[U-Boot] [PATCH v1 00/26] colibri imx6 fixes, device tree enablement and driver model conversion
This series addresses some shortcomings, enables/introduces device tree support and converts all except video to using the driver model. This is fully tested both running our latest downstream BSP as well as the mainline Linux kernel.
Bhuvanchandra DV (2): toradex: colibri_imx6: overwrite CMA memory set in device tree colibri_imx6: switch to zimage
Gerard Salvatella (2): colibri_imx6: added nreset gpio on reboot board: colibri_imx6: check for and report ecc errors in fuses
Marcel Ziswiler (12): colibri_imx6: get rid of obsolete nospl configurations colibri_imx6: use distro defaults colibri_imx6: move console in env from header file to defconfig colibri_imx6: enable fit image, gpt, imx thermal, efi loader support colibri_imx6: remove obsolete USB_GADGET_MASS_STORAGE configuration colibri_imx6: migrate to using device tree colibri_imx6: clean-up and migrate gpios to using driver model colibri_imx6: enable pin control driver colibri_imx6: migrate i2c to using driver model colibri_imx6: migrate pmic and regulator to using driver model colibri_imx6: migrate mmc to using driver model colibri_imx6: migrate usb to using driver model
Max Krummenacher (7): colibri_imx6: drop CONFIG_OF_SYSTEM_SETUP colibri_imx6: print also 64-bit IT colibri_imx6: unify sd/mmc drive strenght with linux kernel settings colibri imx6: pf0100: reorder and cleanup message printing colibri imx6: disable ri and dcd irq in uarts colibri_imx6: change pmic fusing according to hw 1.1 requirements colibri_imx6: revert fuse value set in mfgr_fuse
Sanchayan Maity (1): configs: colibri_imx6: Use ext4 file system by default
Stefan Agner (2): colibri_imx6: add distroboot support colibri_imx6: use SDP if USB serial downloader has been used
arch/arm/dts/imx6-colibri.dts | 411 ++++++++++++++++++ .../toradex/colibri_imx6/800mhz_2x64mx16.cfg | 58 --- .../toradex/colibri_imx6/800mhz_4x64mx16.cfg | 58 --- board/toradex/colibri_imx6/MAINTAINERS | 3 +- board/toradex/colibri_imx6/clocks.cfg | 41 -- board/toradex/colibri_imx6/colibri_imx6.c | 395 +++++++++-------- board/toradex/colibri_imx6/colibri_imx6.cfg | 37 -- board/toradex/colibri_imx6/ddr-setup.cfg | 97 ----- board/toradex/colibri_imx6/do_fuse.c | 2 +- board/toradex/colibri_imx6/pf0100.c | 177 +++++--- board/toradex/colibri_imx6/pf0100.h | 59 ++- board/toradex/colibri_imx6/pf0100_otp.inc | 16 +- configs/colibri_imx6_defconfig | 33 +- configs/colibri_imx6_nospl_defconfig | 63 --- include/configs/colibri_imx6.h | 66 +-- 15 files changed, 853 insertions(+), 663 deletions(-) create mode 100644 arch/arm/dts/imx6-colibri.dts delete mode 100644 board/toradex/colibri_imx6/800mhz_2x64mx16.cfg delete mode 100644 board/toradex/colibri_imx6/800mhz_4x64mx16.cfg delete mode 100644 board/toradex/colibri_imx6/clocks.cfg delete mode 100644 board/toradex/colibri_imx6/colibri_imx6.cfg delete mode 100644 board/toradex/colibri_imx6/ddr-setup.cfg delete mode 100644 configs/colibri_imx6_nospl_defconfig
Now with SPL long since being in place even for recovery using SDP finally get rid of those nospl configurations.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
.../toradex/colibri_imx6/800mhz_2x64mx16.cfg | 58 ----------- .../toradex/colibri_imx6/800mhz_4x64mx16.cfg | 58 ----------- board/toradex/colibri_imx6/MAINTAINERS | 1 - board/toradex/colibri_imx6/clocks.cfg | 41 -------- board/toradex/colibri_imx6/colibri_imx6.cfg | 37 ------- board/toradex/colibri_imx6/ddr-setup.cfg | 97 ------------------- configs/colibri_imx6_nospl_defconfig | 63 ------------ 7 files changed, 355 deletions(-) delete mode 100644 board/toradex/colibri_imx6/800mhz_2x64mx16.cfg delete mode 100644 board/toradex/colibri_imx6/800mhz_4x64mx16.cfg delete mode 100644 board/toradex/colibri_imx6/clocks.cfg delete mode 100644 board/toradex/colibri_imx6/colibri_imx6.cfg delete mode 100644 board/toradex/colibri_imx6/ddr-setup.cfg delete mode 100644 configs/colibri_imx6_nospl_defconfig
diff --git a/board/toradex/colibri_imx6/800mhz_2x64mx16.cfg b/board/toradex/colibri_imx6/800mhz_2x64mx16.cfg deleted file mode 100644 index c9407143d2..0000000000 --- a/board/toradex/colibri_imx6/800mhz_2x64mx16.cfg +++ /dev/null @@ -1,58 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2013 Boundary Devices - * Copyright (C) 2014-2016, Toradex AG - */ - -DATA 4, MX6_MMDC_P0_MDPDC, 0x0002002D -DATA 4, MX6_MMDC_P0_MDCFG0, 0x2C305503 -DATA 4, MX6_MMDC_P0_MDCFG1, 0xB66D8D63 -DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB -DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 -DATA 4, MX6_MMDC_P0_MDOR, 0x00301023 -DATA 4, MX6_MMDC_P0_MDOTC, 0x00333030 -DATA 4, MX6_MMDC_P0_MDPDC, 0x0002556D -/* CS0 End: 7MSB of ((0x10000000 + 512M) -1) >> 25 */ -DATA 4, MX6_MMDC_P0_MDASP, 0x00000017 -/* DDR3 DATA BUS SIZE: 64BIT */ -/* DATA 4, MX6_MMDC_P0_MDCTL, 0x821A0000 */ -/* DDR3 DATA BUS SIZE: 32BIT */ -DATA 4, MX6_MMDC_P0_MDCTL, 0x82190000 - -/* Write commands to DDR */ -/* Load Mode Registers */ -/* TODO Use Auto Self-Refresh mode (Extended Temperature)*/ -/* DATA 4, MX6_MMDC_P0_MDSCR, 0x04408032 */ -DATA 4, MX6_MMDC_P0_MDSCR, 0x04008032 -DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 -DATA 4, MX6_MMDC_P0_MDSCR, 0x00048031 -DATA 4, MX6_MMDC_P0_MDSCR, 0x13208030 -/* ZQ calibration */ -DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 - -DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 -DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 -DATA 4, MX6_MMDC_P0_MDREF, 0x00005800 - -DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00000000 -DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00000000 - -DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x42360232 -DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x021F022A -DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x421E0224 -DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x02110218 - -DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x41434344 -DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x4345423E -DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x39383339 -DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x3E363930 - -DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x00340039 -DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x002C002D -DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x00120019 -DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x0012002D - -DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 -DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 -DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 -DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/toradex/colibri_imx6/800mhz_4x64mx16.cfg b/board/toradex/colibri_imx6/800mhz_4x64mx16.cfg deleted file mode 100644 index c319d2a729..0000000000 --- a/board/toradex/colibri_imx6/800mhz_4x64mx16.cfg +++ /dev/null @@ -1,58 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2013 Boundary Devices - * Copyright (C) 2014-2016, Toradex AG - */ - -DATA 4, MX6_MMDC_P0_MDPDC, 0x0002002D -DATA 4, MX6_MMDC_P0_MDCFG0, 0x2C305503 -DATA 4, MX6_MMDC_P0_MDCFG1, 0xB66D8D63 -DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB -DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 -DATA 4, MX6_MMDC_P0_MDOR, 0x00301023 -DATA 4, MX6_MMDC_P0_MDOTC, 0x00333030 -DATA 4, MX6_MMDC_P0_MDPDC, 0x0002556D -/* CS0 End: 7MSB of ((0x10000000 + 512M) -1) >> 25 */ -DATA 4, MX6_MMDC_P0_MDASP, 0x00000017 -/* DDR3 DATA BUS SIZE: 64BIT */ -DATA 4, MX6_MMDC_P0_MDCTL, 0x821A0000 -/* DDR3 DATA BUS SIZE: 32BIT */ -/* DATA 4, MX6_MMDC_P0_MDCTL, 0x82190000 */ - -/* Write commands to DDR */ -/* Load Mode Registers */ -/* TODO Use Auto Self-Refresh mode (Extended Temperature)*/ -/* DATA 4, MX6_MMDC_P0_MDSCR, 0x04408032 */ -DATA 4, MX6_MMDC_P0_MDSCR, 0x04008032 -DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 -DATA 4, MX6_MMDC_P0_MDSCR, 0x00048031 -DATA 4, MX6_MMDC_P0_MDSCR, 0x13208030 -/* ZQ calibration */ -DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 - -DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 -DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 -DATA 4, MX6_MMDC_P0_MDREF, 0x00005800 - -DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00000000 -DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00000000 - -DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x42360232 -DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x021F022A -DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x421E0224 -DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x02110218 - -DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x41434344 -DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x4345423E -DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x39383339 -DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x3E363930 - -DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x00340039 -DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x002C002D -DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x00120019 -DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x0012002D - -DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 -DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 -DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 -DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/toradex/colibri_imx6/MAINTAINERS b/board/toradex/colibri_imx6/MAINTAINERS index 1cc7ef2e71..49999d8cf5 100644 --- a/board/toradex/colibri_imx6/MAINTAINERS +++ b/board/toradex/colibri_imx6/MAINTAINERS @@ -5,4 +5,3 @@ S: Maintained F: board/toradex/colibri_imx6/ F: include/configs/colibri_imx6.h F: configs/colibri_imx6_defconfig -F: configs/colibri_imx6_nospl_defconfig diff --git a/board/toradex/colibri_imx6/clocks.cfg b/board/toradex/colibri_imx6/clocks.cfg deleted file mode 100644 index 1bcbc4fa38..0000000000 --- a/board/toradex/colibri_imx6/clocks.cfg +++ /dev/null @@ -1,41 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2013 Boundary Devices - * Copyright (C) 2014-2016, Toradex AG - * - * Device Configuration Data (DCD) - * - * Each entry must have the format: - * Addr-type Address Value - * - * where: - * Addr-type register length (1,2 or 4 bytes) - * Address absolute address of the register - * value value to be stored in the register - */ - -/* set the default clock gate to save power */ -DATA 4, CCM_CCGR0, 0x00C03F3F -DATA 4, CCM_CCGR1, 0x0030FC03 -DATA 4, CCM_CCGR2, 0x0FFFC000 -DATA 4, CCM_CCGR3, 0x3FF00000 -DATA 4, CCM_CCGR4, 0x00FFF300 -DATA 4, CCM_CCGR5, 0x0F0000C3 -DATA 4, CCM_CCGR6, 0x000003FF - -/* enable AXI cache for VDOA/VPU/IPU */ -DATA 4, MX6_IOMUXC_GPR4, 0xF00000CF -/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ -DATA 4, MX6_IOMUXC_GPR6, 0x007F007F -DATA 4, MX6_IOMUXC_GPR7, 0x007F007F - -/* - * Setup CCM_CCOSR register as follows: - * - * cko1_en = 1 --> CKO1 enabled - * cko1_div = 111 --> divide by 8 - * cko1_sel = 1011 --> ahb_clk_root - * - * This sets CKO1 at ahb_clk_root/8 = 132/8 = 16.5 MHz - */ -DATA 4, CCM_CCOSR, 0x000000fb diff --git a/board/toradex/colibri_imx6/colibri_imx6.cfg b/board/toradex/colibri_imx6/colibri_imx6.cfg deleted file mode 100644 index 517c5eb107..0000000000 --- a/board/toradex/colibri_imx6/colibri_imx6.cfg +++ /dev/null @@ -1,37 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2013 Boundary Devices - * Copyright (C) 2014 Toradex AG - * - * Refer doc/README.imximage for more details about how-to configure - * and create imximage boot image - * - * The syntax is taken as close as possible with the kwbimage - */ - -/* image version */ -IMAGE_VERSION 2 - -/* - * Boot Device : one of - * spi, sd (the board has no nand neither onenand) - */ -BOOT_FROM sd - -#define __ASSEMBLY__ -#include <config.h> -#include "asm/arch/mx6-ddr.h" -#include "asm/arch/iomux.h" -#include "asm/arch/crm_regs.h" - -#include "ddr-setup.cfg" - -#if CONFIG_DDR_MB == 256 -#include "800mhz_2x64mx16.cfg" -#elif CONFIG_DDR_MB == 512 -#include "800mhz_4x64mx16.cfg" -#else -#error "unknown DDR size" -#endif - -#include "clocks.cfg" diff --git a/board/toradex/colibri_imx6/ddr-setup.cfg b/board/toradex/colibri_imx6/ddr-setup.cfg deleted file mode 100644 index a943fd228c..0000000000 --- a/board/toradex/colibri_imx6/ddr-setup.cfg +++ /dev/null @@ -1,97 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2013 Boundary Devices - * Copyright (C) 2014-2016, Toradex AG - * - * Device Configuration Data (DCD) - * - * Each entry must have the format: - * Addr-type Address Value - * - * where: - * Addr-type register length (1,2 or 4 bytes) - * Address absolute address of the register - * value value to be stored in the register - */ - -/* - * DDR3 settings - * MX6Q ddr is limited to 1066 Mhz currently 1056 MHz(528 MHz clock), - * memory bus width: 64 bits x16/x32/x64 - * MX6DL ddr is limited to 800 MHz(400 MHz clock) - * memory bus width: 64 bits x16/x32/x64 - * MX6SOLO ddr is limited to 800 MHz(400 MHz clock) - * memory bus width: 32 bits x16/x32 - */ -DATA 4, MX6_IOM_DRAM_SDQS0, 0x00000030 -DATA 4, MX6_IOM_DRAM_SDQS1, 0x00000030 -DATA 4, MX6_IOM_DRAM_SDQS2, 0x00000030 -DATA 4, MX6_IOM_DRAM_SDQS3, 0x00000030 -DATA 4, MX6_IOM_DRAM_SDQS4, 0x00000030 -DATA 4, MX6_IOM_DRAM_SDQS5, 0x00000030 -DATA 4, MX6_IOM_DRAM_SDQS6, 0x00000030 -DATA 4, MX6_IOM_DRAM_SDQS7, 0x00000030 - -DATA 4, MX6_IOM_GRP_B0DS, 0x00000030 -DATA 4, MX6_IOM_GRP_B1DS, 0x00000030 -DATA 4, MX6_IOM_GRP_B2DS, 0x00000030 -DATA 4, MX6_IOM_GRP_B3DS, 0x00000030 -DATA 4, MX6_IOM_GRP_B4DS, 0x00000030 -DATA 4, MX6_IOM_GRP_B5DS, 0x00000030 -DATA 4, MX6_IOM_GRP_B6DS, 0x00000030 -DATA 4, MX6_IOM_GRP_B7DS, 0x00000030 -DATA 4, MX6_IOM_GRP_ADDDS, 0x00000030 -/* 40 Ohm drive strength for cs0/1,sdba2,cke0/1,sdwe */ -DATA 4, MX6_IOM_GRP_CTLDS, 0x00000030 - -DATA 4, MX6_IOM_DRAM_DQM0, 0x00020030 -DATA 4, MX6_IOM_DRAM_DQM1, 0x00020030 -DATA 4, MX6_IOM_DRAM_DQM2, 0x00020030 -DATA 4, MX6_IOM_DRAM_DQM3, 0x00020030 -DATA 4, MX6_IOM_DRAM_DQM4, 0x00020030 -DATA 4, MX6_IOM_DRAM_DQM5, 0x00020030 -DATA 4, MX6_IOM_DRAM_DQM6, 0x00020030 -DATA 4, MX6_IOM_DRAM_DQM7, 0x00020030 - -DATA 4, MX6_IOM_DRAM_CAS, 0x00020030 -DATA 4, MX6_IOM_DRAM_RAS, 0x00020030 -DATA 4, MX6_IOM_DRAM_SDCLK_0, 0x00020030 -DATA 4, MX6_IOM_DRAM_SDCLK_1, 0x00020030 - -DATA 4, MX6_IOM_DRAM_RESET, 0x00020030 -DATA 4, MX6_IOM_DRAM_SDCKE0, 0x00003000 -DATA 4, MX6_IOM_DRAM_SDCKE1, 0x00003000 - -DATA 4, MX6_IOM_DRAM_SDODT0, 0x00003030 -DATA 4, MX6_IOM_DRAM_SDODT1, 0x00003030 - -/* (differential input) */ -DATA 4, MX6_IOM_DDRMODE_CTL, 0x00020000 -/* (differential input) */ -DATA 4, MX6_IOM_GRP_DDRMODE, 0x00020000 -/* disable ddr pullups */ -DATA 4, MX6_IOM_GRP_DDRPKE, 0x00000000 -DATA 4, MX6_IOM_DRAM_SDBA2, 0x00000000 -/* 40 Ohm drive strength for cs0/1,sdba2,cke0/1,sdwe */ -DATA 4, MX6_IOM_GRP_DDR_TYPE, 0x000C0000 - -/* Read data DQ Byte0-3 delay */ -DATA 4, MX6_MMDC_P0_MPRDDQBY0DL, 0x33333333 -DATA 4, MX6_MMDC_P0_MPRDDQBY1DL, 0x33333333 -DATA 4, MX6_MMDC_P0_MPRDDQBY2DL, 0x33333333 -DATA 4, MX6_MMDC_P0_MPRDDQBY3DL, 0x33333333 -DATA 4, MX6_MMDC_P1_MPRDDQBY0DL, 0x33333333 -DATA 4, MX6_MMDC_P1_MPRDDQBY1DL, 0x33333333 -DATA 4, MX6_MMDC_P1_MPRDDQBY2DL, 0x33333333 -DATA 4, MX6_MMDC_P1_MPRDDQBY3DL, 0x33333333 - -/* - * MDMISC mirroring interleaved (row/bank/col) - */ -/* TODO: check what the RALAT field does */ -DATA 4, MX6_MMDC_P0_MDMISC, 0x00081740 - -/* - * MDSCR con_req - */ -DATA 4, MX6_MMDC_P0_MDSCR, 0x00008000 diff --git a/configs/colibri_imx6_nospl_defconfig b/configs/colibri_imx6_nospl_defconfig deleted file mode 100644 index 5e9490bc42..0000000000 --- a/configs/colibri_imx6_nospl_defconfig +++ /dev/null @@ -1,63 +0,0 @@ -CONFIG_ARM=y -CONFIG_SYS_THUMB_BUILD=y -CONFIG_ARCH_MX6=y -CONFIG_SYS_TEXT_BASE=0x17800000 -CONFIG_TARGET_COLIBRI_IMX6=y -CONFIG_CMD_HDMIDETECT=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_imx6/colibri_imx6.cfg,MX6DL,DDR_MB=256" -CONFIG_BOOTDELAY=1 -# CONFIG_CONSOLE_MUX is not set -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_MISC_INIT_R=y -CONFIG_VERSION_VARIABLE=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_BOUNCE_BUFFER=y -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="Colibri iMX6 # " -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_ELF is not set -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_ASKENV=y -CONFIG_CRC32_VERIFY=y -CONFIG_CMD_MEMTEST=y -CONFIG_SYS_ALT_MEMTEST=y -CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_BMP=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_DFU_MMC=y -CONFIG_FSL_ESDHC=y -CONFIG_PHYLIB=y -CONFIG_PHY_MICREL=y -CONFIG_MII=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Toradex" -CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 -CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_VIDEO=y -CONFIG_FAT_WRITE=y -CONFIG_OF_LIBFDT=y -# CONFIG_EFI_LOADER is not set
From: Marcel Ziswiler marcel.ziswiler@toradex.com Now with SPL long since being in place even for recovery using SDP finally get rid of those nospl configurations. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Applied to u-boot-imx, -next, thanks !
Best regards, Stefano Babic
Use distro defaults and minimise default configuration again using savedefconfig.
configs/colibri_imx6_defconfig | 12 +----------- 1 file changed, 1 insertion(+), 11 deletions(-)
diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 2072281354..699eb70088 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -9,12 +9,11 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_CMD_HDMIDETECT=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6DL" CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -26,9 +25,7 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET=y CONFIG_SPL_USB_SDP_SUPPORT=y -CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri iMX6 # " -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set @@ -43,14 +40,8 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DFU_MMC=y @@ -59,7 +50,6 @@ CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_MII=y CONFIG_USB=y -CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Toradex"
From: Marcel Ziswiler marcel.ziswiler@toradex.com Use distro defaults and minimise default configuration again using savedefconfig. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Move console in env from header file to defconfig.
While at it also update copyright year.
configs/colibri_imx6_defconfig | 1 + include/configs/colibri_imx6.h | 3 +-- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 699eb70088..0b31a46cc9 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -14,6 +14,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6DL" CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 2d40ceb24e..9e45d63245 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2013-2015 Toradex, Inc. + * Copyright 2013-2019 Toradex, Inc. * * Configuration settings for the Toradex Colibri iMX6 */ @@ -74,7 +74,6 @@
/* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN
From: Marcel Ziswiler marcel.ziswiler@toradex.com Move console in env from header file to defconfig. While at it also update copyright year. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Enbale FIT image, GPT command, i.MX thermal and EFI loader support.
configs/colibri_imx6_defconfig | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 0b31a46cc9..84fa427c8c 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL=y CONFIG_CMD_HDMIDETECT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6DL" CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set @@ -36,6 +37,7 @@ CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y @@ -50,6 +52,7 @@ CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_MII=y +CONFIG_IMX_THERMAL=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y @@ -63,4 +66,3 @@ CONFIG_VIDEO=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y CONFIG_OF_LIBFDT_OVERLAY=y -# CONFIG_EFI_LOADER is not set
From: Marcel Ziswiler marcel.ziswiler@toradex.com Enbale FIT image, GPT command, i.MX thermal and EFI loader support. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Remove obsolete USB_GADGET_MASS_STORAGE configuration.
include/configs/colibri_imx6.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 9e45d63245..f029a885d2 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -70,8 +70,6 @@ /* Client */ #define CONFIG_USBD_HS
-#define CONFIG_USB_GADGET_MASS_STORAGE - /* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
From: Marcel Ziswiler marcel.ziswiler@toradex.com Remove obsolete USB_GADGET_MASS_STORAGE configuration. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Migrate to using device tree required for further driver model integration.
arch/arm/dts/imx6-colibri.dts | 411 +++++++++++++++++++++++++ board/toradex/colibri_imx6/MAINTAINERS | 2 + configs/colibri_imx6_defconfig | 3 +- 3 files changed, 415 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx6-colibri.dts
diff --git a/arch/arm/dts/imx6-colibri.dts b/arch/arm/dts/imx6-colibri.dts new file mode 100644 index 0000000000..5c9f1f0d2b --- /dev/null +++ b/arch/arm/dts/imx6-colibri.dts @@ -0,0 +1,411 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * Copyright 2019 Toradex AG + */ + +/dts-v1/; +#include <dt-bindings/gpio/gpio.h> +#include "imx6dl.dtsi" + +/ { + model = "Toradex Colibri iMX6DL/S"; + compatible = "toradex,colibri_imx6dl", "fsl,imx6dl"; + + /* Will be filled by the bootloader */ + memory@10000000 { + device_type = "memory"; + reg = <0x10000000 0>; + }; + + aliases { + mmc0 = &usdhc3; + mmc1 = &usdhc1; + usb0 = &usbotg; /* required for ums */ + }; + + chosen { + stdout-path = &uart1; + }; + + reg_module_3v3: regulator-module-3v3 { + compatible = "regulator-fixed"; + regulator-name = "+V3.3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + reg_usb_host_vbus: regulator-usb-host-vbus { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_regulator_usbh_pwr>; + regulator-name = "usb_host_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio3 31 GPIO_ACTIVE_LOW>; /* USBH_PEN */ + }; +}; + +/* + * PWR_I2C: power I2C to audio codec, PMIC, temperature sensor and + * touch screen controller + */ +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + pmic: pfuze100@8 { + compatible = "fsl,pfuze100"; + reg = <0x08>; + + regulators { + sw1a_reg: sw1ab { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw1c_reg: sw1c { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw3a_reg: sw3a { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1975000>; + regulator-boot-on; + regulator-always-on; + }; + + swbst_reg: swbst { + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + regulator-boot-on; + regulator-always-on; + }; + + snvs_reg: vsnvs { + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + regulator-always-on; + }; + + vref_reg: vrefddr { + regulator-boot-on; + regulator-always-on; + }; + + /* vgen1: unused */ + + vgen2_reg: vgen2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + regulator-boot-on; + regulator-always-on; + }; + + /* vgen3: unused */ + + vgen4_reg: vgen4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + vgen5_reg: vgen5 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + vgen6_reg: vgen6 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; +}; + +/* + * I2C3_SDA/SCL on SODIMM 194/196 (e.g. RTC on carrier board) + */ +&i2c3 { + clock-frequency = <100000>; + pinctrl-names = "default", "gpio"; + pinctrl-0 = <&pinctrl_i2c3>; + pinctrl-1 = <&pinctrl_i2c3_recovery>; + scl-gpios = <&gpio1 3 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + sda-gpios = <&gpio1 6 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + status = "okay"; +}; + +/* Colibri UART_A */ +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1_dte &pinctrl_uart1_ctrl>; + fsl,dte-mode; + uart-has-rtscts; + status = "okay"; +}; + +/* Colibri UART_B */ +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2_dte>; + fsl,dte-mode; + uart-has-rtscts; + status = "okay"; +}; + +/* Colibri UART_C */ +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3_dte>; + fsl,dte-mode; + status = "okay"; +}; + +/* Colibri USBH */ +&usbh1 { + dr_mode = "host"; + vbus-supply = <®_usb_host_vbus>; + status = "okay"; +}; + +/* Colibri USBC */ +&usbotg { + dr_mode = "host"; + status = "okay"; +}; + +/* Colibri MMC */ +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1 &pinctrl_mmc_cd>; + cd-gpios = <&gpio2 5 GPIO_ACTIVE_LOW>; /* MMCD */ + disable-wp; + vqmmc-supply = <®_module_3v3>; + bus-width = <4>; + no-1-8-v; + status = "okay"; +}; + +/* eMMC */ +&usdhc3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc3>; + vqmmc-supply = <®_module_3v3>; + bus-width = <8>; + no-1-8-v; + non-removable; + status = "okay"; +}; + +&iomuxc { + pinctrl_ecspi4: ecspi4grp { + fsl,pins = < + MX6QDL_PAD_EIM_D22__ECSPI4_MISO 0x100b1 + MX6QDL_PAD_EIM_D28__ECSPI4_MOSI 0x100b1 + MX6QDL_PAD_EIM_D21__ECSPI4_SCLK 0x100b1 + /* SPI CS */ + MX6QDL_PAD_EIM_A25__GPIO5_IO02 0x000b1 + >; + }; + + pinctrl_enet: enetgrp { + fsl,pins = < + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b0b0 + MX6QDL_PAD_ENET_RXD0__ENET_RX_DATA0 0x1b0b0 + MX6QDL_PAD_ENET_RXD1__ENET_RX_DATA1 0x1b0b0 + MX6QDL_PAD_ENET_RX_ER__ENET_RX_ER 0x1b0b0 + MX6QDL_PAD_ENET_TX_EN__ENET_TX_EN 0x1b0b0 + MX6QDL_PAD_ENET_TXD0__ENET_TX_DATA0 0x1b0b0 + MX6QDL_PAD_ENET_TXD1__ENET_TX_DATA1 0x1b0b0 + MX6QDL_PAD_ENET_CRS_DV__ENET_RX_EN 0x1b0b0 + MX6QDL_PAD_GPIO_16__ENET_REF_CLK ((1<<30) | 0x1b0b0) + >; + }; + + pinctrl_gpio_bl_on: gpioblon { + fsl,pins = < + MX6QDL_PAD_EIM_D26__GPIO3_IO26 0x1b0b0 + >; + }; + + pinctrl_hdmi_ddc: hdmiddcgrp { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__HDMI_TX_DDC_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__HDMI_TX_DDC_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6QDL_PAD_EIM_EB2__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_EIM_D16__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX6QDL_PAD_GPIO_3__I2C3_SCL 0x4001b8b1 + MX6QDL_PAD_GPIO_6__I2C3_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3_recovery: i2c3recoverygrp { + fsl,pins = < + MX6QDL_PAD_GPIO_3__GPIO1_IO03 0x4001b8b1 + MX6QDL_PAD_GPIO_6__GPIO1_IO06 0x4001b8b1 + >; + }; + + pinctrl_ipu1_lcdif: ipu1lcdifgrp { + fsl,pins = < + MX6QDL_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK 0xa1 + MX6QDL_PAD_DI0_PIN15__IPU1_DI0_PIN15 0xa1 + MX6QDL_PAD_DI0_PIN2__IPU1_DI0_PIN02 0xa1 + MX6QDL_PAD_DI0_PIN3__IPU1_DI0_PIN03 0xa1 + MX6QDL_PAD_DISP0_DAT0__IPU1_DISP0_DATA00 0xa1 + MX6QDL_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 0xa1 + MX6QDL_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 0xa1 + MX6QDL_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 0xa1 + MX6QDL_PAD_DISP0_DAT4__IPU1_DISP0_DATA04 0xa1 + MX6QDL_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 0xa1 + MX6QDL_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 0xa1 + MX6QDL_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 0xa1 + MX6QDL_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 0xa1 + MX6QDL_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 0xa1 + MX6QDL_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 0xa1 + MX6QDL_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 0xa1 + MX6QDL_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 0xa1 + MX6QDL_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 0xa1 + MX6QDL_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 0xa1 + MX6QDL_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 0xa1 + MX6QDL_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 0xa1 + MX6QDL_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 0xa1 + >; + }; + + pinctrl_mmc_cd: gpiommccd { + fsl,pins = < + MX6QDL_PAD_NANDF_D5__GPIO2_IO05 0x1b0b1 + >; + }; + + pinctrl_pwm1: pwm1grp { + fsl,pins = < + MX6QDL_PAD_GPIO_9__PWM1_OUT 0x1b0b1 + >; + }; + + pinctrl_pwm2: pwm2grp { + fsl,pins = < + MX6QDL_PAD_GPIO_1__PWM2_OUT 0x1b0b1 + MX6QDL_PAD_EIM_A21__GPIO2_IO17 0x00040 + >; + }; + + pinctrl_pwm3: pwm3grp { + fsl,pins = < + MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x1b0b1 + MX6QDL_PAD_EIM_A22__GPIO2_IO16 0x00040 + >; + }; + + pinctrl_pwm4: pwm4grp { + fsl,pins = < + MX6QDL_PAD_SD4_DAT2__PWM4_OUT 0x1b0b1 + >; + }; + + pinctrl_regulator_usbh_pwr: gpioregusbhpwrgrp { + fsl,pins = < + /* SODIMM 129 USBH_PEN */ + MX6QDL_PAD_EIM_D31__GPIO3_IO31 0x0f058 + >; + }; + + pinctrl_uart1_dce: uart1dcegrp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT10__UART1_TX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT11__UART1_RX_DATA 0x1b0b1 + >; + }; + + /* DTE mode */ + pinctrl_uart1_dte: uart1dtegrp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT10__UART1_RX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT11__UART1_TX_DATA 0x1b0b1 + MX6QDL_PAD_EIM_D19__UART1_RTS_B 0x1b0b1 + MX6QDL_PAD_EIM_D20__UART1_CTS_B 0x1b0b1 + >; + }; + + /* Additional DTR, DSR, DCD */ + pinctrl_uart1_ctrl: uart1ctrlgrp { + fsl,pins = < + MX6QDL_PAD_EIM_D23__UART1_DCD_B 0x1b0b0 + MX6QDL_PAD_EIM_D24__UART1_DTR_B 0x1b0b0 + MX6QDL_PAD_EIM_D25__UART1_DSR_B 0x1b0b0 + >; + }; + + pinctrl_uart2_dte: uart2dtegrp { + fsl,pins = < + MX6QDL_PAD_SD4_DAT4__UART2_TX_DATA 0x1b0b1 + MX6QDL_PAD_SD4_DAT7__UART2_RX_DATA 0x1b0b1 + MX6QDL_PAD_SD4_DAT6__UART2_RTS_B 0x1b0b1 + MX6QDL_PAD_SD4_DAT5__UART2_CTS_B 0x1b0b1 + >; + }; + + pinctrl_uart3_dte: uart3dtegrp { + fsl,pins = < + MX6QDL_PAD_SD4_CLK__UART3_TX_DATA 0x1b0b1 + MX6QDL_PAD_SD4_CMD__UART3_RX_DATA 0x1b0b1 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX6QDL_PAD_SD1_CMD__SD1_CMD 0x17071 + MX6QDL_PAD_SD1_CLK__SD1_CLK 0x10071 + MX6QDL_PAD_SD1_DAT0__SD1_DATA0 0x17071 + MX6QDL_PAD_SD1_DAT1__SD1_DATA1 0x17071 + MX6QDL_PAD_SD1_DAT2__SD1_DATA2 0x17071 + MX6QDL_PAD_SD1_DAT3__SD1_DATA3 0x17071 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10059 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x17059 + MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x17059 + MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x17059 + MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x17059 + /* eMMC reset */ + MX6QDL_PAD_SD3_RST__SD3_RESET 0x17059 + >; + }; +}; diff --git a/board/toradex/colibri_imx6/MAINTAINERS b/board/toradex/colibri_imx6/MAINTAINERS index 49999d8cf5..e25c07306c 100644 --- a/board/toradex/colibri_imx6/MAINTAINERS +++ b/board/toradex/colibri_imx6/MAINTAINERS @@ -1,7 +1,9 @@ Colibri iMX6 M: Max Krummenacher max.krummenacher@toradex.com W: http://developer.toradex.com/software/linux/linux-software +W: https://www.toradex.com/community S: Maintained F: board/toradex/colibri_imx6/ F: include/configs/colibri_imx6.h F: configs/colibri_imx6_defconfig +F: arch/arm/dts/imx6-colibri.dts diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 84fa427c8c..47e05b0b26 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -45,6 +45,8 @@ CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx6-colibri" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DFU_MMC=y @@ -64,5 +66,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_VIDEO=y CONFIG_FAT_WRITE=y -CONFIG_OF_LIBFDT=y CONFIG_OF_LIBFDT_OVERLAY=y
From: Marcel Ziswiler marcel.ziswiler@toradex.com Migrate to using device tree required for further driver model integration. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Migrate GPIOs to using driver model, properly request backlight, MMC/SD card detect and USB power enable GPIOs and also enable SION bit in pin muxing for auxiliary, backlight and USB power enable GPIOs.
While at it also update copyright year, clean-up/re-order includes, add some comments clarifying ifdef scope and do some white-space clean-up.
board/toradex/colibri_imx6/colibri_imx6.c | 209 ++++++++++++++-------- configs/colibri_imx6_defconfig | 1 + 2 files changed, 135 insertions(+), 75 deletions(-)
diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index 68c0c02a8a..1f5de2f5f6 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -2,39 +2,34 @@ /* * Copyright (C) 2010-2013 Freescale Semiconductor, Inc. * Copyright (C) 2013, Boundary Devices info@boundarydevices.com - * Copyright (C) 2014-2016, Toradex AG + * Copyright (C) 2014-2019, Toradex AG * copied from nitrogen6x */
#include <common.h> #include <dm.h> + #include <asm/arch/clock.h> #include <asm/arch/crm_regs.h> #include <asm/arch/imx-regs.h> -#include <asm/arch/iomux.h> -#include <asm/arch/mx6-pins.h> #include <asm/arch/mx6-ddr.h> +#include <asm/arch/mx6-pins.h> #include <asm/arch/mxc_hdmi.h> #include <asm/arch/sys_proto.h> #include <asm/bootm.h> #include <asm/gpio.h> +#include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/sata.h> -#include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/video.h> -#include <asm/io.h> #include <dm/platform_data/serial_mxc.h> -#include <dm/platdata.h> +#include <environment.h> #include <fsl_esdhc.h> #include <i2c.h> -#include <input.h> #include <imx_thermal.h> -#include <linux/errno.h> -#include <malloc.h> #include <micrel.h> #include <miiphy.h> -#include <mmc.h> #include <netdev.h>
#include "../common/tdx-cfg-block.h" @@ -173,68 +168,123 @@ static void setup_iomux_enet(void) /* mux auxiliary pins to GPIO, so they can be used from the U-Boot cmdline */ iomux_v3_cfg_t const gpio_pads[] = { /* ADDRESS[17:18] [25] used as GPIO */ - MX6_PAD_KEY_ROW2__GPIO4_IO11 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_KEY_COL2__GPIO4_IO10 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_NANDF_D1__GPIO2_IO01 | MUX_PAD_CTRL(WEAK_PULLUP), + MX6_PAD_KEY_ROW2__GPIO4_IO11 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_KEY_COL2__GPIO4_IO10 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_NANDF_D1__GPIO2_IO01 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, /* ADDRESS[19:24] used as GPIO */ - MX6_PAD_DISP0_DAT23__GPIO5_IO17 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_DISP0_DAT22__GPIO5_IO16 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_DISP0_DAT21__GPIO5_IO15 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_DISP0_DAT20__GPIO5_IO14 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_DISP0_DAT19__GPIO5_IO13 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_DISP0_DAT18__GPIO5_IO12 | MUX_PAD_CTRL(WEAK_PULLUP), + MX6_PAD_DISP0_DAT23__GPIO5_IO17 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_DISP0_DAT22__GPIO5_IO16 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_DISP0_DAT21__GPIO5_IO15 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_DISP0_DAT20__GPIO5_IO14 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_DISP0_DAT19__GPIO5_IO13 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_DISP0_DAT18__GPIO5_IO12 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, /* DATA[16:29] [31] used as GPIO */ - MX6_PAD_EIM_LBA__GPIO2_IO27 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_EIM_BCLK__GPIO6_IO31 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_NANDF_CS3__GPIO6_IO16 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_NANDF_CS1__GPIO6_IO14 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_NANDF_RB0__GPIO6_IO10 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_NANDF_ALE__GPIO6_IO08 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_NANDF_WP_B__GPIO6_IO09 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_NANDF_CS0__GPIO6_IO11 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_NANDF_CLE__GPIO6_IO07 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_GPIO_19__GPIO4_IO05 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_CSI0_MCLK__GPIO5_IO19 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_CSI0_PIXCLK__GPIO5_IO18 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_GPIO_4__GPIO1_IO04 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_GPIO_5__GPIO1_IO05 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_GPIO_2__GPIO1_IO02 | MUX_PAD_CTRL(WEAK_PULLUP), + MX6_PAD_EIM_LBA__GPIO2_IO27 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_EIM_BCLK__GPIO6_IO31 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_NANDF_CS3__GPIO6_IO16 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_NANDF_CS1__GPIO6_IO14 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_NANDF_RB0__GPIO6_IO10 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_NANDF_ALE__GPIO6_IO08 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_NANDF_WP_B__GPIO6_IO09 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_NANDF_CS0__GPIO6_IO11 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_NANDF_CLE__GPIO6_IO07 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_GPIO_19__GPIO4_IO05 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_CSI0_MCLK__GPIO5_IO19 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_CSI0_PIXCLK__GPIO5_IO18 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_GPIO_4__GPIO1_IO04 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_GPIO_5__GPIO1_IO05 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_GPIO_2__GPIO1_IO02 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, /* DQM[0:3] used as GPIO */ - MX6_PAD_EIM_EB0__GPIO2_IO28 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_EIM_EB1__GPIO2_IO29 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_SD2_DAT2__GPIO1_IO13 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_NANDF_D0__GPIO2_IO00 | MUX_PAD_CTRL(WEAK_PULLUP), + MX6_PAD_EIM_EB0__GPIO2_IO28 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_EIM_EB1__GPIO2_IO29 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_SD2_DAT2__GPIO1_IO13 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_NANDF_D0__GPIO2_IO00 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, /* RDY used as GPIO */ - MX6_PAD_EIM_WAIT__GPIO5_IO00 | MUX_PAD_CTRL(WEAK_PULLUP), + MX6_PAD_EIM_WAIT__GPIO5_IO00 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, /* ADDRESS[16] DATA[30] used as GPIO */ - MX6_PAD_KEY_ROW4__GPIO4_IO15 | MUX_PAD_CTRL(WEAK_PULLDOWN), - MX6_PAD_KEY_COL4__GPIO4_IO14 | MUX_PAD_CTRL(WEAK_PULLUP), + MX6_PAD_KEY_ROW4__GPIO4_IO15 | MUX_PAD_CTRL(WEAK_PULLDOWN) | + MUX_MODE_SION, + MX6_PAD_KEY_COL4__GPIO4_IO14 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, /* CSI pins used as GPIO */ - MX6_PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_SD2_CMD__GPIO1_IO11 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_NANDF_CS2__GPIO6_IO15 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_EIM_D18__GPIO3_IO18 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_EIM_A19__GPIO2_IO19 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_EIM_D29__GPIO3_IO29 | MUX_PAD_CTRL(WEAK_PULLDOWN), - MX6_PAD_EIM_A23__GPIO6_IO06 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_EIM_A20__GPIO2_IO18 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_EIM_A17__GPIO2_IO21 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_EIM_A18__GPIO2_IO20 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_EIM_EB3__GPIO2_IO31 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_EIM_D17__GPIO3_IO17 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_SD2_DAT0__GPIO1_IO15 | MUX_PAD_CTRL(WEAK_PULLUP), + MX6_PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_SD2_CMD__GPIO1_IO11 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_NANDF_CS2__GPIO6_IO15 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_EIM_D18__GPIO3_IO18 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_EIM_A19__GPIO2_IO19 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_EIM_D29__GPIO3_IO29 | MUX_PAD_CTRL(WEAK_PULLDOWN) | + MUX_MODE_SION, + MX6_PAD_EIM_A23__GPIO6_IO06 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_EIM_A20__GPIO2_IO18 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_EIM_A17__GPIO2_IO21 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_EIM_A18__GPIO2_IO20 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_EIM_EB3__GPIO2_IO31 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_EIM_D17__GPIO3_IO17 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_SD2_DAT0__GPIO1_IO15 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, /* GPIO */ - MX6_PAD_EIM_D26__GPIO3_IO26 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_EIM_D27__GPIO3_IO27 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_NANDF_D6__GPIO2_IO06 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_NANDF_D3__GPIO2_IO03 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_ENET_REF_CLK__GPIO1_IO23 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_DI0_PIN4__GPIO4_IO20 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_SD4_DAT3__GPIO2_IO11 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_NANDF_D4__GPIO2_IO04 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_SD4_DAT0__GPIO2_IO08 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_GPIO_7__GPIO1_IO07 | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_GPIO_8__GPIO1_IO08 | MUX_PAD_CTRL(WEAK_PULLUP), + MX6_PAD_EIM_D26__GPIO3_IO26 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_EIM_D27__GPIO3_IO27 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_NANDF_D6__GPIO2_IO06 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_NANDF_D3__GPIO2_IO03 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_ENET_REF_CLK__GPIO1_IO23 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_DI0_PIN4__GPIO4_IO20 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_SD4_DAT3__GPIO2_IO11 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_NANDF_D4__GPIO2_IO04 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_SD4_DAT0__GPIO2_IO08 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_GPIO_7__GPIO1_IO07 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, + MX6_PAD_GPIO_8__GPIO1_IO08 | MUX_PAD_CTRL(WEAK_PULLUP) | + MUX_MODE_SION, /* USBH_OC */ MX6_PAD_EIM_D30__GPIO3_IO30 | MUX_PAD_CTRL(WEAK_PULLUP), /* USBC_ID */ @@ -249,8 +299,8 @@ static void setup_iomux_gpio(void) }
iomux_v3_cfg_t const usb_pads[] = { - /* USB_PE */ - MX6_PAD_EIM_D31__GPIO3_IO31 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* USBH_PEN */ + MX6_PAD_EIM_D31__GPIO3_IO31 | MUX_PAD_CTRL(NO_PAD_CTRL) | MUX_MODE_SION, # define GPIO_USBH_EN IMX_GPIO_NR(3, 31) };
@@ -292,6 +342,7 @@ int board_ehci_power(int port, int on) case 1: /* Control MXM USBH */ /* Set MXM USBH power enable, '0' means on */ + gpio_request(GPIO_USBH_EN, "USBH_EN"); gpio_direction_output(GPIO_USBH_EN, !on); mdelay(100); break; @@ -300,7 +351,7 @@ int board_ehci_power(int port, int on) } return 0; } -#endif +#endif /* CONFIG_USB_EHCI_MX6 */
#ifdef CONFIG_FSL_ESDHC /* use the following sequence: eMMC, MMC */ @@ -316,6 +367,7 @@ int board_mmc_getcd(struct mmc *mmc)
switch (cfg->esdhc_base) { case USDHC1_BASE_ADDR: + gpio_request(GPIO_MMC_CD, "MMC_CD"); gpio_direction_input(GPIO_MMC_CD); ret = !gpio_get_value(GPIO_MMC_CD); break; @@ -356,7 +408,7 @@ int board_mmc_init(bd_t *bis) }
return status; -#else +#else /* !CONFIG_SPL_BUILD */ struct src *psrc = (struct src *)SRC_BASE_ADDR; unsigned reg = readl(&psrc->sbmr1) >> 11; /* @@ -388,9 +440,9 @@ int board_mmc_init(bd_t *bis) }
return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); -#endif +#endif /* !CONFIG_SPL_BUILD */ } -#endif +#endif /* CONFIG_FSL_ESDHC */
int board_phy_config(struct phy_device *phydev) { @@ -412,6 +464,7 @@ int board_eth_init(bd_t *bis) ret = enable_fec_anatop_clock(0, ENET_50MHZ); if (ret) return ret; + /* set gpr1[ENET_CLK_SEL] */ setbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_ENET_CLK_SEL_MASK);
@@ -421,6 +474,7 @@ int board_eth_init(bd_t *bis) bus = fec_get_miibus(base, -1); if (!bus) return 0; + /* scan PHY 1..7 */ phydev = phy_find_by_mask(bus, 0xff, PHY_INTERFACE_MODE_RMII); if (!phydev) { @@ -428,6 +482,7 @@ int board_eth_init(bd_t *bis) puts("no PHY found\n"); return 0; } + phy_reset(phydev); printf("using PHY at %d\n", phydev->addr); ret = fec_probe(bis, -1, base, bus, phydev); @@ -436,7 +491,8 @@ int board_eth_init(bd_t *bis) free(phydev); free(bus); } -#endif +#endif /* CONFIG_FEC_MXC */ + return 0; }
@@ -452,11 +508,12 @@ static iomux_v3_cfg_t const pwr_intb_pads[] = {
static iomux_v3_cfg_t const backlight_pads[] = { /* Backlight On */ - MX6_PAD_EIM_D26__GPIO3_IO26 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_D26__GPIO3_IO26 | MUX_PAD_CTRL(NO_PAD_CTRL) | MUX_MODE_SION, #define RGB_BACKLIGHT_GP IMX_GPIO_NR(3, 26) /* Backlight PWM, used as GPIO in U-Boot */ MX6_PAD_EIM_A22__GPIO2_IO16 | MUX_PAD_CTRL(NO_PULLUP), - MX6_PAD_SD4_DAT1__GPIO2_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_DAT1__GPIO2_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL) | + MUX_MODE_SION, #define RGB_BACKLIGHTPWM_GP IMX_GPIO_NR(2, 9) };
@@ -619,6 +676,8 @@ static void setup_display(void) imx_iomux_v3_setup_multiple_pads(backlight_pads, ARRAY_SIZE(backlight_pads)); /* use 0 for EDT 7", use 1 for LG fullHD panel */ + gpio_request(RGB_BACKLIGHTPWM_GP, "PWM<A>"); + gpio_request(RGB_BACKLIGHT_GP, "BL_ON"); gpio_direction_output(RGB_BACKLIGHTPWM_GP, 0); gpio_direction_output(RGB_BACKLIGHT_GP, 1); } @@ -1108,7 +1167,7 @@ void reset_cpu(ulong addr) { }
-#endif +#endif /* CONFIG_SPL_BUILD */
static struct mxc_serial_platdata mxc_serial_plat = { .reg = (struct mxc_uart *)UART1_BASE, diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 47e05b0b26..27b85c61dc 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -50,6 +50,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6-colibri" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DFU_MMC=y +CONFIG_DM_GPIO=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y
From: Marcel Ziswiler marcel.ziswiler@toradex.com Migrate GPIOs to using driver model, properly request backlight, MMC/SD card detect and USB power enable GPIOs and also enable SION bit in pin muxing for auxiliary, backlight and USB power enable GPIOs. While at it also update copyright year, clean-up/re-order includes, add some comments clarifying ifdef scope and do some white-space clean-up. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Enable pin control driver as required for further driver model migration.
configs/colibri_imx6_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 27b85c61dc..481d65329f 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -55,6 +55,8 @@ CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y CONFIG_IMX_THERMAL=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y
From: Marcel Ziswiler marcel.ziswiler@toradex.com Enable pin control driver as required for further driver model migration. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Migrate I2C to using driver model.
board/toradex/colibri_imx6/colibri_imx6.c | 50 +-------------------- board/toradex/colibri_imx6/pf0100.c | 54 ++++++++++++----------- configs/colibri_imx6_defconfig | 1 + include/configs/colibri_imx6.h | 8 ++-- 4 files changed, 36 insertions(+), 77 deletions(-)
diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index 1f5de2f5f6..f5cfeb30bc 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -20,13 +20,11 @@ #include <asm/gpio.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/iomux-v3.h> -#include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/sata.h> #include <asm/mach-imx/video.h> #include <dm/platform_data/serial_mxc.h> #include <environment.h> #include <fsl_esdhc.h> -#include <i2c.h> #include <imx_thermal.h> #include <micrel.h> #include <miiphy.h> @@ -50,16 +48,6 @@ DECLARE_GLOBAL_DATA_PTR; #define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
-#define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) - -#define BUTTON_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) - -#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ - PAD_CTL_ODE | PAD_CTL_SRE_FAST) - #define WEAK_PULLUP (PAD_CTL_PUS_100K_UP | \ PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ PAD_CTL_SRE_SLOW) @@ -72,8 +60,6 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ PAD_CTL_HYS | PAD_CTL_SRE_SLOW)
-#define OUTPUT_40OHM (PAD_CTL_SPEED_MED|PAD_CTL_DSE_40ohm) - #define OUTPUT_RGB (PAD_CTL_SPEED_MED|PAD_CTL_DSE_60ohm|PAD_CTL_SRE_FAST)
int dram_init(void) @@ -91,36 +77,7 @@ iomux_v3_cfg_t const uart1_pads[] = { MX6_PAD_CSI0_DAT11__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
-#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) -/* Colibri I2C */ -struct i2c_pads_info i2c_pad_info1 = { - .scl = { - .i2c_mode = MX6_PAD_GPIO_3__I2C3_SCL | PC, - .gpio_mode = MX6_PAD_GPIO_3__GPIO1_IO03 | PC, - .gp = IMX_GPIO_NR(1, 3) - }, - .sda = { - .i2c_mode = MX6_PAD_GPIO_6__I2C3_SDA | PC, - .gpio_mode = MX6_PAD_GPIO_6__GPIO1_IO06 | PC, - .gp = IMX_GPIO_NR(1, 6) - } -}; - -/* Colibri local, PMIC, SGTL5000, STMPE811 */ -struct i2c_pads_info i2c_pad_info_loc = { - .scl = { - .i2c_mode = MX6_PAD_EIM_EB2__I2C2_SCL | PC, - .gpio_mode = MX6_PAD_EIM_EB2__GPIO2_IO30 | PC, - .gp = IMX_GPIO_NR(2, 30) - }, - .sda = { - .i2c_mode = MX6_PAD_EIM_D16__I2C2_SDA | PC, - .gpio_mode = MX6_PAD_EIM_D16__GPIO3_IO16 | PC, - .gp = IMX_GPIO_NR(3, 16) - } -}; - -/* Apalis MMC */ +/* Colibri MMC */ iomux_v3_cfg_t const usdhc1_pads[] = { MX6_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), MX6_PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), @@ -706,9 +663,6 @@ int board_init(void) /* address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info_loc); - #if defined(CONFIG_VIDEO_IPUV3) setup_display(); #endif @@ -1141,7 +1095,7 @@ void board_init_f(ulong dummy) ccgr_init(); gpr_init();
- /* iomux and setup of i2c */ + /* iomux */ board_early_init_f();
/* setup GP timer */ diff --git a/board/toradex/colibri_imx6/pf0100.c b/board/toradex/colibri_imx6/pf0100.c index fa63865670..5e411f1743 100644 --- a/board/toradex/colibri_imx6/pf0100.c +++ b/board/toradex/colibri_imx6/pf0100.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2014-2016, Toradex AG + * Copyright (C) 2014-2019, Toradex AG */
/* @@ -29,22 +29,25 @@ static __maybe_unused iomux_v3_cfg_t const pmic_prog_pads[] = {
unsigned pmic_init(void) { + int rc; + struct udevice *dev = NULL; unsigned programmed = 0; uchar bus = 1; uchar devid, revid, val;
puts("PMIC: "); - if (!((0 == i2c_set_bus_num(bus)) && - (0 == i2c_probe(PFUZE100_I2C_ADDR)))) { - puts("i2c bus failed\n"); + rc = i2c_get_chip_for_busnum(bus, PFUZE100_I2C_ADDR, 1, &dev); + if (rc) { + printf("failed to get device for PMIC at address 0x%x\n", + PFUZE100_I2C_ADDR); return 0; } /* get device ident */ - if (i2c_read(PFUZE100_I2C_ADDR, PFUZE100_DEVICEID, 1, &devid, 1) < 0) { + if (dm_i2c_read(dev, PFUZE100_DEVICEID, &devid, 1) < 0) { puts("i2c pmic devid read failed\n"); return 0; } - if (i2c_read(PFUZE100_I2C_ADDR, PFUZE100_REVID, 1, &revid, 1) < 0) { + if (dm_i2c_read(dev, PFUZE100_REVID, &revid, 1) < 0) { puts("i2c pmic revid read failed\n"); return 0; } @@ -52,14 +55,14 @@ unsigned pmic_init(void)
#ifdef DEBUG { - unsigned i, j; + unsigned int i, j;
for (i = 0; i < 16; i++) printf("\t%x", i); for (j = 0; j < 0x80; ) { printf("\n%2x", j); for (i = 0; i < 16; i++) { - i2c_read(PFUZE100_I2C_ADDR, j+i, 1, &val, 1); + dm_i2c_read(dev, j + i, &val, 1); printf("\t%2x", val); } j += 0x10; @@ -67,8 +70,7 @@ unsigned pmic_init(void) printf("\nEXT Page 1");
val = PFUZE100_PAGE_REGISTER_PAGE1; - if (i2c_write(PFUZE100_I2C_ADDR, PFUZE100_PAGE_REGISTER, 1, - &val, 1)) { + if (dm_i2c_write(dev, PFUZE100_PAGE_REGISTER, &val, 1)) { puts("i2c write failed\n"); return 0; } @@ -76,7 +78,7 @@ unsigned pmic_init(void) for (j = 0x80; j < 0x100; ) { printf("\n%2x", j); for (i = 0; i < 16; i++) { - i2c_read(PFUZE100_I2C_ADDR, j+i, 1, &val, 1); + dm_i2c_read(dev, j + i, &val, 1); printf("\t%2x", val); } j += 0x10; @@ -84,8 +86,7 @@ unsigned pmic_init(void) printf("\nEXT Page 2");
val = PFUZE100_PAGE_REGISTER_PAGE2; - if (i2c_write(PFUZE100_I2C_ADDR, PFUZE100_PAGE_REGISTER, 1, - &val, 1)) { + if (dm_i2c_write(dev, PFUZE100_PAGE_REGISTER, &val, 1)) { puts("i2c write failed\n"); return 0; } @@ -93,35 +94,36 @@ unsigned pmic_init(void) for (j = 0x80; j < 0x100; ) { printf("\n%2x", j); for (i = 0; i < 16; i++) { - i2c_read(PFUZE100_I2C_ADDR, j+i, 1, &val, 1); + dm_i2c_read(dev, j + i, &val, 1); printf("\t%2x", val); } j += 0x10; } printf("\n"); } -#endif +#endif /* DEBUG */ + /* get device programmed state */ val = PFUZE100_PAGE_REGISTER_PAGE1; - if (i2c_write(PFUZE100_I2C_ADDR, PFUZE100_PAGE_REGISTER, 1, &val, 1)) { + if (dm_i2c_write(dev, PFUZE100_PAGE_REGISTER, &val, 1)) { puts("i2c write failed\n"); return 0; } - if (i2c_read(PFUZE100_I2C_ADDR, PFUZE100_FUSE_POR1, 1, &val, 1) < 0) { + if (dm_i2c_read(dev, PFUZE100_FUSE_POR1, &val, 1) < 0) { puts("i2c fuse_por read failed\n"); return 0; } if (val & PFUZE100_FUSE_POR_M) programmed++;
- if (i2c_read(PFUZE100_I2C_ADDR, PFUZE100_FUSE_POR2, 1, &val, 1) < 0) { + if (dm_i2c_read(dev, PFUZE100_FUSE_POR2, &val, 1) < 0) { puts("i2c fuse_por read failed\n"); return programmed; } if (val & PFUZE100_FUSE_POR_M) programmed++;
- if (i2c_read(PFUZE100_I2C_ADDR, PFUZE100_FUSE_POR3, 1, &val, 1) < 0) { + if (dm_i2c_read(dev, PFUZE100_FUSE_POR3, &val, 1) < 0) { puts("i2c fuse_por read failed\n"); return programmed; } @@ -146,6 +148,8 @@ unsigned pmic_init(void) #ifndef CONFIG_SPL_BUILD static int pf0100_prog(void) { + int rc; + struct udevice *dev = NULL; unsigned char bus = 1; unsigned char val; unsigned int i; @@ -159,9 +163,10 @@ static int pf0100_prog(void) ARRAY_SIZE(pmic_prog_pads)); gpio_direction_output(PMIC_PROG_VOLTAGE, 0);
- if (!((0 == i2c_set_bus_num(bus)) && - (0 == i2c_probe(PFUZE100_I2C_ADDR)))) { - puts("i2c bus failed\n"); + rc = i2c_get_chip_for_busnum(bus, PFUZE100_I2C_ADDR, 1, &dev); + if (rc) { + printf("failed to get device for PMIC at address 0x%x\n", + PFUZE100_I2C_ADDR); return CMD_RET_FAILURE; }
@@ -169,8 +174,7 @@ static int pf0100_prog(void) switch (pmic_otp_prog[i].cmd) { case pmic_i2c: val = (unsigned char) (pmic_otp_prog[i].value & 0xff); - if (i2c_write(PFUZE100_I2C_ADDR, pmic_otp_prog[i].reg, - 1, &val, 1)) { + if (dm_i2c_write(dev, pmic_otp_prog[i].reg, &val, 1)) { printf("i2c write failed, reg 0x%2x, value 0x%2x\n", pmic_otp_prog[i].reg, val); return CMD_RET_FAILURE; @@ -209,4 +213,4 @@ U_BOOT_CMD( "Program the OTP fuses on the PMIC PF0100", "" ); -#endif +#endif /* CONFIG_SPL_BUILD */ diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 481d65329f..dea6ca6270 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -51,6 +51,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index f029a885d2..e51ec8516f 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -32,12 +32,12 @@ #define CONFIG_MXC_UART_BASE UART1_BASE
/* I2C Configs */ -#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC -#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ -#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ -#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ +#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_MXC_I2C3_SPEED 400000
/* OCOTP Configs */ #ifdef CONFIG_CMD_FUSE
From: Marcel Ziswiler marcel.ziswiler@toradex.com Migrate I2C to using driver model. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Migrate PMIC and regulator to using driver model.
configs/colibri_imx6_defconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index dea6ca6270..6fd050a99f 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -45,6 +45,8 @@ CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6-colibri" CONFIG_ENV_IS_IN_MMC=y @@ -58,6 +60,11 @@ CONFIG_PHY_MICREL=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PFUZE100=y +CONFIG_DM_REGULATOR_FIXED=y CONFIG_IMX_THERMAL=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y
From: Marcel Ziswiler marcel.ziswiler@toradex.com Migrate PMIC and regulator to using driver model. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Migrate MMC to using driver model.
board/toradex/colibri_imx6/colibri_imx6.c | 38 +++-------------------- configs/colibri_imx6_defconfig | 1 + 2 files changed, 5 insertions(+), 34 deletions(-)
diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index f5cfeb30bc..ef4dd0c87c 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -77,6 +77,7 @@ iomux_v3_cfg_t const uart1_pads[] = { MX6_PAD_CSI0_DAT11__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
+#if defined(CONFIG_FSL_ESDHC) && defined(CONFIG_SPL_BUILD) /* Colibri MMC */ iomux_v3_cfg_t const usdhc1_pads[] = { MX6_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), @@ -103,6 +104,7 @@ iomux_v3_cfg_t const usdhc3_pads[] = { MX6_PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), MX6_PAD_SD3_RST__SD3_RESET | MUX_PAD_CTRL(USDHC_PAD_CTRL), }; +#endif /* CONFIG_FSL_ESDHC & CONFIG_SPL_BUILD */
iomux_v3_cfg_t const enet_pads[] = { MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), @@ -310,7 +312,7 @@ int board_ehci_power(int port, int on) } #endif /* CONFIG_USB_EHCI_MX6 */
-#ifdef CONFIG_FSL_ESDHC +#if defined(CONFIG_FSL_ESDHC) && defined(CONFIG_SPL_BUILD) /* use the following sequence: eMMC, MMC */ struct fsl_esdhc_cfg usdhc_cfg[CONFIG_SYS_FSL_USDHC_NUM] = { {USDHC3_BASE_ADDR}, @@ -335,37 +337,6 @@ int board_mmc_getcd(struct mmc *mmc)
int board_mmc_init(bd_t *bis) { -#ifndef CONFIG_SPL_BUILD - s32 status = 0; - u32 index = 0; - - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); - - usdhc_cfg[0].max_bus_width = 8; - usdhc_cfg[1].max_bus_width = 4; - - for (index = 0; index < CONFIG_SYS_FSL_USDHC_NUM; ++index) { - switch (index) { - case 0: - imx_iomux_v3_setup_multiple_pads( - usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); - break; - case 1: - imx_iomux_v3_setup_multiple_pads( - usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); - break; - default: - printf("Warning: you configured more USDHC controllers (%d) then supported by the board (%d)\n", - index + 1, CONFIG_SYS_FSL_USDHC_NUM); - return status; - } - - status |= fsl_esdhc_initialize(bis, &usdhc_cfg[index]); - } - - return status; -#else /* !CONFIG_SPL_BUILD */ struct src *psrc = (struct src *)SRC_BASE_ADDR; unsigned reg = readl(&psrc->sbmr1) >> 11; /* @@ -397,9 +368,8 @@ int board_mmc_init(bd_t *bis) }
return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); -#endif /* !CONFIG_SPL_BUILD */ } -#endif /* CONFIG_FSL_ESDHC */ +#endif /* CONFIG_FSL_ESDHC & CONFIG_SPL_BUILD */
int board_phy_config(struct phy_device *phydev) { diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 6fd050a99f..2ab7db44a8 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -54,6 +54,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y
From: Marcel Ziswiler marcel.ziswiler@toradex.com Migrate MMC to using driver model. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Migrate USB to using driver model.
board/toradex/colibri_imx6/colibri_imx6.c | 23 +---------------------- configs/colibri_imx6_defconfig | 1 + 2 files changed, 2 insertions(+), 22 deletions(-)
diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index ef4dd0c87c..adb5a3df4c 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -289,28 +289,7 @@ int board_ehci_hcd_init(int port) imx_iomux_v3_setup_multiple_pads(usb_pads, ARRAY_SIZE(usb_pads)); return 0; } - -int board_ehci_power(int port, int on) -{ - switch (port) { - case 0: - /* control OTG power */ - /* No special PE for USBC, always on when ID pin signals - host mode */ - break; - case 1: - /* Control MXM USBH */ - /* Set MXM USBH power enable, '0' means on */ - gpio_request(GPIO_USBH_EN, "USBH_EN"); - gpio_direction_output(GPIO_USBH_EN, !on); - mdelay(100); - break; - default: - break; - } - return 0; -} -#endif /* CONFIG_USB_EHCI_MX6 */ +#endif
#if defined(CONFIG_FSL_ESDHC) && defined(CONFIG_SPL_BUILD) /* use the following sequence: eMMC, MMC */ diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 2ab7db44a8..df5a7be39f 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -68,6 +68,7 @@ CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_IMX_THERMAL=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Toradex"
From: Marcel Ziswiler marcel.ziswiler@toradex.com Migrate USB to using driver model. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
From: Max Krummenacher max.krummenacher@toradex.com
This doesn't do anything anymore, probably never did.
Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
board/toradex/colibri_imx6/colibri_imx6.c | 7 ------- include/configs/colibri_imx6.h | 2 -- 2 files changed, 9 deletions(-)
diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index adb5a3df4c..83ecd20b3d 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -646,13 +646,6 @@ int board_late_init(void) } #endif /* CONFIG_BOARD_LATE_INIT */
-#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_SYSTEM_SETUP) -int ft_system_setup(void *blob, bd_t *bd) -{ - return 0; -} -#endif - int checkboard(void) { char it[] = " IT"; diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index e51ec8516f..c782b2924c 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -237,8 +237,6 @@ #define CONFIG_SYS_MMC_ENV_PART 1 #endif
-#define CONFIG_OF_SYSTEM_SETUP - #define CONFIG_CMD_TIME
#endif /* __CONFIG_H */
From: Max Krummenacher max.krummenacher@toradex.com This doesn't do anything anymore, probably never did. Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Print also for Colibri iMX6 512MB IT with 64-bit RAM bus.
board/toradex/colibri_imx6/colibri_imx6.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index 83ecd20b3d..439d38bc29 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -1019,6 +1019,7 @@ static void spl_dram_init(void) case TEMP_AUTOMOTIVE: default: if (is_cpu_type(MXC_CPU_MX6DL)) { + puts("Industrial temperature grade DDR3 timings, 64bit bus width.\n"); ddr_init(mx6dl_dcd_table, ARRAY_SIZE(mx6dl_dcd_table)); } else { puts("Industrial temperature grade DDR3 timings, 32bit bus width.\n");
From: Max Krummenacher max.krummenacher@toradex.com Print also for Colibri iMX6 512MB IT with 64-bit RAM bus. Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Add support for distro boot. This is especially helpful for external devices. There is a global boot command which scans a predefined list of boot targets: run distro_bootcmd
As well as direct boot commands such as: run bootcmd_mmc1 run bootcmd_usb run bootcmd_dhcp ...
Refer to doc/README.distro fo details.
While at it, remove the CONFIG_DRIVE_TYPES define which has not been used and was meant to be used for multi device boot support which is now provided by distroboot.
Signed-off-by: Stefan Agner stefan.agner@toradex.com Acked-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
include/configs/colibri_imx6.h | 23 +++++++++++++++-------- 1 file changed, 15 insertions(+), 8 deletions(-)
diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index c782b2924c..77f884f341 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -100,14 +100,18 @@
#define CONFIG_LOADADDR 0x12000000
-#ifdef CONFIG_CMD_MMC -#define CONFIG_DRIVE_MMC "mmc " +#ifndef CONFIG_SPL_BUILD +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 1) \ + func(USB, usb, 0) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> +#undef BOOTENV_RUN_NET_USB_START +#define BOOTENV_RUN_NET_USB_START "" #else -#define CONFIG_DRIVE_MMC +#define BOOTENV #endif
-#define CONFIG_DRIVE_TYPES CONFIG_DRIVE_MMC - #define DFU_ALT_EMMC_INFO \ "u-boot.imx raw 0x2 0x3ff mmcpart 0;" \ "boot part 0 1;" \ @@ -134,7 +138,9 @@ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ "kernel_addr_r=0x11000000\0" \ - "ramdisk_addr_r=0x12100000\0" + "pxefile_addr_r=0x17100000\0" \ + "ramdisk_addr_r=0x12100000\0" \ + "scriptaddr=0x17000000\0"
#define NFS_BOOTCMD \ "nfsargs=ip=:::::eth0:on root=/dev/nfs rw\0" \ @@ -171,9 +177,10 @@
#define FDT_FILE "imx6dl-colibri-eval-v3.dtb" #define CONFIG_EXTRA_ENV_SETTINGS \ + BOOTENV \ "bootcmd=run emmcboot ; echo ; echo emmcboot failed ; " \ - "run nfsboot ; echo ; echo nfsboot failed ; " \ - "usb start ;" \ + "run distro_bootcmd ; " \ + "usb start ; " \ "setenv stdout serial,vga ; setenv stdin serial,usbkbd\0" \ "boot_file=uImage\0" \ "console=ttymxc0\0" \
From: Stefan Agner stefan.agner@toradex.com Add support for distro boot. This is especially helpful for external devices. There is a global boot command which scans a predefined list of boot targets: run distro_bootcmd As well as direct boot commands such as: run bootcmd_mmc1 run bootcmd_usb run bootcmd_dhcp ... Refer to doc/README.distro fo details. While at it, remove the CONFIG_DRIVE_TYPES define which has not been used and was meant to be used for multi device boot support which is now provided by distroboot. Signed-off-by: Stefan Agner stefan.agner@toradex.com Acked-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
In the linux device tree we use 40Ohm drive strenght. So use the same value in U-Boot.
board/toradex/colibri_imx6/colibri_imx6.c | 24 +++++++++++++---------- 1 file changed, 14 insertions(+), 10 deletions(-)
diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index 439d38bc29..3d72a315b4 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -42,6 +42,10 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_SRE_FAST | PAD_CTL_HYS)
#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_EMMC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ PAD_CTL_SRE_FAST | PAD_CTL_HYS)
@@ -92,16 +96,16 @@ iomux_v3_cfg_t const usdhc1_pads[] = {
/* eMMC */ iomux_v3_cfg_t const usdhc3_pads[] = { - MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), MX6_PAD_SD3_RST__SD3_RESET | MUX_PAD_CTRL(USDHC_PAD_CTRL), }; #endif /* CONFIG_FSL_ESDHC & CONFIG_SPL_BUILD */
From: Max Krummenacher max.krummenacher@toradex.com In the linux device tree we use 40Ohm drive strenght. So use the same value in U-Boot. Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Keep debug code at the end of the function. Use a one line informational message for the PMIC only.
board/toradex/colibri_imx6/pf0100.c | 82 ++++++++++++++--------------- 1 file changed, 41 insertions(+), 41 deletions(-)
diff --git a/board/toradex/colibri_imx6/pf0100.c b/board/toradex/colibri_imx6/pf0100.c index 5e411f1743..09c3cc950a 100644 --- a/board/toradex/colibri_imx6/pf0100.c +++ b/board/toradex/colibri_imx6/pf0100.c @@ -35,7 +35,7 @@ unsigned pmic_init(void) uchar bus = 1; uchar devid, revid, val;
- puts("PMIC: "); + puts("PMIC: "); rc = i2c_get_chip_for_busnum(bus, PFUZE100_I2C_ADDR, 1, &dev); if (rc) { printf("failed to get device for PMIC at address 0x%x\n", @@ -51,7 +51,46 @@ unsigned pmic_init(void) puts("i2c pmic revid read failed\n"); return 0; } - printf("device id: 0x%.2x, revision id: 0x%.2x\n", devid, revid); + printf("device id: 0x%.2x, revision id: 0x%.2x, ", devid, revid); + + /* get device programmed state */ + val = PFUZE100_PAGE_REGISTER_PAGE1; + if (dm_i2c_write(dev, PFUZE100_PAGE_REGISTER, &val, 1)) { + puts("i2c write failed\n"); + return 0; + } + if (dm_i2c_read(dev, PFUZE100_FUSE_POR1, &val, 1) < 0) { + puts("i2c fuse_por read failed\n"); + return 0; + } + if (val & PFUZE100_FUSE_POR_M) + programmed++; + + if (dm_i2c_read(dev, PFUZE100_FUSE_POR2, &val, 1) < 0) { + puts("i2c fuse_por read failed\n"); + return programmed; + } + if (val & PFUZE100_FUSE_POR_M) + programmed++; + + if (dm_i2c_read(dev, PFUZE100_FUSE_POR3, &val, 1) < 0) { + puts("i2c fuse_por read failed\n"); + return programmed; + } + if (val & PFUZE100_FUSE_POR_M) + programmed++; + + switch (programmed) { + case 0: + puts("not programmed\n"); + break; + case 3: + puts("programmed\n"); + break; + default: + puts("undefined programming state\n"); + break; + }
#ifdef DEBUG { @@ -103,45 +142,6 @@ unsigned pmic_init(void) } #endif /* DEBUG */
- /* get device programmed state */ - val = PFUZE100_PAGE_REGISTER_PAGE1; - if (dm_i2c_write(dev, PFUZE100_PAGE_REGISTER, &val, 1)) { - puts("i2c write failed\n"); - return 0; - } - if (dm_i2c_read(dev, PFUZE100_FUSE_POR1, &val, 1) < 0) { - puts("i2c fuse_por read failed\n"); - return 0; - } - if (val & PFUZE100_FUSE_POR_M) - programmed++; - - if (dm_i2c_read(dev, PFUZE100_FUSE_POR2, &val, 1) < 0) { - puts("i2c fuse_por read failed\n"); - return programmed; - } - if (val & PFUZE100_FUSE_POR_M) - programmed++; - - if (dm_i2c_read(dev, PFUZE100_FUSE_POR3, &val, 1) < 0) { - puts("i2c fuse_por read failed\n"); - return programmed; - } - if (val & PFUZE100_FUSE_POR_M) - programmed++; - - switch (programmed) { - case 0: - printf("PMIC: not programmed\n"); - break; - case 3: - printf("PMIC: programmed\n"); - break; - default: - printf("PMIC: undefined programming state\n"); - break; - } - return programmed; }
From: Max Krummenacher max.krummenacher@toradex.com Keep debug code at the end of the function. Use a one line informational message for the PMIC only. Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
If the UART is used in DTE mode the RI and DCD bits in UCR3 become irq enable bits. Both are set to enabled after reset and both likely are pending.
Disable the bits also on UARTs not used in the boot loader to prevent an interrupt storm when Linux enables the UART interrupts.
board/toradex/colibri_imx6/colibri_imx6.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index 3d72a315b4..76b776e17e 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -271,14 +271,21 @@ iomux_v3_cfg_t const usb_pads[] = { * UARTs are used in DTE mode, switch the mode on all UARTs before * any pinmuxing connects a (DCE) output to a transceiver output. */ +#define UCR3 0x88 /* FIFO Control Register */ +#define UCR3_RI BIT(8) /* RIDELT DTE mode */ +#define UCR3_DCD BIT(9) /* DCDDELT DTE mode */ #define UFCR 0x90 /* FIFO Control Register */ -#define UFCR_DCEDTE (1<<6) /* DCE=0 */ +#define UFCR_DCEDTE BIT(6) /* DCE=0 */
static void setup_dtemode_uart(void) { setbits_le32((u32 *)(UART1_BASE + UFCR), UFCR_DCEDTE); setbits_le32((u32 *)(UART2_BASE + UFCR), UFCR_DCEDTE); setbits_le32((u32 *)(UART3_BASE + UFCR), UFCR_DCEDTE); + + clrbits_le32((u32 *)(UART1_BASE + UCR3), UCR3_DCD | UCR3_RI); + clrbits_le32((u32 *)(UART2_BASE + UCR3), UCR3_DCD | UCR3_RI); + clrbits_le32((u32 *)(UART3_BASE + UCR3), UCR3_DCD | UCR3_RI); }
static void setup_iomux_uart(void)
From: Max Krummenacher max.krummenacher@toradex.com If the UART is used in DTE mode the RI and DCD bits in UCR3 become irq enable bits. Both are set to enabled after reset and both likely are pending. Disable the bits also on UARTs not used in the boot loader to prevent an interrupt storm when Linux enables the UART interrupts. Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Colibri iMX6 V1.1 HW can use the PMIC GEN3 to power the NVCC_SD1. Change the settings fused into the PMIC's OTP to powerup with GEN3 set to output 3.3V.
Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Stefan Agner stefan.agner@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
board/toradex/colibri_imx6/pf0100_otp.inc | 16 +++++++++------- 1 file changed, 9 insertions(+), 7 deletions(-)
diff --git a/board/toradex/colibri_imx6/pf0100_otp.inc b/board/toradex/colibri_imx6/pf0100_otp.inc index ce29b95ae2..c3b1f67f81 100644 --- a/board/toradex/colibri_imx6/pf0100_otp.inc +++ b/board/toradex/colibri_imx6/pf0100_otp.inc @@ -5,16 +5,17 @@
// Register Output for PF0100 programmer // Customer: Toradex AG -// Program: Colibri iMX6 +// Program: Colibri iMX6 V1.1 // Sample marking: -// Date: 24.07.2015 -// Time: 10:52:58 +// Date: 01.05.2017 +// Time: 16:22:32 // Generated from Spreadsheet Revision: P1.8
-/* sed commands to get from programmer script to struct */ +/* sed commands to get from programmer script to struct content */ /* sed -e 's/^WRITE_I2C:(..):(..)/{pmic_i2c, 0x\1, 0x\2},/g' -e 's/^DELAY:([0-9]*)/{pmic_delay, 0, \1},/g' pf0100_otp_Colibri_iMX6.txt > pf0100_otp.inc sed -i -e 's/^VPGM:ON/{pmic_vpgm, 0, 1},/g' -e 's/^VPGM:OFF/{pmic_vpgm, 0, 0},/g' pf0100_otp.inc - sed -i -e 's/^PWRON: HIGH/{pmic_pwr, 0, 1},/g' -e 's/^PWRON:LOW/{pmic_pwr, 0, 0},/g' pf0100_otp.inc */ + sed -i -e 's/^PWRON: HIGH/{pmic_pwr, 0, 1},/g' -e 's/^PWRON:LOW/{pmic_pwr, 0, 0},/g' pf0100_otp.inc +*/
enum { pmic_i2c, pmic_delay, pmic_vpgm, pmic_pwr }; struct pmic_otp_prog_t{ @@ -47,7 +48,8 @@ struct pmic_otp_prog_t pmic_otp_prog[] = { {pmic_i2c, 0xC8, 0x0E}, // Auto gen from Row134 {pmic_i2c, 0xCC, 0x0E}, // Auto gen from Row138 {pmic_i2c, 0xCD, 0x05}, // Auto gen from Row139 -{pmic_i2c, 0xD0, 0x0C}, // Auto gen from Row142 +{pmic_i2c, 0xD0, 0x0F}, // Auto gen from Row142 +{pmic_i2c, 0xD1, 0x05}, // Auto gen from Row143 {pmic_i2c, 0xD5, 0x07}, // Auto gen from Row147 {pmic_i2c, 0xD8, 0x07}, // Auto gen from Row150 {pmic_i2c, 0xD9, 0x06}, // Auto gen from Row151 @@ -185,4 +187,4 @@ struct pmic_otp_prog_t pmic_otp_prog[] = { {pmic_delay, 0, 500}, {pmic_pwr, 0, 1}, #endif -}; \ No newline at end of file +};
From: Max Krummenacher max.krummenacher@toradex.com Colibri iMX6 V1.1 HW can use the PMIC GEN3 to power the NVCC_SD1. Change the settings fused into the PMIC's OTP to powerup with GEN3 set to output 3.3V. Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Stefan Agner stefan.agner@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Applied to u-boot-imx, -next, thanks !
Best regards, Stefano Babic
We have two commands to change the bootmode fuses: mfgr_fuse which set fuse 0/5 and 0/6 and updt_fuse which burns bit 4 of 0/5.
Before Image 2.6 we fused in mfgr_fuse 0x5062, which boots from the user partition of the eMMC. To workaround certain hangs we moved to fastboot mode and using the first bootpartition of the eMMC requiring a fuse value of 0x5072 which could be achived by the then added updt_fuse command. At the same time the mfgr_fuse command was changed to also fuse 0x5072, revert that second change so that one can fuse both values, one with just mfgr_fuse and the later with mfgr_fuse;updt_fuse.
Note that the mfgr_fuse command is only needed at module production time, a customer might need to use updt_fuse when upgrading an older module to be compatible with a newer image. The command is integrated into the image update scripts.
board/toradex/colibri_imx6/do_fuse.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/toradex/colibri_imx6/do_fuse.c b/board/toradex/colibri_imx6/do_fuse.c index e6793e366a..22d191f52a 100644 --- a/board/toradex/colibri_imx6/do_fuse.c +++ b/board/toradex/colibri_imx6/do_fuse.c @@ -29,7 +29,7 @@ static int mfgr_fuse(void) return CMD_RET_FAILURE; } /* boot cfg */ - fuse_prog(0, 5, 0x00005072); + fuse_prog(0, 5, 0x00005062); /* BT_FUSE_SEL */ fuse_prog(0, 6, 0x00000010); return CMD_RET_SUCCESS;
From: Max Krummenacher max.krummenacher@toradex.com We have two commands to change the bootmode fuses: mfgr_fuse which set fuse 0/5 and 0/6 and updt_fuse which burns bit 4 of 0/5. Before Image 2.6 we fused in mfgr_fuse 0x5062, which boots from the user partition of the eMMC. To workaround certain hangs we moved to fastboot mode and using the first bootpartition of the eMMC requiring a fuse value of 0x5072 which could be achived by the then added updt_fuse command. At the same time the mfgr_fuse command was changed to also fuse 0x5072, revert that second change so that one can fuse both values, one with just mfgr_fuse and the later with mfgr_fuse;updt_fuse. Note that the mfgr_fuse command is only needed at module production time, a customer might need to use updt_fuse when upgrading an older module to be compatible with a newer image. The command is integrated into the image update scripts. Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Stefan Agner stefan.agner@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
From: Bhuvanchandra DV bhuvanchandra.dv@toradex.com
Make sure CMA memory is not greater than 50% of available physical memory.
Allow user to change the CMA memory via 'cma-size' U-Boot environment variable.
Signed-off-by: Bhuvanchandra DV bhuvanchandra.dv@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
board/toradex/colibri_imx6/colibri_imx6.c | 14 +++++++++++++- 1 file changed, 13 insertions(+), 1 deletion(-)
diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index 76b776e17e..fd988bd2b0 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -22,6 +22,7 @@ #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/sata.h> #include <asm/mach-imx/video.h> +#include <cpu.h> #include <dm/platform_data/serial_mxc.h> #include <environment.h> #include <fsl_esdhc.h> @@ -679,7 +680,18 @@ int checkboard(void) #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, bd_t *bd) { - return ft_common_board_setup(blob, bd); + u32 cma_size; + + ft_common_board_setup(blob, bd); + + cma_size = getenv_ulong("cma-size", 10, 320 * 1024 * 1024); + cma_size = min((u32)(gd->ram_size >> 1), cma_size); + + fdt_setprop_u32(blob, + fdt_path_offset(blob, "/reserved-memory/linux,cma"), + "size", + cma_size); + return 0; } #endif
From: Bhuvanchandra DV bhuvanchandra.dv@toradex.com Make sure CMA memory is not greater than 50% of available physical memory. Allow user to change the CMA memory via 'cma-size' U-Boot environment variable. Signed-off-by: Bhuvanchandra DV bhuvanchandra.dv@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Use ext4 file system by default.
Signed-off-by: Sanchayan Maity maitysanchayan@gmail.com Acked-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
include/configs/colibri_imx6.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 77f884f341..6e056aab31 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -121,7 +121,7 @@ "imx6q-colibri-cam-eval-v3.dtb fat 0 1"
#define EMMC_BOOTCMD \ - "emmcargs=ip=off root=/dev/mmcblk0p2 rw,noatime rootfstype=ext3 " \ + "emmcargs=ip=off root=/dev/mmcblk0p2 rw,noatime rootfstype=ext4 " \ "rootwait\0" \ "emmcboot=run setup; " \ "setenv bootargs ${defargs} ${emmcargs} ${setupargs} " \ @@ -153,7 +153,7 @@ "&& setenv dtbparam " - ${fdt_addr_r}" && true\0"
#define SD_BOOTCMD \ - "sdargs=ip=off root=/dev/mmcblk1p2 rw,noatime rootfstype=ext3 " \ + "sdargs=ip=off root=/dev/mmcblk1p2 rw,noatime rootfstype=ext4 " \ "rootwait\0" \ "sdboot=run setup; " \ "setenv bootargs ${defargs} ${sdargs} ${setupargs} " \ @@ -165,7 +165,7 @@ "${fdt_file} && setenv dtbparam " - ${fdt_addr_r}" && true\0"
#define USB_BOOTCMD \ - "usbargs=ip=off root=/dev/sda2 rw,noatime rootfstype=ext3 " \ + "usbargs=ip=off root=/dev/sda2 rw,noatime rootfstype=ext4 " \ "rootwait\0" \ "usbboot=run setup; setenv bootargs ${defargs} ${setupargs} " \ "${usbargs} ${vidargs}; echo Booting from USB stick...; " \
From: Sanchayan Maity maitysanchayan@gmail.com Use ext4 file system by default. Signed-off-by: Sanchayan Maity maitysanchayan@gmail.com Acked-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
In case USB serial downloader has been used to load U-Boot start the serial download protocol (SDP) emulation. This allows to download complete images such as Toradex Easy Installer over USB SDP as well. This code uses the boot ROM provided boot information to reliably detect USB serial downloader.
Signed-off-by: Stefan Agner stefan.agner@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
board/toradex/colibri_imx6/colibri_imx6.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index fd988bd2b0..4d9032419a 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -654,6 +654,14 @@ int board_late_init(void) env_set("board_rev", env_str); #endif
+#ifdef CONFIG_CMD_USB_SDP + if (is_boot_from_usb()) { + printf("Serial Downloader recovery mode, using sdp command\n"); + env_set("bootdelay", "0"); + env_set("bootcmd", "sdp 0"); + } +#endif /* CONFIG_CMD_USB_SDP */ + return 0; } #endif /* CONFIG_BOARD_LATE_INIT */ @@ -684,7 +692,7 @@ int ft_board_setup(void *blob, bd_t *bd)
- cma_size = getenv_ulong("cma-size", 10, 320 * 1024 * 1024); + cma_size = env_get_ulong("cma-size", 10, 320 * 1024 * 1024); cma_size = min((u32)(gd->ram_size >> 1), cma_size);
From: Stefan Agner stefan.agner@toradex.com In case USB serial downloader has been used to load U-Boot start the serial download protocol (SDP) emulation. This allows to download complete images such as Toradex Easy Installer over USB SDP as well. This code uses the boot ROM provided boot information to reliably detect USB serial downloader. Signed-off-by: Stefan Agner stefan.agner@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Switch to the generic compressed Kernel image type (zImage) instead of the U-Boot specific uImage format.
While at it also fix device tree naming for MMC DFU.
include/configs/colibri_imx6.h | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 6e056aab31..a6a823ee1f 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -108,17 +108,17 @@ #include <config_distro_bootcmd.h> #undef BOOTENV_RUN_NET_USB_START #define BOOTENV_RUN_NET_USB_START "" -#else +#else /* CONFIG_SPL_BUILD */ #define BOOTENV -#endif +#endif /* CONFIG_SPL_BUILD */
#define DFU_ALT_EMMC_INFO \ "u-boot.imx raw 0x2 0x3ff mmcpart 0;" \ "boot part 0 1;" \ "rootfs part 0 2;" \ - "uImage fat 0 1;" \ - "imx6q-colibri-eval-v3.dtb fat 0 1;" \ - "imx6q-colibri-cam-eval-v3.dtb fat 0 1" + "zImage fat 0 1;" \ + "imx6dl-colibri-eval-v3.dtb fat 0 1;" \ + "imx6dl-colibri-cam-eval-v3.dtb fat 0 1"
#define EMMC_BOOTCMD \ "emmcargs=ip=off root=/dev/mmcblk0p2 rw,noatime rootfstype=ext4 " \ @@ -128,7 +128,7 @@ "${vidargs}; echo Booting from internal eMMC chip...; " \ "run emmcdtbload; load mmc 0:1 ${kernel_addr_r} " \ "${boot_file} && run fdt_fixup && " \ - "bootm ${kernel_addr_r} ${dtbparam}\0" \ + "bootz ${kernel_addr_r} ${dtbparam}\0" \ "emmcdtbload=setenv dtbparam; load mmc 0:1 ${fdt_addr_r} " \ "${fdt_file} && setenv dtbparam " - ${fdt_addr_r}" && true\0"
@@ -148,11 +148,11 @@ "setenv bootargs ${defargs} ${nfsargs} ${setupargs} " \ "${vidargs}; echo Booting via DHCP/TFTP/NFS...; " \ "run nfsdtbload; dhcp ${kernel_addr_r} " \ - "&& run fdt_fixup && bootm ${kernel_addr_r} ${dtbparam}\0" \ + "&& run fdt_fixup && bootz ${kernel_addr_r} ${dtbparam}\0" \ "nfsdtbload=setenv dtbparam; tftp ${fdt_addr_r} ${fdt_file} " \ "&& setenv dtbparam " - ${fdt_addr_r}" && true\0"
-#define SD_BOOTCMD \ +#define SD_BOOTCMD \ "sdargs=ip=off root=/dev/mmcblk1p2 rw,noatime rootfstype=ext4 " \ "rootwait\0" \ "sdboot=run setup; " \ @@ -160,7 +160,7 @@ "${vidargs}; echo Booting from SD card; " \ "run sddtbload; load mmc 1:1 ${kernel_addr_r} " \ "${boot_file} && run fdt_fixup && " \ - "bootm ${kernel_addr_r} ${dtbparam}\0" \ + "bootz ${kernel_addr_r} ${dtbparam}\0" \ "sddtbload=setenv dtbparam; load mmc 1:1 ${fdt_addr_r} " \ "${fdt_file} && setenv dtbparam " - ${fdt_addr_r}" && true\0"
@@ -171,7 +171,7 @@ "${usbargs} ${vidargs}; echo Booting from USB stick...; " \ "usb start && run usbdtbload; load usb 0:1 ${kernel_addr_r} " \ "${boot_file} && run fdt_fixup && " \ - "bootm ${kernel_addr_r} ${dtbparam}\0" \ + "bootz ${kernel_addr_r} ${dtbparam}\0" \ "usbdtbload=setenv dtbparam; load usb 0:1 ${fdt_addr_r} " \ "${fdt_file} && setenv dtbparam " - ${fdt_addr_r}" && true\0"
@@ -182,7 +182,7 @@ "run distro_bootcmd ; " \ "usb start ; " \ "setenv stdout serial,vga ; setenv stdin serial,usbkbd\0" \ - "boot_file=uImage\0" \ + "boot_file=zImage\0" \ "console=ttymxc0\0" \ "defargs=enable_wait_mode=off galcore.contiguousSize=50331648\0" \ "dfu_alt_info=" DFU_ALT_EMMC_INFO "\0" \
Hi Marcel,
I would recommend switching to use fitImage instead of zImage.
You can look on display5 board for a reference.
- "zImage fat 0 1;" \
- "imx6dl-colibri-eval-v3.dtb fat 0 1;" \
- "imx6dl-colibri-cam-eval-v3.dtb fat 0 1"
"emmcdtbload=setenv dtbparam; load mmc 0:1 ${fdt_addr_r} " \ "${fdt_file} && setenv dtbparam " - ${fdt_addr_r}""bootz ${kernel_addr_r} ${dtbparam}\0" \
&& true\0" @@ -148,11 +148,11 @@ "setenv bootargs ${defargs} ${nfsargs} ${setupargs} " \ "${vidargs}; echo Booting via DHCP/TFTP/NFS...; " \ "run nfsdtbload; dhcp ${kernel_addr_r} " \
${dtbparam}\0" \
"sddtbload=setenv dtbparam; load mmc 1:1 ${fdt_addr_r} " \ "${fdt_file} && setenv dtbparam " - ${fdt_addr_r}""bootz ${kernel_addr_r} ${dtbparam}\0" \
&& true\0" @@ -171,7 +171,7 @@ "${usbargs} ${vidargs}; echo Booting from USB stick...; " \ "usb start && run usbdtbload; load usb 0:1 ${kernel_addr_r} " \ "${boot_file} && run fdt_fixup && " \
"usbdtbload=setenv dtbparam; load usb 0:1 ${fdt_addr_r} " \ "${fdt_file} && setenv dtbparam " - ${fdt_addr_r}""bootz ${kernel_addr_r} ${dtbparam}\0" \
&& true\0" @@ -182,7 +182,7 @@ "run distro_bootcmd ; " \ "usb start ; " \ "setenv stdout serial,vga ; setenv stdin serial,usbkbd\0" \
- "boot_file=zImage\0" \ "console=ttymxc0\0" \ "defargs=enable_wait_mode=off
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Hi Lukasz
On Fri, 2019-02-08 at 22:42 +0100, Lukasz Majewski wrote:
Hi Marcel,
Thanks, we are, of course, aware of fitImage and we do use it e.g. for the Toradex Easy Installer. However, while our former BSPs still booted from uImage our current BSPs now boot from zImage. In the future, we plan to fully integrate distroboot which basically makes this choice here obsolete anyway.
${dtbparam}\0" \
Lukasz Majewski
Best regards - Mit freundlichen Grüssen - Meilleures salutations
Marcel Ziswiler Platform Manager Embedded Linux
Toradex AG Altsagenstrasse 5 | 6048 Horw/Luzern | Switzerland | T: +41 41 500 48 00 (main line) | Direct: +41 41 500 48 10
From: Bhuvanchandra DV bhuvanchandra.dv@toradex.com Switch to the generic compressed Kernel image type (zImage) instead of the U-Boot specific uImage format. While at it also fix device tree naming for MMC DFU. Signed-off-by: Bhuvanchandra DV bhuvanchandra.dv@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
From: Gerard Salvatella gerard.salvatella@toradex.com
RGMII_RD1 pin (active high, GPIO6_IO27) is triggered on reboot during the SPL phase. This asserts (active low) nReset_Out from the PMIC. Only V1.1 and later Colibri iMX6 modules implement this in hw. Previous versions do not use this pin, so it is safe to leave it enabled at all times.
Signed-off-by: Gerard Salvatella gerard.salvatella@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
board/toradex/colibri_imx6/colibri_imx6.c | 24 +++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index 4d9032419a..98ad87af19 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -30,6 +30,7 @@ #include <micrel.h> #include <miiphy.h> #include <netdev.h> +#include <cpu.h>
#include "../common/tdx-cfg-block.h" #ifdef CONFIG_TDX_CMD_IMX_MFGR @@ -1061,6 +1062,26 @@ static void spl_dram_init(void) udelay(100); }
+static iomux_v3_cfg_t const gpio_reset_pad[] = { + MX6_PAD_RGMII_RD1__GPIO6_IO27 | MUX_PAD_CTRL(NO_PAD_CTRL) | + MUX_MODE_SION +#define GPIO_NRESET IMX_GPIO_NR(6, 27) +}; + +#define IMX_RESET_CAUSE_POR 0x00011 +static void nreset_out(void) +{ + int reset_cause = get_imx_reset_cause(); + + if (reset_cause != IMX_RESET_CAUSE_POR) { + imx_iomux_v3_setup_multiple_pads(gpio_reset_pad, + ARRAY_SIZE(gpio_reset_pad)); + gpio_direction_output(GPIO_NRESET, 1); + udelay(100); + gpio_direction_output(GPIO_NRESET, 0); + } +} + void board_init_f(ulong dummy) { /* setup AIPS and disable watchdog */ @@ -1087,6 +1108,9 @@ void board_init_f(ulong dummy) /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
+ /* Assert nReset_Out */ + nreset_out(); + /* load/boot image from boot device */ board_init_r(NULL, 0); }
From: Gerard Salvatella gerard.salvatella@toradex.com RGMII_RD1 pin (active high, GPIO6_IO27) is triggered on reboot during the SPL phase. This asserts (active low) nReset_Out from the PMIC. Only V1.1 and later Colibri iMX6 modules implement this in hw. Previous versions do not use this pin, so it is safe to leave it enabled at all times. Signed-off-by: Gerard Salvatella gerard.salvatella@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
The PMIC on the Colibri iMX6 may have ECC errors in fuses that will prevent correct settings. Up to one bit error per fuse bank can be reported and corrected by the ECC logic. Two bit errors can only be reported.
board/toradex/colibri_imx6/pf0100.c | 51 +++++++++++++++++++++++++ board/toradex/colibri_imx6/pf0100.h | 59 ++++++++++++++++++++++++++++- 2 files changed, 108 insertions(+), 2 deletions(-)
diff --git a/board/toradex/colibri_imx6/pf0100.c b/board/toradex/colibri_imx6/pf0100.c index 09c3cc950a..e744243297 100644 --- a/board/toradex/colibri_imx6/pf0100.c +++ b/board/toradex/colibri_imx6/pf0100.c @@ -21,6 +21,8 @@ /* define for PMIC register dump */ /*#define DEBUG */
+#define WARNBAR "@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@\n" + /* use GPIO: EXT_IO1 to switch on VPGM, ON: 1 */ static __maybe_unused iomux_v3_cfg_t const pmic_prog_pads[] = { MX6_PAD_NANDF_D3__GPIO2_IO03 | MUX_PAD_CTRL(NO_PAD_CTRL), @@ -42,6 +44,55 @@ unsigned pmic_init(void) PFUZE100_I2C_ADDR); return 0; } + + /* check for errors in PMIC fuses */ + if (dm_i2c_read(dev, PFUZE100_INTSTAT3, &val, 1) < 0) { + puts("i2c pmic INTSTAT3 register read failed\n"); + return 0; + } + if (val & PFUZE100_BIT_OTP_ECCI) { + puts("\n" WARNBAR); + puts("WARNING: ecc errors found in pmic fuse banks\n"); + puts(WARNBAR); + } + if (dm_i2c_read(dev, PFUZE100_OTP_ECC_SE1, &val, 1) < 0) { + puts("i2c pmic ECC_SE1 register read failed\n"); + return 0; + } + if (val & PFUZE100_BITS_ECC_SE1) { + puts(WARNBAR); + puts("WARNING: ecc has made bit corrections in banks 1 to 5\n"); + puts(WARNBAR); + } + if (dm_i2c_read(dev, PFUZE100_OTP_ECC_SE2, &val, 1) < 0) { + puts("i2c pmic ECC_SE2 register read failed\n"); + return 0; + } + if (val & PFUZE100_BITS_ECC_SE2) { + puts(WARNBAR); + puts("WARNING: ecc has made bit corrections in banks 6 to 10\n" + ); + puts(WARNBAR); + } + if (dm_i2c_read(dev, PFUZE100_OTP_ECC_DE1, &val, 1) < 0) { + puts("i2c pmic ECC_DE register read failed\n"); + return 0; + } + if (val & PFUZE100_BITS_ECC_DE1) { + puts(WARNBAR); + puts("ERROR: banks 1 to 5 have uncorrectable bits\n"); + puts(WARNBAR); + } + if (dm_i2c_read(dev, PFUZE100_OTP_ECC_DE2, &val, 1) < 0) { + puts("i2c pmic ECC_DE register read failed\n"); + return 0; + } + if (val & PFUZE100_BITS_ECC_DE2) { + puts(WARNBAR); + puts("ERROR: banks 6 to 10 have uncorrectable bits\n"); + puts(WARNBAR); + } + /* get device ident */ if (dm_i2c_read(dev, PFUZE100_DEVICEID, &devid, 1) < 0) { puts("i2c pmic devid read failed\n"); diff --git a/board/toradex/colibri_imx6/pf0100.h b/board/toradex/colibri_imx6/pf0100.h index c0efb79bbc..9257620511 100644 --- a/board/toradex/colibri_imx6/pf0100.h +++ b/board/toradex/colibri_imx6/pf0100.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright (C) 2014-2016, Toradex AG + * Copyright (C) 2014-2019, Toradex AG */
/* @@ -10,11 +10,23 @@ #ifndef PF0100_H_ #define PF0100_H_
+/* bit definitions */ +#define PFUZE100_BIT_0 (0x01 << 0) +#define PFUZE100_BIT_1 (0x01 << 1) +#define PFUZE100_BIT_2 (0x01 << 2) +#define PFUZE100_BIT_3 (0x01 << 3) +#define PFUZE100_BIT_4 (0x01 << 4) +#define PFUZE100_BIT_5 (0x01 << 5) +#define PFUZE100_BIT_6 (0x01 << 6) +#define PFUZE100_BIT_7 (0x01 << 7) + /* 7-bit I2C bus slave address */ #define PFUZE100_I2C_ADDR (0x08) /* Register Addresses */ #define PFUZE100_DEVICEID (0x0) #define PFUZE100_REVID (0x3) +#define PFUZE100_INTSTAT3 (0xe) +#define PFUZE100_BIT_OTP_ECCI PFUZE100_BIT_7 #define PFUZE100_SW1AMODE (0x23) #define PFUZE100_SW1ACON 36 #define PFUZE100_SW1ACON_SPEED_VAL (0x1<<6) /*default */ @@ -39,12 +51,55 @@ #define PFUZE100_PAGE_REGISTER_PAGE2 (0x02 & PFUZE100_PAGE_REGISTER_PAGE_M)
/* extended page 1 */ +#define PFUZE100_OTP_ECC_SE1 0x8a +#define PFUZE100_BIT_ECC1_SE PFUZE100_BIT_0 +#define PFUZE100_BIT_ECC2_SE PFUZE100_BIT_1 +#define PFUZE100_BIT_ECC3_SE PFUZE100_BIT_2 +#define PFUZE100_BIT_ECC4_SE PFUZE100_BIT_3 +#define PFUZE100_BIT_ECC5_SE PFUZE100_BIT_4 +#define PFUZE100_BITS_ECC_SE1 ((PFUZE100_BIT_ECC1_SE) | \ + (PFUZE100_BIT_ECC2_SE) | \ + (PFUZE100_BIT_ECC3_SE) | \ + (PFUZE100_BIT_ECC4_SE) | \ + (PFUZE100_BIT_ECC5_SE)) +#define PFUZE100_OTP_ECC_SE2 0x8b +#define PFUZE100_BIT_ECC6_SE PFUZE100_BIT_0 +#define PFUZE100_BIT_ECC7_SE PFUZE100_BIT_1 +#define PFUZE100_BIT_ECC8_SE PFUZE100_BIT_2 +#define PFUZE100_BIT_ECC9_SE PFUZE100_BIT_3 +#define PFUZE100_BIT_ECC10_SE PFUZE100_BIT_4 +#define PFUZE100_BITS_ECC_SE2 ((PFUZE100_BIT_ECC6_SE) | \ + (PFUZE100_BIT_ECC7_SE) | \ + (PFUZE100_BIT_ECC8_SE) | \ + (PFUZE100_BIT_ECC9_SE) | \ + (PFUZE100_BIT_ECC10_SE)) +#define PFUZE100_OTP_ECC_DE1 0x8c +#define PFUZE100_BIT_ECC1_DE PFUZE100_BIT_0 +#define PFUZE100_BIT_ECC2_DE PFUZE100_BIT_1 +#define PFUZE100_BIT_ECC3_DE PFUZE100_BIT_2 +#define PFUZE100_BIT_ECC4_DE PFUZE100_BIT_3 +#define PFUZE100_BIT_ECC5_DE PFUZE100_BIT_4 +#define PFUZE100_BITS_ECC_DE1 ((PFUZE100_BIT_ECC1_DE) | \ + (PFUZE100_BIT_ECC2_DE) | \ + (PFUZE100_BIT_ECC3_DE) | \ + (PFUZE100_BIT_ECC4_DE) | \ + (PFUZE100_BIT_ECC5_DE)) +#define PFUZE100_OTP_ECC_DE2 0x8d +#define PFUZE100_BIT_ECC6_DE PFUZE100_BIT_0 +#define PFUZE100_BIT_ECC7_DE PFUZE100_BIT_1 +#define PFUZE100_BIT_ECC8_DE PFUZE100_BIT_2 +#define PFUZE100_BIT_ECC9_DE PFUZE100_BIT_3 +#define PFUZE100_BIT_ECC10_DE PFUZE100_BIT_4 +#define PFUZE100_BITS_ECC_DE2 ((PFUZE100_BIT_ECC6_DE) | \ + (PFUZE100_BIT_ECC7_DE) | \ + (PFUZE100_BIT_ECC8_DE) | \ + (PFUZE100_BIT_ECC9_DE) | \ + (PFUZE100_BIT_ECC10_DE)) #define PFUZE100_FUSE_POR1 0xe4 #define PFUZE100_FUSE_POR2 0xe5 #define PFUZE100_FUSE_POR3 0xe6 #define PFUZE100_FUSE_POR_M (0x1 << 1)
- /* output some informational messages, return the number FUSE_POR=1 */ /* i.e. 0: unprogrammed, 3: programmed, other: undefined prog. state */ unsigned pmic_init(void);
From: Gerard Salvatella gerard.salvatella@toradex.com The PMIC on the Colibri iMX6 may have ECC errors in fuses that will prevent correct settings. Up to one bit error per fuse bank can be reported and corrected by the ECC logic. Two bit errors can only be reported. Signed-off-by: Gerard Salvatella gerard.salvatella@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Hi Stefano
Unfortunately, I can't find that one anywhere on u-boot-imx.git/next.
I will resend it as a separate patch for you to pick up, OK?
BTW: I will also send a V2 of the Colibri Vybrid stuff, plus the Colibri iMX6ULL overhaul and the initial add of the Colibri iMX8QXP.
Cheers
Marcel
On 24/03/19 22:42, Marcel Ziswiler wrote:
Hi Stefano
mmhhh...I have applied them, I see in my local -next, I am sure I pushed before. Let me see why they do not appear on git.denx.de, you do not need to repush, they are alreay applied.
Ok, thanks for info. I set V1 as obsolete in patchwork.
Regards, Stefano
Cheers
Marcel
participants (5)
Lukasz Majewski
Marcel Ziswiler
Marcel Ziswiler
sbabic@denx.de
Stefano Babic
