[PATCH 1/2] clk: cdce9xx: Convert .of_xlate to .request
This xlate function just performs some checking. We can do this in request() instead and use the default xlate.
Signed-off-by: Sean Anderson seanga2@gmail.com ---
drivers/clk/clk-cdce9xx.c | 12 +++--------- 1 file changed, 3 insertions(+), 9 deletions(-)
diff --git a/drivers/clk/clk-cdce9xx.c b/drivers/clk/clk-cdce9xx.c index 6634b7b799..c15e9f210e 100644 --- a/drivers/clk/clk-cdce9xx.c +++ b/drivers/clk/clk-cdce9xx.c @@ -86,19 +86,13 @@ static int cdce9xx_reg_write(struct udevice *dev, u8 addr, u8 val) return ret; }
-static int cdce9xx_clk_of_xlate(struct clk *clk, - struct ofnode_phandle_args *args) +static int cdce9xx_clk_of_request(struct clk *clk) { struct cdce9xx_clk_data *data = dev_get_priv(clk->dev);
- if (args->args_count != 1) + if (clk->id > data->chip->num_outputs) return -EINVAL;
- if (args->args[0] > data->chip->num_outputs) - return -EINVAL; - - clk->id = args->args[0]; - return 0; }
@@ -241,7 +235,7 @@ static const struct udevice_id cdce9xx_clk_of_match[] = { };
static const struct clk_ops cdce9xx_clk_ops = { - .of_xlate = cdce9xx_clk_of_xlate, + .request = cdce9xx_clk_request, .get_rate = cdce9xx_clk_get_rate, .set_rate = cdce9xx_clk_set_rate, };
This adds an entry in MAINTAINERS for the cdce9xx driver, since it was not added when the driver was submitted.
Signed-off-by: Sean Anderson seanga2@gmail.com --- Tero, if you don't want to maintain this I'll resubmit this patch with the orphaned status. Alternatively, perhaps Tom wants to maintain this driver since it is used exclusively by boards he maintains.
MAINTAINERS | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index 6db5354322..2946a96c04 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -658,6 +658,12 @@ M: Simon Glass sjg@chromium.org S: Maintained F: tools/buildman/
+CDCE9XX CLOCK: +M: Tero Kristo t-kristo@ti.com +S: Maintained +F: doc/device-tree-bindings/clock/ti,cdce9xx.txt +F: drivers/clk/clk-cdce9xx.c + CFI FLASH M: Stefan Roese sr@denx.de S: Maintained
Well, it looks like Tero's email bounced, so it will have to be either Tom or orphaned.
--Sean
- if (clk->id > data->chip->num_outputs) return -EINVAL;
return -EINVAL;
- .request = cdce9xx_clk_request, .get_rate = cdce9xx_clk_get_rate, .set_rate = cdce9xx_clk_set_rate,
Adding Tero...
return -EINVAL;
- return 0; }
- .request = cdce9xx_clk_request, .get_rate = cdce9xx_clk_get_rate, .set_rate = cdce9xx_clk_set_rate, };
Adding Tero...
Thanks. Perhaps .mailmap should be updated?
--Sean
Hi Sean,
Did you compile this? I see...
diff --git a/drivers/clk/clk-cdce9xx.c b/drivers/clk/clk-cdce9xx.c index 6634b7b799..c15e9f210e 100644 --- a/drivers/clk/clk-cdce9xx.c +++ b/drivers/clk/clk-cdce9xx.c @@ -86,19 +86,13 @@ static int cdce9xx_reg_write(struct udevice *dev, u8 addr, u8 val) return ret; } -static int cdce9xx_clk_of_xlate(struct clk *clk, - struct ofnode_phandle_args *args) +static int cdce9xx_clk_of_request(struct clk *clk)
cdce9xx_clk_of_request here...
{ struct cdce9xx_clk_data *data = dev_get_priv(clk->dev); - if (args->args_count != 1) + if (clk->id > data->chip->num_outputs) return -EINVAL; - if (args->args[0] > data->chip->num_outputs) - return -EINVAL;
return 0; } @@ -241,7 +235,7 @@ static const struct udevice_id cdce9xx_clk_of_match[] = { }; static const struct clk_ops cdce9xx_clk_ops = { - .of_xlate = cdce9xx_clk_of_xlate, + .request = cdce9xx_clk_request,
but cdce9xx_clk_request here.
Other than that, looks fine to me.
-Tero
Adding Tero...
--Sean
Hi Sean,
Oops. Thanks for catching that.
Resubmitted after compile-testing :)
--Sean
Sean Anderson
Tero Kristo
