[U-Boot-Users] [PATCH] [new uImage] rework error handling so common functions don't reset
Changed image_get_ramdisk() to just return NULL on error and have get_ramdisk() propogate that error to the caller. It's left to the caller to call do_reset() if it wants to.
Also moved calling do_reset() in get_fdt() on ppc to a common location. In the future we will change get_fdt() to return success/failure and not call do_reset() at all.
Signed-off-by: Kumar Gala galak@kernel.crashing.org ---
This is against the new-image branch of u-boot-testing
common/image.c | 25 ++++++++++++++++--------- include/image.h | 2 +- lib_m68k/bootm.c | 15 +++++++++++++-- lib_ppc/bootm.c | 46 +++++++++++++++++++++++++++++----------------- 4 files changed, 59 insertions(+), 29 deletions(-)
diff --git a/common/image.c b/common/image.c index 46cecef..0a74083 100644 --- a/common/image.c +++ b/common/image.c @@ -41,8 +41,6 @@ #include <logbuff.h> #endif
-extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); - #ifdef CONFIG_CMD_BDI extern int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); #endif @@ -324,7 +322,7 @@ const char* image_get_comp_name (uint8_t comp) * * returns: * pointer to a ramdisk image header, if image was found and valid - * otherwise, board is reset + * otherwise, return NULL */ image_header_t* image_get_ramdisk (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], @@ -348,13 +346,13 @@ image_header_t* image_get_ramdisk (cmd_tbl_t *cmdtp, int flag, if (!image_check_magic (rd_hdr)) { puts ("Bad Magic Number\n"); show_boot_progress (-10); - do_reset (cmdtp, flag, argc, argv); + return NULL; }
if (!image_check_hcrc (rd_hdr)) { puts ("Bad Header Checksum\n"); show_boot_progress (-11); - do_reset (cmdtp, flag, argc, argv); + return NULL; }
show_boot_progress (10); @@ -377,7 +375,7 @@ image_header_t* image_get_ramdisk (cmd_tbl_t *cmdtp, int flag, if (!image_check_dcrc_wd (rd_hdr, CHUNKSZ)) { puts ("Bad Data CRC\n"); show_boot_progress (-12); - do_reset (cmdtp, flag, argc, argv); + return NULL; } puts("OK\n"); } @@ -390,7 +388,7 @@ image_header_t* image_get_ramdisk (cmd_tbl_t *cmdtp, int flag, printf ("No Linux %s Ramdisk Image\n", image_get_arch_name(arch)); show_boot_progress (-13); - do_reset (cmdtp, flag, argc, argv); + return NULL; }
return rd_hdr; @@ -417,9 +415,10 @@ image_header_t* image_get_ramdisk (cmd_tbl_t *cmdtp, int flag, * rd_start and rd_end are set to ramdisk start/end addresses if * ramdisk image is found and valid * rd_start and rd_end are set to 0 if no ramdisk exists - * board is reset if ramdisk image is found but corrupted + * return 1 if ramdisk image is found but corrupted + * */ -void get_ramdisk (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], +int get_ramdisk (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], image_header_t *hdr, int verify, uint8_t arch, ulong *rd_start, ulong *rd_end) { @@ -447,6 +446,12 @@ void get_ramdisk (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], rd_hdr = image_get_ramdisk (cmdtp, flag, argc, argv, rd_addr, arch, verify);
+ if (rd_hdr == NULL) { + *rd_start = 0; + *rd_end = 0; + return 1; + } + rd_data = image_get_data (rd_hdr); rd_len = image_get_data_size (rd_hdr);
@@ -488,6 +493,8 @@ void get_ramdisk (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], } debug (" ramdisk start = 0x%08lx, ramdisk end = 0x%08lx\n", *rd_start, *rd_end); + + return 0; }
#if defined(CONFIG_PPC) || defined(CONFIG_M68K) diff --git a/include/image.h b/include/image.h index a67489e..d35b476 100644 --- a/include/image.h +++ b/include/image.h @@ -338,7 +338,7 @@ image_header_t* image_get_ramdisk (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], ulong rd_addr, uint8_t arch, int verify);
-void get_ramdisk (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], +int get_ramdisk (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], image_header_t *hdr, int verify, uint8_t arch, ulong *rd_start, ulong *rd_end);
diff --git a/lib_m68k/bootm.c b/lib_m68k/bootm.c index da76844..9a98b83 100644 --- a/lib_m68k/bootm.c +++ b/lib_m68k/bootm.c @@ -35,6 +35,8 @@
DECLARE_GLOBAL_DATA_PTR;
+extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); + #define PHYSADDR(x) x
#define LINUX_MAX_ENVS 256 @@ -51,6 +53,7 @@ void do_bootm_linux(cmd_tbl_t * cmdtp, int flag,
ulong rd_data_start, rd_data_end, rd_len; ulong initrd_start, initrd_end; + int ret;
ulong cmd_start, cmd_end; bd_t *kbd; @@ -83,8 +86,11 @@ void do_bootm_linux(cmd_tbl_t * cmdtp, int flag, (void (*)(bd_t *, ulong, ulong, ulong, ulong))image_get_ep (hdr);
/* find ramdisk */ - get_ramdisk (cmdtp, flag, argc, argv, hdr, verify, - IH_ARCH_M68K, &rd_data_start, &rd_data_end); + ret = get_ramdisk (cmdtp, flag, argc, argv, hdr, verify, + IH_ARCH_M68K, &rd_data_start, &rd_data_end); + + if (ret) + goto error;
rd_len = rd_data_end - rd_data_start; alloc_current = ramdisk_high (alloc_current, rd_data_start, rd_len, @@ -105,6 +111,11 @@ void do_bootm_linux(cmd_tbl_t * cmdtp, int flag, */ (*kernel) (kbd, initrd_start, initrd_end, cmd_start, cmd_end); /* does not return */ + return ; + +error: + do_reset (cmdtp, flag, argc, argv); + return ; }
static ulong get_sp (void) diff --git a/lib_ppc/bootm.c b/lib_ppc/bootm.c index 99d32eb..ec98e1b 100644 --- a/lib_ppc/bootm.c +++ b/lib_ppc/bootm.c @@ -75,7 +75,7 @@ do_bootm_linux(cmd_tbl_t *cmdtp, int flag, int has_of = 0;
#if defined(CONFIG_OF_LIBFDT) - char *of_flat_tree; + char *of_flat_tree = NULL;
/* determine if we are booting w/of */ if (argc > 3) @@ -117,8 +117,11 @@ do_bootm_linux(cmd_tbl_t *cmdtp, int flag, kernel = (void (*)(bd_t *, ulong, ulong, ulong, ulong))image_get_ep (hdr);
/* find ramdisk */ - get_ramdisk (cmdtp, flag, argc, argv, hdr, verify, - IH_ARCH_PPC, &rd_data_start, &rd_data_end); + ret = get_ramdisk (cmdtp, flag, argc, argv, hdr, verify, + IH_ARCH_PPC, &rd_data_start, &rd_data_end); + + if (ret) + goto error;
@@ -135,18 +138,18 @@ do_bootm_linux(cmd_tbl_t *cmdtp, int flag, /* pass in dummy initrd info, we'll fix up later */ if (fdt_chosen(of_flat_tree, rd_data_start, rd_data_end, 0) < 0) { fdt_error ("/chosen node create failed"); - do_reset (cmdtp, flag, argc, argv); + goto error; } #ifdef CONFIG_OF_HAS_UBOOT_ENV if (fdt_env(of_flat_tree) < 0) { fdt_error ("/u-boot-env node create failed"); - do_reset (cmdtp, flag, argc, argv); + goto error; } #endif #ifdef CONFIG_OF_HAS_BD_T if (fdt_bd_t(of_flat_tree) < 0) { fdt_error ("/bd_t node create failed"); - do_reset (cmdtp, flag, argc, argv); + goto error; } #endif #ifdef CONFIG_OF_BOARD_SETUP @@ -179,7 +182,7 @@ do_bootm_linux(cmd_tbl_t *cmdtp, int flag, initrd_end - initrd_start + 1); if (ret < 0) { printf("fdt_chosen: %s\n", fdt_strerror(ret)); - do_reset (cmdtp, flag, argc, argv); + goto error; }
do_fixup_by_path_u32(of_flat_tree, "/chosen", @@ -221,6 +224,11 @@ do_bootm_linux(cmd_tbl_t *cmdtp, int flag, */ (*kernel) (kbd, initrd_start, initrd_end, cmd_start, cmd_end); /* does not return */ + return ; + +error: + do_reset (cmdtp, flag, argc, argv); + return ; }
static ulong get_sp (void) @@ -304,32 +312,32 @@ static ulong get_fdt (ulong alloc_current,
if ((load_start < image_end) && (load_end > image_start)) { fdt_error ("fdt overwritten"); - do_reset (cmdtp, flag, argc, argv); + goto error; }
puts (" Verifying Checksum ... "); if (!image_check_hcrc (fdt_hdr)) { fdt_error ("fdt header checksum invalid"); - do_reset (cmdtp, flag, argc, argv); + goto error; }
if (!image_check_dcrc (fdt_hdr)) { fdt_error ("fdt checksum invalid"); - do_reset (cmdtp, flag, argc, argv); + goto error; } puts ("OK\n");
if (!image_check_type (fdt_hdr, IH_TYPE_FLATDT)) { fdt_error ("uImage is not a fdt"); - do_reset (cmdtp, flag, argc, argv); + goto error; } if (image_get_comp (fdt_hdr) != IH_COMP_NONE) { fdt_error ("uImage is compressed"); - do_reset (cmdtp, flag, argc, argv); + goto error; } if (fdt_check_header ((char *)image_get_data (fdt_hdr)) != 0) { fdt_error ("uImage data is not a fdt"); - do_reset (cmdtp, flag, argc, argv); + goto error; }
memmove ((void *)image_get_load (fdt_hdr), @@ -339,7 +347,7 @@ static ulong get_fdt (ulong alloc_current, fdt = (char *)image_get_load (fdt_hdr); } else { fdt_error ("Did not find a Flattened Device Tree"); - do_reset (cmdtp, flag, argc, argv); + goto error; } printf (" Booting using the fdt at 0x%x\n", fdt); @@ -363,12 +371,12 @@ static ulong get_fdt (ulong alloc_current,
if (fdt_check_header (fdt) != 0) { fdt_error ("image is not a fdt"); - do_reset (cmdtp, flag, argc, argv); + goto error; }
if (be32_to_cpu (fdt_totalsize (fdt)) != fdt_len) { fdt_error ("fdt size != image size"); - do_reset (cmdtp, flag, argc, argv); + goto error; } } else { debug (" Did not find a Flattened Device Tree"); @@ -405,7 +413,7 @@ static ulong get_fdt (ulong alloc_current, err = fdt_open_into (fdt, (void *)of_start, of_len); if (err != 0) { fdt_error ("fdt move failed"); - do_reset (cmdtp, flag, argc, argv); + goto error; } puts ("OK\n");
@@ -417,5 +425,9 @@ static ulong get_fdt (ulong alloc_current, }
return new_alloc_current; + +error: + do_reset (cmdtp, flag, argc, argv); + return 1; } #endif
Dear Kumar,
in message Pine.LNX.4.64.0802181306060.21964@blarg.am.freescale.net you wrote:
Just to make my position clear: I expect that you negotiate new-image related patches more or less directly with Bartek, who I consider as kind of "new-image" custodian.
That means that I will not track the state of these patches - if you want me to apply something directly, please ring a bell.
Bartek: I would also appreciate if you could merge Kumar's patches in a local repo and then send me just a pull request when something is ready to go into u-boot-testing (or even into mainline).
Thanks!
Wolfgang Denk wrote:
Dear Kumar,
OK, will coordinate new uImage stuff that gets posted to the list, and request pulling as needed.
Regards, Bartlomiej
Dear Kumar, in message <Pine.LNX. 4.64.0802181306060.21964@blarg.am.freescale.net> you wrote:
Just to make my position clear: I expect that you negotiate new-image related patches more or less directly with Bartek, who I consider as kind of "new-image" custodian. That means that I will not track the state of these patches - if you want me to apply something directly, please ring a bell. Bartek: I would also appreciate if you could merge Kumar's patches in a local repo and then send me just a pull request when something is ready to go into u-boot-testing (or even into mainline).
Works for me. I'll look at updating my patches based on the new code in the branch.
- k
Bartlomiej Sieka
Kumar Gala
