[PATCH] dm: core: downgrade some dm_warn messages to log_debug()
People complained that enabling (SPL_)DM_WARN was now totally unusable due to the amount of messages printed on the console.
Let's downgrade the log level of some messages that are clearly not on the error path.
Note that there's one pr_debug in there, because it is followed by pr_cont so it made sense to reuse the same family of functions.
Reported-by: Alexander Dahl ada@thorsis.com Fixes: 6afdb1585112 ("dm: core: migrate debug() messages to use dm_warn") Signed-off-by: Quentin Schulz quentin.schulz@cherry.de --- Note that I am not entirely sure about the "not found" and "not large enough" changes there.
Another note, %#x isn't handled by tinyprintf so it just prints "x" instead of the value.
Finally, I don't know how one can enable LOG_DEBUG level without enabling DEBUG which enables assert() so I just tested that by removing the #define DEBUG in include/log.h :) --- drivers/core/of_access.c | 36 ++++++++++++------------- drivers/core/of_addr.c | 26 +++++++++--------- drivers/core/of_extra.c | 6 ++--- drivers/core/ofnode.c | 68 ++++++++++++++++++++++++------------------------ 4 files changed, 68 insertions(+), 68 deletions(-)
diff --git a/drivers/core/of_access.c b/drivers/core/of_access.c index d05be273e7bbb68c3ad82ef4c1c036ae7f68ae61..77acd76626257b6da95a27d107052ff8800c2b67 100644 --- a/drivers/core/of_access.c +++ b/drivers/core/of_access.c @@ -490,17 +490,17 @@ int of_read_u8(const struct device_node *np, const char *propname, u8 *outp) { const u8 *val;
- dm_warn("%s: %s: ", __func__, propname); + log_debug("%s: %s: ", __func__, propname); if (!np) return -EINVAL; val = of_find_property_value_of_size(np, propname, sizeof(*outp)); if (IS_ERR(val)) { - dm_warn("(not found)\n"); + log_debug("(not found)\n"); return PTR_ERR(val); }
*outp = *val; - dm_warn("%#x (%d)\n", *outp, *outp); + log_debug("%#x (%d)\n", *outp, *outp);
return 0; } @@ -509,17 +509,17 @@ int of_read_u16(const struct device_node *np, const char *propname, u16 *outp) { const __be16 *val;
*outp = be16_to_cpup(val); - dm_warn("%#x (%d)\n", *outp, *outp); + log_debug("%#x (%d)\n", *outp, *outp);
return 0; } @@ -534,14 +534,14 @@ int of_read_u32_array(const struct device_node *np, const char *propname, { const __be32 *val;
- dm_warn("%s: %s: ", __func__, propname); + log_debug("%s: %s: ", __func__, propname); val = of_find_property_value_of_size(np, propname, sz * sizeof(*out_values));
if (IS_ERR(val)) return PTR_ERR(val);
- dm_warn("size %zd\n", sz); + log_debug("size %zd\n", sz); while (sz--) *out_values++ = be32_to_cpup(val++);
@@ -553,19 +553,19 @@ int of_read_u32_index(const struct device_node *np, const char *propname, { const __be32 *val;
val = of_find_property_value_of_size(np, propname, sizeof(*outp) * (index + 1)); if (IS_ERR(val)) { - dm_warn("(not found)\n"); + log_debug("(not found)\n"); return PTR_ERR(val); }
*outp = be32_to_cpup(val + index); - dm_warn("%#x (%d)\n", *outp, *outp); + log_debug("%#x (%d)\n", *outp, *outp);
return 0; } @@ -575,20 +575,20 @@ int of_read_u64_index(const struct device_node *np, const char *propname, { const __be64 *val;
*outp = be64_to_cpup(val + index); - dm_warn("%#llx (%lld)\n", (unsigned long long)*outp, - (unsigned long long)*outp); + log_debug("%#llx (%lld)\n", (unsigned long long)*outp, + (unsigned long long)*outp);
return 0; } @@ -621,7 +621,7 @@ int of_property_match_string(const struct device_node *np, const char *propname, l = strnlen(p, end - p) + 1; if (p + l > end) return -EILSEQ; - dm_warn("comparing %s with %s\n", string, p); + log_debug("comparing %s with %s\n", string, p); if (strcmp(string, p) == 0) return i; /* Found it; return index */ } @@ -826,8 +826,8 @@ static void of_alias_add(struct alias_prop *ap, struct device_node *np, strncpy(ap->stem, stem, stem_len); ap->stem[stem_len] = 0; list_add_tail(&ap->link, &aliases_lookup); - dm_warn("adding DT alias:%s: stem=%s id=%i node=%s\n", - ap->alias, ap->stem, ap->id, of_node_full_name(np)); + log_debug("adding DT alias:%s: stem=%s id=%i node=%s\n", + ap->alias, ap->stem, ap->id, of_node_full_name(np)); }
int of_alias_scan(void) diff --git a/drivers/core/of_addr.c b/drivers/core/of_addr.c index 6c7b4c97d6778e632e6c318ca094bd94cc6248d4..250dd175b55c053fb80c7fa34ccaa66f3a4a8a1f 100644 --- a/drivers/core/of_addr.c +++ b/drivers/core/of_addr.c @@ -27,7 +27,7 @@ static struct of_bus *of_match_bus(struct device_node *np); #ifdef DEBUG static void of_dump_addr(const char *s, const __be32 *addr, int na) { - dm_warn("%s", s); + pr_debug("%s", s); while (na--) pr_cont(" %08x", be32_to_cpu(*(addr++))); pr_cont("\n"); @@ -66,9 +66,9 @@ static u64 of_bus_default_map(__be32 *addr, const __be32 *range, s = of_read_number(range + na + pna, ns); da = of_read_number(addr, na);
- dm_warn("default map, cp=%llx, s=%llx, da=%llx\n", - (unsigned long long)cp, (unsigned long long)s, - (unsigned long long)da); + log_debug("default map, cp=%llx, s=%llx, da=%llx\n", + (unsigned long long)cp, (unsigned long long)s, + (unsigned long long)da);
if (da < cp || da >= (cp + s)) return OF_BAD_ADDR; @@ -200,11 +200,11 @@ static int of_translate_one(const struct device_node *parent, if (ranges == NULL || rlen == 0) { offset = of_read_number(addr, na); memset(addr, 0, pna * 4); - dm_warn("empty ranges; 1:1 translation\n"); + log_debug("empty ranges; 1:1 translation\n"); goto finish; }
- dm_warn("walking ranges...\n"); + log_debug("walking ranges...\n");
/* Now walk through the ranges */ rlen /= 4; @@ -222,7 +222,7 @@ static int of_translate_one(const struct device_node *parent,
finish: of_dump_addr("parent translation for:", addr, pna); - dm_warn("with offset: %llx\n", (unsigned long long)offset); + log_debug("with offset: %llx\n", (unsigned long long)offset);
/* Translate it into parent bus space */ return pbus->translate(addr, offset, pna); @@ -247,7 +247,7 @@ static u64 __of_translate_address(const struct device_node *dev, int na, ns, pna, pns; u64 result = OF_BAD_ADDR;
- dm_warn("** translation for device %s **\n", of_node_full_name(dev)); + log_debug("** translation for device %s **\n", of_node_full_name(dev));
/* Increase refcount at current level */ (void)of_node_get(dev); @@ -266,8 +266,8 @@ static u64 __of_translate_address(const struct device_node *dev, } memcpy(addr, in_addr, na * 4);
- dm_warn("bus is %s (na=%d, ns=%d) on %s\n", bus->name, na, ns, - of_node_full_name(parent)); + log_debug("bus is %s (na=%d, ns=%d) on %s\n", bus->name, na, ns, + of_node_full_name(parent)); of_dump_addr("translating address:", addr, na);
/* Translate */ @@ -279,7 +279,7 @@ static u64 __of_translate_address(const struct device_node *dev,
/* If root, we have finished */ if (parent == NULL) { - dm_warn("reached root node\n"); + log_debug("reached root node\n"); result = of_read_number(addr, na); break; } @@ -293,8 +293,8 @@ static u64 __of_translate_address(const struct device_node *dev, break; }
- dm_warn("parent bus is %s (na=%d, ns=%d) on %s\n", pbus->name, - pna, pns, of_node_full_name(parent)); + log_debug("parent bus is %s (na=%d, ns=%d) on %s\n", pbus->name, + pna, pns, of_node_full_name(parent));
/* Apply bus translation */ if (of_translate_one(dev, bus, pbus, addr, na, ns, pna, rprop)) diff --git a/drivers/core/of_extra.c b/drivers/core/of_extra.c index bfc1e3441b1d63e3ef72352863842c9e49647db5..f49187dfc1ec2491b525be35d8deac0bd70a6c4e 100644 --- a/drivers/core/of_extra.c +++ b/drivers/core/of_extra.c @@ -58,7 +58,7 @@ int ofnode_decode_region(ofnode node, const char *prop_name, fdt_addr_t *basep, const fdt_addr_t *cell; int len;
- dm_warn("%s: %s: %s\n", __func__, ofnode_get_name(node), prop_name); + log_debug("%s: %s: %s\n", __func__, ofnode_get_name(node), prop_name); cell = ofnode_get_property(node, prop_name, &len); if (!cell || (len < sizeof(fdt_addr_t) * 2)) { dm_warn("cell=%p, len=%d\n", cell, len); @@ -67,8 +67,8 @@ int ofnode_decode_region(ofnode node, const char *prop_name, fdt_addr_t *basep,
*basep = fdt_addr_to_cpu(*cell); *sizep = fdt_size_to_cpu(cell[1]); - dm_warn("%s: base=%08lx, size=%lx\n", __func__, (ulong)*basep, - (ulong)*sizep); + log_debug("%s: base=%08lx, size=%lx\n", __func__, (ulong)*basep, + (ulong)*sizep);
return 0; } diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 48ae8ce830ec5a37675900e4f537e087fcac37b7..950895e72a9949fff44222fd039a82a9351de714 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -315,7 +315,7 @@ int ofnode_read_u8(ofnode node, const char *propname, u8 *outp) int len;
assert(ofnode_valid(node)); - dm_warn("%s: %s: ", __func__, propname); + log_debug("%s: %s: ", __func__, propname);
if (ofnode_is_np(node)) return of_read_u8(ofnode_to_np(node), propname, outp); @@ -323,11 +323,11 @@ int ofnode_read_u8(ofnode node, const char *propname, u8 *outp) cell = fdt_getprop(gd->fdt_blob, ofnode_to_offset(node), propname, &len); if (!cell || len < sizeof(*cell)) { - dm_warn("(not found)\n"); + log_debug("(not found)\n"); return -EINVAL; } *outp = *cell; - dm_warn("%#x (%u)\n", *outp, *outp); + log_debug("%#x (%u)\n", *outp, *outp);
return 0; } @@ -346,7 +346,7 @@ int ofnode_read_u16(ofnode node, const char *propname, u16 *outp) int len;
if (ofnode_is_np(node)) return of_read_u16(ofnode_to_np(node), propname, outp); @@ -354,11 +354,11 @@ int ofnode_read_u16(ofnode node, const char *propname, u16 *outp) cell = fdt_getprop(gd->fdt_blob, ofnode_to_offset(node), propname, &len); if (!cell || len < sizeof(*cell)) { - dm_warn("(not found)\n"); + log_debug("(not found)\n"); return -EINVAL; } *outp = be16_to_cpup(cell); - dm_warn("%#x (%u)\n", *outp, *outp); + log_debug("%#x (%u)\n", *outp, *outp);
return 0; } @@ -391,7 +391,7 @@ int ofnode_read_u32_index(ofnode node, const char *propname, int index, int len;
if (ofnode_is_np(node)) return of_read_u32_index(ofnode_to_np(node), propname, index, @@ -400,17 +400,17 @@ int ofnode_read_u32_index(ofnode node, const char *propname, int index, cell = fdt_getprop(ofnode_to_fdt(node), ofnode_to_offset(node), propname, &len); if (!cell) { - dm_warn("(not found)\n"); + log_debug("(not found)\n"); return -EINVAL; }
if (len < (sizeof(int) * (index + 1))) { - dm_warn("(not large enough)\n"); + log_debug("(not large enough)\n"); return -EOVERFLOW; }
*outp = fdt32_to_cpu(cell[index]); - dm_warn("%#x (%u)\n", *outp, *outp); + log_debug("%#x (%u)\n", *outp, *outp);
return 0; } @@ -430,17 +430,17 @@ int ofnode_read_u64_index(ofnode node, const char *propname, int index, cell = fdt_getprop(ofnode_to_fdt(node), ofnode_to_offset(node), propname, &len); if (!cell) { - dm_warn("(not found)\n"); + log_debug("(not found)\n"); return -EINVAL; }
if (len < (sizeof(u64) * (index + 1))) { - dm_warn("(not large enough)\n"); + log_debug("(not large enough)\n"); return -EOVERFLOW; }
*outp = fdt64_to_cpu(cell[index]); - dm_warn("%#llx (%llu)\n", *outp, *outp); + log_debug("%#llx (%llu)\n", *outp, *outp);
return 0; } @@ -468,7 +468,7 @@ int ofnode_read_u64(ofnode node, const char *propname, u64 *outp) int len;
if (ofnode_is_np(node)) return of_read_u64(ofnode_to_np(node), propname, outp); @@ -476,12 +476,12 @@ int ofnode_read_u64(ofnode node, const char *propname, u64 *outp) cell = fdt_getprop(ofnode_to_fdt(node), ofnode_to_offset(node), propname, &len); if (!cell || len < sizeof(*cell)) { - dm_warn("(not found)\n"); + log_debug("(not found)\n"); return -EINVAL; } *outp = fdt64_to_cpu(cell[0]); - dm_warn("%#llx (%llu)\n", (unsigned long long)*outp, - (unsigned long long)*outp); + log_debug("%#llx (%llu)\n", (unsigned long long)*outp, + (unsigned long long)*outp);
return 0; } @@ -499,11 +499,11 @@ bool ofnode_read_bool(ofnode node, const char *propname) bool prop;
prop = ofnode_has_property(node, propname);
- dm_warn("%s\n", prop ? "true" : "false"); + log_debug("%s\n", prop ? "true" : "false");
return prop ? true : false; } @@ -514,7 +514,7 @@ const void *ofnode_read_prop(ofnode node, const char *propname, int *sizep) int len;
if (ofnode_is_np(node)) { struct property *prop = of_find_property( @@ -529,7 +529,7 @@ const void *ofnode_read_prop(ofnode node, const char *propname, int *sizep) propname, &len); } if (!val) { - dm_warn("<not found>\n"); + log_debug("<not found>\n"); if (sizep) *sizep = -FDT_ERR_NOTFOUND; return NULL; @@ -553,7 +553,7 @@ const char *ofnode_read_string(ofnode node, const char *propname) dm_warn("<invalid>\n"); return NULL; } - dm_warn("%s\n", str); + log_debug("%s\n", str);
return str; } @@ -573,7 +573,7 @@ ofnode ofnode_find_subnode(ofnode node, const char *subnode_name) ofnode subnode;
assert(ofnode_valid(node)); - dm_warn("%s: %s: ", __func__, subnode_name); + log_debug("%s: %s: ", __func__, subnode_name);
if (ofnode_is_np(node)) { struct device_node *np = ofnode_to_np(node); @@ -588,8 +588,8 @@ ofnode ofnode_find_subnode(ofnode node, const char *subnode_name) ofnode_to_offset(node), subnode_name); subnode = noffset_to_ofnode(node, ooffset); } - dm_warn("%s\n", ofnode_valid(subnode) ? - ofnode_get_name(subnode) : "<none>"); + log_debug("%s\n", ofnode_valid(subnode) ? + ofnode_get_name(subnode) : "<none>");
return subnode; } @@ -598,7 +598,7 @@ int ofnode_read_u32_array(ofnode node, const char *propname, u32 *out_values, size_t sz) { assert(ofnode_valid(node)); - dm_warn("%s: %s: ", __func__, propname); + log_debug("%s: %s: ", __func__, propname);
if (ofnode_is_np(node)) { return of_read_u32_array(ofnode_to_np(node), propname, @@ -1032,7 +1032,7 @@ ofnode ofnode_get_aliases_node(const char *name) if (!prop) return ofnode_null();
- dm_warn("%s: node_path: %s\n", __func__, prop); + log_debug("%s: node_path: %s\n", __func__, prop);
return ofnode_path(prop); } @@ -1301,7 +1301,7 @@ int ofnode_read_pci_addr(ofnode node, enum fdt_pci_space type, int len; int ret = -ENOENT;
/* * If we follow the pci bus bindings strictly, we should check @@ -1318,10 +1318,10 @@ int ofnode_read_pci_addr(ofnode node, enum fdt_pci_space type, int i;
for (i = 0; i < num; i++) { - dm_warn("pci address #%d: %08lx %08lx %08lx\n", i, - (ulong)fdt32_to_cpu(cell[0]), - (ulong)fdt32_to_cpu(cell[1]), - (ulong)fdt32_to_cpu(cell[2])); + log_debug("pci address #%d: %08lx %08lx %08lx\n", i, + (ulong)fdt32_to_cpu(cell[0]), + (ulong)fdt32_to_cpu(cell[1]), + (ulong)fdt32_to_cpu(cell[2])); if ((fdt32_to_cpu(*cell) & type) == type) { const unaligned_fdt64_t *ptr;
@@ -1348,7 +1348,7 @@ int ofnode_read_pci_addr(ofnode node, enum fdt_pci_space type, ret = -EINVAL;
fail: - dm_warn("(not found)\n"); + log_debug("(not found)\n"); return ret; }
@@ -1632,7 +1632,7 @@ int ofnode_write_string(ofnode node, const char *propname, const char *value) { assert(ofnode_valid(node));
- dm_warn("%s: %s = %s", __func__, propname, value); + log_debug("%s: %s = %s", __func__, propname, value);
return ofnode_write_prop(node, propname, value, strlen(value) + 1, false);
--- base-commit: d2061828a4c1b60b44cd2307b6a782ac2efbffbe change-id: 20241015-dm-debug-less-verbose-29d4aba76f5b
Ah, and I was also wondering if we shouldn't actually use
log(LOGC_DM, LOGL_DEBUG, ...)
instead of log_debug() (which uses LOGL_CATEGORY, set by UCLASSes or drivers usually as far as I could tell?)
If we do, then maybe having dm_debug() similarly to dm_warn() would make sense?
Cheers, Quentin
Hello Quentin,
Am Tue, Oct 15, 2024 at 04:32:14PM +0200 schrieb Quentin Schulz:
- log_debug("%s: %s: ", __func__, propname);
Printing __func__ when using log_* functions, is redundant, isn't it? You can enabling printing the function name through the logging framework, right?
return PTR_ERR(val);log_debug("(not found)\n");
What about using log_msg_ret() instead in these cases?
Greets Alex
*outp = *val;
- log_debug("%s: %s: ", __func__, propname); if (!np) return -EINVAL; val = of_find_property_value_of_size(np, propname, sizeof(*outp)); if (IS_ERR(val)) {
- log_debug("size %zd\n", sz); while (sz--) *out_values++ = be32_to_cpup(val++);
if (strcmp(string, p) == 0) return i; /* Found it; return index */ }log_debug("comparing %s with %s\n", string, p);
- log_debug("adding DT alias:%s: stem=%s id=%i node=%s\n",
- dm_warn("%s", s);
- pr_debug("%s", s); while (na--) pr_cont(" %08x", be32_to_cpu(*(addr++))); pr_cont("\n");
goto finish; }log_debug("empty ranges; 1:1 translation\n");
/* Translate */
}log_debug("reached root node\n"); result = of_read_number(addr, na); break;
- log_debug("%s: %s: %s\n", __func__, ofnode_get_name(node), prop_name); cell = ofnode_get_property(node, prop_name, &len); if (!cell || (len < sizeof(fdt_addr_t) * 2)) { dm_warn("cell=%p, len=%d\n", cell, len);
(ulong)*sizep);
(ulong)*sizep);
return -EINVAL; } *outp = *cell;log_debug("(not found)\n");
return -EINVAL; } *outp = be16_to_cpup(cell);log_debug("(not found)\n");
return -EINVAL; }
return -EINVAL; }
return -EINVAL; } *outp = fdt64_to_cpu(cell[0]);log_debug("(not found)\n");
if (sizep) *sizep = -FDT_ERR_NOTFOUND; return NULL;log_debug("<not found>\n");
return str;
return subnode;
- If we follow the pci bus bindings strictly, we should check
fail:
- log_debug("(not found)\n"); return ret;
Hi Alex,
On 10/17/24 4:56 PM, Alexander Dahl wrote:
Hello Quentin,
Only if LOGF_FUNC symbol is enabled, if I understood correctly. Not an excuse but:
$ git grep -o "log.*__func__" | wc -l 202
So there are a "few" other places doing that. Will let Simon decide on that one, no personal opinion.
log_msg_ret will log with LOGL_ERR and not LOGL_DEBUG if LOG_ERROR_RETURN symbol is enabled, otherwise it'll simply not be printed. It's a change of behavior/expectation here.
If we go this route we should at least make this a bit more useful by adding the propname to the error message since it would be printed with log_debug() at the beginning of the function, and the log level wouldn't match. Also, this means that enabling debug log level but not enabling LOG_ERROR_RETURN would basically print the first log_debug() and nothing else in case it fails. A choice to be made but it's a bit more complex than the one above.
Cheers, Quentin
Hi Quentin,
This is an improvement, so:
For -EOVERFLOW I think warning would be better, but in that case you need to print a prefix, since otherwise the warning will have nothing before it. So it is a little tricky. I can imagine some support in the log module to help with this, although I haven't thought about it too hard.
Also, we should really remove __func__ when adding logging, since people can enable the option if they want function names to be stored.
Hi Simon,
On 10/27/24 6:16 PM, Simon Glass wrote:
Hi Quentin,
Agreed. We could also simply print the propname in the dm_warn() call and keep the one at the top of the function to use dm_debug() instead.
But then we'll have a bunch of functions printing one of their parameters and "(not found)" for example. A bit odd to me. But on the theoretical level, I agree, enabling the appropriate symbol would already add that line, it's just that I see limit use of those messages if it's not set.
Thanks for the review!
Cheers, Quentin
participants (5)
Alexander Dahl
Quentin Schulz
Quentin Schulz
