[U-Boot] [PATCH] build system: treat all Darwin's alike
The x86 based version of Darwin behaves the same quirky way as the powerpc Darwin, so only check HOSTOS when setting up Darwin workarounds.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- config.mk | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/config.mk b/config.mk index d770f09..b1254e9 100644 --- a/config.mk +++ b/config.mk @@ -46,7 +46,7 @@ PLATFORM_LDFLAGS =
-ifeq ($(HOSTOS)-$(HOSTARCH),darwin-ppc) +ifeq ($(HOSTOS),darwin) HOSTCC = cc else HOSTCC = gcc @@ -181,7 +181,7 @@ endif # # So far, this is used only by tools/gdb/Makefile.
-ifeq ($(HOSTOS)-$(HOSTARCH),darwin-ppc) +ifeq ($(HOSTOS),darwin) BFD_ROOT_DIR = /usr/local/tools else ifeq ($(HOSTARCH),$(ARCH))
could more specific about which Darwin?
I use MacOS for years and I gcc installed since MacOS X at min
Best Regards, J.
considering there are only two arches Darwin supports and i suggest we stop requiring ppc, that kind of narrows it down ... -mike
Dear Mike Frysinger,
Applied, thanks.
Mike Frysinger
