[U-Boot] [PATCH v3 0/3] board: at91sam9rlek: Convert to support DM and DT
The purpose of the patch set is to convert the board to support the driver model and the device tree.
The patch set is based on the patch set: 1./ PATCH v2 0/6] ARM: dts: at91: Add dts files for AT91 SoCs' boards https://lists.denx.de/pipermail/u-boot/2017-April/287222.html
2./ [PATCH v6] mmc: gen_atmel_mci: add driver model support for mci https://lists.denx.de/pipermail/u-boot/2017-April/287071.html
Changes in v3: - Rebase on the master branch (22e10be45) of u-boot-dm git tree. - Update the cover-letter.
Changes in v2: - Add converting UART to support DM_SERIAL and used in the board_init_f stage. - Remove unused LED feature. - Improve the commit log. - Add [PATCH]: board: at91sam9rlek: Enable early debug UART. - Move out [PATCH]: ARM: dts: at91: add dts files for at91sam9rlek.
Wenyou Yang (3): configs: at91sam9rlek: Update for DT and DM support board: at91sam9rlek: Clean up code board: at91sam9rlek: Enable early debug UART
board/atmel/at91sam9rlek/Makefile | 2 +- board/atmel/at91sam9rlek/at91sam9rlek.c | 24 +++++++++--------------- configs/at91sam9rlek_dataflash_defconfig | 22 +++++++++++++++++++++- configs/at91sam9rlek_mmc_defconfig | 22 +++++++++++++++++++++- configs/at91sam9rlek_nandflash_defconfig | 22 +++++++++++++++++++++- include/configs/at91sam9rlek.h | 22 +--------------------- 6 files changed, 74 insertions(+), 40 deletions(-)
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
Changes in v3: None Changes in v2: - Add converting UART to support DM_SERIAL and used in the board_init_f stage. - Remove unused LED feature. - Improve the commit log.
board/atmel/at91sam9rlek/Makefile | 2 +- configs/at91sam9rlek_dataflash_defconfig | 16 +++++++++++++++- configs/at91sam9rlek_mmc_defconfig | 16 +++++++++++++++- configs/at91sam9rlek_nandflash_defconfig | 16 +++++++++++++++- include/configs/at91sam9rlek.h | 22 +--------------------- 5 files changed, 47 insertions(+), 25 deletions(-)
diff --git a/board/atmel/at91sam9rlek/Makefile b/board/atmel/at91sam9rlek/Makefile index 51daf8d30c..7acfee5350 100644 --- a/board/atmel/at91sam9rlek/Makefile +++ b/board/atmel/at91sam9rlek/Makefile @@ -10,5 +10,5 @@ #
obj-y += at91sam9rlek.o -obj-y += led.o +obj-$(CONFIG_AT91_LED) += led.o obj-$(CONFIG_HAS_DATAFLASH) += partition.o diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 49e1353b7d..24fbfe619c 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9RLEK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9rlek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -20,5 +22,17 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_MMC=y +CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y CONFIG_LCD=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index 483d9b68ec..a46deac284 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9RLEK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9rlek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_MMC" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -20,5 +22,17 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_MMC=y +CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y CONFIG_LCD=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index d7f2d7f1b3..b6400d0317 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9RLEK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9rlek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -20,5 +22,17 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_MMC=y +CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y CONFIG_LCD=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 8752f1f3b6..afc924d825 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -29,18 +29,11 @@ #define CONFIG_INITRD_TAG 1
#define CONFIG_ATMEL_LEGACY -#define CONFIG_AT91_GPIO 1 -#define CONFIG_AT91_GPIO_PULLUP 1
/* * Hardware drivers */
-/* serial console */ -#define CONFIG_ATMEL_USART -#define CONFIG_USART_BASE ATMEL_BASE_DBGU -#define CONFIG_USART_ID ATMEL_ID_SYS - /* LCD */ #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO 1 @@ -53,13 +46,6 @@ /* Let board_init_f handle the framebuffer allocation */ #undef CONFIG_FB_ADDR
-/* LED */ -#define CONFIG_AT91_LED -#define CONFIG_RED_LED AT91_PIN_PD14 /* this is the power led */ -#define CONFIG_GREEN_LED AT91_PIN_PD15 /* this is the user1 led */ -#define CONFIG_YELLOW_LED AT91_PIN_PD16 /* this is the user2 led */ - - /* * Command line configuration. */ @@ -72,7 +58,7 @@ #define CONFIG_SYS_SDRAM_SIZE 0x04000000
#define CONFIG_SYS_INIT_SP_ADDR \ - (ATMEL_BASE_SRAM + 0x1000 - GENERATED_GBL_DATA_SIZE) + (ATMEL_BASE_SRAM + 16 * 1024 - GENERATED_GBL_DATA_SIZE)
/* DataFlash */ #define CONFIG_ATMEL_DATAFLASH_SPI @@ -98,12 +84,6 @@
#endif
-/* MMC */ - -#ifdef CONFIG_CMD_MMC -#define CONFIG_GENERIC_ATMEL_MCI -#endif - /* Ethernet - not present */
/* USB - not supported */
Since the introduction of the pinctrl and clk drivers and the device tree files, remove unneeded hard coded related code from the board file.
board/atmel/at91sam9rlek/at91sam9rlek.c | 19 ------------------- 1 file changed, 19 deletions(-)
diff --git a/board/atmel/at91sam9rlek/at91sam9rlek.c b/board/atmel/at91sam9rlek/at91sam9rlek.c index 994f246078..0c4d51765e 100644 --- a/board/atmel/at91sam9rlek/at91sam9rlek.c +++ b/board/atmel/at91sam9rlek/at91sam9rlek.c @@ -18,10 +18,6 @@
#include <lcd.h> #include <atmel_lcdc.h> -#include <atmel_mci.h> -#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) -#include <net.h> -#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -159,22 +155,8 @@ void lcd_show_board_info(void) #endif /* CONFIG_LCD_INFO */ #endif
-#ifdef CONFIG_GENERIC_ATMEL_MCI -int board_mmc_init(bd_t *bis) -{ - at91_mci_hw_init(); - - return atmel_mci_init((void *)ATMEL_BASE_MCI); -} -#endif - int board_early_init_f(void) { - at91_periph_clk_enable(ATMEL_ID_PIOA); - at91_periph_clk_enable(ATMEL_ID_PIOB); - at91_periph_clk_enable(ATMEL_ID_PIOC); - at91_periph_clk_enable(ATMEL_ID_PIOD); - return 0; }
@@ -185,7 +167,6 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- at91_seriald_hw_init(); #ifdef CONFIG_CMD_NAND at91sam9rlek_nand_hw_init(); #endif
Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available.
Changes in v2: - Add [PATCH]: board: at91sam9rlek: Enable early debug UART. - Move out [PATCH]: ARM: dts: at91: add dts files for at91sam9rlek.
board/atmel/at91sam9rlek/at91sam9rlek.c | 13 +++++++++++++ configs/at91sam9rlek_dataflash_defconfig | 6 ++++++ configs/at91sam9rlek_mmc_defconfig | 6 ++++++ configs/at91sam9rlek_nandflash_defconfig | 6 ++++++ 4 files changed, 31 insertions(+)
diff --git a/board/atmel/at91sam9rlek/at91sam9rlek.c b/board/atmel/at91sam9rlek/at91sam9rlek.c index 0c4d51765e..0b603ed13a 100644 --- a/board/atmel/at91sam9rlek/at91sam9rlek.c +++ b/board/atmel/at91sam9rlek/at91sam9rlek.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <debug_uart.h> #include <asm/io.h> #include <asm/arch/at91sam9rl.h> #include <asm/arch/at91sam9rl_matrix.h> @@ -155,10 +156,22 @@ void lcd_show_board_info(void) #endif /* CONFIG_LCD_INFO */ #endif
+#ifdef CONFIG_DEBUG_UART_BOARD_INIT +void board_debug_uart_init(void) +{ + at91_seriald_hw_init(); +} +#endif + +#ifdef CONFIG_BOARD_EARLY_INIT_F int board_early_init_f(void) { +#ifdef CONFIG_DEBUG_UART + debug_uart_init(); +#endif return 0; } +#endif
int board_init(void) { diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 24fbfe619c..d4abb2a2fd 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -34,5 +34,11 @@ CONFIG_GENERIC_ATMEL_MCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_LCD=y diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index a46deac284..9a40c41f36 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -34,5 +34,11 @@ CONFIG_GENERIC_ATMEL_MCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_LCD=y diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index b6400d0317..d68b562b0e 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -34,5 +34,11 @@ CONFIG_GENERIC_ATMEL_MCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_LCD=y
Changes in v3:
Changes in v2:
Wenyou Yang
