[PATCH 0/5] video: Avoid #ifdef to increase build coverage
A recent change to the video subsystem added more #ifdefs to the code but these are not necessary. In fact we can often rely on the compiler to drop dead code. Using the IS_ENABLED() macros with if() can produce the same result while reducing the number of build combinations in the code.
This series removes most #ifdefs from the core video code. Code size for wandaboard (for example) does not change.
It also includes a patch to enable 32bpp video on x86, since video is currently broken.
Simon Glass (5): video: x86: Enable 32-bit graphics by default video: Avoid using #ifdef in video blitting code video: Avoid using #ifdef in console_rotate.c video: Avoid using #ifdef in vidconsole-uclass.c video: Avoid using #ifdef in video-uclass.c
drivers/video/Kconfig | 5 +- drivers/video/console_normal.c | 125 ++++++------ drivers/video/console_rotate.c | 325 +++++++++++++++--------------- drivers/video/vidconsole-uclass.c | 22 +- drivers/video/video-uclass.c | 54 +++-- 5 files changed, 256 insertions(+), 275 deletions(-)
Most x86 boards that use video make use of 32bpp graphics. Enable this by default. This fixes missing graphics output on some x86 boards.
Also remove the unnecessary 'default n' while we are here.
drivers/video/Kconfig | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 4cde0acbf6..50ab3650ee 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -38,7 +38,6 @@ config BACKLIGHT_GPIO config VIDEO_BPP8 bool "Support 8-bit-per-pixel displays" depends on DM_VIDEO - default n help Support drawing text and bitmaps onto a 8-bit-per-pixel display. Enabling this will include code to support this display. Without @@ -48,7 +47,6 @@ config VIDEO_BPP8 config VIDEO_BPP16 bool "Support 16-bit-per-pixel displays" depends on DM_VIDEO - default n help Support drawing text and bitmaps onto a 16-bit-per-pixel display. Enabling this will include code to support this display. Without @@ -58,7 +56,7 @@ config VIDEO_BPP16 config VIDEO_BPP32 bool "Support 32-bit-per-pixel displays" depends on DM_VIDEO - default n + default y if X86 help Support drawing text and bitmaps onto a 32-bit-per-pixel display. Enabling this will include code to support this display. Without @@ -68,7 +66,6 @@ config VIDEO_BPP32 config VIDEO_ANSI bool "Support ANSI escape sequences in video console" depends on DM_VIDEO - default n help Enable ANSI escape sequence decoding for a more fully functional console.
This code does not really need to use #ifdef. We can use if() instead and gain build coverage without impacting code size.
Change the #ifdefs to use IS_ENABLED() instead.
drivers/video/console_normal.c | 125 ++++++++++++++++----------------- 1 file changed, 61 insertions(+), 64 deletions(-)
diff --git a/drivers/video/console_normal.c b/drivers/video/console_normal.c index 2f25af7332..c3f7ef8add 100644 --- a/drivers/video/console_normal.c +++ b/drivers/video/console_normal.c @@ -16,39 +16,36 @@ static int console_normal_set_row(struct udevice *dev, uint row, int clr) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); - void * __maybe_unused line; - int __maybe_unused pixels = VIDEO_FONT_HEIGHT * vid_priv->xsize; - int __maybe_unused i; + void *line; + int pixels = VIDEO_FONT_HEIGHT * vid_priv->xsize; + int i;
line = vid_priv->fb + row * VIDEO_FONT_HEIGHT * vid_priv->line_length; switch (vid_priv->bpix) { -#ifdef CONFIG_VIDEO_BPP8 - case VIDEO_BPP8: { - uint8_t *dst = line; + case VIDEO_BPP8: + if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { + uint8_t *dst = line;
- for (i = 0; i < pixels; i++) - *dst++ = clr; - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP16 - case VIDEO_BPP16: { - uint16_t *dst = line; - - for (i = 0; i < pixels; i++) - *dst++ = clr; - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP32 - case VIDEO_BPP32: { - uint32_t *dst = line; - - for (i = 0; i < pixels; i++) - *dst++ = clr; - break; - } -#endif + for (i = 0; i < pixels; i++) + *dst++ = clr; + break; + } + case VIDEO_BPP16: + if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { + uint16_t *dst = line; + + for (i = 0; i < pixels; i++) + *dst++ = clr; + break; + } + case VIDEO_BPP32: + if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { + uint32_t *dst = line; + + for (i = 0; i < pixels; i++) + *dst++ = clr; + break; + } default: return -ENOSYS; } @@ -76,7 +73,7 @@ static int console_normal_putc_xy(struct udevice *dev, uint x_frac, uint y, struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); struct udevice *vid = dev->parent; struct video_priv *vid_priv = dev_get_uclass_priv(vid); - int __maybe_unused i, row; + int i, row; void *line = vid_priv->fb + y * vid_priv->line_length + VID_TO_PIXEL(x_frac) * VNBYTES(vid_priv->bpix);
@@ -85,45 +82,45 @@ static int console_normal_putc_xy(struct udevice *dev, uint x_frac, uint y,
for (row = 0; row < VIDEO_FONT_HEIGHT; row++) { unsigned int idx = (u8)ch * VIDEO_FONT_HEIGHT + row; - uchar __maybe_unused bits = video_fontdata[idx]; + uchar bits = video_fontdata[idx];
switch (vid_priv->bpix) { -#ifdef CONFIG_VIDEO_BPP8 - case VIDEO_BPP8: { - uint8_t *dst = line; - - for (i = 0; i < VIDEO_FONT_WIDTH; i++) { - *dst++ = (bits & 0x80) ? vid_priv->colour_fg - : vid_priv->colour_bg; - bits <<= 1; + case VIDEO_BPP8: + if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { + uint8_t *dst = line; + + for (i = 0; i < VIDEO_FONT_WIDTH; i++) { + *dst++ = (bits & 0x80) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + bits <<= 1; + } + break; } - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP16 - case VIDEO_BPP16: { - uint16_t *dst = line; - - for (i = 0; i < VIDEO_FONT_WIDTH; i++) { - *dst++ = (bits & 0x80) ? vid_priv->colour_fg - : vid_priv->colour_bg; - bits <<= 1; + case VIDEO_BPP16: + if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { + uint16_t *dst = line; + + for (i = 0; i < VIDEO_FONT_WIDTH; i++) { + *dst++ = (bits & 0x80) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + bits <<= 1; + } + break; } - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP32 - case VIDEO_BPP32: { - uint32_t *dst = line; - - for (i = 0; i < VIDEO_FONT_WIDTH; i++) { - *dst++ = (bits & 0x80) ? vid_priv->colour_fg - : vid_priv->colour_bg; - bits <<= 1; + case VIDEO_BPP32: + if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { + uint32_t *dst = line; + + for (i = 0; i < VIDEO_FONT_WIDTH; i++) { + *dst++ = (bits & 0x80) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + bits <<= 1; + } + break; } - break; - } -#endif default: return -ENOSYS; }
drivers/video/console_rotate.c | 325 ++++++++++++++++----------------- 1 file changed, 158 insertions(+), 167 deletions(-)
diff --git a/drivers/video/console_rotate.c b/drivers/video/console_rotate.c index 71a5c5efba..b485255598 100644 --- a/drivers/video/console_rotate.c +++ b/drivers/video/console_rotate.c @@ -22,33 +22,30 @@ static int console_set_row_1(struct udevice *dev, uint row, int clr) (row + 1) * VIDEO_FONT_HEIGHT * pbytes; for (j = 0; j < vid_priv->ysize; j++) { switch (vid_priv->bpix) { -#ifdef CONFIG_VIDEO_BPP8 - case VIDEO_BPP8: { - uint8_t *dst = line; + case VIDEO_BPP8: + if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { + uint8_t *dst = line;
- for (i = 0; i < VIDEO_FONT_HEIGHT; i++) - *dst++ = clr; - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP16 - case VIDEO_BPP16: { - uint16_t *dst = line; + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) + *dst++ = clr; + break; + } + case VIDEO_BPP16: + if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { + uint16_t *dst = line;
- for (i = 0; i < VIDEO_FONT_HEIGHT; i++) - *dst++ = clr; - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP32 - case VIDEO_BPP32: { - uint32_t *dst = line; + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) + *dst++ = clr; + break; + } + case VIDEO_BPP32: + if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { + uint32_t *dst = line;
- for (i = 0; i < VIDEO_FONT_HEIGHT; i++) - *dst++ = clr; - break; - } -#endif + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) + *dst++ = clr; + break; + } default: return -ENOSYS; } @@ -99,39 +96,39 @@ static int console_putc_xy_1(struct udevice *dev, uint x_frac, uint y, char ch)
for (col = 0; col < VIDEO_FONT_HEIGHT; col++) { switch (vid_priv->bpix) { -#ifdef CONFIG_VIDEO_BPP8 - case VIDEO_BPP8: { - uint8_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { - *dst-- = (pfont[i] & mask) ? vid_priv->colour_fg - : vid_priv->colour_bg; + case VIDEO_BPP8: + if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { + uint8_t *dst = line; + + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { + *dst-- = (pfont[i] & mask) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + } + break; } - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP16 - case VIDEO_BPP16: { - uint16_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { - *dst-- = (pfont[i] & mask) ? vid_priv->colour_fg - : vid_priv->colour_bg; + case VIDEO_BPP16: + if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { + uint16_t *dst = line; + + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { + *dst-- = (pfont[i] & mask) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + } + break; } - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP32 - case VIDEO_BPP32: { - uint32_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { - *dst-- = (pfont[i] & mask) ? vid_priv->colour_fg - : vid_priv->colour_bg; + case VIDEO_BPP32: + if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { + uint32_t *dst = line; + + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { + *dst-- = (pfont[i] & mask) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + } + break; } - break; - } -#endif default: return -ENOSYS; } @@ -153,33 +150,30 @@ static int console_set_row_2(struct udevice *dev, uint row, int clr) line = vid_priv->fb + vid_priv->ysize * vid_priv->line_length - (row + 1) * VIDEO_FONT_HEIGHT * vid_priv->line_length; switch (vid_priv->bpix) { -#ifdef CONFIG_VIDEO_BPP8 - case VIDEO_BPP8: { - uint8_t *dst = line; + case VIDEO_BPP8: + if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { + uint8_t *dst = line;
- for (i = 0; i < pixels; i++) - *dst++ = clr; - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP16 - case VIDEO_BPP16: { - uint16_t *dst = line; - - for (i = 0; i < pixels; i++) - *dst++ = clr; - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP32 - case VIDEO_BPP32: { - uint32_t *dst = line; - - for (i = 0; i < pixels; i++) - *dst++ = clr; - break; - } -#endif + for (i = 0; i < pixels; i++) + *dst++ = clr; + break; + } + case VIDEO_BPP16: + if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { + uint16_t *dst = line; + + for (i = 0; i < pixels; i++) + *dst++ = clr; + break; + } + case VIDEO_BPP32: + if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { + uint32_t *dst = line; + + for (i = 0; i < pixels; i++) + *dst++ = clr; + break; + } default: return -ENOSYS; } @@ -226,42 +220,42 @@ static int console_putc_xy_2(struct udevice *dev, uint x_frac, uint y, char ch) uchar bits = video_fontdata[idx];
switch (vid_priv->bpix) { -#ifdef CONFIG_VIDEO_BPP8 - case VIDEO_BPP8: { - uint8_t *dst = line; - - for (i = 0; i < VIDEO_FONT_WIDTH; i++) { - *dst-- = (bits & 0x80) ? vid_priv->colour_fg - : vid_priv->colour_bg; - bits <<= 1; + case VIDEO_BPP8: + if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { + uint8_t *dst = line; + + for (i = 0; i < VIDEO_FONT_WIDTH; i++) { + *dst-- = (bits & 0x80) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + bits <<= 1; + } + break; } - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP16 - case VIDEO_BPP16: { - uint16_t *dst = line; - - for (i = 0; i < VIDEO_FONT_WIDTH; i++) { - *dst-- = (bits & 0x80) ? vid_priv->colour_fg - : vid_priv->colour_bg; - bits <<= 1; + case VIDEO_BPP16: + if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { + uint16_t *dst = line; + + for (i = 0; i < VIDEO_FONT_WIDTH; i++) { + *dst-- = (bits & 0x80) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + bits <<= 1; + } + break; } - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP32 - case VIDEO_BPP32: { - uint32_t *dst = line; - - for (i = 0; i < VIDEO_FONT_WIDTH; i++) { - *dst-- = (bits & 0x80) ? vid_priv->colour_fg - : vid_priv->colour_bg; - bits <<= 1; + case VIDEO_BPP32: + if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { + uint32_t *dst = line; + + for (i = 0; i < VIDEO_FONT_WIDTH; i++) { + *dst-- = (bits & 0x80) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + bits <<= 1; + } + break; } - break; - } -#endif default: return -ENOSYS; } @@ -281,33 +275,30 @@ static int console_set_row_3(struct udevice *dev, uint row, int clr) line = vid_priv->fb + row * VIDEO_FONT_HEIGHT * pbytes; for (j = 0; j < vid_priv->ysize; j++) { switch (vid_priv->bpix) { -#ifdef CONFIG_VIDEO_BPP8 - case VIDEO_BPP8: { - uint8_t *dst = line; + case VIDEO_BPP8: + if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { + uint8_t *dst = line;
- for (i = 0; i < VIDEO_FONT_HEIGHT; i++) - *dst++ = clr; - break; - } -#endif + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) + *dst++ = clr; + break; + } default: return -ENOSYS; } @@ -356,39 +347,39 @@ static int console_putc_xy_3(struct udevice *dev, uint x_frac, uint y, char ch)
for (col = 0; col < VIDEO_FONT_HEIGHT; col++) { switch (vid_priv->bpix) { -#ifdef CONFIG_VIDEO_BPP8 - case VIDEO_BPP8: { - uint8_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { - *dst++ = (pfont[i] & mask) ? vid_priv->colour_fg - : vid_priv->colour_bg; + case VIDEO_BPP8: + if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { + uint8_t *dst = line; + + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { + *dst++ = (pfont[i] & mask) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + } + break; } - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP16 - case VIDEO_BPP16: { - uint16_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { - *dst++ = (pfont[i] & mask) ? vid_priv->colour_fg - : vid_priv->colour_bg; + case VIDEO_BPP16: + if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { + uint16_t *dst = line; + + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { + *dst++ = (pfont[i] & mask) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + } + break; } - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP32 - case VIDEO_BPP32: { - uint32_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { - *dst++ = (pfont[i] & mask) ? vid_priv->colour_fg - : vid_priv->colour_bg; + case VIDEO_BPP32: + if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { + uint32_t *dst = line; + + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { + *dst++ = (pfont[i] & mask) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + } + break; } - break; - } -#endif default: return -ENOSYS; }
Change the #ifdefs to use CONFIG_IS_ENABLED() instead.
drivers/video/vidconsole-uclass.c | 22 ++++++++++------------ 1 file changed, 10 insertions(+), 12 deletions(-)
diff --git a/drivers/video/vidconsole-uclass.c b/drivers/video/vidconsole-uclass.c index c690eceeaa..75c7e25095 100644 --- a/drivers/video/vidconsole-uclass.c +++ b/drivers/video/vidconsole-uclass.c @@ -116,7 +116,6 @@ static void vidconsole_newline(struct udevice *dev) video_sync(dev->parent, false); }
-#if CONFIG_IS_ENABLED(VIDEO_BPP16) || CONFIG_IS_ENABLED(VIDEO_BPP32) static const struct vid_rgb colors[VID_COLOR_COUNT] = { { 0x00, 0x00, 0x00 }, /* black */ { 0xc0, 0x00, 0x00 }, /* red */ @@ -135,23 +134,22 @@ static const struct vid_rgb colors[VID_COLOR_COUNT] = { { 0x00, 0xff, 0xff }, /* bright cyan */ { 0xff, 0xff, 0xff }, /* white */ }; -#endif
u32 vid_console_color(struct video_priv *priv, unsigned int idx) { switch (priv->bpix) { -#if CONFIG_IS_ENABLED(VIDEO_BPP16) case VIDEO_BPP16: - return ((colors[idx].r >> 3) << 11) | - ((colors[idx].g >> 2) << 5) | - ((colors[idx].b >> 3) << 0); -#endif -#if CONFIG_IS_ENABLED(VIDEO_BPP32) + if (CONFIG_IS_ENABLED(VIDEO_BPP16)) { + return ((colors[idx].r >> 3) << 11) | + ((colors[idx].g >> 2) << 5) | + ((colors[idx].b >> 3) << 0); + } case VIDEO_BPP32: - return (colors[idx].r << 16) | - (colors[idx].g << 8) | - (colors[idx].b << 0); -#endif + if (CONFIG_IS_ENABLED(VIDEO_BPP32)) { + return (colors[idx].r << 16) | + (colors[idx].g << 8) | + (colors[idx].b << 0); + } default: /* * For unknown bit arrangements just support
Change the #ifdefs to use IS_ENABLED(), etc., instead.
drivers/video/video-uclass.c | 54 +++++++++++++++++------------------- 1 file changed, 26 insertions(+), 28 deletions(-)
diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 5ea7568fa4..12057c8a5b 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -92,26 +92,24 @@ int video_clear(struct udevice *dev) struct video_priv *priv = dev_get_uclass_priv(dev);
switch (priv->bpix) { -#ifdef CONFIG_VIDEO_BPP16 - case VIDEO_BPP16: { - u16 *ppix = priv->fb; - u16 *end = priv->fb + priv->fb_size; - - while (ppix < end) - *ppix++ = priv->colour_bg; - break; - } -#endif -#ifdef CONFIG_VIDEO_BPP32 - case VIDEO_BPP32: { - u32 *ppix = priv->fb; - u32 *end = priv->fb + priv->fb_size; - - while (ppix < end) - *ppix++ = priv->colour_bg; - break; - } -#endif + case VIDEO_BPP16: + if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { + u16 *ppix = priv->fb; + u16 *end = priv->fb + priv->fb_size; + + while (ppix < end) + *ppix++ = priv->colour_bg; + break; + } + case VIDEO_BPP32: + if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { + u32 *ppix = priv->fb; + u32 *end = priv->fb + priv->fb_size; + + while (ppix < end) + *ppix++ = priv->colour_bg; + break; + } default: memset(priv->fb, priv->colour_bg, priv->fb_size); break; @@ -125,14 +123,14 @@ void video_set_default_colors(struct udevice *dev, bool invert) struct video_priv *priv = dev_get_uclass_priv(dev); int fore, back;
-#ifdef CONFIG_SYS_WHITE_ON_BLACK - /* White is used when switching to bold, use light gray here */ - fore = VID_LIGHT_GRAY; - back = VID_BLACK; -#else - fore = VID_BLACK; - back = VID_WHITE; -#endif + if (CONFIG_IS_ENABLED(SYS_WHITE_ON_BLACK)) { + /* White is used when switching to bold, use light gray here */ + fore = VID_LIGHT_GRAY; + back = VID_BLACK; + } else { + fore = VID_BLACK; + back = VID_WHITE; + } if (invert) { int temp;
Hi Simon,
On Fri, 20 Dec 2019 18:10:32 -0700 Simon Glass sjg@chromium.org wrote: ...
Series applied to u-boot-video/master, thanks!
-- Anatolij
Anatolij Gustschin
