[PATCH] spi: mtk_spim: prevent global pll clock override
With commit 793e6230118032a099ec42a1ea67f434721edcc0 a new system to calculate the SPI clocks has been added.
Unfortunately, the do_div macro overrides the global priv->pll_clk_rate field. This will cause to have a reduced clock rate on each subsequent SPI call.
Signed-off-by: Valerio 'ftp21' Mancini ftp21@ftp21.eu Signed-off-by: Nicolò Veronese nicveronese@gmail.com --- drivers/spi/mtk_spim.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/mtk_spim.c b/drivers/spi/mtk_spim.c index 418e586b91..90f4c3cecb 100644 --- a/drivers/spi/mtk_spim.c +++ b/drivers/spi/mtk_spim.c @@ -409,7 +409,7 @@ static int mtk_spim_transfer_wait(struct spi_slave *slave, { struct udevice *bus = dev_get_parent(slave->dev); struct mtk_spim_priv *priv = dev_get_priv(bus); - u32 sck_l, sck_h, clk_count, reg; + u32 pll_clk, sck_l, sck_h, clk_count, reg; ulong us = 1; int ret = 0;
@@ -418,11 +418,12 @@ static int mtk_spim_transfer_wait(struct spi_slave *slave, else clk_count = op->data.nbytes;
+ pll_clk = priv->pll_clk_rate; sck_l = readl(priv->base + SPI_CFG2_REG) >> SPI_CFG2_SCK_LOW_OFFSET; sck_h = readl(priv->base + SPI_CFG2_REG) & SPI_CFG2_SCK_HIGH_MASK; - do_div(priv->pll_clk_rate, sck_l + sck_h + 2); + do_div(pll_clk, sck_l + sck_h + 2);
- us = CLK_TO_US(priv->pll_clk_rate, clk_count * 8); + us = CLK_TO_US(pll_clk, clk_count * 8); us += 1000 * 1000; /* 1s tolerance */
if (us > UINT_MAX)
Nicolò Veronese
