
This does not work:
$ make infodocs make[1]: ./scripts/sphinx-pre-install: No such file or directory
$ make texinfodocs make[1]: ./scripts/sphinx-pre-install: No such file or directory make[1]: *** [doc/Makefile:73: texinfodocs] Error 127 make: *** [Makefile:2378: texinfodocs] Error 2
@Tom: Should we add a build step for each of the new targets to .gitlab-ci.yml and .azure-pipelines.yml?
Best regards
Heinrich
# Media build rules
Hi Heinrich,
Heinrich Schuchardt xypron.glpk@gmx.de writes:
+texinfodocs:
This does not work:
Good catch; this is not a problem introduced by the new targets, I think (already in the Makefile -- it must happen for other documentation targets too, no?). I'll look into it.
The reason I overlooked this was that I'm already patching out the 'sphinx-pre-install' script invocation in the to-become 'u-boot-documentation' Guix package, as that was problematic in the Linux tree, which uses the same build system (I forgot why exactly, perhaps it used sudo or wanted to setup its own virtualenvs).
On 12/17/22 16:02, Maxim Cournoyer wrote:
Hi Heinrich,
+texinfodocs:
This does not work:
make htmldocs is what we rely on to generate https://u-boot.readthedocs.io. This works fine.
Best regards
Heinrich
+texinfodocs:
This does not work:
We should rename the job and build all doc targets, once they've been fixed I think.
Maxim Cournoyer
