[U-Boot] [PATCH v8 00/10] Fix CVE-2018-18440 and CVE-2018-18439
This series fixes CVE-2018-18440 ("insufficient boundary checks in filesystem image load") by adding restrictions to the 'load' command and fixes CVE-2018-18439 ("insufficient boundary checks in network image boot") by adding restrictions to the tftp code. The functions from lmb.c are used to setup regions of allowed and reserved memory. Then, the file size to load is checked against these addresses and loading the file is aborted if it would overwrite reserved memory.
The memory reservation code is reused from bootm/image.
Changes in v8: - fix address overflow in 'arch_lmb_reserve' for ARM
Changes in v7: - add braces around if/else with macros accross more than one line - fix compiling without CONFIG_FIT - fix compiling without CONFIG_LMB
Changes in v6: - fix size of allocated regions that need alignment padding - fix compiling without OF_CONTROL - fixed NULL pointer access in 'fdt_blob' passed to 'boot_fdt_add_mem_rsv_regions'
Changes in v5: - added tests for lib/lmb.c - fixed bug in lmb.c when ram is at the end of 32-bit address range - fixed a bug in lmb_alloc_addr when resulting reserved ranges get combined
Changes in v4: - fixed invalid 'if' statement without braces in boot_fdt_reserve_region - removed patch 7 ("net: remove CONFIG_MCAST_TFTP), adapted patch 8
Changes in v3: - No patch changes, but needed to resend since patman added too many cc addresses that gmail seemed to detect as spam :-(
Changes in v2: - added code to reserve devicetree reserved-memory in lmb - added tftp fixes (patches 7 and 8) - fixed a bug in new function lmb_alloc_addr
Simon Goldschmidt (10): test: add test for lib/lmb.c lmb: fix allocation at end of address range lib: lmb: reserving overlapping regions should fail fdt: parse "reserved-memory" for memory reservation lib: lmb: extend lmb for checks at load time fs: prevent overwriting reserved memory bootm: use new common function lmb_init_and_reserve lmb: remove unused extern declaration tftp: prevent overwriting reserved memory arm: bootm: fix sp detection at end of address range
arch/arm/lib/bootm.c | 9 +- common/bootm.c | 8 +- common/image-fdt.c | 53 +++- fs/fs.c | 56 +++- include/lmb.h | 7 +- lib/Makefile | 1 + lib/lmb.c | 106 ++++++-- net/tftp.c | 73 +++++- test/lib/Makefile | 1 + test/lib/lmb.c | 601 +++++++++++++++++++++++++++++++++++++++++++ 10 files changed, 858 insertions(+), 57 deletions(-) create mode 100644 test/lib/lmb.c
Add basic tests for the lmb memory allocation code used to reserve and allocate memory during boot.
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com ---
Changes in v8: None Changes in v7: None Changes in v6: None Changes in v5: - this patch is new in v5
Changes in v4: None Changes in v2: None
test/lib/Makefile | 1 + test/lib/lmb.c | 297 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 298 insertions(+) create mode 100644 test/lib/lmb.c
diff --git a/test/lib/Makefile b/test/lib/Makefile index ea68fae566..5a636aac74 100644 --- a/test/lib/Makefile +++ b/test/lib/Makefile @@ -3,3 +3,4 @@ # (C) Copyright 2018 # Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc obj-y += hexdump.o +obj-y += lmb.o diff --git a/test/lib/lmb.c b/test/lib/lmb.c new file mode 100644 index 0000000000..dd7ba14b34 --- /dev/null +++ b/test/lib/lmb.c @@ -0,0 +1,297 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2018 Simon Goldschmidt + */ + +#include <common.h> +#include <lmb.h> +#include <dm/test.h> +#include <test/ut.h> + +static int check_lmb(struct unit_test_state *uts, struct lmb *lmb, + phys_addr_t ram_base, phys_size_t ram_size, + unsigned long num_reserved, + phys_addr_t base1, phys_size_t size1, + phys_addr_t base2, phys_size_t size2, + phys_addr_t base3, phys_size_t size3) +{ + ut_asserteq(lmb->memory.cnt, 1); + ut_asserteq(lmb->memory.region[0].base, ram_base); + ut_asserteq(lmb->memory.region[0].size, ram_size); + + ut_asserteq(lmb->reserved.cnt, num_reserved); + if (num_reserved > 0) { + ut_asserteq(lmb->reserved.region[0].base, base1); + ut_asserteq(lmb->reserved.region[0].size, size1); + } + if (num_reserved > 1) { + ut_asserteq(lmb->reserved.region[1].base, base2); + ut_asserteq(lmb->reserved.region[1].size, size2); + } + if (num_reserved > 2) { + ut_asserteq(lmb->reserved.region[2].base, base3); + ut_asserteq(lmb->reserved.region[2].size, size3); + } + return 0; +} + +#define ASSERT_LMB(lmb, ram_base, ram_size, num_reserved, base1, size1, \ + base2, size2, base3, size3) \ + ut_assert(!check_lmb(uts, lmb, ram_base, ram_size, \ + num_reserved, base1, size1, base2, size2, base3, \ + size3)) + +/* + * Test helper function that reserves 64 KiB somewhere in the simulated RAM and + * then does some alloc + free tests. + */ +static int test_multi_alloc(struct unit_test_state *uts, + const phys_addr_t ram, const phys_size_t ram_size, + const phys_addr_t alloc_64k_addr) +{ + const phys_addr_t ram_end = ram + ram_size; + const phys_addr_t alloc_64k_end = alloc_64k_addr + 0x10000; + + struct lmb lmb; + long ret; + phys_addr_t a, a2, b, b2, c, d; + + /* check for overflow */ + ut_assert(ram_end == 0 || ram_end > ram); + ut_assert(alloc_64k_end > alloc_64k_addr); + /* check input addresses + size */ + ut_assert(alloc_64k_addr >= ram + 8); + ut_assert(alloc_64k_end <= ram_end - 8); + + lmb_init(&lmb); + + ret = lmb_add(&lmb, ram, ram_size); + ut_asserteq(ret, 0); + + /* reserve 64KiB somewhere */ + ret = lmb_reserve(&lmb, alloc_64k_addr, 0x10000); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 1, alloc_64k_addr, 0x10000, + 0, 0, 0, 0); + + /* allocate somewhere, should be at the end of RAM */ + a = lmb_alloc(&lmb, 4, 1); + ut_asserteq(a, ram_end - 4); + ASSERT_LMB(&lmb, ram, ram_size, 2, alloc_64k_addr, 0x10000, + ram_end - 4, 4, 0, 0); + /* alloc below end of reserved region -> below reserved region */ + b = lmb_alloc_base(&lmb, 4, 1, alloc_64k_end); + ut_asserteq(b, alloc_64k_addr - 4); + ASSERT_LMB(&lmb, ram, ram_size, 2, + alloc_64k_addr - 4, 0x10000 + 4, ram_end - 4, 4, 0, 0); + + /* 2nd time */ + c = lmb_alloc(&lmb, 4, 1); + ut_asserteq(c, ram_end - 8); + ASSERT_LMB(&lmb, ram, ram_size, 2, + alloc_64k_addr - 4, 0x10000 + 4, ram_end - 8, 8, 0, 0); + d = lmb_alloc_base(&lmb, 4, 1, alloc_64k_end); + ut_asserteq(d, alloc_64k_addr - 8); + ASSERT_LMB(&lmb, ram, ram_size, 2, + alloc_64k_addr - 8, 0x10000 + 8, ram_end - 8, 8, 0, 0); + + ret = lmb_free(&lmb, a, 4); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 2, + alloc_64k_addr - 8, 0x10000 + 8, ram_end - 8, 4, 0, 0); + /* allocate again to ensure we get the same address */ + a2 = lmb_alloc(&lmb, 4, 1); + ut_asserteq(a, a2); + ASSERT_LMB(&lmb, ram, ram_size, 2, + alloc_64k_addr - 8, 0x10000 + 8, ram_end - 8, 8, 0, 0); + ret = lmb_free(&lmb, a2, 4); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 2, + alloc_64k_addr - 8, 0x10000 + 8, ram_end - 8, 4, 0, 0); + + ret = lmb_free(&lmb, b, 4); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 3, + alloc_64k_addr - 8, 4, alloc_64k_addr, 0x10000, + ram_end - 8, 4); + /* allocate again to ensure we get the same address */ + b2 = lmb_alloc_base(&lmb, 4, 1, alloc_64k_end); + ut_asserteq(b, b2); + ASSERT_LMB(&lmb, ram, ram_size, 2, + alloc_64k_addr - 8, 0x10000 + 8, ram_end - 8, 4, 0, 0); + ret = lmb_free(&lmb, b2, 4); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 3, + alloc_64k_addr - 8, 4, alloc_64k_addr, 0x10000, + ram_end - 8, 4); + + ret = lmb_free(&lmb, c, 4); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 2, + alloc_64k_addr - 8, 4, alloc_64k_addr, 0x10000, 0, 0); + ret = lmb_free(&lmb, d, 4); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 1, alloc_64k_addr, 0x10000, + 0, 0, 0, 0); + + return 0; +} + +static int test_multi_alloc_512mb(struct unit_test_state *uts, + const phys_addr_t ram) +{ + return test_multi_alloc(uts, ram, 0x20000000, ram + 0x10000000); +} + +/* Create a memory region with one reserved region and allocate */ +static int lib_test_lmb_simple(struct unit_test_state *uts) +{ + /* simulate 512 MiB RAM beginning at 1GiB */ + return test_multi_alloc_512mb(uts, 0x40000000); +} + +DM_TEST(lib_test_lmb_simple, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Simulate 512 MiB RAM, allocate some blocks that fit/don't fit */ +static int test_bigblock(struct unit_test_state *uts, const phys_addr_t ram) +{ + const phys_size_t ram_size = 0x20000000; + const phys_size_t big_block_size = 0x10000000; + const phys_addr_t ram_end = ram + ram_size; + const phys_addr_t alloc_64k_addr = ram + 0x10000000; + struct lmb lmb; + long ret; + phys_addr_t a, b; + + /* check for overflow */ + ut_assert(ram_end == 0 || ram_end > ram); + + lmb_init(&lmb); + + ret = lmb_add(&lmb, ram, ram_size); + ut_asserteq(ret, 0); + + /* reserve 64KiB in the middle of RAM */ + ret = lmb_reserve(&lmb, alloc_64k_addr, 0x10000); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 1, alloc_64k_addr, 0x10000, + 0, 0, 0, 0); + + /* allocate a big block, should be below reserved */ + a = lmb_alloc(&lmb, big_block_size, 1); + ut_asserteq(a, ram); + ASSERT_LMB(&lmb, ram, ram_size, 1, a, + big_block_size + 0x10000, 0, 0, 0, 0); + /* allocate 2nd big block */ + /* This should fail, printing an error */ + b = lmb_alloc(&lmb, big_block_size, 1); + ut_asserteq(b, 0); + ASSERT_LMB(&lmb, ram, ram_size, 1, a, + big_block_size + 0x10000, 0, 0, 0, 0); + + ret = lmb_free(&lmb, a, big_block_size); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 1, alloc_64k_addr, 0x10000, + 0, 0, 0, 0); + + /* allocate too big block */ + /* This should fail, printing an error */ + a = lmb_alloc(&lmb, ram_size, 1); + ut_asserteq(a, 0); + ASSERT_LMB(&lmb, ram, ram_size, 1, alloc_64k_addr, 0x10000, + 0, 0, 0, 0); + + return 0; +} + +static int lib_test_lmb_big(struct unit_test_state *uts) +{ + return test_bigblock(uts, 0x40000000); +} + +DM_TEST(lib_test_lmb_big, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Simulate 512 MiB RAM, allocate a block without previous reservation */ +static int test_noreserved(struct unit_test_state *uts, const phys_addr_t ram) +{ + const phys_size_t ram_size = 0x20000000; + const phys_addr_t ram_end = ram + ram_size; + struct lmb lmb; + long ret; + phys_addr_t a, b; + + /* check for overflow */ + ut_assert(ram_end == 0 || ram_end > ram); + + lmb_init(&lmb); + + ret = lmb_add(&lmb, ram, ram_size); + ut_asserteq(ret, 0); + + /* allocate a block */ + a = lmb_alloc(&lmb, 4, 1); + ut_assert(a != 0); + /* and free it */ + ret = lmb_free(&lmb, a, 4); + ut_asserteq(ret, 0); + + /* allocate a block with base*/ + b = lmb_alloc_base(&lmb, 4, 1, ram_end); + ut_assert(a == b); + /* and free it */ + ret = lmb_free(&lmb, b, 4); + ut_asserteq(ret, 0); + + return 0; +} + +static int lib_test_lmb_noreserved(struct unit_test_state *uts) +{ + return test_noreserved(uts, 0x40000000); +} + +DM_TEST(lib_test_lmb_noreserved, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* + * Simulate a RAM that starts at 0 and allocate down to address 0, which must + * fail as '0' means failure for the lmb_alloc functions. + */ +static int lib_test_lmb_at_0(struct unit_test_state *uts) +{ + const phys_addr_t ram = 0; + const phys_size_t ram_size = 0x20000000; + struct lmb lmb; + long ret; + phys_addr_t a, b; + + lmb_init(&lmb); + + ret = lmb_add(&lmb, ram, ram_size); + ut_asserteq(ret, 0); + + /* allocate nearly everything */ + a = lmb_alloc(&lmb, ram_size - 4, 1); + ut_asserteq(a, ram + 4); + ASSERT_LMB(&lmb, ram, ram_size, 1, a, ram_size - 4, + 0, 0, 0, 0); + /* allocate the rest */ + /* This should fail as the allocated address would be 0 */ + b = lmb_alloc(&lmb, 4, 1); + ut_asserteq(b, 0); + /* check that this was an error by checking lmb */ + ASSERT_LMB(&lmb, ram, ram_size, 1, a, ram_size - 4, + 0, 0, 0, 0); + /* check that this was an error by freeing b */ + ret = lmb_free(&lmb, b, 4); + ut_asserteq(ret, -1); + ASSERT_LMB(&lmb, ram, ram_size, 1, a, ram_size - 4, + 0, 0, 0, 0); + + ret = lmb_free(&lmb, a, ram_size - 4); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 0, 0, 0, 0, 0, 0, 0); + + return 0; +} + +DM_TEST(lib_test_lmb_at_0, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
The lmb code fails if base + size of RAM overflows to zero.
Fix this by calculating end as 'base + size - 1' instead of 'base + size' where appropriate.
Added tests to assert this is fixed.
lib/lmb.c | 29 ++++++++++++----------------- test/lib/lmb.c | 29 ++++++++++++++++++++++++++--- 2 files changed, 38 insertions(+), 20 deletions(-)
diff --git a/lib/lmb.c b/lib/lmb.c index 1705417348..6d3dcf4e09 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -43,7 +43,10 @@ void lmb_dump_all(struct lmb *lmb) static long lmb_addrs_overlap(phys_addr_t base1, phys_size_t size1, phys_addr_t base2, phys_size_t size2) { - return ((base1 < (base2+size2)) && (base2 < (base1+size1))); + const phys_addr_t base1_end = base1 + size1 - 1; + const phys_addr_t base2_end = base2 + size2 - 1; + + return ((base1 <= base2_end) && (base2 <= base1_end)); }
static long lmb_addrs_adjacent(phys_addr_t base1, phys_size_t size1, @@ -89,18 +92,9 @@ static void lmb_coalesce_regions(struct lmb_region *rgn,
void lmb_init(struct lmb *lmb) { - /* Create a dummy zero size LMB which will get coalesced away later. - * This simplifies the lmb_add() code below... - */ - lmb->memory.region[0].base = 0; - lmb->memory.region[0].size = 0; - lmb->memory.cnt = 1; + lmb->memory.cnt = 0; lmb->memory.size = 0; - - /* Ditto. */ - lmb->reserved.region[0].base = 0; - lmb->reserved.region[0].size = 0; - lmb->reserved.cnt = 1; + lmb->reserved.cnt = 0; lmb->reserved.size = 0; }
@@ -110,9 +104,10 @@ static long lmb_add_region(struct lmb_region *rgn, phys_addr_t base, phys_size_t unsigned long coalesced = 0; long adjacent, i;
- if ((rgn->cnt == 1) && (rgn->region[0].size == 0)) { + if (rgn->cnt == 0) { rgn->region[0].base = base; rgn->region[0].size = size; + rgn->cnt = 1; return 0; }
@@ -183,7 +178,7 @@ long lmb_free(struct lmb *lmb, phys_addr_t base, phys_size_t size) { struct lmb_region *rgn = &(lmb->reserved); phys_addr_t rgnbegin, rgnend; - phys_addr_t end = base + size; + phys_addr_t end = base + size - 1; int i;
rgnbegin = rgnend = 0; /* supress gcc warnings */ @@ -191,7 +186,7 @@ long lmb_free(struct lmb *lmb, phys_addr_t base, phys_size_t size) /* Find the region where (base, size) belongs to */ for (i=0; i < rgn->cnt; i++) { rgnbegin = rgn->region[i].base; - rgnend = rgnbegin + rgn->region[i].size; + rgnend = rgnbegin + rgn->region[i].size - 1;
if ((rgnbegin <= base) && (end <= rgnend)) break; @@ -209,7 +204,7 @@ long lmb_free(struct lmb *lmb, phys_addr_t base, phys_size_t size)
/* Check to see if region is matching at the front */ if (rgnbegin == base) { - rgn->region[i].base = end; + rgn->region[i].base = end + 1; rgn->region[i].size -= size; return 0; } @@ -225,7 +220,7 @@ long lmb_free(struct lmb *lmb, phys_addr_t base, phys_size_t size) * beginging of the hole and add the region after hole. */ rgn->region[i].size = base - rgn->region[i].base; - return lmb_add_region(rgn, end, rgnend - end); + return lmb_add_region(rgn, end + 1, rgnend - end); }
long lmb_reserve(struct lmb *lmb, phys_addr_t base, phys_size_t size) diff --git a/test/lib/lmb.c b/test/lib/lmb.c index dd7ba14b34..fb7ca45ef1 100644 --- a/test/lib/lmb.c +++ b/test/lib/lmb.c @@ -146,8 +146,15 @@ static int test_multi_alloc_512mb(struct unit_test_state *uts, /* Create a memory region with one reserved region and allocate */ static int lib_test_lmb_simple(struct unit_test_state *uts) { + int ret; + /* simulate 512 MiB RAM beginning at 1GiB */ - return test_multi_alloc_512mb(uts, 0x40000000); + ret = test_multi_alloc_512mb(uts, 0x40000000); + if (ret) + return ret; + + /* simulate 512 MiB RAM beginning at 1.5GiB */ + return test_multi_alloc_512mb(uts, 0xE0000000); }
DM_TEST(lib_test_lmb_simple, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); @@ -206,7 +213,15 @@ static int test_bigblock(struct unit_test_state *uts, const phys_addr_t ram)
static int lib_test_lmb_big(struct unit_test_state *uts) { - return test_bigblock(uts, 0x40000000); + int ret; + + /* simulate 512 MiB RAM beginning at 1GiB */ + ret = test_bigblock(uts, 0x40000000); + if (ret) + return ret; + + /* simulate 512 MiB RAM beginning at 1.5GiB */ + return test_bigblock(uts, 0xE0000000); }
DM_TEST(lib_test_lmb_big, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); @@ -247,7 +262,15 @@ static int test_noreserved(struct unit_test_state *uts, const phys_addr_t ram)
static int lib_test_lmb_noreserved(struct unit_test_state *uts) { - return test_noreserved(uts, 0x40000000); + int ret; + + /* simulate 512 MiB RAM beginning at 1GiB */ + ret = test_noreserved(uts, 0x40000000); + if (ret) + return ret; + + /* simulate 512 MiB RAM beginning at 1.5GiB */ + return test_noreserved(uts, 0xE0000000); }
lmb_add_region handles overlapping regions wrong: instead of merging or rejecting to add a new reserved region that overlaps an existing one, it just adds the new region.
Since internally the same function is used for lmb_alloc, change lmb_add_region to reject overlapping regions.
Also, to keep reserved memory correct after 'free', reserved entries created by allocating memory must not set their size to a multiple of alignment but to the original size. This ensures the reserved region is completely removed when the caller calls 'lmb_free', as this one takes the same size as passed to 'lmb_alloc' etc.
Add test to assert this.
Changes in v8: None Changes in v7: - add braces around if/else with macros accross more than one line
Changes in v5: - added a test for this bug
lib/lmb.c | 11 +++--- test/lib/lmb.c | 95 +++++++++++++++++++++++++++++++++++++++++++++----- 2 files changed, 91 insertions(+), 15 deletions(-)
diff --git a/lib/lmb.c b/lib/lmb.c index 6d3dcf4e09..cd297f8202 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -131,6 +131,9 @@ static long lmb_add_region(struct lmb_region *rgn, phys_addr_t base, phys_size_t rgn->region[i].size += size; coalesced++; break; + } else if (lmb_addrs_overlap(base, size, rgnbase, rgnsize)) { + /* regions overlap */ + return -1; } }
@@ -269,11 +272,6 @@ static phys_addr_t lmb_align_down(phys_addr_t addr, phys_size_t size) return addr & ~(size - 1); }
-static phys_addr_t lmb_align_up(phys_addr_t addr, ulong size) -{ - return (addr + (size - 1)) & ~(size - 1); -} - phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phys_addr_t max_addr) { long i, j; @@ -302,8 +300,7 @@ phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phy if (j < 0) { /* This area isn't reserved, take it */ if (lmb_add_region(&lmb->reserved, base, - lmb_align_up(size, - align)) < 0) + size) < 0) return 0; return base; } diff --git a/test/lib/lmb.c b/test/lib/lmb.c index fb7ca45ef1..e6acb70e76 100644 --- a/test/lib/lmb.c +++ b/test/lib/lmb.c @@ -227,13 +227,16 @@ static int lib_test_lmb_big(struct unit_test_state *uts) DM_TEST(lib_test_lmb_big, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
/* Simulate 512 MiB RAM, allocate a block without previous reservation */ -static int test_noreserved(struct unit_test_state *uts, const phys_addr_t ram) +static int test_noreserved(struct unit_test_state *uts, const phys_addr_t ram, + const phys_addr_t alloc_size, const ulong align) { const phys_size_t ram_size = 0x20000000; const phys_addr_t ram_end = ram + ram_size; struct lmb lmb; long ret; phys_addr_t a, b; + const phys_addr_t alloc_size_aligned = (alloc_size + align - 1) & + ~(align - 1);
/* check for overflow */ ut_assert(ram_end == 0 || ram_end > ram); @@ -242,20 +245,43 @@ static int test_noreserved(struct unit_test_state *uts, const phys_addr_t ram)
ret = lmb_add(&lmb, ram, ram_size); ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 0, 0, 0, 0, 0, 0, 0);
/* allocate a block */ - a = lmb_alloc(&lmb, 4, 1); + a = lmb_alloc(&lmb, alloc_size, align); ut_assert(a != 0); - /* and free it */ - ret = lmb_free(&lmb, a, 4); + ASSERT_LMB(&lmb, ram, ram_size, 1, ram + ram_size - alloc_size_aligned, + alloc_size, 0, 0, 0, 0); + /* allocate another block */ + b = lmb_alloc(&lmb, alloc_size, align); + ut_assert(b != 0); + if (alloc_size == alloc_size_aligned) { + ASSERT_LMB(&lmb, ram, ram_size, 1, ram + ram_size - + (alloc_size_aligned * 2), alloc_size * 2, 0, 0, 0, + 0); + } else { + ASSERT_LMB(&lmb, ram, ram_size, 2, ram + ram_size - + (alloc_size_aligned * 2), alloc_size, ram + ram_size + - alloc_size_aligned, alloc_size, 0, 0); + } + /* and free them */ + ret = lmb_free(&lmb, b, alloc_size); ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 1, ram + ram_size - alloc_size_aligned, + alloc_size, 0, 0, 0, 0); + ret = lmb_free(&lmb, a, alloc_size); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 0, 0, 0, 0, 0, 0, 0);
/* allocate a block with base*/ - b = lmb_alloc_base(&lmb, 4, 1, ram_end); + b = lmb_alloc_base(&lmb, alloc_size, align, ram_end); ut_assert(a == b); + ASSERT_LMB(&lmb, ram, ram_size, 1, ram + ram_size - alloc_size_aligned, + alloc_size, 0, 0, 0, 0); /* and free it */ - ret = lmb_free(&lmb, b, 4); + ret = lmb_free(&lmb, b, alloc_size); ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 0, 0, 0, 0, 0, 0, 0);
return 0; } @@ -265,16 +291,30 @@ static int lib_test_lmb_noreserved(struct unit_test_state *uts) int ret;
/* simulate 512 MiB RAM beginning at 1GiB */ - ret = test_noreserved(uts, 0x40000000); + ret = test_noreserved(uts, 0x40000000, 4, 1); if (ret) return ret;
/* simulate 512 MiB RAM beginning at 1.5GiB */ - return test_noreserved(uts, 0xE0000000); + return test_noreserved(uts, 0xE0000000, 4, 1); }
+static int lib_test_lmb_unaligned_size(struct unit_test_state *uts) +{ + int ret; + + /* simulate 512 MiB RAM beginning at 1GiB */ + ret = test_noreserved(uts, 0x40000000, 5, 8); + if (ret) + return ret; + + /* simulate 512 MiB RAM beginning at 1.5GiB */ + return test_noreserved(uts, 0xE0000000, 5, 8); +} + +DM_TEST(lib_test_lmb_unaligned_size, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); /* * Simulate a RAM that starts at 0 and allocate down to address 0, which must * fail as '0' means failure for the lmb_alloc functions. @@ -318,3 +358,42 @@ static int lib_test_lmb_at_0(struct unit_test_state *uts) }
DM_TEST(lib_test_lmb_at_0, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Check that calling lmb_reserve with overlapping regions fails. */ +static int lib_test_lmb_overlapping_reserve(struct unit_test_state *uts) +{ + const phys_addr_t ram = 0x40000000; + const phys_size_t ram_size = 0x20000000; + struct lmb lmb; + long ret; + + lmb_init(&lmb); + + ret = lmb_add(&lmb, ram, ram_size); + ut_asserteq(ret, 0); + + ret = lmb_reserve(&lmb, 0x40010000, 0x10000); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 1, 0x40010000, 0x10000, + 0, 0, 0, 0); + /* allocate overlapping region should fail */ + ret = lmb_reserve(&lmb, 0x40011000, 0x10000); + ut_asserteq(ret, -1); + ASSERT_LMB(&lmb, ram, ram_size, 1, 0x40010000, 0x10000, + 0, 0, 0, 0); + /* allocate 3nd region */ + ret = lmb_reserve(&lmb, 0x40030000, 0x10000); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 2, 0x40010000, 0x10000, + 0x40030000, 0x10000, 0, 0); + /* allocate 2nd region */ + ret = lmb_reserve(&lmb, 0x40020000, 0x10000); + ut_assert(ret >= 0); + ASSERT_LMB(&lmb, ram, ram_size, 1, 0x40010000, 0x30000, + 0, 0, 0, 0); + + return 0; +} + +DM_TEST(lib_test_lmb_overlapping_reserve, + DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
boot_fdt_add_mem_rsv_regions() adds reserved memory sections to an lmb struct. Currently, it only parses regions described by /memreserve/ entries.
Extend this to the more commonly used scheme of the "reserved-memory" node.
Changes in v8: None Changes in v7: - fix compiling without CONFIG_FIT
Changes in v6: - fix compiling without OF_CONTROL
Changes in v5: None Changes in v4: - fixed invalid 'if' statement without braces in boot_fdt_reserve_region
Changes in v2: - this patch is new in v2
common/image-fdt.c | 53 +++++++++++++++++++++++++++++++++++++++------- lib/Makefile | 1 + 2 files changed, 46 insertions(+), 8 deletions(-)
diff --git a/common/image-fdt.c b/common/image-fdt.c index 95748f0ae1..5c0d6db3fe 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -10,6 +10,7 @@
#include <common.h> #include <fdt_support.h> +#include <fdtdec.h> #include <errno.h> #include <image.h> #include <linux/libfdt.h> @@ -67,30 +68,66 @@ static const image_header_t *image_get_fdt(ulong fdt_addr) } #endif
+static void boot_fdt_reserve_region(struct lmb *lmb, uint64_t addr, + uint64_t size) +{ + int ret; + + ret = lmb_reserve(lmb, addr, size); + if (!ret) { + debug(" reserving fdt memory region: addr=%llx size=%llx\n", + (unsigned long long)addr, (unsigned long long)size); + } else { + puts("ERROR: reserving fdt memory region failed "); + printf("(addr=%llx size=%llx)\n", + (unsigned long long)addr, (unsigned long long)size); + } +} + /** - * boot_fdt_add_mem_rsv_regions - Mark the memreserve sections as unusable + * boot_fdt_add_mem_rsv_regions - Mark the memreserve and reserved-memory + * sections as unusable * @lmb: pointer to lmb handle, will be used for memory mgmt * @fdt_blob: pointer to fdt blob base address * - * Adds the memreserve regions in the dtb to the lmb block. Adding the - * memreserve regions prevents u-boot from using them to store the initrd - * or the fdt blob. + * Adds the and reserved-memorymemreserve regions in the dtb to the lmb block. + * Adding the memreserve regions prevents u-boot from using them to store the + * initrd or the fdt blob. */ void boot_fdt_add_mem_rsv_regions(struct lmb *lmb, void *fdt_blob) { uint64_t addr, size; - int i, total; + int i, total, ret; + int nodeoffset, subnode; + struct fdt_resource res;
if (fdt_check_header(fdt_blob) != 0) return;
+ /* process memreserve sections */ total = fdt_num_mem_rsv(fdt_blob); for (i = 0; i < total; i++) { if (fdt_get_mem_rsv(fdt_blob, i, &addr, &size) != 0) continue; - printf(" reserving fdt memory region: addr=%llx size=%llx\n", - (unsigned long long)addr, (unsigned long long)size); - lmb_reserve(lmb, addr, size); + boot_fdt_reserve_region(lmb, addr, size); + } + + /* process reserved-memory */ + nodeoffset = fdt_subnode_offset(fdt_blob, 0, "reserved-memory"); + if (nodeoffset >= 0) { + subnode = fdt_first_subnode(fdt_blob, nodeoffset); + while (subnode >= 0) { + /* check if this subnode has a reg property */ + ret = fdt_get_resource(fdt_blob, subnode, "reg", 0, + &res); + if (!ret) { + addr = res.start; + size = res.end - res.start + 1; + boot_fdt_reserve_region(lmb, addr, size); + } + + subnode = fdt_next_subnode(fdt_blob, subnode); + } } }
diff --git a/lib/Makefile b/lib/Makefile index a6dd928a92..358789ff12 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -30,6 +30,7 @@ obj-y += crc7.o obj-y += crc8.o obj-y += crc16.o obj-$(CONFIG_ERRNO_STR) += errno_str.o +obj-$(CONFIG_OF_LIBFDT) += fdtdec.o obj-$(CONFIG_FIT) += fdtdec_common.o obj-$(CONFIG_TEST_FDTDEC) += fdtdec_test.o obj-$(CONFIG_GZIP_COMPRESSED) += gzip.o
This adds two new functions, lmb_alloc_addr and lmb_get_unreserved_size.
lmb_alloc_addr behaves like lmb_alloc, but it tries to allocate a pre-specified address range. Unlike lmb_reserve, this address range must be inside one of the memory ranges that has been set up with lmb_add.
lmb_get_unreserved_size returns the number of bytes that can be used up to the next reserved region or the end of valid ram. This can be 0 if the address passed is reserved.
Added test for these new functions.
Changes in v8: None Changes in v7: None Changes in v6: None Changes in v5: - fixed lmb_alloc_addr when resulting reserved ranges get combined - added test for these new functions
Changes in v4: None Changes in v2: - added lmb_get_unreserved_size() for tftp
include/lmb.h | 3 + lib/lmb.c | 53 +++++++++++++ test/lib/lmb.c | 202 +++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 258 insertions(+)
diff --git a/include/lmb.h b/include/lmb.h index f04d058093..7d7e2a78dc 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -38,6 +38,9 @@ extern phys_addr_t lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align phys_addr_t max_addr); extern phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phys_addr_t max_addr); +extern phys_addr_t lmb_alloc_addr(struct lmb *lmb, phys_addr_t base, + phys_size_t size); +extern phys_size_t lmb_get_unreserved_size(struct lmb *lmb, phys_addr_t addr); extern int lmb_is_reserved(struct lmb *lmb, phys_addr_t addr); extern long lmb_free(struct lmb *lmb, phys_addr_t base, phys_size_t size);
diff --git a/lib/lmb.c b/lib/lmb.c index cd297f8202..e380a0a722 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -313,6 +313,59 @@ phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phy return 0; }
+/* + * Try to allocate a specific address range: must be in defined memory but not + * reserved + */ +phys_addr_t lmb_alloc_addr(struct lmb *lmb, phys_addr_t base, phys_size_t size) +{ + long j; + + /* Check if the requested address is in one of the memory regions */ + j = lmb_overlaps_region(&lmb->memory, base, size); + if (j >= 0) { + /* + * Check if the requested end address is in the same memory + * region we found. + */ + if (lmb_addrs_overlap(lmb->memory.region[j].base, + lmb->memory.region[j].size, base + size - + 1, 1)) { + /* ok, reserve the memory */ + if (lmb_reserve(lmb, base, size) >= 0) + return base; + } + } + return 0; +} + +/* Return number of bytes from a given address that are free */ +phys_size_t lmb_get_unreserved_size(struct lmb *lmb, phys_addr_t addr) +{ + int i; + long j; + + /* check if the requested address is in the memory regions */ + j = lmb_overlaps_region(&lmb->memory, addr, 1); + if (j >= 0) { + for (i = 0; i < lmb->reserved.cnt; i++) { + if (addr < lmb->reserved.region[i].base) { + /* first reserved range > requested address */ + return lmb->reserved.region[i].base - addr; + } + if (lmb->reserved.region[i].base + + lmb->reserved.region[i].size > addr) { + /* requested addr is in this reserved range */ + return 0; + } + } + /* if we come here: no reserved ranges above requested addr */ + return lmb->memory.region[lmb->memory.cnt - 1].base + + lmb->memory.region[lmb->memory.cnt - 1].size - addr; + } + return 0; +} + int lmb_is_reserved(struct lmb *lmb, phys_addr_t addr) { int i; diff --git a/test/lib/lmb.c b/test/lib/lmb.c index e6acb70e76..058d3c332b 100644 --- a/test/lib/lmb.c +++ b/test/lib/lmb.c @@ -397,3 +397,205 @@ static int lib_test_lmb_overlapping_reserve(struct unit_test_state *uts)
DM_TEST(lib_test_lmb_overlapping_reserve, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* + * Simulate 512 MiB RAM, reserve 3 blocks, allocate addresses in between. + * Expect addresses outside the memory range to fail. + */ +static int test_alloc_addr(struct unit_test_state *uts, const phys_addr_t ram) +{ + const phys_size_t ram_size = 0x20000000; + const phys_addr_t ram_end = ram + ram_size; + const phys_size_t alloc_addr_a = ram + 0x8000000; + const phys_size_t alloc_addr_b = ram + 0x8000000 * 2; + const phys_size_t alloc_addr_c = ram + 0x8000000 * 3; + struct lmb lmb; + long ret; + phys_addr_t a, b, c, d, e; + + /* check for overflow */ + ut_assert(ram_end == 0 || ram_end > ram); + + lmb_init(&lmb); + + ret = lmb_add(&lmb, ram, ram_size); + ut_asserteq(ret, 0); + + /* reserve 3 blocks */ + ret = lmb_reserve(&lmb, alloc_addr_a, 0x10000); + ut_asserteq(ret, 0); + ret = lmb_reserve(&lmb, alloc_addr_b, 0x10000); + ut_asserteq(ret, 0); + ret = lmb_reserve(&lmb, alloc_addr_c, 0x10000); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 3, alloc_addr_a, 0x10000, + alloc_addr_b, 0x10000, alloc_addr_c, 0x10000); + + /* allocate blocks */ + a = lmb_alloc_addr(&lmb, ram, alloc_addr_a - ram); + ut_asserteq(a, ram); + ASSERT_LMB(&lmb, ram, ram_size, 3, ram, 0x8010000, + alloc_addr_b, 0x10000, alloc_addr_c, 0x10000); + b = lmb_alloc_addr(&lmb, alloc_addr_a + 0x10000, + alloc_addr_b - alloc_addr_a - 0x10000); + ut_asserteq(b, alloc_addr_a + 0x10000); + ASSERT_LMB(&lmb, ram, ram_size, 2, ram, 0x10010000, + alloc_addr_c, 0x10000, 0, 0); + c = lmb_alloc_addr(&lmb, alloc_addr_b + 0x10000, + alloc_addr_c - alloc_addr_b - 0x10000); + ut_asserteq(c, alloc_addr_b + 0x10000); + ASSERT_LMB(&lmb, ram, ram_size, 1, ram, 0x18010000, + 0, 0, 0, 0); + d = lmb_alloc_addr(&lmb, alloc_addr_c + 0x10000, + ram_end - alloc_addr_c - 0x10000); + ut_asserteq(d, alloc_addr_c + 0x10000); + ASSERT_LMB(&lmb, ram, ram_size, 1, ram, ram_size, + 0, 0, 0, 0); + + /* allocating anything else should fail */ + e = lmb_alloc(&lmb, 1, 1); + ut_asserteq(e, 0); + ASSERT_LMB(&lmb, ram, ram_size, 1, ram, ram_size, + 0, 0, 0, 0); + + ret = lmb_free(&lmb, d, ram_end - alloc_addr_c - 0x10000); + ut_asserteq(ret, 0); + + /* allocate at 3 points in free range */ + + d = lmb_alloc_addr(&lmb, ram_end - 4, 4); + ut_asserteq(d, ram_end - 4); + ASSERT_LMB(&lmb, ram, ram_size, 2, ram, 0x18010000, + d, 4, 0, 0); + ret = lmb_free(&lmb, d, 4); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 1, ram, 0x18010000, + 0, 0, 0, 0); + + d = lmb_alloc_addr(&lmb, ram_end - 128, 4); + ut_asserteq(d, ram_end - 128); + ASSERT_LMB(&lmb, ram, ram_size, 2, ram, 0x18010000, + d, 4, 0, 0); + ret = lmb_free(&lmb, d, 4); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 1, ram, 0x18010000, + 0, 0, 0, 0); + + d = lmb_alloc_addr(&lmb, alloc_addr_c + 0x10000, 4); + ut_asserteq(d, alloc_addr_c + 0x10000); + ASSERT_LMB(&lmb, ram, ram_size, 1, ram, 0x18010004, + 0, 0, 0, 0); + ret = lmb_free(&lmb, d, 4); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 1, ram, 0x18010000, + 0, 0, 0, 0); + + /* allocate at the bottom */ + ret = lmb_free(&lmb, a, alloc_addr_a - ram); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 1, ram + 0x8000000, 0x10010000, + 0, 0, 0, 0); + d = lmb_alloc_addr(&lmb, ram, 4); + ut_asserteq(d, ram); + ASSERT_LMB(&lmb, ram, ram_size, 2, d, 4, + ram + 0x8000000, 0x10010000, 0, 0); + + /* check that allocating outside memory fails */ + if (ram_end != 0) { + ret = lmb_alloc_addr(&lmb, ram_end, 1); + ut_asserteq(ret, 0); + } + if (ram != 0) { + ret = lmb_alloc_addr(&lmb, ram - 1, 1); + ut_asserteq(ret, 0); + } + + return 0; +} + +static int lib_test_lmb_alloc_addr(struct unit_test_state *uts) +{ + int ret; + + /* simulate 512 MiB RAM beginning at 1GiB */ + ret = test_alloc_addr(uts, 0x40000000); + if (ret) + return ret; + + /* simulate 512 MiB RAM beginning at 1.5GiB */ + return test_alloc_addr(uts, 0xE0000000); +} + +DM_TEST(lib_test_lmb_alloc_addr, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Simulate 512 MiB RAM, reserve 3 blocks, check addresses in between */ +static int test_get_unreserved_size(struct unit_test_state *uts, + const phys_addr_t ram) +{ + const phys_size_t ram_size = 0x20000000; + const phys_addr_t ram_end = ram + ram_size; + const phys_size_t alloc_addr_a = ram + 0x8000000; + const phys_size_t alloc_addr_b = ram + 0x8000000 * 2; + const phys_size_t alloc_addr_c = ram + 0x8000000 * 3; + struct lmb lmb; + long ret; + phys_size_t s; + + /* check for overflow */ + ut_assert(ram_end == 0 || ram_end > ram); + + lmb_init(&lmb); + + ret = lmb_add(&lmb, ram, ram_size); + ut_asserteq(ret, 0); + + /* reserve 3 blocks */ + ret = lmb_reserve(&lmb, alloc_addr_a, 0x10000); + ut_asserteq(ret, 0); + ret = lmb_reserve(&lmb, alloc_addr_b, 0x10000); + ut_asserteq(ret, 0); + ret = lmb_reserve(&lmb, alloc_addr_c, 0x10000); + ut_asserteq(ret, 0); + ASSERT_LMB(&lmb, ram, ram_size, 3, alloc_addr_a, 0x10000, + alloc_addr_b, 0x10000, alloc_addr_c, 0x10000); + + /* check addresses in between blocks */ + s = lmb_get_unreserved_size(&lmb, ram); + ut_asserteq(s, alloc_addr_a - ram); + s = lmb_get_unreserved_size(&lmb, ram + 0x10000); + ut_asserteq(s, alloc_addr_a - ram - 0x10000); + s = lmb_get_unreserved_size(&lmb, alloc_addr_a - 4); + ut_asserteq(s, 4); + + s = lmb_get_unreserved_size(&lmb, alloc_addr_a + 0x10000); + ut_asserteq(s, alloc_addr_b - alloc_addr_a - 0x10000); + s = lmb_get_unreserved_size(&lmb, alloc_addr_a + 0x20000); + ut_asserteq(s, alloc_addr_b - alloc_addr_a - 0x20000); + s = lmb_get_unreserved_size(&lmb, alloc_addr_b - 4); + ut_asserteq(s, 4); + + s = lmb_get_unreserved_size(&lmb, alloc_addr_c + 0x10000); + ut_asserteq(s, ram_end - alloc_addr_c - 0x10000); + s = lmb_get_unreserved_size(&lmb, alloc_addr_c + 0x20000); + ut_asserteq(s, ram_end - alloc_addr_c - 0x20000); + s = lmb_get_unreserved_size(&lmb, ram_end - 4); + ut_asserteq(s, 4); + + return 0; +} + +static int lib_test_lmb_get_unreserved_size(struct unit_test_state *uts) +{ + int ret; + + /* simulate 512 MiB RAM beginning at 1GiB */ + ret = test_get_unreserved_size(uts, 0x40000000); + if (ret) + return ret; + + /* simulate 512 MiB RAM beginning at 1.5GiB */ + return test_get_unreserved_size(uts, 0xE0000000); +} + +DM_TEST(lib_test_lmb_get_unreserved_size, + DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
This fixes CVE-2018-18440 ("insufficient boundary checks in filesystem image load") by using lmb to check the load size of a file against reserved memory addresses.
Changes in v8: None Changes in v7: None Changes in v6: - fixed NULL pointer access in 'fdt_blob' passed to 'boot_fdt_add_mem_rsv_regions'
Changes in v5: None Changes in v4: None Changes in v2: None
fs/fs.c | 56 ++++++++++++++++++++++++++++++++++++++++++++++++--- include/lmb.h | 2 ++ lib/lmb.c | 13 ++++++++++++ 3 files changed, 68 insertions(+), 3 deletions(-)
diff --git a/fs/fs.c b/fs/fs.c index cb265174e2..400aa921a7 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -429,13 +429,57 @@ int fs_size(const char *filename, loff_t *size) return ret; }
-int fs_read(const char *filename, ulong addr, loff_t offset, loff_t len, - loff_t *actread) +#ifdef CONFIG_LMB +/* Check if a file may be read to the given address */ +static int fs_read_lmb_check(const char *filename, ulong addr, loff_t offset, + loff_t len, struct fstype_info *info) +{ + struct lmb lmb; + int ret; + loff_t size; + loff_t read_len; + + /* get the actual size of the file */ + ret = info->size(filename, &size); + if (ret) + return ret; + if (offset >= size) { + /* offset >= EOF, no bytes will be written */ + return 0; + } + read_len = size - offset; + + /* limit to 'len' if it is smaller */ + if (len && len < read_len) + read_len = len; + + lmb_init_and_reserve(&lmb, gd->bd->bi_dram[0].start, + gd->bd->bi_dram[0].size, (void *)gd->fdt_blob); + lmb_dump_all(&lmb); + + if (lmb_alloc_addr(&lmb, addr, read_len) == addr) + return 0; + + printf("** Reading file would overwrite reserved memory **\n"); + return -1; +} +#endif + +static int _fs_read(const char *filename, ulong addr, loff_t offset, loff_t len, + int do_lmb_check, loff_t *actread) { struct fstype_info *info = fs_get_info(fs_type); void *buf; int ret;
+#ifdef CONFIG_LMB + if (do_lmb_check) { + ret = fs_read_lmb_check(filename, addr, offset, len, info); + if (ret) + return ret; + } +#endif + /* * We don't actually know how many bytes are being read, since len==0 * means read the whole file. @@ -452,6 +496,12 @@ int fs_read(const char *filename, ulong addr, loff_t offset, loff_t len, return ret; }
+int fs_read(const char *filename, ulong addr, loff_t offset, loff_t len, + loff_t *actread) +{ + return _fs_read(filename, addr, offset, len, 0, actread); +} + int fs_write(const char *filename, ulong addr, loff_t offset, loff_t len, loff_t *actwrite) { @@ -622,7 +672,7 @@ int do_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], pos = 0;
time = get_timer(0); - ret = fs_read(filename, addr, pos, bytes, &len_read); + ret = _fs_read(filename, addr, pos, bytes, 1, &len_read); time = get_timer(time); if (ret < 0) return 1; diff --git a/include/lmb.h b/include/lmb.h index 7d7e2a78dc..62da85e716 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -31,6 +31,8 @@ struct lmb { extern struct lmb lmb;
extern void lmb_init(struct lmb *lmb); +extern void lmb_init_and_reserve(struct lmb *lmb, phys_addr_t base, + phys_size_t size, void *fdt_blob); extern long lmb_add(struct lmb *lmb, phys_addr_t base, phys_size_t size); extern long lmb_reserve(struct lmb *lmb, phys_addr_t base, phys_size_t size); extern phys_addr_t lmb_alloc(struct lmb *lmb, phys_size_t size, ulong align); diff --git a/lib/lmb.c b/lib/lmb.c index e380a0a722..3407705fa7 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -98,6 +98,19 @@ void lmb_init(struct lmb *lmb) lmb->reserved.size = 0; }
+/* Initialize the struct, add memory and call arch/board reserve functions */ +void lmb_init_and_reserve(struct lmb *lmb, phys_addr_t base, phys_size_t size, + void *fdt_blob) +{ + lmb_init(lmb); + lmb_add(lmb, base, size); + arch_lmb_reserve(lmb); + board_lmb_reserve(lmb); + + if (IMAGE_ENABLE_OF_LIBFDT && fdt_blob) + boot_fdt_add_mem_rsv_regions(lmb, fdt_blob); +} + /* This routine called with relocation disabled. */ static long lmb_add_region(struct lmb_region *rgn, phys_addr_t base, phys_size_t size) {
This reduces duplicate code only.
Changes in v8: None Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v2: None
common/bootm.c | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/common/bootm.c b/common/bootm.c index 8bf84ebcb7..31e4f0f794 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -56,15 +56,11 @@ static void boot_start_lmb(bootm_headers_t *images) ulong mem_start; phys_size_t mem_size;
- lmb_init(&images->lmb); - mem_start = env_get_bootm_low(); mem_size = env_get_bootm_size();
- lmb_add(&images->lmb, (phys_addr_t)mem_start, mem_size); - - arch_lmb_reserve(&images->lmb); - board_lmb_reserve(&images->lmb); + lmb_init_and_reserve(&images->lmb, (phys_addr_t)mem_start, mem_size, + NULL); } #else #define lmb_reserve(lmb, base, size)
lmb.h includes an extern declaration of "struct lmb lmb;" which is not used anywhere, so remove it.
Changes in v8: None Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v2: - this patch is new in v2
include/lmb.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/include/lmb.h b/include/lmb.h index 62da85e716..1bb003e35e 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -28,8 +28,6 @@ struct lmb { struct lmb_region reserved; };
-extern struct lmb lmb; - extern void lmb_init(struct lmb *lmb); extern void lmb_init_and_reserve(struct lmb *lmb, phys_addr_t base, phys_size_t size, void *fdt_blob);
This fixes CVE-2018-18439 ("insufficient boundary checks in network image boot") by using lmb to check for a valid range to store received blocks.
Changes in v8: None Changes in v7: - fix compiling without CONFIG_LMB
Changes in v6: None Changes in v5: None Changes in v4: - this was patch 8, is now patch 7 - lines changed because v3 patch 7 got removed and MCAST_TFTP still exists
net/tftp.c | 73 ++++++++++++++++++++++++++++++++++++++++++++++-------- 1 file changed, 63 insertions(+), 10 deletions(-)
diff --git a/net/tftp.c b/net/tftp.c index 68ffd81414..a9335b1b7e 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -17,6 +17,8 @@ #include <flash.h> #endif
+DECLARE_GLOBAL_DATA_PTR; + /* Well known TFTP port # */ #define WELL_KNOWN_PORT 69 /* Millisecs to timeout for lost pkt */ @@ -81,6 +83,10 @@ static ulong tftp_block_wrap; /* memory offset due to wrapping */ static ulong tftp_block_wrap_offset; static int tftp_state; +static ulong tftp_load_addr; +#ifdef CONFIG_LMB +static ulong tftp_load_size; +#endif #ifdef CONFIG_TFTP_TSIZE /* The file size reported by the server */ static int tftp_tsize; @@ -164,10 +170,11 @@ static void mcast_cleanup(void)
#endif /* CONFIG_MCAST_TFTP */
-static inline void store_block(int block, uchar *src, unsigned len) +static inline int store_block(int block, uchar *src, unsigned int len) { ulong offset = block * tftp_block_size + tftp_block_wrap_offset; ulong newsize = offset + len; + ulong store_addr = tftp_load_addr + offset; #ifdef CONFIG_SYS_DIRECT_FLASH_TFTP int i, rc = 0;
@@ -175,24 +182,32 @@ static inline void store_block(int block, uchar *src, unsigned len) /* start address in flash? */ if (flash_info[i].flash_id == FLASH_UNKNOWN) continue; - if (load_addr + offset >= flash_info[i].start[0]) { + if (store_addr >= flash_info[i].start[0]) { rc = 1; break; } }
if (rc) { /* Flash is destination for this packet */ - rc = flash_write((char *)src, (ulong)(load_addr+offset), len); + rc = flash_write((char *)src, store_addr, len); if (rc) { flash_perror(rc); - net_set_state(NETLOOP_FAIL); - return; + return rc; } } else #endif /* CONFIG_SYS_DIRECT_FLASH_TFTP */ { - void *ptr = map_sysmem(load_addr + offset, len); - + void *ptr; + +#ifdef CONFIG_LMB + if (store_addr < tftp_load_addr || + store_addr + len > tftp_load_addr + tftp_load_size) { + puts("\nTFTP error: "); + puts("trying to overwrite reserved memory...\n"); + return -1; + } +#endif + ptr = map_sysmem(store_addr, len); memcpy(ptr, src, len); unmap_sysmem(ptr); } @@ -203,6 +218,8 @@ static inline void store_block(int block, uchar *src, unsigned len)
if (net_boot_file_size < newsize) net_boot_file_size = newsize; + + return 0; }
/* Clear our state ready for a new transfer */ @@ -606,7 +623,11 @@ static void tftp_handler(uchar *pkt, unsigned dest, struct in_addr sip, timeout_count_max = tftp_timeout_count_max; net_set_timeout_handler(timeout_ms, tftp_timeout_handler);
- store_block(tftp_cur_block - 1, pkt + 2, len); + if (store_block(tftp_cur_block - 1, pkt + 2, len)) { + eth_halt(); + net_set_state(NETLOOP_FAIL); + break; + }
/* * Acknowledge the block just received, which will prompt @@ -695,6 +716,25 @@ static void tftp_timeout_handler(void) } }
+/* Initialize tftp_load_addr and tftp_load_size from load_addr and lmb */ +static int tftp_init_load_addr(void) +{ +#ifdef CONFIG_LMB + struct lmb lmb; + phys_size_t max_size; + + lmb_init_and_reserve(&lmb, gd->bd->bi_dram[0].start, + gd->bd->bi_dram[0].size, (void *)gd->fdt_blob); + + max_size = lmb_get_unreserved_size(&lmb, load_addr); + if (!max_size) + return -1; + + tftp_load_size = max_size; +#endif + tftp_load_addr = load_addr; + return 0; +}
void tftp_start(enum proto_t protocol) { @@ -791,7 +831,14 @@ void tftp_start(enum proto_t protocol) } else #endif { - printf("Load address: 0x%lx\n", load_addr); + if (tftp_init_load_addr()) { + eth_halt(); + net_set_state(NETLOOP_FAIL); + puts("\nTFTP error: "); + puts("trying to overwrite reserved memory...\n"); + return; + } + printf("Load address: 0x%lx\n", tftp_load_addr); puts("Loading: *\b"); tftp_state = STATE_SEND_RRQ; #ifdef CONFIG_CMD_BOOTEFI @@ -842,9 +889,15 @@ void tftp_start_server(void) { tftp_filename[0] = 0;
+ if (tftp_init_load_addr()) { + eth_halt(); + net_set_state(NETLOOP_FAIL); + puts("\nTFTP error: trying to overwrite reserved memory...\n"); + return; + } printf("Using %s device\n", eth_get_name()); printf("Listening for TFTP transfer on %pI4\n", &net_ip); - printf("Load address: 0x%lx\n", load_addr); + printf("Load address: 0x%lx\n", tftp_load_addr);
This fixes 'arch_lmb_reserve()' for ARM that tries to detect in which DRAM bank 'sp' is in.
This code failed if a bank was at the end of physical address range (i.e. size + length overflowed to 0).
To fix this, calculate 'bank_end' as 'size + length - 1' so that such banks end at 0xffffffff, not 0.
Fixes: 15751403b6 ("ARM: bootm: don't assume sp is in DRAM bank 0") Reported-by: Frank Wunderlich frank-w@public-files.de Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com ---
Changes in v8: - this patch is new in v8
arch/arm/lib/bootm.c | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index c3c1d2fdfa..e9a333af0e 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -64,13 +64,14 @@ void arch_lmb_reserve(struct lmb *lmb) /* adjust sp by 4K to be safe */ sp -= 4096; for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { - if (sp < gd->bd->bi_dram[bank].start) + if (!bi_dram[bank].size || sp < gd->bd->bi_dram[bank].start) continue; + /* Watch out for RAM at end of address space! */ bank_end = gd->bd->bi_dram[bank].start + - gd->bd->bi_dram[bank].size; - if (sp >= bank_end) + gd->bd->bi_dram[bank].size - 1; + if (sp > bank_end) continue; - lmb_reserve(lmb, sp, bank_end - sp); + lmb_reserve(lmb, sp, bank_end - sp + 1); break; } }
This patch, Reviewed-by: Stephen Warren swarren@nvidia.com
seems that Patch0 does not receive Mailinglist and my answer to it got blocked...
i get:
arch/arm/lib/bootm.c: In function ‘arch_lmb_reserve’: arch/arm/lib/bootm.c:67:8: error: ‘bi_dram’ undeclared (first use in this function); did you mean ‘blk_dread’? if (!bi_dram[bank].size || sp < gd->bd->bi_dram[bank].start) ^~~~~~~ blk_dread
which i fixed this way:
diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index e9a333af0e..48bb41249e 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -64,7 +64,7 @@ void arch_lmb_reserve(struct lmb *lmb) /* adjust sp by 4K to be safe */ sp -= 4096; for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { - if (!bi_dram[bank].size || sp < gd->bd->bi_dram[bank].start) + if (!gd->bd->bi_dram[bank].size || sp < gd->bd->bi_dram[bank].start) continue; /* Watch out for RAM at end of address space! */ bank_end = gd->bd->bi_dram[bank].start +
after that at least sp_start is protected
U-Boot> bd arch_number = 0x00000000 boot_params = 0x80000100 DRAM bank = 0x00000000 -> start = 0x80000000 -> size = 0x80000000 current eth = unknown ip_addr = <NULL> baudrate = 115200 bps TLB addr = 0xFFFF0000 relocaddr = 0xFFF9C000 reloc off = 0x7E19C000 irq_sp = 0xFFB9AED0 sp start = 0xFFB9AEC0 Early malloc usage: 318 / 4000 fdt_blob = fffd0be0
U-Boot> setenv scriptaddr 0xFFB9AEC0 U-Boot> fatload ${device} ${partition} ${scriptaddr} ${bpi}/${board}/${service}/${bootenv}; ** Reading file would overwrite reserved memory **
same with relocaddr -x
U-Boot> setenv scriptaddr 0xFFF9BF00 U-Boot> fatload ${device} ${partition} ${scriptaddr} ${bpi}/${board}/${service}/ ${bootenv}; ** Reading file would overwrite reserved memory **
regards Frank
Gesendet: Montag, 17. Dezember 2018 um 21:08 Uhr Von: "Simon Goldschmidt" simon.k.r.goldschmidt@gmail.com An: "Tom Rini" trini@konsulko.com, u-boot@lists.denx.de, "Joe Hershberger" joe.hershberger@ni.com Cc: "Heinrich Schuchardt" xypron.glpk@gmx.de, "Fabio Estevam" festevam@gmail.com, "Andrea Barisani" andrea.barisani@f-secure.com, "Frank Wunderlich" frank-w@public-files.de, "Simon Goldschmidt" simon.k.r.goldschmidt@gmail.com, "Simon Glass" sjg@chromium.org, "Masahiro Yamada" yamada.masahiro@socionext.com, "Tom Warren" twarren@nvidia.com, "Bin Meng" bmeng.cn@gmail.com, "Vasyl Vavrychuk" vvavrychuk@gmail.com, "Albert Aribaud" albert.u.boot@aribaud.net, "Hannes Schmelzer" hannes.schmelzer@br-automation.com, "Stephen Warren" swarren@nvidia.com Betreff: [PATCH v8 10/10] arm: bootm: fix sp detection at end of address range
Changes in v8:
bank_end = gd->bd->bi_dram[bank].start +/* Watch out for RAM at end of address space! */
if (sp >= bank_end)
break; }lmb_reserve(lmb, sp, bank_end - sp + 1);
2.17.1
Am 18.12.2018 um 16:55 schrieb Frank Wunderlich:
i get:
D'Oh! Don't know how that could have slipped through. Seems I was a little hasty in adding this last patch :-(
Your fix is of course correct. I'll submit v9 :-/
So, yay, it finally works for you!
Thanks for testing!
regards Frank
Changes in v8:
if (sp >= bank_end)
break; } }lmb_reserve(lmb, sp, bank_end - sp + 1);
-- 2.17.1
Frank Wunderlich
Simon Goldschmidt
Stephen Warren
