[U-Boot] Kirkwood: no console messages from init_sequence?
I rebased my dockstar patches on master, after the recent ARM relocation support for kirkwood had been merged.
I no longer see any of the early console messages that should result from display_banner, print_cpuinfo, etc. The first thing I see is the NAND information:
Marvell>> reset resetting ... NAND: 256 MiB In: serial Out: serial Err: serial Net: egiga0 [...]
(I see the same behavior on a cold start, not just a reset.) Can someone with another kirkwood board please check whether they see this behavior also, or did I somehow break something when I rebased? Thanks.
On Sun, Oct 17, 2010 at 08:40:31PM -0400, Eric Cooper wrote:
I no longer see any of the early console messages that should result from display_banner, print_cpuinfo, etc. The first thing I see is the NAND information: [...]
But if I load the same u-boot image into memory and execute it with "go", I see the entire banner, DRAM message, etc. So the problem only occurs when it is booting from NAND flash.
Dear Eric Cooper,
Looks to me like the console does not get initialized early or that the console driver does not work before relocation. Check for possible static data usage in the driver.
Best Regards Reinhard
Dear Eric Cooper,
the
static
The init_sequence is the first variable to hold initialized static data, possibly its pointers are wrong even before relocation. Will be if your link address!=load address
Eric Cooper
Joakim Tjernlund
Reinhard Meyer
