[U-Boot] [PATCH] video: Add support for NXP's TDA19988 HDMI encoder
Add support for the NXP TDA19988 HDMI encoder as used on the Juno development board from Arm.
Signed-off-by: Liviu Dudau liviu.dudau@foss.arm.com --- drivers/video/Kconfig | 7 + drivers/video/Makefile | 1 + drivers/video/tda19988.c | 637 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 645 insertions(+) create mode 100644 drivers/video/tda19988.c
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index ed0b21f2a7..9f21ef30a9 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -431,6 +431,13 @@ config DISPLAY The devices provide a simple interface to start up the display, read display information and enable it.
+config NXP_TDA19988 + bool "Enable NXP TDA19988 support" + depends on DISPLAY + default n + help + This enables support for the NXP TDA19988 HDMI encoder. + config ATMEL_HLCD bool "Enable ATMEL video support using HLCDC" depends on DM_VIDEO diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 0f41a23193..4c130e179d 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -31,6 +31,7 @@ obj-$(CONFIG_FSL_DIU_FB) += fsl_diu_fb.o videomodes.o obj-$(CONFIG_LD9040) += ld9040.o obj-$(CONFIG_LG4573) += lg4573.o obj-$(CONFIG_LOGICORE_DP_TX) += logicore_dp_tx.o +obj-$(CONFIG_NXP_TDA19988) += tda19988.o obj-$(CONFIG_PXA_LCD) += pxa_lcd.o obj-$(CONFIG_S6E8AX0) += s6e8ax0.o obj-$(CONFIG_SCF0403_LCD) += scf0403_lcd.o diff --git a/drivers/video/tda19988.c b/drivers/video/tda19988.c new file mode 100644 index 0000000000..b6a895ac37 --- /dev/null +++ b/drivers/video/tda19988.c @@ -0,1 +1,637 @@ +/* + * (C) Copyright 2018 Liviu Dudau liviu@dudau.co.uk + * + * Based on the Linux driver, (C) 2012 Texas Instruments + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <display.h> +#include <i2c.h> + +/* + * TDA19988 uses paged registers. We encode the page# in the upper + * bits of the register#. It also means that reads/writes to a register + * have to ensure that the register's page is selected as the current + * page. + */ +#define REG(page, addr) (((page) << 8) | (addr)) +#define REG2ADDR(reg) ((reg) & 0xff) +#define REG2PAGE(reg) (((reg) >> 8) & 0xff) + +/* register for setting current page */ +#define REG_CURRENT_PAGE 0xff + +/* Page 00h: General Control */ +#define REG_VERSION_LSB REG(0x00, 0x00) /* read */ +#define REG_MAIN_CNTRL0 REG(0x00, 0x01) /* read/write */ +#define MAIN_CNTRL0_SR BIT(0) +#define MAIN_CNTRL0_DECS BIT(1) +#define MAIN_CNTRL0_DEHS BIT(2) +#define MAIN_CNTRL0_CECS BIT(3) +#define MAIN_CNTRL0_CEHS BIT(4) +#define MAIN_CNTRL0_SCALER BIT(7) +#define REG_VERSION_MSB REG(0x00, 0x02) /* read */ +#define REG_SOFTRESET REG(0x00, 0x0a) /* write */ +#define SOFTRESET_AUDIO BIT(0) +#define SOFTRESET_I2C_MASTER BIT(1) +#define REG_DDC_DISABLE REG(0x00, 0x0b) /* read/write */ +#define REG_I2C_MASTER REG(0x00, 0x0d) /* read/write */ +#define I2C_MASTER_DIS_MM BIT(0) +#define I2C_MASTER_DIS_FILT BIT(1) +#define I2C_MASTER_APP_STRT_LAT BIT(2) +#define REG_FEAT_POWERDOWN REG(0x00, 0x0e) /* read/write */ +#define FEAT_POWERDOWN_PREFILT BIT(0) +#define FEAT_POWERDOWN_CSC BIT(1) +#define FEAT_POWERDOWN_SPDIF BIT(3) +#define REG_INT_FLAGS_0 REG(0x00, 0x0f) /* read/write */ +#define REG_INT_FLAGS_1 REG(0x00, 0x10) /* read/write */ +#define REG_INT_FLAGS_2 REG(0x00, 0x11) /* read/write */ +#define INT_FLAGS_2_EDID_BLK_RD BIT(1) +#define REG_ENA_VP_0 REG(0x00, 0x18) /* read/write */ +#define REG_ENA_VP_1 REG(0x00, 0x19) /* read/write */ +#define REG_ENA_VP_2 REG(0x00, 0x1a) /* read/write */ +#define REG_ENA_AP REG(0x00, 0x1e) /* read/write */ +#define REG_VIP_CNTRL_0 REG(0x00, 0x20) /* write */ +#define VIP_CNTRL_0_MIRR_A BIT(7) +#define VIP_CNTRL_0_SWAP_A(x) (((x) & 7) << 4) +#define VIP_CNTRL_0_MIRR_B BIT(3) +#define VIP_CNTRL_0_SWAP_B(x) (((x) & 7) << 0) +#define REG_VIP_CNTRL_1 REG(0x00, 0x21) /* write */ +#define VIP_CNTRL_1_MIRR_C BIT(7) +#define VIP_CNTRL_1_SWAP_C(x) (((x) & 7) << 4) +#define VIP_CNTRL_1_MIRR_D BIT(3) +#define VIP_CNTRL_1_SWAP_D(x) (((x) & 7) << 0) +#define REG_VIP_CNTRL_2 REG(0x00, 0x22) /* write */ +#define VIP_CNTRL_2_MIRR_E BIT(7) +#define VIP_CNTRL_2_SWAP_E(x) (((x) & 7) << 4) +#define VIP_CNTRL_2_MIRR_F BIT(3) +#define VIP_CNTRL_2_SWAP_F(x) (((x) & 7) << 0) +#define REG_VIP_CNTRL_3 REG(0x00, 0x23) /* write */ +#define VIP_CNTRL_3_X_TGL BIT(0) +#define VIP_CNTRL_3_H_TGL BIT(1) +#define VIP_CNTRL_3_V_TGL BIT(2) +#define VIP_CNTRL_3_EMB BIT(3) +#define VIP_CNTRL_3_SYNC_DE BIT(4) +#define VIP_CNTRL_3_SYNC_HS BIT(5) +#define VIP_CNTRL_3_DE_INT BIT(6) +#define VIP_CNTRL_3_EDGE BIT(7) +#define REG_VIP_CNTRL_4 REG(0x00, 0x24) /* write */ +#define VIP_CNTRL_4_BLC(x) (((x) & 3) << 0) +#define VIP_CNTRL_4_BLANKIT(x) (((x) & 3) << 2) +#define VIP_CNTRL_4_CCIR656 BIT(4) +#define VIP_CNTRL_4_656_ALT BIT(5) +#define VIP_CNTRL_4_TST_656 BIT(6) +#define VIP_CNTRL_4_TST_PAT BIT(7) +#define REG_VIP_CNTRL_5 REG(0x00, 0x25) /* write */ +#define VIP_CNTRL_5_CKCASE BIT(0) +#define VIP_CNTRL_5_SP_CNT(x) (((x) & 3) << 1) +#define REG_MUX_VP_VIP_OUT REG(0x00, 0x27) /* read/write */ +#define REG_MAT_CONTRL REG(0x00, 0x80) /* write */ +#define MAT_CONTRL_MAT_SC(x) (((x) & 3) << 0) +#define MAT_CONTRL_MAT_BP BIT(2) +#define REG_VIDFORMAT REG(0x00, 0xa0) /* write */ +#define REG_REFPIX_MSB REG(0x00, 0xa1) /* write */ +#define REG_REFPIX_LSB REG(0x00, 0xa2) /* write */ +#define REG_REFLINE_MSB REG(0x00, 0xa3) /* write */ +#define REG_REFLINE_LSB REG(0x00, 0xa4) /* write */ +#define REG_NPIX_MSB REG(0x00, 0xa5) /* write */ +#define REG_NPIX_LSB REG(0x00, 0xa6) /* write */ +#define REG_NLINE_MSB REG(0x00, 0xa7) /* write */ +#define REG_NLINE_LSB REG(0x00, 0xa8) /* write */ +#define REG_VS_LINE_STRT_1_MSB REG(0x00, 0xa9) /* write */ +#define REG_VS_LINE_STRT_1_LSB REG(0x00, 0xaa) /* write */ +#define REG_VS_PIX_STRT_1_MSB REG(0x00, 0xab) /* write */ +#define REG_VS_PIX_STRT_1_LSB REG(0x00, 0xac) /* write */ +#define REG_VS_LINE_END_1_MSB REG(0x00, 0xad) /* write */ +#define REG_VS_LINE_END_1_LSB REG(0x00, 0xae) /* write */ +#define REG_VS_PIX_END_1_MSB REG(0x00, 0xaf) /* write */ +#define REG_VS_PIX_END_1_LSB REG(0x00, 0xb0) /* write */ +#define REG_VS_LINE_STRT_2_MSB REG(0x00, 0xb1) /* write */ +#define REG_VS_LINE_STRT_2_LSB REG(0x00, 0xb2) /* write */ +#define REG_VS_PIX_STRT_2_MSB REG(0x00, 0xb3) /* write */ +#define REG_VS_PIX_STRT_2_LSB REG(0x00, 0xb4) /* write */ +#define REG_VS_LINE_END_2_MSB REG(0x00, 0xb5) /* write */ +#define REG_VS_LINE_END_2_LSB REG(0x00, 0xb6) /* write */ +#define REG_VS_PIX_END_2_MSB REG(0x00, 0xb7) /* write */ +#define REG_VS_PIX_END_2_LSB REG(0x00, 0xb8) /* write */ +#define REG_HS_PIX_START_MSB REG(0x00, 0xb9) /* write */ +#define REG_HS_PIX_START_LSB REG(0x00, 0xba) /* write */ +#define REG_HS_PIX_STOP_MSB REG(0x00, 0xbb) /* write */ +#define REG_HS_PIX_STOP_LSB REG(0x00, 0xbc) /* write */ +#define REG_VWIN_START_1_MSB REG(0x00, 0xbd) /* write */ +#define REG_VWIN_START_1_LSB REG(0x00, 0xbe) /* write */ +#define REG_VWIN_END_1_MSB REG(0x00, 0xbf) /* write */ +#define REG_VWIN_END_1_LSB REG(0x00, 0xc0) /* write */ +#define REG_VWIN_START_2_MSB REG(0x00, 0xc1) /* write */ +#define REG_VWIN_START_2_LSB REG(0x00, 0xc2) /* write */ +#define REG_VWIN_END_2_MSB REG(0x00, 0xc3) /* write */ +#define REG_VWIN_END_2_LSB REG(0x00, 0xc4) /* write */ +#define REG_DE_START_MSB REG(0x00, 0xc5) /* write */ +#define REG_DE_START_LSB REG(0x00, 0xc6) /* write */ +#define REG_DE_STOP_MSB REG(0x00, 0xc7) /* write */ +#define REG_DE_STOP_LSB REG(0x00, 0xc8) /* write */ +#define REG_TBG_CNTRL_0 REG(0x00, 0xca) /* write */ +#define TBG_CNTRL_0_TOP_TGL BIT(0) +#define TBG_CNTRL_0_TOP_SEL BIT(1) +#define TBG_CNTRL_0_DE_EXT BIT(2) +#define TBG_CNTRL_0_TOP_EXT BIT(3) +#define TBG_CNTRL_0_FRAME_DIS BIT(5) +#define TBG_CNTRL_0_SYNC_MTHD BIT(6) +#define TBG_CNTRL_0_SYNC_ONCE BIT(7) +#define REG_TBG_CNTRL_1 REG(0x00, 0xcb) /* write */ +#define TBG_CNTRL_1_H_TGL BIT(0) +#define TBG_CNTRL_1_V_TGL BIT(1) +#define TBG_CNTRL_1_TGL_EN BIT(2) +#define TBG_CNTRL_1_X_EXT BIT(3) +#define TBG_CNTRL_1_H_EXT BIT(4) +#define TBG_CNTRL_1_V_EXT BIT(5) +#define TBG_CNTRL_1_DWIN_DIS BIT(6) +#define REG_ENABLE_SPACE REG(0x00, 0xd6) /* write */ +#define REG_HVF_CNTRL_0 REG(0x00, 0xe4) /* write */ +#define HVF_CNTRL_0_SM BIT(7) +#define HVF_CNTRL_0_RWB BIT(6) +#define HVF_CNTRL_0_PREFIL(x) (((x) & 3) << 2) +#define HVF_CNTRL_0_INTPOL(x) (((x) & 3) << 0) +#define REG_HVF_CNTRL_1 REG(0x00, 0xe5) /* write */ +#define HVF_CNTRL_1_FOR BIT(0) +#define HVF_CNTRL_1_YUVBLK BIT(1) +#define HVF_CNTRL_1_VQR(x) (((x) & 3) << 2) +#define HVF_CNTRL_1_PAD(x) (((x) & 3) << 4) +#define REG_RPT_CNTRL REG(0x00, 0xf0) /* write */ +#define REG_AIP_CLKSEL REG(0x00, 0xfd) /* write */ +#define AIP_CLKSEL_AIP_SPDIF (0 << 3) +#define AIP_CLKSEL_AIP_I2S BIT(3) +#define AIP_CLKSEL_FS_ACLK (0 << 0) +#define AIP_CLKSEL_FS_MCLK BIT(0) + +/* Page 02h: PLL settings */ +#define REG_PLL_SERIAL_1 REG(0x02, 0x00) /* read/write */ +#define PLL_SERIAL_1_SRL_FDN BIT(0) +#define PLL_SERIAL_1_SRL_IZ(x) (((x) & 3) << 1) +#define PLL_SERIAL_1_SRL_MAN_IZ BIT(6) +#define REG_PLL_SERIAL_2 REG(0x02, 0x01) /* read/write */ +#define PLL_SERIAL_2_SRL_NOSC(x) ((x) << 0) +#define PLL_SERIAL_2_SRL_PR(x) (((x) & 0xf) << 4) +#define REG_PLL_SERIAL_3 REG(0x02, 0x02) /* read/write */ +#define PLL_SERIAL_3_SRL_CCIR BIT(0) +#define PLL_SERIAL_3_SRL_DE BIT(2) +#define PLL_SERIAL_3_SRL_PXIN_SEL BIT(4) +#define REG_SERIALIZER REG(0x02, 0x03) /* read/write */ +#define REG_BUFFER_OUT REG(0x02, 0x04) /* read/write */ +#define REG_PLL_SCG1 REG(0x02, 0x05) /* read/write */ +#define REG_PLL_SCG2 REG(0x02, 0x06) /* read/write */ +#define REG_PLL_SCGN1 REG(0x02, 0x07) /* read/write */ +#define REG_PLL_SCGN2 REG(0x02, 0x08) /* read/write */ +#define REG_PLL_SCGR1 REG(0x02, 0x09) /* read/write */ +#define REG_PLL_SCGR2 REG(0x02, 0x0a) /* read/write */ +#define REG_AUDIO_DIV REG(0x02, 0x0e) /* read/write */ +#define AUDIO_DIV_SERCLK_1 0 +#define AUDIO_DIV_SERCLK_2 1 +#define AUDIO_DIV_SERCLK_4 2 +#define AUDIO_DIV_SERCLK_8 3 +#define AUDIO_DIV_SERCLK_16 4 +#define AUDIO_DIV_SERCLK_32 5 +#define REG_SEL_CLK REG(0x02, 0x11) /* read/write */ +#define SEL_CLK_SEL_CLK1 BIT(0) +#define SEL_CLK_SEL_VRF_CLK(x) (((x) & 3) << 1) +#define SEL_CLK_ENA_SC_CLK BIT(3) +#define REG_ANA_GENERAL REG(0x02, 0x12) /* read/write */ + +/* Page 09h: EDID Control */ +#define REG_EDID_DATA_0 REG(0x09, 0x00) /* read */ +/* next 127 successive registers are the EDID block */ +#define REG_EDID_CTRL REG(0x09, 0xfa) /* read/write */ +#define REG_DDC_ADDR REG(0x09, 0xfb) /* read/write */ +#define REG_DDC_OFFS REG(0x09, 0xfc) /* read/write */ +#define REG_DDC_SEGM_ADDR REG(0x09, 0xfd) /* read/write */ +#define REG_DDC_SEGM REG(0x09, 0xfe) /* read/write */ + +/* Page 11h: audio settings and content info packets */ +#define REG_AIP_CNTRL_0 REG(0x11, 0x00) /* read/write */ +#define AIP_CNTRL_0_RST_FIFO BIT(0) +#define REG_ENC_CNTRL REG(0x11, 0x0d) /* read/write */ +#define ENC_CNTRL_RST_ENC BIT(0) +#define ENC_CNTRL_RST_SEL BIT(1) +#define ENC_CNTRL_CTL_CODE(x) (((x) & 3) << 2) + +/* Page 12h: HDCP and OTP */ +#define REG_TX3 REG(0x12, 0x9a) /* read/write */ +#define REG_TX4 REG(0x12, 0x9b) /* read/write */ +#define TX4_PD_RAM BIT(1) +#define REG_TX33 REG(0x12, 0xb8) /* read/write */ +#define TX33_HDMI BIT(1) + +/* CEC registers, not paged */ +#define REG_CEC_FRO_IM_CLK_CTRL 0xfb /* read/write */ +#define CEC_FRO_IM_CLK_CTRL_GHOST_DIS BIT(7) +#define CEC_FRO_IM_CLK_CTRL_ENA_OTP BIT(6) +#define CEC_FRO_IM_CLK_CTRL_IMCLK_SEL BIT(1) +#define CEC_FRO_IM_CLK_CTRL_FRO_DIV BIT(0) +#define REG_CEC_RXSHPDINTENA 0xfc /* read/write */ +#define REG_CEC_RXSHPDINT 0xfd /* read */ +#define CEC_RXSHPDINT_RXSENS BIT(0) +#define CEC_RXSHPDINT_HPD BIT(1) +#define TDA19988_CEC_ENAMODS 0xff /* read/write */ +#define CEC_ENAMODS_EN_RXSENS BIT(2) +#define CEC_ENAMODS_EN_HDMI BIT(1) +#define CEC_ENAMODS_EN_CEC BIT(0) + +/* Device versions */ +#define TDA9989N2 0x0101 +#define TDA19989 0x0201 +#define TDA19989N2 0x0202 +#define TDA19988 0x0301 + + +struct tda19988_priv { + struct udevice *chip; + struct udevice *cec_chip; + u16 revision; + u8 current_page; +}; + +static void tda19988_register_set(struct tda19988_priv *priv, u16 reg, u8 val) +{ + u8 old_val, page = REG2PAGE(reg); + + if (priv->current_page != page) { + dm_i2c_reg_write(priv->chip, REG_CURRENT_PAGE, page); + priv->current_page = page; + } + old_val = dm_i2c_reg_read(priv->chip, REG2ADDR(reg)); + old_val |= val; + dm_i2c_reg_write(priv->chip, REG2ADDR(reg), old_val); +} + +static void tda19988_register_clear(struct tda19988_priv *priv, u16 reg, u8 val) +{ + u8 old_val, page = REG2PAGE(reg); + + if (priv->current_page != page) { + dm_i2c_reg_write(priv->chip, REG_CURRENT_PAGE, page); + priv->current_page = page; + } + old_val = dm_i2c_reg_read(priv->chip, REG2ADDR(reg)); + old_val &= ~val; + dm_i2c_reg_write(priv->chip, REG2ADDR(reg), old_val); +} + +static void tda19988_register_write(struct tda19988_priv *priv, u16 reg, u8 val) +{ + u8 page = REG2PAGE(reg); + + if (priv->current_page != page) { + dm_i2c_reg_write(priv->chip, REG_CURRENT_PAGE, page); + priv->current_page = page; + } + dm_i2c_reg_write(priv->chip, REG2ADDR(reg), val); +} + +static int tda19988_register_read(struct tda19988_priv *priv, u16 reg) +{ + u8 page = REG2PAGE(reg); + + if (priv->current_page != page) { + dm_i2c_reg_write(priv->chip, REG_CURRENT_PAGE, page); + priv->current_page = page; + } + return dm_i2c_reg_read(priv->chip, REG2ADDR(reg)); +} + +static void tda19988_register_write16(struct tda19988_priv *priv, u16 reg, u16 val) +{ + u8 buf[] = { val >> 8, val }, page = REG2PAGE(reg); + + if (priv->current_page != page) { + dm_i2c_reg_write(priv->chip, REG_CURRENT_PAGE, page); + priv->current_page = page; + } + dm_i2c_write(priv->chip, REG2ADDR(reg), buf, 2); +} + +static int tda19988_read_edid(struct udevice *dev, u8 *buf, int buf_size) +{ + struct tda19988_priv *priv = dev_get_priv(dev); + int i, val = 0, offset = 0; + + /* + * The TDA998x has a problem when trying to read the EDID close to a + * HPD assertion: it needs a delay of 100ms to avoid timing out while + * trying to read EDID data. + */ + mdelay(120); + + if (priv->revision == TDA19988) + tda19988_register_clear(priv, REG_TX4, TX4_PD_RAM); + + while (offset < buf_size) { + tda19988_register_write(priv, REG_DDC_ADDR, 0xa0); + tda19988_register_write(priv, REG_DDC_OFFS, offset); + tda19988_register_write(priv, REG_DDC_SEGM_ADDR, 0x60); + tda19988_register_write(priv, REG_DDC_SEGM, 0); + + /* enable reading EDID */ + tda19988_register_write(priv, REG_EDID_CTRL, 1); + + /* flags must be cleared by software */ + tda19988_register_write(priv, REG_EDID_CTRL, 0); + + /* wait for block read to complete */ + for (i = 300; i > 0; i--) { + mdelay(1); + val = tda19988_register_read(priv, REG_INT_FLAGS_2); + if (val < 0) + return val; + if (val & INT_FLAGS_2_EDID_BLK_RD) + break; + } + + if (i == 0) + return -ETIMEDOUT; + + priv->current_page = REG2PAGE(REG_EDID_DATA_0); + dm_i2c_reg_write(priv->chip, REG_CURRENT_PAGE, REG2PAGE(REG_EDID_DATA_0)); + val = dm_i2c_read(priv->chip, REG2ADDR(REG_EDID_DATA_0), buf + offset, 128); + offset += 128; + } + + if (priv->revision == TDA19988) + tda19988_register_set(priv, REG_TX4, TX4_PD_RAM); + + return offset; +} + +static int tda19988_enable(struct udevice *dev, int panel_bpp, + const struct display_timing *timing) +{ + struct tda19988_priv *priv = dev_get_priv(dev); + u8 div = 148500000 / timing->pixelclock.typ, reg; + u16 line_clocks, lines; + + if (dev != 0) { + div--; + if (div > 3) + div = 3; + } + /* first disable the video ports */ + tda19988_register_write(priv, REG_ENA_VP_0, 0); + tda19988_register_write(priv, REG_ENA_VP_1, 0); + tda19988_register_write(priv, REG_ENA_VP_2, 0); + + /* shutdown audio */ + tda19988_register_write(priv, REG_ENA_AP, 0); + + line_clocks = timing->hsync_len.typ + timing->hback_porch.typ + + timing->hactive.typ + timing->hfront_porch.typ; + lines = timing->vsync_len.typ + timing->vback_porch.typ + + timing->vactive.typ + timing->vfront_porch.typ; + + /* mute the audio FIFO */ + tda19988_register_set(priv, REG_AIP_CNTRL_0, AIP_CNTRL_0_RST_FIFO); + /* HDMI HDCP: off */ + tda19988_register_write(priv, REG_TBG_CNTRL_1, TBG_CNTRL_1_DWIN_DIS); + tda19988_register_clear(priv, REG_TX33, TX33_HDMI); + tda19988_register_write(priv, REG_ENC_CNTRL, ENC_CNTRL_CTL_CODE(0)); + + /* no pre-filter or interpolator */ + tda19988_register_write(priv, REG_HVF_CNTRL_0, HVF_CNTRL_0_PREFIL(0) | + HVF_CNTRL_0_INTPOL(0)); + tda19988_register_set(priv, REG_FEAT_POWERDOWN, FEAT_POWERDOWN_PREFILT); + tda19988_register_write(priv, REG_VIP_CNTRL_5, VIP_CNTRL_5_SP_CNT(0)); + tda19988_register_write(priv, REG_VIP_CNTRL_4, VIP_CNTRL_4_BLANKIT(0) | + VIP_CNTRL_4_BLC(0) | VIP_CNTRL_4_TST_PAT); + + tda19988_register_clear(priv, REG_PLL_SERIAL_1, PLL_SERIAL_1_SRL_MAN_IZ); + tda19988_register_clear(priv, REG_PLL_SERIAL_3, PLL_SERIAL_3_SRL_CCIR | + PLL_SERIAL_3_SRL_DE); + + tda19988_register_write(priv, REG_SERIALIZER, 0); + tda19988_register_write(priv, REG_HVF_CNTRL_1, HVF_CNTRL_1_VQR(0)); + + tda19988_register_write(priv, REG_RPT_CNTRL, 0); + tda19988_register_write(priv, REG_SEL_CLK, SEL_CLK_SEL_VRF_CLK(0) | + SEL_CLK_SEL_CLK1 | SEL_CLK_ENA_SC_CLK); + tda19988_register_write(priv, REG_PLL_SERIAL_2, PLL_SERIAL_2_SRL_NOSC(div) | + PLL_SERIAL_2_SRL_PR(0)); + + /* set color matrix bypass flag: */ + tda19988_register_write(priv, REG_MAT_CONTRL, MAT_CONTRL_MAT_BP | + MAT_CONTRL_MAT_SC(1)); + tda19988_register_set(priv, REG_FEAT_POWERDOWN, FEAT_POWERDOWN_CSC); + + /* set BIAS tmds value: */ + tda19988_register_write(priv, REG_ANA_GENERAL, 0x09); + + /* + * Sync on rising HSYNC/VSYNC + */ + reg = VIP_CNTRL_3_SYNC_HS; + + /* + * TDA19988 requires high-active sync at input stage, + * so invert low-active sync provided by master encoder here + */ + if (timing->flags & DISPLAY_FLAGS_HSYNC_LOW) + reg |= VIP_CNTRL_3_H_TGL; + if (timing->flags & DISPLAY_FLAGS_VSYNC_LOW) + reg |= VIP_CNTRL_3_V_TGL; + tda19988_register_write(priv, REG_VIP_CNTRL_3, reg); + + tda19988_register_write(priv, REG_VIDFORMAT, 0x00); + tda19988_register_write16(priv, REG_REFPIX_MSB, timing->hfront_porch.typ + 3); + tda19988_register_write16(priv, REG_REFLINE_MSB, timing->vfront_porch.typ + 1); + tda19988_register_write16(priv, REG_NPIX_MSB, line_clocks); + tda19988_register_write16(priv, REG_NLINE_MSB, lines); + tda19988_register_write16(priv, REG_VS_LINE_STRT_1_MSB, timing->vfront_porch.typ); + tda19988_register_write16(priv, REG_VS_PIX_STRT_1_MSB, timing->hfront_porch.typ); + tda19988_register_write16(priv, REG_VS_LINE_END_1_MSB, + timing->vfront_porch.typ + timing->vsync_len.typ); + tda19988_register_write16(priv, REG_VS_PIX_END_1_MSB, timing->hfront_porch.typ); + tda19988_register_write16(priv, REG_VS_LINE_STRT_2_MSB, 0); + tda19988_register_write16(priv, REG_VS_PIX_STRT_2_MSB, 0); + tda19988_register_write16(priv, REG_VS_LINE_END_2_MSB, 0); + tda19988_register_write16(priv, REG_VS_PIX_END_2_MSB, 0); + tda19988_register_write16(priv, REG_HS_PIX_START_MSB, timing->hfront_porch.typ); + tda19988_register_write16(priv, REG_HS_PIX_STOP_MSB, + timing->hfront_porch.typ + timing->hsync_len.typ); + tda19988_register_write16(priv, REG_VWIN_START_1_MSB, + lines - timing->vactive.typ - 1); + tda19988_register_write16(priv, REG_VWIN_END_1_MSB, lines - 1); + tda19988_register_write16(priv, REG_VWIN_START_2_MSB, 0); + tda19988_register_write16(priv, REG_VWIN_END_2_MSB, 0); + tda19988_register_write16(priv, REG_DE_START_MSB, + line_clocks - timing->hactive.typ); + tda19988_register_write16(priv, REG_DE_STOP_MSB, line_clocks); + + if (priv->revision == TDA19988) { + /* let incoming pixels fill the active space (if any) */ + tda19988_register_write(priv, REG_ENABLE_SPACE, 0x00); + } + + /* + * Always generate sync polarity relative to input sync and + * revert input stage toggled sync at output stage + */ + reg = TBG_CNTRL_1_DWIN_DIS | TBG_CNTRL_1_TGL_EN; + if (timing->flags & DISPLAY_FLAGS_HSYNC_LOW) + reg |= TBG_CNTRL_1_H_TGL; + if (timing->flags & DISPLAY_FLAGS_VSYNC_LOW) + reg |= TBG_CNTRL_1_V_TGL; + tda19988_register_write(priv, REG_TBG_CNTRL_1, reg); + + /* must be last register set: */ + tda19988_register_write(priv, REG_TBG_CNTRL_0, 0); + + /* turn on HDMI HDCP */ + reg &= ~TBG_CNTRL_1_DWIN_DIS; + tda19988_register_write(priv, REG_TBG_CNTRL_1, reg); + tda19988_register_write(priv, REG_ENC_CNTRL, ENC_CNTRL_CTL_CODE(1)); + tda19988_register_set(priv, REG_TX33, TX33_HDMI); + + mdelay(400); + + /* enable video ports */ + tda19988_register_write(priv, REG_ENA_VP_0, 0xff); + tda19988_register_write(priv, REG_ENA_VP_1, 0xff); + tda19988_register_write(priv, REG_ENA_VP_2, 0xff); + /* set muxing after enabling ports: */ + tda19988_register_write(priv, REG_VIP_CNTRL_0, + VIP_CNTRL_0_SWAP_A(2) | VIP_CNTRL_0_SWAP_B(3)); + tda19988_register_write(priv, REG_VIP_CNTRL_1, + VIP_CNTRL_1_SWAP_C(4) | VIP_CNTRL_1_SWAP_D(5)); + tda19988_register_write(priv, REG_VIP_CNTRL_2, + VIP_CNTRL_2_SWAP_E(0) | VIP_CNTRL_2_SWAP_F(1)); + + return 0; +} + +struct dm_display_ops tda19988_ops = { + .read_edid = tda19988_read_edid, + .enable = tda19988_enable, +}; + +static const struct udevice_id tda19988_ids[] = { + { .compatible = "nxp,tda998x" }, + { } +}; + +static int tda19988_probe(struct udevice *dev) +{ + u8 cec_addr, chip_addr, rev_lo, rev_hi; + int err; + struct tda19988_priv *priv = dev_get_priv(dev); + + chip_addr = dev_read_addr(dev); + /* CEC I2C address is using TDA19988 I2C address configuration pins */ + cec_addr = 0x34 + (chip_addr & 0x03); + + err = i2c_get_chip_for_busnum(0, cec_addr, 1, &priv->cec_chip); + if (err) { + printf("cec i2c_get_chip_for_busnum returned %d\n", err); + return err; + } + + err = i2c_get_chip_for_busnum(0, chip_addr, 1, &priv->chip); + if (err) { + printf("i2c_get_chip_for_busnum returned %d\n", err); + return err; + } + + priv->current_page = 0xff; + + /* wake up device */ + dm_i2c_reg_write(priv->cec_chip, TDA19988_CEC_ENAMODS, + CEC_ENAMODS_EN_RXSENS | CEC_ENAMODS_EN_HDMI); + + /* reset audio and I2C master */ + tda19988_register_write(priv, REG_SOFTRESET, + SOFTRESET_AUDIO | SOFTRESET_I2C_MASTER); + mdelay(50); + tda19988_register_write(priv, REG_SOFTRESET, 0); + mdelay(50); + + /* reset transmitter */ + tda19988_register_set(priv, REG_MAIN_CNTRL0, MAIN_CNTRL0_SR); + tda19988_register_clear(priv, REG_MAIN_CNTRL0, MAIN_CNTRL0_SR); + + /* PLL registers common configuration */ + tda19988_register_write(priv, REG_PLL_SERIAL_1, 0x00); + tda19988_register_write(priv, REG_PLL_SERIAL_2, PLL_SERIAL_2_SRL_NOSC(1)); + tda19988_register_write(priv, REG_PLL_SERIAL_3, 0x00); + tda19988_register_write(priv, REG_SERIALIZER, 0x00); + tda19988_register_write(priv, REG_BUFFER_OUT, 0x00); + tda19988_register_write(priv, REG_PLL_SCG1, 0x00); + tda19988_register_write(priv, REG_AUDIO_DIV, AUDIO_DIV_SERCLK_8); + tda19988_register_write(priv, REG_SEL_CLK, SEL_CLK_SEL_CLK1 | SEL_CLK_ENA_SC_CLK); + tda19988_register_write(priv, REG_PLL_SCGN1, 0xfa); + tda19988_register_write(priv, REG_PLL_SCGN2, 0x00); + tda19988_register_write(priv, REG_PLL_SCGR1, 0x5b); + tda19988_register_write(priv, REG_PLL_SCGR2, 0x00); + tda19988_register_write(priv, REG_PLL_SCG2, 0x10); + + /* Write the default value MUX register */ + tda19988_register_write(priv, REG_MUX_VP_VIP_OUT, 0x24); + + /* read version */ + rev_lo = dm_i2c_reg_read(priv->chip, REG_VERSION_LSB); + rev_hi = dm_i2c_reg_read(priv->chip, REG_VERSION_MSB); + + /* mask off feature bits */ + priv->revision = ((rev_hi << 8) | rev_lo) & ~0x30; + + printf("HDMI: "); + switch (priv->revision) { + case TDA9989N2: + printf("TDA9989 n2\n"); + break; + case TDA19989: + printf("TDA19989\n"); + break; + case TDA19989N2: + printf("TDA19989 n2\n"); + break; + case TDA19988: + printf("TDA19988\n"); + break; + default: + printf("unknown TDA device: 0x%04x\n", priv->revision); + return -ENXIO; + } + + /* after reset, enable DDC */ + tda19988_register_write(priv, REG_DDC_DISABLE, 0x00); + + /* set clock on DDC channel */ + tda19988_register_write(priv, REG_TX3, 39); + + /* if necessary, disable multi-master */ + if (priv->revision == TDA19989) + tda19988_register_set(priv, REG_I2C_MASTER, I2C_MASTER_DIS_MM); + + dm_i2c_reg_write(priv->cec_chip, REG_CEC_FRO_IM_CLK_CTRL, + CEC_FRO_IM_CLK_CTRL_GHOST_DIS | CEC_FRO_IM_CLK_CTRL_IMCLK_SEL); + /* ensure interrupts are disabled */ + dm_i2c_reg_write(priv->cec_chip, REG_CEC_RXSHPDINTENA, 0); + /* clear pending interrupts */ + dm_i2c_reg_read(priv->cec_chip, REG_CEC_RXSHPDINT); + tda19988_register_read(priv, REG_INT_FLAGS_0); + tda19988_register_read(priv, REG_INT_FLAGS_1); + tda19988_register_read(priv, REG_INT_FLAGS_2); + + /* enable EDID read irq */ + tda19988_register_set(priv, REG_INT_FLAGS_2, INT_FLAGS_2_EDID_BLK_RD); + + return 0; +} + +U_BOOT_DRIVER(tda19988) = { + .name = "tda19988", + .id = UCLASS_DISPLAY, + .of_match = tda19988_ids, + .ops = &tda19988_ops, + .probe = tda19988_probe, + .priv_auto_alloc_size = sizeof(struct tda19988_priv), +};
On Mon, 17 Sep 2018 17:52:54 +0100 Liviu Dudau Liviu.Dudau@foss.arm.com wrote:
There are some issues reported by checkpatch, please fix. Thanks!
-- Anatolij
Signed-off-by: Liviu Dudau liviu.dudau@foss.arm.com --- Changelog: - v2: Added MAINTAINERS entry and fixed checkpatch warnings.
MAINTAINERS | 5 + drivers/video/Kconfig | 8 + drivers/video/Makefile | 1 + drivers/video/tda19988.c | 653 +++++++++++++++++++++++++++++++++++++++ 4 files changed, 667 insertions(+) create mode 100644 drivers/video/tda19988.c
diff --git a/MAINTAINERS b/MAINTAINERS index 11fc404167..112e41d2c3 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -598,6 +598,11 @@ S: Maintained F: drivers/spmi/ F: include/spmi/
+TDA19988 HDMI ENCODER +M: Liviu Dudau liviu.dudau@foss.arm.com +S: Maintained +F: drivers/video/tda19988.c + TI SYSTEM SECURITY M: Andrew F. Davis afd@ti.com S: Supported diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index ed0b21f2a7..5d932072a8 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -431,6 +431,14 @@ config DISPLAY The devices provide a simple interface to start up the display, read display information and enable it.
+config NXP_TDA19988 + bool "Enable NXP TDA19988 support" + depends on DISPLAY + default n + help + This enables support for the NXP TDA19988 HDMI encoder. This encoder + will convert RGB data streams into HDMI-encoded signals. + config ATMEL_HLCD bool "Enable ATMEL video support using HLCDC" depends on DM_VIDEO diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 0f41a23193..4c130e179d 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -31,6 +31,7 @@ obj-$(CONFIG_FSL_DIU_FB) += fsl_diu_fb.o videomodes.o obj-$(CONFIG_LD9040) += ld9040.o obj-$(CONFIG_LG4573) += lg4573.o obj-$(CONFIG_LOGICORE_DP_TX) += logicore_dp_tx.o +obj-$(CONFIG_NXP_TDA19988) += tda19988.o obj-$(CONFIG_PXA_LCD) += pxa_lcd.o obj-$(CONFIG_S6E8AX0) += s6e8ax0.o obj-$(CONFIG_SCF0403_LCD) += scf0403_lcd.o diff --git a/drivers/video/tda19988.c b/drivers/video/tda19988.c new file mode 100644 index 0000000000..01ed6193ea --- /dev/null +++ b/drivers/video/tda19988.c @@ -0,0 +1,653 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2018 Liviu Dudau liviu@dudau.co.uk + * + * Based on the Linux driver, (C) 2012 Texas Instruments + */ + +#include <common.h> +#include <dm.h> +#include <display.h> +#include <i2c.h> + +/* + * TDA19988 uses paged registers. We encode the page# in the upper + * bits of the register#. It also means that reads/writes to a register + * have to ensure that the register's page is selected as the current + * page. + */ +#define REG(page, addr) (((page) << 8) | (addr)) +#define REG2ADDR(reg) ((reg) & 0xff) +#define REG2PAGE(reg) (((reg) >> 8) & 0xff) + +/* register for setting current page */ +#define REG_CURRENT_PAGE 0xff + +/* Page 00h: General Control */ +#define REG_VERSION_LSB REG(0x00, 0x00) /* read */ +#define REG_MAIN_CNTRL0 REG(0x00, 0x01) /* read/write */ +#define MAIN_CNTRL0_SR BIT(0) +#define MAIN_CNTRL0_DECS BIT(1) +#define MAIN_CNTRL0_DEHS BIT(2) +#define MAIN_CNTRL0_CECS BIT(3) +#define MAIN_CNTRL0_CEHS BIT(4) +#define MAIN_CNTRL0_SCALER BIT(7) +#define REG_VERSION_MSB REG(0x00, 0x02) /* read */ +#define REG_SOFTRESET REG(0x00, 0x0a) /* write */ +#define SOFTRESET_AUDIO BIT(0) +#define SOFTRESET_I2C_MASTER BIT(1) +#define REG_DDC_DISABLE REG(0x00, 0x0b) /* read/write */ +#define REG_I2C_MASTER REG(0x00, 0x0d) /* read/write */ +#define I2C_MASTER_DIS_MM BIT(0) +#define I2C_MASTER_DIS_FILT BIT(1) +#define I2C_MASTER_APP_STRT_LAT BIT(2) +#define REG_FEAT_POWERDOWN REG(0x00, 0x0e) /* read/write */ +#define FEAT_POWERDOWN_PREFILT BIT(0) +#define FEAT_POWERDOWN_CSC BIT(1) +#define FEAT_POWERDOWN_SPDIF BIT(3) +#define REG_INT_FLAGS_0 REG(0x00, 0x0f) /* read/write */ +#define REG_INT_FLAGS_1 REG(0x00, 0x10) /* read/write */ +#define REG_INT_FLAGS_2 REG(0x00, 0x11) /* read/write */ +#define INT_FLAGS_2_EDID_BLK_RD BIT(1) +#define REG_ENA_VP_0 REG(0x00, 0x18) /* read/write */ +#define REG_ENA_VP_1 REG(0x00, 0x19) /* read/write */ +#define REG_ENA_VP_2 REG(0x00, 0x1a) /* read/write */ +#define REG_ENA_AP REG(0x00, 0x1e) /* read/write */ +#define REG_VIP_CNTRL_0 REG(0x00, 0x20) /* write */ +#define VIP_CNTRL_0_MIRR_A BIT(7) +#define VIP_CNTRL_0_SWAP_A(x) (((x) & 7) << 4) +#define VIP_CNTRL_0_MIRR_B BIT(3) +#define VIP_CNTRL_0_SWAP_B(x) (((x) & 7) << 0) +#define REG_VIP_CNTRL_1 REG(0x00, 0x21) /* write */ +#define VIP_CNTRL_1_MIRR_C BIT(7) +#define VIP_CNTRL_1_SWAP_C(x) (((x) & 7) << 4) +#define VIP_CNTRL_1_MIRR_D BIT(3) +#define VIP_CNTRL_1_SWAP_D(x) (((x) & 7) << 0) +#define REG_VIP_CNTRL_2 REG(0x00, 0x22) /* write */ +#define VIP_CNTRL_2_MIRR_E BIT(7) +#define VIP_CNTRL_2_SWAP_E(x) (((x) & 7) << 4) +#define VIP_CNTRL_2_MIRR_F BIT(3) +#define VIP_CNTRL_2_SWAP_F(x) (((x) & 7) << 0) +#define REG_VIP_CNTRL_3 REG(0x00, 0x23) /* write */ +#define VIP_CNTRL_3_X_TGL BIT(0) +#define VIP_CNTRL_3_H_TGL BIT(1) +#define VIP_CNTRL_3_V_TGL BIT(2) +#define VIP_CNTRL_3_EMB BIT(3) +#define VIP_CNTRL_3_SYNC_DE BIT(4) +#define VIP_CNTRL_3_SYNC_HS BIT(5) +#define VIP_CNTRL_3_DE_INT BIT(6) +#define VIP_CNTRL_3_EDGE BIT(7) +#define REG_VIP_CNTRL_4 REG(0x00, 0x24) /* write */ +#define VIP_CNTRL_4_BLC(x) (((x) & 3) << 0) +#define VIP_CNTRL_4_BLANKIT(x) (((x) & 3) << 2) +#define VIP_CNTRL_4_CCIR656 BIT(4) +#define VIP_CNTRL_4_656_ALT BIT(5) +#define VIP_CNTRL_4_TST_656 BIT(6) +#define VIP_CNTRL_4_TST_PAT BIT(7) +#define REG_VIP_CNTRL_5 REG(0x00, 0x25) /* write */ +#define VIP_CNTRL_5_CKCASE BIT(0) +#define VIP_CNTRL_5_SP_CNT(x) (((x) & 3) << 1) +#define REG_MUX_VP_VIP_OUT REG(0x00, 0x27) /* read/write */ +#define REG_MAT_CONTRL REG(0x00, 0x80) /* write */ +#define MAT_CONTRL_MAT_SC(x) (((x) & 3) << 0) +#define MAT_CONTRL_MAT_BP BIT(2) +#define REG_VIDFORMAT REG(0x00, 0xa0) /* write */ +#define REG_REFPIX_MSB REG(0x00, 0xa1) /* write */ +#define REG_REFPIX_LSB REG(0x00, 0xa2) /* write */ +#define REG_REFLINE_MSB REG(0x00, 0xa3) /* write */ +#define REG_REFLINE_LSB REG(0x00, 0xa4) /* write */ +#define REG_NPIX_MSB REG(0x00, 0xa5) /* write */ +#define REG_NPIX_LSB REG(0x00, 0xa6) /* write */ +#define REG_NLINE_MSB REG(0x00, 0xa7) /* write */ +#define REG_NLINE_LSB REG(0x00, 0xa8) /* write */ +#define REG_VS_LINE_STRT_1_MSB REG(0x00, 0xa9) /* write */ +#define REG_VS_LINE_STRT_1_LSB REG(0x00, 0xaa) /* write */ +#define REG_VS_PIX_STRT_1_MSB REG(0x00, 0xab) /* write */ +#define REG_VS_PIX_STRT_1_LSB REG(0x00, 0xac) /* write */ +#define REG_VS_LINE_END_1_MSB REG(0x00, 0xad) /* write */ +#define REG_VS_LINE_END_1_LSB REG(0x00, 0xae) /* write */ +#define REG_VS_PIX_END_1_MSB REG(0x00, 0xaf) /* write */ +#define REG_VS_PIX_END_1_LSB REG(0x00, 0xb0) /* write */ +#define REG_VS_LINE_STRT_2_MSB REG(0x00, 0xb1) /* write */ +#define REG_VS_LINE_STRT_2_LSB REG(0x00, 0xb2) /* write */ +#define REG_VS_PIX_STRT_2_MSB REG(0x00, 0xb3) /* write */ +#define REG_VS_PIX_STRT_2_LSB REG(0x00, 0xb4) /* write */ +#define REG_VS_LINE_END_2_MSB REG(0x00, 0xb5) /* write */ +#define REG_VS_LINE_END_2_LSB REG(0x00, 0xb6) /* write */ +#define REG_VS_PIX_END_2_MSB REG(0x00, 0xb7) /* write */ +#define REG_VS_PIX_END_2_LSB REG(0x00, 0xb8) /* write */ +#define REG_HS_PIX_START_MSB REG(0x00, 0xb9) /* write */ +#define REG_HS_PIX_START_LSB REG(0x00, 0xba) /* write */ +#define REG_HS_PIX_STOP_MSB REG(0x00, 0xbb) /* write */ +#define REG_HS_PIX_STOP_LSB REG(0x00, 0xbc) /* write */ +#define REG_VWIN_START_1_MSB REG(0x00, 0xbd) /* write */ +#define REG_VWIN_START_1_LSB REG(0x00, 0xbe) /* write */ +#define REG_VWIN_END_1_MSB REG(0x00, 0xbf) /* write */ +#define REG_VWIN_END_1_LSB REG(0x00, 0xc0) /* write */ +#define REG_VWIN_START_2_MSB REG(0x00, 0xc1) /* write */ +#define REG_VWIN_START_2_LSB REG(0x00, 0xc2) /* write */ +#define REG_VWIN_END_2_MSB REG(0x00, 0xc3) /* write */ +#define REG_VWIN_END_2_LSB REG(0x00, 0xc4) /* write */ +#define REG_DE_START_MSB REG(0x00, 0xc5) /* write */ +#define REG_DE_START_LSB REG(0x00, 0xc6) /* write */ +#define REG_DE_STOP_MSB REG(0x00, 0xc7) /* write */ +#define REG_DE_STOP_LSB REG(0x00, 0xc8) /* write */ +#define REG_TBG_CNTRL_0 REG(0x00, 0xca) /* write */ +#define TBG_CNTRL_0_TOP_TGL BIT(0) +#define TBG_CNTRL_0_TOP_SEL BIT(1) +#define TBG_CNTRL_0_DE_EXT BIT(2) +#define TBG_CNTRL_0_TOP_EXT BIT(3) +#define TBG_CNTRL_0_FRAME_DIS BIT(5) +#define TBG_CNTRL_0_SYNC_MTHD BIT(6) +#define TBG_CNTRL_0_SYNC_ONCE BIT(7) +#define REG_TBG_CNTRL_1 REG(0x00, 0xcb) /* write */ +#define TBG_CNTRL_1_H_TGL BIT(0) +#define TBG_CNTRL_1_V_TGL BIT(1) +#define TBG_CNTRL_1_TGL_EN BIT(2) +#define TBG_CNTRL_1_X_EXT BIT(3) +#define TBG_CNTRL_1_H_EXT BIT(4) +#define TBG_CNTRL_1_V_EXT BIT(5) +#define TBG_CNTRL_1_DWIN_DIS BIT(6) +#define REG_ENABLE_SPACE REG(0x00, 0xd6) /* write */ +#define REG_HVF_CNTRL_0 REG(0x00, 0xe4) /* write */ +#define HVF_CNTRL_0_SM BIT(7) +#define HVF_CNTRL_0_RWB BIT(6) +#define HVF_CNTRL_0_PREFIL(x) (((x) & 3) << 2) +#define HVF_CNTRL_0_INTPOL(x) (((x) & 3) << 0) +#define REG_HVF_CNTRL_1 REG(0x00, 0xe5) /* write */ +#define HVF_CNTRL_1_FOR BIT(0) +#define HVF_CNTRL_1_YUVBLK BIT(1) +#define HVF_CNTRL_1_VQR(x) (((x) & 3) << 2) +#define HVF_CNTRL_1_PAD(x) (((x) & 3) << 4) +#define REG_RPT_CNTRL REG(0x00, 0xf0) /* write */ +#define REG_AIP_CLKSEL REG(0x00, 0xfd) /* write */ +#define AIP_CLKSEL_AIP_SPDIF (0 << 3) +#define AIP_CLKSEL_AIP_I2S BIT(3) +#define AIP_CLKSEL_FS_ACLK (0 << 0) +#define AIP_CLKSEL_FS_MCLK BIT(0) + +/* Page 02h: PLL settings */ +#define REG_PLL_SERIAL_1 REG(0x02, 0x00) /* read/write */ +#define PLL_SERIAL_1_SRL_FDN BIT(0) +#define PLL_SERIAL_1_SRL_IZ(x) (((x) & 3) << 1) +#define PLL_SERIAL_1_SRL_MAN_IZ BIT(6) +#define REG_PLL_SERIAL_2 REG(0x02, 0x01) /* read/write */ +#define PLL_SERIAL_2_SRL_NOSC(x) ((x) << 0) +#define PLL_SERIAL_2_SRL_PR(x) (((x) & 0xf) << 4) +#define REG_PLL_SERIAL_3 REG(0x02, 0x02) /* read/write */ +#define PLL_SERIAL_3_SRL_CCIR BIT(0) +#define PLL_SERIAL_3_SRL_DE BIT(2) +#define PLL_SERIAL_3_SRL_PXIN_SEL BIT(4) +#define REG_SERIALIZER REG(0x02, 0x03) /* read/write */ +#define REG_BUFFER_OUT REG(0x02, 0x04) /* read/write */ +#define REG_PLL_SCG1 REG(0x02, 0x05) /* read/write */ +#define REG_PLL_SCG2 REG(0x02, 0x06) /* read/write */ +#define REG_PLL_SCGN1 REG(0x02, 0x07) /* read/write */ +#define REG_PLL_SCGN2 REG(0x02, 0x08) /* read/write */ +#define REG_PLL_SCGR1 REG(0x02, 0x09) /* read/write */ +#define REG_PLL_SCGR2 REG(0x02, 0x0a) /* read/write */ +#define REG_AUDIO_DIV REG(0x02, 0x0e) /* read/write */ +#define AUDIO_DIV_SERCLK_1 0 +#define AUDIO_DIV_SERCLK_2 1 +#define AUDIO_DIV_SERCLK_4 2 +#define AUDIO_DIV_SERCLK_8 3 +#define AUDIO_DIV_SERCLK_16 4 +#define AUDIO_DIV_SERCLK_32 5 +#define REG_SEL_CLK REG(0x02, 0x11) /* read/write */ +#define SEL_CLK_SEL_CLK1 BIT(0) +#define SEL_CLK_SEL_VRF_CLK(x) (((x) & 3) << 1) +#define SEL_CLK_ENA_SC_CLK BIT(3) +#define REG_ANA_GENERAL REG(0x02, 0x12) /* read/write */ + +/* Page 09h: EDID Control */ +#define REG_EDID_DATA_0 REG(0x09, 0x00) /* read */ +/* next 127 successive registers are the EDID block */ +#define REG_EDID_CTRL REG(0x09, 0xfa) /* read/write */ +#define REG_DDC_ADDR REG(0x09, 0xfb) /* read/write */ +#define REG_DDC_OFFS REG(0x09, 0xfc) /* read/write */ +#define REG_DDC_SEGM_ADDR REG(0x09, 0xfd) /* read/write */ +#define REG_DDC_SEGM REG(0x09, 0xfe) /* read/write */ + +/* Page 11h: audio settings and content info packets */ +#define REG_AIP_CNTRL_0 REG(0x11, 0x00) /* read/write */ +#define AIP_CNTRL_0_RST_FIFO BIT(0) +#define REG_ENC_CNTRL REG(0x11, 0x0d) /* read/write */ +#define ENC_CNTRL_RST_ENC BIT(0) +#define ENC_CNTRL_RST_SEL BIT(1) +#define ENC_CNTRL_CTL_CODE(x) (((x) & 3) << 2) + +/* Page 12h: HDCP and OTP */ +#define REG_TX3 REG(0x12, 0x9a) /* read/write */ +#define REG_TX4 REG(0x12, 0x9b) /* read/write */ +#define TX4_PD_RAM BIT(1) +#define REG_TX33 REG(0x12, 0xb8) /* read/write */ +#define TX33_HDMI BIT(1) + +/* CEC registers, not paged */ +#define REG_CEC_FRO_IM_CLK_CTRL 0xfb /* read/write */ +#define CEC_FRO_IM_CLK_CTRL_GHOST_DIS BIT(7) +#define CEC_FRO_IM_CLK_CTRL_ENA_OTP BIT(6) +#define CEC_FRO_IM_CLK_CTRL_IMCLK_SEL BIT(1) +#define CEC_FRO_IM_CLK_CTRL_FRO_DIV BIT(0) +#define REG_CEC_RXSHPDINTENA 0xfc /* read/write */ +#define REG_CEC_RXSHPDINT 0xfd /* read */ +#define CEC_RXSHPDINT_RXSENS BIT(0) +#define CEC_RXSHPDINT_HPD BIT(1) +#define TDA19988_CEC_ENAMODS 0xff /* read/write */ +#define CEC_ENAMODS_EN_RXSENS BIT(2) +#define CEC_ENAMODS_EN_HDMI BIT(1) +#define CEC_ENAMODS_EN_CEC BIT(0) + +/* Device versions */ +#define TDA9989N2 0x0101 +#define TDA19989 0x0201 +#define TDA19989N2 0x0202 +#define TDA19988 0x0301 + +struct tda19988_priv { + struct udevice *chip; + struct udevice *cec_chip; + u16 revision; + u8 current_page; +}; + +static void tda19988_register_set(struct tda19988_priv *priv, u16 reg, u8 val) +{ + u8 old_val, page = REG2PAGE(reg); + + if (priv->current_page != page) { + dm_i2c_reg_write(priv->chip, REG_CURRENT_PAGE, page); + priv->current_page = page; + } + old_val = dm_i2c_reg_read(priv->chip, REG2ADDR(reg)); + old_val |= val; + dm_i2c_reg_write(priv->chip, REG2ADDR(reg), old_val); +} + +static void tda19988_register_clear(struct tda19988_priv *priv, u16 reg, u8 val) +{ + u8 old_val, page = REG2PAGE(reg); + + if (priv->current_page != page) { + dm_i2c_reg_write(priv->chip, REG_CURRENT_PAGE, page); + priv->current_page = page; + } + old_val = dm_i2c_reg_read(priv->chip, REG2ADDR(reg)); + old_val &= ~val; + dm_i2c_reg_write(priv->chip, REG2ADDR(reg), old_val); +} + +static void tda19988_register_write(struct tda19988_priv *priv, u16 reg, u8 val) +{ + u8 page = REG2PAGE(reg); + + if (priv->current_page != page) { + dm_i2c_reg_write(priv->chip, REG_CURRENT_PAGE, page); + priv->current_page = page; + } + dm_i2c_reg_write(priv->chip, REG2ADDR(reg), val); +} + +static int tda19988_register_read(struct tda19988_priv *priv, u16 reg) +{ + u8 page = REG2PAGE(reg); + + if (priv->current_page != page) { + dm_i2c_reg_write(priv->chip, REG_CURRENT_PAGE, page); + priv->current_page = page; + } + return dm_i2c_reg_read(priv->chip, REG2ADDR(reg)); +} + +static void tda19988_register_write16(struct tda19988_priv *priv, + u16 reg, u16 val) +{ + u8 buf[] = { val >> 8, val }, page = REG2PAGE(reg); + + if (priv->current_page != page) { + dm_i2c_reg_write(priv->chip, REG_CURRENT_PAGE, page); + priv->current_page = page; + } + dm_i2c_write(priv->chip, REG2ADDR(reg), buf, 2); +} + +static int tda19988_read_edid(struct udevice *dev, u8 *buf, int buf_size) +{ + struct tda19988_priv *priv = dev_get_priv(dev); + int i, val = 0, offset = 0; + + /* + * The TDA998x has a problem when trying to read the EDID close to a + * HPD assertion: it needs a delay of 100ms to avoid timing out while + * trying to read EDID data. + */ + mdelay(120); + + if (priv->revision == TDA19988) + tda19988_register_clear(priv, REG_TX4, TX4_PD_RAM); + + while (offset < buf_size) { + tda19988_register_write(priv, REG_DDC_ADDR, 0xa0); + tda19988_register_write(priv, REG_DDC_OFFS, offset); + tda19988_register_write(priv, REG_DDC_SEGM_ADDR, 0x60); + tda19988_register_write(priv, REG_DDC_SEGM, 0); + + /* enable reading EDID */ + tda19988_register_write(priv, REG_EDID_CTRL, 1); + + /* flags must be cleared by software */ + tda19988_register_write(priv, REG_EDID_CTRL, 0); + + /* wait for block read to complete */ + for (i = 300; i > 0; i--) { + mdelay(1); + val = tda19988_register_read(priv, REG_INT_FLAGS_2); + if (val < 0) + return val; + if (val & INT_FLAGS_2_EDID_BLK_RD) + break; + } + + if (i == 0) + return -ETIMEDOUT; + + priv->current_page = REG2PAGE(REG_EDID_DATA_0); + dm_i2c_reg_write(priv->chip, + REG_CURRENT_PAGE, REG2PAGE(REG_EDID_DATA_0)); + val = dm_i2c_read(priv->chip, + REG2ADDR(REG_EDID_DATA_0), buf + offset, 128); + offset += 128; + } + + if (priv->revision == TDA19988) + tda19988_register_set(priv, REG_TX4, TX4_PD_RAM); + + return offset; +} + +static int tda19988_enable(struct udevice *dev, int panel_bpp, + const struct display_timing *timing) +{ + struct tda19988_priv *priv = dev_get_priv(dev); + u8 div = 148500000 / timing->pixelclock.typ, reg; + u16 line_clocks, lines; + + if (dev != 0) { + div--; + if (div > 3) + div = 3; + } + /* first disable the video ports */ + tda19988_register_write(priv, REG_ENA_VP_0, 0); + tda19988_register_write(priv, REG_ENA_VP_1, 0); + tda19988_register_write(priv, REG_ENA_VP_2, 0); + + /* shutdown audio */ + tda19988_register_write(priv, REG_ENA_AP, 0); + + line_clocks = timing->hsync_len.typ + timing->hback_porch.typ + + timing->hactive.typ + timing->hfront_porch.typ; + lines = timing->vsync_len.typ + timing->vback_porch.typ + + timing->vactive.typ + timing->vfront_porch.typ; + + /* mute the audio FIFO */ + tda19988_register_set(priv, REG_AIP_CNTRL_0, AIP_CNTRL_0_RST_FIFO); + /* HDMI HDCP: off */ + tda19988_register_write(priv, REG_TBG_CNTRL_1, TBG_CNTRL_1_DWIN_DIS); + tda19988_register_clear(priv, REG_TX33, TX33_HDMI); + tda19988_register_write(priv, REG_ENC_CNTRL, ENC_CNTRL_CTL_CODE(0)); + + /* no pre-filter or interpolator */ + tda19988_register_write(priv, REG_HVF_CNTRL_0, HVF_CNTRL_0_PREFIL(0) | + HVF_CNTRL_0_INTPOL(0)); + tda19988_register_set(priv, REG_FEAT_POWERDOWN, + FEAT_POWERDOWN_PREFILT); + tda19988_register_write(priv, REG_VIP_CNTRL_5, VIP_CNTRL_5_SP_CNT(0)); + tda19988_register_write(priv, REG_VIP_CNTRL_4, + VIP_CNTRL_4_BLANKIT(0) | VIP_CNTRL_4_BLC(0) | + VIP_CNTRL_4_TST_PAT); + + tda19988_register_clear(priv, REG_PLL_SERIAL_1, + PLL_SERIAL_1_SRL_MAN_IZ); + tda19988_register_clear(priv, REG_PLL_SERIAL_3, PLL_SERIAL_3_SRL_CCIR | + PLL_SERIAL_3_SRL_DE); + + tda19988_register_write(priv, REG_SERIALIZER, 0); + tda19988_register_write(priv, REG_HVF_CNTRL_1, HVF_CNTRL_1_VQR(0)); + + tda19988_register_write(priv, REG_RPT_CNTRL, 0); + tda19988_register_write(priv, REG_SEL_CLK, SEL_CLK_SEL_VRF_CLK(0) | + SEL_CLK_SEL_CLK1 | SEL_CLK_ENA_SC_CLK); + tda19988_register_write(priv, REG_PLL_SERIAL_2, + PLL_SERIAL_2_SRL_NOSC(div) | + PLL_SERIAL_2_SRL_PR(0)); + + /* set color matrix bypass flag: */ + tda19988_register_write(priv, REG_MAT_CONTRL, MAT_CONTRL_MAT_BP | + MAT_CONTRL_MAT_SC(1)); + tda19988_register_set(priv, REG_FEAT_POWERDOWN, FEAT_POWERDOWN_CSC); + + /* set BIAS tmds value: */ + tda19988_register_write(priv, REG_ANA_GENERAL, 0x09); + + /* + * Sync on rising HSYNC/VSYNC + */ + reg = VIP_CNTRL_3_SYNC_HS; + + /* + * TDA19988 requires high-active sync at input stage, + * so invert low-active sync provided by master encoder here + */ + if (timing->flags & DISPLAY_FLAGS_HSYNC_LOW) + reg |= VIP_CNTRL_3_H_TGL; + if (timing->flags & DISPLAY_FLAGS_VSYNC_LOW) + reg |= VIP_CNTRL_3_V_TGL; + tda19988_register_write(priv, REG_VIP_CNTRL_3, reg); + + tda19988_register_write(priv, REG_VIDFORMAT, 0x00); + tda19988_register_write16(priv, REG_REFPIX_MSB, + timing->hfront_porch.typ + 3); + tda19988_register_write16(priv, REG_REFLINE_MSB, + timing->vfront_porch.typ + 1); + tda19988_register_write16(priv, REG_NPIX_MSB, line_clocks); + tda19988_register_write16(priv, REG_NLINE_MSB, lines); + tda19988_register_write16(priv, REG_VS_LINE_STRT_1_MSB, + timing->vfront_porch.typ); + tda19988_register_write16(priv, REG_VS_PIX_STRT_1_MSB, + timing->hfront_porch.typ); + tda19988_register_write16(priv, REG_VS_LINE_END_1_MSB, + timing->vfront_porch.typ + + timing->vsync_len.typ); + tda19988_register_write16(priv, REG_VS_PIX_END_1_MSB, + timing->hfront_porch.typ); + tda19988_register_write16(priv, REG_VS_LINE_STRT_2_MSB, 0); + tda19988_register_write16(priv, REG_VS_PIX_STRT_2_MSB, 0); + tda19988_register_write16(priv, REG_VS_LINE_END_2_MSB, 0); + tda19988_register_write16(priv, REG_VS_PIX_END_2_MSB, 0); + tda19988_register_write16(priv, REG_HS_PIX_START_MSB, + timing->hfront_porch.typ); + tda19988_register_write16(priv, REG_HS_PIX_STOP_MSB, + timing->hfront_porch.typ + + timing->hsync_len.typ); + tda19988_register_write16(priv, REG_VWIN_START_1_MSB, + lines - timing->vactive.typ - 1); + tda19988_register_write16(priv, REG_VWIN_END_1_MSB, lines - 1); + tda19988_register_write16(priv, REG_VWIN_START_2_MSB, 0); + tda19988_register_write16(priv, REG_VWIN_END_2_MSB, 0); + tda19988_register_write16(priv, REG_DE_START_MSB, + line_clocks - timing->hactive.typ); + tda19988_register_write16(priv, REG_DE_STOP_MSB, line_clocks); + + if (priv->revision == TDA19988) { + /* let incoming pixels fill the active space (if any) */ + tda19988_register_write(priv, REG_ENABLE_SPACE, 0x00); + } + + /* + * Always generate sync polarity relative to input sync and + * revert input stage toggled sync at output stage + */ + reg = TBG_CNTRL_1_DWIN_DIS | TBG_CNTRL_1_TGL_EN; + if (timing->flags & DISPLAY_FLAGS_HSYNC_LOW) + reg |= TBG_CNTRL_1_H_TGL; + if (timing->flags & DISPLAY_FLAGS_VSYNC_LOW) + reg |= TBG_CNTRL_1_V_TGL; + tda19988_register_write(priv, REG_TBG_CNTRL_1, reg); + + /* must be last register set: */ + tda19988_register_write(priv, REG_TBG_CNTRL_0, 0); + + /* turn on HDMI HDCP */ + reg &= ~TBG_CNTRL_1_DWIN_DIS; + tda19988_register_write(priv, REG_TBG_CNTRL_1, reg); + tda19988_register_write(priv, REG_ENC_CNTRL, ENC_CNTRL_CTL_CODE(1)); + tda19988_register_set(priv, REG_TX33, TX33_HDMI); + + mdelay(400); + + /* enable video ports */ + tda19988_register_write(priv, REG_ENA_VP_0, 0xff); + tda19988_register_write(priv, REG_ENA_VP_1, 0xff); + tda19988_register_write(priv, REG_ENA_VP_2, 0xff); + /* set muxing after enabling ports: */ + tda19988_register_write(priv, REG_VIP_CNTRL_0, + VIP_CNTRL_0_SWAP_A(2) | VIP_CNTRL_0_SWAP_B(3)); + tda19988_register_write(priv, REG_VIP_CNTRL_1, + VIP_CNTRL_1_SWAP_C(4) | VIP_CNTRL_1_SWAP_D(5)); + tda19988_register_write(priv, REG_VIP_CNTRL_2, + VIP_CNTRL_2_SWAP_E(0) | VIP_CNTRL_2_SWAP_F(1)); + + return 0; +} + +struct dm_display_ops tda19988_ops = { + .read_edid = tda19988_read_edid, + .enable = tda19988_enable, +}; + +static const struct udevice_id tda19988_ids[] = { + { .compatible = "nxp,tda998x" }, + { } +}; + +static int tda19988_probe(struct udevice *dev) +{ + u8 cec_addr, chip_addr, rev_lo, rev_hi; + int err; + struct tda19988_priv *priv = dev_get_priv(dev); + + chip_addr = dev_read_addr(dev); + /* CEC I2C address is using TDA19988 I2C address configuration pins */ + cec_addr = 0x34 + (chip_addr & 0x03); + + err = i2c_get_chip_for_busnum(0, cec_addr, 1, &priv->cec_chip); + if (err) { + printf("cec i2c_get_chip_for_busnum returned %d\n", err); + return err; + } + + err = i2c_get_chip_for_busnum(0, chip_addr, 1, &priv->chip); + if (err) { + printf("i2c_get_chip_for_busnum returned %d\n", err); + return err; + } + + priv->current_page = 0xff; + + /* wake up device */ + dm_i2c_reg_write(priv->cec_chip, TDA19988_CEC_ENAMODS, + CEC_ENAMODS_EN_RXSENS | CEC_ENAMODS_EN_HDMI); + + /* reset audio and I2C master */ + tda19988_register_write(priv, REG_SOFTRESET, + SOFTRESET_AUDIO | SOFTRESET_I2C_MASTER); + mdelay(50); + tda19988_register_write(priv, REG_SOFTRESET, 0); + mdelay(50); + + /* reset transmitter */ + tda19988_register_set(priv, REG_MAIN_CNTRL0, MAIN_CNTRL0_SR); + tda19988_register_clear(priv, REG_MAIN_CNTRL0, MAIN_CNTRL0_SR); + + /* PLL registers common configuration */ + tda19988_register_write(priv, REG_PLL_SERIAL_1, 0x00); + tda19988_register_write(priv, REG_PLL_SERIAL_2, + PLL_SERIAL_2_SRL_NOSC(1)); + tda19988_register_write(priv, REG_PLL_SERIAL_3, 0x00); + tda19988_register_write(priv, REG_SERIALIZER, 0x00); + tda19988_register_write(priv, REG_BUFFER_OUT, 0x00); + tda19988_register_write(priv, REG_PLL_SCG1, 0x00); + tda19988_register_write(priv, REG_AUDIO_DIV, AUDIO_DIV_SERCLK_8); + tda19988_register_write(priv, REG_SEL_CLK, + SEL_CLK_SEL_CLK1 | SEL_CLK_ENA_SC_CLK); + tda19988_register_write(priv, REG_PLL_SCGN1, 0xfa); + tda19988_register_write(priv, REG_PLL_SCGN2, 0x00); + tda19988_register_write(priv, REG_PLL_SCGR1, 0x5b); + tda19988_register_write(priv, REG_PLL_SCGR2, 0x00); + tda19988_register_write(priv, REG_PLL_SCG2, 0x10); + + /* Write the default value MUX register */ + tda19988_register_write(priv, REG_MUX_VP_VIP_OUT, 0x24); + + /* read version */ + rev_lo = dm_i2c_reg_read(priv->chip, REG_VERSION_LSB); + rev_hi = dm_i2c_reg_read(priv->chip, REG_VERSION_MSB); + + /* mask off feature bits */ + priv->revision = ((rev_hi << 8) | rev_lo) & ~0x30; + + printf("HDMI: "); + switch (priv->revision) { + case TDA9989N2: + printf("TDA9989 n2\n"); + break; + case TDA19989: + printf("TDA19989\n"); + break; + case TDA19989N2: + printf("TDA19989 n2\n"); + break; + case TDA19988: + printf("TDA19988\n"); + break; + default: + printf("unknown TDA device: 0x%04x\n", priv->revision); + return -ENXIO; + } + + /* after reset, enable DDC */ + tda19988_register_write(priv, REG_DDC_DISABLE, 0x00); + + /* set clock on DDC channel */ + tda19988_register_write(priv, REG_TX3, 39); + + /* if necessary, disable multi-master */ + if (priv->revision == TDA19989) + tda19988_register_set(priv, REG_I2C_MASTER, I2C_MASTER_DIS_MM); + + dm_i2c_reg_write(priv->cec_chip, REG_CEC_FRO_IM_CLK_CTRL, + CEC_FRO_IM_CLK_CTRL_GHOST_DIS | + CEC_FRO_IM_CLK_CTRL_IMCLK_SEL); + /* ensure interrupts are disabled */ + dm_i2c_reg_write(priv->cec_chip, REG_CEC_RXSHPDINTENA, 0); + /* clear pending interrupts */ + dm_i2c_reg_read(priv->cec_chip, REG_CEC_RXSHPDINT); + tda19988_register_read(priv, REG_INT_FLAGS_0); + tda19988_register_read(priv, REG_INT_FLAGS_1); + tda19988_register_read(priv, REG_INT_FLAGS_2); + + /* enable EDID read irq */ + tda19988_register_set(priv, REG_INT_FLAGS_2, INT_FLAGS_2_EDID_BLK_RD); + + return 0; +} + +U_BOOT_DRIVER(tda19988) = { + .name = "tda19988", + .id = UCLASS_DISPLAY, + .of_match = tda19988_ids, + .ops = &tda19988_ops, + .probe = tda19988_probe, + .priv_auto_alloc_size = sizeof(struct tda19988_priv), +};
On Fri, 28 Sep 2018 13:49:31 +0100 Liviu Dudau Liviu.Dudau@foss.arm.com wrote:
Changelog:
Applied to u-boot-video/master, thanks!
-- Anatolij
Anatolij Gustschin
Liviu Dudau
