[U-Boot] [PATCH v4] arm: add initial support for the Phytium Durian Board
This adds platform code and the device tree for the Phytium Durian Board. The initial support comprises the UART the GMAC and the PCIE.
Cc: Bin Meng bmeng.cn@gmail.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Tom Rini trini@konsulko.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de
Signed-off-by: Steven Hao liuhao@phytium.com.cn --- Changes for v4: - Drop the changelog from the commit message, and put it after that. @Bin Meng - Change __FT_2004_CONFIG_H__ to __DURIAN_CONFIG_H__ in include/configs/durian.h file.
Changes for v3: - Change the board name from ft2004 to durian. The dts does not on mainline Kernel. @ Kever Yang - Add pcie driver and boot kernel from scsi-pci card. Add README about durian board. The system initialization is worked in BPF that we do not want to open source. But the hex file can be gitted referring to the board README. @Tom
Changes for v2: - Some printf() are removed or replaced by debug(). @Tom - The ft2004_defconfig file is generated with savedefconfig. @Tom, @Heinrich --- MAINTAINERS | 7 ++ arch/arm/Kconfig | 8 ++ arch/arm/dts/Makefile | 2 + arch/arm/dts/phytium-durian.dts | 45 +++++++++ board/phytium/durian/Kconfig | 12 +++ board/phytium/durian/MAINTAINERS | 8 ++ board/phytium/durian/Makefile | 9 ++ board/phytium/durian/README | 65 +++++++++++++ board/phytium/durian/cpu.h | 23 +++++ board/phytium/durian/durian.c | 110 +++++++++++++++++++++ configs/durian_defconfig | 36 +++++++ drivers/pci/Kconfig | 7 ++ drivers/pci/Makefile | 1 + drivers/pci/pcie_phytium.c | 200 +++++++++++++++++++++++++++++++++++++++ include/configs/durian.h | 44 +++++++++ 15 files changed, 577 insertions(+) create mode 100644 arch/arm/dts/phytium-durian.dts create mode 100644 board/phytium/durian/Kconfig create mode 100644 board/phytium/durian/MAINTAINERS create mode 100644 board/phytium/durian/Makefile create mode 100644 board/phytium/durian/README create mode 100644 board/phytium/durian/cpu.h create mode 100644 board/phytium/durian/durian.c create mode 100644 configs/durian_defconfig create mode 100644 drivers/pci/pcie_phytium.c create mode 100644 include/configs/durian.h
diff --git a/MAINTAINERS b/MAINTAINERS index a7c355c..a49e274 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -473,6 +473,13 @@ S: Maintained T: git https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze.git F: arch/arm/mach-zynqmp-r5/
+ARM PHYTIUM +M: liuhao liuhao@phytium.com.cn +M: shuyiqi shuyiqi@phytium.com.cn +S: Maintained +F: drivers/pci/pcie_phytium.c +F: arch/arm/dts/phytium-durian.dts + BINMAN M: Simon Glass sjg@chromium.org S: Maintained diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 75041ce..fcd3018 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1632,6 +1632,13 @@ config ARCH_ASPEED select OF_CONTROL imply CMD_DM
+config TARGET_DURIAN + bool "Support Phytium Durian Platform" + select ARM64 + help + Support for durian platform. + It has 2GB Sdram, uart, gmac and pcie. + endchoice
config ARCH_SUPPORT_TFABOOT @@ -1831,6 +1838,7 @@ source "board/woodburn/Kconfig" source "board/xilinx/Kconfig" source "board/xilinx/zynq/Kconfig" source "board/xilinx/zynqmp/Kconfig" +source "board/phytium/durian/Kconfig"
source "arch/arm/Kconfig.debug"
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 3b8dc2f..e3bdbc6 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -824,6 +824,8 @@ dtb-$(CONFIG_TARGET_VEXPRESS_CA5X2) += vexpress-v2p-ca5s.dtb dtb-$(CONFIG_TARGET_VEXPRESS_CA9X4) += vexpress-v2p-ca9.dtb dtb-$(CONFIG_TARGET_VEXPRESS_CA15_TC2) += vexpress-v2p-ca15_a7.dtb
+dtb-$(CONFIG_TARGET_DURIAN) += phytium-durian.dtb + targets += $(dtb-y)
# Add any required device tree compiler flags here diff --git a/arch/arm/dts/phytium-durian.dts b/arch/arm/dts/phytium-durian.dts new file mode 100644 index 0000000..811d50b --- /dev/null +++ b/arch/arm/dts/phytium-durian.dts @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019, Phytium Ltd. + * shuyiqi shuyiqi@phytium.com.cn + */ + +/dts-v1/; + +/ { + model = "Phytium Durian"; + compatible = "phytium,durian"; + #address-cells = <2>; + #size-cells = <2>; + + pcie-controller@40000000 { + compatible = "phytium,pcie-host-1.0"; + device_type = "pci"; + #address-cells = <3>; + #size-cells = <2>; + reg = <0x0 0x40000000 0x0 0x10000000>; + bus-range = <0x0 0xff>; + ranges = <0x1000000 0x0 0x0 0x0 0x50000000 0x0 0xF00000>, + <0x2000000 0x0 0x58000000 0x0 0x58000000 0x0 0x28000000>, + <0x43000000 0x10 0x00000000 0x10 0x00000000 0x10 0x00000000>; + }; + + ethernet@2820c000 { + compatible = "st,stm32-dwmac"; + reg = <0x0 0x2820C000 0x0 0x2000>; + phy-mode = "rgmii"; + }; + + ethernet@28210000 { + compatible = "st,stm32-dwmac"; + reg = <0x0 0x28210000 0x0 0x2000>; + phy-mode = "rgmii"; + }; + + uart@28001000 { + compatible = "arm,pl011"; + reg = <0x0 0x28001000 0x0 0x1000>; + clock = <48000000>; + }; +}; + diff --git a/board/phytium/durian/Kconfig b/board/phytium/durian/Kconfig new file mode 100644 index 0000000..dc07109 --- /dev/null +++ b/board/phytium/durian/Kconfig @@ -0,0 +1,12 @@ +if TARGET_DURIAN + +config SYS_BOARD + default "durian" + +config SYS_VENDOR + default "phytium" + +config SYS_CONFIG_NAME + default "durian" + +endif diff --git a/board/phytium/durian/MAINTAINERS b/board/phytium/durian/MAINTAINERS new file mode 100644 index 0000000..895b762 --- /dev/null +++ b/board/phytium/durian/MAINTAINERS @@ -0,0 +1,8 @@ +DURIAN BOARD +M: liuhao liuhao@phytium.com.cn +M: shuyiqi shuyiqi@phytium.com.cn +S: Maintained +F: board/phytium/durian/* +F: include/configs/durian.h +F: configs/durian_defconfig + diff --git a/board/phytium/durian/Makefile b/board/phytium/durian/Makefile new file mode 100644 index 0000000..c2fbf19 --- /dev/null +++ b/board/phytium/durian/Makefile @@ -0,0 +1,9 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2019 +# shuyiqi shuyiqi@phytium.com.cn +# liuhao liuhao@phytium.com.cn +# + +obj-y += durian.o + diff --git a/board/phytium/durian/README b/board/phytium/durian/README new file mode 100644 index 0000000..26439d2 --- /dev/null +++ b/board/phytium/durian/README @@ -0,0 +1,65 @@ +Here is the step-by-step to boot U-Boot on phytium durian board. + +Compile U-Boot +============== + > make durian_defconfig + > make + +Get the prebuild binary about BPF +================================= + > cd ../ + > git clone https://github.com/phytium-durian/bpf.git + +Package the image +================= + > cd bpf + > cp ../u-boot/u-boot.bin ./ + > ./dopack + + The fip-all.bin is the final image. + +Flash the image into the spi nor-flash using em100 +================================================== + > cd ../ + > git clone https://github.com/phytium-durian/em100.git + > cd em100 + > cp ../bpf/fip-all.bin ./ + > ./flash + +Reset the board, you can get U-Boot log message from boot console: + +Power on... +Start pcie setup! +End pcie setup! +Start ddr setup! +End ddr setup! +Jump to entrypoint: 0x500000 + +U-Boot 2019.10-00594-g9ccc1b17ea-dirty (Oct 18 2019 - 00:17:09 +0800) + +DRAM: 1.9 GiB +In: uart@28001000 +Out: uart@28001000 +Err: uart@28001000 +Net: +Warning: ethernet@2820c000 (eth0) using random MAC address - 4e:28:bc:50:f6:05 +eth0: ethernet@2820c000Could not get PHY for ethernet@28210000: addr -1 +, eth-1: ethernet@28210000 +scanning bus for devices... +Target spinup took 0 ms. +SATA link 1 timeout. +SATA link 2 timeout. +SATA link 3 timeout. +AHCI 0001.0000 32 slots 4 ports 6 Gbps 0xf impl SATA mode +flags: 64bit ncq led only pmp fbss pio slum part sxs + Device 0: (0:0) Vendor: ATA Prod.: ST1000DM010-2EP1 Rev: CC43 + Type: Hard Disk + Capacity: 953869.7 MB = 931.5 GB (1953525168 x 512) +SATA link 0 timeout. +SATA link 1 timeout. +SATA link 2 timeout. +SATA link 3 timeout. +AHCI 0001.0000 32 slots 4 ports 6 Gbps 0xf impl SATA mode +flags: 64bit ncq led only pmp fbss pio slum part sxs +Hit any key to stop autoboot: 0 +durian# diff --git a/board/phytium/durian/cpu.h b/board/phytium/durian/cpu.h new file mode 100644 index 0000000..a5a213d --- /dev/null +++ b/board/phytium/durian/cpu.h @@ -0,0 +1,23 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2019 + * Phytium Technology Ltd <www.phytium.com> + * shuyiqi shuyiqi@phytium.com.cn + */ + +#ifndef _FT_DURIAN_H +#define _FT_DURIAN_H + +/* FLUSH L3 CASHE */ +#define HNF_COUNT 0x8 +#define HNF_PSTATE_REQ (HNF_BASE + 0x10) +#define HNF_PSTATE_STAT (HNF_BASE + 0x18) +#define HNF_PSTATE_OFF 0x0 +#define HNF_PSTATE_SFONLY 0x1 +#define HNF_PSTATE_HALF 0x2 +#define HNF_PSTATE_FULL 0x3 +#define HNF_STRIDE 0x10000 +#define HNF_BASE (unsigned long)(0x3A200000) + +#endif /* _FT_DURIAN_H */ + diff --git a/board/phytium/durian/durian.c b/board/phytium/durian/durian.c new file mode 100644 index 0000000..59f307d --- /dev/null +++ b/board/phytium/durian/durian.c @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 + * shuyiqi shuyiqi@phytium.com.cn + * liuhao liuhao@phytium.com.cn + */ + +#include <common.h> +#include <asm/armv8/mmu.h> +#include <asm/system.h> +#include <asm/io.h> +#include <linux/arm-smccc.h> +#include <linux/kernel.h> +#include <scsi.h> +#include "cpu.h" + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + gd->mem_clk = 0; + gd->ram_size = PHYS_SDRAM_1_SIZE; + return 0; +} + +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} + +int board_init(void) +{ + return 0; +} + +void reset_cpu(ulong addr) +{ + struct arm_smccc_res res; + + arm_smccc_smc(0x84000009, 0, 0, 0, 0, 0, 0, 0, &res); + debug("reset cpu error, %lx\n", res.a0); +} + +static struct mm_region durian_mem_map[] = { + { + .virt = 0x0UL, + .phys = 0x0UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | + PTE_BLOCK_UXN + }, + { + .virt = (u64)PHYS_SDRAM_1, + .phys = (u64)PHYS_SDRAM_1, + .size = (u64)PHYS_SDRAM_1_SIZE, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_NS | + PTE_BLOCK_INNER_SHARE + }, + { + 0, + } +}; + +struct mm_region *mem_map = durian_mem_map; + +int print_cpuinfo(void) +{ + printf("CPU: Phytium ft2004 %ld MHz\n", gd->cpu_clk); + return 0; +} + +int __asm_flush_l3_dcache(void) +{ + int i, pstate; + + for (i = 0; i < HNF_COUNT; i++) + writeq(HNF_PSTATE_SFONLY, HNF_PSTATE_REQ + i * HNF_STRIDE); + for (i = 0; i < HNF_COUNT; i++) { + do { + pstate = readq(HNF_PSTATE_STAT + i * HNF_STRIDE); + } while ((pstate & 0xf) != (HNF_PSTATE_SFONLY << 2)); + } + + for (i = 0; i < HNF_COUNT; i++) + writeq(HNF_PSTATE_FULL, HNF_PSTATE_REQ + i * HNF_STRIDE); + + return 0; +} + +int last_stage_init(void) +{ + int ret; + + /* pci e */ + pci_init(); + /* scsi scan */ + ret = scsi_scan(true); + if (ret) { + printf("scsi scan failed\n"); + return CMD_RET_FAILURE; + } + return ret; +} + diff --git a/configs/durian_defconfig b/configs/durian_defconfig new file mode 100644 index 0000000..a85b9a8 --- /dev/null +++ b/configs/durian_defconfig @@ -0,0 +1,36 @@ +CONFIG_ARM=y +CONFIG_ARM_SMCCC=y +CONFIG_TARGET_DURIAN=y +CONFIG_SYS_TEXT_BASE=0x500000 +CONFIG_NR_DRAM_BANKS=1 +# CONFIG_PSCI_RESET is not set +CONFIG_AHCI=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 earlycon=pl011,0x28001000 root=/dev/sda2 rw" +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_LAST_STAGE_INIT=y +CONFIG_SYS_PROMPT="durian#" +# CONFIG_CMD_LZMADEC is not set +# CONFIG_CMD_UNZIP is not set +CONFIG_CMD_PCI=y +CONFIG_CMD_TFTPPUT=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="phytium-durian" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SCSI_AHCI=y +CONFIG_AHCI_PCI=y +CONFIG_BLK=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCI_PHYTIUM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_PL01X_SERIAL=y diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 19e7b50..bfc7f6c 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -51,6 +51,13 @@ config PCIE_ECAM_GENERIC Say Y here if you want to enable support for generic ECAM-based PCIe host controllers, such as the one emulated by QEMU.
+config PCI_PHYTIUM + bool "Phytium PCIe support" + depends on DM_PCI + help + Say Y here if you want to enable PCIe controller support on + Phytium SoCs. + config PCIE_DW_MVEBU bool "Enable Armada-8K PCIe driver (DesignWare core)" depends on DM_PCI diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index b1d3dc8..ba2aa4b 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -37,6 +37,7 @@ obj-$(CONFIG_PCIE_LAYERSCAPE) += pcie_layerscape_fixup.o obj-$(CONFIG_PCIE_LAYERSCAPE_GEN4) += pcie_layerscape_gen4.o \ pcie_layerscape_gen4_fixup.o obj-$(CONFIG_PCI_XILINX) += pcie_xilinx.o +obj-$(CONFIG_PCI_PHYTIUM) += pcie_phytium.o obj-$(CONFIG_PCIE_INTEL_FPGA) += pcie_intel_fpga.o obj-$(CONFIG_PCI_KEYSTONE) += pcie_dw_ti.o obj-$(CONFIG_PCIE_MEDIATEK) += pcie_mediatek.o diff --git a/drivers/pci/pcie_phytium.c b/drivers/pci/pcie_phytium.c new file mode 100644 index 0000000..92e281e --- /dev/null +++ b/drivers/pci/pcie_phytium.c @@ -0,0 +1,200 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Phytium PCIE host driver + * + * Heavily based on drivers/pci/pcie_xilinx.c + * + * Copyright (C) 2019 + */ + +#include <common.h> +#include <dm.h> +#include <pci.h> +#include <asm/io.h> + +/** + * struct phytium_pcie - phytium PCIe controller state + * @cfg_base: The base address of memory mapped configuration space + */ +struct phytium_pcie { + void *cfg_base; +}; + +/* + * phytium_pci_skip_dev() + * @parent: Identifies the PCIe device to access + * + * Checks whether the parent of the PCIe device is bridge + * + * Return: true if it is bridge, else false. + */ +static int phytium_pci_skip_dev(pci_dev_t parent) +{ + unsigned char pos, id; + unsigned long addr = 0x40000000; + unsigned short capreg; + unsigned char port_type; + + addr += PCI_BUS(parent) << 20; + addr += PCI_DEV(parent) << 15; + addr += PCI_FUNC(parent) << 12; + + pos = 0x34; + while (1) { + pos = readb(addr + pos); + if (pos < 0x40) + break; + pos &= ~3; + id = readb(addr + pos); + if (id == 0xff) + break; + if (id == 0x10) { + capreg = readw(addr + pos + 2); + port_type = (capreg >> 4) & 0xf; + if (port_type == 0x6 || port_type == 0x4) + return 1; + else + return 0; + } + pos += 1; + } + return 0; +} + +/** + * pci_phytium_conf_address() - Calculate the address of a config access + * @bus: Pointer to the PCI bus + * @bdf: Identifies the PCIe device to access + * @offset: The offset into the device's configuration space + * @paddress: Pointer to the pointer to write the calculates address to + * + * Calculates the address that should be accessed to perform a PCIe + * configuration space access for a given device identified by the PCIe + * controller device @pcie and the bus, device & function numbers in @bdf. If + * access to the device is not valid then the function will return an error + * code. Otherwise the address to access will be written to the pointer pointed + * to by @paddress. + */ +static int pci_phytium_conf_address(struct udevice *bus, pci_dev_t bdf, + uint offset, + void **paddress) +{ + struct phytium_pcie *pcie = dev_get_priv(bus); + void *addr; + pci_dev_t bdf_parent; + + unsigned int bus_no = PCI_BUS(bdf); + unsigned int dev_no = PCI_DEV(bdf); + + bdf_parent = PCI_BDF((bus_no - 1), 0, 0); + + addr = pcie->cfg_base; + addr += PCI_BUS(bdf) << 20; + addr += PCI_DEV(bdf) << 15; + addr += PCI_FUNC(bdf) << 12; + + if (bus_no > 0 && dev_no > 0) { + if ((readb(addr + PCI_HEADER_TYPE) & 0x7f) != + PCI_HEADER_TYPE_BRIDGE) + return -ENODEV; + if (phytium_pci_skip_dev(bdf_parent)) + return -ENODEV; + } + + addr += offset; + *paddress = addr; + + return 0; +} + +/** + * pci_phytium_read_config() - Read from configuration space + * @bus: Pointer to the PCI bus + * @bdf: Identifies the PCIe device to access + * @offset: The offset into the device's configuration space + * @valuep: A pointer at which to store the read value + * @size: Indicates the size of access to perform + * + * Read a value of size @size from offset @offset within the configuration + * space of the device identified by the bus, device & function numbers in @bdf + * on the PCI bus @bus. + */ +static int pci_phytium_read_config(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong *valuep, + enum pci_size_t size) +{ + return pci_generic_mmap_read_config(bus, pci_phytium_conf_address, + bdf, offset, valuep, size); +} + +/** + * pci_phytium_write_config() - Write to configuration space + * @bus: Pointer to the PCI bus + * @bdf: Identifies the PCIe device to access + * @offset: The offset into the device's configuration space + * @value: The value to write + * @size: Indicates the size of access to perform + * + * Write the value @value of size @size from offset @offset within the + * configuration space of the device identified by the bus, device & function + * numbers in @bdf on the PCI bus @bus. + */ +static int pci_phytium_write_config(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong value, + enum pci_size_t size) +{ + return pci_generic_mmap_write_config(bus, pci_phytium_conf_address, + bdf, offset, value, size); +} + +/** + * pci_phytium_ofdata_to_platdata() - Translate from DT to device state + * @dev: A pointer to the device being operated on + * + * Translate relevant data from the device tree pertaining to device @dev into + * state that the driver will later make use of. This state is stored in the + * device's private data structure. + * + * Return: 0 on success, else -EINVAL + */ +static int pci_phytium_ofdata_to_platdata(struct udevice *dev) +{ + struct phytium_pcie *pcie = dev_get_priv(dev); + struct fdt_resource reg_res; + + DECLARE_GLOBAL_DATA_PTR; + + int err; + + err = fdt_get_resource(gd->fdt_blob, dev_of_offset(dev), "reg", + 0, ®_res); + if (err < 0) { + pr_err(""reg" resource not found\n"); + return err; + } + + pcie->cfg_base = map_physmem(reg_res.start, + fdt_resource_size(®_res), + MAP_NOCACHE); + + return 0; +} + +static const struct dm_pci_ops pci_phytium_ops = { + .read_config = pci_phytium_read_config, + .write_config = pci_phytium_write_config, +}; + +static const struct udevice_id pci_phytium_ids[] = { + { .compatible = "phytium,pcie-host-1.0" }, + { } +}; + +U_BOOT_DRIVER(pci_phytium) = { + .name = "pci_phytium", + .id = UCLASS_PCI, + .of_match = pci_phytium_ids, + .ops = &pci_phytium_ops, + .ofdata_to_platdata = pci_phytium_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct phytium_pcie), +}; diff --git a/include/configs/durian.h b/include/configs/durian.h new file mode 100644 index 0000000..c42a98b --- /dev/null +++ b/include/configs/durian.h @@ -0,0 +1,44 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 + * shuyiqi shuyiqi@phytium.com.cn + * liuhao liuhao@phytium.com.cn + */ + +#ifndef __DURIAN_CONFIG_H__ +#define __DURIAN_CONFIG_H__ + +/* Sdram Bank #1 Address */ +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_1_SIZE 0x7B000000 +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 + +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x10000000) + +/* Size of Malloc Pool */ +#define CONFIG_ENV_SIZE 4096 +#define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024 + CONFIG_ENV_SIZE) + +#define CONFIG_SYS_INIT_SP_ADDR (0x88000000 - 0x100000) + +/* PCI CONFIG */ +#define CONFIG_SYS_PCI_64BIT 1 +#define CONFIG_PCI_SCAN_SHOW + +/* SCSI */ +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 4 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE 128 +#define CONFIG_SCSI_AHCI_PLAT +#define CONFIG_SYS_SATA_MAX_DEVICE 4 + +/* BOOT */ +#define CONFIG_SYS_BOOTM_LEN (60 * 1024 * 1024) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "load_kernel=ext4load scsi 0:1 0x90100000 uImage-2004\0" \ + "load_fdt=ext4load scsi 0:1 0x95000000 ft2004-pci-64.dtb\0"\ + "boot_fdt=bootm 0x90100000 -:- 0x95000000\0" \ + "distro_bootcmd=run load_kernel; run load_fdt; run boot_fdt" + +#endif
liu hao
