[U-Boot] [PATCH] pmic: Fix pfuze100 bit definitions
The following patch changed the PFUZE100 swbst register bit definitions and broke PMIC configuration on multiple boards, at least on the novena and gw_ventana. This patch fixes it.
commit 8fa46350a4c7dca7710362f6c871098557b934ad Author: Peng Fan Peng.Fan@freescale.com Date: Fri Aug 7 16:43:45 2015 +0800
power: regulator: add pfuze100 support
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Peng Fan Peng.Fan@freescale.com Cc: Przemyslaw Marczak p.marczak@samsung.com Cc: Tim Harvey tharvey@gateworks.com Cc: Vagrant Cascadian vagrant@aikidev.net --- include/power/pfuze100_pmic.h | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/power/pfuze100_pmic.h b/include/power/pfuze100_pmic.h index 41cb710..cc019a9 100644 --- a/include/power/pfuze100_pmic.h +++ b/include/power/pfuze100_pmic.h @@ -215,10 +215,10 @@ enum { #define SWBST_VOL_MASK 0x3 #define SWBST_MODE_MASK 0xC #define SWBST_MODE_SHIFT 0x2 -#define SWBST_MODE_OFF 0 -#define SWBST_MODE_PFM 1 -#define SWBST_MODE_AUTO 2 -#define SWBST_MODE_APS 3 +#define SWBST_MODE_OFF (0 << 2) +#define SWBST_MODE_PFM (1 << 2) +#define SWBST_MODE_AUTO (2 << 2) +#define SWBST_MODE_APS (3 << 2)
/* * Regulator Mode Control
Tested on a Novena PVT2-A, fixes USB support.
Tested-by: Vagrant Cascadian vagrant@aikidev.net
live well, vagrant
- Regulator Mode Control
-- 2.6.2
Can we use "(SWBST_MODE_AUTO << SWBST_MODE_SHIFT)" in the board code, but not revert this?
Thanks, Peng.
-- 2.6.2
On Thursday, November 26, 2015 at 02:27:01 AM, Peng Fan wrote:
Hi Marek,
I undid the breakage introduced by the aforementioned patch. If you want to update all the boards which use these macros and then drop the bitshift, patch is welcome, but that's beyond the scope of this fix.
Best regards, Marek Vasut
Hi Marek,
Hmm. My original patch is that bit shift not included into "mode", the user need to do bitshift by itself. I'll check the pfuze100_regulator driver.
If "mode" needs to include the bit shift, then patch is ok and Reviewed-by: Peng Fan Peng.Fan@freescale.com
Regards, Peng.
Hello Marek,
Ok we missed this in the review. But as I can see it broken only the two boards, you mentioned.
The intentions are good, but this patch fixes one thing and breaks the another one, I would prefer avoid this.
'git grep -n SWBST_MODE'
As I can see, you can fix the issue for multiple boards by update only two lines in those two boards, which you mentioned.
So why you moving back those definitions, since they are now used in more places?
The line suggested by Peng is good enough to call it 'fix' for your boards:
On Thursday, November 26, 2015 at 01:21:36 PM, Przemyslaw Marczak wrote:
Hello Marek,
OK, so instead of fixing the patch which introduced a bug, we're supposed to be fixing the fallout from that. I cannot say I'm very happy with this sort of handling of a bug and with the testing this particular change received.
Besides, seeing how this patch already needed another patch to make it complete and how it now needs more patches to fix the boards which it broke, I am really disappointed.
Hello Marek,
Hello Marek,
You are right, the mentioned patch breaks your boards, and we missed this in the review as I mentioned - sorry for that.
But for now, there is also other code based on those definitions, so you can not just revert only this particular change and ignore the rest - because it breaks the new code? Should we all work in this way?
As a custodian I'm not able to test everything, especially when I don't have the hardware for it. Moreover I trust people who are working for this project and I can imagine that they test the code.
I can't understand what is the problem. You send new patch with two simple lines - it fixes your issue and doesn't break the existing PMIC driver. I think, this is what we need here.
On Thursday, November 26, 2015 at 03:35:26 PM, Przemyslaw Marczak wrote:
Hello Marek,
Hello Marek,
This is even worse then -- the patch adds code which uses the changed macros, but doesn't fix the existing users. This should not happen again and it'd be very nice if the author actually checked when digging in /include and changing some macros there if this might affect someone.
I don't expect you to test anything in this case, other but possibly compile testing the stuff, don't get me wrong.
I did that. And unfortunatelly, it turns out we have really no other option now, than to fix the boards. Sigh ...
Hello Marek,
Hello Marek,
Hello Marek,
Ok, but as you could check in this example, even recompile all boards with such kind of 'new patch' - will not tell you what is wrong, because it doesn't break the build...
But isn't this also an important part of our job?
I don't know why we discuss about this...
Found bug? Can fix? Then send a patch and don't blame the people for a bugs - it's natural. Don't cry if got a comments - this is the Open Source project:)
I hope you don't get me wrong.
Have a nice weekend! - I'm starting it right now:)
On Thursday, November 26, 2015 at 05:13:55 PM, Przemyslaw Marczak wrote:
Hello Marek,
Hello Marek,
Hello Marek,
Yeah
I already did that, but it seems to be about time to re-state that if you dig in /include, then you should check thoroughly if your change cannot have some sort of side-effects.
Please, educate me more on this topic :)
DTTO.
You as well, cheers!
Peng Fan
Przemyslaw Marczak
Vagrant Cascadian
