[U-Boot] [PATCH 1/1] efi_loader: parameter checks for LoadImage
Add parameter checks in efi_load_image(). Check memory allocation is successful in efi_load_image().
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_boottime.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 6c7a2ebf95..1ff0568d47 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1573,8 +1573,27 @@ static efi_status_t EFIAPI efi_load_image(bool boot_policy, EFI_ENTRY("%d, %p, %pD, %p, %ld, %p", boot_policy, parent_image, file_path, source_buffer, source_size, image_handle);
+ if (!image_handle || !parent_image) { + ret = EFI_INVALID_PARAMETER; + goto error; + } + + if (!source_buffer && !file_path) { + ret = EFI_NOT_FOUND; + goto error; + } + info = calloc(1, sizeof(*info)); + if (!info) { + ret = EFI_OUT_OF_RESOURCES; + goto error; + } obj = calloc(1, sizeof(*obj)); + if (!obj) { + free(info); + ret = EFI_OUT_OF_RESOURCES; + goto error; + }
if (!source_buffer) { struct efi_device_path *dp, *fp; @@ -1610,6 +1629,7 @@ static efi_status_t EFIAPI efi_load_image(bool boot_policy, failure: free(info); efi_delete_handle(obj); +error: return EFI_EXIT(ret); }
